@2cee553
03/29/12 11:52:16 |
Daniel Hellstrom |
LEON3: various cleanups in leon.h
Removed old LEON2 definitions never …
4.115
@226771c
03/29/12 11:52:14 |
Daniel Hellstrom |
LEON3: IRQ index mask was bad, but always shifted out anyway
4.115
@4fa6be9
03/29/12 11:52:13 |
Daniel Hellstrom |
LEON3: clock timer indexing should be consequent
Signed-off-by: …
4.115
@0729e2a7
03/28/12 08:49:27 |
Daniel Hellstrom |
SPARC: bsp_early_malloc() routine for startup memory allocation
If …
4.115
@d0dbcf8
03/29/12 11:52:11 |
Daniel Hellstrom |
LEON3: fix GRETH interrupt initialization bug
Fixed a bug where the …
4.115
@39671330
12/02/11 09:53:35 |
Daniel Hellstrom |
GRETH: added support for non-snooping GRETH 10/100 systems
When data …
4.115
@a73884e9
03/24/12 21:56:37 |
Sebastian Huber |
bsp/lm3s69xx: Reflect new Qemu patch
4.115
@bd0fb473
03/24/12 21:53:07 |
Sebastian Huber |
bsps: Shared ARMv7-M interrupt support
4.115
@0f31fddc
03/24/12 21:01:08 |
Sebastian Huber |
bsps: Add shared default IRQ handler
4.115
@b2ee4d5f
03/24/12 20:04:40 |
Sebastian Huber |
bsp/lm3s69xx: Format
4.115
@954393ca
03/24/12 19:57:21 |
Sebastian Huber |
bsp/lm3s69xx: Use shared timer stub driver
4.115
@1ed238e
03/24/12 19:55:40 |
Sebastian Huber |
bsp/lm3s69xx: Use shared start.S
4.115
@34c61517
03/24/12 19:14:27 |
Sebastian Huber |
bsps: Shared ARMv7-M clock driver
4.115
@3c0e7f9b
03/24/12 19:06:49 |
Sebastian Huber |
bsp/lm3s69xx: New Qemu patch
4.115
@5cc813f
03/24/12 16:33:22 |
Sebastian Huber |
bsps: Provide optional prototype
4.115
@e8adc8e3
03/24/12 15:59:25 |
Sebastian Huber |
bsp/lpc24xx: Use proper clock value
4.115
@f3cdf279
03/24/12 15:58:31 |
Sebastian Huber |
bsp/lpc24xx: More CAN pin definitions
4.115
@67b1ce4
02/06/12 14:15:49 |
Daniel Hellstrom |
SMC91111: ERC32 was never supported by driver
Moved the intelligence …
4.115
@f636ba64
02/06/12 14:15:48 |
Daniel Hellstrom |
shared-irq: add support for custom BSP vector verification
4.115
@b4dfce9b
02/06/12 14:15:47 |
Daniel Hellstrom |
LEON3: spurious trap handler print out trap in hex instead
4.115
@80d01b3c
02/08/12 14:57:03 |
Daniel Hellstrom |
SPARC: added libcpu lowlevel access and byteorder routines/definitions …
4.115
@67baf60
03/14/12 17:06:13 |
Gedare Bloom |
PR2041: sparc64: vector number not included in CPU_Interrupt_frame
4.115
@4868c771
03/14/12 15:45:26 |
Sebastian Huber |
bsp/lpc24xx: New BSP variant
4.115
@2563410
03/13/12 08:22:11 |
Sebastian Huber |
Filesystem: Rename defines
o Removed RTEMS_LIBIO_PERMS_SEARCH.
o …
4.115
@4116fce6
02/24/12 16:39:27 |
Sebastian Huber |
Filesystem: New defaults fsync_h and fdatasync_h
New defaults …
4.115
@3b7c123
03/13/12 10:33:51 |
Sebastian Huber |
Filesystem: Reference counting for locations
o A new data structure …
4.115
@0bda8b4
03/09/12 16:28:39 |
Joel Sherrill |
Add missing BSD sections.
4.115
@c5a6e617
03/09/12 14:47:32 |
Sebastian Huber |
bsp/gen5200: Fix FPU initialization
The change of the MSR[FP] status …
4.115
@3bd4656
03/09/12 14:46:07 |
Sebastian Huber |
bsp/gen5200: Reflect clocks of new BRS5L hardware
4.115
@314d327
03/06/12 14:36:49 |
Joel Sherrill |
Merge branch 'master' of ssh://git.rtems.org/data/git/rtems
4.115
@47a45e5c
03/06/12 14:25:39 |
werner |
Milkymist - Increase SOFTUSB_PMEM_SIZE to 8 KB
We increased PMEM to 8 …
4.115
@dc1a3b9
03/03/12 21:02:33 |
Sebastien Bourdeauducq |
PR 2032: Milkymist USB: Ioctl interface for loading USB firmware
4.115
@f0d2261
03/03/12 20:50:53 |
Xiangfu Liu <xiangfu at sharism dot cc> |
PR2029: Milkymist VGA: adjust video timings
Slightly adjust video …
4.115
@f7bb9f9
02/29/12 16:08:44 |
werner |
PR2028: Milkymist USB: forward MIDI messages.
