# # ChangeLog for c/src/lib in rtems # # Generated by Trac 1.2.1.dev0 # 04/16/24 18:53:10 Fri, 26 Apr 2013 13:06:32 GMT Sebastian Huber [a91dc98b] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (added) * c/src/lib/libbsp/arm/realview-pbx-a9/README (added) * c/src/lib/libbsp/arm/realview-pbx-a9/bsp_specs (added) * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (added) * c/src/lib/libbsp/arm/realview-pbx-a9/console/console-config.c (added) * c/src/lib/libbsp/arm/realview-pbx-a9/include/bsp.h (added) * c/src/lib/libbsp/arm/realview-pbx-a9/include/irq.h (added) * c/src/lib/libbsp/arm/realview-pbx-a9/include/tm27.h (added) * c/src/lib/libbsp/arm/realview-pbx-a9/make/custom/realview_pbx_a9_qemu.cfg (added) * c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am (added) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspreset.c (added) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstart.c (added) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds (added) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c (added) * c/src/lib/libbsp/arm/shared/arm-gic-irq.c (added) * c/src/lib/libbsp/arm/shared/arm-pl011.c (added) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-irq.h (added) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h (added) * c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h (added) * c/src/lib/libbsp/arm/shared/include/arm-gic-regs.h (added) * c/src/lib/libbsp/arm/shared/include/arm-gic.h (added) * c/src/lib/libbsp/arm/shared/include/arm-pl011-regs.h (added) * c/src/lib/libbsp/arm/shared/include/arm-pl011.h (added) bsp/realview-pbx-a9: New BSP Thu, 02 May 2013 11:37:30 GMT Sebastian Huber [9ce65803] * c/src/lib/libbsp/arm/shared/start/start.S (modified) bsps/arm: Copy vector table only if necessary Thu, 02 May 2013 11:36:03 GMT Sebastian Huber [27690ec3] * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) bsps/arm: Move .vector section The .vector section contains ... Thu, 02 May 2013 09:41:22 GMT Sebastian Huber [ecf7dd9] * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h (added) bsps/arm: Move CP15 start initialization Thu, 02 May 2013 09:09:24 GMT Sebastian Huber [fd51f7e] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Support ARMv7 VMSA sections and control Tue, 30 Apr 2013 13:23:45 GMT Sebastian Huber [88cf23f8] * c/src/lib/libbsp/arm/shared/arm-cp15-set-exception-handler.c (added) * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Add arm_cp15_set_exception_handler() Thu, 02 May 2013 15:42:20 GMT Sebastian Huber [037e8ae5] * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/include/mmu.h (modified) * c/src/lib/libbsp/arm/shared/arm-cp15-set-ttb-entries.c (moved) * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Add arm_cp15_set_trans*_table_entries() Thu, 02 May 2013 15:41:11 GMT Sebastian Huber [544615d] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Add arm_cp15_mmu_disable() Thu, 02 May 2013 15:40:45 GMT Sebastian Huber [d2d02961] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Add arm_cp15_get_min_cache_line_size() Thu, 02 May 2013 09:18:09 GMT Sebastian Huber [962e0fac] * c/src/lib/libbsp/arm/lpc32xx/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx (modified) * c/src/lib/libbsp/arm/shared/include/linker-symbols.h (modified) bsps/arm: Add and use bsp_translation_table_base Fri, 03 May 2013 08:39:26 GMT Sebastian Huber [fb0584f] * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/bspstarthook.c (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/shared/include/start.h (modified) * c/src/lib/libbsp/arm/shared/startup/bsp-start-copy-sections.c (deleted) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/startup/bspstarthook.c (modified) bsps/arm: Move implementation to inline functions Tue, 30 Apr 2013 17:31:29 GMT Joel Sherrill [5aa4ed9] * c/src/lib/libbsp/i386/pc386/make/custom/pc386dx.cfg (deleted) * c/src/lib/libbsp/i386/pc386/make/custom/pc586-sse.cfg (modified) * c/src/lib/libbsp/i386/pc386/make/custom/pcp4.cfg (modified) i386: PR2010: Remove pc386 BSPs using soft-float i386 soft-float is ... Mon, 29 Apr 2013 07:28:58 GMT Sebastian Huber [024a572] * c/src/lib/libcpu/powerpc/mpc55xx/include/siu.h (modified) bsp/mpc55xx: Avoid empty enum Fri, 26 Apr 2013 09:03:59 GMT Eugeniy Meshcheryakov [f22bba3] * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/configure.ac (modified) * c/src/lib/libbsp/arm/lm3s69xx/console/console-config.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/console/uart.