# # ChangeLog for c/src/lib in rtems # # Generated by Trac 1.2.1.dev0 # 05/03/24 02:03:49 Wed, 04 Sep 2013 12:03:47 GMT Sebastian Huber [d157a4fd] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Fix ARM CP15 opcode for get functions Thu, 29 Aug 2013 20:20:03 GMT Karel Gardas [0c47440] * c/src/lib/libbsp/arm/lm3s69xx/configure.ac (modified) * c/src/lib/libbsp/arm/lm3s69xx/include/lm3s69xx.h (modified) * c/src/lib/libbsp/arm/lm3s69xx/include/syscon.h (modified) * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm4f120.cfg (added) * c/src/lib/libbsp/arm/lm3s69xx/ssi/ssi.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/linkcmds.lm4f120 (added) * c/src/lib/libbsp/arm/lm3s69xx/startup/syscon.c (modified) bsp/lm4f120: new BSP to support TI LM4F120 XL LaunchPad board Mon, 26 Aug 2013 13:14:33 GMT Sebastian Huber [1215fd4] * c/src/lib/libcpu/powerpc/mpc55xx/edma/edma.c (modified) * c/src/libchip/ide/ata.c (modified) * cpukit/posix/src/aio_cancel.c (modified) * cpukit/posix/src/aio_misc.c (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/rtems/chain.h (modified) * cpukit/sapi/src/chainsmp.c (added) * testsuites/libtests/block06/init.c (modified) * testsuites/sptests/spchain/init.c (modified) sapi: SMP support for chains Add ISR lock to chain control for ... Mon, 26 Aug 2013 11:00:53 GMT Sebastian Huber [d56f76a] * c/src/lib/libbsp/shared/bootcard.c (modified) * c/src/lib/libbsp/shared/include/bootcard.h (modified) bsps: Fix header includes Mon, 26 Aug 2013 19:26:50 GMT Joel Sherrill [3109857c] * c/src/lib/libbsp/i386/pc386/clock/ckinit.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) bsps: Add and use CLOCK_DRIVER_ISRS_PER_TICK_VALUE pc386 set ... Thu, 22 Aug 2013 12:18:14 GMT Ric Claus [2bd440e] * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/cache_.h (added) * c/src/lib/libcpu/shared/src/cache_manager.c (modified) bsp/xilinx-zynq: Add cache support Thu, 22 Aug 2013 12:00:51 GMT Ric Claus [c9b66f5] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Add more CP15 cache functions Thu, 08 Aug 2013 23:22:06 GMT Pavel Pisa [2a2f559] * c/src/lib/libbsp/arm/csb336/start/start.S (modified) * c/src/lib/libbsp/arm/csb336/startup/memmap.c (modified) bsp/csb336: Memory map update and jump to start at image start ... Wed, 14 Aug 2013 13:35:58 GMT Karel Gardas [526f895] * c/src/lib/libbsp/arm/lm3s69xx/include/io.h (modified) bsp/lm3s69xx: add macros for UART CTS/RTS pin configuration Wed, 14 Aug 2013 11:26:41 GMT Sebastian Huber [d473dc0] * c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c (modified) * c/src/lib/libbsp/lm32/shared/clock/ckinit.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_clock/ckinit.c (modified) * c/src/lib/libbsp/mips/jmr3904/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/rbtx4925/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/rbtx4938/clock/clockdrv.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon2/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) * c/src/lib/libcpu/arm/pxa255/clock/clock.c (modified) * c/src/lib/libcpu/bfin/clock/clock.c (modified) bsps: Fix clock driver defines Wed, 14 Aug 2013 01:53:28 GMT Chris Johns [b7f2060] * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) bsp: Fix CLOCK_DRIVER_USE_FAST_IDLE and CLOCK_DRIVER_ISRS_PER_TICK. ... Tue, 13 Aug 2013 12:43:54 GMT Sebastian Huber [c32c80e] * c/src/lib/libbsp/arm/shared/arm-gic-irq.c (modified) bsps/arm: Use proper default priority for GIC Some GIC ... Fri, 02 Aug 2013 14:28:23 GMT Sebastian Huber [4e3b7e26] * c/src/lib/libbsp/i386/shared/irq/irq_asm.S (modified) bsps/i386: SMP and per-CPU thread dispatch disable Interrupt ... Fri, 02 Aug 2013 07:05:29 GMT Sebastian Huber [55b1aee4] * c/src/lib/libbsp/i386/shared/irq/irq_asm.S (modified) bsps/i386: Revert most SMP related changes The commit partially ... Fri, 02 Aug 2013 12:12:55 GMT Sebastian Huber [f8ad6c6f] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) sparc: Make _CPU_ISR_Dispatch_disable per-CPU This variable must be ... Fri, 02 Aug 2013 12:06:52 GMT Sebastian Huber [88f6c4fc] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) sparc: Move _CPU_Context_switch(), etc. Move the ... Fri, 09 Aug 2013 09:12:56 GMT Sebastian Huber [8b077ca0] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) bsps/sparc: SMP and per-CPU thread dispatch disable Interrupt ... Thu, 01 Aug 2013 09:35:16 GMT Sebastian Huber [849bb7a3] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) bsps/sparc: Revert most SMP related changes As a side-effect the ... Thu, 01 Aug 2013 14:36:55 GMT Sebastian Huber [c6c998b] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_asm_macros.h (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) bsps/powerpc: Per-CPU thread dispatch disable Interrupt support for ... Mon, 05 Aug 2013 12:54:11 GMT Sebastian Huber [d19cce29] * c/src/lib/libbsp/mips/shared/irq/exception.S (modified) * c/src/lib/libcpu/sparc64/shared/score/interrupt.S (modified) * cpukit/rtems/src/clocktick.c (modified) * cpukit/rtems/src/taskrestart.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/bfin/cpu_asm.S (modified) * cpukit/score/cpu/h8300/cpu_asm.S (modified) * cpukit/score/cpu/m68k/cpu_asm.S (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/include/rtems/score/isr.h (modified) * cpukit/score/include/rtems/score/objectimpl.h (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/assertthreaddispatchingrepressed.c (modified) * cpukit/score/src/isrsmp.c (deleted) * cpukit/score/src/percpuasm.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threaddispatchdisablelevel.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadloadenv.