# # ChangeLog for c/src/lib/libcpu in rtems # # Generated by Trac 1.2.1.dev0 # 04/20/24 00:21:35 Mon, 18 Sep 2017 06:22:38 GMT Sebastian Huber [f3b29236] * c/src/lib/libbsp/arm/beagle/clock.c (modified) * c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c (modified) * c/src/lib/libbsp/arm/raspberrypi/clock/clockdrv.c (modified) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/arm-generic-timer-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/lpc/clock/lpc-clock-config.c (modified) * c/src/lib/libbsp/arm/tms570/clock/clock.c (modified) * c/src/lib/libbsp/i386/pc386/clock/ckinit.c (modified) * c/src/lib/libbsp/lm32/shared/clock/ckinit.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/av5282/clock/clock.c (modified) * c/src/lib/libbsp/m68k/gen68360/clock/clock.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf52235/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5235/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5329/clock/clock.c (modified) * c/src/lib/libbsp/m68k/uC5282/clock/clock.c (modified) * c/src/lib/libbsp/mips/csb350/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/jmr3904/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/rbtx4925/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/rbtx4938/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/shared/clock/clockdrv.c (modified) * c/src/lib/libbsp/nios2/nios2_iss/clock/clock.c (modified) * c/src/lib/libbsp/or1k/generic_or1k/clock/clockdrv.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/clock/clock-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/clock/clock-config.c (modified) * c/src/lib/libbsp/shared/clock_driver_simidle.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon2/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c (modified) * c/src/lib/libbsp/sparc64/shared/clock/ckinit.c (modified) * c/src/lib/libcpu/arm/at91rm9200/clock/clock.c (modified) * c/src/lib/libcpu/arm/lpc22xx/clock/clockdrv.c (modified) * c/src/lib/libcpu/arm/mc9328mxl/clock/clockdrv.c (modified) * c/src/lib/libcpu/arm/pxa255/clock/clock.c (modified) * c/src/lib/libcpu/arm/s3c24xx/clock/clockdrv.c (modified) bsps: Clock_driver_support_install_isr() Remove old ISR parameter ... Fri, 08 Sep 2017 08:38:46 GMT Sebastian Huber [1bc0ad2] * c/src/lib/libbsp/arm/altera-cyclone-v/console/console-config.c (modified) * c/src/lib/libbsp/arm/atsam/console/debug-console.c (modified) * c/src/lib/libbsp/arm/beagle/console/console-config.c (modified) * c/src/lib/libbsp/arm/csb336/console/uart.c (modified) * c/src/lib/libbsp/arm/imx/console/console-config.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/console/console-config.c (modified) * c/src/lib/libbsp/arm/raspberrypi/console/console-config.c (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/console/console-config.c (modified) * c/src/lib/libbsp/arm/rtl22xx/console/uart.c (modified) * c/src/lib/libbsp/arm/shared/comm/uart.c (modified) * c/src/lib/libbsp/arm/smdk2410/console/uart.c (modified) * c/src/lib/libbsp/arm/stm32f4/console/console-config.c (modified) * c/src/lib/libbsp/arm/tms570/console/printk-support.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/console/debug-console.c (modified) * c/src/lib/libbsp/i386/pc386/console/printk_support.c (modified) * c/src/lib/libbsp/i386/shared/comm/uart.c (modified) * c/src/lib/libbsp/m68k/av5282/console/console.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/console/debugio.c (modified) * c/src/lib/libbsp/m68k/mcf5235/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5329/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme167/console/console.c (modified) * c/src/lib/libbsp/m68k/uC5282/console/console.c (modified) * c/src/lib/libbsp/mips/csb350/console/console-io.c (modified) * c/src/lib/libbsp/or1k/generic_or1k/console/console-config.c (modified) * c/src/lib/libbsp/powerpc/gen5200/console/console.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/console/console-config.c (modified) * c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-generic.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/console/console.c (modified) * c/src/lib/libbsp/powerpc/qoriq/console/console-config.c (modified) * c/src/lib/libbsp/powerpc/shared/console/polled_io.c (modified) * c/src/lib/libbsp/powerpc/shared/console/uart.c (modified) * c/src/lib/libbsp/powerpc/t32mppc/console/console.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/console/console.c (modified) * c/src/lib/libbsp/powerpc/virtex/console/consolelite.c (modified) * c/src/lib/libbsp/powerpc/virtex4/startup/dummy_console.c (modified) * c/src/lib/libbsp/powerpc/virtex5/startup/dummy_console.c (modified) * c/src/lib/libbsp/shared/console-output-char.c (modified) * c/src/lib/libbsp/shared/src/uart-output-char.c (modified) * c/src/lib/libcpu/arm/at91rm9200/dbgu/dbgu.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/esci/esci.c (modified) * cpukit/include/rtems/bspIo.h (modified) * cpukit/libcsupport/src/putk.c (modified) * cpukit/libmisc/serdbg/termios_printk.c (modified) Simplify and unify BSP_output_char The BSP_output_char should ... Fri, 25 Aug 2017 08:58:58 GMT Sebastian Huber [b2ed712] * c/src/lib/libbsp/arm/altera-cyclone-v/rtc/rtc.c (modified) * c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c (modified) * c/src/lib/libbsp/arm/lpc176x/can/can.c (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/nand-mlc-read-blocks.c (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/nand-mlc-write-blocks.c (modified) * c/src/lib/libbsp/arm/raspberrypi/console/console_select.c (modified) * c/src/lib/libbsp/arm/raspberrypi/misc/vc_defines.h (modified) * c/src/lib/libbsp/arm/raspberrypi/startup/cmdline.c (modified) * c/src/lib/libbsp/arm/shared/arm-pl111-fb.c (modified) * c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c (modified) * c/src/lib/libbsp/arm/tms570/console/printk-support.c (modified) * c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_framebuffer/framebuffer.