Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src/lib
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @29e68b75   07/26/99 21:26:44 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: This patch is … 4.104.114.84.95
(edit) @08b5f55   07/26/99 20:31:49 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: A bug in … 4.104.114.84.95
(edit) @eb299afc   07/26/99 20:20:22 Joel Sherrill This is part of a major patch from Ralf Corsepius … 4.104.114.84.95
(edit) @6693a68   07/26/99 20:00:37 Joel Sherrill This is part of a major patch from Ralf Corsepius … 4.104.114.84.95
(edit) @1f42090   07/23/99 19:33:28 Joel Sherrill Patch to ease building MCP750 BSP. 4.104.114.84.95
(edit) @38e4a916   07/13/99 14:54:16 Joel Sherrill Patch from Rosimildo DaSilva? <rdasilva@…> to readd calls … 4.104.114.84.95
(edit) @09ea257c   07/12/99 15:52:35 Joel Sherrill Patch from Eric Norum <eric@…>: I get the following … 4.104.114.84.95
(edit) @f421132   07/09/99 18:23:59 Joel Sherrill New files from Jiri Gaisler <jgais@…>. 4.104.114.84.95
(edit) @2728b074   07/09/99 17:23:15 Joel Sherrill New file from Jake Janovetz <janovetz@…>. 4.104.114.84.95
(edit) @93180ea2   07/09/99 17:16:10 Joel Sherrill Patch from Eric Valette <valette@…>: - The same bug fix … 4.104.114.84.95
(edit) @b73e57b   07/09/99 17:08:48 Joel Sherrill Patch from Jiri Gaisler <jgais@…>: + interrupt … 4.104.114.84.95
(edit) @771c1479   07/03/99 15:38:38 Joel Sherrill New files missed in previous addition. 4.104.114.84.95
(edit) @a381e6e4   07/03/99 15:33:08 Joel Sherrill Added some C++/GNU sections. 4.104.114.84.95
(edit) @c8d9183   07/02/99 18:57:11 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> that splits … 4.104.114.84.95
(edit) @a0a225f   07/02/99 18:50:40 Joel Sherrill Added code to initialize the /etc/group and /etc/passwd files. 4.104.114.84.95
(edit) @c51917f3   07/02/99 18:09:03 Joel Sherrill Fixed format strings and warnings. 4.104.114.84.95
(edit) @c3d20eb   07/02/99 18:03:43 Joel Sherrill Reentrant versions added by Joel. Signficant formatting cleanup. 4.104.114.84.95
(edit) @258fd79   07/02/99 17:13:27 Joel Sherrill Password and group routines added by Ralf Corsepius … 4.104.114.84.95
(edit) @fcee56c0   07/01/99 23:39:13 Joel Sherrill Patch from Eric Valette <valette@…> to clean up the … 4.104.114.84.95
(edit) @78b78e2   07/01/99 22:43:09 Joel Sherrill Another attempt at getting everything to build with the new powerpc libcpu. 4.104.114.84.95
(edit) @2a85368d   07/01/99 22:42:33 Joel Sherrill Fixed typo. 4.104.114.84.95
(edit) @e7792b25   07/01/99 22:07:32 Joel Sherrill Cleaned up to behave properly -- does not make a directory in the … 4.104.114.84.95
(edit) @6be1238   07/01/99 22:06:49 Joel Sherrill Now preinstalls header files. 4.104.114.84.95
(edit) @9519bf4   07/01/99 22:05:36 Joel Sherrill Removed mkdir of libcpu. This should have been at the top of the tree. 4.104.114.84.95
(edit) @28861e8d   07/01/99 22:05:10 Joel Sherrill Remove mkdir command. It should be at the top level of the tree. 4.104.114.84.95