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadstartmultitasking.c (modified) * testsuites/smptests/smp06/init.c (modified) * testsuites/sptests/sp37/init.c (modified) * testsuites/tmtests/tm25/task1.c (modified) * testsuites/tmtests/tm26/task1.c (modified) score: Per-CPU thread dispatch disable level Use a per-CPU thread ... Fri, 09 Aug 2013 13:23:15 GMT Sebastian Huber [838d714] * c/src/lib/libbsp/i386/pc386/3c509/elink.c (modified) bsp/pc386: Provide local outb() for elink driver Fri, 09 Aug 2013 08:22:42 GMT Chris Johns [c31a7129] * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_zc706_smp.cfg (added) * c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zc706_smp (added) bsp/xilinx_zynq_zc706_smp: Add. Fri, 09 Aug 2013 04:18:17 GMT Nick Withers [efdda565] * c/src/lib/libbsp/arm/gba/make/custom/gba.cfg (modified) * c/src/lib/libbsp/arm/gp32/make/custom/gp32.cfg (modified) * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s69xx.inc (modified) * c/src/lib/libbsp/arm/nds/make/custom/nds.cfg (modified) * c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.cfg (modified) * c/src/lib/libbsp/i386/pc386/make/custom/pc386.cfg (modified) * c/src/lib/libbsp/lm32/lm32_evr/make/custom/lm32_evr.cfg (modified) * c/src/lib/libbsp/lm32/milkymist/make/custom/milkymist.cfg (modified) * c/src/lib/libbsp/m68k/av5282/make/custom/av5282.cfg (modified) * c/src/lib/libbsp/m68k/genmcf548x/make/custom/genmcf548x.inc (modified) * c/src/lib/libbsp/m68k/idp/make/custom/idp.cfg (modified) * c/src/lib/libbsp/m68k/mcf52235/make/custom/mcf52235.cfg (modified) * c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x.cfg (modified) * c/src/lib/libbsp/m68k/mcf5235/make/custom/mcf5235.cfg (modified) * c/src/lib/libbsp/m68k/mcf5329/make/custom/mcf5329.cfg (modified) * c/src/lib/libbsp/m68k/mrm332/make/custom/mrm332.cfg (modified) * c/src/lib/libbsp/m68k/mvme136/make/custom/mvme136.cfg (modified) * c/src/lib/libbsp/m68k/mvme147/make/custom/mvme147.cfg (modified) * c/src/lib/libbsp/m68k/mvme147s/make/custom/mvme147s.cfg (modified) * c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162.cfg (modified) * c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162lx.cfg (modified) * c/src/lib/libbsp/m68k/mvme167/make/custom/mvme167.cfg (modified) * c/src/lib/libbsp/m68k/sim68000/make/custom/sim68000.cfg (modified) * c/src/lib/libbsp/m68k/sim68000/make/custom/simcpu32.cfg (modified) * c/src/lib/libbsp/m68k/uC5282/make/custom/uC5282.cfg (modified) * c/src/lib/libbsp/nios2/nios2_iss/make/custom/nios2_iss.cfg (modified) * c/src/lib/libbsp/powerpc/haleakala/make/custom/haleakala.cfg (modified) * c/src/lib/libbsp/powerpc/mbx8xx/make/custom/mbx8xx.inc (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mcp750.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mtx603e.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2100.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2307.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep-altivec.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep.cfg (modified) * c/src/lib/libbsp/powerpc/mvme3100/make/custom/mvme3100.cfg (modified) * c/src/lib/libbsp/powerpc/mvme5500/make/custom/mvme5500.cfg (modified) * c/src/lib/libbsp/powerpc/qemuppc/make/custom/qemuppc.cfg (modified) * c/src/lib/libbsp/powerpc/score603e/make/custom/score603e.cfg (modified) * c/src/lib/libbsp/powerpc/ss555/make/custom/ss555.cfg (modified) * c/src/lib/libbsp/powerpc/tqm8xx/make/custom/tqm8xx.inc (modified) * c/src/lib/libbsp/powerpc/virtex/make/custom/virtex.cfg (modified) * c/src/lib/libbsp/powerpc/virtex4/make/custom/virtex4.cfg (modified) * c/src/lib/libbsp/powerpc/virtex5/make/custom/virtex5.cfg (modified) * c/src/make/leaf.cfg (modified) * make/leaf.cfg (modified) Use $(EXEEXT) [defaults to "exe"] to generate binaries Thu, 08 Aug 2013 23:23:14 GMT Pavel Pisa [98bcf4ff] * c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c (modified) bsp/csb336: implement bsp_interrupt_vector_enable/disable. ... Thu, 08 Aug 2013 23:21:15 GMT Pavel Pisa [e4b16ea9] * c/src/lib/libbsp/arm/csb336/startup/linkcmds (modified) bsp/csb336: Fix MMU _ttbl_base location to not overlap with exception ... Tue, 06 Aug 2013 14:10:26 GMT Sebastian Huber [ae75429] * c/src/ada-tests/support/init.c (modified) * c/src/lib/libbsp/i386/shared/irq/irq.c (modified) * cpukit/libcsupport/src/__gettod.c (modified) * cpukit/libcsupport/src/error.c (modified) * cpukit/libcsupport/src/malloc_p.h (modified) * cpukit/libcsupport/src/mallocfreespace.c (modified) * cpukit/libcsupport/src/mallocgetheapptr.c (modified) * cpukit/libcsupport/src/mallocsetheapptr.c (modified) * cpukit/libcsupport/src/newlibc_reent.c (modified) * cpukit/libcsupport/src/sync.c (modified) * cpukit/libfs/src/pipe/fifo.c (modified) * cpukit/libmisc/monitor/mon-config.c (modified) * cpukit/libmisc/monitor/mon-driver.c (modified) * cpukit/libmisc/monitor/mon-itask.c (modified) * cpukit/libmisc/monitor/mon-mpci.c (modified) * cpukit/libmisc/monitor/mon-object.c (modified) * cpukit/libmisc/monitor/mon-symbols.c (modified) * cpukit/libmisc/shell/main_wkspaceinfo.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_malloc_mbuf.c (modified) * testsuites/libtests/malloctest/init.c (modified) * testsuites/psxtests/psxfatal_support/system.h (modified) * testsuites/psxtests/psxsignal05/init.c (modified) * testsuites/psxtests/psxstack01/init.c (modified) * testsuites/psxtests/psxstack02/init.c (modified) * testsuites/sptests/sp40/init.c (modified) * testsuites/sptests/sp67/init.c (modified) * testsuites/sptests/sp75/init.c (modified) * testsuites/sptests/spfatal_support/system.h (modified) * testsuites/sptests/spintrcritical06/init.c (modified) * testsuites/sptests/spintrcritical08/init.c (modified) * testsuites/sptests/spintrcritical09/init.c (modified) * testsuites/sptests/spintrcritical10/init.c (modified) * testsuites/sptests/spintrcritical16/init.c (modified) * testsuites/sptests/spobjgetnext/init.c (modified) PR766: Delete __RTEMS_VIOLATE_KERNEL_VISIBILITY__ Tue, 06 Aug 2013 14:03:40 GMT Sebastian Huber [00630411] * c/src/lib/libbsp/powerpc/beatnik/startup/bspstart.c (modified) * cpukit/rtems/include/rtems.h (modified) PR766: Delete __RTEMS_APPLICATION__ This define is no longer used. Thu, 08 Aug 2013 05:34:01 GMT Chris Johns [e932c53] * c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_zc706.cfg (added) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zc706 (added) bsp/xilinx_zynq_zc706: Add. Tue, 06 Aug 2013 06:36:48 GMT Sebastian Huber [5a556e4e] * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (modified) bsp/realview-pbx-a9: Enable fast idle clock Wed, 31 Jul 2013 11:42:07 GMT Sebastian Huber [f031df0e] * c/src/lib/libcpu/bfin/clock/rtc.c (modified) * cpukit/libcsupport/src/__gettod.c (modified) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/posix/src/adjtime.c (modified) * cpukit/posix/src/alarm.c (modified) * cpukit/posix/src/clockgetres.c (modified) * cpukit/posix/src/clockgettime.c (modified) * cpukit/posix/src/clocksettime.c (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/posix/src/posixtimespecabsolutetimeout.c (modified) * cpukit/posix/src/sysconf.c (modified) * cpukit/posix/src/timergettime.c (modified) * cpukit/posix/src/timersettime.c (modified) * cpukit/posix/src/timertsr.c (modified) * cpukit/posix/src/ualarm.c (modified) * cpukit/rtems/src/clockgetsecondssinceepoch.c (modified) * cpukit/rtems/src/clockgettickspersecond.c (modified) * cpukit/rtems/src/clockgettod.c (modified) * cpukit/rtems/src/clockgettodtimeval.c (modified) * cpukit/rtems/src/clockgetuptime.c (modified) * cpukit/rtems/src/clockgetuptimeseconds.c (modified) * cpukit/rtems/src/clockgetuptimetimeval.c (modified) * cpukit/rtems/src/clockset.c (modified) * cpukit/rtems/src/clocktick.c (modified) * cpukit/rtems/src/clocktodtoseconds.c (modified) * cpukit/rtems/src/clocktodvalidate.