@27ea47c
11/22/99 13:45:55 |
Joel Sherrill |
Removed unneeded directory.
4.104.114.84.95
@9608320
11/22/99 13:41:11 |
Joel Sherrill |
Patch rtems-rc-19991117-4.diff from Ralf Corsepius …
4.104.114.84.95
@d2a05e7
11/19/99 16:40:40 |
Joel Sherrill |
Renaming all BSP specific startXXX directories to use the same name …
4.104.114.84.95
@9c0385a
11/19/99 16:22:09 |
Joel Sherrill |
4.104.114.84.95
@149f3f9
11/19/99 16:06:32 |
Joel Sherrill |
Moved startsis to start.
4.104.114.84.95
@4a238002
11/18/99 21:22:58 |
Joel Sherrill |
Patch from "John M. Mills" <jmills@…> with subsequent cleanup …
4.104.114.84.95
@08311cc3
11/17/99 17:51:34 |
Joel Sherrill |
Updated copyright notice.
4.104.114.84.95
@39827cc
11/17/99 17:31:51 |
Joel Sherrill |
Now allows override of base address via -Ttext command to linker.
4.104.114.84.95
@23d9392f
11/17/99 15:42:18 |
Joel Sherrill |
New file documenting the on board monitor (PPCBUG) configuration used …
4.104.114.84.95
@0b0441af
11/16/99 22:57:32 |
Joel Sherrill |
Added TERMINAL_IDENTIFICATION pieces.
4.104.114.84.95
@38d65f80
11/16/99 22:56:53 |
Joel Sherrill |
Fixed alignment problem on _endtext.
4.104.114.84.95
@9181246
11/16/99 22:45:51 |
Jennifer.Averett |
Fixed bug.
4.104.114.84.95
@18c3155
11/16/99 22:45:33 |
Jennifer.Averett |
Added handler for fsync. For the memfile it is the same as the data sync.
4.104.114.84.95
@ce18601a
11/16/99 16:13:26 |
Joel Sherrill |
Removed start subdirectory and distributed contents to the appropriate …
4.104.114.84.95
@31473b7
11/16/99 16:03:21 |
Joel Sherrill |
Works now.
Removed times() since the version in the C Library support …
4.104.114.84.95
@817031f
11/16/99 15:28:03 |
Joel Sherrill |
New file.
4.104.114.84.95
@c7016198
11/16/99 15:27:52 |
Joel Sherrill |
Added.
4.104.114.84.95
@b88691c
11/16/99 15:26:29 |
Joel Sherrill |
Source and destination arguments to strncpy were swapped. This …
4.104.114.84.95
@ac656f2d
11/16/99 14:15:56 |
Joel Sherrill |
Moved start code from lib/start to libbsp.
4.104.114.84.95
@25f705e
11/16/99 13:55:35 |
Joel Sherrill |
4.104.114.84.95
@1d04e16
11/16/99 13:45:51 |
Joel Sherrill |
4.104.114.84.95
@7f93f772
11/16/99 13:37:49 |
Joel Sherrill |
Committed modifications from ITRON Task and Task Dependendent …
4.104.114.84.95
@a7d988a
11/16/99 13:37:25 |
Joel Sherrill |
Minor changes since new Makefile.
4.104.114.84.95
@14dbf50
11/16/99 13:34:41 |
Joel Sherrill |
Added start subdirectory.
4.104.114.84.95
@1bcdb3f6
11/16/99 13:31:13 |
Joel Sherrill |
4.104.114.84.95
@d102810e
11/11/99 02:39:12 |
Joel Sherrill |
Updated.
4.104.114.84.95
@c73b8ac2
11/09/99 22:18:43 |
Joel Sherrill |
This patch adds the basic framework for the ITRON 3.0 API …
4.104.114.84.95
@c8cad188
11/09/99 22:16:16 |
Joel Sherrill |
Removed.
4.104.114.84.95
@d55af6d
11/09/99 15:38:47 |
Joel Sherrill |
Now using libchip instead of local precursor to libchip. Untested.
4.104.114.84.95
@53b1847
11/09/99 13:40:57 |
Joel Sherrill |
Removed reaching "up and over" to install BSP header files.
4.104.114.84.95
@b440e57b
11/09/99 13:40:30 |
Joel Sherrill |
Added imfs_unixstub.c to satisfy linker problems on UNIX port.
4.104.114.84.95
@84bf329
11/09/99 03:37:40 |
Joel Sherrill |
Added #define to make this file exactly like its siblings in mpc821 …
4.104.114.84.95
@78facc4
11/09/99 02:50:26 |
Joel Sherrill |
Removed "up and over" into libbsp/.../include.
4.104.114.84.95
@9af31a6
11/09/99 02:32:37 |
Joel Sherrill |
Moved include files to hppa1.1 subdirectory and put their sources
in …
4.104.114.84.95
@bb11d7e
11/09/99 02:31:37 |
Joel Sherrill |
Removed runway directory and moved contents to include.
4.104.114.84.95
@f758f810
11/05/99 22:26:12 |
Jennifer.Averett |
Correctly set and called handlers table for the link.