(edit) @7782f9fc   07/01/99 21:53:17 Joel Sherrill Modified to provide symbols with and without leading underscore in … 4.104.114.84.95
(edit) @e2ba0af6   07/01/99 21:52:33 Joel Sherrill Modified to support ELF. Before SYM() macro was not used consistently. 4.104.114.84.95
(edit) @4e556493   07/01/99 21:52:01 Joel Sherrill Modified to ignore console interrupts. Otherwise console interrupts … 4.104.114.84.95
(edit) @455d8552   06/24/99 17:53:16 Joel Sherrill Added dummy gnatinstallhandler code for all BSPs. This lets Ada … 4.104.114.84.95
(edit) @e72dfa23   06/18/99 14:30:09 Joel Sherrill Patch from Eric Valette <valette@…> based on bug report … 4.104.114.84.95
(edit) @123bbf9   06/18/99 14:12:26 Joel Sherrill Removed pc386 specific command. 4.104.114.84.95
(edit) @dd55c5e7   06/17/99 21:51:32 Joel Sherrill Switched to using right INSTALL command after report from Ian Lance … 4.104.114.84.95
(edit) @8c92fa3   06/16/99 14:55:28 Joel Sherrill Patcg from Ralf Corsepius <corsepiu@…>: -- configure … 4.104.114.84.95
(edit) @d2d22780   06/15/99 22:46:44 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: > When I run … 4.104.114.84.95
(edit) @cf1806b4   06/15/99 22:17:10 Joel Sherrill Attempt at getting desired ioctl.h included. :) 4.104.114.84.95
(edit) @937ab62c   06/15/99 22:16:30 Joel Sherrill After comments D. V. Henkel-Wallace <gumby@…>, the interface … 4.104.114.84.95
(edit) @8e0dcade   06/15/99 22:01:04 Joel Sherrill Patch from Rosimildo DaSilva? <rdasilva@…> to make C++ … 4.104.114.84.95
(edit) @4ecc390   06/14/99 20:18:56 Joel Sherrill RTEMS_FILESYSTEM_READ_WRITE_ONLY changed to … 4.104.114.84.95
(edit) @d741406c   06/14/99 20:18:13 Joel Sherrill Wrong prototype corrected. 4.104.114.84.95
(edit) @0ac8e382   06/14/99 19:44:07 Joel Sherrill Warning removal from D. V. Henkel-Wallace <gumby@…>. 4.104.114.84.95
(edit) @15aa5ffb   06/14/99 18:54:24 Joel Sherrill Patch ("FIX: no_cpu/no_bsp") from Ralf Corsepius … 4.104.114.84.95
(edit) @fbe75c6e   06/14/99 18:17:33 Joel Sherrill This is a large patch from Eric Valette <valette@…> that … 4.104.114.84.95
(edit) @a4f6b02   06/14/99 17:54:21 Joel Sherrill This is a large patch from Eric Valette <valette@…> that … 4.104.114.84.95
(edit) @ba46ffa6   06/14/99 16:51:13 Joel Sherrill This is a large patch from Eric Valette <valette@…> that … 4.104.114.84.95
(edit) @d001776f   06/11/99 14:49:13 Joel Sherrill Added local prototype of ioctl() to avoid requiring sys/ioctl.h. 4.104.114.84.95
(edit) @a6f3cff   06/11/99 14:11:44 Joel Sherrill Patch from Ian Lance Taylor <ian@…>: The select function … 4.104.114.84.95
(edit) @0643693   06/11/99 14:06:13 Joel Sherrill Patch from Eric Norum <eric@…> to fix bug reported by Ian … 4.104.114.84.95
(edit) @5a0592c   06/09/99 16:47:49 Joel Sherrill Do not use the RTEMS simpleioctl.h if networking is enabled since that … 4.104.114.84.95
(edit) @8dba373   06/09/99 13:50:47 Joel Sherrill Switched to using strcasecmp() since it is more portable. D. V. … 4.104.114.84.95