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/taskwakewhen.c (modified) * cpukit/rtems/src/timerfirewhen.c (modified) * cpukit/rtems/src/timerserver.c (modified) * cpukit/rtems/src/timerserverfirewhen.c (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/include/rtems/score/todimpl.h (moved) * cpukit/score/preinstall.am (modified) * cpukit/score/src/coretod.c (modified) * cpukit/score/src/coretodget.c (modified) * cpukit/score/src/coretodgetuptimetimespec.c (modified) * cpukit/score/src/coretodset.c (modified) * cpukit/score/src/coretodtickle.c (modified) * cpukit/score/src/coretodtickspersec.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/timespecaddto.c (modified) * cpukit/score/src/timespecdivide.c (modified) * cpukit/score/src/timespecdividebyinteger.c (modified) * cpukit/score/src/timespecfromticks.c (modified) * cpukit/score/src/timespecisvalid.c (modified) * cpukit/score/src/timespecsubtract.c (modified) * cpukit/score/src/timespectoticks.c (modified) * testsuites/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx05/init.c (modified) * testsuites/psxtests/psxclock/init.c (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/sptests/sptimespec01/init.c (modified) score: Rename tod.h to todimpl.h Tue, 30 Jul 2013 13:54:53 GMT Sebastian Huber [c236082] * c/src/lib/libbsp/i386/shared/irq/irq_asm.S (modified) * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/src/percpu.c (modified) * cpukit/score/src/percpuasm.c (modified) smp: Provide cache optimized Per_CPU_Control Delete ... Tue, 30 Jul 2013 09:09:26 GMT Sebastian Huber [b23abb48] * c/src/lib/libbsp/i386/shared/smp/smp-imps.c (modified) bsps/i386: Include missing header and fix warnings Fri, 26 Jul 2013 12:10:25 GMT Sebastian Huber [fe52e7c0] * c/src/lib/libbsp/i386/shared/smp/smp-imps.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/smp.c (modified) * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/src/percpu.c (modified) * cpukit/score/src/schedulerdefaulttick.c (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * testsuites/smptests/smpschedule01/init.c (modified) smp: Add and use _Per_CPU_Get() Add and use _Per_CPU_Get_by_index() ... Fri, 26 Jul 2013 14:53:39 GMT Vipul Nayyar [2bdcf4fd] * c/src/lib/libbsp/i386/pc386/3c509/3c509.c (modified) * c/src/lib/libbsp/i386/pc386/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/pc386/console/ps2_mouse.c (modified) * c/src/lib/libbsp/i386/pc386/console/vgacons.c (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/wd8003/wd8003.c (modified) * c/src/lib/libbsp/i386/shared/comm/tty_drv.c (modified) * c/src/lib/libbsp/i386/shared/smp/smp-imps.c (modified) Updated legacy code in i386 pc386 Fri, 26 Jul 2013 07:52:43 GMT Sebastian Huber [fcff6c7] * c/src/lib/libbsp/arm/nds/fb/fb.c (modified) bsp/nds: Include missing Fri, 26 Jul 2013 07:18:05 GMT Sebastian Huber [4e00fe62] * c/src/lib/libbsp/powerpc/gen5200/bestcomm/bestcomm_glue.c (modified) * c/src/lib/libbsp/shared/src/stackalloc.c (modified) bsps: Include missing Wed, 24 Jul 2013 17:49:51 GMT Vipul Nayyar [1f4321b] * c/src/lib/libbsp/arm/csb336/console/uart.c (modified) * c/src/lib/libbsp/arm/csb336/network/network.c (modified) * c/src/lib/libbsp/arm/csb337/network/network.c (modified) Removed legacy data types from arm Thu, 25 Jul 2013 08:34:50 GMT Pavel Pisa [02632e8] * c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c (modified) bsp/csb336: mc9328mxl correct AITC access in bsp_interrupt_dispatch. ... Thu, 25 Jul 2013 13:10:11 GMT Sebastian Huber [88c74ab] * c/src/ada-tests/support/init.c (modified) * c/src/lib/libbsp/i386/pc386/ide/ide.c (modified) * c/src/lib/libbsp/lm32/shared/startup/bspstart.c (modified) * c/src/lib/libcpu/bfin/clock/rtc.c (modified) * c/src/libchip/network/cs8900.c (modified) * c/src/libchip/network/open_eth.c (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libcsupport/src/__gettod.c (modified) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c (modified) * cpukit/posix/src/alarm.c (modified) * cpukit/posix/src/clockgetcpuclockid.c (modified) * cpukit/posix/src/clockgetenableattr.c (modified) * cpukit/posix/src/clockgetres.c (modified) * cpukit/posix/src/clockgettime.c (modified) * cpukit/posix/src/clocksetenableattr.c (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/posix/src/nanosleep.c (modified) * cpukit/posix/src/posixtimespecabsolutetimeout.c (modified) * cpukit/posix/src/ptimer.c (modified) * cpukit/posix/src/sched_getscheduler.c (modified) * cpukit/posix/src/sched_rr_get_interval.c (modified) * cpukit/posix/src/sched_setparam.c (modified) * cpukit/posix/src/sched_setscheduler.c (modified) * cpukit/posix/src/sysconf.c (modified) * cpukit/posix/src/timergettime.c (modified) * cpukit/posix/src/timersettime.c (modified) * cpukit/posix/src/timertsr.c (modified) * cpukit/posix/src/ualarm.c (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) * cpukit/rtems/include/rtems/rtems/support.h (modified) * cpukit/rtems/include/rtems/rtems/types.h (modified) * cpukit/rtems/src/clockget.c (modified) * cpukit/rtems/src/clockgetsecondssinceepoch.c (modified) * cpukit/rtems/src/clockgettickspersecond.c (modified) * cpukit/rtems/src/clockgettickssinceboot.c (modified) * cpukit/rtems/src/clockgettod.c (modified) * cpukit/rtems/src/clockgettodtimeval.c (modified) * cpukit/rtems/src/clockgetuptime.c (modified) * cpukit/rtems/src/clockgetuptimeseconds.c (modified) * cpukit/rtems/src/clockgetuptimetimeval.c (modified) * cpukit/rtems/src/clocksetnsecshandler.c (modified) * cpukit/rtems/src/clocktodtoseconds.c (modified) * cpukit/rtems/src/clocktodvalidate.c (modified) * cpukit/rtems/src/rtclock.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/signalsend.c (modified) * cpukit/rtems/src/taskident.