@2fabda6
01/31/00 14:45:43 |
Joel Sherrill |
Modification to properly support BSP aliases (pc[456]86).
4.104.114.84.95
@71aeab4d
01/31/00 14:45:27 |
Joel Sherrill |
Suggested modification from Rosimildo da Silva …
4.104.114.84.95
@49440a6e
01/31/00 14:43:38 |
Joel Sherrill |
Added AC_SUBST(RTEMS_BSP) so the makefiles properly honor the
BSP …
4.104.114.84.95
@8be7bef
01/31/00 14:42:18 |
Joel Sherrill |
BSP now links although this change is untested.
4.104.114.84.95
@c01ba67
01/28/00 15:27:58 |
Joel Sherrill |
Patch from John M. Mills <jmills@…> to include more
information …
4.104.114.84.95
@a1f89b4
01/26/00 14:22:34 |
Joel Sherrill |
No longer incorrectly references mips.
4.104.114.84.95
@21677c0e
01/26/00 14:20:08 |
Joel Sherrill |
Patch rtems-rc-20000118-0.diff from Ralf Corsepius …
4.104.114.84.95
@41b27b94
01/23/00 18:29:45 |
Joel Sherrill |
Wrong BSP referenced.
4.104.114.84.95
@b9478fc6
01/21/00 01:47:22 |
Joel Sherrill |
Patch from Eric Norum <eric@…>:
Some excellent …
4.104.114.84.95
@20eb69d
01/14/00 17:41:20 |
Joel Sherrill |
Now ignores minimum and does not run it.
4.104.114.84.95
@512a536
01/14/00 17:40:49 |
Joel Sherrill |
Now using Makefile.am to generate this file.
4.104.114.84.95
@c819ea4
01/14/00 14:44:11 |
Joel Sherrill |
Removed numerous warnings.
4.104.114.84.95
@5890919
01/13/00 22:11:35 |
Joel Sherrill |
Updated files missed in earlier batch from Eric Norum.
4.104.114.84.95
@b8c9883
01/13/00 20:45:07 |
Joel Sherrill |
All m68k BSPs now build with new ELF style linkcmds.
4.104.114.84.95
@ee4ddd83
01/13/00 19:23:59 |
Joel Sherrill |
Missed removing this file in an earlier commit. This is removed …
4.104.114.84.95
@9b2c969
01/13/00 15:07:03 |
Joel Sherrill |
Made sweep of changes to get all BSPs to the same point on the …
4.104.114.84.95
@c0ebf02
01/13/00 15:06:24 |
Joel Sherrill |
New patch from Eric Norum plus some minor mods by Joel.
4.104.114.84.95
@e60d75d
01/13/00 14:28:10 |
Joel Sherrill |
Fixed spacing.
4.104.114.84.95
@bd9e482a
01/13/00 14:05:11 |
Joel Sherrill |
Made _clear_end a "PROVIDE."
4.104.114.84.95
@c1d2cc9
01/12/00 17:58:34 |
Joel Sherrill |
Patch rtems-rc-20000104-16.diff from Ralf Corsepius …
4.104.114.84.95
@b2b4835
01/12/00 16:38:57 |
Joel Sherrill |
Eric Norum <eric@…> submitted linker script and bsp_specs …
4.104.114.84.95
@69537ca9
01/12/00 16:38:56 |
Joel Sherrill |
4.104.114.84.95
@737a599
01/12/00 16:05:58 |
Joel Sherrill |
Patch rtems-rc-20000104-15.diff from Ralf Corsepius …
4.104.114.84.95
@76c2b35
01/11/00 19:09:24 |
Joel Sherrill |
File removed as it was not being used.
4.104.114.84.95
@0dd1d44
01/11/00 17:34:20 |
Joel Sherrill |
Removed old hack of using Configuration Table entry …
4.104.114.84.95
@86c9eb0
01/11/00 14:57:41 |
Joel Sherrill |
Bug fix from Wayne Bullaughey <wayneb@…> to use the …
4.104.114.84.95
@0f59d63f
01/10/00 21:38:43 |
Joel Sherrill |
Now automake generated.
4.104.114.84.95
@710f76a
01/10/00 21:37:57 |
Joel Sherrill |
Added mpc6xx/timer/Makefile.
4.104.114.84.95
@01ab7019
01/10/00 21:36:34 |
Joel Sherrill |
Accidentally deleted.
4.104.114.84.95
@119204d8
01/10/00 20:40:41 |
Joel Sherrill |
Removed warning by changing %eax -> %ax as source of move to segment …
4.104.114.84.95
@f9bcb58
01/10/00 20:12:11 |
Joel Sherrill |
Corrected compilation problem in lgdt instruction.
4.104.114.84.95
@f4d21dd
01/10/00 19:07:40 |
Joel Sherrill |
Added include of <bsp/irq.h> per Jay Kulpinski <jskulpin@…>.
