@d9ff8b3e
06/06/14 11:35:56 |
Sebastian Huber |
bsps/powerpc: Fix potential relocation truncation
See also
4.115
@dc44de7
06/05/14 14:38:29 |
Sebastian Huber |
bsps/arm: Fix TLB invalidation for ARMv7-A
4.115
@66a2409d
06/05/14 09:40:48 |
Sebastian Huber |
bsps/arm: Add ARM_CP15_TEXT_SECTION
Allow users of this header file …
4.115
@d0a8f513
06/05/14 06:32:15 |
Sebastian Huber |
bsps/arm: Add all level data cache invalidation
4.115
@def03ae
06/05/14 06:31:45 |
Sebastian Huber |
bsps/arm: Typo
4.115
@8df1f408
06/02/14 14:31:51 |
Christian.Mauderer |
score/sparc: Add support for paravirtualization
Guest systems in …
4.115
@6ddc4da
06/01/14 23:18:00 |
Joel Sherrill |
m68k/shared/misc/memProbe.c: Add prototype to eliminate warning
4.115
@d6f1ec91
05/26/14 13:22:12 |
Daniel Hellstrom |
SPARC: syscall optimizations and PSR-write fix
The last optimization …
4.115
@6a740c2
05/23/14 13:52:16 |
Daniel Hellstrom |
SPARC: add syscall 1 (exit) function entry point
The exit SPARC …
4.115
@434e7f7
05/23/14 13:52:15 |
Daniel Hellstrom |
SPARC: syscall code clean-up and minor optimizations
4.115
@11b05f1
05/08/14 08:11:13 |
Sebastian Huber |
score: Fix CPU context usage on SMP
We must not alter the is …
4.115
@38b59a6
05/02/14 08:31:09 |
Sebastian Huber |
score: Implement forced thread migration
The current implementation …
4.115
@03b7789
04/26/14 13:09:10 |
Sebastian Huber |
score: Statically initialize _ISR_Vector_table
4.115
@a16af0b3
04/29/14 07:39:08 |
Sebastian Huber |
bsps/mips: Delete unused files
The MIPS port defines …
4.115
@90bc4d03
04/21/14 14:07:51 |
Joel Sherrill |
libcpu/sh: Build cache stubs so apps usign cache API link
4.115
@320faf8e
04/17/14 05:57:09 |
Sebastian Huber |
score: Clarify TLS support
4.115
@487b94e7
04/15/14 11:34:24 |
Sebastian Huber |
bsps/powerpc: SMP support for SPR functions
These registers are local …
4.115
@509040f0
04/14/14 15:11:12 |
Sebastian Huber |
bsps/powerpc: SMP support for one TSEC driver
4.115
@10b0c3f
03/31/14 14:11:30 |
Sebastian Huber |
bsps/powerpc: PR757: Fix PPC_IRQ_TRACE for ppc601
We could probably …
4.115
@c499856
03/20/14 21:10:47 |
Chris Johns |
Change all references of rtems.com to rtems.org.
4.115
@1550242
03/05/14 16:14:21 |
Sebastian Huber |
bsps/powerpc: Add support for interrupt profiling
4.115
@0656a00a
01/23/14 09:56:31 |
ralf.kirchner |
bsp/arm: Add CP15 methods
4.115
@dedc1393
03/12/14 15:37:10 |
Sebastian Huber |
bsps/powerpc: Fix GET_INTERRUPT_MASK macro
Use …
4.115
@ae88aa7
03/10/14 07:15:37 |
Sebastian Huber |
sapi: Use one SMP lock for all chains
This partially reverts commit …
4.115
@e1d7bf0
02/26/14 10:08:31 |
Sebastian Huber |
rtems: Add cache size functions
Add rtems_cache_get_data_cache_size() …
4.115
@e7549ff4
02/26/14 10:00:17 |
Sebastian Huber |
rtems: Use size_t for cache line size
A cache line cannot have a …
4.115
@33cb8bf
02/17/14 10:40:18 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_BSP
Merge …
4.115
@801b5d8
02/17/14 08:23:59 |
Sebastian Huber |
powerpc: Change interrupt disable implemetation
Instead of SPRG0 (= …
4.115
@022851a
01/28/14 11:10:08 |
Sebastian Huber |