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/taskwakewhen.c (modified) * cpukit/rtems/src/timercancel.c (modified) * cpukit/rtems/src/timercreate.c (modified) * cpukit/rtems/src/timerdelete.c (modified) * cpukit/rtems/src/timerfireafter.c (modified) * cpukit/rtems/src/timerfirewhen.c (modified) * cpukit/rtems/src/timergetinfo.c (modified) * cpukit/rtems/src/timerident.c (modified) * cpukit/rtems/src/timerreset.c (modified) * cpukit/rtems/src/timerserver.c (modified) * cpukit/rtems/src/timerserverfireafter.c (modified) * cpukit/rtems/src/timerserverfirewhen.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/tod.h (modified) * cpukit/score/inline/rtems/score/tod.inl (deleted) * cpukit/score/preinstall.am (modified) * cpukit/score/src/coretod.c (modified) * cpukit/score/src/coretodget.c (modified) * cpukit/score/src/coretodgetuptimetimespec.c (modified) * cpukit/score/src/coretodmsecstoticks.c (deleted) * cpukit/score/src/coretodset.c (modified) * cpukit/score/src/coretodtickle.c (modified) * cpukit/score/src/coretodtickspersec.c (modified) * cpukit/score/src/coretodusectoticks.c (deleted) * cpukit/score/src/timespecaddto.c (modified) * cpukit/score/src/timespecdivide.c (modified) * cpukit/score/src/timespecdividebyinteger.c (modified) * cpukit/score/src/timespecfromticks.c (modified) * cpukit/score/src/timespecisvalid.c (modified) * cpukit/score/src/timespeclessthan.c (modified) * cpukit/score/src/timespecsubtract.c (modified) * cpukit/score/src/timespectoticks.c (modified) * cpukit/score/src/ts64toticks.c (modified) * testsuites/libtests/block06/init.c (modified) * testsuites/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx05/init.c (modified) * testsuites/psxtests/psxclock/init.c (modified) * testsuites/samples/nsecs/init.c (modified) * testsuites/sptests/sp01/task1.c (modified) * testsuites/sptests/sp16/task5.c (modified) * testsuites/sptests/spcbssched01/task1.c (modified) * testsuites/sptests/spedfsched01/task1.c (modified) score: Merge tod implementation into one file Delete ... Wed, 24 Jul 2013 11:50:54 GMT Sebastian Huber [a2e3f33] * c/src/lib/libbsp/shared/gdbstub/rtems-stub-glue.c (modified) * cpukit/libcsupport/src/getdents.c (modified) * cpukit/libcsupport/src/getegid.c (modified) * cpukit/libcsupport/src/geteuid.c (modified) * cpukit/libcsupport/src/getlogin.c (modified) * cpukit/libcsupport/src/getpgrp.c (modified) * cpukit/libcsupport/src/getpid.c (modified) * cpukit/libcsupport/src/getppid.c (modified) * cpukit/libcsupport/src/realloc.c (modified) * cpukit/libcsupport/src/setegid.c (modified) * cpukit/libcsupport/src/utsname.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/monitor/monitor.h (modified) * cpukit/posix/include/rtems/posix/barrierimpl.h (modified) * cpukit/posix/include/rtems/posix/condimpl.h (modified) * cpukit/posix/include/rtems/posix/key.h (modified) * cpukit/posix/include/rtems/posix/posixapi.h (modified) * cpukit/posix/include/rtems/posix/pthreadimpl.h (modified) * cpukit/posix/include/rtems/posix/rwlockimpl.h (modified) * cpukit/posix/include/rtems/posix/spinlockimpl.h (modified) * cpukit/posix/include/rtems/posix/threadsup.h (modified) * cpukit/posix/include/rtems/posix/timerimpl.h (modified) * cpukit/posix/src/barrierattrdestroy.c (modified) * cpukit/posix/src/cond.c (modified) * cpukit/posix/src/condattrdestroy.c (modified) * cpukit/posix/src/condattrgetpshared.c (modified) * cpukit/posix/src/condattrinit.c (modified) * cpukit/posix/src/condattrsetpshared.c (modified) * cpukit/posix/src/condbroadcast.c (modified) * cpukit/posix/src/conddefaultattributes.c (modified) * cpukit/posix/src/conddestroy.c (modified) * cpukit/posix/src/condget.c (modified) * cpukit/posix/src/condinit.c (modified) * cpukit/posix/src/condsignal.c (modified) * cpukit/posix/src/condsignalsupp.c (modified) * cpukit/posix/src/condtimedwait.c (modified) * cpukit/posix/src/condwait.c (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/keyrundestructors.c (modified) * cpukit/posix/src/posixtimespecabsolutetimeout.c (modified) * cpukit/posix/src/rwlockattrdestroy.c (modified) * cpukit/posix/src/semaphore.c (modified) * cpukit/posix/src/semaphorecreatesupp.c (modified) * cpukit/posix/src/semaphoredeletesupp.c (modified) * cpukit/posix/src/semaphorewaitsupp.c (modified) * cpukit/posix/src/semclose.c (modified) * cpukit/posix/src/semdestroy.c (modified) * cpukit/posix/src/semgetvalue.c (modified) * cpukit/posix/src/seminit.c (modified) * cpukit/posix/src/semopen.c (modified) * cpukit/posix/src/sempost.c (modified) * cpukit/posix/src/semtimedwait.c (modified) * cpukit/posix/src/semtrywait.c (modified) * cpukit/posix/src/semunlink.c (modified) * cpukit/posix/src/semwait.c (modified) * cpukit/rtems/include/rtems/rtems/barrierimpl.h (modified) * cpukit/rtems/include/rtems/rtems/dpmemimpl.h (modified) * cpukit/rtems/include/rtems/rtems/messageimpl.h (modified) * cpukit/rtems/include/rtems/rtems/partimpl.h (modified) * cpukit/rtems/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/rtems/include/rtems/rtems/regionimpl.h (modified) * cpukit/rtems/include/rtems/rtems/tasksimpl.h (modified) * cpukit/rtems/include/rtems/rtems/timerimpl.h (modified) * cpukit/rtems/src/barrier.c (modified) * cpukit/rtems/src/barriercreate.c (modified) * cpukit/rtems/src/barrierident.c (modified) * cpukit/rtems/src/dpmem.c (modified) * cpukit/rtems/src/dpmemcreate.c (modified) * cpukit/rtems/src/dpmemdelete.c (modified) * cpukit/rtems/src/dpmemexternal2internal.c (modified) * cpukit/rtems/src/dpmemident.c (modified) * cpukit/rtems/src/dpmeminternal2external.c (modified) * cpukit/rtems/src/eventmp.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgqallocate.c (modified) * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/rtems/src/msgqdelete.c (modified) * cpukit/rtems/src/msgqflush.c (modified) * cpukit/rtems/src/msgqgetnumberpending.c (modified) * cpukit/rtems/src/msgqident.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqtranslatereturncode.c (modified) * cpukit/rtems/src/msgqurgent.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/partgetbuffer.c (modified) * cpukit/rtems/src/partident.c (modified) * cpukit/rtems/src/partreturnbuffer.c (modified) * cpukit/rtems/src/ratemon.c (modified) * cpukit/rtems/src/ratemoncreate.c (modified) * cpukit/rtems/src/ratemongetstatistics.c (modified) * cpukit/rtems/src/ratemongetstatus.c (modified) * cpukit/rtems/src/ratemonident.c (modified) * cpukit/rtems/src/ratemonresetall.c (modified) * cpukit/rtems/src/ratemonresetstatistics.