# # ChangeLog for c/src/lib in rtems # # Generated by Trac 1.2.1.dev0 # 05/22/24 12:51:51 Wed, 29 Jul 1998 00:01:44 GMT Joel Sherrill [677943a] * c/src/lib/libchip/rtc/Makefile.in (modified) * c/src/libchip/rtc/Makefile.in (modified) Added new files. Tue, 28 Jul 1998 23:16:34 GMT Joel Sherrill [9968efb] * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/config.c (added) * c/src/lib/libbsp/powerpc/dmv177/tod/tod.c (deleted) * c/src/lib/libbsp/powerpc/dmv177/tod/todcfg.c (added) First cut at configuration table for libchip RTC. At this point, we ... Tue, 28 Jul 1998 23:03:40 GMT Joel Sherrill [a1f514f] * c/src/lib/libchip/rtc/Makefile.in (modified) * c/src/lib/libchip/rtc/m48t08.c (added) * c/src/lib/libchip/rtc/m48t08.h (added) * c/src/lib/libchip/rtc/rtc.h (modified) * c/src/lib/libchip/rtc/rtcprobe.c (added) * c/src/libchip/rtc/Makefile.in (modified) * c/src/libchip/rtc/m48t08.c (added) * c/src/libchip/rtc/m48t08.h (added) * c/src/libchip/rtc/rtc.h (modified) * c/src/libchip/rtc/rtcprobe.c (added) First cut implementation of real-time clock support in libchip. This ... Tue, 28 Jul 1998 21:18:17 GMT Joel Sherrill [009c235] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/serial.h (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/serial.h (modified) Corrected spacing. Tue, 28 Jul 1998 21:18:11 GMT Joel Sherrill [07e91808] * c/src/lib/libchip/Makefile.in (modified) * c/src/lib/libchip/rtc/Makefile.in (added) * c/src/lib/libchip/rtc/rtc.h (added) * c/src/libchip/rtc/Makefile.in (added) * c/src/libchip/rtc/rtc.h (added) Added rtc directory. Tue, 28 Jul 1998 16:49:36 GMT Joel Sherrill [bd7c547] * c/src/exec/libcsupport/src/termios.c (modified) * c/src/lib/libc/termios.c (modified) * cpukit/libcsupport/src/termios.c (modified) Closed window thanks to patch from Eric Norum. Sat, 25 Jul 1998 17:34:41 GMT Joel Sherrill [5752f930] * c/src/lib/libbsp/shared/console.c (added) New file -- copied from dmv177 but same as ppcn_60x. Sat, 25 Jul 1998 17:22:58 GMT Joel Sherrill [749c54e] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/z85c30.c (modified) Added comments and corrected spacing. Sat, 25 Jul 1998 17:19:45 GMT Joel Sherrill [cae0504] * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550.c (modified) Corrected spacing and added headers. Sat, 25 Jul 1998 17:17:46 GMT Joel Sherrill [8739322] * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/lib/libchip/serial/ns16550_p.h (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550_p.h (modified) Added ns16550_set_attributes. Sat, 25 Jul 1998 17:17:36 GMT Joel Sherrill [b636d56] * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/z85c30.c (modified) Corrected spacing and added a comment. Sat, 25 Jul 1998 17:17:05 GMT Joel Sherrill [ccfa60b] * c/src/lib/libchip/serial/STATUS (modified) * c/src/libchip/serial/STATUS (modified) Updated to reflect set attributes. Sat, 25 Jul 1998 16:53:21 GMT Joel Sherrill [70a9451] * c/src/lib/libchip/serial/STATUS (modified) * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/lib/libchip/serial/ns16550_p.h (modified) * c/src/libchip/serial/STATUS (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550_p.h (modified) Rewrote NS16550 TX interrupt processing to use termios for the buffer ... Sat, 25 Jul 1998 16:52:17 GMT Joel Sherrill [adedb057] * c/src/lib/libchip/serial/serial.h (modified) * c/src/libchip/serial/serial.h (modified) Removed TX ring buffer. Sat, 25 Jul 1998 16:52:00 GMT Joel Sherrill [cb27f05] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/z85c30.c (modified) Changed variable to hold received data to unsigned. Sat, 25 Jul 1998 16:20:33 GMT Joel Sherrill [dfb16ce] * c/src/lib/libchip/serial/z85c30_p.h (modified) * c/src/libchip/serial/z85c30_p.h (modified) Added constants for z85c30_enable_interrupts. Sat, 25 Jul 1998 16:20:14 GMT Joel Sherrill [04c5ac7] * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/z85c30.c (modified) Removed z85c30_flush(). Reworked transmit interrupt processing to ... Sat, 25 Jul 1998 16:18:46 GMT Joel Sherrill [c1da250] * c/src/lib/libchip/serial/serial.h (modified) * c/src/libchip/serial/serial.h (modified) Changed comment on TxBuffer. Sat, 25 Jul 1998 16:18:27 GMT Joel Sherrill [b070d69a] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/mc68681_p.h (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681_p.h (modified) Removed mc68681_flush and corrected spacing. Sat, 25 Jul 1998 16:17:33 GMT Joel Sherrill [f600da3f] * c/src/lib/libchip/serial/STATUS (modified) * c/src/libchip/serial/STATUS (modified) Added information on Chris Johns' suggestion to use pointers ... Sat, 25 Jul 1998 16:16:10 GMT Joel Sherrill [3d2c161] * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) Removed "if 0" used to switch between serial ports. Sat, 25 Jul 1998 16:02:21 GMT Joel Sherrill [da8ac60a] * c/src/lib/libchip/serial/STATUS (added) * c/src/libchip/serial/STATUS (added) New file. Sat, 25 Jul 1998 14:51:57 GMT Joel Sherrill [c68b990] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Changed to utilize return status from ... Sat, 25 Jul 1998 14:50:07 GMT Joel Sherrill [a3c9f0d] * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/console.c (deleted) Moved console.c to libbsp/shared. Sat, 25 Jul 1998 14:13:34 GMT Joel Sherrill [f246caf] * c/src/lib/libchip/serial/z85c30_reg.c (modified) * c/src/libchip/serial/z85c30_reg.c (modified) Interrupts were incorrectly managed with a disable/disable pair ... Fri, 24 Jul 1998 16:18:39 GMT Joel Sherrill [03c0961] * c/src/lib/libbsp/m68k/gen68340/console/console.c (modified) Patch from David Fiddes : Here's a small ... Fri, 24 Jul 1998 16:09:51 GMT Joel Sherrill [dbab462] * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/network/network.c (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/irq/irq_init.c (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * make/leaf.cfg (modified) Patch from Eric Valette and Emmanuel Raguet ... Thu, 23 Jul 1998 22:13:10 GMT Joel Sherrill [dbaf51a] * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/wd80x3.h (added) * c/src/lib/libbsp/i386/pc386/network/Makefile.in (added) * c/src/lib/libbsp/i386/pc386/network/network.c (added) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * make/custom/pc386.cfg (modified) Patch from Emmanuel Raguet : Here is a ... Thu, 23 Jul 1998 22:02:34 GMT Joel Sherrill [67a2288] * Makefile.in (modified) * c/Makefile.in (modified) * c/src/exec/score/cpu/i386/cpu.c (modified) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/exec/score/cpu/i386/cpu_asm.s (modified) * c/src/exec/score/cpu/i386/i386.h (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/console/inch.c (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/start/start.s (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.s (modified) * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) * c/src/lib/libbsp/i386/shared/Makefile.in (added) * c/src/lib/libbsp/i386/shared/irq/Makefile.in (added) * c/src/lib/libbsp/i386/shared/irq/idt.c (added) * c/src/lib/libbsp/i386/shared/irq/irq.c (added) * c/src/lib/libbsp/i386/shared/irq/irq.h (added) * c/src/lib/libbsp/i386/shared/irq/irq_asm.h (added) * c/src/lib/libbsp/i386/shared/irq/irq_asm.s (added) * c/src/lib/libbsp/i386/shared/irq/irq_init.c (added) * c/src/lib/libcpu/i386/Makefile.in (added) * c/src/lib/libcpu/i386/cpu.c (added) * c/src/lib/libcpu/i386/cpu.h (added) * c/src/lib/libcpu/i386/cpu_asm.S (added) * c/src/lib/libcpu/i386/idt.c (added) * c/src/lib/libcpu/i386/wrapup/Makefile.in (added) * c/src/lib/wrapup/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * cpukit/score/cpu/i386/cpu.c (modified) Patch from Eric VALETTE : Here is a ... Thu, 23 Jul 1998 19:32:01 GMT Joel Sherrill [c91e032] * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) Removed consolex from build list. This file should be obsoleted by ... Tue, 21 Jul 1998 13:59:12 GMT Joel Sherrill [92fc5a5d] * c/src/lib/start/m68k/start.s (modified) Fix from Chris Johns . Comments: Mask interrupts ... Sat, 18 Jul 1998 18:44:12 GMT Joel Sherrill [bced36d] * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) Changed so we could test interrupts on port 3. Sat, 18 Jul 1998 18:35:34 GMT Joel Sherrill [c14a619] * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/lib/libchip/serial/z85c30_reg.c (modified) * c/src/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/z85c30_reg.c (modified) Removed use of data port for z8530. Move some code around. Sat, 18 Jul 1998 18:35:07 GMT Joel Sherrill [3652929e] * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) Removed use of data port for z8530. Tested all four ports. MC68681 ... Sat, 18 Jul 1998 18:34:04 GMT Joel Sherrill [91f16d5] * c/src/lib/libbsp/powerpc/dmv177/QUIRKS (added) New file Sat, 18 Jul 1998 17:47:50 GMT Joel Sherrill [a4d34dd2] * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) Added z85c30 specific probe routine to decide what the clock rate ... Sat, 18 Jul 1998 17:46:33 GMT Joel Sherrill [f8a5d54e] * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) Addresses for SCC were wrong. A and B ports were swapped. Deleted ... Sat, 18 Jul 1998 16:56:16 GMT Joel Sherrill [c53e1df4] * c/src/lib/libbsp/powerpc/dmv177/cable.doc (modified) Swapped RX and TX since doing this makes the lights blink on the ... Sat, 18 Jul 1998 16:11:13 GMT Joel Sherrill [fe05ec5e] * c/src/lib/libbsp/powerpc/dmv177/cable.doc (modified) Added RS-422 converter information and cable building information. Sat, 18 Jul 1998 15:34:03 GMT Joel Sherrill [cc3d33ac] * c/src/lib/libbsp/powerpc/dmv177/cable.doc (modified) Added information on the MC68681. Sat, 18 Jul 1998 15:24:14 GMT Joel Sherrill [f7d6e57] * c/src/lib/libbsp/powerpc/dmv177/cable.doc (modified) Added background and setup to add section on RS-422. Sat, 18 Jul 1998 15:23:56 GMT Joel Sherrill [f77670be] * c/src/lib/libbsp/powerpc/dmv177/startup/genpvec.c (modified) Reworked to removed dependency on DY-4 CSS ROM monitor interface. Sat, 18 Jul 1998 15:23:24 GMT Joel Sherrill [e286479] * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) Removed css_iface. Sat, 18 Jul 1998 15:22:54 GMT Joel Sherrill [6d4062f] * c/src/lib/libbsp/powerpc/dmv177/css_iface/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/css_iface/css_iface.c (deleted) Removed. We are no longer dependent on DY-4 CSS interface code. Sat, 18 Jul 1998 15:19:28 GMT Joel Sherrill [cce1200e] * c/src/lib/libbsp/powerpc/dmv177/cable.doc (added) New file. Fri, 17 Jul 1998 22:34:54 GMT Joel Sherrill [4555bc1e] * c/src/exec/libcsupport/src/termios.c (modified) * c/src/lib/libc/termios.c (modified) * cpukit/libcsupport/src/termios.c (modified) Initialized tty->refcount to 0. When (for whatever reason) malloc() ... Fri, 17 Jul 1998 15:43:42 GMT Joel Sherrill [8123c635] * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (modified) Added scitab directory. Fri, 17 Jul 1998 15:19:04 GMT Joel Sherrill [bdba552f] * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (added) Patch fromalf Corsepius : * ... Fri, 17 Jul 1998 13:05:03 GMT Joel Sherrill [6e65840] * c/src/exec/libcsupport/src/termios.c (modified) * c/src/lib/libc/termios.c (modified) * cpukit/libcsupport/src/termios.c (modified) Patch from Dario Alcocer . His comments: ... Thu, 16 Jul 1998 00:16:22 GMT Joel Sherrill [16d0e63] * c/src/lib/libchip/serial/mc68681_baud.c (modified) * c/src/libchip/serial/mc68681_baud.c (modified) Corrected header files. Thu, 16 Jul 1998 00:16:11 GMT Joel Sherrill [a6f441b] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Minor corrections for typos to get it to compile. Thu, 16 Jul 1998 00:03:01 GMT Joel Sherrill [dd5d2f04] * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libchip/serial/README.mc68681 (modified) * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/lib/libchip/serial/mc68681_baud.c (added) * c/src/libchip/serial/Makefile.in (modified) * c/src/libchip/serial/README.mc68681 (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681_baud.c (added) Split default baud rate table into its own file. This shrinks the ... Wed, 15 Jul 1998 23:58:08 GMT Joel Sherrill [4a11d8c] * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) Fixed typo in which last port did not get switched to default ... Wed, 15 Jul 1998 23:57:41 GMT Joel Sherrill [849dc107] * c/src/lib/libchip/serial/mc68681_reg.c (modified) * c/src/lib/libchip/serial/mc68681_reg2.c (modified) * c/src/lib/libchip/serial/mc68681_reg4.c (modified) * c/src/lib/libchip/serial/mc68681_reg8.c (modified) * c/src/libchip/serial/mc68681_reg.c (modified) * c/src/libchip/serial/mc68681_reg2.c (modified) * c/src/libchip/serial/mc68681_reg4.c (modified) * c/src/libchip/serial/mc68681_reg8.c (modified) Fixed typos. Wed, 15 Jul 1998 23:55:04 GMT Joel Sherrill [670d037] * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/mc68681cfg.c (deleted) * c/src/lib/libbsp/powerpc/dmv177/console/mc68681cfg.h (deleted) * c/src/lib/libbsp/powerpc/dmv177/console/z85c30cfg.c (deleted) * c/src/lib/libbsp/powerpc/dmv177/console/z85c30cfg.h (deleted) Switched to usign the default z8530 and mc68681 register access routines. Wed, 15 Jul 1998 23:54:24 GMT Joel Sherrill [8414c033] * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libchip/serial/z85c30.h (modified) * c/src/lib/libchip/serial/z85c30_reg.c (added) * c/src/libchip/serial/Makefile.in (modified) * c/src/libchip/serial/z85c30.h (modified) * c/src/libchip/serial/z85c30_reg.c (added) Added default z85c30 register access routines. Wed, 15 Jul 1998 23:54:08 GMT Joel Sherrill [cce9322] * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/lib/libchip/serial/mc68681_reg.c (added) * c/src/lib/libchip/serial/mc68681_reg2.c (added) * c/src/lib/libchip/serial/mc68681_reg4.c (added) * c/src/lib/libchip/serial/mc68681_reg8.c (added) * c/src/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681_reg.c (added) * c/src/libchip/serial/mc68681_reg2.c (added) * c/src/libchip/serial/mc68681_reg4.c (added) * c/src/libchip/serial/mc68681_reg8.c (added) Added default mc68681 register access routines. Wed, 15 Jul 1998 23:21:55 GMT Joel Sherrill [991a1ab4] * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/z85c30.c (modified) Added check for proper deviceType to interrupt processing code. Wed, 15 Jul 1998 23:21:30 GMT Joel Sherrill [efaf85fa] * c/src/lib/libchip/serial/mc68681_p.h (modified) * c/src/libchip/serial/mc68681_p.h (modified) Added interrupt mask and interrupt status register bit constants. ... Wed, 15 Jul 1998 23:20:50 GMT Joel Sherrill [49370cd] * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681.h (modified) Added default mc68681 register access routines. Wed, 15 Jul 1998 23:20:33 GMT Joel Sherrill [198d851] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Switched from driver's own buffering to using termios. This ... Wed, 15 Jul 1998 23:15:49 GMT Joel