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_versions/versions.c (modified) * c/src/lib/libbsp/lm32/shared/tsmac/tsmac.c (modified) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * c/src/lib/libbsp/sparc/shared/amba/ahbstat.c (modified) * c/src/lib/libbsp/sparc/shared/analog/gradcdac.c (modified) * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus_leon2.c (modified) * c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c (modified) * c/src/lib/libbsp/sparc/shared/iommu/griommu.c (modified) * c/src/lib/libbsp/sparc/shared/l2c/l2c.c (modified) * c/src/lib/libbsp/sparc/shared/pci/grpci2dma.c (modified) * c/src/lib/libbsp/sparc/shared/scrub/memscrub.c (modified) * c/src/lib/libbsp/sparc/shared/time/grctm.c (modified) * c/src/lib/libbsp/sparc/shared/time/spwcuc.c (modified) * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) * c/src/lib/libbsp/sparc64/shared/helenos/boot/sparc64/loader/main.c (modified) * c/src/lib/libcpu/bfin/bf52x/interrupt/interrupt.c (modified) * c/src/lib/libcpu/bfin/interrupt/interrupt.c (modified) * cpukit/dev/i2c/ti-lm25066a.c (modified) * cpukit/include/rtems/printer.h (modified) * cpukit/libcsupport/src/cfmakesane.c (modified) * cpukit/libcsupport/src/chroot.c (modified) * cpukit/libcsupport/src/fchmod.c (modified) * cpukit/libcsupport/src/fchown.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libdl/rtl-allocator.c (modified) * cpukit/libdl/rtl-error.c (modified) * cpukit/libdl/rtl-find-file.c (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-sym.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libfs/src/imfs/imfs_linfile.c (modified) * cpukit/libmisc/dummy/default-configuration.c (modified) * cpukit/libmisc/redirector/stdio-redirect.c (modified) * cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c (modified) * cpukit/libmisc/shell/main_md5.c (modified) * cpukit/libmisc/shell/main_rtrace.c (modified) * cpukit/libmisc/untar/untar_tgz.c (modified) * cpukit/libpci/pci_cfg_print_code.c (modified) * cpukit/librpc/src/rpc/get_myaddress.c (modified) * cpukit/posix/src/mmap.c (modified) * cpukit/posix/src/shmheap.c (modified) * cpukit/posix/src/shmwkspace.c (modified) * cpukit/score/src/threadq.c (modified) Include missing Update #2133. Fri, 11 Aug 2017 08:44:04 GMT Sebastian Huber [c693a3a] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_fatal.S (modified) * cpukit/score/cpu/powerpc/rtems/asm.h (modified) powerpc: PPC64_NOP_FOR_LINKER_TOC_POINTER_RESTORE In 64-bit mode, ... Mon, 31 Jul 2017 13:10:33 GMT Sebastian Huber [c6994af] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) bsp/qoriq: Use LA to load an address Add 64-bit support for LA. ... Tue, 01 Aug 2017 09:54:25 GMT Sebastian Huber [d50124d] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) bsps/powerpc: Rename ppc_exc_wrap_async_normal_end Rename ... Mon, 31 Jul 2017 13:25:12 GMT Sebastian Huber [50382788] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/t32mppc/start/start.S (modified) * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) bsps/powerpc: Add 64-bit SET_SELF_CPU_CONTROL Update #3082. Tue, 01 Aug 2017 08:57:46 GMT Sebastian Huber [a6f84b27] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_fatal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) * cpukit/score/cpu/powerpc/cpu.c (modified) * cpukit/score/cpu/powerpc/ppc-context-validate.S (modified) * cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/powerpc/rtems/score/powerpc.h (modified) powerpc: Add 64-bit context/interrupt support Update #3082. Thu, 10 Aug 2017 11:09:22 GMT Sebastian Huber [7837728b] * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * c/src/lib/libcpu/powerpc/rtems/powerpc/powerpc.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: 64-bit _CPU_Context_Initialize() support Update #3082. Fri, 04 Aug 2017 11:51:42 GMT Sebastian Huber [ef04443] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Add ARMv7-AR Generic Timer support Update #3090. Thu, 03 Aug 2017 12:48:04 GMT Sebastian Huber [30be024a] * c/src/lib/libbsp/lm32/shared/clock/ckinit.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mcf52235/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5329/clock/clock.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libcpu/arm/at91rm9200/clock/clock.c (modified) * c/src/lib/libcpu/arm/pxa255/clock/clock.c (modified) Optional Clock_driver_support_shutdown_hardware() Make ... Tue, 01 Aug 2017 09:43:57 GMT Sebastian Huber [a8694035] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/exc-vector-base.S (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/t32mppc/start/start.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) bsps/powerpc: Add PPC_EXC_INTERRUPT_FRAME_SIZE Use a specific ... Tue, 01 Aug 2017 09:38:32 GMT Sebastian Huber [23cb9af] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/exc-vector-base.S (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/t32mppc/start/start.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) bsps/powerpc: Rename ppc_exc_wrap_async_normal Rename ... Mon, 31 Jul 2017 11:39:34 GMT Sebastian Huber [65ee42c] * c/src/lib/libbsp/powerpc/qoriq/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspsmp.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-config.c (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_fatal.S (added) * c/src/lib/libcpu/powerpc/preinstall.am (modified) bsp/qoriq: Simplify fatal exceptions Avoid use of small-data area, ... Mon, 31 Jul 2017 11:35:21 GMT Sebastian Huber [2d0a805] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c (modified) bsps/powerpc: Fix format specifiers Mon, 17 Jul 2017 05:30:46 GMT Sebastian Huber [146adb1] * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libcpu/sparc/syscall/syscall.S (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/cpu_asm.S (deleted) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) * testsuites/sptests/spfatal30/init.c (modified) * testsuites/sptests/spfatal31/init.c (modified) * testsuites/sptests/spsize/size.c (modified) sparc: Add lazy floating point switch The SPARC ABI is a bit ... Wed, 19 Jul 2017 13:54:16 GMT Sebastian Huber [7ed8ad0] * c/src/lib/libcpu/sparc/cache/cache_.h (modified) bsps/sparc: Fix cache support Fix infinite loop in ... Thu, 13 Jul 2017 07:26:50 GMT Daniel Cederman [2f8704b6] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libcpu/sparc/access/access.S (modified) * c/src/lib/libcpu/sparc/reg_win/window.S (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) sparc: Add assembly workaround for LEON3FT B2BST errata This patch ... Mon, 19 Jun 2017 12:09:28 GMT Sebastian Huber [c6810c8] * c/src/lib/libbsp/arm/beagle/irq.c (modified) * c/src/lib/libbsp/arm/edb7312/irq/irq.c (modified) * c/src/lib/libbsp/arm/gdbarmsim/irq/irq.c (modified) * c/src/lib/libbsp/arm/lpc24xx/irq/irq.c (modified) * c/src/lib/libbsp/arm/lpc32xx/irq/irq.c (modified) * c/src/lib/libbsp/arm/raspberrypi/irq/irq.c (modified) * c/src/lib/libbsp/arm/shared/arm-gic-irq.c (modified) * c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c (modified) * c/src/lib/libbsp/arm/tms570/irq/irq.c (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c (modified) * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) * c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c (modified) * c/src/lib/libbsp/i386/shared/irq/irq.c (modified) * c/src/lib/libbsp/lm32/shared/irq/irq.