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/regiondelete.c (modified) * cpukit/rtems/src/regionextend.c (modified) * cpukit/rtems/src/regiongetfreeinfo.c (modified) * cpukit/rtems/src/regiongetinfo.c (modified) * cpukit/rtems/src/regiongetsegmentsize.c (modified) * cpukit/rtems/src/regionident.c (modified) * cpukit/rtems/src/regionresizesegment.c (modified) * cpukit/rtems/src/regionreturnsegment.c (modified) * cpukit/rtems/src/rtemsbuildid.c (modified) * cpukit/rtems/src/rtemsbuildname.c (modified) * cpukit/rtems/src/rtemsobjectapimaximumclass.c (modified) * cpukit/rtems/src/rtemsobjectapiminimumclass.c (modified) * cpukit/rtems/src/rtemsobjectgetapiclassname.c (modified) * cpukit/rtems/src/rtemsobjectgetapiname.c (modified) * cpukit/rtems/src/rtemsobjectgetclassicname.c (modified) * cpukit/rtems/src/rtemsobjectgetclassinfo.c (modified) * cpukit/rtems/src/rtemsobjectgetname.c (modified) * cpukit/rtems/src/rtemsobjectidapimaximum.c (modified) * cpukit/rtems/src/rtemsobjectidapiminimum.c (modified) * cpukit/rtems/src/rtemsobjectidgetapi.c (modified) * cpukit/rtems/src/rtemsobjectidgetclass.c (modified) * cpukit/rtems/src/rtemsobjectidgetindex.c (modified) * cpukit/rtems/src/rtemsobjectidgetnode.c (modified) * cpukit/rtems/src/rtemsobjectsetname.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semident.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/taskident.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/timercancel.c (modified) * cpukit/rtems/src/timercreate.c (modified) * cpukit/rtems/src/timerdelete.c (modified) * cpukit/rtems/src/timerfireafter.c (modified) * cpukit/rtems/src/timerfirewhen.c (modified) * cpukit/rtems/src/timergetinfo.c (modified) * cpukit/rtems/src/timerident.c (modified) * cpukit/rtems/src/timerreset.c (modified) * cpukit/rtems/src/timerserverfireafter.c (modified) * cpukit/rtems/src/timerserverfirewhen.c (modified) * cpukit/sapi/include/rtems/extensionimpl.h (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/sapi/src/extensioncreate.c (modified) * cpukit/sapi/src/extensiondelete.c (modified) * cpukit/sapi/src/extensionident.c (modified) * cpukit/sapi/src/posixapi.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/apimutex.h (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/objectimpl.h (added) * cpukit/score/include/rtems/score/schedulerpriorityimpl.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/inline/rtems/score/object.inl (deleted) * cpukit/score/preinstall.am (modified) * cpukit/score/src/apimutex.c (modified) * cpukit/score/src/apimutexallocate.c (deleted) * cpukit/score/src/corebarrierrelease.c (modified) * cpukit/score/src/coremsgbroadcast.c (modified) * cpukit/score/src/coremsgclose.c (modified) * cpukit/score/src/coremsgflush.c (modified) * cpukit/score/src/coremsgflushsupp.c (modified) * cpukit/score/src/coremsgflushwait.c (modified) * cpukit/score/src/coremsginsert.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coresemsurrender.c (modified) * cpukit/score/src/coretod.c (modified) * cpukit/score/src/coretodset.c (modified) * cpukit/score/src/coretodtickle.c (modified) * cpukit/score/src/iterateoverthreads.c (modified) * cpukit/score/src/objectactivecount.c (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectapimaximumclass.c (modified) * cpukit/score/src/objectclose.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectget.c (modified) * cpukit/score/src/objectgetinfo.c (modified) * cpukit/score/src/objectgetinfoid.c (modified) * cpukit/score/src/objectgetisr.c (modified) * cpukit/score/src/objectgetnameasstring.c (modified) * cpukit/score/src/objectgetnext.c (modified) * cpukit/score/src/objectgetnoprotection.c (modified) * cpukit/score/src/objectidtoname.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/objectnamespaceremove.c (modified) * cpukit/score/src/objectnametoid.c (modified) * cpukit/score/src/objectnametoidstring.c (modified) * cpukit/score/src/objectsetname.c (modified) * cpukit/score/src/objectshrinkinformation.c (modified) * cpukit/score/src/threaddispatchdisablelevel.c (modified) * cpukit/score/src/threadqextractwithproxy.c (modified) * cpukit/score/src/threadqflush.c (modified) * testsuites/psxtests/psxobj01/init.c (modified) * testsuites/samples/unlimited/test1.c (modified) * testsuites/sptests/sp41/init.c (modified) score: Create object implementation header Move implementation ... Thu, 25 Jul 2013 08:46:15 GMT Sebastian Huber [0c3edbf] * c/src/lib/libbsp/powerpc/shared/startup/panic.c (modified) * c/src/lib/libbsp/shared/clock_driver_simidle.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_hdl.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c (modified) * c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c (modified) * cpukit/libcsupport/src/malloc_deferred.c (modified) * cpukit/libcsupport/src/privateenv.c (modified) * cpukit/libcsupport/src/sup_fs_location.c (modified) * cpukit/libcsupport/src/umask.c (modified) * cpukit/posix/src/adjtime.c (modified) * cpukit/posix/src/clocksettime.c (modified) * cpukit/rtems/src/clockset.c (modified) * cpukit/rtems/src/eventreceive.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/signalcatch.c (modified) * cpukit/rtems/src/systemeventreceive.c (modified) * cpukit/rtems/src/workspacegreedy.c (modified) * cpukit/sapi/src/ioregisterdriver.c (modified) * cpukit/sapi/src/iounregisterdriver.c (modified) * cpukit/score/cpu/arm/armv7m-isr-enter-leave.c (modified) * cpukit/score/cpu/lm32/irq.c (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/src/pheapwalk.c (modified) * cpukit/score/src/threadenabledispatch.c (modified) Include missing Wed, 24 Jul 2013 13:49:05 GMT Peter Dufault [b3a84034] * c/src/lib/libcpu/powerpc/mpc55xx/include/mpc55xx.h (modified) bsp/mpc55xx: Fix prototype Wed, 24 Jul 2013 09:09:23 GMT Sebastian Huber [39046f7] * c/src/lib/libbsp/m68k/mcf5206elite/i2c/i2c.c (modified) * c/src/lib/libbsp/powerpc/gen5200/i2c/i2c.c (modified) * c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/i2c/i2c_init.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c (modified) * c/src/lib/libbsp/powerpc/shared/motorola/vpd.c (modified) * c/src/lib/libbsp/shared/gdbstub/rtems-stub-glue.c (modified) * c/src/lib/libbsp/shared/src/irq-generic.c (modified) * c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.c (modified) * c/src/libchip/rtc/ds1375.c (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/z85c30.c (modified) * cpukit/libcsupport/src/error.c (modified) * cpukit/libcsupport/src/free.