@d3b34d2
10/22/98 16:15:40 |
Joel Sherrill |
Changed all of these to stubs.
4.104.114.84.95
@0cd2bd96
10/13/98 18:04:16 |
Joel Sherrill |
Added rest of opendir family and made it compile.
4.104.114.84.95
@928395e
10/13/98 16:07:38 |
Joel Sherrill |
New files.
4.104.114.84.95
@fbd5320
10/13/98 14:59:35 |
Joel Sherrill |
Modified to avoid building certain files under UNIX.
4.104.114.84.95
@22bb7cd1
10/12/98 17:28:33 |
Joel Sherrill |
New files.
4.104.114.84.95
@d2018142
10/12/98 17:23:28 |
Joel Sherrill |
Removed fork(), execv(), and wait() since they are now stubbed in the …
4.104.114.84.95
@f7f64f6
10/12/98 17:23:03 |
Joel Sherrill |
Added opendir and readdir.
4.104.114.84.95
@388be68f
10/01/98 21:44:31 |
Joel Sherrill |
Patch from Ian Lance Taylor <ian@…>:
The reentrant …
4.104.114.84.95
@3b93a2de
09/23/98 16:34:23 |
Joel Sherrill |
Modifed to zero out the C heap if the CPU Table indicates that the …
4.104.114.84.95
@8a496e46
09/23/98 13:20:34 |
Joel Sherrill |
Patch from Aleksey (Quality Quorum <qqi@…>):
1. …
4.104.114.84.95
@30ba752
09/21/98 00:01:26 |
Joel Sherrill |
Patch from Eric Norum:
I fixed the problems noted by Victor …
4.104.114.84.95
@d9d75fc
08/31/98 23:06:50 |
Joel Sherrill |
Patch from Emmanuel Raguet <raguet@…>:
I have reworked …
4.104.114.84.95
@85734b3
08/31/98 22:53:42 |
Joel Sherrill |
Patch from Eric Norum <eric@…>:
I think I figured …
4.104.114.84.95
@b3fd1641
08/21/98 15:32:19 |
Joel Sherrill |
Fix from Eric Norum <eric@…>:
"Thomas Doerfler" …
4.104.114.84.95
@bbdab89
08/21/98 12:52:08 |
Joel Sherrill |
Added initialization of missing termios structure entries.
4.104.114.84.95
@bd7c547
07/28/98 16:49:36 |
Joel Sherrill |
Closed window thanks to patch from Eric Norum.
4.104.114.84.95
@4555bc1e
07/17/98 22:34:54 |
Joel Sherrill |
Initialized tty->refcount to 0. When (for whatever reason) malloc() …
4.104.114.84.95
@6e65840
07/17/98 13:05:03 |
Joel Sherrill |
Patch from Dario Alcocer <alcocer@…>. His comments:
4.104.114.84.95
@270d58f
07/06/98 19:00:33 |
Joel Sherrill |
New file to satisfy readdir() family.
4.104.114.84.95
@a05de51
07/01/98 21:33:38 |
Joel Sherrill |
Added _stat_r and changed spacing.
4.104.114.84.95
@9a6994b4
06/18/98 15:22:35 |
Joel Sherrill |
Added freebsd support from Dario Alcocer <alcocer@…>.
4.104.114.84.95
@ce691c51
06/18/98 15:14:48 |
Joel Sherrill |
Corrected so it returns the correct date. Previously was getting the …
4.104.114.84.95
@64be9d4
06/02/98 17:38:16 |
Joel Sherrill |
Added some missing files per Eric Norum.
4.104.114.84.95
@119bced
05/22/98 14:51:11 |
Joel Sherrill |
Added tcdrain(), cfgetospeed(0, cfsetospeed(), cfgetispeed(), and …
4.104.114.84.95
@27dccae
05/20/98 17:09:12 |
Joel Sherrill |
Patch to add return status to rtems_termios_enqueue_raw_characters …
4.104.114.84.95
@603d706
05/20/98 17:00:22 |
Joel Sherrill |
Added tcdrain() from Eric Norum
4.104.114.84.95
@9c3b406b
05/19/98 11:34:04 |
Joel Sherrill |
Addition of tcdrain() from Eric Norum.
4.104.114.84.95
@3ac8e59c
05/19/98 10:53:12 |
Joel Sherrill |
Removed prototype of rtems_libio_config() per Chris Johns' eagle eye.
4.104.114.84.95
@c4638fff
05/11/98 17:39:59 |
Joel Sherrill |
new file to support execv family support in newlib
4.104.114.84.95
@d37ea462
05/11/98 17:39:38 |
Joel Sherrill |
execv*() now comes from newlib.
4.104.114.84.95
@161e1b3f
05/04/98 12:41:07 |
Joel Sherrill |
Patch from Eric Norum to switch to termios callback structure, add …
4.104.114.84.95
@edbb81d0
04/27/98 14:39:51 |
Joel Sherrill |
Removed redundant implementation of tcgetattr and tcsetattr.