Add thread-local storage (TLS) support
Tested and implemented on ARM, …
4.115
@fc6a0ae
01/14/14 13:40:07 |
Aleksandr Platonov |
rtems_cache_invalidate_multiple_instruction_lines
According with …
4.115
@eba0626
12/18/13 10:47:07 |
Sebastian Huber |
bsps/arm: Use Normal memory for code and data
4.115
@e626c60
12/06/13 17:14:57 |
cdesai |
libcpu/powerpc/mpc5xx: use THREAD_DISABLE_DISPATCH_LEVEL in asm
4.115
@057c294
12/03/13 08:55:52 |
Sebastian Huber |
bsps/powerpc: Unconditionally clear reservations
4.115
@39a4574
06/24/13 13:21:46 |
Sebastian Huber |
powerpc: Add r2 to CPU context
The r2 may be used for thread-local …
4.115
@f074a4d
10/27/13 18:27:44 |
Sebastian Huber |
bsps/arm: ARMV7_MMU_DATA_READ_WRITE_SHAREABLE
Delete …
4.115
@0a9533fc
09/28/13 08:08:24 |
Hesham Almatary |
Add a new necessary definition needed for raspberrypi MMU support
The …
4.115
@4fab260d
09/23/13 13:24:32 |
Joel Sherrill |
libcpu/sparc/.../access_le.c: Add include file to fix warning
4.115
@f55215a
09/10/13 06:50:24 |
Sebastian Huber |
bsps: Fix cache manager support
4.115
@d157a4fd
09/04/13 12:03:47 |
Sebastian Huber |
bsps/arm: Fix ARM CP15 opcode for get functions
4.115
@1215fd4
08/26/13 13:14:33 |
Sebastian Huber |
sapi: SMP support for chains
Add ISR lock to chain control for proper …
4.115
@2bd440e
08/22/13 12:18:14 |
Ric Claus |
bsp/xilinx-zynq: Add cache support
4.115
@c9b66f5
08/22/13 12:00:51 |
Ric Claus |
bsps/arm: Add more CP15 cache functions
4.115
@d473dc0
08/14/13 11:26:41 |
Sebastian Huber |
bsps: Fix clock driver defines
4.115
@c6c998b
08/01/13 14:36:55 |
Sebastian Huber |
bsps/powerpc: Per-CPU thread dispatch disable
Interrupt support for …
4.115
@d19cce29
08/05/13 12:54:11 |
Sebastian Huber |
score: Per-CPU thread dispatch disable level
Use a per-CPU thread …
4.115
@98bcf4ff
08/08/13 23:23:14 |
Pavel Pisa |
bsp/csb336: implement bsp_interrupt_vector_enable/disable.
4.115
@f031df0e
07/31/13 11:42:07 |
Sebastian Huber |
score: Rename tod.h to todimpl.h
4.115
@02632e8
07/25/13 08:34:50 |
Pavel Pisa |
bsp/csb336: mc9328mxl correct AITC access in bsp_interrupt_dispatch.
4.115
@88c74ab
07/25/13 13:10:11 |
Sebastian Huber |
score: Merge tod implementation into one file
Delete …
4.115
@0c3edbf
07/25/13 08:46:15 |
Sebastian Huber |
Include missing <rtems/score/threaddispatch.h>
4.115
@b3a84034
07/24/13 13:49:05 |
dufault |
bsp/mpc55xx: Fix prototype
4.115
@39046f7
07/24/13 09:09:23 |
Sebastian Huber |
score: Merge sysstate API into one file
4.115
@c8d78ee
07/02/13 08:37:13 |
Sebastian Huber |
bsp/mpc55xx: Add MPC5668G support
4.115
@4fe3ad2
07/09/13 14:37:32 |
Sebastian Huber |
bsps/powerpc: Add ppc_count_leading_zeros()
4.115
@56435e6
06/26/13 08:25:42 |
Sebastian Huber |
powerpc: Fix Altivec support
Use the right context.
4.115
@e18db9f
06/24/13 15:29:11 |
Sebastian Huber |
termios: Update due to API changes
Termios notifies now the driver …
4.115
@7d0e88f2
06/21/13 14:19:46 |
Sebastian Huber |
bsps/powerpc: Delete clock_4xx.c
4.115
@ade27c6
06/20/13 09:44:04 |
Sebastian Huber |
bsps: Move bsp_generic_fatal_code to new file
Add bsp_generic_fatal().
