Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src/lib/libcpu/m68k
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @dfa8fe34   12/06/02 08:23:08 Ralf Corsepius 2002-12-06 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @0730209   12/01/02 12:14:38 Ralf Corsepius 2002-12-01 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @8730f45   10/21/02 12:19:27 Ralf Corsepius 2002-10-21 Ralf Corsepius <corsepiu@…> * .cvsignore: … 4.104.114.84.95
(edit) @06a27bbf   08/21/02 17:43:48 Joel Sherrill 2002-08-21 Joel Sherrill <joel@…> * configure.ac, … 4.104.114.84.95
(edit) @ee64711   08/11/02 05:39:18 Ralf Corsepius 2002-08-11 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @f8ac3ae3   08/06/02 20:23:58 Joel Sherrill 2002-08-06 Joel Sherrill <joel@…> * configure.ac: Be more … 4.104.114.84.95
(edit) @c5ada0b   08/06/02 14:20:40 Ralf Corsepius 2002-08-06 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @3f5480c   08/05/02 19:03:52 Joel Sherrill 2002-08-05 Joel Sherrill <joel@…> * Per PR260 eliminate … 4.104.114.84.95
(edit) @e3355c71   03/28/02 00:48:05 Joel Sherrill 2002-03-27 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @ebe9aef   03/28/02 00:48:01 Joel Sherrill 2002-03-27 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @ad1fb14   11/14/01 18:40:47 Joel Sherrill 2001-11-09 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @922eb07   10/29/01 14:23:19 Joel Sherrill 2001-10-29 Joel Sherrill <joel@…> * .cvsignore: Add more … 4.104.114.84.95
(edit) @cff0d64   10/26/01 19:49:03 Joel Sherrill 2001-10-26 Victor V. Vengerov <vvv@…> * New libcpu support … 4.104.114.84.95
(edit) @62f48b3   10/26/01 19:33:37 Joel Sherrill 2001-10-26 Joel Sherrill <joel@…> * Makefile.am, … 4.104.114.84.95
(edit) @00717a3   10/26/01 19:32:40 Joel Sherrill 2001-10-26 Victor V. Vengerov <vvv@…> * New libcpu support … 4.104.114.84.95
(edit) @d7aecdc   10/12/01 18:47:00 Joel Sherrill 2001-10-11 Ralf Corsepius <corsepiu@…> * .cvsignore: … 4.104.114.84.95
(edit) @cfb99fb   10/12/01 16:05:32 Joel Sherrill 2001-10-12 Ralf Corsepius <corsepiu@…> * .cvsignore: … 4.104.114.84.95
(edit) @df25c998   10/11/01 19:36:23 Joel Sherrill 2001-10-11 Ralf Corsepius <corsepiu@…> * .cvsignore: … 4.104.114.84.95
(edit) @563acb1   09/27/01 19:45:04 Joel Sherrill 2001-09-27 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @b98c8c9   03/05/01 22:47:50 Joel Sherrill 2001-03-03 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @feead226   11/09/00 16:43:05 Joel Sherrill 2000-11-09 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @a314d3b4   11/02/00 15:49:06 Joel Sherrill 2000-11-02 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @d82c006   10/26/00 13:05:10 Joel Sherrill 2000-10-26 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @00e8978b   09/05/00 16:01:00 Joel Sherrill 2000-09-04 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @e94ad1fe   08/10/00 13:24:00 Joel Sherrill Adding ChangeLogs?. 4.104.114.84.95
(edit) @10d8a60   06/15/00 13:21:30 Joel Sherrill Updated. 4.104.114.84.95
(edit) @5e77d129   06/14/00 20:32:44 Joel Sherrill Patch from John Cotton <john.cotton@…> to correct cache routine … 4.104.114.84.95
(edit) @cf1f72e   06/13/00 21:53:38 Joel Sherrill Moved i386 and m68k cache management code to libcpu. Everything now … 4.104.114.84.95
(edit) @f0b11d63   06/13/00 21:52:13 Joel Sherrill Added .cvsignore. 4.104.114.84.95
(edit) @df49c60   06/12/00 15:00:15 Joel Sherrill Merged from 4.5.0-beta3a 4.104.114.84.95
(edit) @bf85b19   04/13/00 14:37:14 Joel Sherrill Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @70810dc   02/08/00 22:33:25 Joel Sherrill Patches rtems-rc-20000204-0.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @4e36a2f   01/31/00 15:27:02 Joel Sherrill Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff from … 4.104.114.84.95
(edit) @400c552   12/21/99 16:20:38 Joel Sherrill Removing Makefile.in and adding Makefile.am. These were missed in … 4.104.114.84.95
(edit) @35d7b15   12/21/99 14:41:43 Joel Sherrill Patch rtems-rc-19991203-7.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @7e642ba   11/22/99 19:27:13 Joel Sherrill Patch rtems-rc-19991117-9.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @9608320   11/22/99 13:41:11 Joel Sherrill Patch rtems-rc-19991117-4.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @f817b02   11/04/99 18:05:09 Joel Sherrill The files in libcpu should not be directly dependent on any BSP. In … 4.104.114.84.95
(edit) @e1d8abb   09/07/99 13:45:03 Joel Sherrill Applied patch rtems-rc-19990820-6.diff.gz from Ralf Corsepius … 4.104.114.84.95
(edit) @54f440d   07/26/99 22:11:02 Joel Sherrill Patch from Charles-Antoine Gauthier <charles.gauthier@…>. to … 4.104.114.84.95
(edit) @08b5f55   07/26/99 20:31:49 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: A bug in … 4.104.114.84.95
(edit) @6693a68   07/26/99 20:00:37 Joel Sherrill This is part of a major patch from Ralf Corsepius … 4.104.114.84.95
(edit) @196094eb   04/19/99 13:19:14 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: This one is … 4.104.114.84.95
(edit) @d8ff793   03/19/99 22:27:02 Joel Sherrill Towards automake XI patch from Ralf Corsepius … 4.104.114.84.95
(edit) @8548fe0   02/18/99 18:36:05 Joel Sherrill Part of the automake VI patch from Ralf Corsepius … 4.104.114.84.95
(edit) @0162910   12/14/98 23:15:38 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> to rename all .s … 4.104.114.84.95
(edit) @7738906   06/12/98 21:12:12 Joel Sherrill Added optimized version of memcpy.c to this directory since RTEMS … 4.104.114.84.95
(edit) @5c3511e   01/30/98 21:49:51 Joel Sherrill Big patch form Ralf Corsepius described in this email: Here is the … 4.104.114.84.95
(edit) @cb5bfe4   01/20/98 19:41:09 Joel Sherrill Removed CONFIG_DIR and PROJECT_HOME directories. 4.104.114.84.95
(edit) @6f9c75c3   01/16/98 16:56:48 Joel Sherrill Ralf Corsepius reported a number of missing CVS Id's: > RTEMS is … 4.104.114.84.95
(edit) @674c900   12/10/97 16:58:00 Joel Sherrill Modified a lot of files to take a first cut at supporting building … 4.104.114.84.95
(edit) @89f5f5a1   10/08/97 18:23:58 Joel Sherrill Fix from Eric Norum to assemble under COFF. 4.104.114.84.95
(edit) @1d320bac   07/09/97 23:41:20 Joel Sherrill This code was in the tree but not actually being compiled. There were … 4.104.114.84.95
(edit) @010e7582   04/16/97 17:34:23 Joel Sherrill Added CVS Id's 4.104.114.84.95
(add) @f9b93da   04/16/97 17:33:04 Joel Sherrill Added the MC68040 Floating Point Support Package. This was ported to … 4.104.114.84.95