4.104.114.84.95
@4955afc
04/18/98 17:25:35 |
Joel Sherrill |
rtems_libio_number_iops is now defined in confdefs.h so the maximum …
4.104.114.84.95
@bd9c3d1
04/15/98 20:50:31 |
Joel Sherrill |
Numerous changes which in total greatly reduced the amount of source …
4.104.114.84.95
@c796ea9
04/06/98 15:57:58 |
Joel Sherrill |
More stuff removed as a result of using newlib's isatty() …
4.104.114.84.95
@b82c957
04/03/98 18:45:42 |
Joel Sherrill |
Removed isatty() since we are now using newlib's implementation as
a …
4.104.114.84.95
@ece79bb1
03/27/98 21:08:59 |
Joel Sherrill |
GO32 does not have sockets.
4.104.114.84.95
@3973e40
03/27/98 16:34:25 |
Joel Sherrill |
Should have included <rtems.h> before checking for ifdef RTEMS_UNIX. …
4.104.114.84.95
@725f310
03/20/98 16:28:36 |
Joel Sherrill |
Removed blank line.
4.104.114.84.95
@60b791ad
02/17/98 23:46:28 |
Joel Sherrill |
updated copyright to 1998
4.104.114.84.95
@9646d5be
02/17/98 18:46:38 |
Joel Sherrill |
I've gone through …
4.104.114.84.95
@f00d7ad
02/03/98 18:30:05 |
Joel Sherrill |
Added call to libc_wrapup() in _exit. This fixes a problem where
the …
4.104.114.84.95
@5c3511e
01/30/98 21:49:51 |
Joel Sherrill |
Big patch form Ralf Corsepius described in this email:
Here is the …
4.104.114.84.95
@421dfef6
01/30/98 20:59:22 |
Joel Sherrill |
Corrected Linux port for glibc2
4.104.114.84.95
@2936b425
01/23/98 17:45:05 |
Joel Sherrill |
Solaris port updates from Chris Johns
4.104.114.84.95
@3294650
01/19/98 22:31:23 |
Joel Sherrill |
Added _times_r.
4.104.114.84.95
@866c465f
01/19/98 22:27:56 |
Joel Sherrill |
more info from Eric
4.104.114.84.95
@4dc0fd6
01/19/98 22:22:25 |
Joel Sherrill |
With this in place, it is possible to fdopen …
4.104.114.84.95
@3a7782b
01/16/98 15:37:20 |
Joel Sherrill |
Jennifer found some uninitialized variables:
+ major and minor …
4.104.114.84.95
@2872e0b
01/06/98 15:47:37 |
Joel Sherrill |
Changed initial settings of first time.
4.104.114.84.95
@608641e
12/22/97 17:29:51 |
Joel Sherrill |
Corrected prototypes for all termios console write driver entries to …
4.104.114.84.95
@674c900
12/10/97 16:58:00 |
Joel Sherrill |
Modified a lot of files to take a first cut at supporting building …
4.104.114.84.95
@7150f00f
12/01/97 22:06:48 |
Joel Sherrill |
Inclusion of PC386 BSP submitted by Pedro Miguel Da Cruz Neto Romano …
4.104.114.84.95
@c7ca28cf
11/18/97 22:32:55 |
Joel Sherrill |
Removed warning under linux port.
4.104.114.84.95
@d24ceb3
11/15/97 18:15:36 |
Joel Sherrill |
interrupt driven change from Eric Norum
4.104.114.84.95
@a307f79
11/10/97 17:50:50 |
Joel Sherrill |
Fixed prototype
4.104.114.84.95
@52e1708
11/10/97 17:31:11 |
Joel Sherrill |
Set return code to avoid spurious errors.
4.104.114.84.95
@5a5bd13b
10/24/97 19:29:01 |
Joel Sherrill |
added katsutoshi Shibuya
4.104.114.84.95
@51eb8d5
10/23/97 18:49:34 |
Joel Sherrill |
Changed prototype of read routine.
4.104.114.84.95
@3ee825e8
10/23/97 15:00:32 |
Joel Sherrill |
fixed comment
4.104.114.84.95
@118a812
10/23/97 13:13:46 |
Joel Sherrill |
New termios.c from Eric Norum.
Added new entry point to add in per …
4.104.114.84.95
@a75c783
10/21/97 17:03:18 |
Joel Sherrill |
Converted from using a message queue for the raw input queue to using …
4.104.114.84.95
@55e1322
10/21/97 17:03:17 |
Joel Sherrill |
Added termios submission from Eric Norum and Katsutoshi Shibuya.
4.104.114.84.95
@ae35953d
10/21/97 16:18:03 |
Joel Sherrill |
4.104.114.84.95
@4fd61795
10/21/97 16:17:12 |
Joel Sherrill |
Added casts and fixed line break.
4.104.114.84.95
@98e4ebf5
10/08/97 15:45:54 |
Joel Sherrill |
Fixed typo in the pointer to the license terms.
4.104.114.84.95
@a2016b99
10/08/97 14:42:08 |
Joel Sherrill |
Removed include directory at "build" point and the link of this …
4.104.114.84.95
@f795ca90
09/21/97 17:44:50 |
Joel Sherrill |
Uncommented gettimeofday_r to resolve missing symbol.
