@339646e
01/09/13 11:50:55 |
Sebastian Huber |
bsps/powerpc: Fix compiler warnings
4.115
@370c2c80
01/04/13 12:06:51 |
Sebastian Huber |
arm: Rename arm_exc_interrupt()
Rename arm_exc_interrupt() to …
4.115
@9b2e7143
01/04/13 12:05:28 |
Sebastian Huber |
arm: Move prototypes to new file
Move bsp_interrupt_dispatch() and …
4.115
@3af7e23e
12/21/12 13:11:36 |
Sebastian Huber |
bsp/gen83xx: Add GPR_1 to register map
4.115
@a640b204
12/21/12 08:26:27 |
Sebastian Huber |
bsp/gen83xx: Fix RCWLR_CEVCO defines
4.115
@191929cd
12/06/12 16:31:48 |
Sebastian Huber |
bsps/powerpc: Install missing <bsp/vectors.h>
4.115
@3ce66aa
11/19/12 08:02:12 |
Sebastian Huber |
bsp/mpc55xx: Set PPC_EXC_CONFIG_USE_FIXED_HANDLER
4.115
@67338ed
11/15/12 15:57:02 |
Sebastian Huber |
bsp/mpc55xx: Add mpc55xx_wait_for_interrupt()
Use …
4.115
@bd75e589
11/13/12 11:20:59 |
Sebastian Huber |
bsp/mpc55xx: Fix INTC initialization
4.115
@353f0fa
11/22/12 15:21:32 |
Sebastian Huber |
bsp/mpc55xx: Add union tags
4.115
@f665f13
11/19/12 07:37:04 |
Sebastian Huber |
bsps/powerpc: Add PPC_EXC_CONFIG_BOOKE_ONLY
In combination with the …
4.115
@4bd4c9e
11/23/12 08:32:52 |
Sebastian Huber |
bsps/powerpc: Add PPC_EXC_CONFIG_USE_FIXED_HANDLER
In case a BSP …
4.115
@4263155
11/23/12 08:27:20 |
Sebastian Huber |
bsps/powerpc: Declare ppc_exc_handler_table
4.115
@809b726a
12/01/12 00:12:59 |
Ric Claus |
Print MCSR and ESR.
The Machine Check and Exception Syndrome …
4.115
@655bd39
11/30/12 23:58:32 |
Ric Claus |
Virtex5 BSP: Various updates and improvements.
This BSP now uses the …
4.115
@84b19b5
11/30/12 23:47:34 |
Ric Claus |
Restored to pre PPC440 changes.
This file was originally modified by …
4.115
@d1c89524
11/13/12 17:09:19 |
ralf.kirchner |
bsps/powerpc: Do not use GCC extern inline
4.115
@815994f
11/25/12 16:48:11 |
Sebastian Huber |
score: Add CPU_Exception_frame
Add CPU port type CPU_Exception_frame …
4.115
@d2202ac
11/26/12 17:04:12 |
Sebastian Huber |
powerpc: Add CPU_Exception_frame
The powerpc port uses now a unified …
4.115
@f0e3cc0
11/26/12 16:52:01 |
Sebastian Huber |
bsps/powerpc: Delete unused EXC_DAR field
The Data Access Register …
4.115
@7b02f3c
11/26/12 16:45:28 |
Sebastian Huber |
bsps/powerpc: Delete unused EXC_MSR field
The MSR of the interrupted …
4.115
@7e32b62
11/17/12 11:31:22 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_POWERPC_EXCEPTION
Add …
4.115
@b1e8a58
11/14/12 08:57:55 |
Sebastian Huber |
bsps/powerpc: Exception initialization error is fatal
4.115
@b31a960
11/13/12 16:53:43 |
Sebastian Huber |
score: Add INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR
Use …
4.115
@00dae186
11/13/12 15:39:26 |
Sebastian Huber |
powerpc: Delete _CPU_Install_interrupt_stack()
This function is only …
4.115
@5e86086
11/06/12 09:34:42 |
Sebastian Huber |
sapi: Use rtems_config*_get_microseconds_per_tick
4.115
@26e90fb1
10/30/12 16:42:17 |
Sebastian Huber |
libnetworking: Use system events
Add reserved system events …
4.115
@02687e22
10/18/12 13:22:58 |
Ralf Corsepius |
Remove unused vars 'rxdmaBase', txdmaBase.
4.115
@37a532b
10/18/12 10:40:54 |
Ralf Corsepius |
Remove stray blanks.
