# # ChangeLog for c/src/lib/libcpu/hppa1.1/milli/milli.S in rtems # # Generated by Trac 1.2.1.dev0 # 05/26/22 13:36:34 Mon, 14 Dec 1998 23:15:38 GMT Joel Sherrill [0162910] * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/a29k/cpu_asm.S (moved) * c/src/exec/score/cpu/a29k/sig.S (moved) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/cpu_asm.S (moved) * c/src/exec/score/cpu/hppa1.1/rtems.S (moved) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i386/cpu_asm.S (moved) * c/src/exec/score/cpu/i386/rtems.S (moved) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/i960/cpu_asm.S (moved) * c/src/exec/score/cpu/i960/rtems.S (moved) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/m68k/cpu_asm.S (moved) * c/src/exec/score/cpu/m68k/rtems.S (moved) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/cpu_asm.S (moved) * c/src/exec/score/cpu/powerpc/irq_stub.S (moved) * c/src/exec/score/cpu/powerpc/rtems.S (moved) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/cpu_asm.S (moved) * c/src/exec/score/cpu/sparc/rtems.S (moved) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/crt0.S (moved) * c/src/lib/libbsp/a29k/portsw/start/register.S (moved) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/start.S (moved) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/start/start.S (moved) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/ldsegs.S (moved) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/timer/timerisr.S (moved) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/timerisr.S (moved) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/start/start.S (moved) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/timerisr.S (moved) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/videoAsm.S (moved) * c/src/lib/libbsp/i386/pc386/start/start.S (moved) * c/src/lib/libbsp/i386/pc386/start/start16.S (moved) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (moved) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/timerisr.S (moved) * c/src/lib/libbsp/i386/shared/irq/irq_asm.S (moved) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/start.S (moved) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/timerisr.S (moved) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/timerisr.S (moved) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start/start.S (moved) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start302/start302.S (moved) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/timerisr.S (moved) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/console/Modif_cpu_asm.S (moved) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start/start.S (moved) * c/src/lib/libbsp/m68k/gen68340/start/startfor340only.S (moved) * c/src/lib/libbsp/m68k/gen68340/start340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start340/start340.S (moved) * c/src/lib/libbsp/m68k/gen68340/start340/startfor340only.S (moved) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/start.S (moved) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start360/start360.S (moved) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/timerisr.S (moved) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/timerisr.S (moved) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/timerisr.s (deleted) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/timerisr.S (moved) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/timerisr.S (moved) * c/src/lib/libbsp/m68k/shared/start.S (moved) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/start.S (moved) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/dlentry.S (moved) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/flashentry.S (moved) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/dlentry.S (moved) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/flashentry.S (moved) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/console/consupp.S (moved) * c/src/lib/libbsp/powerpc/psim/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/start/start.S (moved) * c/src/lib/libbsp/powerpc/psim/startsim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startsim/startsim.S (moved) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/vectors/align_h.S (moved) * c/src/lib/libbsp/powerpc/psim/vectors/vectors.S (moved) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/start.S (moved) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/start.S (moved) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startsis/startsis.S (moved) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/milli.S (moved) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/bindec.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/binstr.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/bugfix.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/decbin.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/do_func.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/gen_except.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/get_op.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/kernel_ex.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/res_func.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/round.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/rtems_skel.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/sacos.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/sasin.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/satan.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/satanh.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/scale.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/scosh.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/setox.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/sgetem.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/sint.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/slog2.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/slogn.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/smovecr.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/srem_mod.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/ssin.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/ssinh.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/stan.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/stanh.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/sto_res.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/stwotox.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/tbldo.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/util.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_bsun.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_fline.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_operr.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_ovfl.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_snan.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_store.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_unfl.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_unimp.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_unsupp.S (moved) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/align_h.S (moved) * c/src/lib/libcpu/powerpc/ppc403/vectors/vectors.S (moved) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/console/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/window.S (moved) * c/src/lib/librdbg/i386/rdbg_cpu_asm.S (moved) * c/src/lib/start/a29k/Makefile.in (modified) * c/src/lib/start/a29k/crt0.S (added) * c/src/lib/start/a29k/register.S (added) * c/src/lib/start/i960/Makefile.in (modified) * c/src/lib/start/i960/start.S (added) * c/src/lib/start/m68k/Makefile.in (modified) * c/src/lib/start/m68k/start.S (added) * c/src/lib/start/mips64orion/Makefile.in (modified) * c/src/lib/start/sh/Makefile.in (modified) * c/src/lib/start/sh/start.S (added) * c/src/librdbg/src/i386/rdbg_cpu_asm.S (moved) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * cpukit/score/cpu/a29k/cpu_asm.S (added) * cpukit/score/cpu/a29k/sig.S (added) * cpukit/score/cpu/hppa1.1/cpu_asm.S (added) * cpukit/score/cpu/i386/cpu_asm.S (added) * cpukit/score/cpu/i960/cpu_asm.S (added) * cpukit/score/cpu/m68k/cpu_asm.S (added) * cpukit/score/cpu/sparc/cpu_asm.S (added) * make/Templates/Makefile.leaf (modified) * make/Templates/Makefile.lib (modified) * make/compilers/gcc-target-default.cfg (modified) Patch from Ralf Corsepius to rename all .s ...
