@f1413c4
01/07/13 13:56:53 |
Sebastian Huber |
bsp/lpc24xx: System reset after fatal conditions
4.115
@2460cc7
01/07/13 13:56:18 |
Sebastian Huber |
bsp/lpc24xx: Request system reset for LPC17XX
4.115
@4cc629cd
01/07/13 13:55:54 |
Sebastian Huber |
bsp/lpc24xx: Add WWDT module defines
4.115
@04f399d
01/07/13 09:19:23 |
Sebastian Huber |
arm: Add and use _ARMV7M_Exception_default()
4.115
@0f7abd99
01/04/13 15:25:19 |
Sebastian Huber |
arm: Rename inline functions
Rename arm_status_irq_enable() to …
4.115
@8df0e91
01/04/13 15:22:18 |
Sebastian Huber |
arm: Move inline functions
4.115
@13cf952
01/04/13 14:47:34 |
Sebastian Huber |
arm: Add and use default exception handler
Add and use …
4.115
@370c2c80
01/04/13 12:06:51 |
Sebastian Huber |
arm: Rename arm_exc_interrupt()
Rename arm_exc_interrupt() to …
4.115
@9b2e7143
01/04/13 12:05:28 |
Sebastian Huber |
arm: Move prototypes to new file
Move bsp_interrupt_dispatch() and …
4.115
@9224905b
01/03/13 14:41:16 |
Sebastian Huber |
bsps: Fix rtems_interrupt_server_handler_remove()
4.115
@566c05c
12/19/12 12:41:27 |
Sebastian Huber |
bsp/gen83xx: Fix CSB clock calculation for MPC8309
4.115
@4592658
12/18/12 08:24:56 |
Sebastian Huber |
bsps/arm: Move promiscuous mode setting
4.115
@3f58ac7
12/17/12 14:41:53 |
Sebastian Huber |
bsps/arm: Add PHY up/down
All PHYs will be set to power up/down state …
4.115
@50233d37
12/17/12 10:12:20 |
Sebastian Huber |
bsps/arm: Add PHY timeout detection
4.115
@2cd48da
12/14/12 12:08:10 |
Sebastian Huber |
bsps/arm: Add interface down support
4.115
@e99893f9
12/14/12 11:17:15 |
Sebastian Huber |
bsps/arm: Prepare for interface down support
4.115
@573822b
12/14/12 11:07:28 |
Sebastian Huber |
bsps/arm: Use assert() instead of status macros
4.115
@5970dcc9
12/14/12 09:28:18 |
Sebastian Huber |
bsps/arm: Remove superfluous attributes
4.115
@e5a7f846
12/14/12 08:40:44 |
Sebastian Huber |
bsps/arm: Avoid mbuf migration in LPC ethernet
The receive task will …
4.115
@c9562c5
12/18/12 10:18:40 |
Sebastian Huber |
bsp/lpc32xx: Add UART_CLKMODE settings
4.115
@380628ea
12/18/12 09:45:13 |
Sebastian Huber |
bsp/lpc32xx: Configure U4_TX pin for UART 4
4.115
@d1cf326
12/18/12 09:44:48 |
Sebastian Huber |
bsp/lpc32xx: Fix function prototype
4.115
@f25d31f
12/17/12 15:40:23 |
Sebastian Huber |
bsp/lpc32xx: Add idle thread body
4.115
@7371995
12/12/12 08:26:51 |
Sebastian Huber |
bsp/lpc32xx: Fix console baud configuration
4.115
@80232ee7
12/07/12 08:50:27 |
Sebastian Huber |
bsps/powerpc: Use explicit compiler options
4.115
@48bff53b
12/06/12 16:47:30 |
Sebastian Huber |
score: rtems_initialize_start_multitasking()
Do not return from …
4.115
@1bb8782
12/06/12 16:44:55 |
Sebastian Huber |
bsp/gdbarmsim: Do not call bsp_cleanup()
4.115
@facf8362
12/06/12 16:42:41 |
Sebastian Huber |
bsps: Add BSP_GENERIC_FATAL_SPURIOUS_INTERRUPT
Use rtems_fatal() …
4.115
@dabdbd91
12/06/12 16:40:42 |
Sebastian Huber |
bsp/mrm332: Use shared bspclean.c
4.115
@40fe4b86
12/06/12 16:40:08 |
Sebastian Huber |
