@4fd61795
10/21/97 16:17:12 |
Joel Sherrill |
Added casts and fixed line break.
4.104.114.84.95
@f33a3f2a
10/16/97 21:06:47 |
Joel Sherrill |
Control and Data addresses were swapped for port A.
4.104.114.84.95
@d17d4d2f
10/15/97 21:27:00 |
Joel Sherrill |
Moved selection of console port to custom file.
4.104.114.84.95
@84ff8b7b
10/13/97 17:38:18 |
Joel Sherrill |
New version of this file from Eric Norum.
4.104.114.84.95
@f00108f
10/09/97 18:35:02 |
Joel Sherrill |
Fixed incorrect reference to RTEMS_BSP instead of RTEMS_BSP_FAMILY.
4.104.114.84.95
@a86443fb
10/09/97 18:33:46 |
Joel Sherrill |
Added search of libcpu and fpsp.
4.104.114.84.95
@b546242
10/08/97 19:52:47 |
Joel Sherrill |
Modified to search RTEMS library before Newlib C library.
4.104.114.84.95
@89f5f5a1
10/08/97 18:23:58 |
Joel Sherrill |
Fix from Eric Norum to assemble under COFF.
4.104.114.84.95
@7de0960
10/08/97 18:19:43 |
Joel Sherrill |
Update from Eric Norum:
Change label names so they can be …
4.104.114.84.95
@98e4ebf5
10/08/97 15:45:54 |
Joel Sherrill |
Fixed typo in the pointer to the license terms.
4.104.114.84.95
@a2016b99
10/08/97 14:42:08 |
Joel Sherrill |
Removed include directory at "build" point and the link of this …
4.104.114.84.95
@ffa6183
10/06/97 21:30:16 |
Joel Sherrill |
Increased interrupt stack space.
4.104.114.84.95
@f795ca90
09/21/97 17:44:50 |
Joel Sherrill |
Uncommented gettimeofday_r to resolve missing symbol.
4.104.114.84.95
@5beb562
09/21/97 16:58:57 |
Joel Sherrill |
Cleaned up as part of adding the Monitor test.
4.104.114.84.95
@8f367d6b
09/19/97 18:31:05 |
Joel Sherrill |
Bug fix from Eric Norum:
After weeks of trying to figure why my …
4.104.114.84.95
@6b4ca31
09/18/97 16:01:52 |
Joel Sherrill |
Merged changes from Eric Norum:
Enable 68360 watchdog. The …
4.104.114.84.95
@a72e3dd
09/16/97 13:08:58 |
Joel Sherrill |
updated
4.104.114.84.95
@fc4675f0
09/15/97 19:01:33 |
Joel Sherrill |
syslog added
4.104.114.84.95
@8f35817
09/15/97 18:52:26 |
Joel Sherrill |
eliminated potential for overfilling buffer on read
4.104.114.84.95
@8d05346
09/03/97 22:05:51 |
Joel Sherrill |
Fix from Eric Norum. Here is the comment:
Enable SDMA …
4.104.114.84.95
@e9932367
08/28/97 21:54:59 |
Joel Sherrill |
Switched to new style which does not require hackspecs.awk.
4.104.114.84.95
@7d352a49
08/28/97 13:59:41 |
Joel Sherrill |
Added RTEMS_IO_ERROR status code.
4.104.114.84.95
@3473f605
08/27/97 20:33:49 |
Joel Sherrill |
Added error numbers and changed default error code from 0 to -1 for …
4.104.114.84.95
@f80faeb
08/27/97 20:33:11 |
Joel Sherrill |
Modified to support the BSP family concept.
4.104.114.84.95
@49c2f589
08/27/97 20:31:34 |
Joel Sherrill |
Modified to have correct address for vector table on multiple models.
4.104.114.84.95
@12a17af3
08/26/97 18:10:59 |
Joel Sherrill |
Corrected to compile with egcs.
4.104.114.84.95
@b57992a
08/22/97 19:17:54 |
Joel Sherrill |
Removed assert condition when not initialized or there are 0 periods.
4.104.114.84.95
@b1459dc
08/22/97 19:17:09 |
Joel Sherrill |
Moved reentrant wrappers into their own file.
4.104.114.84.95
@78d87bd
08/22/97 19:16:47 |
Joel Sherrill |
Fixed iop/memory leak bug reported by Dan Dickey.
4.104.114.84.95
@8affd6f1
08/22/97 19:16:22 |
Joel Sherrill |
Removed redundant stanza.
4.104.114.84.95
@2d997375
08/22/97 13:08:56 |
Joel Sherrill |
start no longer a global symbol per Eric Norum's request.
