@8389628
04/22/96 16:53:46 |
Joel Sherrill |
updates from Tony Bennett
4.104.114.84.95
@1f94ed6b
04/22/96 16:50:17 |
Joel Sherrill |
Updates from Tony Bennett.
4.104.114.84.95
@34f3d17
04/22/96 16:49:53 |
Joel Sherrill |
Updates from Tony Bennett. rtems_environp removed among other minor …
4.104.114.84.95
@f5674938
04/22/96 16:49:25 |
Joel Sherrill |
Fixed so now supports more than 16 nodes. Tested for up to 24 nodes …
4.104.114.84.95
@767a6c6
04/20/96 16:48:30 |
Joel Sherrill |
swapped order of operands on a movw to fix LOAD_SEGMENTS macro
4.104.114.84.95
@8cf88427
03/21/96 20:20:40 |
Joel Sherrill |
minor mods to get to compile locally
4.104.114.84.95
@487a7ca
03/21/96 20:20:27 |
Joel Sherrill |
some instructions altered for older binutils
4.104.114.84.95
@99e7cbbb
03/21/96 20:20:13 |
Joel Sherrill |
updated
4.104.114.84.95
@bdf531ee
03/06/96 22:25:11 |
Joel Sherrill |
include of mc68360.h changed to m68360.h to reflect filename change.
4.104.114.84.95
@457b6ae
03/06/96 22:01:11 |
Joel Sherrill |
Generic 68360 BSP (gen360) submitted by: W. Eric Norum …
4.104.114.84.95
@e6424462
03/06/96 21:37:43 |
Joel Sherrill |
As part of reducing visibility into rtems and hiding the .inl files …
4.104.114.84.95
@1a8fde6c
03/06/96 21:34:57 |
Joel Sherrill |
Removed prototyes for static inline routines and moved the comments …
4.104.114.84.95
@8cbbe312
02/21/96 14:47:03 |
Joel Sherrill |
Dispersal of internal thread handler resulted in the SYSI task being …
4.104.114.84.95
@8bde6ea9
02/13/96 22:16:36 |
Joel Sherrill |
removed post switch extension
4.104.114.84.95
@da646dd
02/13/96 22:15:52 |
Joel Sherrill |
fixed bug when outbyte had argument in wrong order relative to those …
4.104.114.84.95
@4f7c546e
01/22/96 21:12:12 |
Joel Sherrill |
new times for 3.5.1
4.104.114.84.95
@29310016
01/19/96 22:21:16 |
Joel Sherrill |
Added condition compile flag for dump of stack usage information on …
4.104.114.84.95
@eaa442fc
01/19/96 22:20:40 |
Joel Sherrill |
added a task begin extension for unix simulator configurations. This …
4.104.114.84.95
@05e4e419
01/19/96 22:19:49 |
Joel Sherrill |
updated
4.104.114.84.95
@64f311f7
01/19/96 22:19:31 |
Joel Sherrill |
added definition of cpu_number.
4.104.114.84.95
@84147e4f
01/17/96 20:15:41 |
Joel Sherrill |
Removed comment about a confusion on newlib buffering.
4.104.114.84.95
@72c440e
01/17/96 20:13:45 |
Joel Sherrill |
Update from Tony Bennett (tbennett@…)
4.104.114.84.95
@217e398
01/17/96 20:13:01 |
Joel Sherrill |
Modified fstat and stat to be consistent with isatty in that all three …
4.104.114.84.95
@6661eaa1
01/15/96 23:06:16 |
Joel Sherrill |
Split error handler into its own directory.
