@d0cff6dc
07/15/98 21:43:00 |
Joel Sherrill |
Added SCV64_Get_Interrupt_Enable().
4.104.114.84.95
@38e717f
07/15/98 21:42:26 |
Joel Sherrill |
Added chip type identifier field. This was necessary because a single …
4.104.114.84.95
@c0573d7
07/15/98 21:40:42 |
Joel Sherrill |
Added comment to remove use of TxBuffer? ring buffer in all libchip …
4.104.114.84.95
@0f61336
07/15/98 19:28:29 |
Joel Sherrill |
Added comments.
4.104.114.84.95
@a69f0ad9
07/15/98 19:20:20 |
Joel Sherrill |
Added comments.
4.104.114.84.95
@100a4e5
07/15/98 19:19:14 |
Joel Sherrill |
Masked out interrupts not being used prior to processing the status …
4.104.114.84.95
@6c45da17
07/15/98 19:12:11 |
Joel Sherrill |
Added routine to return interrupt mask. Added comments.
4.104.114.84.95
@01e54b8
07/15/98 14:06:37 |
Joel Sherrill |
Added scv64 subdirectory.
4.104.114.84.95
@e49ef37c
07/15/98 14:06:08 |
Joel Sherrill |
Switched to SCV64.
4.104.114.84.95
@8f563b9b
07/15/98 14:05:51 |
Joel Sherrill |
Added CSCV64 functions and addresses.
4.104.114.84.95
@30a3f76
07/15/98 14:04:31 |
Joel Sherrill |
Switched from polling to interrupts and in the process added a …
4.104.114.84.95
@437b5a7d
07/15/98 14:00:23 |
Joel Sherrill |
4.104.114.84.95
@090a3511
07/15/98 14:00:09 |
Joel Sherrill |
New files.
4.104.114.84.95
@be8cbbf
07/15/98 13:58:23 |
Joel Sherrill |
Switched deviceOutputUsesInterrupts to TRUE so output would be …
4.104.114.84.95
@e283140c
07/15/98 13:53:58 |
Joel Sherrill |
Switched to "deviceOutput = TRUE" which made device output use interrupts.
4.104.114.84.95
@dbfa3148
07/10/98 15:43:18 |
Joel Sherrill |
Patch from Quality Quorum <qqi@…>. Comments:
4.104.114.84.95
@fb32356b
07/09/98 23:32:07 |
Joel Sherrill |
Added set attributes routine but did not hook it in to the table.
4.104.114.84.95
@abd8c82
07/09/98 23:31:48 |
Joel Sherrill |
Added new files.
4.104.114.84.95
@31cad72c
07/09/98 23:31:26 |
Joel Sherrill |
Renamed so we could have one file per routine.
4.104.114.84.95
@064b9be
07/09/98 23:30:32 |
Joel Sherrill |
Switched to shared default probe routine.
4.104.114.84.95
@693b5b88
07/09/98 23:30:02 |
Joel Sherrill |
Switched to default probe routine.
4.104.114.84.95
@61ff7ac8
07/09/98 23:29:33 |
Joel Sherrill |
Added new baud rate to number function and default serial probe …
4.104.114.84.95
@11c6a92d
07/09/98 22:59:32 |
Joel Sherrill |
Commented out the system call invocation since we don't know what …
4.104.114.84.95
@a6e36dff
07/09/98 22:59:13 |
Joel Sherrill |
Removed call back to exit() since that has already been called.
4.104.114.84.95
@e78c474b
07/09/98 22:21:54 |
Joel Sherrill |
Added proper handling of extended baud rate table selection at boot …
4.104.114.84.95
@2c5ea01
07/09/98 22:16:27 |
Joel Sherrill |
Properly handle extended baud rate set commands.
Temporarily "if 0" …
4.104.114.84.95
@e3c59dd
07/09/98 22:11:49 |
Joel Sherrill |
Corrected definition of MC68681_RX_BUFFER.
4.104.114.84.95
@2ba0a0c2
07/09/98 18:50:13 |
Joel Sherrill |
Corrected z85c30 address and clock constants.
4.104.114.84.95
@459c1d2
07/09/98 18:49:49 |
Joel Sherrill |
Added board specific baud rate table and set driver function table
to …
4.104.114.84.95
@2d8e51aa
07/09/98 18:45:28 |
Joel Sherrill |
Changed static to MC68681_STATIC to make all data and routines …
4.104.114.84.95
@b2ec38c8
07/09/98 18:44:10 |
Joel Sherrill |
Removed commented out line.
4.104.114.84.95
@8f6f641e
07/09/98 18:41:49 |
Joel Sherrill |
Added sersupp.c.
4.104.114.84.95
@d94d47b3
07/09/98 18:41:33 |
Joel Sherrill |
New files to contain generally needed serial driver support routines.
