@b285860
08/31/98 23:03:45 |
Joel Sherrill |
Patch from Eric Valette <valette@…>:
Eric> NB : there …
4.104.114.84.95
@de9edc4
08/31/98 22:56:20 |
Joel Sherrill |
Here is a brief …
4.104.114.84.95
@85734b3
08/31/98 22:53:42 |
Joel Sherrill |
Patch from Eric Norum <eric@…>:
I think I figured …
4.104.114.84.95
@564d2c3a
08/24/98 16:59:20 |
Joel Sherrill |
Patch from Eric Valette <valette@…> to add an extra newline.
4.104.114.84.95
@69036586
08/24/98 16:58:39 |
Joel Sherrill |
Celso Labinaz …
4.104.114.84.95
@9a95524f
08/24/98 14:47:19 |
Joel Sherrill |
Cleanup patch from Eric Norum.
4.104.114.84.95
@4de817d
08/21/98 18:14:27 |
Joel Sherrill |
Added i386 specific version of in_cksum.c and restructured the main …
4.104.114.84.95
@617a1a2d
08/21/98 17:37:01 |
Joel Sherrill |
Another missing piece. Thanks Eric.
4.104.114.84.95
@eb562f2
08/21/98 16:39:52 |
Joel Sherrill |
Here is a patch …
4.104.114.84.95
@b3fd1641
08/21/98 15:32:19 |
Joel Sherrill |
Fix from Eric Norum <eric@…>:
"Thomas Doerfler" …
4.104.114.84.95
@d47de32
08/21/98 14:04:31 |
Joel Sherrill |
Update from Eric Norum.
4.104.114.84.95
@33679ec4
08/21/98 13:04:55 |
Joel Sherrill |
All warnings removed.
4.104.114.84.95
@c3a1c05
08/21/98 13:04:36 |
Joel Sherrill |
Removed networkconfig.h since it reflects target specific initialization.
4.104.114.84.95
@bbdab89
08/21/98 12:52:08 |
Joel Sherrill |
Added initialization of missing termios structure entries.
4.104.114.84.95
@ab09043a
08/21/98 12:51:29 |
Joel Sherrill |
Fixed warning about pointer/integer conversion which turned out to be …
4.104.114.84.95
@fd808ba
08/21/98 12:48:44 |
Joel Sherrill |
Fixed discrepancies noted by John Oleynick <johno@…>.
4.104.114.84.95
@28e7d7fa
08/20/98 22:04:22 |
Joel Sherrill |
Patches from Eric Norum
4.104.114.84.95
@96b39164
08/20/98 21:56:40 |
Joel Sherrill |
Added CVS Ids
4.104.114.84.95
@ff0f694d
08/20/98 21:47:37 |
Joel Sherrill |
Fixed many warnings.
4.104.114.84.95
@d9e6224
08/20/98 15:38:30 |
Joel Sherrill |
Temporarily leave strsep out of the build.
4.104.114.84.95
@4e1d5c6
08/20/98 15:38:15 |
Joel Sherrill |
Added missing file.
4.104.114.84.95
@53ee76b
08/20/98 15:37:42 |
Joel Sherrill |
Removed stub implementation
4.104.114.84.95
@0280cb6
08/20/98 14:39:09 |
Joel Sherrill |
FreeBSD stack compiles for the first time (except libc/strsep.c)
4.104.114.84.95
@3f098aed
08/20/98 14:37:17 |
Joel Sherrill |
FreeBSD stack compiles for the first time (except libc/strsep.c).
4.104.114.84.95
@c197b6c
08/20/98 12:54:04 |
Joel Sherrill |
Base files
4.104.114.84.95
@888497d
08/20/98 12:45:04 |
Joel Sherrill |
Base files
4.104.114.84.95
@f31f46d2
08/20/98 12:37:35 |
Joel Sherrill |
Base version.
4.104.114.84.95
@39e6e65a
08/19/98 21:32:28 |
Joel Sherrill |
Base files
4.104.114.84.95
@8b2ee37c
08/19/98 20:09:59 |
Joel Sherrill |
- Use the …
4.104.114.84.95
@0375c72
08/19/98 14:47:39 |
Joel Sherrill |
Patch from Aleksey <qqi@…>:
This patch has same …
4.104.114.84.95
@2d7d605
08/19/98 14:41:23 |
Joel Sherrill |
It fixes netboot build …
4.104.114.84.95
@e013fe3
08/14/98 16:55:50 |
Joel Sherrill |
If 0 out the code which touches the chip in questionable ways for …
4.104.114.84.95
@7ba7108
08/14/98 15:24:09 |
Joel Sherrill |
Changed tm27 clear interrupt macro on all PPC BSPs except the papyrus.
4.104.114.84.95
@db8e8a8b
08/14/98 15:23:33 |
Joel Sherrill |
Added information on caching.