4.104.114.84.95
@c64e4ed4
01/15/96 21:50:28 |
Joel Sherrill |
updates from Tony Bennett for PA and UNIX ports
4.104.114.84.95
@5c491aef
12/20/95 15:39:19 |
Joel Sherrill |
changes remerged after lost in disk crash -- recovered from snapshot, …
4.104.114.84.95
@4442d21c
12/19/95 22:29:43 |
Joel Sherrill |
initial history lost in disk crash
4.104.114.84.95
@8bdcfc4
12/19/95 20:26:32 |
Joel Sherrill |
changes remerged after disk crash -- history lost
4.104.114.84.95
@7593d56c
12/19/95 19:22:55 |
Joel Sherrill |
file lost in crash and re-added
4.104.114.84.95
@f3fe5b24
12/19/95 19:21:24 |
Joel Sherrill |
file lost in crash and readded
4.104.114.84.95
@2b5944cf
12/08/95 21:06:29 |
Joel Sherrill |
updated for snapshot 3.5.02
4.104.114.84.95
@8442656a
12/07/95 15:44:23 |
Joel Sherrill |
updated to include HW information
4.104.114.84.95
@52cd72b1
12/07/95 15:42:53 |
Joel Sherrill |
the bss start and end symbols were changed
4.104.114.84.95
@62c4e481
12/07/95 15:42:23 |
Joel Sherrill |
updated to reflect HW information
4.104.114.84.95
@8e54b0b7
12/07/95 15:42:14 |
Joel Sherrill |
updated to reflect HW information and have correct timing information …
4.104.114.84.95
@4aac818
12/06/95 15:47:43 |
Joel Sherrill |
created
4.104.114.84.95
@e57b0e2
12/05/95 19:23:05 |
Joel Sherrill |
update from Andy Bray <andy@…>
4.104.114.84.95
@289ad86
12/05/95 15:29:53 |
Joel Sherrill |
bug fix in statistics from Tony Bennett (tbennett@…)
4.104.114.84.95
@c4808ca
10/31/95 21:28:16 |
Joel Sherrill |
typos fixed
4.104.114.84.95
@9700578
10/30/95 21:54:45 |
Joel Sherrill |
SPARC port passes all tests
4.104.114.84.95
@eb5a7e07
10/06/95 20:48:38 |
Joel Sherrill |
fixed missing CVS IDs
4.104.114.84.95
@c62d36f
10/06/95 20:01:20 |
Joel Sherrill |
SPARC merged and successfully tested w/o interrupt support
4.104.114.84.95
@1ceface
10/06/95 16:33:30 |
Joel Sherrill |
moved to new development machine and went to gcc 2.7.0
4.104.114.84.95
@11290355
09/29/95 17:19:16 |
Joel Sherrill |
all targets compile .. tony's patches in place
4.104.114.84.95
@37f4c2d
09/27/95 20:53:58 |
Joel Sherrill |
Modified UNIX simulator port so all references to native unix
stuff is …
4.104.114.84.95
@5e9b32b
09/26/95 19:27:15 |
Joel Sherrill |
posix support initially added
4.104.114.84.95
@879a047
09/26/95 13:25:58 |
Joel Sherrill |
fixed Id strings
4.104.114.84.95
@5e5731da
09/26/95 13:22:47 |
Joel Sherrill |
new file
4.104.114.84.95
@18c5378
09/22/95 15:35:48 |
Joel Sherrill |
moving files around and adding the exec/wrapup directory
4.104.114.84.95
@79aaec8
09/21/95 17:47:06 |
Joel Sherrill |
Fixed problem in fast_idle_switch_hook
4.104.114.84.95
@486c329
09/20/95 15:05:19 |
Joel Sherrill |
Actually adding efi bsp's from John Gwynne after forgetting to
commit them.
4.104.114.84.95
@3652ad35
09/19/95 14:53:29 |
Joel Sherrill |
Minor bug fixes to get all targets compilable and running. The
single …
4.104.114.84.95
@b3ac6a8d
09/12/95 19:45:42 |
Joel Sherrill |
Initial attempt at building HP PA-RISC using Solaris hosted tools.
4.104.114.84.95
@ced11f99
09/11/95 20:18:16 |
Joel Sherrill |
Added
4.104.114.84.95
@3a4ae6c
09/11/95 19:35:39 |
Joel Sherrill |
The word "RTEMS" almost completely removed from the core.
4.104.114.84.95
@7f6a24ab
08/28/95 15:30:29 |
Joel Sherrill |
Added unused priority ceiling parameter to rtems_semaphore_create.
4.104.114.84.95
@5250ff39
08/23/95 21:06:31 |
Joel Sherrill |
Moved _Thread_Information -> _RTEMS_tasks_Information.
Added a table …
4.104.114.84.95
@3235ad9
08/23/95 19:30:23 |
Joel Sherrill |
Support for variable length names added to Object Handler. This …
4.104.114.84.95
@80e2c29e
08/22/95 17:11:19 |
Joel Sherrill |
Added file .. fixed RCS Id
4.104.114.84.95
@0cf5bd6
08/22/95 17:11:04 |
Joel Sherrill |
fixed RCS Id
4.104.114.84.95
@63edbb3f
08/22/95 16:57:18 |
Joel Sherrill |
Fixed missing RCS Ids
4.104.114.84.95
@0f592fba
08/18/95 21:43:40 |
Joel Sherrill |
Modified references to task name.
