source: rtems/c/src/lib/libcpu
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @5019592   06/26/00 15:43:13 Joel Sherrill Removed as it was orphaned by previous patches. 4.104.114.84.95
(edit) @c8e0c3a   06/15/00 22:00:22 Joel Sherrill Make ppc603e pick up caching code. 4.104.114.84.95
(edit) @667c8a0   06/15/00 19:27:56 Joel Sherrill Typo corrected from John Cotton <john.cotton@…>. 4.104.114.84.95
(edit) @10d8a60   06/15/00 13:21:30 Joel Sherrill Updated. 4.104.114.84.95
(edit) @5e77d129   06/14/00 20:32:44 Joel Sherrill Patch from John Cotton <john.cotton@…> to correct cache routine … 4.104.114.84.95
(edit) @05352c24   06/14/00 20:21:18 Joel Sherrill Added .cvsignore files. 4.104.114.84.95
(edit) @ac815430   06/14/00 17:07:54 Joel Sherrill Patch rtems-rc-20000614-sh.tar.gz from Ralf Corsepius … 4.104.114.84.95
(edit) @61bd0301   06/14/00 15:52:24 Joel Sherrill Moved PowerPC cache management code to libcpu. Also compiled mpc8xx … 4.104.114.84.95
(edit) @134b163f   06/14/00 15:47:38 Joel Sherrill Removed building of libcpu.a. It is now the individual BSPs … 4.104.114.84.95
(edit) @ddbaa1e   06/14/00 15:39:53 Joel Sherrill Moved to include subdirectory. 4.104.114.84.95
(edit) @0a18747   06/14/00 15:39:31 Joel Sherrill New files containing cache manager functionality stripped from … 4.104.114.84.95
(edit) @18dbd6a   06/14/00 15:39:00 Joel Sherrill New file. 4.104.114.84.95
(edit) @abd9401   06/14/00 15:38:08 Joel Sherrill Functionality moved from directory above to accomodate building shared … 4.104.114.84.95
(edit) @90ff45b   06/14/00 15:37:30 Joel Sherrill Moved from score/cpu/PowerPC. 4.104.114.84.95
(edit) @8358faa   06/13/00 22:25:28 Joel Sherrill Prototypes for cache manager support functions now agree. 4.104.114.84.95
(edit) @cf1f72e   06/13/00 21:53:38 Joel Sherrill Moved i386 and m68k cache management code to libcpu. Everything now … 4.104.114.84.95
(edit) @f0b11d63   06/13/00 21:52:13 Joel Sherrill Added .cvsignore. 4.104.114.84.95
(edit) @310a2ec   06/13/00 21:45:42 Joel Sherrill Added .cvsignore. 4.104.114.84.95
(edit) @3ab61f0   06/12/00 21:34:51 Joel Sherrill Patch from John Cotton <john.cotton@…>, Charles-Antoine Gauthier … 4.104.114.84.95
(edit) @edc61d4   06/12/00 20:27:50 Joel Sherrill Fixed so hppa1.1 compiles with only problems in simhppa BSP. 4.104.114.84.95
(edit) @8ef3818   06/12/00 19:57:02 Joel Sherrill Patch from John Cotton <john.cotton@…>, Charles-Antoine Gauthier … 4.104.114.84.95
(edit) @df49c60   06/12/00 15:00:15 Joel Sherrill Merged from 4.5.0-beta3a 4.104.114.84.95
(edit) @bf85b19   04/13/00 14:37:14 Joel Sherrill Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @70810dc   02/08/00 22:33:25 Joel Sherrill Patches rtems-rc-20000204-0.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @847dbbe   02/01/00 13:41:54 Joel Sherrill Patches rtems-rc-20000118-5.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @4e36a2f   01/31/00 15:27:02 Joel Sherrill Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff from … 4.104.114.84.95
(edit) @4c46630   01/31/00 15:15:10 Joel Sherrill Patch rtems-rc-20000118-1.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @a1f89b4   01/26/00 14:22:34 Joel Sherrill No longer incorrectly references mips. 4.104.114.84.95
(edit) @21677c0e   01/26/00 14:20:08 Joel Sherrill Patch rtems-rc-20000118-0.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @0dd1d44   01/11/00 17:34:20 Joel Sherrill Removed old hack of using Configuration Table entry … 4.104.114.84.95
(edit) @86c9eb0   01/11/00 14:57:41 Joel Sherrill Bug fix from Wayne Bullaughey <wayneb@…> to use the … 4.104.114.84.95
(edit) @0f59d63f   01/10/00 21:38:43 Joel Sherrill Now automake generated. 4.104.114.84.95
(edit) @710f76a   01/10/00 21:37:57 Joel Sherrill Added mpc6xx/timer/Makefile. 4.104.114.84.95
