# # ChangeLog for c/src/lib/libchip in rtems # # Generated by Trac 1.2.1.dev0 # 04/24/24 14:44:38 Fri, 11 Sep 1998 23:35:09 GMT Joel Sherrill [bfcf4cb3] * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.c (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.h (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/z85c30.c (modified) * make/custom/dmv177.cfg (modified) Updates to tree to make it build with all desired changes and the ... Thu, 13 Aug 1998 15:52:40 GMT Joel Sherrill [70502bc4] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Don't disable the RX/TX on close in polled mode. Fixed a comment. Wed, 05 Aug 1998 23:57:35 GMT Joel Sherrill [0eb85ae] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/z85c30.c (modified) Commented out the code which yields the CPU when the serial ... Thu, 30 Jul 1998 21:30:46 GMT Joel Sherrill [d9bc023a] * c/src/lib/libchip/rtc/STATUS (modified) * c/src/libchip/rtc/STATUS (modified) Updated. Thu, 30 Jul 1998 19:51:03 GMT Joel Sherrill [192a1e0] * c/src/lib/libchip/rtc/README.ds1643 (added) * c/src/lib/libchip/rtc/README.m48t18 (added) * c/src/lib/libchip/serial/README.ns16550 (added) * c/src/lib/libchip/serial/README.xr88681 (added) * c/src/libchip/rtc/README.ds1643 (added) * c/src/libchip/rtc/README.m48t18 (added) * c/src/libchip/serial/README.ns16550 (added) * c/src/libchip/serial/README.xr88681 (added) New files. Wed, 29 Jul 1998 00:18:11 GMT Joel Sherrill [c95e927] * c/src/lib/libchip/rtc/icm7170.h (modified) * c/src/lib/libchip/rtc/icm7170_reg.c (modified) * c/src/lib/libchip/rtc/m48t08.h (modified) * c/src/lib/libchip/rtc/m48t08_reg.c (modified) * c/src/libchip/rtc/icm7170.h (modified) * c/src/libchip/rtc/icm7170_reg.c (modified) * c/src/libchip/rtc/m48t08.h (modified) * c/src/libchip/rtc/m48t08_reg.c (modified) Added prototype for default register access routines to header files. ... Wed, 29 Jul 1998 00:04:02 GMT Joel Sherrill [fb339a8] * c/src/lib/libchip/rtc/rtc.h (modified) * c/src/libchip/rtc/rtc.h (modified) Deleted probe routine as device specific. Renamed port table. Wed, 29 Jul 1998 00:03:12 GMT Joel Sherrill [866c9dd5] * c/src/lib/libchip/rtc/m48t08.h (modified) * c/src/libchip/rtc/m48t08.h (modified) Added function table. Wed, 29 Jul 1998 00:03:07 GMT Joel Sherrill [cb5e6f68] * c/src/lib/libchip/rtc/m48t08.c (modified) * c/src/libchip/rtc/m48t08.c (modified) Renamed control register constants. Set time->ticks to 0. Added ... Wed, 29 Jul 1998 00:02:11 GMT Joel Sherrill [1177cda] * c/src/lib/libchip/rtc/icm7170.c (added) * c/src/lib/libchip/rtc/icm7170.h (added) * c/src/libchip/rtc/icm7170.c (added) * c/src/libchip/rtc/icm7170.h (added) New files for Harris Semiconductor ICM7170. Wed, 29 Jul 1998 00:01:56 GMT Joel Sherrill [8d6e7120] * c/src/lib/libchip/rtc/README.icm7170 (added) * c/src/lib/libchip/rtc/README.m48t08 (added) * c/src/lib/libchip/rtc/STATUS (added) * c/src/lib/libchip/rtc/icm7170_reg.c (added) * c/src/lib/libchip/rtc/icm7170_reg2.c (added) * c/src/lib/libchip/rtc/icm7170_reg4.c (added) * c/src/lib/libchip/rtc/icm7170_reg8.c (added) * c/src/lib/libchip/rtc/m48t08_reg.c (added) * c/src/lib/libchip/rtc/m48t08_reg2.c (added) * c/src/lib/libchip/rtc/m48t08_reg4.c (added) * c/src/lib/libchip/rtc/m48t08_reg8.c (added) * c/src/libchip/rtc/README.icm7170 (added) * c/src/libchip/rtc/README.m48t08 (added) * c/src/libchip/rtc/STATUS (added) * c/src/libchip/rtc/icm7170_reg.c (added) * c/src/libchip/rtc/icm7170_reg2.c (added) * c/src/libchip/rtc/icm7170_reg4.c (added) * c/src/libchip/rtc/icm7170_reg8.c (added) * c/src/libchip/rtc/m48t08_reg.c (added) * c/src/libchip/rtc/m48t08_reg2.c (added) * c/src/libchip/rtc/m48t08_reg4.c (added) * c/src/libchip/rtc/m48t08_reg8.c (added) New files. Wed, 29 Jul 1998 00:01:44 GMT Joel Sherrill [677943a] * c/src/lib/libchip/rtc/Makefile.in (modified) * c/src/libchip/rtc/Makefile.in (modified) Added new files. Tue, 28 Jul 1998 23:03:40 GMT Joel Sherrill [a1f514f] * c/src/lib/libchip/rtc/Makefile.in (modified) * c/src/lib/libchip/rtc/m48t08.c (added) * c/src/lib/libchip/rtc/m48t08.h (added) * c/src/lib/libchip/rtc/rtc.h (modified) * c/src/lib/libchip/rtc/rtcprobe.c (added) * c/src/libchip/rtc/Makefile.in (modified) * c/src/libchip/rtc/m48t08.c (added) * c/src/libchip/rtc/m48t08.h (added) * c/src/libchip/rtc/rtc.h (modified) * c/src/libchip/rtc/rtcprobe.c (added) First cut implementation of real-time clock support in libchip. This ... Tue, 28 Jul 1998 21:18:17 GMT Joel Sherrill [009c235] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/serial.h (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/serial.h (modified) Corrected spacing. Tue, 28 Jul 1998 21:18:11 GMT Joel Sherrill [07e91808] * c/src/lib/libchip/Makefile.in (modified) * c/src/lib/libchip/rtc/Makefile.in (added) * c/src/lib/libchip/rtc/rtc.h (added) * c/src/libchip/rtc/Makefile.in (added) * c/src/libchip/rtc/rtc.h (added) Added rtc directory. Sat, 25 Jul 1998 17:22:58 GMT Joel Sherrill [749c54e] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/z85c30.c (modified) Added comments and corrected spacing. Sat, 25 Jul 1998 17:19:45 GMT Joel Sherrill [cae0504] * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550.c (modified) Corrected spacing and added headers. Sat, 25 Jul 1998 17:17:46 GMT Joel Sherrill [8739322] * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/lib/libchip/serial/ns16550_p.h (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550_p.h (modified) Added ns16550_set_attributes. Sat, 25 Jul 1998 17:17:36 GMT Joel Sherrill [b636d56] * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/z85c30.c (modified) Corrected spacing and added a comment. Sat, 25 Jul 1998 17:17:05 GMT Joel Sherrill [ccfa60b] * c/src/lib/libchip/serial/STATUS (modified) * c/src/libchip/serial/STATUS (modified) Updated to reflect set attributes. Sat, 25 Jul 1998 16:53:21 GMT Joel Sherrill [70a9451] * c/src/lib/libchip/serial/STATUS (modified) * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/lib/libchip/serial/ns16550_p.h (modified) * c/src/libchip/serial/STATUS (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550_p.h (modified) Rewrote NS16550 TX interrupt processing to use termios for the buffer ... Sat, 25 Jul 1998 16:52:17 GMT Joel Sherrill [adedb057] * c/src/lib/libchip/serial/serial.h (modified) * c/src/libchip/serial/serial.h (modified) Removed TX ring buffer. Sat, 25 Jul 1998 16:52:00 GMT Joel Sherrill [cb27f05] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/z85c30.c (modified) Changed variable to hold received data to unsigned. Sat, 25 Jul 1998 16:20:33 GMT Joel Sherrill [dfb16ce] * c/src/lib/libchip/serial/z85c30_p.h (modified) * c/src/libchip/serial/z85c30_p.h (modified) Added constants for z85c30_enable_interrupts. Sat, 25 Jul 1998 16:20:14 GMT Joel Sherrill [04c5ac7] * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/z85c30.c (modified) Removed z85c30_flush(). Reworked transmit interrupt processing to ... Sat, 25 Jul 1998 16:18:46 GMT Joel Sherrill [c1da250] * c/src/lib/libchip/serial/serial.h (modified) * c/src/libchip/serial/serial.h (modified) Changed comment on TxBuffer. Sat, 25 Jul 1998 16:18:27 GMT Joel Sherrill [b070d69a] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/mc68681_p.h (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681_p.h (modified) Removed mc68681_flush and corrected spacing. Sat, 25 Jul 1998 16:17:33 GMT Joel Sherrill [f600da3f] * c/src/lib/libchip/serial/STATUS (modified) * c/src/libchip/serial/STATUS (modified) Added information on Chris Johns' suggestion to use pointers ... Sat, 25 Jul 1998 16:02:21 GMT Joel Sherrill [da8ac60a] * c/src/lib/libchip/serial/STATUS (added) * c/src/libchip/serial/STATUS (added) New file. Sat, 25 Jul 1998 14:51:57 GMT Joel Sherrill [c68b990] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Changed to utilize return status from ... Sat, 25 Jul 1998 14:13:34 GMT Joel Sherrill [f246caf] * c/src/lib/libchip/serial/z85c30_reg.c (modified) * c/src/libchip/serial/z85c30_reg.c (modified) Interrupts were incorrectly managed with a disable/disable pair ... Sat, 18 Jul 1998 18:35:34 GMT Joel Sherrill [c14a619] * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/lib/libchip/serial/z85c30_reg.c (modified) * c/src/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/z85c30_reg.c (modified) Removed use of data port for z8530. Move some code around. Thu, 16 Jul 1998 00:16:22 GMT Joel Sherrill [16d0e63] * c/src/lib/libchip/serial/mc68681_baud.c (modified) * c/src/libchip/serial/mc68681_baud.c (modified) Corrected header files. Thu, 16 Jul 1998 00:16:11 GMT Joel Sherrill [a6f441b] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Minor corrections for typos to get it to compile. Thu, 16 Jul 1998 00:03:01 GMT Joel Sherrill [dd5d2f04] * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libchip/serial/README.mc68681 (modified) * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/lib/libchip/serial/mc68681_baud.c (added) * c/src/libchip/serial/Makefile.in (modified) * c/src/libchip/serial/README.mc68681 (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681_baud.c (added) Split default baud rate table into its own file. This shrinks the ... Wed, 15 Jul 1998 23:57:41 GMT Joel Sherrill [849dc107] * c/src/lib/libchip/serial/mc68681_reg.c (modified) * c/src/lib/libchip/serial/mc68681_reg2.c (modified) * c/src/lib/libchip/serial/mc68681_reg4.c (modified) * c/src/lib/libchip/serial/mc68681_reg8.c (modified) * c/src/libchip/serial/mc68681_reg.c (modified) * c/src/libchip/serial/mc68681_reg2.c (modified) * c/src/libchip/serial/mc68681_reg4.c (modified) * c/src/libchip/serial/mc68681_reg8.c (modified) Fixed typos. Wed, 15 Jul 1998 23:54:24 GMT Joel Sherrill [8414c033] * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libchip/serial/z85c30.h (modified) * c/src/lib/libchip/serial/z85c30_reg.c (added) * c/src/libchip/serial/Makefile.in (modified) * c/src/libchip/serial/z85c30.h (modified) * c/src/libchip/serial/z85c30_reg.c (added) Added default z85c30 register access routines. Wed, 15 Jul 1998 23:54:08 GMT Joel Sherrill [cce9322] * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/lib/libchip/serial/mc68681_reg.c (added) * c/src/lib/libchip/serial/mc68681_reg2.c (added) * c/src/lib/libchip/serial/mc68681_reg4.c (added) * c/src/lib/libchip/serial/mc68681_reg8.c (added) * c/src/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681_reg.c (added) * c/src/libchip/serial/mc68681_reg2.c (added) * c/src/libchip/serial/mc68681_reg4.c (added) * c/src/libchip/serial/mc68681_reg8.c (added) Added default mc68681 register access routines. Wed, 15 Jul 1998 23:21:55 GMT Joel Sherrill [991a1ab4] * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/z85c30.c (modified) Added check for proper deviceType to interrupt processing code. Wed, 15 Jul 1998 23:21:30 GMT Joel Sherrill [efaf85fa] * c/src/lib/libchip/serial/mc68681_p.h (modified) * c/src/libchip/serial/mc68681_p.h (modified) Added interrupt mask and interrupt status register bit constants. ... Wed, 15 Jul 1998 23:20:50 GMT Joel Sherrill [49370cd] * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681.h (modified) Added default mc68681 register access routines. Wed, 15 Jul 1998 23:20:33 GMT Joel Sherrill [198d851] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Switched from driver's own buffering to using termios. This ... Wed, 15 Jul 1998 23:15:49 GMT Joel Sherrill [27a66bd] * c/src/lib/libchip/serial/README.mc68681 (modified) * c/src/lib/libchip/serial/README.z85c30 (modified) * c/src/libchip/serial/README.mc68681 (modified) * c/src/libchip/serial/README.z85c30 (modified) Added information on the deviceType field. Wed, 15 Jul 1998 23:15:32 GMT Joel Sherrill [66f95fc] * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) Added default mc68681 register access routines. Wed, 15 Jul 1998 21:40:42 GMT Joel Sherrill [c0573d7] * c/src/lib/libchip/serial/serial.h (modified) * c/src/libchip/serial/serial.h (modified) Added comment to remove use of TxBuffer ring buffer in all libchip ... Wed, 15 Jul 1998 13:58:23 GMT Joel Sherrill [be8cbbf] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Switched deviceOutputUsesInterrupts to TRUE so output would be ... Wed, 15 Jul 1998 13:53:58 GMT Joel Sherrill [e283140c] * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/z85c30.c (modified) Switched to "deviceOutput = TRUE" which made device output use ... Thu, 09 Jul 1998 23:32:07 GMT Joel Sherrill [fb32356b] * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/lib/libchip/serial/z85c30_p.h (modified) * c/src/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/z85c30_p.h (modified) Added set attributes routine but did not hook it in to the table. ... Thu, 09 Jul 1998 23:31:48 GMT Joel Sherrill [abd8c82] * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) Added new files. Thu, 09 Jul 1998 23:31:26 GMT Joel Sherrill [31cad72c] * c/src/lib/libchip/serial/sersupp.c (deleted) Renamed so we could have one file per routine. Thu, 09 Jul 1998 23:30:32 GMT Joel Sherrill [064b9be] * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550.c (modified) Switched to shared default probe routine. Thu, 09 Jul 1998 23:30:02 GMT Joel Sherrill [693b5b88] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Switched to default probe routine. Thu, 09 Jul 1998 23:29:33 GMT Joel Sherrill [61ff7ac8] * c/src/lib/libchip/serial/serprobe.c (added) * c/src/lib/libchip/serial/sersupp.h (modified) * c/src/lib/libchip/serial/termios_baud2index.c (added) * c/src/lib/libchip/serial/termios_baud2num.c (added) * c/src/libchip/serial/serprobe.c (added) * c/src/libchip/serial/sersupp.h (modified) * c/src/libchip/serial/termios_baud2index.c (added) * c/src/libchip/serial/termios_baud2num.c (added) Added new baud rate to number function and default serial probe ... Thu, 09 Jul 1998 22:21:54 GMT Joel Sherrill [e78c474b] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Added proper handling of extended baud rate table selection at boot ... Thu, 09 Jul 1998 22:16:27 GMT Joel Sherrill [2c5ea01] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Properly handle extended baud rate set commands. Temporarily "if 0" ... Thu, 09 Jul 1998 22:11:49 GMT Joel Sherrill [e3c59dd] * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681.h (modified) Corrected definition of MC68681_RX_BUFFER. Thu, 09 Jul 1998 18:45:28 GMT Joel Sherrill [2d8e51aa] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Changed static to MC68681_STATIC to make all data and routines ... Thu, 09 Jul 1998 18:44:10 GMT Joel Sherrill [b2ec38c8] * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681.h (modified) Removed commented out line. Thu, 09 Jul 1998 18:41:49 GMT Joel Sherrill [8f6f641e] * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) Added