Sherrill [27a66bd] * c/src/lib/libchip/serial/README.mc68681 (modified) * c/src/lib/libchip/serial/README.z85c30 (modified) * c/src/libchip/serial/README.mc68681 (modified) * c/src/libchip/serial/README.z85c30 (modified) Added information on the deviceType field. Wed, 15 Jul 1998 23:15:32 GMT Joel Sherrill [66f95fc] * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) Added default mc68681 register access routines. Wed, 15 Jul 1998 21:43:28 GMT Joel Sherrill [8a2e9c41] * c/src/lib/libbsp/powerpc/dmv177/scv64/scv64.c (modified) Added SCV64_Get_Interrupt_Enable(). Added proper headers to routines. Wed, 15 Jul 1998 21:43:00 GMT Joel Sherrill [d0cff6dc] * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) Added SCV64_Get_Interrupt_Enable(). Wed, 15 Jul 1998 21:42:26 GMT Joel Sherrill [38e717f] * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) Added chip type identifier field. This was necessary because a ... Wed, 15 Jul 1998 21:40:42 GMT Joel Sherrill [c0573d7] * c/src/lib/libchip/serial/serial.h (modified) * c/src/libchip/serial/serial.h (modified) Added comment to remove use of TxBuffer ring buffer in all libchip ... Wed, 15 Jul 1998 19:28:29 GMT Joel Sherrill [0f61336] * c/src/lib/libbsp/powerpc/dmv177/console/console.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/z85c30cfg.c (modified) Added comments. Wed, 15 Jul 1998 19:20:20 GMT Joel Sherrill [a69f0ad9] * c/src/lib/libbsp/powerpc/dmv177/startup/setvec.c (modified) Added comments. Wed, 15 Jul 1998 19:19:14 GMT Joel Sherrill [100a4e5] * c/src/lib/libbsp/powerpc/dmv177/startup/genpvec.c (modified) Masked out interrupts not being used prior to processing the status ... Wed, 15 Jul 1998 19:12:11 GMT Joel Sherrill [6c45da17] * c/src/lib/libbsp/powerpc/dmv177/scv64/scv64.c (modified) Added routine to return interrupt mask. Added comments. Wed, 15 Jul 1998 14:06:37 GMT Joel Sherrill [01e54b8] * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) Added scv64 subdirectory. Wed, 15 Jul 1998 14:06:08 GMT Joel Sherrill [e49ef37c] * c/src/lib/libbsp/powerpc/dmv177/startup/genpvec.c (modified) Switched to SCV64. Wed, 15 Jul 1998 14:05:51 GMT Joel Sherrill [8f563b9b] * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) Added CSCV64 functions and addresses. Wed, 15 Jul 1998 14:04:31 GMT Joel Sherrill [30a3f76] * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) Switched from polling to interrupts and in the process added a ... Wed, 15 Jul 1998 14:00:23 GMT Joel Sherrill [437b5a7d] * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) Added scv64 subdirectory. Wed, 15 Jul 1998 14:00:09 GMT Joel Sherrill [090a3511] * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.in (added) * c/src/lib/libbsp/powerpc/dmv177/scv64/scv64.c (added) New files. Wed, 15 Jul 1998 13:58:23 GMT Joel Sherrill [be8cbbf] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Switched deviceOutputUsesInterrupts to TRUE so output would be ... Wed, 15 Jul 1998 13:53:58 GMT Joel Sherrill [e283140c] * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/z85c30.c (modified) Switched to "deviceOutput = TRUE" which made device output use ... Fri, 10 Jul 1998 15:43:18 GMT Joel Sherrill [dbfa3148] * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/console/inch.c (modified) * c/src/lib/libbsp/i386/pc386/startup/exit.c (modified) Patch from Quality Quorum . Comments: ... Thu, 09 Jul 1998 23:32:07 GMT Joel Sherrill [fb32356b] * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/lib/libchip/serial/z85c30_p.h (modified) * c/src/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/z85c30_p.h (modified) Added set attributes routine but did not hook it in to the table. ... Thu, 09 Jul 1998 23:31:48 GMT Joel Sherrill [abd8c82] * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) Added new files. Thu, 09 Jul 1998 23:31:26 GMT Joel Sherrill [31cad72c] * c/src/lib/libchip/serial/sersupp.c (deleted) Renamed so we could have one file per routine. Thu, 09 Jul 1998 23:30:32 GMT Joel Sherrill [064b9be] * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550.c (modified) Switched to shared default probe routine. Thu, 09 Jul 1998 23:30:02 GMT Joel Sherrill [693b5b88] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Switched to default probe routine. Thu, 09 Jul 1998 23:29:33 GMT Joel Sherrill [61ff7ac8] * c/src/lib/libchip/serial/serprobe.c (added) * c/src/lib/libchip/serial/sersupp.h (modified) * c/src/lib/libchip/serial/termios_baud2index.c (added) * c/src/lib/libchip/serial/termios_baud2num.c (added) * c/src/libchip/serial/serprobe.c (added) * c/src/libchip/serial/sersupp.h (modified) * c/src/libchip/serial/termios_baud2index.c (added) * c/src/libchip/serial/termios_baud2num.c (added) Added new baud rate to number function and default serial probe ... Thu, 09 Jul 1998 22:59:32 GMT Joel Sherrill [11c6a92d] * c/src/lib/libbsp/powerpc/dmv177/startup/bspclean.c (modified) Commented out the system call invocation since we don't know what ... Thu, 09 Jul 1998 22:59:13 GMT Joel Sherrill [a6e36dff] * c/src/lib/libbsp/powerpc/dmv177/start/start.s (modified) Removed call back to exit() since that has already been called. Thu, 09 Jul 1998 22:21:54 GMT Joel Sherrill [e78c474b] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Added proper handling of extended baud rate table selection at boot ... Thu, 09 Jul 1998 22:16:27 GMT Joel Sherrill [2c5ea01] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Properly handle extended baud rate set commands. Temporarily "if 0" ... Thu, 09 Jul 1998 22:11:49 GMT Joel Sherrill [e3c59dd] * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681.h (modified) Corrected definition of MC68681_RX_BUFFER. Thu, 09 Jul 1998 18:50:13 GMT Joel Sherrill [2ba0a0c2] * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) Corrected z85c30 address and clock constants. Thu, 09 Jul 1998 18:49:49 GMT Joel Sherrill [459c1d2] * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) Added board specific baud rate table and set driver function table ... Thu, 09 Jul 1998 18:45:28 GMT Joel Sherrill [2d8e51aa] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Changed static to MC68681_STATIC to make all data and routines ... Thu, 09 Jul 1998 18:44:10 GMT Joel Sherrill [b2ec38c8] * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681.h (modified) Removed commented out line. Thu, 09 Jul 1998 18:41:49 GMT Joel Sherrill [8f6f641e] * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) Added sersupp.c. Thu, 09 Jul 1998 18:41:33 GMT Joel Sherrill [d94d47b3] * c/src/lib/libchip/serial/sersupp.c (added) * c/src/lib/libchip/serial/sersupp.h (added) * c/src/libchip/serial/sersupp.h (added) New files to contain generally needed serial driver support routines. Thu, 09 Jul 1998 18:40:27 GMT Joel Sherrill [37e8259] * c/src/lib/libchip/serial/mc68681_p.h (modified) * c/src/libchip/serial/mc68681_p.h (modified) Changed static to MC68681_STATIC to make all routines and data global ... Thu, 09 Jul 1998 18:39:50 GMT Joel Sherrill [8b2492f] * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681.h (modified) Added support for the Extended Baud Rate set control found in the ... Thu, 09 Jul 1998 18:38:18 GMT Joel Sherrill [27045a82] * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/lib/libchip/serial/ns16550_p.h (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550_p.h (modified) Changed static to NS16550_STATIC to make all routines and data global ...