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lm3s69xx/include/io.h (added) * c/src/lib/libbsp/arm/lm3s69xx/include/irq.h (modified) * c/src/lib/libbsp/arm/lm3s69xx/include/lm3s69xx.h (modified) * c/src/lib/libbsp/arm/lm3s69xx/include/ssi.h (added) * c/src/lib/libbsp/arm/lm3s69xx/include/syscon.h (added) * c/src/lib/libbsp/arm/lm3s69xx/include/uart.h (modified) * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s3749.cfg (added) * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s6965_qemu.cfg (added) * c/src/lib/libbsp/arm/lm3s69xx/preinstall.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/ssi/ssi.c (added) * c/src/lib/libbsp/arm/lm3s69xx/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/io.c (added) * c/src/lib/libbsp/arm/lm3s69xx/startup/linkcmds.lm3s3749 (added) * c/src/lib/libbsp/arm/lm3s69xx/startup/linkcmds.lm3s6965 (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/linkcmds.lm3s6965_qemu (added) * c/src/lib/libbsp/arm/lm3s69xx/startup/syscon.c (added) bsp/lm3s69xx: New BSP variants Add support for LM3S3749. Wed, 24 Apr 2013 12:37:50 GMT Sebastian Huber [5fa0e5c5] * c/src/lib/libbsp/shared/bsppost.c (modified) * cpukit/libcsupport/include/rtems/libcsupport.h (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/open_dev_console.c (modified) * cpukit/sapi/include/confdefs.h (modified) libcsupport: Rename open_dev_console() Rename open_dev_console() to ... Wed, 24 Apr 2013 12:30:42 GMT Sebastian Huber [a290fbe9] * c/src/lib/libbsp/shared/bsplibc.c (modified) * c/src/lib/libbsp/shared/bsppost.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/libio_helper_null.c (added) * cpukit/libcsupport/src/libio_init.c (modified) * cpukit/sapi/include/confdefs.h (modified) libcsupport: Make LibIO helper const Add and use rtems_libio_helper ... Thu, 25 Apr 2013 13:21:35 GMT Sebastian Huber [62aa318] * c/src/lib/libcpu/powerpc/mpc55xx/include/regs-mmu.h (modified) bsp/mpc55xx: Add MMU tag translate initializer Fri, 19 Apr 2013 09:53:07 GMT Sebastian Huber [92d8038] * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen5200/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen5200/make/custom/brs6l.cfg (added) * c/src/lib/libbsp/powerpc/gen5200/start/start.S (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/cpuinit.c (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/linkcmds.brs6l (added) bsp/mpc5200: New BSP variant BRS6L Fri, 19 Apr 2013 12:17:09 GMT Sebastian Huber [7a44d06] * c/src/lib/libbsp/powerpc/gen5200/start/start.S (modified) bsp/mpc5200: Change SDRAM initialization Change SDRAM ... Fri, 19 Apr 2013 12:01:47 GMT Sebastian Huber [d4a4811] * c/src/lib/libbsp/powerpc/gen5200/start/start.S (modified) bsp/mpc5200: Set SDELAY register Fri, 19 Apr 2013 11:51:54 GMT Sebastian Huber [dbe6aae7] * c/src/lib/libbsp/powerpc/gen5200/start/start.S (modified) bsp/mpc5200: Move CSBOOTROM_VAL definition Fri, 19 Apr 2013 11:50:34 GMT Sebastian Huber [e79e904] * c/src/lib/libbsp/powerpc/gen5200/start/start.S (modified) bsp/mpc5200: Move comment Fri, 19 Apr 2013 11:48:48 GMT Sebastian Huber [6c094da] * c/src/lib/libbsp/powerpc/gen5200/start/start.S (modified) bsp/mpc5200: Change ADREN register defines Fri, 19 Apr 2013 11:00:14 GMT Sebastian Huber [2793778] * c/src/lib/libbsp/powerpc/gen5200/start/start.S (modified) bsp/mpc5200: Remove Erratum 342/339 comment Fri, 19 Apr 2013 10:51:57 GMT Sebastian Huber [be04e62] * c/src/lib/libbsp/powerpc/gen5200/start/start.S (modified) bsp/mpc5200: Set XLB timeout values Fri, 19 Apr 2013 10:50:10 GMT Sebastian Huber [5e920ceb] * c/src/lib/libbsp/powerpc/gen5200/start/start.S (modified) bsp/mpc5200: Do not initialize debug registers Wed, 17 Apr 2013 13:57:20 GMT Sebastian Huber [740abbd] * c/src/lib/libbsp/powerpc/gen5200/startup/cpuinit.c (modified) bsp/mpc5200: Add and use enable_bat_4_to_7() Wed, 17 Apr 2013 14:03:03 GMT Sebastian Huber [d5587f9f] * c/src/lib/libbsp/powerpc/gen5200/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/cpuinit.c (modified) bsp/mpc5200: Fix cache handling Thu, 11 Apr 2013 15:22:02 GMT Sebastian Huber [47fb2fe] * c/src/lib/libbsp/powerpc/gen5200/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen5200/ide/ata.c (modified) * c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.c (modified) * c/src/lib/libbsp/powerpc/gen5200/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen5200/start/start.S (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/cpuinit.c (modified) bsp/mpc5200: Add MPC5200_BOARD prefix Wed, 17 Apr 2013 12:54:05 GMT Peng Fan [76de8a8e] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) D-cache clean&&invalidate for Tiny6410 Wed, 17 Apr 2013 13:45:52 GMT Sebastian Huber [ef8e851] * c/src/lib/libcpu/powerpc/mpc55xx/include/edma.h (modified) bsp/mpc55xx: Typo Wed, 03 Apr 2013 10:05:49 GMT Sebastian Huber [db21e1d] * c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/dspi/dspi.