Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src/lib
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @fc4675f0   09/15/97 19:01:33 Joel Sherrill syslog added 4.104.114.84.95
(edit) @8f35817   09/15/97 18:52:26 Joel Sherrill eliminated potential for overfilling buffer on read 4.104.114.84.95
(edit) @8d05346   09/03/97 22:05:51 Joel Sherrill Fix from Eric Norum. Here is the comment: Enable SDMA … 4.104.114.84.95
(edit) @e9932367   08/28/97 21:54:59 Joel Sherrill Switched to new style which does not require hackspecs.awk. 4.104.114.84.95
(edit) @7d352a49   08/28/97 13:59:41 Joel Sherrill Added RTEMS_IO_ERROR status code. 4.104.114.84.95
(edit) @3473f605   08/27/97 20:33:49 Joel Sherrill Added error numbers and changed default error code from 0 to -1 for … 4.104.114.84.95
(edit) @f80faeb   08/27/97 20:33:11 Joel Sherrill Modified to support the BSP family concept. 4.104.114.84.95
(edit) @49c2f589   08/27/97 20:31:34 Joel Sherrill Modified to have correct address for vector table on multiple models. 4.104.114.84.95
(edit) @12a17af3   08/26/97 18:10:59 Joel Sherrill Corrected to compile with egcs. 4.104.114.84.95
(edit) @b57992a   08/22/97 19:17:54 Joel Sherrill Removed assert condition when not initialized or there are 0 periods. 4.104.114.84.95
(edit) @b1459dc   08/22/97 19:17:09 Joel Sherrill Moved reentrant wrappers into their own file. 4.104.114.84.95
(edit) @78d87bd   08/22/97 19:16:47 Joel Sherrill Fixed iop/memory leak bug reported by Dan Dickey. 4.104.114.84.95
(edit) @8affd6f1   08/22/97 19:16:22 Joel Sherrill Removed redundant stanza. 4.104.114.84.95
(edit) @2d997375   08/22/97 13:08:56 Joel Sherrill start no longer a global symbol per Eric Norum's request. Also, I … 4.104.114.84.95
(edit) @d074e12   08/04/97 22:22:59 Joel Sherrill Switched to new version of mc68681.h 4.104.114.84.95
(edit) @19fd334   08/04/97 22:22:31 Joel Sherrill moved mc68230.h from main include directory to motorola 4.104.114.84.95
(edit) @0789abef   08/04/97 22:17:17 Joel Sherrill new implementation of mc68681.h 4.104.114.84.95
(edit) @89a32784   08/04/97 22:12:39 Joel Sherrill Fixed type 4.104.114.84.95
(edit) @3dd8372   08/04/97 22:03:03 Joel Sherrill Corrected typo 4.104.114.84.95
(edit) @a397c9c1   08/04/97 21:59:14 Joel Sherrill Corrected descent to a hardcoded directory and made it dependent on … 4.104.114.84.95
(edit) @8bc9051   08/04/97 21:58:30 Joel Sherrill Fixed typo and removed duplicated code 4.104.114.84.95
(edit) @4ef9e99   08/04/97 21:58:00 Joel Sherrill First attempt at values for PPC 4.104.114.84.95
(edit) @50b5f9d   08/04/97 21:57:06 Joel Sherrill Trying to support all models 4.104.114.84.95
(edit) @c74169bd   08/04/97 21:56:48 Joel Sherrill Trying to support all models. 4.104.114.84.95
(edit) @c9647b3   08/04/97 21:56:00 Joel Sherrill consolex built for all models. 4.104.114.84.95
(edit) @81d96577   08/04/97 21:55:30 Joel Sherrill moved header files into the motorola and zilog subdirectories 4.104.114.84.95
(edit) @669123e1   08/04/97 21:53:42 Joel Sherrill Correcting difference between mvme162lx and mvme162. All versions … 4.104.114.84.95
(edit) @02d0880   08/04/97 21:50:35 Joel Sherrill moved header files into the motorola and zilog subdirectories 4.104.114.84.95
(edit) @033ec54   08/04/97 21:49:47 Joel Sherrill Modified to reflect changes in mc68681.h header file. 4.104.114.84.95
(edit) @b739617   08/04/97 21:45:27 Joel Sherrill Header files moved into zilog subdirectory. 4.104.114.84.95
(edit) @9b024884   08/04/97 21:44:05 Joel Sherrill Moved files into the zilog and motorola subdirectories. 4.104.114.84.95
(edit) @28a4b1d   08/04/97 21:39:07 Joel Sherrill moved from main include directory 4.104.114.84.95
(edit) @30e3029   08/01/97 20:58:10 Joel Sherrill Added conditional for KA9Q. 4.104.114.84.95