4.104.114.84.95
@0088e39c
08/14/98 15:23:22 |
Joel Sherrill |
Updated.
4.104.114.84.95
@2097470
08/13/98 22:46:59 |
Joel Sherrill |
Fixed version reference
4.104.114.84.95
@3978eec2
08/13/98 22:46:35 |
Joel Sherrill |
Updated.
4.104.114.84.95
@8626d6d
08/13/98 17:46:27 |
Joel Sherrill |
base line -- copied from erc32
4.104.114.84.95
@af3e81c9
08/13/98 16:53:37 |
Joel Sherrill |
Enable TX interrupts only when we need TDAs.
4.104.114.84.95
@1253f39
08/13/98 16:20:14 |
Joel Sherrill |
Cleaned up some debugging stuff.
Redid interrupt handler to read …
4.104.114.84.95
@70502bc4
08/13/98 15:52:40 |
Joel Sherrill |
Don't disable the RX/TX on close in polled mode.
Fixed a comment.
4.104.114.84.95
@9898425
08/13/98 14:28:22 |
Joel Sherrill |
Patch from Chris Johns <ccj@…> to change the way in which the …
4.104.114.84.95
@7e19c72b
08/13/98 14:22:48 |
Joel Sherrill |
fixed spacing
4.104.114.84.95
@ae320e0
08/12/98 23:53:23 |
Joel Sherrill |
Removed spurious prints and cleaned up XXX.
4.104.114.84.95
@9693fac4
08/12/98 23:10:38 |
Joel Sherrill |
Added more debug information. There are probably debug prints left …
4.104.114.84.95
@4f38b713
08/12/98 16:28:17 |
Joel Sherrill |
Fixed bug where the last link of the RDA was not initialized properly.
4.104.114.84.95
@7d07970
08/11/98 14:20:26 |
Joel Sherrill |
Added SONIC_DEBUG_DESCRIPTORS and changed debug level.
4.104.114.84.95
@339737b
08/10/98 23:20:25 |
Joel Sherrill |
Survives 16-20 packets. Appears to be ok on TX buffer management. …
4.104.114.84.95
@3fbd528
08/10/98 22:23:33 |
Joel Sherrill |
Added prints
4.104.114.84.95
@7344fba9
08/10/98 21:45:01 |
Joel Sherrill |
Can now reply to multiple successive pings successfully without being …
4.104.114.84.95
@c153a7b
08/10/98 21:27:33 |
Joel Sherrill |
replies to ping -- forced into prosmiscuous mode
4.104.114.84.95
@0c0419a1
08/08/98 17:57:23 |
Joel Sherrill |
Reordered some stuff.
4.104.114.84.95
@870284d
08/08/98 16:37:43 |
Joel Sherrill |
Corrected spacing.
4.104.114.84.95
@301a2a3c
08/08/98 16:37:25 |
Joel Sherrill |
Changed debug level.
Moved CAM Descriptor types to sonic.h.
CAM …
4.104.114.84.95
@13451a3
08/06/98 19:01:03 |
Joel Sherrill |
Removed SonicRegisters? structure since we now use register indices
and …
4.104.114.84.95
@e70a8f16
08/06/98 19:01:02 |
Joel Sherrill |
Enabled specific types of debug info.
Added pointer to RDA to sonic …
4.104.114.84.95
@e995f3a1
08/06/98 15:27:08 |
Joel Sherrill |
Changed debug enable macros to support individually enabling different …
4.104.114.84.95
@c23118b
08/06/98 15:05:59 |
Joel Sherrill |
Card Resource Register was a 16-bit register not a 32-bit one.
Used …
4.104.114.84.95
@308e18c
08/06/98 00:24:52 |
Joel Sherrill |
Added support for the Card Resource Register. The new probe routines …
4.104.114.84.95
@0eb85ae
08/05/98 23:57:35 |
Joel Sherrill |
Commented out the code which yields the CPU when the serial controller …
4.104.114.84.95
@d4bf16c
08/05/98 23:56:48 |
Joel Sherrill |
Added constants which made the multiple bit settings more readable
for …
4.104.114.84.95
@dddc0557
08/05/98 23:56:13 |
Joel Sherrill |
DCR setting changed to match what the DY-4 Firmware initialized it to. …
4.104.114.84.95
@bd8c8b2a
08/05/98 16:51:39 |
Joel Sherrill |
Patch from Eric Valette <valette@…> which brings the i386ex …
4.104.114.84.95
@ab0df696
08/05/98 15:15:46 |
Joel Sherrill |
Automatic CPU type detection code from Eric Valette …
4.104.114.84.95
@5094711
08/05/98 15:12:03 |
Joel Sherrill |
Fixed name of Buffer so this would compile.
4.104.114.84.95
@7fc5d54e
08/03/98 21:01:21 |
Joel Sherrill |
Switched to read/write register routines and added some basic debug
help.