bsps: Use <bsp/bootcard.h>
4.115
@2858aeb9
11/23/12 16:25:54 |
Sebastian Huber |
bsp/mpc55xx: New BSP variants for RSM6
4.115
@e1e248f
11/26/12 16:02:44 |
Sebastian Huber |
bsp/mpc55xx: Add optional EBI configuration
4.115
@f4309b0
11/26/12 15:58:58 |
Sebastian Huber |
bsp/mpc55xx: Use RTEMS_ARRAY_SIZE()
4.115
@29919ec0
11/23/12 14:12:41 |
Sebastian Huber |
bsp/mpc55xx: Add .sysram section
4.115
@65ab304b
11/23/12 13:47:47 |
Sebastian Huber |
bsp/mpc55xx: Add .dsram section
4.115
@bb3090c5
11/23/12 13:43:04 |
Sebastian Huber |
bsp/mpc55xx: Delete <bsp/mpc55xxevb.h>
4.115
@113768f
11/23/12 13:16:11 |
Sebastian Huber |
bsps/powerpc: Add .nvram section
4.115
@95aebbe
11/23/12 09:11:55 |
Sebastian Huber |
bsp/mpc55xx: Add and use STARTROM
4.115
@840dd00
11/23/12 09:11:22 |
Sebastian Huber |
bsp/mpc55xx: Add and use linkcmds.mpc5674f_ecu508
4.115
@c6d35ad4
11/21/12 08:46:58 |
Sebastian Huber |
bsp/mpc55xx: Errata e4396 for e200z7
4.115
@2e80662
11/19/12 08:12:07 |
Sebastian Huber |
bsp/mpc55xx: Set PPC_EXC_CONFIG_BOOKE_ONLY
4.115
@3ce66aa
11/19/12 08:02:12 |
Sebastian Huber |
bsp/mpc55xx: Set PPC_EXC_CONFIG_USE_FIXED_HANDLER
4.115
@1c479be4
11/16/12 09:06:07 |
Sebastian Huber |
bsp/mpc55xx: Documentation
4.115
@fee41c9
12/03/12 12:08:42 |
Sebastian Huber |
bsp/mpc55xx: Add and use mpc55xx_fatal_code
4.115
@6eb0ce2
11/15/12 16:33:15 |
christian.mauderer |
bsp/mpc55xx: Fix SMSC9218I MAC address setting
4.115
@da2fa4eb
11/15/12 16:01:29 |
Sebastian Huber |
bsp/mpc55xx: Remove BSP_panic()
4.115
@67338ed
11/15/12 15:57:02 |
Sebastian Huber |
bsp/mpc55xx: Add mpc55xx_wait_for_interrupt()
Use …
4.115
@2d561b9
11/13/12 13:39:19 |
Sebastian Huber |
bsp/mpc55xx: Use BSP_START_DATA_SECTION
4.115
@6c454104
11/13/12 10:50:38 |
Sebastian Huber |
bsp/mpc55xx: Fix no-cache section load
4.115
@fe1a4e4b
11/21/12 08:54:32 |
Sebastian Huber |
bsp/qoriq: Set PPC_EXC_CONFIG_BOOKE_ONLY
4.115
@f6999e6
11/21/12 08:54:12 |
Sebastian Huber |
bsp/qoriq: Set PPC_EXC_CONFIG_USE_FIXED_HANDLER
4.115
@c383372
11/13/12 14:01:24 |
Sebastian Huber |
bsps/powerpc: Add and use bsp_text input section
4.115
@d33f743
11/13/12 14:00:53 |
Sebastian Huber |
bsps/powerpc: Move .fast_text after .text section
4.115
@f665f13
11/19/12 07:37:04 |
Sebastian Huber |
bsps/powerpc: Add PPC_EXC_CONFIG_BOOKE_ONLY
In combination with the …
4.115
@4bd4c9e
11/23/12 08:32:52 |
Sebastian Huber |
bsps/powerpc: Add PPC_EXC_CONFIG_USE_FIXED_HANDLER
In case a BSP …
4.115
@3bf002a
11/30/12 12:21:37 |
Sebastian Huber |
bsp/gen83xx: Workaround for USB stack
4.115
@7ac89a6f
11/30/12 12:14:34 |
Sebastian Huber |
bsp/gen83xx: Add sections for USB stack
4.115
@fd5c1eb
12/03/12 09:02:29 |
Sebastian Huber |
bsp/csb637: Fix memory map
4.115
@e168410
12/03/12 08:57:59 |
Sebastian Huber |
bsp/csb337: Fix memory map
4.115
@655bd39
11/30/12 23:58:32 |
Ric Claus |
Virtex5 BSP: Various updates and improvements.
This BSP now uses the …
4.115
@5b822ab
11/30/12 23:56:04 |
Ric Claus |
Virtex4 BSP: Various updates and improvements.