(edit) @a5d697dc   06/02/99 16:14:36 Joel Sherrill Removed "NO CTOR" from list of objects to be picked up. It now comes … 4.104.114.84.95
(edit) @f74abcf7   05/28/99 18:21:25 Joel Sherrill Changes from Eric Norum to add a loop and limit on the length of time … 4.104.114.84.95
(edit) @8f2cb41c   05/28/99 16:10:05 Joel Sherrill Use fgrep instead of grep to avoid treating filenames as regular … 4.104.114.84.95
(edit) @403d7b18   05/28/99 16:09:00 Joel Sherrill Alignment corrected per Eric Norum's suggestion. 4.104.114.84.95
(edit) @d54bdfaf   05/28/99 16:08:38 Joel Sherrill Corrected to include shared console driver. 4.104.114.84.95
(edit) @bb7b1260   05/28/99 14:09:53 Joel Sherrill Renamed config.c to conscfg.c to avoid naming conflicts. 4.104.114.84.95
(edit) @caa11739   05/28/99 14:09:34 Joel Sherrill Renamed config.s to todcfg.c to avoid naming conflicts. 4.104.114.84.95
(edit) @7afa2dd   05/28/99 14:02:21 Joel Sherrill Renamed fatal.c to bspfatal.c to avoid name conflicts with Fatal Error … 4.104.114.84.95
(edit) @af84b968   05/27/99 18:53:02 Joel Sherrill Switched from picking up the .rel for each subdirectory in the BSP … 4.104.114.84.95
(edit) @11cdbeb   05/27/99 18:03:50 Joel Sherrill Patch from Eric Norum <eric@…> to eliminate a panic when … 4.104.114.84.95
(edit) @1c841bd2   05/27/99 16:13:19 Joel Sherrill Split out the routine rtems_assoc_name_bad(). 4.104.114.84.95
(edit) @556ea0e3   05/27/99 16:12:20 Joel Sherrill Removed usage of printf. 4.104.114.84.95
(edit) @5adf355a   05/27/99 16:11:52 Joel Sherrill Split initialization and reserve resources from termios to reduce size … 4.104.114.84.95
(edit) @1d1b1507   05/27/99 16:08:40 Joel Sherrill Split out polled io, debug puts, and console reserve resources to … 4.104.114.84.95
(edit) @7398901   05/27/99 15:46:00 Joel Sherrill Regenerated. 4.104.114.84.95
(edit) @8bbaf3b   05/20/99 13:32:54 Joel Sherrill Removed all post 4.0 changes. 4.104.114.84.95
(edit) @fbec4a1   05/18/99 17:33:52 Joel Sherrill Regenerated. 4.104.114.84.95
(edit) @0090c1a   05/18/99 17:31:27 Joel Sherrill Spacing correction. 4.104.114.84.95
(edit) @a238cc9   05/17/99 15:45:15 Joel Sherrill Patch from D. V. Henkel-Wallace <gumby@…> to remove compiler … 4.104.114.84.95
(edit) @44dd8a61   05/14/99 16:23:42 Joel Sherrill Added 3COM 3C509 driver from Rosimildo DaSilva? <rdasilva@…>. 4.104.114.84.95
(edit) @c5881fc1   05/14/99 15:31:07 Joel Sherrill Enabled compilation of rtems_servers at request of Jake Janovetz … 4.104.114.84.95
(edit) @4c5080ed   05/11/99 16:30:51 Joel Sherrill Fix based on bug report from Jay Kulpinski <jskulpin@…> … 4.104.114.84.95
(edit) @ddd22e5   05/11/99 15:15:03 Joel Sherrill Patch from Erik Ivanenko <erik.ivanenko@…> to correct 32 bit … 4.104.114.84.95
(edit) @acb644a6   05/07/99 16:30:44 Joel Sherrill Error reporting fixed by Jennifer. 4.104.114.84.95
(edit) @c34aaae7   05/07/99 16:29:54 Joel Sherrill Bug fix from Gunter Magin <magin@@skil.camelot.de>: in … 4.104.114.84.95