4.104.114.84.95
@8f367d6b
09/19/97 18:31:05 |
Joel Sherrill |
Bug fix from Eric Norum:
After weeks of trying to figure why my …
4.104.114.84.95
@7d352a49
08/28/97 13:59:41 |
Joel Sherrill |
Added RTEMS_IO_ERROR status code.
4.104.114.84.95
@3473f605
08/27/97 20:33:49 |
Joel Sherrill |
Added error numbers and changed default error code from 0 to -1 for …
4.104.114.84.95
@b1459dc
08/22/97 19:17:09 |
Joel Sherrill |
Moved reentrant wrappers into their own file.
4.104.114.84.95
@78d87bd
08/22/97 19:16:47 |
Joel Sherrill |
Fixed iop/memory leak bug reported by Dan Dickey.
4.104.114.84.95
@1f581ec
08/01/97 20:57:21 |
Joel Sherrill |
Added include of termios.h which was accidentally left out.
4.104.114.84.95
@9deb5b8b
08/01/97 18:12:11 |
Joel Sherrill |
Katsutoshi Shibuya (shibuya@…)of BU-Denken Co., Ltd. …
4.104.114.84.95
@e71ce071
04/22/97 17:47:16 |
Joel Sherrill |
updated with new license information per Tony Bennett.
4.104.114.84.95
@03f2154e
04/22/97 17:20:27 |
Joel Sherrill |
headers updated to reflect new style copyright notice as part
of …
4.104.114.84.95
@334b01f1
04/16/97 17:46:26 |
Joel Sherrill |
fixed spacing
4.104.114.84.95
@e39e6f7
04/09/97 20:05:59 |
Joel Sherrill |
added code to prevent attempts to clean up the library when rtems is
down.
4.104.114.84.95
@e2d79559
04/09/97 14:05:50 |
Joel Sherrill |
Added ka9q tcpip stack and network driver for the gen68360. This …
4.104.114.84.95
@bd71da7
04/07/97 21:30:42 |
Joel Sherrill |
removed noreturn attribute to eliminate warnings.
4.104.114.84.95
@254b4450
04/01/97 23:07:52 |
Joel Sherrill |
This set of changes is the build of what was required to convert to …
4.104.114.84.95
@1dc3500
03/10/97 19:38:30 |
Joel Sherrill |
added include of rtems.h so the proper macro definitions would be present.
4.104.114.84.95
@41c58154
03/10/97 19:38:06 |
Joel Sherrill |
made some of this conditional on unix lib
4.104.114.84.95
@aea06ed
01/29/97 15:54:31 |
Joel Sherrill |
Modifications to make go32 build using new i386-go32-rtems toolset
and …
4.104.114.84.95
@dcec5a4
01/29/97 00:29:25 |
Joel Sherrill |
Merged newlib's libgloss support for rtems into this directory. This …
4.104.114.84.95
@c6126e57
01/08/97 16:21:38 |
Joel Sherrill |
removed assert() for stat on non-devices. Now it returns -1. This …
4.104.114.84.95
@331d9e3b
11/08/96 20:08:52 |
Joel Sherrill |
Added asserts for unhandled conditions which need to result in error …
4.104.114.84.95
@9e406d9
10/15/96 21:58:32 |
Joel Sherrill |
added ENOSYS support
4.104.114.84.95
@0c35efe
09/18/96 20:54:05 |
Joel Sherrill |
dummy function added to satisfy ANSI
4.104.114.84.95
@5e9a594
09/18/96 20:53:35 |
Joel Sherrill |
modified to support non-GNU compilers and to use calloc rather than …
4.104.114.84.95
@1f2d5df
09/18/96 20:52:47 |
Joel Sherrill |
added malloc_walk
miscellaneous corrections in casting.
4.104.114.84.95
@b1c215e
09/18/96 20:52:16 |
Joel Sherrill |
added prototype for malloc_walk
4.104.114.84.95
@4bab8e2d
08/06/96 17:45:12 |
Joel Sherrill |
get_errno: no longer needed by gnat runtime
4.104.114.84.95
@e21cf313
07/03/96 14:24:07 |
Joel Sherrill |
another attempt at the rtems_posix_api ifdef
4.104.114.84.95
@8d7a1d76
06/18/96 19:06:58 |
Joel Sherrill |
minor changes to insure the few posix-ish routines needed in non-posix …
4.104.114.84.95
@da4b6e8
06/12/96 22:50:03 |
Joel Sherrill |
use exit() from newlib by default.
4.104.114.84.95
@09b1f1a
06/06/96 17:57:39 |
Joel Sherrill |
patch from Tony Bennett on the ifdef for O_NDELAY
4.104.114.84.95
@685f4d65
06/03/96 18:59:24 |
Joel Sherrill |
sleep moved into newlibc.c so the sleep.o object would not be in the …
4.104.114.84.95
@b169590e
05/30/96 20:34:46 |
Joel Sherrill |
added dummy versions of kill and getpid which assert(0) so that …
4.104.114.84.95