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/edma/edma.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/dspi.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/edma.h (modified) bsp/mpc55xx: eDMA API changes Fri, 05 Apr 2013 13:57:19 GMT Sebastian Huber [4e3deaf7] * c/src/lib/libcpu/powerpc/mpc55xx/include/regs-edma.h (modified) bsp/mpc55xx: Add alternative register layout Mon, 08 Apr 2013 08:43:42 GMT Sebastian Huber [db0ed4c5] * c/src/lib/libbsp/powerpc/mpc55xxevb/include/mpc55xx-config.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/siu.h (modified) bsp/mpc55xx: Add PCR index enumeration Fri, 05 Apr 2013 14:05:30 GMT Sebastian Huber [7806a2b5] * c/src/lib/libbsp/powerpc/mpc55xxevb/include/bsp.h (modified) bsp/mpc55xx: New define MPC55XX_PERIPHERAL_CLOCK Fri, 05 Apr 2013 14:05:03 GMT Sebastian Huber [15c7657] * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-clock.c (modified) bsp/mpc55xx: Rename BSP option Wed, 03 Apr 2013 10:10:25 GMT Sebastian Huber [30158371] * c/src/lib/libbsp/powerpc/mpc55xxevb/include/bsp.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/edma/edma.c (modified) bsp/mpc55xx: New fatal errors Mon, 08 Apr 2013 13:21:37 GMT Sebastian Huber [055f1f4c] * c/src/lib/libbsp/powerpc/mpc55xxevb/include/bsp.h (modified) bsp/mpc55xx: Include Mon, 08 Apr 2013 14:13:18 GMT Sebastian Huber [087a29b4] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/restart.c (modified) bsp/mpc55xx: Fix warnings Mon, 08 Apr 2013 14:13:02 GMT Sebastian Huber [ab49921] * c/src/lib/libbsp/shared/bootcard.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) bsps: Fix warnings Mon, 08 Apr 2013 14:11:02 GMT Sebastian Huber [602d5ba] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/irq.c (modified) * cpukit/include/rtems/irq.h (modified) bsps: Fix warnings Mon, 08 Apr 2013 07:45:45 GMT Sebastian Huber [5ab9b13] * c/src/lib/libbsp/powerpc/gen83xx/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/tm27.h (modified) bsps/powerpc: Use proper type Mon, 08 Apr 2013 07:45:09 GMT Sebastian Huber [166d78f] * c/src/lib/libbsp/powerpc/gen5200/ide/ata.c (modified) bsp/gen5200: Fix syntax Wed, 03 Apr 2013 04:24:32 GMT Sebastian Huber [39586f6] * c/src/lib/libbsp/arm/lpc24xx/include/lpc24xx.h (modified) bsp/lpc24xx: Fix register address Tue, 02 Apr 2013 14:01:05 GMT Sebastian Huber [dea6fb6] * c/src/lib/libbsp/powerpc/gen5200/configure.ac (modified) bsp/gen5200: Typo Tue, 02 Apr 2013 13:58:40 GMT Sebastian Huber [0841c07] * c/src/lib/libbsp/powerpc/gen5200/configure.ac (modified) bsp/gen5200: Elaborate option help message Tue, 02 Apr 2013 13:50:23 GMT Sebastian Huber [fa77ad4b] * c/src/lib/libbsp/powerpc/gen5200/configure.ac (modified) bsp/gen5200: Remove superfluous option definition Thu, 28 Mar 2013 08:25:07 GMT Sebastian Huber [aa11df6] * c/src/lib/libbsp/powerpc/gen5200/ide/ata.c (modified) * c/src/lib/libbsp/powerpc/gen5200/include/ata.h (modified) bsp/gen5200: Use busy wait The usage of rtems_task_wake_after() is ... Thu, 28 Mar 2013 08:24:11 GMT Sebastian Huber [d1e1df68] * c/src/lib/libbsp/powerpc/gen5200/ide/ata.c (modified) * c/src/lib/libbsp/powerpc/gen5200/include/bsp.h (modified) bsp/gen5200: Use fatal error instead of assert Tue, 26 Mar 2013 15:01:10 GMT Sebastian Huber [8ac62c4] * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) bsps/arm: Add thread-local storage (TLS) sections Sat, 23 Mar 2013 18:13:07 GMT Alan Cudmore [c32b1ef] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (added) * c/src/lib/libbsp/arm/raspberrypi/README (added) * c/src/lib/libbsp/arm/raspberrypi/bsp_specs (added) * c/src/lib/libbsp/arm/raspberrypi/clock/clockdrv.c (added) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (added) * c/src/lib/libbsp/arm/raspberrypi/console/console-config.c (added) * c/src/lib/libbsp/arm/raspberrypi/console/usart.c (added) * c/src/lib/libbsp/arm/raspberrypi/include/bsp.h (added) * c/src/lib/libbsp/arm/raspberrypi/include/irq.h (added) * c/src/lib/libbsp/arm/raspberrypi/include/mmu.h (added) * c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h (added) * c/src/lib/libbsp/arm/raspberrypi/include/usart.h (added) * c/src/lib/libbsp/arm/raspberrypi/irq/irq.c (added) * c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.cfg (added) * c/src/lib/libbsp/arm/raspberrypi/misc/timer.c (added) * c/src/lib/libbsp/arm/raspberrypi/preinstall.am (added) * c/src/lib/libbsp/arm/raspberrypi/startup/bspreset.c (added) * c/src/lib/libbsp/arm/raspberrypi/startup/bspstart.c (added) * c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds (added) bsp/raspberrypi: New BSP Thu, 21 Mar 2013 09:46:03 GMT Sebastian Huber [7b14e8b] * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) bsp/mpc83xx: Add MPC83XX_NET*_INTERFACE_0_PHY_ADDR Tue, 19 Mar 2013 09:12:06 GMT Sebastian Huber [6457fb29] * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/preinstall.am (modified) * c/src/lib/libbsp/powerpc/psim/start/start.S (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (modified) bsp/psim: Use shared linkcmds.base Several GCC tests faild due to ... Mon, 18 Mar 2013 14:24:00 GMT Sebastian Huber [df6818f9] * c/src/lib/libbsp/arm/gba/startup/linkcmds (modified) * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/i386/pc386/startup/linkcmds (modified) * c/src/lib/libbsp/m32r/m32rsim/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/linkcmds.base (modified) * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/linkcmds.base (modified) bsps: Support DWARF extension Thu, 14 Mar 2013 10:54:31 GMT Sebastian Huber [c2015b44] * c/src/lib/libbsp/arm/edb7312/console/uart.c (modified) bsp/edb7312: Improve output char The output char function used by ... Thu, 14 Mar 2013 10:45:44 GMT Sebastian Huber [df3f0226] * c/src/lib/libbsp/arm/edb7312/console/uart.c (modified) bsp/edb7312: Fix warnings Mon, 11 Mar 2013 16:54:34 GMT Sebastian Huber [faad192] * c/src/lib/libbsp/powerpc/gen83xx/startup/bspreset.c (modified) * c/src/lib/libcpu/powerpc/mpc83xx/include/mpc83xx.h (modified) mpc83xx: Add and use mpc83xx_reset() The inline version makes it ... Mon, 11 Mar 2013 16:50:27 GMT Sebastian Huber [f88da30] * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen83xx/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/start/start.S (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/linkcmds.base (deleted) * c/src/lib/libbsp/powerpc/gen83xx/startup/linkcmds.br_uid (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/linkcmds.hsc_cm01 (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/linkcmds.mpc8309som (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/linkcmds.mpc8313erdb (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/linkcmds.mpc8349eamds (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/linkcmds.mpc83xx (added) * c/src/lib/libbsp/powerpc/gen83xx/startup/mpc83xx_regs.c (deleted) mpc83xx: Use shared linkcmds.base Mon, 11 Mar 2013 16:44:51 GMT Sebastian Huber [b34401cc] * c/src/lib/libbsp/powerpc/gen83xx/start/start.S (modified) mpc83xx: Copy nothing if necessary Mon, 11 Mar 2013 16:44:19 GMT Sebastian Huber [9e25621] * c/src/lib/libbsp/powerpc/gen83xx/start/start.S (modified) mpc83xx: Fix local access window 1 configuration Mon, 11 Mar 2013 16:43:08 GMT Sebastian Huber [907b07d9] * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/hwreg_vals.h (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/cpuinit.c (modified) mpc83xx: Add MPC83XX_HAS_NAND_LP_FLASH_ON_CS0 Mon, 11 Mar 2013 19:28:06 GMT Joel Sherrill [dbc983c] * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) mvme3100/Makefile.am: Remove reference to ChangeLog Mon, 11 Mar 2013 19:27:50 GMT Joel Sherrill [b1f105e1] * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) beatnik/Makefile.am: Remove reference to ChangeLog Fri, 08 Mar 2013 20:55:06 GMT Gedare Bloom [fad2d38] * ChangeLog (deleted) * c/ChangeLog (deleted) * c/src/ChangeLog (deleted) * c/src/ada-tests/ChangeLog (deleted) * c/src/ada/ChangeLog (deleted) * c/src/lib/libbsp/ChangeLog (deleted) * c/src/lib/libbsp/arm/ChangeLog (deleted) * c/src/lib/libbsp/arm/csb336/ChangeLog (deleted) * c/src/lib/libbsp/arm/csb337/ChangeLog (deleted) * c/src/lib/libbsp/arm/edb7312/ChangeLog (deleted) * c/src/lib/libbsp/arm/gba/ChangeLog (deleted) * c/src/lib/libbsp/arm/gdbarmsim/ChangeLog (deleted) * c/src/lib/libbsp/arm/gp32/ChangeLog (deleted) * c/src/lib/libbsp/arm/gumstix/ChangeLog (deleted) * c/src/lib/libbsp/arm/lm3s69xx/ChangeLog (deleted) * c/src/lib/libbsp/arm/lpc24xx/ChangeLog (deleted) * c/src/lib/libbsp/arm/lpc32xx/ChangeLog (deleted) * c/src/lib/libbsp/arm/nds/ChangeLog (deleted) * c/src/lib/libbsp/arm/nds/tools/ChangeLog (deleted) * c/src/lib/libbsp/arm/rtl22xx/ChangeLog (deleted) * c/src/lib/libbsp/arm/smdk2410/ChangeLog (deleted) * c/src/lib/libbsp/avr/ChangeLog (deleted) * c/src/lib/libbsp/avr/avrtest/ChangeLog (deleted) * c/src/lib/libbsp/bfin/ChangeLog (deleted) * c/src/lib/libbsp/bfin/TLL6527M/ChangeLog (deleted) * c/src/lib/libbsp/bfin/bf537Stamp/ChangeLog (deleted) * c/src/lib/libbsp/bfin/eZKit533/ChangeLog (deleted) * c/src/lib/libbsp/h8300/ChangeLog (deleted) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (deleted) * c/src/lib/libbsp/i386/ChangeLog (deleted) * c/src/lib/libbsp/i386/pc386/ChangeLog (deleted) * c/src/lib/libbsp/i386/pc386/tools/ChangeLog (deleted) * c/src/lib/libbsp/lm32/ChangeLog (deleted) * c/src/lib/libbsp/lm32/lm32_evr/ChangeLog (deleted) * c/src/lib/libbsp/lm32/milkymist/ChangeLog (deleted) * c/src/lib/libbsp/lm32/shared/ChangeLog (deleted) * c/src/lib/libbsp/m32c/ChangeLog (deleted) * c/src/lib/libbsp/m32c/m32cbsp/ChangeLog (deleted) * c/src/lib/libbsp/m32r/ChangeLog (deleted) * c/src/lib/libbsp/m32r/m32rsim/ChangeLog (deleted) * c/src/lib/libbsp/m68k/ChangeLog (deleted) * c/src/lib/libbsp/m68k/av5282/ChangeLog (deleted) * c/src/lib/libbsp/m68k/csb360/ChangeLog (deleted) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (deleted) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (deleted) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (deleted) * c/src/lib/libbsp/m68k/genmcf548x/ChangeLog (deleted) * c/src/lib/libbsp/m68k/idp/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mcf5206elite/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mcf5206elite/tools/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mcf52235/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mcf5225x/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mcf5235/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mcf5329/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mvme162/tools/ChangeLog (deleted) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (deleted) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (deleted) * c/src/lib/libbsp/m68k/shared/gdbstub/ChangeLog (deleted) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (deleted) * c/src/lib/libbsp/m68k/uC5282/ChangeLog (deleted) * c/src/lib/libbsp/mips/ChangeLog (deleted) * c/src/lib/libbsp/mips/csb350/ChangeLog (deleted) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (deleted) * c/src/lib/libbsp/mips/hurricane/ChangeLog (deleted) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (deleted) * c/src/lib/libbsp/mips/jmr3904/tools/ChangeLog (deleted) * c/src/lib/libbsp/mips/malta/ChangeLog (deleted) * c/src/lib/libbsp/mips/rbtx4925/ChangeLog (deleted) * c/src/lib/libbsp/mips/rbtx4938/ChangeLog (deleted) * c/src/lib/libbsp/mips/shared/gdbstub/ChangeLog (deleted) * c/src/lib/libbsp/nios2/ChangeLog (deleted) * c/src/lib/libbsp/nios2/nios2_iss/ChangeLog (deleted) * c/src/lib/libbsp/no_cpu/ChangeLog (deleted) * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/beatnik/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/ep1a/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/gen83xx/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/haleakala/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/mpc55xxevb/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/mvme3100/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/psim/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/qemuppc/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/qoriq/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/ss555/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/tqm8xx/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/virtex/ChangeLog (deleted) * c/src/lib/libbsp/sh/ChangeLog (deleted) * c/src/lib/libbsp/sh/gensh1/ChangeLog (deleted) * c/src/lib/libbsp/sh/gensh2/ChangeLog (deleted) * c/src/lib/libbsp/sh/gensh4/ChangeLog (deleted) * c/src/lib/libbsp/sh/shsim/ChangeLog (deleted) * c/src/lib/libbsp/shared/ChangeLog (deleted) * c/src/lib/libbsp/sparc/ChangeLog (deleted) * c/src/lib/libbsp/sparc/erc32/ChangeLog (deleted) * c/src/lib/libbsp/sparc/leon2/ChangeLog (deleted) * c/src/lib/libbsp/sparc/leon3/ChangeLog (deleted) * c/src/lib/libbsp/sparc64/ChangeLog (deleted) * c/src/lib/libbsp/sparc64/niagara/ChangeLog (deleted) * c/src/lib/libbsp/sparc64/usiii/ChangeLog (deleted) * c/src/lib/libcpu/ChangeLog (deleted) * c/src/lib/libcpu/arm/ChangeLog (deleted) * c/src/lib/libcpu/bfin/ChangeLog (deleted) * c/src/lib/libcpu/i386/ChangeLog (deleted) * c/src/lib/libcpu/lm32/ChangeLog (deleted) * c/src/lib/libcpu/m68k/ChangeLog (deleted) * c/src/lib/libcpu/mips/ChangeLog (deleted) * c/src/lib/libcpu/nios2/ChangeLog (deleted) * c/src/lib/libcpu/powerpc/ChangeLog (deleted) * c/src/lib/libcpu/sh/ChangeLog (deleted) * c/src/lib/libcpu/sparc/ChangeLog (deleted) * c/src/lib/libcpu/sparc64/ChangeLog (deleted) * c/src/librtems++/ChangeLog (deleted) * c/src/make/ChangeLog (deleted) * contrib/mingw/ChangeLog (deleted) * contrib/rtemsrpms/ChangeLog (deleted) * cpukit/ChangeLog (deleted) * cpukit/ChangeLog-pre2007 (deleted) * cpukit/score/cpu/arm/ChangeLog (deleted) * cpukit/score/cpu/avr/ChangeLog (deleted) * cpukit/score/cpu/bfin/ChangeLog (deleted) * cpukit/score/cpu/h8300/ChangeLog (deleted) * cpukit/score/cpu/i386/ChangeLog (deleted) * cpukit/score/cpu/lm32/ChangeLog (deleted) * cpukit/score/cpu/m32c/ChangeLog (deleted) * cpukit/score/cpu/m32r/ChangeLog (deleted) * cpukit/score/cpu/m68k/ChangeLog (deleted) * cpukit/score/cpu/mips/ChangeLog (deleted) * cpukit/score/cpu/nios2/ChangeLog (deleted) * cpukit/score/cpu/no_cpu/ChangeLog (deleted) * cpukit/score/cpu/powerpc/ChangeLog (deleted) * cpukit/score/cpu/sh/ChangeLog (deleted) * cpukit/score/cpu/sparc/ChangeLog (deleted) * cpukit/score/cpu/sparc64/ChangeLog (deleted) * cpukit/zlib/ChangeLog (deleted) * doc/ChangeLog (deleted) * doc/new_chapters/ChangeLog (deleted) * doc/relnotes/ChangeLog (deleted) * doc/tools/ChangeLog (deleted) * doc/tools/bmenu/ChangeLog (deleted) * make/ChangeLog (deleted) * testsuites/ChangeLog (deleted) * testsuites/fstests/ChangeLog (deleted) * testsuites/libtests/ChangeLog (deleted) * testsuites/mptests/ChangeLog (deleted) * testsuites/psxtests/ChangeLog (deleted) * testsuites/psxtmtests/ChangeLog (deleted) * testsuites/samples/ChangeLog (deleted) * testsuites/smptests/ChangeLog (deleted) * testsuites/sptests/ChangeLog (deleted) * testsuites/tmtests/ChangeLog (deleted) * testsuites/tools/ChangeLog (deleted) * testsuites/tools/generic/ChangeLog (deleted) * tools/build/ChangeLog (deleted) * tools/cpu/ChangeLog (deleted) * tools/cpu/generic/ChangeLog (deleted) * tools/cpu/nios2/ChangeLog (deleted) * tools/cpu/sh/ChangeLog (deleted) RTEMS: Delete ChangeLog files. This commit deletes all RTEMS ... Wed, 27 Feb 2013 18:13:20 GMT Anthony Green [032e5e4] * c/src/lib/libbsp/moxie/Makefile.am (added) * c/src/lib/libbsp/moxie/acinclude.m4 (added) * c/src/lib/libbsp/moxie/configure.ac (added) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (added) * c/src/lib/libbsp/moxie/moxiesim/bsp_specs (added) * c/src/lib/libbsp/moxie/moxiesim/configure.ac (added) * c/src/lib/libbsp/moxie/moxiesim/console/console-io.c (added) * c/src/lib/libbsp/moxie/moxiesim/console/syscalls.S (added) * c/src/lib/libbsp/moxie/moxiesim/include/bsp.h (added) * c/src/lib/libbsp/moxie/moxiesim/make/custom/moxiesim.cfg (added) * c/src/lib/libbsp/moxie/moxiesim/preinstall.am (added) * c/src/lib/libbsp/moxie/moxiesim/start/start.S (added) * c/src/lib/libbsp/moxie/moxiesim/startup/__main.c (added) * c/src/lib/libbsp/moxie/moxiesim/startup/linkcmds (added) * c/src/lib/libbsp/moxie/moxiesim/startup/moxiebdinstallirq.c (added) Add sample Moxie BSP for GDB sim Signed-off-by: Anthony Green ... Tue, 26 Feb 2013 18:31:23 GMT Jennifer Averett [e517714b] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) sparc: Remove dead code that was leftover from SMP development. Mon, 25 Feb 2013 16:33:17 GMT Sebastian Huber [ef921556] * c/src/lib/libcpu/powerpc/mpc55xx/include/fsl-mpc564xL.h (modified) bsp/mpc55xx: Add register type definition Mon, 18 Feb 2013 16:00:28 GMT Sebastian Huber [57bcb88e] * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/ide/ata-dma-pio-single.c (added) * c/src/lib/libbsp/powerpc/gen5200/ide/ata-instance.c (added) * c/src/lib/libbsp/powerpc/gen5200/ide/ata.c (added) * c/src/lib/libbsp/powerpc/gen5200/include/ata.h (added) * c/src/lib/libbsp/powerpc/gen5200/include/bestcomm.h (added) * c/src/lib/libbsp/powerpc/gen5200/include/bestcomm_ops.h (added) * c/src/lib/libbsp/powerpc/gen5200/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen5200/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/bestcomm.c (added) bsp/gen5200: New ATA driver This is a replacement for the ATA task. ... Mon, 18 Feb 2013 15:29:32 GMT Sebastian Huber [c7a5656] * c/src/lib/libbsp/powerpc/gen5200/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/gen5200/mscan/mscan.c (modified) * c/src/lib/libbsp/powerpc/gen5200/slicetimer/slicetimer.c (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen5200/tod/pcf8563.c (modified) bsp/gen5200: Add and use mpc5200_fatal() Mon, 18 Feb 2013 15:27:50 GMT Sebastian Huber [ced11eb1] * c/src/lib/libbsp/powerpc/mpc55xxevb/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) bsp/mpc55xx: Fix prototype Tue, 12 Feb 