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c (modified) * c/src/lib/libbsp/mips/shared/irq/irq.c (modified) * c/src/lib/libbsp/or1k/generic_or1k/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/gen5200/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/psim/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/qoriq/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/t32mppc/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c (modified) * c/src/lib/libbsp/shared/include/irq-generic.h (modified) * c/src/lib/libbsp/shared/src/irq-generic.c (modified) * c/src/lib/libbsp/shared/src/irq-server.c (modified) * c/src/lib/libbsp/sparc/shared/irq/irq-shared.c (modified) * c/src/lib/libcpu/arm/at91rm9200/irq/irq.c (modified) * c/src/lib/libcpu/arm/lpc22xx/irq/irq.c (modified) * c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c (modified) * c/src/lib/libcpu/arm/pxa255/irq/irq.c (modified) * c/src/lib/libcpu/arm/s3c24xx/irq/irq.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c (modified) bsps: Improve interrupt vector enable/disable API Change ... Wed, 14 Jun 2017 14:53:44 GMT Sichen Zhao <1473996754@…> [8f550d2] * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c (added) * c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h (modified) * c/src/lib/libbsp/arm/beagle/include/i2c.h (modified) * c/src/lib/libcpu/arm/shared/include/am335x.h (modified) Add the i2c driver for Beaglebone Black Update ticket #2891 and my ... Fri, 09 Jun 2017 05:25:02 GMT Sebastian Huber [32b4a0c] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) Simplify TLS support in context switch There is no need to save the ... Sun, 07 May 2017 21:08:17 GMT Phong Pham [848007c] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_categories.c (modified) * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.c (modified) * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.h (modified) Add support for IBM PowerPC 750 chip. Closes #3015. Sun, 14 May 2017 01:52:52 GMT Chris Johns [a748603] * c/Makefile.am (modified) * c/src/Makefile.am (modified) * c/src/automake/subdirs.am (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/arm/Makefile.am (modified) * c/src/lib/libbsp/bfin/Makefile.am (modified) * c/src/lib/libbsp/epiphany/Makefile.am (modified) * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/Makefile.am (modified) * c/src/lib/libbsp/m32c/Makefile.am (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/mips/Makefile.am (modified) * c/src/lib/libbsp/moxie/Makefile.am (modified) * c/src/lib/libbsp/nios2/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/Makefile.am (modified) * c/src/lib/libbsp/or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/sh/Makefile.am (modified) * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc64/Makefile.am (modified) * c/src/lib/libbsp/v850/Makefile.am (modified) * c/src/lib/libcpu/Makefile.am (modified) * cpukit/Makefile.am (modified) * cpukit/automake/subdirs.am (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/Makefile.am (modified) build-system: Parallel build all subdirs. Fri, 28 Oct 2016 14:05:56 GMT Jacob Hansen [8639685] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libcpu/sparc/access/access.S (modified) * c/src/lib/libcpu/sparc/reg_win/window.S (modified) * c/src/lib/libcpu/sparc/syscall/syscall.S (modified) sparc: Adjust assembly to improve compability with LLVM - All ... Mon, 24 Apr 2017 16:18:03 GMT Joel Sherrill [0d01cdd6] * c/src/lib/libcpu/sh/sh7750/sci/sh4uart.c (modified) sh/sh7750/sci/sh4uart.c: ix misleading indentation warning Mon, 24 Apr 2017 16:17:41 GMT Joel Sherrill [646df54c] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c (modified) powerpc/new-exceptions/bspsupport/ppc_exc_print.c: Fix printf() ... Mon, 24 Apr 2017 16:17:12 GMT Joel Sherrill [2808c26] * c/src/lib/libcpu/powerpc/mpc5xx/console-generic/console-generic.c (modified) powerpc/mpc5xx/console-generic/console-generic.c: Use updated struct ... Fri, 07 Apr 2017 14:11:20 GMT Cillian O'Donnell [7acdb10] * c/src/lib/libcpu/powerpc/mpc5xx/vectors/vectors_init.c (modified) libcpu/../mpc5xx/.../vectors_init.c: Using inttype macros fixes 39 ... Mon, 27 Mar 2017 11:20:20 GMT Sebastian Huber [0a6a2a7b] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Add Performance Monitors Extension Tue, 21 Mar 2017 19:39:48 GMT Kevin Kirspel [1c6926c1] * c/src/lib/libbsp/arm/csb336/console/uart.c (modified) * c/src/lib/libbsp/arm/lpc32xx/console/hsu.c (modified) * c/src/lib/libbsp/i386/shared/comm/tty_drv.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_console/console.c (modified) * c/src/lib/libbsp/m68k/av5282/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68340/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68360/console/console.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf52235/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5235/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5329/console/console.c (modified) * c/src/lib/libbsp/m68k/mrm332/console/sci.c (modified) * c/src/lib/libbsp/m68k/mvme167/console/console.c (modified) * c/src/lib/libbsp/m68k/uC5282/console/console.c (modified) * c/src/lib/libbsp/powerpc/acinclude.m4 (modified) * c/src/lib/libbsp/powerpc/gen5200/console/console.c (modified) * c/src/lib/libbsp/powerpc/shared/console/console.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/console/console.c (modified) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) * c/src/lib/libcpu/arm/at91rm9200/usart/usart.c (modified) * c/src/lib/libcpu/arm/s3c24xx/include/s3c2400.h (modified) * c/src/lib/libcpu/arm/s3c24xx/include/s3c2410.h (modified) * c/src/lib/libcpu/bfin/serial/uart.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/esci/esci.c (modified) * c/src/lib/libcpu/powerpc/mpc5xx/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console405.c (modified) * c/src/lib/libcpu/powerpc/ppc403/tty_drv/tty_drv.c (modified) * c/src/lib/libcpu/sh/sh7032/sci/sci.c (modified) * c/src/lib/libcpu/sh/sh7045/sci/sci.c (modified) * c/src/lib/libcpu/sh/sh7045/sci/sci_termios.c (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681_baud.c (modified) * c/src/libchip/serial/z85c30.