@d9af2ed4
08/20/12 08:15:20 |
thomas.doerfler |
bsp/gen83xx: Add br_uid BSP variant
4.115
@25802b42
08/13/12 13:32:03 |
Sebastian Huber |
bsp/lpc32xx: Specify scratch area alignment
4.115
@f5db5d2
08/13/12 13:24:03 |
Sebastian Huber |
bsp/lpc32xx: Stop unused DDRAM_CLK
4.115
@25a8c022
08/13/12 09:51:45 |
Sebastian Huber |
bsp/lpc32xx: Fix clock name
Rename lpc32xx_dram_clk() in …
4.115
@6cfe52f
07/25/12 13:51:21 |
Sebastian Huber |
bsp/lpc32xx: Add lpc32xx_select_nand_controller()
4.115
@833ac60
08/06/12 16:32:49 |
Sebastian Huber |
bsp/lpc24xx: Use USB RAM for fast data section
4.115
@ea97782
08/06/12 17:06:35 |
Gedare Bloom |
Delete leftover bspopts.h.in from revert
4.115
@c717fda5
08/06/12 17:03:46 |
Gedare Bloom |
Revert "Add bspopts.h.in."
This reverts commit …
4.115
@b0753c3
07/19/12 07:18:17 |
Sebastian Huber |
bsp/mpc55xx: Add MPC55XX_CONSOLE_MINOR
Remove MPC55XX_ESCI_CONSOLE_MINOR.
4.115
@89c92a0
07/19/12 07:08:07 |
Sebastian Huber |
bsp/mpc55xx: Whitespace changes
4.115
@208f479
07/19/12 07:05:46 |
Sebastian Huber |
bsp/mpc55xx: New EBI settings for MPC5674F boards
4.115
@0ec2c36
07/19/12 15:02:16 |
Ralf Corsepius |
Use http://www.rtems.org/bugzilla as bug-URL.
4.115
@d7af336
07/19/12 15:00:56 |
Ralf Corsepius |
Reformat AC_INIT.
4.115
@1c554014
07/19/12 14:14:53 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@59bd5115
07/19/12 13:59:46 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@bb2b825
07/19/12 13:47:55 |
Ralf Corsepius |
Require automake-1.12.2.
4.115
@0f77281
07/19/12 13:44:32 |
Ralf Corsepius |
Require autoconf-2.69.
4.115
@cece8db
07/17/12 15:41:21 |
Sebastian Huber |
bsp/mpc55xx: Add SMSC9218I_IRQ_PIN
4.115
@f024d4f
07/17/12 15:40:53 |
Sebastian Huber |
bsp/mpc55xx: Add SMSC9218I_RESET_PIN
4.115
@dec7231
07/17/12 15:39:00 |
Sebastian Huber |
bsp/mpc55xx: Add SMSC9218I_ENABLE_LED_OUTPUTS
4.115
@86c5b1c
07/17/12 15:23:31 |
Sebastian Huber |
bsp/mpc55xx: Add SMSC9218I_BIG_ENDIAN_SUPPORT
4.115
@d740e60
07/17/12 15:00:16 |
Sebastian Huber |
bsp/mpc55xx: New ECU508 BSPs
4.115
@64d72e8
07/17/12 15:51:46 |
Sebastian Huber |
bsp/mpc55xx: Add ESCI_C and ESCI_D support
4.115
@dafacfa7
07/18/12 07:26:13 |
Sebastian Huber |
bsp/mpc55xx: Add MPC55XX_SYSTEM_CLOCK_DIVIDER
4.115
@b9b3f3b7
07/18/12 07:20:46 |
Sebastian Huber |
bsp/mpc55xx: Add MPC55XX_NULL_POINTER_PROTECTION
4.115
@32ec0f6b
07/17/12 14:56:58 |
Sebastian Huber |
bsp/mpc55xx: Add MPC55XX_NEEDS_LOW_LEVEL_INIT
4.115
@356c928
04/03/12 12:35:55 |
Christian.Mauderer |
bsp/mpc55xx: Implement network interface off
4.115
@c838ca2d
03/29/12 08:58:10 |
christian.mauderer |
bsp/mpc55xx: Add bsp_restart()
4.115
@afcbd3b2
07/17/12 14:44:50 |
Sebastian Huber |
bsp/mpc55xx: Add output value to PCR config
4.115
@864cf50
07/17/12 21:20:01 |
Joel Sherrill |
mips/malta: Add sections for new FreeBSD TCP/IP stack