(edit) @1f581ec   08/01/97 20:57:21 Joel Sherrill Added include of termios.h which was accidentally left out. 4.104.114.84.95
(edit) @bcbd75d4   08/01/97 20:56:36 Joel Sherrill Added consolex to wrapup 4.104.114.84.95
(edit) @a7fcfd0   08/01/97 20:56:24 Joel Sherrill Corrected typo. 4.104.114.84.95
(edit) @adf7b5c4   08/01/97 20:15:02 Joel Sherrill Made to work. 4.104.114.84.95
(edit) @29a9e5d   08/01/97 20:14:57 Joel Sherrill Removed warnings. 4.104.114.84.95
(edit) @9deb5b8b   08/01/97 18:12:11 Joel Sherrill Katsutoshi Shibuya (shibuya@…)of BU-Denken Co., Ltd. … 4.104.114.84.95
(edit) @0074691a   07/31/97 22:13:29 Joel Sherrill Merged very large and much appreciated patch from Chris Johns … 4.104.114.84.95
(edit) @91333c2   07/31/97 22:04:17 Joel Sherrill Merged very large and much appreciated patch from Chris Johns … 4.104.114.84.95
(edit) @bf3a7a5a   07/10/97 19:16:40 Joel Sherrill Added information on different MVME162 models. 4.104.114.84.95
(edit) @900a3ab1   07/09/97 23:57:56 Joel Sherrill Repository damaged -- file re-added 4.104.114.84.95
(edit) @1d320bac   07/09/97 23:41:20 Joel Sherrill This code was in the tree but not actually being compiled. There were … 4.104.114.84.95
(edit) @1f0f3e35   05/27/97 23:39:29 Joel Sherrill added ka9q stack 4.104.114.84.95
(edit) @f5bd03c   05/23/97 21:44:19 Joel Sherrill KA9Q stack removed prior to testing for 4.0.0 public release. 4.104.114.84.95
(edit) @edd12702   05/21/97 12:59:40 Joel Sherrill patch from Eric Norum 4.104.114.84.95
(edit) @18647b7   04/25/97 16:58:10 Joel Sherrill updated to reflect new license per John Gwynne's permission. 4.104.114.84.95
(edit) @e71ce071   04/22/97 17:47:16 Joel Sherrill updated with new license information per Tony Bennett. 4.104.114.84.95
(edit) @03f2154e   04/22/97 17:20:27 Joel Sherrill headers updated to reflect new style copyright notice as part of … 4.104.114.84.95
(edit) @5bb2ed07   04/22/97 12:39:23 Joel Sherrill Added support for HW API package 4.104.114.84.95
(edit) @59097e7   04/18/97 18:38:19 Joel Sherrill Changed format of comment blocks to C comments. 4.104.114.84.95
(edit) @7e7143e   04/18/97 18:37:48 Joel Sherrill Duplicated timerisr symbol as _timerisr to avoid tool naming problems. 4.104.114.84.95
(edit) @9fbba98   04/16/97 17:47:48 Joel Sherrill Fixed path which points to shared directory for all BSPs. 4.104.114.84.95
(edit) @334b01f1   04/16/97 17:46:26 Joel Sherrill fixed spacing 4.104.114.84.95
(edit) @f9f375e   04/16/97 17:45:52 Joel Sherrill added fpsp support. 4.104.114.84.95
(edit) @f8f370b6   04/16/97 17:45:35 Joel Sherrill Update from Eric Norum. 4.104.114.84.95
(edit) @010e7582   04/16/97 17:34:23 Joel Sherrill Added CVS Id's 4.104.114.84.95
(edit) @f9b93da   04/16/97 17:33:04 Joel Sherrill Added the MC68040 Floating Point Support Package. This was ported to … 4.104.114.84.95
(edit) @b584751   04/15/97 17:37:12 Joel Sherrill Switched all bsps which had an implementation of sbrk.c which only … 4.104.114.84.95
(edit) @ecc4594   04/15/97 17:28:26 Joel Sherrill Removed many BSPs' copy of setvec.c and let them share the same … 4.104.114.84.95
(edit) @bc7d465   04/11/97 18:41:38 Joel Sherrill replaced linking of source from mvme147 drivers with use of vpath to … 4.104.114.84.95
(edit) @18e5d86   04/11/97 18:40:04 Joel Sherrill removed commented out line performing a link 4.104.114.84.95
(edit) @c46ce854   04/09/97 20:19:07 Joel Sherrill printing task names now instead of id numbers 4.104.114.84.95
(edit) @fc7bc51   04/09/97 20:18:54 Joel Sherrill new files. 4.104.114.84.95
(edit) @9d5152f   04/09/97 20:07:22 Joel Sherrill added rtmonuse and cpuuse directories 4.104.114.84.95
(edit) @8f695a1   04/09/97 20:07:09 Joel Sherrill added cpuuse and rtmonuse directories 4.104.114.84.95