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/include/sys/_termios.h (added) * cpukit/libcsupport/include/sys/ioccom.h (modified) * cpukit/libcsupport/include/sys/termios.h (modified) * cpukit/libcsupport/include/sys/ttycom.h (modified) * cpukit/libcsupport/include/sys/ttydefaults.h (added) * cpukit/libcsupport/src/cfgetispeed.c (modified) * cpukit/libcsupport/src/cfgetospeed.c (modified) * cpukit/libcsupport/src/cfmakeraw.c (modified) * cpukit/libcsupport/src/cfmakesane.c (added) * cpukit/libcsupport/src/cfsetispeed.c (modified) * cpukit/libcsupport/src/cfsetospeed.c (modified) * cpukit/libcsupport/src/cfsetspeed.c (modified) * cpukit/libcsupport/src/tcdrain.c (modified) * cpukit/libcsupport/src/tcflush.c (modified) * cpukit/libcsupport/src/tcgetattr.c (modified) * cpukit/libcsupport/src/tcsetattr.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termios_baud2index.c (modified) * cpukit/libcsupport/src/termios_baud2num.c (modified) * cpukit/libcsupport/src/termios_baudtable.c (modified) * cpukit/libcsupport/src/termios_setbestbaud.c (modified) * cpukit/libcsupport/src/termios_setinitialbaud.c (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) * cpukit/preinstall.am (modified) * testsuites/libtests/termios/init.c (modified) * testsuites/libtests/termios01/init.c (modified) * testsuites/libtests/termios01/termios01.scn (modified) * testsuites/libtests/termios01/termios_testdriver.c (modified) * testsuites/libtests/termios02/termios02.scn (modified) * testsuites/libtests/termios03/termios03.scn (modified) * testsuites/libtests/termios04/termios04.scn (modified) * testsuites/libtests/termios05/termios05.scn (modified) * testsuites/libtests/termios06/init.c (modified) * testsuites/libtests/termios06/termios06.scn (modified) * testsuites/libtests/termios07/termios07.scn (modified) * testsuites/libtests/termios08/termios08.scn (modified) * tools/cpu/sh/sci.c (modified) termios: Synchronize with latest FreeBSD headers Adding modified ... Tue, 07 Mar 2017 06:58:11 GMT Sebastian Huber [a11e1ff5] * c/src/lib/libcpu/powerpc/mpc6xx/altivec/vec_sup_asm.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) powerpc: Optimize AltiVec context switch Use r8 instead of r5 to ... Tue, 07 Mar 2017 06:50:12 GMT Sebastian Huber [c6f76392] * c/src/lib/libcpu/powerpc/mpc6xx/altivec/vec_sup_asm.S (modified) powerpc: Fix AltiVec context switch Update #2751. Thu, 02 Mar 2017 10:57:28 GMT Sebastian Huber [805d7213] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c (modified) powerpc: Fix warnings Thu, 02 Mar 2017 10:54:58 GMT Sebastian Huber [09dab28d] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) powerpc: Fix interrupt thread dispatch Update #2751. Wed, 15 Feb 2017 12:14:40 GMT Sebastian Huber [32292d5d] * c/src/lib/libcpu/powerpc/mpc83xx/gtm/gtm.c (modified) bsps/powerpc: Fix warning Wed, 15 Feb 2017 10:12:40 GMT Sebastian Huber [444cb5c] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Fix prototype Wed, 15 Feb 2017 10:09:50 GMT Sebastian Huber [73f8d93] * c/src/lib/libbsp/powerpc/psim/network/if_sim.c (modified) * c/src/lib/libbsp/powerpc/shared/openpic/openpic.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/bat.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/pte121.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c (modified) * c/src/lib/libcpu/powerpc/shared/src/stack.c (modified) bsps/powerpc: Fix warnings Fri, 02 Dec 2016 12:10:31 GMT Sebastian Huber [f65dcc71] * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) score: Fix ARM and PowerPC context initialization Update #2751. Tue, 29 Nov 2016 22:19:05 GMT Chris Johns [e629076] * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/configure.ac (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/preinstall.am (modified) * c/src/lib/libcpu/arm/configure.ac (modified) * cpukit/libdebugger/rtems-debugger-arm.c (modified) libdebugger: Build for ARM's without a CP15. Tue, 22 Nov 2016 09:13:27 GMT Sebastian Huber [6a1b9e4] * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libcpu/sparc/syscall/syscall.S (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) sparc: Optimize _ISR_Handler() Use _Thread_Do_dispatch() instead of ... Fri, 25 Nov 2016 18:21:44 GMT Martin Erik Werner [9bf9068] * c/src/lib/libcpu/or1k/shared/cache/cache.c (modified) or1k: Avoid multiple iterations over cache Previously, if the cache ... Fri, 25 Nov 2016 18:21:43 GMT Martin Erik Werner [a59dd5c] * c/src/lib/libcpu/or1k/shared/cache/cache.c (modified) or1k: Remove secondary functions in cache manager Move the code of ... Fri, 25 Nov 2016 18:21:42 GMT Martin Erik Werner [3b4ddaf] * c/src/lib/libcpu/or1k/shared/cache/cache.c (modified) * c/src/lib/libcpu/or1k/shared/cache/cache_.h (modified) or1k: Avoid excessive ISR toggle in cache manager Previously ... Fri, 25 Nov 2016 18:21:41 GMT Martin Erik Werner [4dcaa48] * c/src/lib/libcpu/or1k/shared/cache/cache.c (modified) or1k: Indent & comment fix in cache.c * Fix indentation of variable ... Fri, 25 Nov 2016 18:21:40 GMT Martin Erik Werner [e639c026] * c/src/lib/libcpu/or1k/shared/cache/cache.c (modified) or1k: Add functions for entire cache operations Add functions for ... Wed, 23 Nov 2016 15:15:13 GMT Sebastian Huber [4b5ff47] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * cpukit/score/include/rtems/score/profiling.h (modified) * cpukit/score/src/profilingisrentryexit.c (modified) score: Fix interrupt profiling Callers of _Thread_Do_dispatch() ... Thu, 24 Nov 2016 07:32:01 GMT Sebastian Huber [01ac1db] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) powerpc: Fix interrupt profiling for e6500 Mon, 21 Nov 2016 09:37:18 GMT Sebastian Huber [f730c25b] * c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c (modified) * c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.h (modified) powerpc/mpc5xx: Rename CPU_Interrupt_frame The MPC5XX support uses ... Mon, 14 Nov 2016 14:23:40 GMT Sebastian Huber [7ce60b3] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * cpukit/score/cpu/powerpc/cpu.c (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Use Per_CPU_Control::isr_dispatch_disable Update #2751. Fri, 11 Nov 2016 13:37:51 GMT Sebastian Huber [d5e073c] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/include/rtems/score/userextimpl.h (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadloadenv.c (modified) score: Allow interrupts during thread dispatch Use a ... Mon, 14 Nov 2016 11:06:46 GMT Sebastian Huber [2599c8e] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/exc-vector-base.S (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/t32mppc/start/start.