2013 10:24:40 GMT Sebastian Huber [7b859d59] * c/src/lib/libbsp/powerpc/haleakala/bsp_specs.dl (deleted) * c/src/lib/libbsp/powerpc/virtex/bsp_specs.dl (deleted) bsps/powerpc: Remove unused files Tue, 12 Feb 2013 08:27:01 GMT Sebastian Huber [77ac5785] * c/src/lib/libbsp/arm/lpc32xx/configure.ac (modified) bsp/lpc32xx: Add BSP_USB_OTG_TRANSCEIVER_VBUS Mon, 11 Feb 2013 19:18:26 GMT Gedare Bloom [0241ab0] * c/src/lib/libbsp/sparc64/shared/startup/linkcmds (modified) sparc64: revert linkcmds to 4 MB ram size Fri, 08 Feb 2013 13:23:22 GMT Sebastian Huber [6a22637] * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc24xx/console/uart-probe-1.c (added) * c/src/lib/libbsp/arm/lpc24xx/console/uart-probe-2.c (added) * c/src/lib/libbsp/arm/lpc24xx/console/uart-probe-3.c (added) * c/src/lib/libbsp/arm/lpc24xx/include/bsp.h (modified) bsp/lpc24xx: Move UART probes to separate files Fri, 08 Feb 2013 12:39:59 GMT Sebastian Huber [c8bd3cd] * c/src/lib/libbsp/arm/csb337/console/fbcons.c (modified) * c/src/lib/libbsp/arm/csb337/console/uarts.c (modified) * c/src/lib/libbsp/arm/edb7312/console/uart.c (modified) * c/src/lib/libbsp/arm/gp32/console/uart.c (modified) * c/src/lib/libbsp/arm/gumstix/console/uarts.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/console/uart.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/include/uart.h (modified) * c/src/lib/libbsp/arm/lpc32xx/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc32xx/console/hsu.c (modified) * c/src/lib/libbsp/arm/rtl22xx/console/uart.c (modified) * c/src/lib/libbsp/arm/stm32f4/console/usart.c (modified) * c/src/lib/libbsp/arm/stm32f4/include/usart.h (modified) * c/src/lib/libbsp/i386/pc386/console/vgacons.c (modified) * c/src/lib/libbsp/i386/pc386/console/vgacons.h (modified) * c/src/lib/libbsp/powerpc/ep1a/console/config.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/mc68360_scc.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/ns16550cfg.h (modified) * c/src/lib/libbsp/powerpc/qoriq/console/uart-bridge-master.c (modified) * c/src/lib/libbsp/powerpc/qoriq/console/uart-bridge-slave.c (modified) * c/src/lib/libbsp/powerpc/qoriq/include/uart-bridge.h (modified) * c/src/lib/libbsp/powerpc/t32mppc/console/console-config.c (modified) * c/src/lib/libbsp/powerpc/virtex/console/consolelite.c (modified) * c/src/lib/libbsp/sh/gensh2/console/config.c (modified) * c/src/lib/libbsp/shared/umon/umoncons.c (modified) * c/src/lib/libbsp/sparc/erc32/console/erc32_console.c (modified) * c/src/lib/libbsp/sparc64/shared/console/conscfg.c (modified) * c/src/lib/libcpu/arm/at91rm9200/dbgu/dbgu.c (modified) * c/src/lib/libcpu/arm/at91rm9200/usart/usart.c (modified) * c/src/lib/libcpu/arm/pxa255/ffuart/ffuart.c (modified) * c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.c (modified) * c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.h (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550.h (modified) * c/src/libchip/serial/serial.h (modified) * c/src/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/z85c30.h (modified) libchip/serial: Add const qualifier Fri, 08 Feb 2013 10:58:20 GMT Sebastian Huber [5de9e8d] * c/src/lib/libbsp/sparc/erc32/console/erc32_console.c (modified) bsp/erc32: Fix warnings Wed, 06 Feb 2013 10:38:29 GMT Sebastian Huber [4b53f191] * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/mpc55xx-config.h (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-prologue.c (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start.S (modified) bsp/mpc55xx: Add MPC55XX_ENABLE_START_PROLOGUE Wed, 06 Feb 2013 10:37:26 GMT Sebastian Huber [dc5cd79] * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_rsm6.cfg (moved) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_rsm6_koma_boot.cfg (deleted) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_rsm6_moma_app.cfg (deleted) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_rsm6_moma_boot.cfg (deleted) * c/src/lib/libbsp/powerpc/mpc55xxevb/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674f_rsm6 (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674f_rsm6_base (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674f_rsm6_koma_app (deleted) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674f_rsm6_koma_boot (deleted) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674f_rsm6_moma_app (deleted) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674f_rsm6_moma_boot (deleted) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-ebi-cs-cal.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-mmu.