4.115
@5f91272
06/20/13 09:17:23 |
Sebastian Huber |
bsps/powerpc: Delete bsp_exceptions_in_RAM
Delete …
4.115
@9a037da9
06/19/13 09:20:06 |
Sebastian Huber |
bsps/arm: Set vector base address if necessary
4.115
@49cdf40
06/12/13 07:25:39 |
Sebastian Huber |
score: Add and use _Thread_Dispatch_is_enabled()
Delete …
4.115
@18e2fbe7
06/07/13 09:50:37 |
Sebastian Huber |
smp: Fix PowerPC context switch
4.115
@db42c079
05/31/13 11:59:47 |
Sebastian Huber |
bsps/arm: Add SMP support
4.115
@ffbeb6f
01/18/13 08:42:49 |
Sebastian Huber |
smp: Add PowerPC support
4.115
@e3be6915
05/27/13 15:31:46 |
Sebastian Huber |
score: Remove idle field of Per_CPU_Control
This field is unused …
4.115
@5b391f85
05/31/13 08:00:07 |
Sebastian Huber |
bsps/arm: Use Write-Allocate cache for ARMv7
4.115
@1dcf5fe
05/31/13 07:59:27 |
Sebastian Huber |
bsps/arm: Merge ARMv7 MMU section definitions
4.115
@33c98fd
05/06/13 08:20:26 |
Sebastian Huber |
bsps/arm: Remove superfluous parameter
4.115
@fd51f7e
05/02/13 09:09:24 |
Sebastian Huber |
bsps/arm: Support ARMv7 VMSA sections and control
4.115
@88cf23f8
04/30/13 13:23:45 |
Sebastian Huber |
bsps/arm: Add arm_cp15_set_exception_handler()
4.115
@037e8ae5
05/02/13 15:42:20 |
Sebastian Huber |
bsps/arm: Add arm_cp15_set_trans*_table_entries()
4.115
@544615d
05/02/13 15:41:11 |
Sebastian Huber |
bsps/arm: Add arm_cp15_mmu_disable()
4.115
@d2d02961
05/02/13 15:40:45 |
Sebastian Huber |
bsps/arm: Add arm_cp15_get_min_cache_line_size()
4.115
@024a572
04/29/13 07:28:58 |
Sebastian Huber |
bsp/mpc55xx: Avoid empty enum
4.115
@62aa318
04/25/13 13:21:35 |
Sebastian Huber |
bsp/mpc55xx: Add MMU tag translate initializer
4.115
@76de8a8e
04/17/13 12:54:05 |
van.freenix |
D-cache clean&&invalidate for Tiny6410
4.115
@ef8e851
04/17/13 13:45:52 |
Sebastian Huber |
bsp/mpc55xx: Typo
4.115
@db21e1d
04/03/13 10:05:49 |
Sebastian Huber |
bsp/mpc55xx: eDMA API changes
4.115
@4e3deaf7
04/05/13 13:57:19 |
Sebastian Huber |
bsp/mpc55xx: Add alternative register layout
4.115
@db0ed4c5
04/08/13 08:43:42 |
Sebastian Huber |
bsp/mpc55xx: Add PCR index enumeration
4.115
@30158371
04/03/13 10:10:25 |
Sebastian Huber |
bsp/mpc55xx: New fatal errors
4.115
@602d5ba
04/08/13 14:11:02 |
Sebastian Huber |
bsps: Fix warnings
4.115
@faad192
03/11/13 16:54:34 |
Sebastian Huber |
mpc83xx: Add and use mpc83xx_reset()
The inline version makes it …
4.115
@fad2d38
03/08/13 20:55:06 |
Gedare Bloom |
RTEMS: Delete ChangeLog? files.
This commit deletes all RTEMS …
4.115
@ef921556
02/25/13 16:33:17 |
Sebastian Huber |
bsp/mpc55xx: Add register type definition
4.115
@c8bd3cd
02/08/13 12:39:59 |
Sebastian Huber |
libchip/serial: Add const qualifier
4.115
@39de538
02/05/13 16:00:10 |
Sebastian Huber |
bsps/powerpc: Add and use ppc_cpu_is_specific_e200
4.115
@3020614
02/05/13 15:59:36 |
Sebastian Huber |
bsps/powerpc: Fix e200 check
4.115
@93d4d06
02/05/13 15:31:30 |
Sebastian Huber |
bsp/mpc55xx: Add mpc55xx_mmu_apply_config()
4.115
@036788d5
01/11/13 13:41:00 |
Sebastian Huber |
bsps/powerpc: Add option for write-through cache
4.115
@aeff597
01/09/13 12:17:18 |
Sebastian Huber |
bsps/powerpc: Add probe handler to I2C driver
4.115
@339646e
01/09/13 11:50:55 |
Sebastian Huber |
bsps/powerpc: Fix compiler warnings
4.115
@370c2c80
01/04/13 12:06:51 |
Sebastian Huber |
arm: Rename arm_exc_interrupt()
Rename arm_exc_interrupt() to …
4.115
@9b2e7143
01/04/13 12:05:28 |
Sebastian Huber |
arm: Move prototypes to new file
Move bsp_interrupt_dispatch() and …
4.115
@3af7e23e
12/21/12 13:11:36 |
Sebastian Huber |
bsp/gen83xx: Add GPR_1 to register map
4.115
@a640b204
12/21/12 08:26:27 |
Sebastian Huber |
bsp/gen83xx: Fix RCWLR_CEVCO defines
4.115
@191929cd
12/06/12 16:31:48 |
Sebastian Huber |
bsps/powerpc: Install missing <bsp/vectors.h>
4.115
@3ce66aa
11/19/12 08:02:12 |
Sebastian Huber |
bsp/mpc55xx: Set PPC_EXC_CONFIG_USE_FIXED_HANDLER
4.115
@67338ed
11/15/12 15:57:02 |
Sebastian Huber |
bsp/mpc55xx: Add mpc55xx_wait_for_interrupt()
Use …
4.115
@bd75e589
11/13/12 11:20:59 |
Sebastian Huber |
bsp/mpc55xx: Fix INTC initialization
4.115