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) * cpukit/score/cpu/powerpc/cpu.c (modified) * cpukit/score/cpu/powerpc/rtems/score/cpuimpl.h (modified) powerpc: Add up to date CPU_Interrupt_frame Rename ... Fri, 11 Nov 2016 10:31:13 GMT Sebastian Huber [bf4fdb1] * c/src/lib/libbsp/powerpc/ss555/irq/irq.h (modified) * c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Move legacy CPU_Interrupt_frame The only remaining user of ... Fri, 11 Nov 2016 10:25:37 GMT Sebastian Huber [40d592eb] * c/src/lib/libcpu/powerpc/ppc403/irq/ictrl.c (modified) bsps/powerpc: Avoid use of CPU_Interrupt_frame This type is not ... Fri, 11 Nov 2016 10:16:33 GMT Sebastian Huber [d18560a] * c/src/lib/libbsp/sparc64/shared/start/start.S (modified) * c/src/lib/libcpu/sparc64/shared/score/interrupt.S (modified) * cpukit/score/cpu/sparc64/context.S (modified) * cpukit/score/cpu/sparc64/cpu.c (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) sparc64: Rename CPU_Minimum_stack_frame Rename SPARC64-specific ... Fri, 11 Nov 2016 09:48:14 GMT Sebastian Huber [8ef8a32] * c/src/lib/libbsp/mips/csb350/irq/vectorisrs.c (modified) * c/src/lib/libbsp/mips/hurricane/irq/vectorisrs.c (modified) * c/src/lib/libbsp/mips/jmr3904/irq/vectorisrs.c (modified) * c/src/lib/libbsp/mips/malta/irq/vectorisrs.c (modified) * c/src/lib/libbsp/mips/rbtx4925/irq/vectorisrs.c (modified) * c/src/lib/libbsp/mips/rbtx4938/irq/vectorisrs.c (modified) * c/src/lib/libcpu/mips/shared/interrupts/isr_entries.h (modified) bsps/mips: Use Avoid duplicate ... Wed, 09 Nov 2016 13:59:33 GMT Sebastian Huber [38a1449] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpuimpl.h (modified) * testsuites/smptests/smpmutex02/smpmutex02.scn (modified) * testsuites/tmtests/tmfine01/tmfine01.scn (modified) powerpc: Add _CPU_Get_current_per_CPU_control() Add ... Mon, 07 Nov 2016 15:54:40 GMT Sebastian Huber [1f5bee3] * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c (modified) * c/src/lib/libcpu/bfin/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/threadcreateidle.c (modified) * testsuites/sptests/spintrcritical_support/intrcritical.c (modified) score: Add and use Thread_Control::is_idle Update #2797. Thu, 08 Sep 2016 07:31:47 GMT Sebastian Huber [275032b] * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) powerpc: Fix SMP context switch We need the unmodified r4 for ... Fri, 02 Sep 2016 23:59:21 GMT Pavel Pisa [6e6a77a6] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: reorganize CP15 code to allow clean and invalidate ARMv7 ... Fri, 02 Sep 2016 23:30:20 GMT Pavel Pisa [7ec689ad] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: use defines for cache type register format field. The ... Sun, 17 Jul 2016 17:31:33 GMT Pavel Pisa [577e7fb] * c/src/lib/libbsp/arm/shared/armv467ar-basic-cache/cache_.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-cache-l1.h (modified) * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) arm/bsps: CP15 and basic cache support entire cache clean for more ... Sun, 17 Jul 2016 16:21:48 GMT Pavel Pisa [33381218] * c/src/lib/libbsp/arm/shared/arm-cp15-set-ttb-entries.c (modified) * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: do not disable MMU during translation table management ... Tue, 19 Jul 2016 04:43:10 GMT Sebastian Huber [8d785f7] * c/src/lib/libcpu/powerpc/mpc6xx/altivec/vec_sup.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) bsps/powerpc: Fix AtliVec context switch Properly pass the stack ... Mon, 04 Jul 2016 18:05:43 GMT Punit Vara [5e3096db] * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/include/bbb-pwm.h (modified) * c/src/lib/libbsp/arm/beagle/pwm/pwm.c (modified) * c/src/lib/libcpu/arm/shared/include/am335x.h (modified) Beaglebone: Update PWM driver imported from BBBIO This patch adapts ... Sun, 03 Jul 2016 23:30:05 GMT Pavel Pisa [0616555] * c/src/lib/libbsp/arm/shared/armv467ar-basic-cache/cache_.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-cache-l1.h (modified) * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: basic on core cache support changed to use l1 functions. ... Sun, 03 Jul 2016 15:26:50 GMT Pavel Pisa [d4316537] * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/preinstall.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/shared/armv467ar-basic-cache/cache_.h (added) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libcpu/arm/shared/include/cache_.h (modified) bsps/arm: Change code to explicit selection of cache implementation ... Sat, 02 Jul 2016 22:19:38 GMT Pavel Pisa [0e507d55] * c/src/lib/libcpu/shared/src/cache_manager.c (modified) * cpukit/libcsupport/src/cachealignedalloc.c (modified) * cpukit/rtems/include/rtems/rtems/cache.h (modified) rtems+bsps/cache: Define cache manager operations for code ... Thu, 30 Jun 2016 22:05:33 GMT Pavel Pisa [19a9090] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm/score and shared: define ARM hypervisor mode and alternate vector ... Wed, 18 May 2016 06:06:54 GMT Sebastian Huber [24713163] * c/src/lib/libbsp/m68k/gen68360/startup/alloc360.c (modified) * c/src/lib/libbsp/m68k/mvme167/network/network.c (modified) * c/src/lib/libcpu/or1k/shared/cache/cache.c (modified) * c/src/lib/libcpu/powerpc/mpc8260/cpm/dpram.c (modified) * c/src/lib/libcpu/powerpc/mpc8xx/cpm/dpram.c (modified) * c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c (modified) * c/src/libchip/ide/ata.c (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/rtems/src/intrbody.c (modified) * cpukit/score/cpu/arm/armv7m-isr-vector-install.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-disable-protected.c (modified) * cpukit/score/cpu/or1k/cpu.c (modified) * cpukit/score/include/rtems/score/assert.h (modified) * cpukit/score/include/rtems/score/cpustdatomic.h (modified) * cpukit/score/include/rtems/score/isrlevel.h (modified) * cpukit/score/include/rtems/score/isrlock.h (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threaddispatchdisablelevel.c (modified) * testsuites/tmtests/tm26/task1.c (modified) score: Rename _ISR_Disable() and _ISR_Enable() Rename ... Wed, 18 May 2016 06:03:05 GMT Sebastian Huber [4b04cb61] * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/score/cpu/sparc/sparcv8-atomic.c (modified) * cpukit/score/include/rtems/score/isrlevel.h (modified) * cpukit/score/include/rtems/score/isrlock.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/smplock.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/debugisthreaddispatchingallowed.c (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/isrisinprogress.c (modified) * cpukit/score/src/smplock.c (modified) * cpukit/score/src/smpmulticastaction.