4.104.114.84.95
@f983d57
01/10/00 18:16:59 |
Joel Sherrill |
Patch rtems-rc-20000104-14.diff from Ralf Corsepius …
4.104.114.84.95
@362ec23e
01/10/00 18:10:59 |
Joel Sherrill |
Patch rtems-rc-20000104-12.diff from Ralf Corsepius …
4.104.114.84.95
@94a86c40
01/10/00 15:18:20 |
Joel Sherrill |
Per suggestions of Eric Valette <valette@…> and Jay …
4.104.114.84.95
@6e7b6ca
01/10/00 15:03:28 |
Joel Sherrill |
Fixed unterminated comment spotted by eagle eye Ralf Corsepius …
4.104.114.84.95
@bc2f04f
01/10/00 14:50:45 |
Joel Sherrill |
Patch rtems-rc-20000104-13.diff from Ralf Corsepius …
4.104.114.84.95
@5fa14794
01/10/00 14:31:16 |
Joel Sherrill |
Patch rtems-rc-20000104-11.diff from Ralf Corsepius …
4.104.114.84.95
@7068e246
01/10/00 14:29:44 |
Joel Sherrill |
Patch rtems-rc-20000104-10.diff from Ralf Corsepius …
4.104.114.84.95
@53ab4823
01/10/00 14:23:56 |
Joel Sherrill |
Patch rtems-rc-20000104-9.diff from Ralf Corsepius …
4.104.114.84.95
@4200321a
01/10/00 14:17:28 |
Joel Sherrill |
Patch rtems-rc-20000104-7.diff from Ralf Corsepius …
4.104.114.84.95
@1597ab4a
01/10/00 14:17:27 |
Joel Sherrill |
Patch rtems-rc-20000104-8.diff from Ralf Corsepius …
4.104.114.84.95
@59909bf
01/10/00 14:09:12 |
Joel Sherrill |
Patch rtems-rc-20000104-6.diff from Ralf Corsepius …
4.104.114.84.95
@d0a8b4b8
01/10/00 14:07:00 |
Joel Sherrill |
Patch rtems-rc-20000104-4.diff from Ralf Corsepius …
4.104.114.84.95
@82f1f6d
01/10/00 14:06:59 |
Joel Sherrill |
4.104.114.84.95
@0cbfa283
01/10/00 14:04:50 |
Joel Sherrill |
4.104.114.84.95
@1e562da6
01/10/00 14:04:49 |
Joel Sherrill |
Patch rtems-rc-20000104-5.diff from Ralf Corsepius …
4.104.114.84.95
@49e05f41
01/10/00 14:03:32 |
Joel Sherrill |
4.104.114.84.95
@10726095
01/10/00 13:59:35 |
Joel Sherrill |
Patch rtems-rc-20000104-3.diff from Ralf Corsepius …
4.104.114.84.95
@94608578
01/10/00 13:56:35 |
Joel Sherrill |
Patch rtems-rc-20000104-2.diff from Ralf Corsepius …
4.104.114.84.95
@338f1dc
01/10/00 13:26:00 |
Joel Sherrill |
Patch from Eric Valette <valette@…> that makes sure the …
4.104.114.84.95
@1d54d3b
01/07/00 20:39:45 |
Joel Sherrill |
Renaming mcp750 to motorola_shared since that is the basis for both …
4.104.114.84.95
@35d9acb3
01/07/00 18:52:14 |
Joel Sherrill |
Patch from John M. Mills <jmills@…> to correct the baseline …
4.104.114.84.95
@c3538f3
01/07/00 14:52:48 |
Joel Sherrill |
Patch from Emmanuel Raguet <raguet@…> which corrects the …
4.104.114.84.95
@0ff37e68
01/07/00 14:47:02 |
Joel Sherrill |
Patch rtems-rc-20000104-0.diff from Ralf Corsepius …
4.104.114.84.95
@0312d81f
01/05/00 23:01:05 |
Joel Sherrill |
Fixed comment thanks to John M. Mills <jmills@…>.
4.104.114.84.95
@3a8b95e
01/05/00 21:32:57 |
Joel Sherrill |
Spacing corrected.
4.104.114.84.95
@66fe6be6
01/05/00 18:40:20 |
Joel Sherrill |
patch from Eric Norum <eric@…> as follows:
At the …
4.104.114.84.95
@69405459
01/05/00 18:40:14 |
Joel Sherrill |
Patch from Eric Norum <eric@…> as follows:
At the …
4.104.114.84.95
@afe8c1b6
01/04/00 13:49:05 |
Joel Sherrill |
Added shared version of this file.
4.104.114.84.95
@7b0ff008
01/04/00 13:48:48 |
Joel Sherrill |
Made to compile again.
4.104.114.84.95
@393be8e
01/03/00 20:43:29 |
Joel Sherrill |
Fixed path to shared/include/coverhd.h.
4.104.114.84.95
@0af1b73f
01/03/00 17:27:06 |
Joel Sherrill |
In another attempt to …
4.104.114.84.95
@110136a
01/03/00 16:53:07 |
Joel Sherrill |
Updated times.