(edit) @f983d57   01/10/00 18:16:59 Joel Sherrill Patch rtems-rc-20000104-14.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @bc2f04f   01/10/00 14:50:45 Joel Sherrill Patch rtems-rc-20000104-13.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @35d9acb3   01/07/00 18:52:14 Joel Sherrill Patch from John M. Mills <jmills@…> to correct the baseline … 4.104.114.84.95
(edit) @0ff37e68   01/07/00 14:47:02 Joel Sherrill Patch rtems-rc-20000104-0.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @0312d81f   01/05/00 23:01:05 Joel Sherrill Fixed comment thanks to John M. Mills <jmills@…>. 4.104.114.84.95
(edit) @205d5645   01/03/00 16:44:04 Joel Sherrill Patch from John Mills <jmills@…> to correct some cut and paste … 4.104.114.84.95
(edit) @32f19fb3   01/03/00 14:38:47 Joel Sherrill Share align_h.S from ppc403. VPATH was not picking it up. Discovered … 4.104.114.84.95
(edit) @95273a6   01/03/00 14:06:42 Joel Sherrill Combination of coverhd.h cleanup and MVME23xx/MCP750 patch from Eric … 4.104.114.84.95
(edit) @ed46b47   12/21/99 20:29:40 Joel Sherrill Moved PPC_Set_decrementer() and PPC_Get_timebase_register() to … 4.104.114.84.95
(edit) @5d807b5   12/21/99 17:06:31 Joel Sherrill New files. 4.104.114.84.95
(edit) @400c552   12/21/99 16:20:38 Joel Sherrill Removing Makefile.in and adding Makefile.am. These were missed in … 4.104.114.84.95
(edit) @35d7b15   12/21/99 14:41:43 Joel Sherrill Patch rtems-rc-19991203-7.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @0fe48346   12/21/99 14:34:30 Joel Sherrill Patch rtems-rc-19991203-7.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @8b91282   12/21/99 14:27:52 Joel Sherrill Patch rtems-rc-19991203-5.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @c629812   12/13/99 22:10:45 Joel Sherrill Removed warnings. 4.104.114.84.95
(edit) @da8ae79b   12/13/99 21:21:31 Joel Sherrill Warning removal patch from Philip A. Prindeville <philipp@…>. 4.104.114.84.95
(edit) @1c98d28   12/13/99 20:35:09 Joel Sherrill Patch rtems-19991203.sh2.diff from John M. Mills <jmills@…> … 4.104.114.84.95
(edit) @f9669ce5   12/13/99 20:06:27 Joel Sherrill Patch from Silverio Diquigiovanni <silverio.di@…> to correct TPC … 4.104.114.84.95
(edit) @eb17041   12/03/99 14:01:11 Joel Sherrill Removed warnings. 4.104.114.84.95
(edit) @43283456   12/02/99 17:45:14 Joel Sherrill Patch rtems-rc-19991123-rc-2.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @3a96054   12/02/99 14:58:38 Joel Sherrill Merged of mcp750 and mvme2307 BSP by Eric Valette … 4.104.114.84.95
(edit) @acc25ee   12/02/99 14:31:19 Joel Sherrill Merged of mcp750 and mvme2307 BSP by Eric Valette … 4.104.114.84.95
(edit) @e4ab88f   12/02/99 14:00:01 Joel Sherrill Merged of mcp750 and mvme2307 BSP by Eric Valette … 4.104.114.84.95
(edit) @3772e2c   11/23/99 14:54:42 Joel Sherrill * empty log message * 4.104.114.84.95
(edit) @7e642ba   11/22/99 19:27:13 Joel Sherrill Patch rtems-rc-19991117-9.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @875fbdbb   11/22/99 13:48:10 Joel Sherrill Added files missed by previous merger of SH-2 port. 4.104.114.84.95
(edit) @b22a19e   11/22/99 13:46:50 Joel Sherrill Adding files not added as part of merger of SH2 port. 4.104.114.84.95
(edit) @9608320   11/22/99 13:41:11 Joel Sherrill Patch rtems-rc-19991117-4.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @4a238002   11/18/99 21:22:58 Joel Sherrill Patch from "John M. Mills" <jmills@…> with subsequent cleanup … 4.104.114.84.95
(edit) @08311cc3   11/17/99 17:51:34 Joel Sherrill Updated copyright notice. 4.104.114.84.95
(edit) @d102810e   11/11/99 02:39:12 Joel Sherrill Updated. 4.104.114.84.95
(edit) @53b1847   11/09/99 13:40:57 Joel Sherrill Removed reaching "up and over" to install BSP header files. 4.104.114.84.95
(edit) @84bf329   11/09/99 03:37:40 Joel Sherrill Added #define to make this file exactly like its siblings in mpc821 … 4.104.114.84.95
(edit) @78facc4   11/09/99 02:50:26 Joel Sherrill Removed "up and over" into libbsp/.../include. 4.104.114.84.95