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threaddispatchdisablelevel.c (modified) * cpukit/score/src/threadhandler.c (modified) * testsuites/smptests/smpcache01/init.c (modified) * testsuites/smptests/smpload01/init.c (modified) * testsuites/smptests/smpthreadlife01/init.c (modified) * testsuites/tmtests/tm26/task1.c (modified) * testsuites/tmtests/tm27/task1.c (modified) score: Rename _ISR_Disable_without_giant() Rename ... Tue, 17 May 2016 13:57:48 GMT Sebastian Huber [d2bacb6c] * c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c (modified) * cpukit/score/cpu/lm32/irq.c (modified) * cpukit/score/cpu/nios2/nios2-iic-irq.c (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) score: _Thread_Dispatch_increment_disable_level() Avoid ... Thu, 19 May 2016 08:21:01 GMT Pavel Pisa [6fbc692] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: CP15 support for flush prefetch buffer and table base control. Sun, 27 Mar 2016 23:37:48 GMT Joel Sherrill [9c7de43] * c/src/lib/libcpu/m68k/mcf5272/clock/ckinit.c (modified) libcpu/m68k/mcf5272/clock/ckinit.c: Fix warning by including ... Sun, 27 Mar 2016 23:37:48 GMT Joel Sherrill [d0cffc73] * c/src/lib/libcpu/m68k/mcf5206/clock/ckinit.c (modified) libcpu/m68k/mcf5206/clock/ckinit.c: Fix warning by including ... Sun, 27 Mar 2016 23:37:48 GMT Joel Sherrill [6b597c39] * c/src/lib/libcpu/bfin/clock/clock.c (modified) libcpu/bfin/clock/clock.c: Fix warning by including Thu, 17 Mar 2016 08:12:19 GMT Daniel Hellstrom [6c4aaf4] * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libcpu/sparc/reg_win/window.S (modified) sparc: Fix window underflow trap handler The window underflow trap ... Sat, 23 Jan 2016 19:06:22 GMT Joel Sherrill [328bd35] * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/shared/irq/idt.c (modified) * c/src/lib/libbsp/i386/shared/irq/irq_init.c (modified) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h (modified) * c/src/lib/libbsp/i386/shared/smp/smp-imps.c (modified) * c/src/lib/libcpu/i386/Makefile.am (modified) * c/src/lib/libcpu/i386/cache.c (modified) * c/src/lib/libcpu/i386/cpu.h (deleted) * c/src/lib/libcpu/i386/displayCpu.c (modified) * c/src/lib/libcpu/i386/page.c (modified) * c/src/lib/libcpu/i386/page.h (added) * c/src/lib/libcpu/i386/preinstall.am (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) i386: refactor libcpu/cpu.h into rtems/score/i386.h Fixes #2515. Sat, 27 Feb 2016 23:19:33 GMT Martin Galvan [8c5c53f4] * c/src/lib/libbsp/arm/beagle/irq.c (modified) * c/src/lib/libcpu/arm/shared/include/omap3.h (modified) am335x irq handling improvement This patch makes the following ... Tue, 26 Jan 2016 10:16:56 GMT Sebastian Huber [3bc12a8f] * c/src/lib/libbsp/i386/shared/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/irq/BSP_irq.c (modified) * c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/irq.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_hdl.c (modified) * cpukit/posix/include/rtems/posix/psignalimpl.h (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/rtems/src/signalcatch.c (modified) * cpukit/rtems/src/taskident.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/apiext.h (deleted) * cpukit/score/preinstall.am (modified) * cpukit/score/src/apiext.c (deleted) * cpukit/score/src/threaddispatch.c (modified) * testsuites/sptests/spsize/size.c (modified) Delete unused API extensions Mon, 25 Jan 2016 09:20:28 GMT Sebastian Huber [a8865f8] * c/src/lib/libcpu/shared/src/cache_manager.c (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) score: Introduce CPU_CACHE_LINE_BYTES Add CPU_CACHE_LINE_BYTES for ... Wed, 23 Dec 2015 06:29:47 GMT Sebastian Huber [76ac1ee3] * c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c (modified) * c/src/lib/libbsp/m68k/mcf52235/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5329/clock/clock.c (modified) * c/src/lib/libbsp/m68k/uC5282/clock/clock.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/clock/clock-config.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon2/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c (modified) * c/src/lib/libcpu/arm/lpc22xx/clock/clockdrv.c (modified) * cpukit/rtems/src/clocktick.c (modified) * cpukit/sapi/include/rtems/timecounter.h (modified) * cpukit/score/include/rtems/score/timecounter.h (modified) * cpukit/score/src/kern_tc.c (modified) * doc/bsp_howto/clock.t (modified) score: Fix simple timecounter support Update #2502. Thu, 07 Jan 2016 08:55:45 GMT Sebastian Huber [ccd5434] * c/src/lib/libbsp/arm/gdbarmsim/include/bsp.h (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/m32c/m32cbsp/include/bsp.h (modified) * c/src/lib/libbsp/moxie/moxiesim/include/bsp.h (modified) * c/src/lib/libbsp/sh/shsim/include/bsp.h (modified) * c/src/lib/libbsp/shared/clock_driver_simidle.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/sparc64/niagara/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/usiii/include/bsp.h (modified) * c/src/lib/libbsp/v850/gdbv850sim/include/bsp.h (modified) * c/src/lib/libcpu/bfin/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (modified) * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/libmisc/monitor/monitor.h (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/rtems/src/taskrestart.c (modified) * cpukit/rtems/src/taskstart.c (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threadentryadaptoridle.c (added) * cpukit/score/src/threadentryadaptornumeric.c (added) * cpukit/score/src/threadentryadaptorpointer.c (added) * cpukit/score/src/threadglobalconstruction.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadstart.c (modified) * testsuites/samples/minimum/init.c (modified) * testsuites/sptests/sp54/init.c (modified) * testsuites/sptests/spintrcritical_support/intrcritical.c (modified) score: Introduce Thread_Entry_information This avoids potential ... Wed, 11 Nov 2015 10:49:45 GMT Sebastian Huber [5c7bfcf] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) Fix interrupt epilogue for ARMv7-AR and PowerPC Fri, 16 Oct 2015 06:26:44 GMT Sebastian Huber [bc792bb] * c/src/lib/libbsp/i386/pc386/include/edid.h (modified) * c/src/lib/libbsp/i386/pc386/include/vbe3.h (modified) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c (modified) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h (modified) * c/src/lib/libcpu/i386/cpu.h (modified) * cpukit/score/include/rtems/score/basedefs.h (modified) basdefs.h: Add and use RTEMS_PACKED Fri, 25 Sep 2015 12:34:24 GMT Sebastian Huber [258ad71] * c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspsmp.c (modified) * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * testsuites/smptests/smpthreadlife01/init.c (modified) SMP: Fix and optimize thread dispatching According to the C11 and ... Tue, 