4.115
@c4547d81
07/17/12 21:19:44 |
Joel Sherrill |
mips/jmr3904: Add sections for new FreeBSD TCP/IP stack
4.115
@aae7daa9
07/16/12 08:56:30 |
Sebastian Huber |
Fix broken _endtext symbol
4.115
@93b1e4b
07/14/12 19:26:43 |
Joel Sherrill |
shsim linkcmds: Add new FreeBSD TCP/IP stack sections
4.115
@c2395717
07/14/12 19:26:20 |
Joel Sherrill |
sparc linkcmds.base: Add new FreeBSD TCP/IP stack sections
4.115
@c5ba8ba
07/09/12 08:44:47 |
xiangfu |
bsps/lm32: PR2045: Add mic boost option
4.115
@574ab8a
06/22/12 08:31:44 |
Sebastian Huber |
bsps/powerpc: Add more BSP sections and sort them
4.115
@a94bcc5a
06/15/12 11:44:08 |
Sebastian Huber |
bsp/lpc24xx: More flexible region configuration
4.115
@62b4fe1
06/15/12 11:07:52 |
Sebastian Huber |
bsp/lpc24xx: Fix timing for M29W320E70
4.115
@4e0755c8
06/15/12 07:51:14 |
Sebastian Huber |
bsp/lpc24xx: Add lpc24xx_module_is_enabled()
4.115
@696c451
06/12/12 07:53:52 |
Sebastian Huber |
bsp/lpc24xx: Ethernet support for EA LPC1788 board
4.115
@e7395c7
06/12/12 07:55:52 |
Sebastian Huber |
bsp/lpc24xx: Ethernet support for LPC17XX
4.115
@8462a96d
06/12/12 07:53:27 |
Sebastian Huber |
bsp/lpc24xx: Use external RAM
4.115
@3e600b2
06/13/12 11:54:36 |
Sebastian Huber |
bsp/lpc24xx: Use RAS and CAS of 2 for IS42S32800B
4.115
@e4bda046
06/11/12 12:48:42 |
Sebastian Huber |
bsp/lpc24xx: Simplify EMCDLYCTL handling
4.115
@f7deb58
06/11/12 06:51:32 |
Sebastian Huber |
bsp/lpc24xx: Simplify EMC configuration
4.115
@d40b09d
06/06/12 13:03:37 |
Sebastian Huber |
bsp/lpc24xx: New BSP variants (PLX800 on LPC1778)
4.115
@7329f55
06/06/12 12:48:23 |
Sebastian Huber |
bsps/arm: Rename linkcmds.armv7 to linkcmds.armv7m
4.115
@c39148d6
06/14/12 12:27:58 |
Sebastian Huber |
libchip: Add support for NS16550 with FDR
4.115
@50fc8f6
06/13/12 07:44:32 |
Sebastian Huber |
sapi: Add nanoseconds_per_tick to configuration
Add …
4.115
@fd153c73
06/12/12 13:27:17 |
Sebastian Huber |
bsps: Replace NIRVANA region
Replace the "NIRVANA" region with the …
4.115
@2d7ae960
06/11/12 18:37:29 |
Joel Sherrill |
v850 port: Initial addition with BSP for simulator in GDB
Port
4.115
@eb1951a
05/22/12 15:21:28 |
Sebastian Huber |
powerpc/mpc55xx: BSP variant changes for MPC5643L
4.115
@5bd7bd5a
06/04/12 11:26:34 |
Sebastian Huber |
bsp/t32mppc: Fix Trace32 configuration file
4.115
@6273201
05/31/12 14:37:02 |
Sebastian Huber |
bsps/powerpc: Add load section for .nocache
4.115
@105ccdd5
05/21/12 08:34:23 |
Sebastian Huber |
bsp/qoriq: New BSP option
New BSP option BSP_USE_DATA_CACHE_BLOCK_TOUCH.
4.115
@721fe34
05/31/12 20:34:36 |
Joel Sherrill |
Fix C files which had two semi-colons at EOL
4.115
@bb08c0c8
05/30/12 18:10:43 |
Jennifer Averett |
pc386: Added sections for rtems-libbsd support.
4.115
@daffa60
05/24/12 04:36:40 |
Ralf Corsepius |
Add bspopts.h.in.