sersupp.c. Thu, 09 Jul 1998 18:41:33 GMT Joel Sherrill [d94d47b3] * c/src/lib/libchip/serial/sersupp.c (added) * c/src/lib/libchip/serial/sersupp.h (added) * c/src/libchip/serial/sersupp.h (added) New files to contain generally needed serial driver support routines. Thu, 09 Jul 1998 18:40:27 GMT Joel Sherrill [37e8259] * c/src/lib/libchip/serial/mc68681_p.h (modified) * c/src/libchip/serial/mc68681_p.h (modified) Changed static to MC68681_STATIC to make all routines and data global ... Thu, 09 Jul 1998 18:39:50 GMT Joel Sherrill [8b2492f] * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681.h (modified) Added support for the Extended Baud Rate set control found in the ... Thu, 09 Jul 1998 18:38:18 GMT Joel Sherrill [27045a82] * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/lib/libchip/serial/ns16550_p.h (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550_p.h (modified) Changed static to NS16550_STATIC to make all routines and data global ... Thu, 09 Jul 1998 18:37:47 GMT Joel Sherrill [677a503] * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/lib/libchip/serial/z85c30_p.h (modified) * c/src/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/z85c30_p.h (modified) Changed static to Z85C30_STATIC so all data and routines could be ... Thu, 09 Jul 1998 18:36:19 GMT Joel Sherrill [80b1c2f] * c/src/lib/libchip/serial/README (added) * c/src/lib/libchip/serial/README.mc68681 (modified) * c/src/lib/libchip/serial/README.z85c30 (added) * c/src/libchip/serial/README (added) * c/src/libchip/serial/README.mc68681 (modified) * c/src/libchip/serial/README.z85c30 (added) Added information to README.mc68681. Created the basic README and ... Sun, 05 Jul 1998 11:04:31 GMT Joel Sherrill [5ae415b] * c/src/lib/libchip/serial/serial.h (modified) * c/src/libchip/serial/serial.h (modified) Added include of termios.h. Also added a block of comments above ... Tue, 23 Jun 1998 17:42:46 GMT Joel Sherrill [4f0ffa57] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/lib/libchip/serial/mc68681_p.h (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681_p.h (modified) Removed RTS and DTR handling code since the MC68681 seems to only ... Tue, 23 Jun 1998 17:40:00 GMT Joel Sherrill [ae21568c] * c/src/lib/libchip/serial/README.mc68681 (added) * c/src/libchip/serial/README.mc68681 (added) New file describing mc68681 libchip driver. Tue, 23 Jun 1998 16:02:52 GMT Joel Sherrill [beaaf49f] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Added numerous comments. Tue, 23 Jun 1998 15:54:33 GMT Joel Sherrill [a5d0c7c] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/lib/libchip/serial/mc68681_p.h (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681_p.h (modified) Added concept of "mate" -- the other port on the same DUART. This is ... Tue, 23 Jun 1998 14:59:26 GMT Joel Sherrill [b7ebcea3] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Added close. Tue, 23 Jun 1998 14:55:21 GMT Joel Sherrill [25c3ff91] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.c (modified) Added set attributes and written initialize and first open. Tue, 23 Jun 1998 14:54:42 GMT Joel Sherrill [790d421] * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681.h (modified) Added more registers. Tue, 23 Jun 1998 14:54:30 GMT Joel Sherrill [9eef52b] * c/src/lib/libchip/serial/mc68681_p.h (modified) * c/src/libchip/serial/mc68681_p.h (modified) Added set attributes prototype. Tue, 23 Jun 1998 14:54:09 GMT Joel Sherrill [8a2d4f2b] * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/lib/libchip/serial/serial.h (modified) * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/serial.h (modified) * c/src/libchip/serial/z85c30.c (modified) Added NULL entry