4.104.114.84.95
@089ad91d
11/05/99 22:25:16 |
Jennifer.Averett |
Fixed comment
4.104.114.84.95
@7f6a0750
11/05/99 22:24:56 |
Jennifer.Averett |
Moved imfs set handlers prototype to the imfs.h file.
4.104.114.84.95
@bf2cf8e6
11/05/99 21:20:30 |
Joel Sherrill |
New file. Added as part of adding a formal API to this object.
4.104.114.84.95
@378fe02
11/05/99 21:11:09 |
Joel Sherrill |
New file.
4.104.114.84.95
@94b357c2
11/05/99 21:10:54 |
Joel Sherrill |
Unmount was failing as a side-effect of splitting the rmnod handler …
4.104.114.84.95
@7edb9281
11/05/99 19:02:03 |
Joel Sherrill |
Following comments from Eric Norum <eric@…>, a fairly …
4.104.114.84.95
@0fab6dde
11/05/99 17:49:56 |
Joel Sherrill |
Patch from Eric Valette <valette@…> so this will build …
4.104.114.84.95
@458bd34
11/05/99 16:44:02 |
Joel Sherrill |
This is another pass at making sure that nothing outside the BSP …
4.104.114.84.95
@f817b02
11/04/99 18:05:09 |
Joel Sherrill |
The files in libcpu should not be directly dependent on any BSP. In …
4.104.114.84.95
@d76608e0
11/03/99 12:46:29 |
Joel Sherrill |
Typo fixed by Ralf Corsepius <corsepiu@…>.
4.104.114.84.95
@b568ccb
11/02/99 20:20:13 |
Joel Sherrill |
The object memfile.o was being included in the miniIMFS even though it …
4.104.114.84.95
@5f2566b
11/02/99 16:27:53 |
Joel Sherrill |
Fixed F_SETFL to properly convert between internal
libio flags and …
4.104.114.84.95
@063e4950
11/02/99 16:27:05 |
Joel Sherrill |
Added support for configuring base filesystem. First attempt at
a …
4.104.114.84.95
@a504ced3
11/02/99 16:25:48 |
Joel Sherrill |
Install imfs.h so base filesystem can be configured or IMFS mounted
by …
4.104.114.84.95
@19b74f31
11/02/99 16:25:05 |
Joel Sherrill |
Check for NULL being passed in.
4.104.114.84.95
@3fb2a8da
11/02/99 16:23:50 |
Joel Sherrill |
Fixed typo where memfile_handlers set twice and directory_handlers
was …
4.104.114.84.95
@ac8adcf
11/02/99 16:22:58 |
Joel Sherrill |
Properly initialize location variable.
4.104.114.84.95
@c42bd452
11/02/99 16:05:41 |
Joel Sherrill |
Split console_reserve_resources into its own file to reduce …
4.104.114.84.95
@dee8a51
11/01/99 21:34:04 |
Joel Sherrill |
Corrected wildcard to pickup CPU model dependent library pieces.
4.104.114.84.95
@92f69999
11/01/99 13:08:35 |
Joel Sherrill |
Removed all references to shared memory driver as it is not supported …
4.104.114.84.95
@a2504f7
11/01/99 13:07:56 |
Joel Sherrill |
Removed shmsupp directory as it is not really implemented.
4.104.114.84.95
@4c9d61e8
11/01/99 13:07:22 |
Joel Sherrill |
MVME2307 does not really include MP support.
4.104.114.84.95
@4a07d2b
10/29/99 15:19:13 |
Jennifer.Averett |
Moved the rmnod callback from the operations table to the handler table.
4.104.114.84.95
@4bde8072
10/29/99 14:28:39 |
Jennifer.Averett |
Joel added a table of mount entry requests to be processed during …
4.104.114.84.95
@7046cdd
10/28/99 16:01:41 |
Joel Sherrill |
Patch rtems-rc-19991011-3.diff from Ralf Corsepius.
4.104.114.84.95
@c8b35b1b
10/28/99 13:36:26 |
Joel Sherrill |
Notes on what to do when merging a BSP.
4.104.114.84.95
@45544f0
10/27/99 20:50:57 |
Joel Sherrill |
Patch from Aleksey (Quality Quorum <qqi@…>) to
increase …
4.104.114.84.95
@3abbfdb
10/27/99 19:27:05 |
Joel Sherrill |
Added $(EXEEXT) in attempt to help Cygwin install process.
4.104.114.84.95
@2bdc1e98
10/27/99 18:54:14 |
Joel Sherrill |
Last cleanup to attempt to link.
4.104.114.84.95
@ae7325bd
10/27/99 17:25:53 |
Joel Sherrill |
rxgen960 now compiles -- may not link.
4.104.114.84.95
@2ea8df3
10/27/99 16:27:34 |
Joel Sherrill |
Added CVS Ids and a basic header. More header cleanup needed.
4.104.114.84.95
@f08a5596
10/27/99 16:26:00 |
Joel Sherrill |
Removed systbl.S save_systbl.c. They were unnecessary.
4.104.114.84.95
@8ac4213
10/27/99 16:21:49 |
Joel Sherrill |
Removed sctns.S. This file was obviously the output of the compiler.