Also, I …
4.104.114.84.95
@d074e12
08/04/97 22:22:59 |
Joel Sherrill |
Switched to new version of mc68681.h
4.104.114.84.95
@19fd334
08/04/97 22:22:31 |
Joel Sherrill |
moved mc68230.h from main include directory to motorola
4.104.114.84.95
@0789abef
08/04/97 22:17:17 |
Joel Sherrill |
new implementation of mc68681.h
4.104.114.84.95
@89a32784
08/04/97 22:12:39 |
Joel Sherrill |
Fixed type
4.104.114.84.95
@3dd8372
08/04/97 22:03:03 |
Joel Sherrill |
Corrected typo
4.104.114.84.95
@a397c9c1
08/04/97 21:59:14 |
Joel Sherrill |
Corrected descent to a hardcoded directory and made it dependent on …
4.104.114.84.95
@8bc9051
08/04/97 21:58:30 |
Joel Sherrill |
Fixed typo and removed duplicated code
4.104.114.84.95
@4ef9e99
08/04/97 21:58:00 |
Joel Sherrill |
First attempt at values for PPC
4.104.114.84.95
@50b5f9d
08/04/97 21:57:06 |
Joel Sherrill |
Trying to support all models
4.104.114.84.95
@c74169bd
08/04/97 21:56:48 |
Joel Sherrill |
Trying to support all models.
4.104.114.84.95
@c9647b3
08/04/97 21:56:00 |
Joel Sherrill |
consolex built for all models.
4.104.114.84.95
@81d96577
08/04/97 21:55:30 |
Joel Sherrill |
moved header files into the motorola and zilog subdirectories
4.104.114.84.95
@669123e1
08/04/97 21:53:42 |
Joel Sherrill |
Correcting difference between mvme162lx and mvme162. All versions …
4.104.114.84.95
@02d0880
08/04/97 21:50:35 |
Joel Sherrill |
4.104.114.84.95
@033ec54
08/04/97 21:49:47 |
Joel Sherrill |
Modified to reflect changes in mc68681.h header file.
4.104.114.84.95
@b739617
08/04/97 21:45:27 |
Joel Sherrill |
Header files moved into zilog subdirectory.
4.104.114.84.95
@9b024884
08/04/97 21:44:05 |
Joel Sherrill |
Moved files into the zilog and motorola subdirectories.
4.104.114.84.95
@28a4b1d
08/04/97 21:39:07 |
Joel Sherrill |
moved from main include directory
4.104.114.84.95
@30e3029
08/01/97 20:58:10 |
Joel Sherrill |
Added conditional for KA9Q.
4.104.114.84.95
@1f581ec
08/01/97 20:57:21 |
Joel Sherrill |
Added include of termios.h which was accidentally left out.
4.104.114.84.95
@bcbd75d4
08/01/97 20:56:36 |
Joel Sherrill |
Added consolex to wrapup
4.104.114.84.95
@a7fcfd0
08/01/97 20:56:24 |
Joel Sherrill |
Corrected typo.
4.104.114.84.95
@adf7b5c4
08/01/97 20:15:02 |
Joel Sherrill |
Made to work.
4.104.114.84.95
@29a9e5d
08/01/97 20:14:57 |
Joel Sherrill |
Removed warnings.
4.104.114.84.95
@9deb5b8b
08/01/97 18:12:11 |
Joel Sherrill |
Katsutoshi Shibuya (shibuya@…)of BU-Denken Co., Ltd. …
4.104.114.84.95
@0074691a
07/31/97 22:13:29 |
Joel Sherrill |
Merged very large and much appreciated patch from Chris Johns …
4.104.114.84.95
@91333c2
07/31/97 22:04:17 |
Joel Sherrill |
4.104.114.84.95
@bf3a7a5a
07/10/97 19:16:40 |
Joel Sherrill |
Added information on different MVME162 models.
4.104.114.84.95
@900a3ab1
07/09/97 23:57:56 |
Joel Sherrill |
Repository damaged -- file re-added
4.104.114.84.95
@1d320bac
07/09/97 23:41:20 |
Joel Sherrill |
This code was in the tree but not actually being compiled. There
were …
4.104.114.84.95
@1f0f3e35
05/27/97 23:39:29 |
Joel Sherrill |
added ka9q stack
4.104.114.84.95
@f5bd03c
05/23/97 21:44:19 |
Joel Sherrill |
KA9Q stack removed prior to testing for 4.0.0 public release.
4.104.114.84.95
@edd12702
05/21/97 12:59:40 |
Joel Sherrill |
patch from Eric Norum
4.104.114.84.95
@18647b7
04/25/97 16:58:10 |
Joel Sherrill |
updated to reflect new license per John Gwynne's permission.
4.104.114.84.95
@e71ce071
04/22/97 17:47:16 |
Joel Sherrill |
updated with new license information per Tony Bennett.