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/realloc.c (modified) * cpukit/libcsupport/src/rtems_malloc.c (modified) * cpukit/libcsupport/src/rtems_memalign.c (modified) * cpukit/libi2c/libi2c.c (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgqallocate.c (modified) * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqdelete.c (modified) * cpukit/rtems/src/msgqflush.c (modified) * cpukit/rtems/src/msgqgetnumberpending.c (modified) * cpukit/rtems/src/msgqident.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqtranslatereturncode.c (modified) * cpukit/rtems/src/msgqurgent.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/partdelete.c (modified) * cpukit/rtems/src/partgetbuffer.c (modified) * cpukit/rtems/src/partident.c (modified) * cpukit/rtems/src/partreturnbuffer.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semident.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/taskdelete.c (modified) * cpukit/rtems/src/taskgetnote.c (modified) * cpukit/rtems/src/taskident.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/rtems/src/taskissuspended.c (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/rtems/src/taskrestart.c (modified) * cpukit/rtems/src/taskresume.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/tasksetnote.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/rtems/src/taskstart.c (modified) * cpukit/rtems/src/tasksuspend.c (modified) * cpukit/rtems/src/taskwakeafter.c (modified) * cpukit/rtems/src/taskwakewhen.c (modified) * cpukit/sapi/include/rtems/sptables.h (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/sysstate.h (modified) * cpukit/score/inline/rtems/score/sysstate.inl (deleted) * cpukit/score/inline/rtems/score/thread.inl (modified) * cpukit/score/preinstall.am (modified) * cpukit/score/src/heapallocate.c (modified) * cpukit/score/src/heapextend.c (modified) * cpukit/score/src/heapgetfreeinfo.c (modified) * cpukit/score/src/heapresizeblock.c (modified) * cpukit/score/src/heapsizeofuserarea.c (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectget.c (modified) * cpukit/score/src/objectgetisr.c (modified) * cpukit/score/src/objectgetnext.c (modified) * cpukit/score/src/objectgetnoprotection.c (modified) * cpukit/score/src/objectnametoid.c (modified) * cpukit/score/src/objectnametoidstring.c (modified) * cpukit/score/src/objectshrinkinformation.c (modified) * cpukit/score/src/threadclearstate.c (modified) * cpukit/score/src/threadclose.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threaddelayended.c (modified) * cpukit/score/src/threaddisabledispatch.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threaddispatchdisablelevel.c (modified) * cpukit/score/src/threadget.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadloadenv.c (modified) * cpukit/score/src/threadready.c (modified) * cpukit/score/src/threadreset.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadsetstate.c (modified) * cpukit/score/src/threadsettransient.c (modified) * cpukit/score/src/threadstackallocate.c (modified) * cpukit/score/src/threadstackfree.c (modified) * cpukit/score/src/threadstart.c (modified) * testsuites/libtests/heapwalk/init.c (modified) * testsuites/sptests/sp08/init.c (modified) * testsuites/sptests/spfatal23/testcase.h (modified) score: Merge sysstate API into one file Wed, 24 Jul 2013 06:57:19 GMT Sebastian Huber [83015b1] * c/src/lib/libbsp/arm/lpc32xx/include/lpc32xx.h (modified) bsp/lpc32xx: Fix memory map for GPIO registers Sun, 21 Jul 2013 21:04:50 GMT Karel Gardas [dbce4c6] * c/src/lib/libbsp/arm/stm32f4/console/console-config.c (modified) bsp/stm32f4: fix typo in USART2 device name Thu, 18 Jul 2013 08:08:05 GMT Ralf Kirchner [2f589cc] * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) bsp/gen83xx: Fix BSP options for MPC8348EAMDS Thu, 13 Jun 2013 13:41:21 GMT Sebastian Huber [ca63ae2] * c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c (modified) * c/src/lib/libbsp/i386/shared/smp/smp-imps.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/smp.c (modified) * c/src/lib/libbsp/shared/smp/smp_stub.c (modified) * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/bspsmp.h (modified) * cpukit/score/src/smp.c (modified) smp: Add and use _CPU_SMP_Send_interrupt() Delete ... Fri, 14 Jun 2013 12:00:38 GMT Sebastian Huber [39e51758] * c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c (modified) * c/src/lib/libbsp/i386/shared/irq/irq_asm.S (modified) * c/src/lib/libbsp/i386/shared/smp/getcpuid.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/smp.c (modified) * c/src/lib/libbsp/shared/smp/getcpuid.c (modified) * c/src/lib/libbsp/sparc/leon3/smp/getcpuid.c (modified) * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/smp.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/bspsmp.h (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/smp.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/threaddispatchdisablelevel.c (modified) * testsuites/smptests/smp01/init.c (modified) * testsuites/smptests/smp01/tasks.c (modified) * testsuites/smptests/smp02/init.c (modified) * testsuites/smptests/smp02/system.h (modified) * testsuites/smptests/smp02/tasks.c (modified) * testsuites/smptests/smp03/init.c (modified) * testsuites/smptests/smp04/init.c (modified) * testsuites/smptests/smp05/init.c (modified) * testsuites/smptests/smp06/init.c (modified) * testsuites/smptests/smp07/init.c (modified) * testsuites/smptests/smp08/init.c (modified) * testsuites/smptests/smp08/tasks.c (modified) * testsuites/smptests/smp09/init.c (modified) * testsuites/smptests/smpatomic01/tasks.c (modified) * testsuites/smptests/smpatomic02/tasks.c (modified) * testsuites/smptests/smpatomic03/tasks.c (modified) * testsuites/smptests/smpatomic04/tasks.c (modified) * testsuites/smptests/smpatomic05/tasks.c (modified) * testsuites/smptests/smpatomic06/tasks.c (modified) * testsuites/smptests/smpatomic07/tasks.c (modified) * testsuites/smptests/smplock01/init.c (modified) smp: Add and use _CPU_SMP_Get_current_processor() Add and use ... Wed, 17 Jul 2013 06:42:35 GMT Ric Claus [39234725] * c/src/lib/libbsp/arm/shared/arm-cp15-set-ttb-entries.c (modified) * c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h (modified) bsps/arm: Fix for top of the address space Sat, 13 Jul 2013 