4.104.114.84.95
@919822f
10/27/99 16:19:24 |
Joel Sherrill |
Replaced Makefile.in's with modified copies of cvme961 to get …
4.104.114.84.95
@d73a8649
10/27/99 15:58:26 |
Joel Sherrill |
Moved timerisr.s to timerisr.S per GNU conventions.
4.104.114.84.95
@ce644256
10/27/99 15:57:20 |
Joel Sherrill |
Moved systbl.s to systbl.S per GNU conventions.
4.104.114.84.95
@5ee66da
10/27/99 15:57:19 |
Joel Sherrill |
Moved sctns.s to sctns.S per GNU conventions.
4.104.114.84.95
@bf71be9e
10/27/99 15:57:17 |
Joel Sherrill |
Moved rxgen_romld.s to rxgen_romld.S per GNU conventions.
4.104.114.84.95
@478c4b8
10/27/99 15:57:16 |
Joel Sherrill |
Moved ihandler.s to ihandler.S per GNU conventions.
4.104.114.84.95
@49b8c26
10/27/99 15:57:15 |
Joel Sherrill |
Moved asmstub.s to asmstub.S per GNU conventions.
4.104.114.84.95
@eb7f0f22
10/27/99 15:57:14 |
Joel Sherrill |
Moved asmfault.s to asmfault.S per GNU conventions.
4.104.114.84.95
@702c5f5
10/27/99 15:29:18 |
Joel Sherrill |
The rxgen960 BSP and i960 RPM support was submitted by Mark Bronson …
4.104.114.84.95
@7999174
10/26/99 21:51:20 |
Joel Sherrill |
New files created by split of old imfs_handlers.c.
4.104.114.84.95
@2fe47ff
10/26/99 21:51:07 |
Joel Sherrill |
Added include of libio.h so this would compile when posix is disabled.
4.104.114.84.95
@7ee88c16
10/26/99 20:30:20 |
Joel Sherrill |
Split console_reserve_resources to separate file to reduce
code size.
4.104.114.84.95
@657e1bf6
10/26/99 20:17:13 |
Joel Sherrill |
Added initial cut at miniIMFS which leaves out memfile and directory …
4.104.114.84.95
@66a8c6f
10/26/99 15:21:01 |
Joel Sherrill |
Patch from Emmanuel Raguet <raguet@…> to fix a small bug …
4.104.114.84.95
@2782e69
10/26/99 12:39:24 |
Joel Sherrill |
idir=/opt/tmp/opt/rtems
rdir=/opt/rtems
cd $idir
find . -type f | …
4.104.114.84.95
@a94521c
10/26/99 12:37:14 |
Joel Sherrill |
cat /tmp/j | while read f
do
rpm -qi $f 2>&1 | grep -v "is not ins"
done
4.104.114.84.95
@dd04e32
10/26/99 02:58:06 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to move …
4.104.114.84.95
@3f06778e
10/26/99 02:49:21 |
Joel Sherrill |
do
done
4.104.114.84.95
@99826740
10/26/99 01:35:36 |
Joel Sherrill |
Modifications from Erik Ivanenko <erik.ivanenko@…> to add …
4.104.114.84.95
@f70598c7
10/26/99 01:34:42 |
Joel Sherrill |
Patch from Erik Ivanenko <erik.ivanenko@…> to fix some …
4.104.114.84.95
@3eb75db3
10/25/99 14:52:19 |
Joel Sherrill |
tch from Eric Valette <valette@…> and Emmanuel Raguet …
4.104.114.84.95
@1e57186
10/25/99 14:46:56 |
Joel Sherrill |
Patch from Eric Valette <valette@…> and Emmanuel Raguet …
4.104.114.84.95
@04df848
10/25/99 14:23:03 |
Jennifer.Averett |
Added code to correctly free any allocated space during the evaluation …
4.104.114.84.95
@c774a07e
10/25/99 14:09:46 |
Joel Sherrill |
Changed leading spaces to periods to ease comparing test output.
4.104.114.84.95
@538db54
10/25/99 14:09:13 |
Joel Sherrill |
Modified to produce correct output with new version of sis.
4.104.114.84.95
@a6883c4
10/12/99 20:22:27 |
Joel Sherrill |
Spacing.
4.104.114.84.95
@51435fc7
10/12/99 19:26:37 |
Joel Sherrill |
Split null handlers table to own file and renamed.
Renamed IMFS …
4.104.114.84.95
@dd0f326
10/12/99 19:10:46 |
Joel Sherrill |
Added rtems_filesystem_freenode() macro and added calls at appropriate …
4.104.114.84.95
@e2116f9
10/12/99 19:09:27 |
Joel Sherrill |
Fixed spacing.
4.104.114.84.95
@578a415
10/12/99 19:08:55 |
Joel Sherrill |
Corrected mistakes in the IMFS file handlers table and added the …
4.104.114.84.95
@d71fcab
10/12/99 18:44:40 |
Joel Sherrill |
Added call to freenod to let each filesystem free its own internal …
4.104.114.84.95