Forward MIDI messages …
4.115
@19d18f23
02/23/12 18:09:55 |
Joel Sherrill |
Fix typo in comment.
4.115
@8d8f363
02/21/12 15:24:37 |
Sebastian Huber |
LPC32XX: Typo
4.115
@39e8aa9
02/17/12 20:28:19 |
Joel Sherrill |
PR 2015 - LEON3: make SHM driver configurable using weak
PR 2015/bsps …
4.115
@e1ebfebf
02/11/12 20:15:06 |
Sebastian Huber |
Patches for Qemu 1.0.50
4.115
@14ee5a1e
02/11/12 20:10:12 |
Sebastian Huber |
Support for NXP LPC1700 family
4.115
@1f8771d2
02/07/12 21:11:50 |
Sebastian Huber |
Use proper ARMv7-M compiler flags.
4.115
@d6f947e
02/07/12 21:09:45 |
Sebastian Huber |
ARMv7-M Systick API change
4.115
@034b041
02/07/12 21:13:04 |
Sebastian Huber |
Fixed bug intoduced due to API changes.
4.115
@3b18c26
02/11/12 19:35:53 |
Wendell P Silva |
PR 2017/bsps - Update due to API changes
4.115
@c75430c
02/02/12 20:08:08 |
Joel Sherrill |
PR 1962/bsps - MVME162 Console Corrections and Improvements
4.115
@ce3caf87
02/02/12 20:07:09 |
Joel Sherrill |
4.115
@2b2e409d
02/02/12 14:46:27 |
Daniel Hellstrom |
LEON3: change d-cache snoop detect implementation
PR 2010/bsps
The …
4.115
@735b0ca
02/02/12 17:00:49 |
Joel Sherrill |
White space correction.
4.115
@54a169db
02/02/12 14:46:26 |
Daniel Hellstrom |
LEON3: CPU index intialization moved to bspstart.c
PR 2009/bsps
All …
4.115
@6d79be5
02/02/12 14:46:22 |
Daniel Hellstrom |
LEON3: fix compiler warning in SHM driver
PR 2008/bsps
4.115
@2a68f53
02/02/12 14:46:23 |
Daniel Hellstrom |
LEON3BSP MP: may wake one more CPU than expected
The SHM code always …
4.115
@184a612e
02/02/12 14:17:25 |
Joel Sherrill |
Merge remote branch 'remotes/origin/gitignore'
4.115
@52694844
02/01/12 21:03:18 |
Joel Sherrill |
Improve comments on console select patch.
4.115
@d1887baf
02/01/12 21:02:03 |
Joel Sherrill |
4.115
@441b90e
02/01/12 20:32:28 |
Jennifer.Averett |
Correct run-time selection of console port.
This was broken by …
4.115
@61250b4
02/01/12 16:59:44 |
Joel Sherrill |
Remove all .cvsignore files.
4.115
@34ce24e
02/01/12 16:49:55 |
Joel Sherrill |
Add minimal .gitignore files.
4.115
@41572c4
01/31/12 21:15:20 |
Joel Sherrill |
Fix spelling error and improve comment.
4.115
@f4491f94
01/26/12 08:57:19 |
Sebastian Huber |
Revert "Disable optimization."
This reverts commit …
4.115
@a762dc2
01/23/12 10:19:22 |
Sebastian Huber |
Support for MPC5643L.