4.104.114.84.95
@205d5645
01/03/00 16:44:04 |
Joel Sherrill |
Patch from John Mills <jmills@…> to correct some cut and paste …
4.104.114.84.95
@6b7cf9f
01/03/00 15:39:06 |
Joel Sherrill |
Patch rtems-rc-19991203-12.diff from Ralf Corsepius …
4.104.114.84.95
@b84176b
01/03/00 15:36:18 |
Joel Sherrill |
Do not explicitly list pieces from libcpu used.
4.104.114.84.95
@32f19fb3
01/03/00 14:38:47 |
Joel Sherrill |
Share align_h.S from ppc403. VPATH was not picking it up. Discovered …
4.104.114.84.95
@e07b6868
01/03/00 14:14:37 |
Joel Sherrill |
Added tm27 stuff.
4.104.114.84.95
@95273a6
01/03/00 14:06:42 |
Joel Sherrill |
Combination of coverhd.h cleanup and MVME23xx/MCP750 patch from Eric …
4.104.114.84.95
@d5c4681e
01/03/00 14:04:22 |
Joel Sherrill |
Use shared coverhd.h.
4.104.114.84.95
@2116e33
12/21/99 20:29:57 |
Joel Sherrill |
Reverted the delay logic.
4.104.114.84.95
@ed46b47
12/21/99 20:29:40 |
Joel Sherrill |
Moved PPC_Set_decrementer() and PPC_Get_timebase_register() to …
4.104.114.84.95
@56018097
12/21/99 20:28:13 |
Joel Sherrill |
Now use coverhd.h out of the libbsp/shared directory.
4.104.114.84.95
@0d6f0b4
12/21/99 20:10:04 |
Joel Sherrill |
Now use shared coverhd.h
4.104.114.84.95
@5d807b5
12/21/99 17:06:31 |
Joel Sherrill |
New files.
4.104.114.84.95
@a3ba9f98
12/21/99 17:05:15 |
Joel Sherrill |
New file.
4.104.114.84.95
@8437abd4
12/21/99 16:56:31 |
Joel Sherrill |
Removed as part of moving this driver to libchip.
4.104.114.84.95
@400c552
12/21/99 16:20:38 |
Joel Sherrill |
Removing Makefile.in and adding Makefile.am. These were missed in …
4.104.114.84.95
@fb16fed
12/21/99 15:25:05 |
Joel Sherrill |
Patch rtems-rc-19991203-10.diff from Ralf Corsepius …
4.104.114.84.95
@9ba1f0a
12/21/99 15:04:48 |
Joel Sherrill |
Patch rtems-rc-19991203-9.diff from Ralf Corsepius …
4.104.114.84.95
@35d7b15
12/21/99 14:41:43 |
Joel Sherrill |
Patch rtems-rc-19991203-7.diff from Ralf Corsepius …
4.104.114.84.95
@0fe48346
12/21/99 14:34:30 |
Joel Sherrill |
4.104.114.84.95
@8b91282
12/21/99 14:27:52 |
Joel Sherrill |
Patch rtems-rc-19991203-5.diff from Ralf Corsepius …
4.104.114.84.95
@947c27aa
12/16/99 14:30:34 |
Joel Sherrill |
Spelling error corrected.
4.104.114.84.95
@e8918ec
12/13/99 22:12:03 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to change to gen68360 clock …
4.104.114.84.95
@c629812
12/13/99 22:10:45 |
Joel Sherrill |
Removed warnings.
4.104.114.84.95
@da8ae79b
12/13/99 21:21:31 |
Joel Sherrill |
Warning removal patch from Philip A. Prindeville <philipp@…>.
4.104.114.84.95
@1c98d28
12/13/99 20:35:09 |
Joel Sherrill |
Patch rtems-19991203.sh2.diff from John M. Mills <jmills@…> …
4.104.114.84.95
@f9669ce5
12/13/99 20:06:27 |
Joel Sherrill |
Patch from Silverio Diquigiovanni <silverio.di@…> to correct
TPC …
4.104.114.84.95
@5dae90a
12/13/99 17:37:25 |
Joel Sherrill |
Patch rtems-rc-19991203-3.diff from Ralf Corsepius …
4.104.114.84.95
@ad0c286
12/13/99 16:02:57 |
Joel Sherrill |
4.104.114.84.95
@fa178d49
12/13/99 15:57:41 |
Joel Sherrill |
4.104.114.84.95
@d9230ea
12/13/99 14:49:38 |
Joel Sherrill |
Added RTEMS_IO_ERROR.
4.104.114.84.95
@49be66d
12/13/99 14:48:58 |
Joel Sherrill |
Now builds and installs properly.
4.104.114.84.95
@76c356f
12/03/99 15:46:17 |
Joel Sherrill |
Patch from Aleksey (Quality Quorum <qqi@…>) to change the …
4.104.114.84.95
@eb17041
12/03/99 14:01:11 |
Joel Sherrill |
Removed warnings.
4.104.114.84.95
@ad9a21a
12/03/99 13:53:01 |
Joel Sherrill |
New file.
4.104.114.84.95
@a0a6f67f
12/03/99 13:48:53 |
Joel Sherrill |
Added more timing information.
4.104.114.84.95
@5707fe9
12/03/99 13:46:13 |
Joel Sherrill |
New file based on information from <valette@…>.
4.104.114.84.95