4.104.114.84.95
@906577f4
08/01/98 14:41:20 |
Joel Sherrill |
Patch from David Fiddes <D.J.Fiddes@…> to not use this file for …
4.104.114.84.95
@2889189
07/30/98 22:57:21 |
Joel Sherrill |
Changed name of network driver.
4.104.114.84.95
@fa655207
07/30/98 22:57:12 |
Joel Sherrill |
Added temporary include of dmv170.h
4.104.114.84.95
@4fbf114
07/30/98 22:56:56 |
Joel Sherrill |
Added SONIC configuration information.
4.104.114.84.95
@56392179
07/30/98 22:56:17 |
Joel Sherrill |
Added a hint to continue writing this.
4.104.114.84.95
@d9bc023a
07/30/98 21:30:46 |
Joel Sherrill |
Updated.
4.104.114.84.95
@509dc7c1
07/30/98 21:27:51 |
Joel Sherrill |
Added getRealTime() and setRealTime().
Reimplemented checkRealTime() …
4.104.114.84.95
@91af3e4
07/30/98 21:27:01 |
Joel Sherrill |
Changed clock rate from 32 Khz to 1 Mhz.
Registers are at 8 byte …
4.104.114.84.95
@a47bca7c
07/30/98 21:26:25 |
Joel Sherrill |
Changed comment to be more polite.
4.104.114.84.95
@8e992e1
07/30/98 21:26:11 |
Joel Sherrill |
Updating to make more readable.
4.104.114.84.95
@192a1e0
07/30/98 19:51:03 |
Joel Sherrill |
New files.
4.104.114.84.95
@1aa4186
07/30/98 19:41:46 |
Joel Sherrill |
Spacing corrected.
4.104.114.84.95
@1a256e3
07/30/98 19:41:41 |
Joel Sherrill |
New file based on email from DY-4 technical support.
4.104.114.84.95
@1c5f4e1
07/30/98 19:26:47 |
Joel Sherrill |
Fixed spacing.
4.104.114.84.95
@8751f800
07/30/98 19:25:54 |
Joel Sherrill |
Updated to accurately reflect the dmv177.
4.104.114.84.95
@7fd8641
07/30/98 16:07:54 |
Joel Sherrill |
Made chain.h shared
4.104.114.84.95
@3fdde4ce
07/30/98 16:05:14 |
Joel Sherrill |
Made tod.h shared
4.104.114.84.95
@02733a96
07/29/98 00:38:51 |
Joel Sherrill |
New file. Based on merged of shared libchip style console.c and the …
4.104.114.84.95
@acac0e8
07/29/98 00:38:14 |
Joel Sherrill |
Cleaned up comment.
Modified open so it uses a local variable rather …
4.104.114.84.95
@6a0f5ac2
07/29/98 00:37:37 |
Joel Sherrill |
Added reference to shared TOD driver.
4.104.114.84.95
@c95e927
07/29/98 00:18:11 |
Joel Sherrill |
Added prototype for default register access routines to header files.
4.104.114.84.95
@ee306fd
07/29/98 00:17:01 |
Joel Sherrill |
Corrected to reflect the ICM7170 which is really on this board.
4.104.114.84.95
@55dcdfd
07/29/98 00:16:44 |
Joel Sherrill |
Added config.c and deleted tod.c.
4.104.114.84.95
@e74735b2
07/29/98 00:16:32 |
Joel Sherrill |
Simplified RTC base address.
4.104.114.84.95
@5217d5a
07/29/98 00:16:11 |
Joel Sherrill |
Changed cast on RTC address and added base address of RTC fields as …
4.104.114.84.95
@fb339a8
07/29/98 00:04:02 |
Joel Sherrill |
Deleted probe routine as device specific.
Renamed port table.
4.104.114.84.95
@866c9dd5
07/29/98 00:03:12 |
Joel Sherrill |
Added function table.
4.104.114.84.95
@cb5e6f68
07/29/98 00:03:07 |
Joel Sherrill |
Renamed control register constants.
Set time->ticks to 0.
Added …
4.104.114.84.95
@1177cda
07/29/98 00:02:11 |
Joel Sherrill |
New files for Harris Semiconductor ICM7170.
4.104.114.84.95
@8d6e7120
07/29/98 00:01:56 |
Joel Sherrill |
New files.
4.104.114.84.95
@677943a
07/29/98 00:01:44 |
Joel Sherrill |
Added new files.
4.104.114.84.95
@9968efb
07/28/98 23:16:34 |
Joel Sherrill |
First cut at configuration table for libchip RTC. At this point, we …
4.104.114.84.95
@a1f514f
07/28/98 23:03:40 |
Joel Sherrill |
First cut implementation of real-time clock support in libchip. This …
4.104.114.84.95
@009c235
07/28/98 21:18:17 |
Joel Sherrill |
Corrected spacing.
4.104.114.84.95