4.115
@23242172
10/18/12 13:22:13 |
Ralf Corsepius |
Add clock/rtc.h to rtc_rel_SOURCES.
4.115
@0e27119
10/11/12 20:52:18 |
Joel Sherrill |
Use proper 3 line form of license text
4.115
@245cad5
10/01/12 12:28:32 |
Sebastian Huber |
bsp/mpc55xx: Fix bsp_idle_thread()
4.115
@94102775
10/01/12 13:02:57 |
Sebastian Huber |
bsp/mpc55xx: Add and use MPC55XX_CHIP_FAMILY
4.115
@d9af2ed4
08/20/12 08:15:20 |
thomas.doerfler |
bsp/gen83xx: Add br_uid BSP variant
4.115
@69b346b
07/25/12 11:48:20 |
Sebastian Huber |
bsp/mpc55xx: eQADC register changes
4.115
@208f479
07/19/12 07:05:46 |
Sebastian Huber |
bsp/mpc55xx: New EBI settings for MPC5674F boards
4.115
@1c554014
07/19/12 14:14:53 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@bb2b825
07/19/12 13:47:55 |
Ralf Corsepius |
Require automake-1.12.2.
4.115
@0f77281
07/19/12 13:44:32 |
Ralf Corsepius |
Require autoconf-2.69.
4.115
@2d43f2d
03/29/12 08:58:37 |
christian.mauderer |
bsp/mpc55xx: Support re-initialization of eDMA
4.115
@c44b517
07/17/12 13:00:47 |
Sebastian Huber |
bsp/mpc55xx: Add union name
4.115
@1869bb7
05/18/12 13:47:23 |
Sebastian Huber |
powerpc: Simplify context switch
PowerPC cores with the SPE (Signal …
4.115
@721fe34
05/31/12 20:34:36 |
Joel Sherrill |
Fix C files which had two semi-colons at EOL
4.115
@e21c287c
05/21/12 12:56:31 |
Sebastian Huber |
powerpc/t32mppc: New BSP
4.115
@65c6425
05/03/12 17:24:46 |
Joel Sherrill |
Remove CVS Id Strings (manual edits after script)
These modifications …
4.115
@9b4422a2
05/03/12 15:09:24 |
Joel Sherrill |
Remove All CVS Id Strings Possible Using a Script
Script does what is …
4.115
@33a105fb
05/07/12 16:08:48 |
Joel Sherrill |
Revert: Remove CVS Ids
See …
4.115
@91d2e18
05/04/12 06:53:58 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@c30045f
05/04/12 06:51:09 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@f7d50ed8
05/04/12 06:51:09 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@e30165d
05/04/12 06:51:09 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@1a749270
05/04/12 06:51:09 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@3ef7c91f
05/04/12 06:51:09 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@f901b51
05/04/12 06:51:08 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@1559075
05/04/12 06:51:08 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@8e25311
05/04/12 06:51:08 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@8f739916
05/04/12 06:51:08 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@c559cba
05/04/12 06:51:08 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@d31c6d3
05/04/12 06:51:08 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@78dea6ce
05/03/12 18:23:07 |
Joel Sherrill |
libcpu misc m68k and sh - Correct formatting and remove weird Id strings
4.115
@cfaa366
05/03/12 17:55:58 |
Joel Sherrill |
General - Remove extraneous blank line in license message
Many files …
4.115
@358522d
05/03/12 17:46:21 |
Joel Sherrill |
Libcpu misc files - Remove execute permission on source files.
4.115
@b8b2f19
05/02/12 19:16:37 |
Joel Sherrill |
libcpu/m68k/mcf532x - Remove bad $Id$ and clean up file header
4.115
@1a3cbfba
04/19/12 18:16:33 |
Joel Sherrill |
s3c24xx shared: Clock driver clean up and ISR Handler Prototype Correction.
4.115
@abb52ce
04/19/12 18:16:20 |
Joel Sherrill |
pxa255 shared: Clock driver clean up and ISR Handler Prototype Correction.
4.115
@bb9cf58d
04/19/12 18:16:09 |
Joel Sherrill |
mc9328mxl shared: Clock driver clean up and ISR Handler Prototype …
4.115
@029ced28
04/19/12 18:15:49 |
Joel Sherrill |
lpc22xx shared: Clock driver clean up and ISR Handler Prototype Correction.