20:58:27 GMT Ric Claus [691e0ef] * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq.inc (added) * c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_zc702.cfg (added) * c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_zc702_smp.cfg (added) * c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_zedboard.cfg (added) * c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_zedboard_smp.cfg (added) * c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq (added) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zc702 (added) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zc702_smp (added) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zedboard (added) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zedboard_smp (added) bsp/xilinx-zynq: Provide BSP variants Tue, 16 Jul 2013 12:40:19 GMT Sebastian Huber [51a58e0] * c/src/lib/libbsp/arm/xilinx-zynq/console/console-config.c (modified) bsp/xilinx-zynq: Use bsp_console_select() Tue, 16 Jul 2013 12:39:59 GMT Sebastian Huber [7306578] * c/src/lib/libbsp/shared/console_private.h (modified) * c/src/lib/libbsp/shared/console_select_simple.c (modified) * c/src/libchip/serial/serial.h (modified) bsps/serial: Move bsp_console_select() declaration Tue, 16 Jul 2013 15:18:18 GMT Sebastian Huber [3ccaf3c] * c/src/lib/libbsp/arm/shared/abort/abort.c (modified) * c/src/lib/libbsp/arm/shared/abort/simple_abort.c (modified) * c/src/lib/libbsp/shared/gdbstub/rtems-stub-glue.c (modified) bsps: Use rtems_task_self() Mon, 15 Jul 2013 12:39:28 GMT Vipul Nayyar [ad4ce28] * c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c (modified) * c/src/lib/libbsp/arm/edb7312/network/network.c (modified) Updated legacy code in arm edb7312 Mon, 15 Jul 2013 07:52:45 GMT Sebastian Huber [06adfae] * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstarthooks.c (modified) bsps/arm: Disable alignment exceptions Tue, 02 Jul 2013 08:37:13 GMT Sebastian Huber [c8d78ee] * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/clock/clock-config.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5668g.cfg (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5668g (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-clock.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-mmu-early.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-flash.S (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/emios.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/fsl-mpc5668.h (added) * c/src/lib/libcpu/powerpc/mpc55xx/include/irq.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/regs-edma.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/regs.h (modified) * c/src/lib/libcpu/powerpc/preinstall.am (modified) bsp/mpc55xx: Add MPC5668G support Mon, 15 Jul 2013 09:34:45 GMT Vipul Nayyar [583eb458] * c/src/lib/libbsp/arm/rtl22xx/network/network.c (modified) bsp/rtl22xx: Use IRQ extensions API Fri, 12 Jul 2013 17:03:57 GMT Vipul Nayyar [163e88a] * c/src/lib/libbsp/arm/gumstix/rtl8019/rtl8019.c (modified) bsp/gumstix: Fix warnings Fri, 12 Jul 2013 11:34:17 GMT Vipul Nayyar [9b6add4] * c/src/lib/libbsp/arm/gba/clock/clockdrv.c (modified) Updated Legacy code in arm gba Thu, 11 Jul 2013 08:06:35 GMT Sebastian Huber [5252822] * c/src/lib/libbsp/shared/include/generic-fatal.h (modified) bsps: Simplify bsp_generic_fatal() declaration Wed, 10 Jul 2013 17:38:12 GMT Joel Sherrill [79363a1] * c/src/lib/libbsp/shared/include/generic-fatal.h (modified) libbsp/shared/generic-fatal.h: Add RTEMS_COMPILER_NO_RETURN_ATTRIBUTE ... Wed, 10 Jul 2013 14:57:24 GMT Vipul Nayyar [e183211b] * c/src/lib/libbsp/arm/gumstix/rtl8019/rtl8019.c (modified) Updated Legacy code in arm gumstix Wed, 10 Jul 2013 14:52:28 GMT Vipul Nayyar [893d669] * c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c (modified) * c/src/lib/libbsp/arm/edb7312/network/network.c (modified) Updated Legacy code in arm edb7312 Wed, 10 Jul 2013 12:36:50 GMT Sebastian Huber [26c093e] * c/src/lib/libbsp/powerpc/virtex/console/consolelite.c (modified) bsp/virtex: Use #if instead of #ifdef This allows ... Wed, 10 Jul 2013 07:54:01 GMT Vipul Nayyar [52e44630] * c/src/lib/libbsp/arm/csb336/console/uart.c (modified) * c/src/lib/libbsp/arm/csb336/network/network.c (modified) bsp/csb336: Use IRQ extensions API Fix warnings. Tue, 09 Jul 2013 09:24:27 GMT Sebastian Huber [0a697dd9] * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex/console/consolelite.c (modified) bsp/virtex: Add VIRTEX_CONSOLE_USE_INTERRUPTS Add interrupt support ... Tue, 09 Jul 2013 14:38:03 GMT Sebastian Huber [d168079] * c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c (modified) bsp/virtex: Use ppc_count_leading_zeros() Use ... Tue, 09 Jul 2013 14:04:04 GMT Sebastian Huber [296b60d7] * c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c (modified) bsp/virtex: Fix interrupt handling Some modules like the XPS UART ... Tue, 09 Jul 2013 14:37:32 GMT Sebastian Huber [4fe3ad2] * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) bsps/powerpc: Add ppc_count_leading_zeros() Sun, 07 Jul 2013 13:00:45 GMT Vipul Nayyar [6886a485] * c/src/lib/libbsp/arm/csb337/network/network.c (modified) bsp/csb337: Use IRQ extensions API Fix warnings. Sun, 07 Jul 2013 12:43:17 GMT Sebastian Huber [ad83ea0] * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/console/console-config.c (modified) * c/src/lib/libbsp/shared/get-serial-mouse-ps2.c (added) * cpukit/libmisc/mouse/serial_mouse.h (modified) mouse: Add shared bsp_get_serial_mouse_device() Tue, 02 Jul 2013 13:16:33 GMT Sebastian Huber [818edbd] * c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-esci.