Rework of the start sequence to reduce the …
4.115
@8ae88d7
01/11/12 13:15:52 |
Sebastian Huber |
4.115
@70fff65
12/14/11 19:23:49 |
Joel Sherrill |
2011-12-14 Joel Sherrill <joel.sherrilL@…>
* Makefile.am: …
4.115
@3007610
12/13/11 12:17:54 |
Ralf Corsepius |
2011-12-13 Ralf Corsépius <ralf.corsepius@…>
4.115
@a1a25ae
12/12/11 19:31:48 |
Gedare Bloom |
2011-12-12 Gedare Bloom <gedare@…>
PR bsps/1989
4.115
@8bc6b663
12/12/11 19:00:48 |
Gedare Bloom |
PR bsps/1988
4.115
@e17789bf
12/12/11 18:52:18 |
Gedare Bloom |
PR bsps/1988
4.115
@ac4f31c8
12/10/11 04:07:46 |
Ralf Corsepius |
2011-12-10 Ralf Corsépius <ralf.corsepius@…>
4.115
@de5868fe
12/10/11 04:03:50 |
Ralf Corsepius |
PR 1986/libcpu …
4.115
@2eddd4d
12/09/11 16:12:46 |
Joel Sherrill |
2011-12-09 Joel Sherrill <joel.sherrill@…>
4.115
@bf5d715
12/09/11 13:12:40 |
Ralf Corsepius |
2011-12-09 Ralf Corsépius <ralf.corsepius@…>
* console/vt.c: …
4.115
@32f2304a
12/09/11 13:10:15 |
Ralf Corsepius |
4.115
@ba5df99c
12/09/11 07:20:28 |
Ralf Corsepius |
4.115
@ff335a37
12/07/11 18:13:14 |
Ralf Corsepius |
2011-12-07 Ralf Corsépius <ralf.corsepius@…>
4.115
@3bbffec7
12/07/11 18:10:52 |
Ralf Corsepius |
4.115
@f41fb2b
12/06/11 14:01:55 |
Sebastian Huber |
2011-12-06 Sebastian Huber <sebastian.huber@…>
4.115
@6dbbe5b8
12/06/11 13:52:48 |
Sebastian Huber |
4.115
@96d29be
12/05/11 15:22:51 |
Gedare Bloom |
2011-12-05 Gedare Bloom <gedare@…>
* ChangeLog?: Add PR …
4.115
@51441425
12/05/11 15:21:50 |
Gedare Bloom |
2011-12-05 Sebastien Bourdeauducq <seb@…>
4.115
@0a962fb
12/02/11 16:44:46 |
Joel Sherrill |
2011-12-02 Joel Sherrill <joel.sherrill@…>
4.115
@f865fc5d
12/01/11 08:20:03 |
Ralf Corsepius |
2011-12-01 Ralf Corsépius <ralf.corsepius@…>
4.115
@a6b5e836
12/01/11 08:16:05 |
Ralf Corsepius |
4.115
@9521992
12/01/11 08:06:06 |
Ralf Corsepius |
4.115
@be8feba8
11/30/11 04:48:11 |
Joel Sherrill |
2011-11-29 Joel Sherrill <joel.sherrilL@…>
* Makefile.am: …
4.115
@267357a
11/27/11 17:33:00 |
Gedare Bloom |
2011-11-27 Sebastien Bourdeauducq <seb@…>
PR 1972/bsps
4.115
@b8ee42c
11/27/11 17:30:18 |
Gedare Bloom |
PR 1970/bsps
4.115
@cc3b482
11/27/11 17:30:11 |
Gedare Bloom |
PR 1970/bsps
4.115
@0f653ba
11/27/11 17:26:32 |
Gedare Bloom |
PR 1966/bsps
4.115
@6fa94b7
11/27/11 17:26:25 |
Gedare Bloom |
PR 1966/bsps
4.115
@7fc2c2cb
11/18/11 20:13:03 |
Jennifer.Averett |
2011-11-18 Jennifer Averett <Jennifer.Averett@…>
PR 1925 …
4.115
@1c0b8d7
11/18/11 20:11:08 |
Jennifer.Averett |
PR 1925 …
4.115
@7c0273e
11/18/11 20:08:15 |
Jennifer.Averett |
4.115
@3aefd34
11/10/11 14:42:08 |
Sebastian Huber |
2011-11-10 Sebastian Huber <sebastian.huber@…>
PR …
4.115
@f0e748c
11/10/11 08:44:37 |
Sebastian Huber |
PR …
4.115
@5c0fb7c
11/10/11 08:25:45 |
Sebastian Huber |
PR …
4.115
@4a6cc2a
11/08/11 10:39:46 |
Sebastian Huber |
2011-11-08 Sebastian Huber <sebastian.huber@…>
4.115
@4c622e5
11/08/11 10:18:19 |
Sebastian Huber |
4.115
@d922dab
11/08/11 10:13:32 |
Sebastian Huber |
4.115
@d558bc49
11/08/11 10:08:14 |
Sebastian Huber |
4.115
@edb1dd83
11/08/11 10:05:50 |
Sebastian Huber |
4.115
@467c767
11/07/11 21:46:19 |
Joel Sherrill |
2011-11-07 Joel Sherrill <joel.sherrill@…>
PR 1953/bsps
4.115
@3dcdad4a
11/07/11 21:46:16 |
Joel Sherrill |
PR 1953/bsps
4.115