4.115
@14811a0
05/22/12 13:07:48 |
Sebastian Huber |
powerpc/t32mppc: Typo
4.115
@e21c287c
05/21/12 12:56:31 |
Sebastian Huber |
powerpc/t32mppc: New BSP
4.115
@1901afc5
05/21/12 07:57:53 |
Sebastian Huber |
powerpc/qoriq: Fix due to console API changes
4.115
@a880c90
05/18/12 13:41:56 |
Sebastian Huber |
powerpc/mpc55xxevb: Fix cache define usage
4.115
@8bbf69e
05/16/12 21:04:10 |
Joel Sherrill |
pci.h cleanup - Consolidate common defines to cpukit pci.h
4.115
@13647019
05/16/12 19:47:31 |
Joel Sherrill |
mvme5500 and cpukit pci.h - Eliminate mvme5500 specific pci.h
All …
4.115
@226d48d8
05/16/12 15:20:35 |
Daniel Hellstrom |
LEON: moved register definitions into grlib header file
Some register …
4.115
@da154e14
05/14/12 14:55:41 |
Sebastian Huber |
Filesystem: Move operations to mount table entry
The scope of the …
4.115
@65c6425
05/03/12 17:24:46 |
Joel Sherrill |
Remove CVS Id Strings (manual edits after script)
These modifications …
4.115
@9b4422a2
05/03/12 15:09:24 |
Joel Sherrill |
Remove All CVS Id Strings Possible Using a Script
Script does what is …
4.115
@183af89
05/03/12 19:17:23 |
Joel Sherrill |
Miscellaneous - Clean up file headers so patterns followed
XXX
4.115
@eb7c6a84
05/10/12 16:17:59 |
Joel Sherrill |
pc386 - Clock driver compiles again plus clean up
The clock drivers …
4.115
@79fee34
05/10/12 12:59:49 |
Joel Sherrill |
clockdrv_shell.h - Fix commment
4.115
@153ef54
05/10/12 12:59:21 |
Joel Sherrill |
clockdrv_shell.c - Remove unreferenced and obsolete file
4.115
@314fab55
05/10/12 12:27:19 |
Joel Sherrill |
Clock Driver Shell - ISR handler prototype should follow port …
4.115
@42547e07
05/10/12 12:26:07 |
Joel Sherrill |
nds - Clock driver compiles again
4.115
@4523829a
05/10/12 12:25:29 |
Joel Sherrill |
nds/libnds - Fix missing prototype warning and formatting
4.115
@890c55c7
05/09/12 23:02:01 |
Joel Sherrill |
hurricane - Remove unused file setvec.c
4.115
@883a02c
05/08/12 22:47:01 |
Joel Sherrill |
score603e - Eliminate any set_vector() remnants
4.115
@16f0a50
05/08/12 22:39:26 |
Joel Sherrill |
virtex4 - Eliminate any set_vector() remnants
4.115
@71d7e02
05/08/12 22:35:49 |
Joel Sherrill |
virtex - Eliminate any set_vector() remnants
4.115
@1290a66
05/08/12 21:53:48 |
Joel Sherrill |
mbx8xx - Eliminate any set_vector() remnants
4.115
@e7afbaa
05/08/12 18:39:08 |
Joel Sherrill |
haleakala - Eliminate commented out code
4.115
@42dea0c
05/08/12 18:36:26 |
Joel Sherrill |
mpc8260ads - Eliminate commented out code
4.115
@96ec7264
05/08/12 18:36:10 |
Joel Sherrill |
mpc8260ads - Eliminate any set_vector() remnants
4.115
@6620a8a8
05/08/12 18:28:07 |
Joel Sherrill |
malta - Eliminate any set_vector() remnants
4.115
@4302c08
05/08/12 18:27:57 |
Joel Sherrill |
jmr3904 - Eliminate any set_vector() remnants
4.115
@87856609
05/08/12 18:27:46 |
Joel Sherrill |
hurricane - Eliminate any set_vector() remnants
4.115
@aeb6a58
05/08/12 18:27:25 |
Joel Sherrill |
genmongoosev - Eliminate any set_vector() remnants
4.115
@498b9e7d
05/08/12 18:26:18 |
Joel Sherrill |
rbtx4925 - Eliminate any set_vector() remnants
4.115
@959a701
05/08/12 18:26:04 |
Joel Sherrill |
rbtx4938 - Eliminate any set_vector() remnants
4.115
@541c5ddc
05/08/12 18:25:44 |
Joel Sherrill |
csb350 - Eliminate any set_vector() remnants
4.115
@19a3f50
05/07/12 22:02:07 |
Joel Sherrill |
jmr3904 - Correct tm27.h to use PIC Interrupt Model
4.115
@dac3a526
05/07/12 21:58:39 |
Joel Sherrill |
genmongoosev - Correct tm27.h to use PIC Interrupt Model
4.115
@c3e7313
05/07/12 21:58:20 |
Joel Sherrill |
csb350 - Correct tm27.h to use PIC Interrupt Model
4.115
@33a105fb
05/07/12 16:08:48 |
Joel Sherrill |
Revert: Remove CVS Ids
See …
4.115
@91d2e18
05/04/12 06:53:58 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@bf8e316
05/04/12 06:51:44 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@63de9348
05/04/12 06:51:44 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@8cbe46c
05/04/12 06:51:44 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@f07bdc47
05/04/12 06:51:44 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@a98262d8
05/04/12 06:51:44 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