4.104.114.84.95
@37e8259
07/09/98 18:40:27 |
Joel Sherrill |
Changed static to MC68681_STATIC to make all routines and data global …
4.104.114.84.95
@8b2492f
07/09/98 18:39:50 |
Joel Sherrill |
Added support for the Extended Baud Rate set control found in the
Exar …
4.104.114.84.95
@27045a82
07/09/98 18:38:18 |
Joel Sherrill |
Changed static to NS16550_STATIC to make all routines and data global …
4.104.114.84.95
@677a503
07/09/98 18:37:47 |
Joel Sherrill |
Changed static to Z85C30_STATIC so all data and routines could be …
4.104.114.84.95
@80b1c2f
07/09/98 18:36:19 |
Joel Sherrill |
Added information to README.mc68681.
Created the basic README and the …
4.104.114.84.95
@030ff417
07/07/98 16:38:18 |
Joel Sherrill |
Conditionals for CONSOLE_USE_INTERRUPTS should have been "if" not
"if …
4.104.114.84.95
@270d58f
07/06/98 19:00:33 |
Joel Sherrill |
New file to satisfy readdir() family.
4.104.114.84.95
@a90b990
07/06/98 18:44:32 |
Joel Sherrill |
Missed this file in the initial merge.
4.104.114.84.95
@b5bb3d6
07/06/98 14:52:30 |
Joel Sherrill |
Update from Geoffroy Montel (g_montel@…) to get in sync with …
4.104.114.84.95
@5ae415b
07/05/98 11:04:31 |
Joel Sherrill |
Added include of termios.h.
Also added a block of comments above the …
4.104.114.84.95
@bc2ebb4
07/05/98 11:01:21 |
Joel Sherrill |
Added some address constants for the SCC and DUART to make it easier …
4.104.114.84.95
@e7ff2b2
07/05/98 11:00:57 |
Joel Sherrill |
New file added in the process of converting the console driver to …
4.104.114.84.95
@92a6454
07/05/98 11:00:00 |
Joel Sherrill |
Converted the console driver to use libchip/serial and added support …
4.104.114.84.95
@0e8c2000
07/02/98 18:07:09 |
Joel Sherrill |
Renamed old_start340.s to startfor340only.s
4.104.114.84.95
@132f194
07/01/98 22:03:20 |
Joel Sherrill |
Initial submission of gen68340 BSP (should run on a 68349) from …
4.104.114.84.95
@a05de51
07/01/98 21:33:38 |
Joel Sherrill |
Added _stat_r and changed spacing.
4.104.114.84.95
@dc95ee8d
06/29/98 17:51:50 |
Joel Sherrill |
Changed prototype for console_write_support to eliminate a warning.
4.104.114.84.95
@cf65c408
06/27/98 20:01:28 |
Joel Sherrill |
Bare BSP patch from Chris Johns <cjohns@…>. He also
sent …
4.104.114.84.95
@5d18fb0
06/27/98 18:51:49 |
Joel Sherrill |
PC386 BSP enhancements from Aleksey Romanov (Quality Quorum …
4.104.114.84.95
@98100d2
06/27/98 17:09:47 |
Joel Sherrill |
Monstrous patch from Ralf Corsepius <corsepiu@…>. I have …
4.104.114.84.95
@d13b247
06/25/98 18:42:30 |
Joel Sherrill |
Clean up from Aleksey Romanov (Quality Quorum <qqi@…>). …
4.104.114.84.95
@4f0ffa57
06/23/98 17:42:46 |
Joel Sherrill |
Removed RTS and DTR handling code since the MC68681 seems to only have …
4.104.114.84.95
@ae21568c
06/23/98 17:40:00 |
Joel Sherrill |
New file describing mc68681 libchip driver.
4.104.114.84.95
@beaaf49f
06/23/98 16:02:52 |
Joel Sherrill |
Added numerous comments.
4.104.114.84.95
@a5d0c7c
06/23/98 15:54:33 |
Joel Sherrill |
Added concept of "mate" -- the other port on the same DUART. This is …
4.104.114.84.95
@b7ebcea3
06/23/98 14:59:26 |
Joel Sherrill |
Added close.
4.104.114.84.95
@25c3ff91
06/23/98 14:55:21 |
Joel Sherrill |
Added set attributes and written initialize and first open.
4.104.114.84.95
@790d421
06/23/98 14:54:42 |
Joel Sherrill |
Added more registers.
4.104.114.84.95
@9eef52b
06/23/98 14:54:30 |
Joel Sherrill |
Added set attributes prototype.
4.104.114.84.95
@8a2d4f2b
06/23/98 14:54:09 |
Joel Sherrill |
Added NULL entry for setAttributes.
4.104.114.84.95
@7deeb16
06/22/98 11:49:38 |
Joel Sherrill |
Added initial part of iniitialization.
4.104.114.84.95
@ab2dbd7
06/22/98 11:09:32 |
Joel Sherrill |
Added mc68681 stuff to the makefile.
Added numerous constants to …
4.104.114.84.95
@36152b0e
06/22/98 11:08:16 |
Joel Sherrill |
Moved get and set register/data typedefs to this file.
