@91cb065
12/19/05 21:23:52 |
WENorum |
Add another 'extended BSP' routine which returns reboot status …
4.104.114.84.95
@0ed348f
12/02/05 20:45:57 |
strauman |
2005-12-02 Till Straumann <strauman@…>
4.104.114.84.95
@d8ada5b
12/02/05 02:47:23 |
strauman |
2005-12-01 Till Straumann <strauman@…>
4.104.114.84.95
@5b8eb3f0
11/30/05 02:21:11 |
strauman |
2005-11-29 Till Straumann <strauman@…>
4.104.114.84.95
@2b370444
11/30/05 01:22:48 |
strauman |
4.104.114.84.95
@8c6579b
11/29/05 18:47:05 |
strauman |
- trivial correction in comment
4.104.114.84.95
@c2eeaaf
11/22/05 15:48:10 |
Joel Sherrill |
Fixed format.
4.104.114.84.95
@5367a6e
11/22/05 03:21:26 |
Ralf Corsepius |
2005-11-22 Ralf Corsepius <ralf.corsepius@…>
* bsp_specs: …
4.104.114.84.95
@36c30fe2
11/22/05 01:24:10 |
strauman |
2005-11-21 Till Straumann <strauman@…>
4.104.114.84.95
@15ec224
11/13/05 05:38:34 |
Ralf Corsepius |
2005-11-13 Ralf Corsepius <ralf.corsepius@…>
* bsp_specs: …
4.104.114.84.95
@17e451a
11/13/05 05:17:24 |
Ralf Corsepius |
* bsp_specs: …
4.104.114.84.95
@bf221c5
11/12/05 07:21:23 |
Ralf Corsepius |
2005-11-12 Ralf Corsepius <ralf.corsepius@…>
* bsp_specs: …
4.104.114.84.95
@bcd0867d
11/12/05 07:08:33 |
Ralf Corsepius |
* bsp_specs: …
4.104.114.84.95
@b1a0917
11/12/05 07:04:49 |
Ralf Corsepius |
* bsp_specs: …
4.104.114.84.95
@cea62b21
11/12/05 05:26:25 |
Ralf Corsepius |
* configure.ac: …
4.104.114.84.95
@46fa1f64
11/11/05 15:48:24 |
WENorum |
Clean up UART2 pin setup. Protect pin setup code.
4.104.114.84.95
@0cf20a9
11/09/05 17:23:35 |
WENorum |
Need to install vme_am_defs.h.
4.104.114.84.95
@ac3a37d7
11/09/05 16:53:30 |
Ralf Corsepius |
2005-11-09 Ralf Corsepius <ralf.corsepius@…>
4.104.114.84.95
@c29d03e9
11/09/05 16:51:26 |
Ralf Corsepius |
4.104.114.84.95
@d5b3fe52
11/09/05 16:38:33 |
WENorum |
Fix disagreement between GCCSPECS and GCC_SPECS.
4.104.114.84.95
@8e6835a5
11/08/05 20:11:02 |
WENorum |
Add code to set up pin assignments.
4.104.114.84.95
@347733c4
11/08/05 10:46:29 |
Ralf Corsepius |
2005-11-08 Ralf Corsepius <ralf.corsepius@…>
* irq/irq.c, …
4.104.114.84.95
@b07b75f
11/08/05 10:46:19 |
Ralf Corsepius |
Remove obsolete types (*unsigned32).
4.104.114.84.95
@91c832b9
11/07/05 17:30:17 |
WENorum |
Remove assignation to U.S. Government.
4.104.114.84.95
@12b36efe
11/07/05 17:22:23 |
WENorum |
Assign copyright to OAR since all files descend from OAR's source.
4.104.114.84.95
@086c1c3
11/07/05 16:19:21 |
Joel Sherrill |
Fixed formatting.
4.104.114.84.95
@fb08bd92
11/07/05 15:36:31 |
Joel Sherrill |
Repaired some changelog entries lost.
4.104.114.84.95
@cb98129
11/07/05 06:26:45 |
Ralf Corsepius |
2005-11-07 Ralf Corsepius <ralf.corsepius@…>
4.104.114.84.95
@71a7ed0
11/07/05 06:26:37 |
Ralf Corsepius |
Eliminate unsigned32.
4.104.114.84.95
@8fd9e978
11/07/05 06:26:08 |
Ralf Corsepius |
Eliminate unsigned32, unsigned8.