18 Aug 2015 14:30:48 GMT Ketul Shah [151e53f] * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c (added) * c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h (added) * c/src/lib/libbsp/arm/beagle/include/beagleboneblack.h (added) * c/src/lib/libbsp/arm/beagle/include/bsp.h (modified) * c/src/lib/libbsp/arm/beagle/preinstall.am (modified) * c/src/lib/libcpu/arm/shared/include/am335x.h (modified) Beagle: GPIO support (for BBB) GPIO Driver Development for ... Fri, 17 Jul 2015 05:56:09 GMT Sebastian Huber [e5a79e54] * c/src/lib/libcpu/powerpc/mpc83xx/i2c/mpc83xx_i2cdrv.c (modified) * c/src/lib/libcpu/powerpc/mpc83xx/i2c/mpc83xx_i2cdrv.h (modified) bsp/mpc83xx: Update due to header guard change Close #2373. Wed, 08 Jul 2015 08:04:39 GMT Sebastian Huber [b171982] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) bsps/powerpc: Provide debug and trace symbols Thu, 25 Jun 2015 12:11:53 GMT Sebastian Huber [48fed9a] * c/src/lib/libbsp/powerpc/mvme5500/vectors/exceptionhandler.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c (modified) * c/src/lib/libcpu/bfin/clock/clock.c (modified) * c/src/lib/libcpu/or1k/shared/cache/cache.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/pte121.c (modified) * cpukit/libcsupport/src/sync.c (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/posix/src/pthreadself.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/src/profilingiterate.c (modified) * cpukit/score/cpu/arm/arm_exc_handler_high.c (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/nios2/nios2-isr-is-in-progress.c (modified) * cpukit/score/include/rtems/score/userextimpl.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/src/corespinlockrelease.c (modified) score: Simplify Drop the ... Tue, 02 Jun 2015 19:43:54 GMT Sebastian Huber [335e5ca] * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadloadenv.c (modified) score: Add Thread_Control::is_fp Store the floating-point unit ... Fri, 29 May 2015 06:59:41 GMT Sebastian Huber [aff220d] * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (modified) bsps/powerpc: Fix potential integer overflow Update #2356. Sun, 03 May 2015 09:55:55 GMT ragunath [d55d7a0] * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/configure.ac (modified) * c/src/lib/libbsp/arm/beagle/rtc.c (added) * c/src/lib/libcpu/arm/shared/include/am335x.h (modified) * c/src/lib/libcpu/arm/shared/include/omap3.h (modified) beagle bsp: RTC support for BBB Thu, 21 May 2015 12:54:57 GMT Joel Sherrill [60e4c00] * c/src/lib/libcpu/arm/s3c24xx/clock/clockdrv.c (modified) arm/s3c24xx/clock/clockdrv.c: Remove unused variable warning Thu, 21 May 2015 12:54:35 GMT Joel Sherrill [562c1b1b] * c/src/lib/libcpu/arm/lpc22xx/clock/clockdrv.c (modified) arm/lpc22xx/clock/clockdrv.c: Remove unused variable warning Wed, 01 Apr 2015 13:33:25 GMT Alexander Krutwig [75acd9e] * c/src/lib/libbsp/arm/beagle/clock.c (modified) * c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c (modified) * c/src/lib/libbsp/arm/gba/clock/clockdrv.c (modified) * c/src/lib/libbsp/arm/lpc176x/include/lpc-clock-config.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/lpc-clock-config.h (modified) * c/src/lib/libbsp/arm/lpc32xx/include/lpc-clock-config.h (modified) * c/src/lib/libbsp/arm/nds/clock/clock.c (modified) * c/src/lib/libbsp/arm/raspberrypi/clock/clockdrv.c (modified) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/lpc/clock/lpc-clock-config.c (modified) * c/src/lib/libbsp/arm/tms570/clock/clock.c (modified) * c/src/lib/libbsp/i386/pc386/clock/ckinit.c (modified) * c/src/lib/libbsp/lm32/shared/clock/ckinit.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/av5282/clock/clock.c (modified) * c/src/lib/libbsp/m68k/gen68360/clock/clock.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf52235/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5235/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5329/clock/clock.c (modified) * c/src/lib/libbsp/m68k/sim68000/clock/clockdrv.c (modified) * c/src/lib/libbsp/m68k/uC5282/clock/clock.c (modified) * c/src/lib/libbsp/mips/csb350/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/genmongoosev/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/jmr3904/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/rbtx4925/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/rbtx4938/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/shared/clock/clockdrv.c (modified) * c/src/lib/libbsp/nios2/nios2_iss/clock/clock.c (modified) * c/src/lib/libbsp/or1k/generic_or1k/clock/clockdrv.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/clock/clock-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/clock/clock-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/shared/clock/clock.c (modified) * c/src/lib/libbsp/shared/clock_driver_simidle.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon2/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc64/shared/clock/ckinit.c (modified) * c/src/lib/libcpu/arm/at91rm9200/clock/clock.c (modified) * c/src/lib/libcpu/arm/lpc22xx/clock/clockdrv.c (modified) * c/src/lib/libcpu/arm/mc9328mxl/clock/clockdrv.c (modified) * c/src/lib/libcpu/arm/pxa255/clock/clock.c (modified) * c/src/lib/libcpu/arm/s3c24xx/clock/clockdrv.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (modified) bsps: Convert clock drivers to use a timecounter Update #2271. Mon, 27 Apr 2015 08:11:47 GMT Sebastian Huber [7f53035] * c/src/lib/libcpu/sparc/Makefile.am (modified) * c/src/lib/libcpu/sparc/cache/cache.c (deleted) * c/src/lib/libcpu/sparc/cache/cache_.h (modified) bsps/sparc: Use inline functions for cache manager Mon, 27 Apr 2015 07:40:16 GMT Sebastian Huber [4bf2a6aa] * c/src/lib/libcpu/shared/include/cache.h (modified) * c/src/lib/libcpu/shared/src/cache_manager.c (modified) bsps/cache: Clarify range functions support Fri, 24 Apr 2015 17:55:04 GMT Hesham ALMatary [1602bf3] * c/src/lib/libcpu/shared/include/cache.h (modified) Fix broken BSPs due to a shared cache function declaration. Get rid ... Fri, 17 Apr 2015 10:05:16 GMT Sebastian Huber [26c142e5] * c/src/lib/libcpu/shared/src/cache_manager.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpmulticastaction.c (added) * testsuites/smptests/smpcache01/init.c (modified) score: Refactor SMP cache manager support Fri, 20 Mar 2015 13:09:26 GMT Sebastian Huber [d4edbdbc] * c/src/lib/libbsp/arm/beagle/clock.c (modified) * c/src/lib/libbsp/arm/beagle/console/console-config.c (modified) * c/src/lib/libbsp/arm/beagle/include/bsp.h (modified) * c/src/lib/libbsp/arm/beagle/include/i2c.h (modified) * c/src/lib/libbsp/arm/beagle/irq.c (modified) * c/src/lib/libbsp/arm/beagle/misc/i2c.c (modified) * c/src/lib/libbsp/arm/lpc176x/adc/adc.c (modified) * c/src/lib/libbsp/arm/lpc176x/benchmark_timer/benchmark_timer.c (modified) * c/src/lib/libbsp/arm/lpc176x/can/can.c (modified) * c/src/lib/libbsp/arm/lpc176x/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc176x/gpio/gpio.c (modified) * c/src/lib/libbsp/arm/lpc176x/include/adc-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/adc.