4.115
@1401076
04/19/12 18:15:34 |
Joel Sherrill |
at91rm9200 shared: Clock driver clean up and ISR Handler Prototype …
4.115
@0c0181d
04/04/12 13:39:46 |
Jennifer Averett |
PR 1993 - Convert MIPS to PIC IRQ model
4.115
@eb6362dc
04/03/12 15:11:10 |
Sebastian Huber |
bsp/mpc55xx: Add and use chip features
Add defines MPC55XX_HAS_SIU …
4.115
@16a8616
03/30/12 15:03:43 |
Ric Claus |
Add Virtex4 and Virtex5 BSPs
This commit covers at least PR2020, …
4.115
@0f31fddc
03/24/12 21:01:08 |
Sebastian Huber |
bsps: Add shared default IRQ handler
4.115
@80d01b3c
02/08/12 14:57:03 |
Daniel Hellstrom |
SPARC: added libcpu lowlevel access and byteorder routines/definitions …
4.115
@67baf60
03/14/12 17:06:13 |
Gedare Bloom |
PR2041: sparc64: vector number not included in CPU_Interrupt_frame
4.115
@61250b4
02/01/12 16:59:44 |
Joel Sherrill |
Remove all .cvsignore files.
4.115
@a762dc2
01/23/12 10:19:22 |
Sebastian Huber |
Support for MPC5643L.
Rework of the start sequence to reduce the …
4.115
@ac4f31c8
12/10/11 04:07:46 |
Ralf Corsepius |
2011-12-10 Ralf Corsépius <ralf.corsepius@…>
4.115
@de5868fe
12/10/11 04:03:50 |
Ralf Corsepius |
PR 1986/libcpu …
4.115
@f865fc5d
12/01/11 08:20:03 |
Ralf Corsepius |
2011-12-01 Ralf Corsépius <ralf.corsepius@…>
4.115
@9521992
12/01/11 08:06:06 |
Ralf Corsepius |
4.115
@f0e748c
11/10/11 08:44:37 |
Sebastian Huber |
2011-11-10 Sebastian Huber <sebastian.huber@…>
PR …
4.115
@edb1dd83
11/08/11 10:05:50 |
Sebastian Huber |
2011-11-08 Sebastian Huber <sebastian.huber@…>
4.115
@65f2aecc
11/06/11 16:55:33 |
Gedare Bloom |
2011-11-06 Gedare Bloom <gedare@…>
* ChangeLog?: Fix …
4.115
@05e75a4b
11/06/11 16:48:36 |
Gedare Bloom |
2011-11-06 gedare@…
* shared/score/interrupt.S: Pass ISR …
4.115
@b01abd58
10/23/11 06:40:09 |
Ralf Corsepius |
2011-10-23 Ralf Corsépius <ralf.corsepius@…>
* page.c: …
4.115
@11f7aab
10/18/11 18:39:05 |
Jennifer.Averett |
2011-10-18 Jennifer Averett <Jennifer.Averett@…>
PR …
4.115
@7431fdc
10/18/11 18:37:32 |
Jennifer.Averett |
PR …
4.115
@fcec9c4
10/10/11 08:37:07 |
Sebastian Huber |
2011-10-10 Sebastian Huber <sebastian.huber@…>
4.115
@e2d3e37
10/10/11 08:22:27 |
Sebastian Huber |
PR …
4.115
@968ff5bb
10/07/11 09:58:39 |
Ralf Corsepius |
2011-10-07 Ralf Corsépius <ralf.corsepius@…>
4.115
@7eb31ec9
10/07/11 09:55:46 |
Ralf Corsepius |
4.115
@c317873
10/07/11 09:18:24 |
Ralf Corsepius |
4.115
@c6d8f997
10/07/11 09:15:21 |
Ralf Corsepius |
4.115
@4960b29
10/07/11 08:41:45 |
Ralf Corsepius |
PR 1928/bsps: …
4.115
@c2bc9ef
09/26/11 10:03:30 |
Sebastian Huber |
2011-09-27 Sebastian Huber <sebastian.huber@…>
4.115
@dfdf7961
09/19/11 07:01:02 |
Sebastian Huber |
2011-09-19 Andrei Mozzhuhin <nopscmn@…>
PR 1915/libcpu
4.115
@df8204f
09/01/11 08:18:56 |
Sebastian Huber |
2011-09-01 Sebastian Huber <sebastian.huber@…>
4.115
@3ac2bf5e
09/01/11 08:15:10 |
Sebastian Huber |
4.115
@7a84689f
09/01/11 08:09:28 |
Sebastian Huber |
4.115
@97fa2f1b
08/31/11 15:50:30 |
Sebastian Huber |
2011-08-31 Sebastian Huber <sebastian.huber@…>
4.115