4.104.114.84.95
@e3996e2b
11/07/05 06:23:24 |
Ralf Corsepius |
4.104.114.84.95
@9ab9f026
11/07/05 06:23:14 |
Ralf Corsepius |
Several minor bug fixes.
4.104.114.84.95
@e6d36b5
11/07/05 02:35:02 |
Ralf Corsepius |
4.104.114.84.95
@fb6bc245
11/07/05 02:34:13 |
Ralf Corsepius |
Eliminate rtems_unsigned32.
4.104.114.84.95
@0f8b4e9
11/07/05 02:33:57 |
Ralf Corsepius |
4.104.114.84.95
@f2535df
11/06/05 08:32:36 |
Ralf Corsepius |
2005-11-06 Ralf Corsepius <ralf.corsepius@…>
4.104.114.84.95
@4d90b98e
11/06/05 08:32:13 |
Ralf Corsepius |
Reflect API changes.
4.104.114.84.95
@1fdeb22
11/06/05 06:25:30 |
Ralf Corsepius |
4.104.114.84.95
@3e21ecf
11/06/05 06:25:07 |
Ralf Corsepius |
Remove C++-style comments.
4.104.114.84.95
@830976c
11/04/05 17:54:49 |
Ralf Corsepius |
2005-11-04 Ralf Corsepius <ralf.corsepius@…>
* Makefile.am: …
4.104.114.84.95
@22d3aed
11/04/05 17:54:37 |
Ralf Corsepius |
Add preinstall.am
4.104.114.84.95
@08e2639
11/04/05 17:54:15 |
Ralf Corsepius |
New
4.104.114.84.95
@4818350
11/04/05 17:52:36 |
Ralf Corsepius |
* configure.ac: …
4.104.114.84.95
@ae5f7a08
11/04/05 17:50:48 |
Ralf Corsepius |
* byteorder.h: New.
4.104.114.84.95
@5acb4d0
11/04/05 17:50:34 |
Ralf Corsepius |
New.
4.104.114.84.95
@47b5568
11/04/05 12:29:38 |
Ralf Corsepius |
4.104.114.84.95
@d04e891
11/04/05 12:29:17 |
Ralf Corsepius |
Remove arch_swap (Unused).
4.104.114.84.95
@0a708729
11/04/05 12:27:42 |
Ralf Corsepius |
* configure.ac: …
4.104.114.84.95
@4609200
11/04/05 12:26:25 |
Ralf Corsepius |
* configure.ac: …
4.104.114.84.95
@03c4c16
11/04/05 09:41:41 |
Ralf Corsepius |
Cleanup.
4.104.114.84.95
@8238048
11/04/05 09:34:39 |
Ralf Corsepius |
Merge new-exceptions/ChangeLog
4.104.114.84.95
@b6a645da
11/04/05 09:33:58 |
Ralf Corsepius |
Remove (Merged into ../ChangeLog?)
4.104.114.84.95
@7634813
11/04/05 09:19:44 |
Ralf Corsepius |
Cleanup
4.104.114.84.95
@751076a6
11/04/05 09:16:46 |
Ralf Corsepius |
Merge old-exceptions/ChangeLog
4.104.114.84.95
@692d614
11/04/05 09:15:20 |
Ralf Corsepius |
4.104.114.84.95
@d3b8db7b
11/04/05 09:05:57 |
Ralf Corsepius |
* Makefile.am: …
4.104.114.84.95
@784e792
11/04/05 08:17:56 |
strauman |
2005-11-04 Till Straumann <strauman@…>
4.104.114.84.95
@6d3ff66f
11/04/05 08:10:42 |
strauman |
2005-11-03 Till Straumann <strauman@…>
4.104.114.84.95
@c4423933
11/04/05 06:14:26 |
strauman |
4.104.114.84.95
@94c31843
11/04/05 04:03:31 |
strauman |
* irq/irq.c, …
4.104.114.84.95
@896cacf
11/04/05 03:44:13 |
strauman |
Added reference to PR#832
4.104.114.84.95
@758ee5c
11/04/05 03:43:10 |
strauman |
corrected redundant PR number
4.104.114.84.95
@98afe31
11/04/05 03:34:08 |
strauman |
4.104.114.84.95
@cca22863
11/04/05 03:31:10 |
strauman |
4.104.114.84.95
@0de2f239
11/04/05 03:25:22 |
strauman |
Added reference to PR#838
4.104.114.84.95
@dc0f6585
11/04/05 03:20:29 |
strauman |
2005-11-03 <strauman@…>