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-linflex.c (modified) bsp/mpc55xx: Update due to API changes Termios notifies now the ... Tue, 02 Jul 2013 13:14:51 GMT Sebastian Huber [d91d50f] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/get-system-clock.c (modified) bsp/mpc55xx: Avoid integer overflow Tue, 02 Jul 2013 13:13:54 GMT Sebastian Huber [c97d3dd] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-clock.c (modified) bsp/mpc55xx: Round PLL divider up Mon, 24 Jun 2013 15:14:08 GMT Ralf Kirchner [cd7db89] * c/src/lib/libbsp/powerpc/psim/make/custom/psim.cfg (modified) bsp/psim: Use EABI and System V small-data area Mon, 24 Jun 2013 15:16:16 GMT Ralf Kirchner [3da02169] * c/src/lib/libbsp/powerpc/shared/startup/sbrk.c (modified) bsps/powerpc: Avoid placement in small-data area Mon, 24 Jun 2013 15:15:42 GMT Ralf Kirchner [1b47871d] * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) bsp/psim: Fix declaration It declares a symbol defined in the ... Fri, 28 Jun 2013 19:26:59 GMT Sebastian Huber [3b645c1] * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/console/console-config.c (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am (modified) * c/src/lib/libbsp/arm/shared/arm-pl050.c (added) * c/src/lib/libbsp/arm/shared/include/arm-pl050-regs.h (added) * c/src/lib/libbsp/arm/shared/include/arm-pl050.h (added) bsps/arm: Add PL050 support Sun, 23 Jun 2013 12:39:47 GMT Sebastian Huber [c8312b3] * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/include/bsp.h (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/fb-config.c (added) * c/src/lib/libbsp/arm/shared/arm-pl111-fb.c (added) * c/src/lib/libbsp/arm/shared/include/arm-pl111-fb.h (added) * c/src/lib/libbsp/arm/shared/include/arm-pl111-regs.h (added) bsps/arm: Add PL111 support Sun, 23 Jun 2013 15:50:55 GMT Sebastian Huber [311ba73] * c/src/lib/libbsp/arm/gumstix/fb/fb.c (modified) * c/src/lib/libbsp/arm/nds/fb/fb.c (modified) * c/src/lib/libbsp/i386/pc386/console/fb_cirrus.c (modified) * c/src/lib/libbsp/i386/pc386/console/fb_vga.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_framebuffer/framebuffer.c (modified) * cpukit/libcsupport/include/rtems/framebuffer.h (modified) framebuffer: Add and use FRAMEBUFFER_DEVICE_0_NAME Fri, 28 Jun 2013 13:05:30 GMT Sebastian Huber [40ce265] * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/psim/startup/psim_registers.c (deleted) bsp/psim: Use plain symbol for PSIM This avoids a linker assertion ... Fri, 28 Jun 2013 07:07:13 GMT Sebastian Huber [4800ffe] * c/src/lib/libbsp/powerpc/shared/startup/linkcmds.base (modified) bsps/powerpc: Update debug sections Fri, 28 Jun 2013 07:03:11 GMT Sebastian Huber [ca59217] * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h (modified) bsps/arm: Set vector base on all processors Wed, 26 Jun 2013 07:40:44 GMT Sebastian Huber [a3a4cd5] * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) bsps/arm: Move input sections Move input sections to preserve order ... Wed, 26 Jun 2013 08:25:42 GMT Sebastian Huber [56435e6] * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Fix Altivec support Use the right context. Fri, 21 Jun 2013 07:59:27 GMT Sebastian Huber [4b83e8f1] * c/src/lib/libbsp/arm/shared/arm-cp15-set-exception-handler.c (modified) bsps/arm: Fix set exception handler for ARMv7 Mon, 24 Jun 2013 15:29:11 GMT Sebastian Huber [e18db9f] * c/src/lib/libbsp/arm/csb336/console/uart.c (modified) * c/src/lib/libbsp/arm/shared/comm/uart.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_console/console.c (modified) * c/src/lib/libbsp/m68k/av5282/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68340/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68360/console/console.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf52235/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5235/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5329/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme167/console/console.c (modified) * c/src/lib/libbsp/m68k/uC5282/console/console.c (modified) * c/src/lib/libbsp/powerpc/gen5200/console/console.c (modified) * c/src/lib/libbsp/powerpc/qoriq/console/uart-bridge-slave.c (modified) * c/src/lib/libbsp/powerpc/shared/console/uart.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/console/console.c (modified) * c/src/lib/libbsp/sparc/erc32/console/erc32_console.c (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * c/src/lib/libcpu/bfin/serial/uart.c (modified) * c/src/lib/libcpu/m68k/mcf5206/console/mcfuart.c (modified) * c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/esci/esci.c (modified) * c/src/lib/libcpu/powerpc/mpc5xx/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console405.c (modified) * c/src/lib/libcpu/sh/sh7750/sci/sh4uart.c (modified) termios: Update due to API changes Termios notifies now the driver ... Mon, 24 Jun 2013 09:00:36 GMT Sebastian Huber [1df348b] * c/src/lib/libbsp/arm/lpc32xx/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstarthooks.c (modified) bsps/arm: Rename function Rename ... Fri, 21 Jun 2013 15:17:28 GMT Sebastian Huber [e916b125] * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) bsp/virtex: Use shared clock driver Thu, 20 Jun 2013 14:22:16 GMT Sebastian Huber [0110491] * c/src/lib/libbsp/powerpc/virtex/console/consolelite.c (modified) bsp/virtex: Add console devices only if present Thu, 20 Jun 2013 14:20:43 GMT Sebastian Huber [dbf62b3] * c/src/lib/libbsp/powerpc/virtex/console/consolelite.c (modified) bsp/virtex: Fix warnings Thu, 20 Jun 2013 12:33:19 GMT Sebastian Huber [c4cfc62] * c/src/lib/libbsp/powerpc/virtex/include/opbintctrl.h (modified) bsp/virtex: Use XPAR_INTC_SINGLE_BASEADDR This define is also ... Thu, 20 Jun 2013 12:32:12 GMT Sebastian Huber [dfb5805] * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) bsp/virtex: Remove unused configure macros Tue, 18 Jun 2013 14:42:25 GMT Sebastian Huber [53dc697] * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) bsp/virtex: Delete BSP_ask_for_reset and BSP_panic Tue, 18 Jun 2013 15:20:28 GMT Sebastian Huber [39c1534f] * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex/include/opbintctrl.h (modified) * c/src/lib/libbsp/powerpc/virtex/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/virtex/opbintctrl/opbintctrl.c (deleted) * c/src/lib/libbsp/powerpc/virtex/preinstall.am (modified) * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) bsp/virtex: Use generic interrupt support Tue, 18 Jun 2013 14:44:40 GMT Sebastian Huber [894e93f] * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) bsp/virtex: Fix header includes Tue, 18 Jun 2013 14:39:24 GMT Sebastian Huber [bee7612e] * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/virtex/timer/timer-config.c (added) bsp/virtex: Move timer config to new file Tue, 18 Jun 2013 14:27:42 GMT Sebastian Huber [48ab8465] * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) bsp/virtex: Do not use PPC403 TTY driver Tue, 18 Jun 2013 14:26:25 GMT Sebastian Huber [ad094f4] * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) bsp/virtex: Fix warnings Tue, 18 Jun 2013 14:25:53 GMT Sebastian Huber [b45397fb] * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) bsp/virtex: Delete bsp_XAssertHandler()