for setAttributes. Mon, 22 Jun 1998 11:49:38 GMT Joel Sherrill [7deeb16] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.h (modified) Added initial part of iniitialization. Mon, 22 Jun 1998 11:09:32 GMT Joel Sherrill [ab2dbd7] * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/mc68681.h (modified) * c/src/lib/libchip/serial/mc68681_p.h (modified) * c/src/libchip/serial/Makefile.in (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681_p.h (modified) Added mc68681 stuff to the makefile. Added numerous constants to ... Mon, 22 Jun 1998 11:08:16 GMT Joel Sherrill [36152b0e] * c/src/lib/libchip/serial/serial.h (modified) * c/src/libchip/serial/serial.h (modified) Moved get and set register/data typedefs to this file. Mon, 22 Jun 1998 11:07:51 GMT Joel Sherrill [4cd4c5a] * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/lib/libchip/serial/ns16550.h (modified) * c/src/lib/libchip/serial/ns16550_p.h (modified) * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550.h (modified) * c/src/libchip/serial/ns16550_p.h (modified) * c/src/libchip/serial/z85c30.c (modified) Moved set and get Register and Data type defininitions to serial.h. ... Mon, 22 Jun 1998 10:34:34 GMT Joel Sherrill [58b1e95] * c/src/lib/libchip/serial/serial.h (modified) * c/src/libchip/serial/serial.h (modified) Corrected spacing Mon, 22 Jun 1998 10:17:14 GMT Joel Sherrill [424e23ee] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/mc68681_p.h (modified) * c/src/lib/libchip/serial/serial.h (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681_p.h (modified) * c/src/libchip/serial/serial.h (modified) spacing changes Mon, 22 Jun 1998 09:59:22 GMT Joel Sherrill [e4acf68] * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/lib/libchip/serial/z85c30.h (modified) * c/src/lib/libchip/serial/z85c30_p.h (modified) * c/src/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/z85c30.h (modified) * c/src/libchip/serial/z85c30_p.h (modified) Added comments and corrected spacing. Mon, 22 Jun 1998 09:56:09 GMT Joel Sherrill [aa0da6b] * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/lib/libchip/serial/ns16550_p.h (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550_p.h (modified) Added a comment and cleaned up spacing Mon, 22 Jun 1998 09:28:03 GMT Joel Sherrill [cd58d82] * c/src/lib/libchip/serial/mc68681.c (added) * c/src/lib/libchip/serial/mc68681.h (added) * c/src/lib/libchip/serial/mc68681_p.h (added) * c/src/libchip/serial/mc68681.c (added) * c/src/libchip/serial/mc68681.h (added) * c/src/libchip/serial/mc68681_p.h (added) Initial version of these files. Sat, 13 Jun 1998 16:03:57 GMT Joel Sherrill [ee3b242b] * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/lib/libchip/serial/serial.h (added) * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/Makefile.in (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/serial.h (added) * c/src/libchip/serial/z85c30.c (modified) Initial incarnation of libchip compiles. Sat, 13 Jun 1998 15:48:25 GMT Joel Sherrill [0737710] * c/src/lib/libchip/Makefile.in (added) * c/src/lib/libchip/serial/Makefile.in (added) * c/src/lib/libchip/serial/ns16550.c (added) * c/src/lib/libchip/serial/ns16550.h (added) * c/src/lib/libchip/serial/ns16550_p.h (added) * c/src/lib/libchip/serial/z85c30.c (added) * c/src/lib/libchip/serial/z85c30.h (added) * c/src/lib/libchip/serial/z85c30_p.h (added) * c/src/libchip/serial/Makefile.in (added) * c/src/libchip/serial/ns16550.c (added) * c/src/libchip/serial/ns16550.h (added) * c/src/libchip/serial/ns16550_p.h (added) * c/src/libchip/serial/z85c30.c (added) * c/src/libchip/serial/z85c30.h (added) * c/src/libchip/serial/z85c30_p.h (added) Base code from ppcn_60x BSP