* shared/console/reboot.c, …
4.104.114.84.95
@8c9fffd
11/04/05 01:39:45 |
strauman |
4.104.114.84.95
@be45f8e
11/04/05 01:00:33 |
strauman |
* Makefile.am, …
4.104.114.84.95
@ab20575
11/04/05 00:57:25 |
strauman |
4.104.114.84.95
@f3173c0
11/04/05 00:23:28 |
strauman |
* mvme5500/irq/irq.h, …
4.104.114.84.95
@0ac68b0
11/03/05 22:14:59 |
strauman |
2005-11-03 straumanatslacdotstanforddotedu
* ChangeLog?: corrected …
4.104.114.84.95
@b6e3ee54
11/03/05 22:13:43 |
strauman |
4.104.114.84.95
@9a76deb5
11/03/05 21:39:33 |
strauman |
* Makefile.am, …
4.104.114.84.95
@7e2dcde
11/03/05 21:38:36 |
strauman |
* startup/linkcmds: …
4.104.114.84.95
@4ef2fd43
11/03/05 21:35:09 |
strauman |
* Makefile.am, …
4.104.114.84.95
@d45540a
11/03/05 21:35:08 |
strauman |
* Makefile.am, …
4.104.114.84.95
@e156c633
11/03/05 19:14:54 |
strauman |
4.104.114.84.95
@cc9073d
11/03/05 18:35:07 |
strauman |
2005-11-03 straumanatslacdotstanford.edu
* mpc6xx/clock/c_clock.c: …
4.104.114.84.95
@ef9e015
11/03/05 14:55:33 |
Ralf Corsepius |
2005-11-03 Ralf Corsepius <ralf.corsepius@…>
PR 844/bsps
4.104.114.84.95
@05a2cc4b
11/03/05 02:59:18 |
strauman |
2005-11-02 straumanatslacdotstanford.edu
* shared/pci/pcibios.c: …
4.104.114.84.95
@ebedf31
11/03/05 02:58:09 |
strauman |
* startup/ldsegs.S: put IDT …
4.104.114.84.95
@1b1b43cc
11/03/05 02:26:08 |
strauman |
* mpc6xx/mmu/pte121.c, …
4.104.114.84.95
@ec58ea04
11/03/05 01:57:27 |
strauman |
* mvme5500/start/start.S, …
4.104.114.84.95
@912ab10e
11/03/05 01:54:59 |
strauman |
* mpc6xx/mmu/bat.c, …
4.104.114.84.95
@408bb71
11/02/05 23:24:48 |
strauman |
* ChangeLog?, …
4.104.114.84.95
@21dd4cf8
10/26/05 14:56:58 |
WENorum |
Allow network to be locked at 100/Full.
4.104.114.84.95
@fab9046
10/20/05 21:41:49 |
Joel Sherrill |
Fix formatting.
4.104.114.84.95
@cc2fcc1
10/20/05 18:38:26 |
WENorum |
Numerous changes and cleanups to support MVME2100.
4.104.114.84.95
@5c786ff7
10/17/05 12:47:51 |
Ralf Corsepius |
Add pci.rel to librtemsbsp.a
4.104.114.84.95
@7e9874b
10/17/05 12:38:54 |
Ralf Corsepius |
Cosmetics.
4.104.114.84.95
@7a9c410
10/17/05 12:38:24 |
Ralf Corsepius |
2005-10-17 Ralf Corsepius <ralf.corsepius@…>
* Makefile.am: …
4.104.114.84.95
@939ae4c
10/17/05 10:34:22 |
Ralf Corsepius |
4.104.114.84.95
@cba119c9
10/17/05 10:34:02 |
Ralf Corsepius |
Remove CVS Log
4.104.114.84.95
@2950439
10/17/05 10:31:42 |
Ralf Corsepius |
4.104.114.84.95
@d94df689
10/17/05 09:02:24 |
Ralf Corsepius |
Remove
4.104.114.84.95
@3d570dfb
10/17/05 09:01:51 |
Ralf Corsepius |
* Makefile.am: …
4.104.114.84.95
@1ebfc5af
10/17/05 08:51:36 |
Ralf Corsepius |
Remove.
4.104.114.84.95
@6fdf978
10/17/05 08:51:06 |
Ralf Corsepius |
* Makefile.am: …
4.104.114.84.95
@dd2c72af
10/17/05 08:45:46 |
Ralf Corsepius |
Regenerate.
4.104.114.84.95
@6b346ca
10/17/05 08:34:46 |
Ralf Corsepius |
* Makefile.am: …
4.104.114.84.95