Switched to using the …
4.115
@815994f
11/25/12 16:48:11 |
Sebastian Huber |
score: Add CPU_Exception_frame
Add CPU port type CPU_Exception_frame …
4.115
@f0e3cc0
11/26/12 16:52:01 |
Sebastian Huber |
bsps/powerpc: Delete unused EXC_DAR field
The Data Access Register …
4.115
@39aa75e7
11/23/12 21:40:09 |
Sebastian Huber |
bsps: Use RTEMS_BSP_CLEANUP_OPTIONS
4.115
@f5d0285
11/22/12 13:41:59 |
Sebastian Huber |
m68k/mrm332: Delete _Internal_error_Occurred()
Use custom …
4.115
@86d80f0
11/22/12 13:34:41 |
Sebastian Huber |
m68k/mvme167: Delete bsp_fatal_error_occurred()
4.115
@7ca64d69
11/20/12 07:36:25 |
Sebastian Huber |
bsp/mpc55xx: Update due to API changes
4.115
@b1e8a58
11/14/12 08:57:55 |
Sebastian Huber |
bsps/powerpc: Exception initialization error is fatal
4.115
@dd8df59
11/14/12 12:59:27 |
Sebastian Huber |
bsps: Interrupt initialization error is fatal
4.115
@a052181
11/14/12 08:59:10 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_EXIT
Include …
4.115
@dc6e830
11/13/12 16:40:33 |
Sebastian Huber |
sapi: Add and use rtems_internal_error_description
4.115
@e4b40531
11/14/12 11:37:24 |
Sebastian Huber |
sapi: Add rtems_fatal_source and rtems_fatal_code
4.115
@767b4c1
11/15/12 12:04:42 |
Sebastian Huber |
bsp/jmr3904: Define bsp_reset()
This is declared in <bsp/bootcard.h> …
4.115
@db5cb262
11/15/12 10:57:59 |
Sebastian Huber |
bsps/lm32: Include <bsp/bootcard.h>
4.115
@12007d0
11/14/12 13:21:26 |
Sebastian Huber |
bsps: Include <bspopts.h> in <bsp.h>
4.115
@a3e8ab2
11/14/12 10:53:38 |
Sebastian Huber |
bsps/sparc: Define bsp_reset()
4.115
@3a1d9c6
11/14/12 10:14:21 |
Sebastian Huber |
bsps: Include <bsp/bootcard.h>
Use <bsp/bootcard.h> to get prototype …
4.115
@7121cac0
11/07/12 13:59:20 |
Sebastian Huber |
bsps/sparc: Add BSP_INITIAL_EXTENSION to <bsp.h>
The …
4.115
@38c0b112
11/07/12 15:18:39 |
Sebastian Huber |
bsps: New file <bsp/default-initial-extension.h>
4.115
@9186fa8
11/06/12 11:32:44 |
Sebastian Huber |
bsps/sparc: Delete unused symbol declaration
4.115
@ef5f359
11/06/12 11:18:10 |
Sebastian Huber |
sapi: Delete duplicate declarations
4.115
@c479497
11/06/12 11:01:19 |
Sebastian Huber |
sapi: Use rtems_configuration_get_work_space_size
4.115
@f536e12
11/06/12 10:59:43 |
Sebastian Huber |
sapi: Use rtems_*_get_user_multiprocessing_table
4.115
@75524a5e
11/06/12 10:26:58 |
Sebastian Huber |
sapi: Use rtems_config*_get_interrupt_stack_size
4.115
@5e86086
11/06/12 09:34:42 |
Sebastian Huber |
sapi: Use rtems_config*_get_microseconds_per_tick
4.115
@524473fd
11/06/12 11:05:26 |
Sebastian Huber |
bsp/nds: Do not change configuration
4.115
@c082e633
11/06/12 10:52:44 |
Sebastian Huber |
bsp/mvme167: Do not provide user extensions table
The application …
4.115
@e85476b
11/06/12 10:50:59 |
Sebastian Huber |
bsp/mvme167: Remove unused parameter
4.115
@a9e5e74
11/06/12 09:15:17 |
Sebastian Huber |
bsps: Use allocator mutex for generic IRQ support
Since the allocator …
4.115
@9f0a68c
10/31/12 10:54:39 |
Sebastian Huber |
libblock: Block device transfer request API change
Add and use …
4.115
@20e1e769
10/31/12 16:03:06 |
Sebastian Huber |
bsp/mpc55xx: SMSC9218i avoid mbuf migration
4.115
@26e90fb1
10/30/12 16:42:17 |
Sebastian Huber |
libnetworking: Use system events
Add reserved system events …
4.115
@f33873b
10/29/12 20:14:23 |
Sebastian Huber |
bsp/pc386: Typo
4.115
@2ece571e
10/25/12 15:40:57 |
Sebastian Huber |
bsp/mpc55xx: Stop tasks for SMSC9218i during off
4.115
@da890759
09/28/12 13:36:26 |
Sebastian Huber |
bsp/mpc55xx: Add custom work area init
4.115
@c118a6e5
08/24/12 13:25:45 |
Sebastian Huber |
bsps: Add bsp_work_area_initialize_with_table()
4.115
@47a3cd8
08/09/12 14:48:00 |
Sebastian Huber |
score: Work area initialization API change
The work areas (RTEMS work …
4.115
@86d7cbd
10/15/12 08:27:59 |
Ralf Corsepius |
Remove unused var 'sc'.
4.115
@61af4b0b
10/15/12 04:00:20 |
Ralf Corsepius |
Include <rtems/framebuffer.h>.
4.115
@f7513a0
08/09/12 14:45:12 |
Sebastian Huber |
bsps: Remove unused bsp_libc_init() prototype
4.115