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/can-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/can.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/common-types.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/dma.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/gpio-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/gpio.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/io-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/io.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/irq.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/lpc-clock-config.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/lpc176x.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/mbed-pinmap.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/pwmout-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/pwmout.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/system-clocks.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/timer-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/timer.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/watchdog-defs.h (modified) * c/src/lib/libbsp/arm/lpc176x/include/watchdog.h (modified) * c/src/lib/libbsp/arm/lpc176x/irq/irq.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/bspidle.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/dma-copy.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/dma.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/io.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/restart.c (modified) * c/src/lib/libbsp/arm/lpc176x/misc/system-clocks.c (modified) * c/src/lib/libbsp/arm/lpc176x/pwmout/pwmout.c (modified) * c/src/lib/libbsp/arm/lpc176x/rtc/rtc-config.c (modified) * c/src/lib/libbsp/arm/lpc176x/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/lpc176x/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/lpc176x/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/lpc176x/timer/timer.c (modified) * c/src/lib/libbsp/arm/lpc176x/watchdog/watchdog.c (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_adc.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_exti.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_flash.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_otgfs.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_pwr.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_syscfg.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_tim.h (modified) * c/src/lib/libcpu/arm/shared/include/am335x.h (modified) * c/src/lib/libcpu/arm/shared/include/omap3.h (modified) * cpukit/libdl/dlfcn-shell.c (modified) * cpukit/libdl/dlfcn-shell.h (modified) * cpukit/libdl/dlfcn.c (modified) * cpukit/libdl/rap-shell.c (modified) * cpukit/libdl/rap-shell.h (modified) * cpukit/libdl/rap.c (modified) * cpukit/libdl/rap.h (modified) * cpukit/libdl/rtl-chain-iterator.c (modified) * cpukit/libdl/rtl-chain-iterator.h (modified) * cpukit/libdl/rtl-debugger.c (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-error.c (modified) * cpukit/libdl/rtl-error.h (modified) * cpukit/libdl/rtl-find-file.c (modified) * cpukit/libdl/rtl-find-file.h (modified) * cpukit/libdl/rtl-fwd.h (modified) * cpukit/libdl/rtl-indirect-ptr.h (modified) * cpukit/libdl/rtl-obj-cache.c (modified) * cpukit/libdl/rtl-obj-cache.h (modified) * cpukit/libdl/rtl-obj-comp.c (modified) * cpukit/libdl/rtl-obj-comp.h (modified) * cpukit/libdl/rtl-obj-fwd.h (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-obj.h (modified) * cpukit/libdl/rtl-rap.c (modified) * cpukit/libdl/rtl-rap.h (modified) * cpukit/libdl/rtl-shell.c (modified) * cpukit/libdl/rtl-shell.h (modified) * cpukit/libdl/rtl-sym.c (modified) * cpukit/libdl/rtl-sym.h (modified) * cpukit/libdl/rtl-trace.c (modified) * cpukit/libdl/rtl-trace.h (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libdl/rtl-unresolved.h (modified) * cpukit/libdl/rtl.c (modified) * cpukit/libdl/rtl.h (modified) * cpukit/libmisc/shell/main_md5.c (modified) * cpukit/score/cpu/or1k/cpu.c (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * testsuites/psxtests/psxclock01/init.c (modified) * testsuites/sptests/spclock_err01/delay.c (modified) * testsuites/sptests/spclock_err01/init.c (modified) * testsuites/sptests/spclock_err01/system.h (modified) * testsuites/sptests/spevent_err03/init.c (modified) * testsuites/sptests/spevent_err03/system.h (modified) * testsuites/sptests/spintr_err01/init.c (modified) * testsuites/sptests/spintr_err01/isr.c (modified) * testsuites/sptests/spintr_err01/system.h (modified) * testsuites/sptests/spintrcritical23/init.c (modified) * testsuites/sptests/spmsgq_err01/init.c (modified) * testsuites/sptests/spmsgq_err01/system.h (modified) * testsuites/sptests/spmsgq_err02/init.c (modified) * testsuites/sptests/spmsgq_err02/system.h (modified) * testsuites/sptests/spmsgq_err02/task3.c (modified) * testsuites/sptests/spport_err01/init.c (modified) * testsuites/sptests/spport_err01/system.h (modified) * testsuites/sptests/spratemon_err01/init.c (modified) * testsuites/sptests/spratemon_err01/screen10.c (modified) * testsuites/sptests/spratemon_err01/system.h (modified) * testsuites/sptests/spratemon_err01/task4.c (modified) * testsuites/sptests/spsem_err01/init.c (modified) * testsuites/sptests/spsem_err01/system.h (modified) * testsuites/sptests/spsem_err02/init.c (modified) * testsuites/sptests/spsem_err02/system.h (modified) * testsuites/sptests/spsem_err02/task2.c (modified) * testsuites/sptests/spsignal_err01/init.c (modified) * testsuites/sptests/spsignal_err01/isr.c (modified) * testsuites/sptests/spsignal_err01/system.h (modified) * testsuites/sptests/sptask_err01/init.c (modified) * testsuites/sptests/sptask_err01/system.h (modified) * testsuites/sptests/sptask_err01/task2.c (modified) * testsuites/sptests/sptask_err02/init.c (modified) * testsuites/sptests/sptask_err02/system.h (modified) * testsuites/sptests/sptask_err03/init.c (modified) * testsuites/sptests/sptask_err03/system.h (modified) * testsuites/sptests/sptask_err04/init.c (modified) * testsuites/sptests/sptask_err04/system.h (modified) Replace www.rtems.com with www.rtems.org