(edit) @e39e6f7   04/09/97 20:05:59 Joel Sherrill added code to prevent attempts to clean up the library when rtems is down. 4.104.114.84.95
(edit) @0956b52   04/09/97 20:05:37 Joel Sherrill correct incorrect register addresses for port a. 4.104.114.84.95
(edit) @8c0dc2c   04/09/97 20:05:12 Joel Sherrill removed unused is_character_ready routine. 4.104.114.84.95
(edit) @e2d79559   04/09/97 14:05:50 Joel Sherrill Added ka9q tcpip stack and network driver for the gen68360. This … 4.104.114.84.95
(edit) @bed475e   04/08/97 11:53:54 Joel Sherrill added cast to eliminate warning. 4.104.114.84.95
(edit) @9ffcaa4a   04/07/97 21:30:58 Joel Sherrill changed signed int to unsigned int to eliminate a warning. 4.104.114.84.95
(edit) @bd71da7   04/07/97 21:30:42 Joel Sherrill removed noreturn attribute to eliminate warnings. 4.104.114.84.95
(edit) @82478528   04/07/97 21:30:16 Joel Sherrill commented out sccs_id's to eliminate warnings. 4.104.114.84.95
(edit) @dd1d1c7   04/07/97 21:29:49 Joel Sherrill added prototype and return statement to eliminate warnings. 4.104.114.84.95
(edit) @f1fc782e   04/07/97 21:29:09 Joel Sherrill commented out sccs_id's to eliminate warnings. main.c: added return … 4.104.114.84.95
(edit) @318976f   04/07/97 21:28:21 Joel Sherrill removed reference to no_bsp. added prototypes. 4.104.114.84.95
(edit) @de1d716   04/07/97 21:27:59 Joel Sherrill commented out sccs_id to eliminate warnings 4.104.114.84.95
(edit) @2938c1a3   04/07/97 21:27:22 Joel Sherrill added or fixed includes of page_table.h to eliminate warnings. 4.104.114.84.95
(edit) @588c9ed   04/07/97 21:26:49 Joel Sherrill added cast to eliminate warning 4.104.114.84.95
(edit) @930b3d5   04/07/97 21:26:34 Joel Sherrill added prototype for delay. 4.104.114.84.95
(edit) @3bc409c   04/07/97 21:26:22 Joel Sherrill added global statement for start entry point 4.104.114.84.95
(edit) @437366f   04/07/97 21:25:42 Joel Sherrill removed noreturn from prototype to avoid warnings. 4.104.114.84.95
(edit) @2bad8aa   04/07/97 21:25:21 Joel Sherrill added cast to eliminate warning. 4.104.114.84.95
(edit) @759a9d9   04/07/97 21:24:28 Joel Sherrill added return statement to avoid warning. 4.104.114.84.95
(edit) @d6ba279   04/07/97 21:24:02 Joel Sherrill added initialization of variable to eliminate warning. 4.104.114.84.95
(edit) @0b50855   04/07/97 21:23:43 Joel Sherrill added include of unistd.h to eliminate warning for no prototype for … 4.104.114.84.95
(edit) @254b4450   04/01/97 23:07:52 Joel Sherrill This set of changes is the build of what was required to convert to … 4.104.114.84.95
(edit) @467eae4d   03/21/97 19:20:40 Joel Sherrill Fixed symbols. 4.104.114.84.95
(edit) @1a3e4fa   03/21/97 19:20:25 Joel Sherrill added decrementer entry. 4.104.114.84.95
(edit) @84e5b57f   03/21/97 19:19:33 Joel Sherrill Removed Fake input ifdef code. 4.104.114.84.95
(edit) @691259b   03/21/97 19:18:11 Joel Sherrill Fixed timerisr symbol. 4.104.114.84.95
(edit) @e667a0b   03/21/97 19:17:46 Joel Sherrill Rewrote to avoid references to C symbols from assembly. This entirely … 4.104.114.84.95
(edit) @51c9fb4   03/21/97 19:17:05 Joel Sherrill Fixes incorrect reference to start symbol. 4.104.114.84.95
(edit) @d0e126a6   03/11/97 15:53:05 Joel Sherrill updates from John Gwynne 4.104.114.84.95
(edit) @6335022e   03/11/97 15:42:59 Joel Sherrill updates from John Gwynne 4.104.114.84.95
(edit) @1dc3500   03/10/97 19:38:30 Joel Sherrill added include of rtems.h so the proper macro definitions would be present. 4.104.114.84.95
(edit) @41c58154   03/10/97 19:38:06 Joel Sherrill made some of this conditional on unix lib 4.104.114.84.95
(edit) @133fb0e5   03/08/97 03:53:37 Joel Sherrill Larger Workspace when it is a POSIX API. Actually this is just to … 4.104.114.84.95