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-siu-pcr.c (modified) bsp/mpc55xx: Merge RSM6 variants into one Tue, 05 Feb 2013 16:23:55 GMT Sebastian Huber [c082b575] * c/src/lib/libbsp/powerpc/mpc55xxevb/clock/clock-config.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-esci.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-generic.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-linflex.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-clock.c (modified) bsp/mpc55xx: Add and use BSP specific fatal codes Tue, 05 Feb 2013 16:00:10 GMT Sebastian Huber [39de538] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c (modified) * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.h (modified) bsps/powerpc: Add and use ppc_cpu_is_specific_e200 Tue, 05 Feb 2013 15:59:36 GMT Sebastian Huber [3020614] * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.h (modified) bsps/powerpc: Fix e200 check Tue, 05 Feb 2013 15:31:30 GMT Sebastian Huber [93d4d06] * c/src/lib/libcpu/powerpc/mpc55xx/include/mpc55xx.h (modified) bsp/mpc55xx: Add mpc55xx_mmu_apply_config() Fri, 11 Jan 2013 13:41:53 GMT Sebastian Huber [c934a10d] * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-mmu.c (modified) * c/src/lib/libbsp/powerpc/shared/src/memcpy.c (modified) bsp/mpc55xx: Add BSP_DATA_CACHE_USE_WRITE_THROUGH Fri, 11 Jan 2013 13:41:00 GMT Sebastian Huber [036788d5] * c/src/lib/libcpu/powerpc/mpc55xx/include/regs-mmu.h (modified) bsps/powerpc: Add option for write-through cache Mon, 28 Jan 2013 11:38:55 GMT Sebastian Huber [4dafa52] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-mmu.c (modified) bsp/mpc55xx: Fix MMU configuration for RSM6 Wed, 23 Jan 2013 00:16:37 GMT Ric Claus [967278f] * c/src/lib/libbsp/powerpc/virtex4/include/irq.h (modified) * c/src/lib/libbsp/powerpc/virtex4/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/virtex5/include/irq.h (modified) * c/src/lib/libbsp/powerpc/virtex5/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c (modified) Fixed virtex4,5 BSP compile time warnings Fri, 18 Jan 2013 08:48:38 GMT Sebastian Huber [7f7b09c] * c/src/lib/libbsp/powerpc/gen83xx/startup/bsprestart.c (modified) bsp/gen83xx: Disable caches in bsp_restart() Mon, 14 Jan 2013 07:16:04 GMT Sebastian Huber [f7351e4] * c/src/lib/libbsp/powerpc/virtex5/include/irq.h (modified) bsp/virtex5: Fix define location Fri, 11 Jan 2013 08:27:50 GMT Sebastian Huber [b1d1021] * c/src/lib/libbsp/arm/lpc32xx/console/console-config.c (modified) bsp/lpc32xx: Bypass the IrDA modem for UART6 Wed, 09 Jan 2013 15:25:37 GMT Sebastian Huber [f12ef239] * c/src/lib/libbsp/arm/shared/lpc/network/lpc-ethernet.c (modified) bsps/arm: Fix LPC Ethernet driver initialization Wed, 09 Jan 2013 13:31:58 GMT Sebastian Huber [da80202] * c/src/lib/libbsp/powerpc/gen83xx/i2c/i2c_init.c (modified) bsp/gen83xx: Register I2C SEMTECH SC620 driver Wed, 09 Jan 2013 12:17:18 GMT Sebastian Huber [aeff597] * c/src/lib/libbsp/powerpc/gen83xx/i2c/i2c_init.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/i2c/i2c_init.c (modified) * c/src/lib/libcpu/powerpc/mpc83xx/i2c/mpc83xx_i2cdrv.h (modified) bsps/powerpc: Add probe handler to I2C driver Wed, 09 Jan 2013 11:50:55 GMT Sebastian Huber [339646e] * c/src/lib/libcpu/powerpc/mpc83xx/i2c/mpc83xx_i2cdrv.c (modified) bsps/powerpc: Fix compiler warnings Wed, 09 Jan 2013 10:12:48 GMT Sebastian Huber [bfde536e] * c/src/lib/libbsp/powerpc/gen83xx/startup/cpuinit.c (modified) bsp/gen83xx: Invalidate caches only if disabled Wed, 09 Jan 2013 08:29:04 GMT Sebastian Huber [5828127] * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) bsp/gen83xx: System reset after fatal conditions Wed, 09 Jan 2013 08:28:19 GMT Sebastian Huber [d4e2f337] * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/bsprestart.c (added) bsp/gen83xx: Add bsp_restart() Tue, 08 Jan 2013 09:37:41 GMT Sebastian Huber [253cb8b5] * c/src/lib/libbsp/powerpc/gen83xx/startup/linkcmds.br_uid (modified) bsp/gen83xx: Delete obsolete region Tue, 08 Jan 2013 18:49:56 GMT Joel Sherrill [f597cc1] * c/src/lib/libbsp/sparc/leon3/shmsupp/mpisr.c (modified) leon3: disable unused ISR handler Tue, 08 Jan 2013 18:37:05 GMT Joel Sherrill [4967f6b] * c/src/lib/libbsp/sparc/leon3/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/sparc/leon3/shmsupp/lock.c (modified) * c/src/lib/libbsp/sparc/leon3/shmsupp/mpisr.c (modified) leon3/shmsupp: Fix warnings & comment clean up Tue, 08 Jan 2013 17:58:41 GMT Joel Sherrill [4fd1ccaa] * c/src/lib/libbsp/sparc/leon3/leon_open_eth/leon_open_eth.c (modified) leon3: Open Ethernet Fixed Warning