(edit) @b06279d   05/07/99 16:28:43 Joel Sherrill Bug fix from Gunter Magin <magin@…>: in … 4.104.114.84.95
(edit) @8846bbd   04/28/99 13:59:11 Joel Sherrill Patch from Emmanuel Raguet <raguet@…>: I have made … 4.104.114.84.95
(edit) @cfcb5a2   04/27/99 17:31:39 Joel Sherrill Patch from Eric Norum <eric@…> to corrent a miscount in … 4.104.114.84.95
(edit) @16a384cf   04/23/99 16:35:11 Joel Sherrill New BSP from Tony R. Ambardar <tonya@…> from the University … 4.104.114.84.95
(edit) @933388ae   04/22/99 21:13:23 Joel Sherrill Added lstat(). 4.104.114.84.95
(edit) @4186b3b   04/19/99 17:17:41 Joel Sherrill Changed ioctl() prototype to be more like Linux/POSIX than BSD to ease … 4.104.114.84.95
(edit) @1059abcd   04/19/99 15:37:36 Joel Sherrill Regenerated. 4.104.114.84.95
(edit) @7807b30e   04/19/99 15:36:21 Joel Sherrill Direct .gcc_exc section to ram to eliminate the warning Ralf Corsepius … 4.104.114.84.95
(edit) @7cdf7fc1   04/19/99 15:27:19 Joel Sherrill After discussion with Eric Norum <eric@…>, I added … 4.104.114.84.95
(edit) @db047f1   04/19/99 14:41:23 Joel Sherrill Patch from Erik Ivanenko <erik.ivanenko@…> to eliminate a … 4.104.114.84.95
(edit) @82307a11   04/19/99 13:25:50 Joel Sherrill New files. 4.104.114.84.95
(edit) @5dc30fb   04/19/99 13:20:15 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> to add scitabs.c … 4.104.114.84.95
(edit) @196094eb   04/19/99 13:19:14 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: This one is … 4.104.114.84.95
(edit) @9572c41   04/19/99 13:11:13 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: This is an … 4.104.114.84.95
(edit) @60e6a0f   04/19/99 13:06:07 Joel Sherrill Fixed some spacing issues. 4.104.114.84.95
(edit) @c00fa38   04/16/99 18:17:31 Joel Sherrill Patch from Ralf Corsepius <corsepiu@@faw.uni-ulm.de>: 2) … 4.104.114.84.95
(edit) @98d051f   04/16/99 18:15:08 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: 1) … 4.104.114.84.95
(edit) @4a22e7a   04/16/99 18:08:27 Joel Sherrill Corrected to reflect new way of doing mips constructors. 4.104.114.84.95
(edit) @2a4791f   04/16/99 18:08:09 Joel Sherrill Added .eh_fram and .gcc_exc sections. 4.104.114.84.95
(edit) @d006519b   04/15/99 19:01:32 Joel Sherrill Added reentrant versions. 4.104.114.84.95
(edit) @a68e6b9   04/15/99 18:58:43 Joel Sherrill Updated version string. 4.104.114.84.95
(edit) @3c87bb9c   04/14/99 22:33:30 Joel Sherrill Minor corrections from Jay Kulpinski <jskulpin@…>. … 4.104.114.84.95
(edit) @2b28307   04/14/99 18:18:03 Joel Sherrill Bug report from Ralf on UNIX port where the S_IR* constants were not … 4.104.114.84.95
(edit) @76e5fe8a   04/13/99 22:50:24 Joel Sherrill Bug fix from Brendan Simon <brendan@…> with fix … 4.104.114.84.95
(edit) @6e27f588   04/12/99 20:27:14 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: Installing of … 4.104.114.84.95
(edit) @8cdb582   04/12/99 15:41:33 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: This patch … 4.104.114.84.95