(edit) @9af31a6   11/09/99 02:32:37 Joel Sherrill Moved include files to hppa1.1 subdirectory and put their sources in … 4.104.114.84.95
(edit) @bb11d7e   11/09/99 02:31:37 Joel Sherrill Removed runway directory and moved contents to include. 4.104.114.84.95
(edit) @bf2cf8e6   11/05/99 21:20:30 Joel Sherrill New file. Added as part of adding a formal API to this object. 4.104.114.84.95
(edit) @0fab6dde   11/05/99 17:49:56 Joel Sherrill Patch from Eric Valette <valette@…> so this will build … 4.104.114.84.95
(edit) @458bd34   11/05/99 16:44:02 Joel Sherrill This is another pass at making sure that nothing outside the BSP … 4.104.114.84.95
(edit) @f817b02   11/04/99 18:05:09 Joel Sherrill The files in libcpu should not be directly dependent on any BSP. In … 4.104.114.84.95
(edit) @dee8a51   11/01/99 21:34:04 Joel Sherrill Corrected wildcard to pickup CPU model dependent library pieces. 4.104.114.84.95
(edit) @7046cdd   10/28/99 16:01:41 Joel Sherrill Patch rtems-rc-19991011-3.diff from Ralf Corsepius. 4.104.114.84.95
(edit) @1f350ef9   10/06/99 20:54:06 Joel Sherrill Removed aclocal.m4 generated from aclocal macros 4.104.114.84.95
(edit) @54eccb1a   10/06/99 20:52:34 Joel Sherrill Removed configure generated from configure.in 4.104.114.84.95
(edit) @2529305   10/06/99 18:07:56 Joel Sherrill Corrected build order so it was not as dependent on the mpc750 check. 4.104.114.84.95
(edit) @e01c706b   10/06/99 13:41:30 Joel Sherrill Fixed spelling error (FAMILLY --> FAMILY). 4.104.114.84.95
(edit) @4075af6f   10/05/99 13:49:54 Joel Sherrill Regenerated. 4.104.114.84.95
(edit) @b62a92c   10/04/99 18:20:14 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: The patch below … 4.104.114.84.95
(edit) @4451bad   10/04/99 16:28:34 Joel Sherrill Removed. 4.104.114.84.95
(edit) @473b4e5   10/04/99 13:30:15 Joel Sherrill Regenerated. 4.104.114.84.95
(edit) @a24c280   09/09/99 21:22:36 Joel Sherrill Applied patch rtems-rc-19990820-6.diff.gz from Ralf Corsepius … 4.104.114.84.95
(edit) @e1d8abb   09/07/99 13:45:03 Joel Sherrill Applied patch rtems-rc-19990820-6.diff.gz from Ralf Corsepius … 4.104.114.84.95
(edit) @7c2243e3   08/30/99 14:28:39 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: The patch … 4.104.114.84.95
(edit) @96284fd8   08/19/99 21:47:51 Joel Sherrill Support for MPC505 from Sergei Organov <osv@…>. His patch was … 4.104.114.84.95
(edit) @1896a650   07/30/99 17:52:50 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: The main topic … 4.104.114.84.95
(edit) @aa9eb940   07/30/99 17:28:11 Joel Sherrill Fixed typos. 4.104.114.84.95
(edit) @54f440d   07/26/99 22:11:02 Joel Sherrill Patch from Charles-Antoine Gauthier <charles.gauthier@…>. to … 4.104.114.84.95
(edit) @08b5f55   07/26/99 20:31:49 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: A bug in … 4.104.114.84.95
(edit) @6693a68   07/26/99 20:00:37 Joel Sherrill This is part of a major patch from Ralf Corsepius … 4.104.114.84.95
(edit) @1f42090   07/23/99 19:33:28 Joel Sherrill Patch to ease building MCP750 BSP. 4.104.114.84.95
(edit) @f421132   07/09/99 18:23:59 Joel Sherrill New files from Jiri Gaisler <jgais@…>. 4.104.114.84.95
(edit) @b73e57b   07/09/99 17:08:48 Joel Sherrill Patch from Jiri Gaisler <jgais@…>: + interrupt … 4.104.114.84.95
(edit) @fcee56c0   07/01/99 23:39:13 Joel Sherrill Patch from Eric Valette <valette@…> to clean up the … 4.104.114.84.95
(edit) @78b78e2   07/01/99 22:43:09 Joel Sherrill Another attempt at getting everything to build with the new powerpc libcpu. 4.104.114.84.95
(edit) @e7792b25   07/01/99 22:07:32 Joel Sherrill Cleaned up to behave properly -- does not make a directory in the … 4.104.114.84.95
(edit) @6be1238   07/01/99 22:06:49 Joel Sherrill Now preinstalls header files. 4.104.114.84.95
(edit) @9519bf4   07/01/99 22:05:36 Joel Sherrill Removed mkdir of libcpu. This should have been at the top of the tree. 4.104.114.84.95
