# # ChangeLog for c/src/lib/libcpu/i960/i960ka in rtems # # Generated by Trac 1.2.1.dev0 # 04/23/24 11:16:10 Tue, 11 Jul 2000 19:41:38 GMT Joel Sherrill [073e2411] * c/src/lib/libcpu/i960/.cvsignore (added) * c/src/lib/libcpu/i960/i960ca/.cvsignore (added) * c/src/lib/libcpu/i960/i960ka/.cvsignore (added) * c/src/lib/libcpu/i960/i960rp/.cvsignore (added) * c/src/lib/libcpu/i960/include/.cvsignore (added) Adding .cvsignore files. Tue, 11 Jul 2000 19:31:04 GMT Joel Sherrill [bc85fd5a] * c/src/exec/score/cpu/i960/Makefile.am (modified) * c/src/exec/score/cpu/i960/cpu.c (modified) * c/src/exec/score/cpu/i960/cpu_asm.S (modified) * c/src/exec/score/cpu/i960/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/i960/rtems/score/i960.h (modified) * c/src/lib/libbsp/i960/cvme961/include/bsp.h (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/i960sim/include/bsp.h (modified) * c/src/lib/libbsp/i960/i960sim/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/i960sim/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/clock/ckinit.c (modified) * c/src/lib/libbsp/i960/rxgen960/include/bsp.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/cntrltbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rom_cntrltbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rom_ibr.c (modified) * c/src/lib/libbsp/i960/rxgen960/timer/timer.c (modified) * c/src/lib/libbsp/i960/rxgen960/wrapup/Makefile.am (modified) * c/src/lib/libcpu/i960/Makefile.am (added) * c/src/lib/libcpu/i960/configure.in (added) * c/src/lib/libcpu/i960/i960ca/Makefile.am (added) * c/src/lib/libcpu/i960/i960ca/cpu_install_intr_stack.c (added) * c/src/lib/libcpu/i960/i960ca/cpu_install_raw_isr.c (added) * c/src/lib/libcpu/i960/i960ka/Makefile.am (added) * c/src/lib/libcpu/i960/i960ka/cpu_install_intr_stack.c (added) * c/src/lib/libcpu/i960/i960ka/cpu_install_raw_isr.c (added) * c/src/lib/libcpu/i960/i960rp/Makefile.am (added) * c/src/lib/libcpu/i960/i960rp/cpu_install_intr_stack.c (added) * c/src/lib/libcpu/i960/i960rp/cpu_install_raw_isr.c (added) * c/src/lib/libcpu/i960/include/Makefile.am (added) * c/src/lib/libcpu/i960/include/i960CA.h (added) * c/src/lib/libcpu/i960/include/i960HA.h (added) * c/src/lib/libcpu/i960/include/i960JX_RP_common.h (added) * c/src/lib/libcpu/i960/include/i960KA.h (added) * c/src/lib/libcpu/i960/include/i960RP.h (moved) * c/src/lib/libcpu/i960/shared/soft_reset_asm.S (added) * cpukit/score/cpu/i960/Makefile.am (modified) * cpukit/score/cpu/i960/cpu.c (modified) * cpukit/score/cpu/i960/cpu_asm.S (modified) * cpukit/score/cpu/i960/rtems/score/cpu.h (modified) * cpukit/score/cpu/i960/rtems/score/i960.h (modified) * make/custom/i960sim.cfg (modified) * make/custom/rxgen960.cfg (modified) Reworked score/cpu/i960 so it can be safely compiled multilib. All ...