4.104.114.84.95
@4cd4c5a
06/22/98 11:07:51 |
Joel Sherrill |
Moved set and get Register and Data type defininitions to serial.h.
4.104.114.84.95
@58b1e95
06/22/98 10:34:34 |
Joel Sherrill |
Corrected spacing
4.104.114.84.95
@424e23ee
06/22/98 10:17:14 |
Joel Sherrill |
spacing changes
4.104.114.84.95
@547de5d
06/22/98 10:15:14 |
Joel Sherrill |
Removed blank lines and bad debug stuff
4.104.114.84.95
@e4acf68
06/22/98 09:59:22 |
Joel Sherrill |
Added comments and corrected spacing.
4.104.114.84.95
@aa0da6b
06/22/98 09:56:09 |
Joel Sherrill |
Added a comment and cleaned up spacing
4.104.114.84.95
@cd58d82
06/22/98 09:28:03 |
Joel Sherrill |
Initial version of these files.
4.104.114.84.95
@9a6994b4
06/18/98 15:22:35 |
Joel Sherrill |
Added freebsd support from Dario Alcocer <alcocer@…>.
4.104.114.84.95
@ce691c51
06/18/98 15:14:48 |
Joel Sherrill |
Corrected so it returns the correct date. Previously was getting the …
4.104.114.84.95
@bdb1057
06/18/98 15:13:29 |
Joel Sherrill |
Spacing changes.
4.104.114.84.95
@ecc9737f
06/18/98 15:12:27 |
Joel Sherrill |
Added a public interface to the chain handler.
4.104.114.84.95
@fe52766e
06/16/98 19:06:35 |
Joel Sherrill |
Corrected compilation problems.
4.104.114.84.95
@8bf6095
06/16/98 19:05:50 |
Joel Sherrill |
Added initialization of css routines.
4.104.114.84.95
@1efeb61
06/16/98 18:22:54 |
Joel Sherrill |
Added css_iface -- assumes ../include/dy_supplied.
4.104.114.84.95
@ee3b242b
06/13/98 16:03:57 |
Joel Sherrill |
Initial incarnation of libchip compiles.
4.104.114.84.95
@0737710
06/13/98 15:48:25 |
Joel Sherrill |
Base code from ppcn_60x BSP
4.104.114.84.95
@23f5cdb5
06/13/98 13:34:09 |
Joel Sherrill |
Adding interrupt handling routine.
4.104.114.84.95
@510524c6
06/13/98 13:34:08 |
Joel Sherrill |
Removed bad comments.
4.104.114.84.95
@8d830755
06/13/98 13:33:38 |
Joel Sherrill |
Added IRQ information.
4.104.114.84.95
@a12d7fd7
06/13/98 13:33:11 |
Joel Sherrill |
Updated to add -qrtems_debug and -qnolinkcmds.
4.104.114.84.95
@7738906
06/12/98 21:12:12 |
Joel Sherrill |
Added optimized version of memcpy.c to this directory since RTEMS …
4.104.114.84.95
@70b0d66
06/04/98 13:08:02 |
Joel Sherrill |
Added support for -qrtems_debug flag.
4.104.114.84.95
@ea57368
06/03/98 19:01:21 |
Joel Sherrill |
Removed PPC_Get_timebase_register() as this is now provided by the …
4.104.114.84.95
@3c7916f
06/03/98 19:00:57 |
Joel Sherrill |
Update from Pedro Romano <pmcnr@…> with an attempt …
4.104.114.84.95
@5184958
06/03/98 18:47:44 |
Joel Sherrill |
Update from Pedro Romano <pmcnr@…> which replaces …
4.104.114.84.95
@64be9d4
06/02/98 17:38:16 |
Joel Sherrill |
Added some missing files per Eric Norum.
4.104.114.84.95
@2785eab2
05/30/98 16:01:12 |
Joel Sherrill |
Changed calculaction for Clock_Decrementer_value to use the …
4.104.114.84.95
@95a683b
05/30/98 15:58:37 |
Joel Sherrill |
Set console to port 2.
Changed #if defined to a #if check for …
4.104.114.84.95
@a874427
05/30/98 15:55:46 |
Joel Sherrill |
Made Debug defination a null routine.
4.104.114.84.95
@b317117a
05/30/98 15:53:19 |
Joel Sherrill |
clicks_per_usec had to be cut in half (unknown reason).
fixed …
4.104.114.84.95
@dc104a4
05/30/98 11:46:21 |
Joel Sherrill |
Updated to current source and removed warnings.
4.104.114.84.95
@a38b9f8
05/30/98 10:42:01 |
Joel Sherrill |
Used shared sbrk.c.
4.104.114.84.95
@825a2bb
05/30/98 10:41:21 |
Joel Sherrill |
Use shared initialization.
4.104.114.84.95
@55b517c
05/30/98 10:32:19 |
Joel Sherrill |
Rewrote in C to avoid Makefile problems.
4.104.114.84.95