4.104.114.84.95
@03f2154e
04/22/97 17:20:27 |
Joel Sherrill |
headers updated to reflect new style copyright notice as part
of …
4.104.114.84.95
@5bb2ed07
04/22/97 12:39:23 |
Joel Sherrill |
Added support for HW API package
4.104.114.84.95
@59097e7
04/18/97 18:38:19 |
Joel Sherrill |
Changed format of comment blocks to C comments.
4.104.114.84.95
@7e7143e
04/18/97 18:37:48 |
Joel Sherrill |
Duplicated timerisr symbol as _timerisr to avoid tool naming problems.
4.104.114.84.95
@9fbba98
04/16/97 17:47:48 |
Joel Sherrill |
Fixed path which points to shared directory for all BSPs.
4.104.114.84.95
@334b01f1
04/16/97 17:46:26 |
Joel Sherrill |
fixed spacing
4.104.114.84.95
@f9f375e
04/16/97 17:45:52 |
Joel Sherrill |
added fpsp support.
4.104.114.84.95
@f8f370b6
04/16/97 17:45:35 |
Joel Sherrill |
Update from Eric Norum.
4.104.114.84.95
@010e7582
04/16/97 17:34:23 |
Joel Sherrill |
Added CVS Id's
4.104.114.84.95
@f9b93da
04/16/97 17:33:04 |
Joel Sherrill |
Added the MC68040 Floating Point Support Package. This was ported
to …
4.104.114.84.95
@b584751
04/15/97 17:37:12 |
Joel Sherrill |
Switched all bsps which had an implementation of sbrk.c which only …
4.104.114.84.95
@ecc4594
04/15/97 17:28:26 |
Joel Sherrill |
Removed many BSPs' copy of setvec.c and let them share the same …
4.104.114.84.95
@bc7d465
04/11/97 18:41:38 |
Joel Sherrill |
replaced linking of source from mvme147 drivers with use of vpath to …
4.104.114.84.95
@18e5d86
04/11/97 18:40:04 |
Joel Sherrill |
removed commented out line performing a link
4.104.114.84.95
@c46ce854
04/09/97 20:19:07 |
Joel Sherrill |
printing task names now instead of id numbers
4.104.114.84.95
@fc7bc51
04/09/97 20:18:54 |
Joel Sherrill |
new files.
4.104.114.84.95
@9d5152f
04/09/97 20:07:22 |
Joel Sherrill |
added rtmonuse and cpuuse directories
4.104.114.84.95
@8f695a1
04/09/97 20:07:09 |
Joel Sherrill |
added cpuuse and rtmonuse directories
4.104.114.84.95
@e39e6f7
04/09/97 20:05:59 |
Joel Sherrill |
added code to prevent attempts to clean up the library when rtems is
down.
4.104.114.84.95
@0956b52
04/09/97 20:05:37 |
Joel Sherrill |
correct incorrect register addresses for port a.
4.104.114.84.95
@8c0dc2c
04/09/97 20:05:12 |
Joel Sherrill |
removed unused is_character_ready routine.
4.104.114.84.95
@e2d79559
04/09/97 14:05:50 |
Joel Sherrill |
Added ka9q tcpip stack and network driver for the gen68360. This …
4.104.114.84.95
@bed475e
04/08/97 11:53:54 |
Joel Sherrill |
added cast to eliminate warning.
4.104.114.84.95
@9ffcaa4a
04/07/97 21:30:58 |
Joel Sherrill |
changed signed int to unsigned int to eliminate a warning.
4.104.114.84.95
@bd71da7
04/07/97 21:30:42 |
Joel Sherrill |
removed noreturn attribute to eliminate warnings.
4.104.114.84.95
@82478528
04/07/97 21:30:16 |
Joel Sherrill |
commented out sccs_id's to eliminate warnings.
4.104.114.84.95
@dd1d1c7
04/07/97 21:29:49 |
Joel Sherrill |
added prototype and return statement to eliminate warnings.
4.104.114.84.95
@f1fc782e
04/07/97 21:29:09 |
Joel Sherrill |
main.c: added return …
4.104.114.84.95
@318976f
04/07/97 21:28:21 |
Joel Sherrill |
removed reference to no_bsp.
added prototypes.
4.104.114.84.95
@de1d716
04/07/97 21:27:59 |
Joel Sherrill |
commented out sccs_id to eliminate warnings
4.104.114.84.95
@2938c1a3
04/07/97 21:27:22 |
Joel Sherrill |
added or fixed includes of page_table.h to eliminate warnings.
4.104.114.84.95
@588c9ed
04/07/97 21:26:49 |
Joel Sherrill |
4.104.114.84.95
@930b3d5
04/07/97 21:26:34 |
Joel Sherrill |
added prototype for delay.
4.104.114.84.95
@3bc409c
04/07/97 21:26:22 |
Joel Sherrill |
added global statement for start entry point
4.104.114.84.95