4.104.114.84.95
@9863dbf
08/18/95 21:42:58 |
Joel Sherrill |
+ Added object type field to object id.
+ Added name pointer to …
4.104.114.84.95
@b06e68ef
08/17/95 19:51:51 |
Joel Sherrill |
Numerous miscellaneous features incorporated from Tony Bennett …
4.104.114.84.95
@556fb911
08/17/95 15:56:55 |
Joel Sherrill |
added tty driver to simhppa
4.104.114.84.95
@4cc631db
08/11/95 14:33:04 |
Joel Sherrill |
Added functions to access the errno of the native system when using …
4.104.114.84.95
@4e58d80
08/11/95 14:31:29 |
Joel Sherrill |
4.104.114.84.95
@c1403ef1
08/11/95 14:30:27 |
Joel Sherrill |
Added flush of output on exit. On some UNIX's using the native …
4.104.114.84.95
@aa9f194
08/11/95 14:27:23 |
Joel Sherrill |
Initialization of semaphores was incorrect. It did not force
the …
4.104.114.84.95
@0e4c603
08/11/95 14:24:44 |
Joel Sherrill |
clean up -- interrupt support is in place
4.104.114.84.95
@12f86efd
08/11/95 14:23:49 |
Joel Sherrill |
minor clean up -- switched to memset for zero'ing SHM
4.104.114.84.95
@0b8b971
08/11/95 14:16:53 |
Joel Sherrill |
cleaned up include statements
4.104.114.84.95
@e349411
08/11/95 14:16:20 |
Joel Sherrill |
clean up of RunWay? interrupt support
4.104.114.84.95
@ad3bf667
08/02/95 20:01:56 |
Joel Sherrill |
Changed order of include files.
4.104.114.84.95
@c6fb8e90
08/01/95 15:33:39 |
Joel Sherrill |
updated mvme162 code from Misha (mms@…)
4.104.114.84.95
@4a6e64d
08/01/95 15:32:09 |
Joel Sherrill |
moved ringbuf.h to a shared include directory
4.104.114.84.95
@c35e9622
07/24/95 15:43:17 |
Joel Sherrill |
times reported reasonably correctly
4.104.114.84.95
@2f2a597
07/24/95 14:00:27 |
Joel Sherrill |
hopefully works with regular timer and tm27
4.104.114.84.95
@1690c6b
07/21/95 20:10:49 |
Joel Sherrill |
after testing go32 and cvme961
4.104.114.84.95
@9e738b65
07/20/95 19:20:31 |
Joel Sherrill |
updating go32 to make timer more accurate
4.104.114.84.95
@4ca27cf
07/18/95 21:19:53 |
Joel Sherrill |
committing for rtems-3.2.01 snapshot
4.104.114.84.95
@3ea5288
07/18/95 21:11:57 |
Joel Sherrill |
fixed for Linux
4.104.114.84.95
@f67ad3d
07/13/95 20:08:53 |
Joel Sherrill |
all built successfully after merge
4.104.114.84.95
@6cc85032
07/12/95 20:44:47 |
Joel Sherrill |
fix oversites in libbsp/unix/posix
4.104.114.84.95
@637df35
07/12/95 19:47:25 |
Joel Sherrill |
Ada95, gnat, go32
4.104.114.84.95
@9526d217
06/07/95 01:49:23 |
Joel Sherrill |
added for first time
4.104.114.84.95
@9e86dd7d
06/07/95 01:27:28 |
Joel Sherrill |
incorporated mc68302 support
4.104.114.84.95
@e8512eb
06/05/95 22:59:47 |
Joel Sherrill |
incorporate Tony's patches:
4.104.114.84.95
@7979e35
06/04/95 22:43:19 |
Joel Sherrill |
changed release number to 3.2.0
4.104.114.84.95
@497428a2
05/30/95 19:42:36 |
Joel Sherrill |
cpu/*types.h added and successfully compiled.
IDLE task priority …
4.104.114.84.95
@88d594a
05/24/95 21:39:42 |
Joel Sherrill |
Fully tested on all in-house targets
4.104.114.84.95
@ac7d5ef0
05/11/95 17:39:37 |
Joel Sherrill |
Initial revision
4.104.114.84.95
