@be4284d0
09/30/98 21:50:42 |
Joel Sherrill |
BSP submitted by Thomas Doerfler <td@…>:
Finally I am …
4.104.114.84.95
@2c3840b
09/30/98 20:58:39 |
Joel Sherrill |
Added new autoconf test for i386 code16/code32 support. The guts of …
4.104.114.84.95
@4ca5bd8
09/30/98 17:27:57 |
Joel Sherrill |
Changed based on patch from pc386 linkcmds from Ian Lance Taylor …
4.104.114.84.95
@d1d47664
09/30/98 17:17:23 |
Joel Sherrill |
Patch from Ian Lance Taylor <ian@…>:
The pc386 linker …
4.104.114.84.95
@21bfd93
09/29/98 12:40:33 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>:
Please find …
4.104.114.84.95
@da38d8a
09/24/98 15:43:38 |
Joel Sherrill |
Removed superfluous initialization of PC video.
4.104.114.84.95
@32f3e34
09/24/98 13:55:18 |
Joel Sherrill |
Patch from Erik Ivanenko <erik.ivanenko@…>:
Please find …
4.104.114.84.95
@287e9584
09/24/98 13:46:27 |
Joel Sherrill |
New version from Erik Ivanenko <erik.ivanenko@…>.
4.104.114.84.95
@5d17a64
09/23/98 13:43:14 |
Joel Sherrill |
Updated to remove bad comment.
4.104.114.84.95
@1cf2df40
09/23/98 13:25:37 |
Joel Sherrill |
Removed printk() references.
4.104.114.84.95
@479c86dd
09/23/98 13:22:43 |
Joel Sherrill |
Please find …
4.104.114.84.95
@8a496e46
09/23/98 13:20:34 |
Joel Sherrill |
Patch from Aleksey (Quality Quorum <qqi@…>):
1. …
4.104.114.84.95
@362b88e
09/23/98 13:17:23 |
Joel Sherrill |
Switched "NEW_GAS" flag.
4.104.114.84.95
@e62488d
09/21/98 01:29:19 |
Joel Sherrill |
New file from Emmanuel Raguet <raguet@…>.
4.104.114.84.95
@97d7b068
09/21/98 00:40:18 |
Joel Sherrill |
Update from Aleksey (Quality Quorum <qqi@…>) to pick up …
4.104.114.84.95
@75e44fa3
09/21/98 00:39:47 |
Joel Sherrill |
Removed by patch from Aleksey.
4.104.114.84.95
@3f929757
09/21/98 00:38:13 |
Joel Sherrill |
Patches from Aleksey which were not in 980911.
I am sending you …
4.104.114.84.95
@c610a1f3
09/21/98 00:24:51 |
Joel Sherrill |
Update from Eric Valette <valette@…>:
Here are patches …
4.104.114.84.95
@04bc5d9
09/21/98 00:23:02 |
Joel Sherrill |
Update from Erik Ivanenko <erik.ivanenko@…> to bring the …
4.104.114.84.95
@6bd0fe4
09/20/98 23:52:43 |
Joel Sherrill |
Patch from Eric Valette <valette@…>:
Compiled and booted …
4.104.114.84.95
@bfcf4cb3
09/11/98 23:35:09 |
Joel Sherrill |
Updates to tree to make it build with all desired changes and the …
4.104.114.84.95
@bd3dec5
09/10/98 12:46:41 |
Joel Sherrill |
Patch from Eric Norum <eric@…>:
If you're getting …
4.104.114.84.95
@b7e3949
09/10/98 12:28:59 |
Joel Sherrill |
Patch from Eric Valette <valette@…>. Most of this was …
4.104.114.84.95
@eff217e
09/10/98 12:16:39 |
Joel Sherrill |
Patch from Emmanuel Raguet <raguet@…>:
After some good …
4.104.114.84.95
@d9d75fc
08/31/98 23:06:50 |
Joel Sherrill |
I have reworked …
4.104.114.84.95
@b285860
08/31/98 23:03:45 |
Joel Sherrill |
Eric> NB : there …
4.104.114.84.95
@de9edc4
08/31/98 22:56:20 |
Joel Sherrill |
Here is a brief …
4.104.114.84.95
@69036586
08/24/98 16:58:39 |
Joel Sherrill |
Celso Labinaz …
4.104.114.84.95
@9a95524f
08/24/98 14:47:19 |
Joel Sherrill |
Cleanup patch from Eric Norum.
4.104.114.84.95
@eb562f2
08/21/98 16:39:52 |
Joel Sherrill |
Here is a patch …
4.104.114.84.95
@d47de32
08/21/98 14:04:31 |
Joel Sherrill |
Update from Eric Norum.
4.104.114.84.95
@fd808ba
08/21/98 12:48:44 |
Joel Sherrill |
Fixed discrepancies noted by John Oleynick <johno@…>.
4.104.114.84.95
@28e7d7fa
08/20/98 22:04:22 |
Joel Sherrill |
Patches from Eric Norum
4.104.114.84.95
@53ee76b
08/20/98 15:37:42 |
Joel Sherrill |
Removed stub implementation
4.104.114.84.95
@0280cb6
08/20/98 14:39:09 |
Joel Sherrill |
FreeBSD stack compiles for the first time (except libc/strsep.c)
4.104.114.84.95
@8b2ee37c
08/19/98 20:09:59 |
Joel Sherrill |
- Use the …
4.104.114.84.95
@0375c72
08/19/98 14:47:39 |
Joel Sherrill |
Patch from Aleksey <qqi@…>:
This patch has same …
4.104.114.84.95
@2d7d605
08/19/98 14:41:23 |
Joel Sherrill |
It fixes netboot build …
4.104.114.84.95
@e013fe3
08/14/98 16:55:50 |
Joel Sherrill |
If 0 out the code which touches the chip in questionable ways for …
4.104.114.84.95
@7ba7108
08/14/98 15:24:09 |
Joel Sherrill |
Changed tm27 clear interrupt macro on all PPC BSPs except the papyrus.
4.104.114.84.95
@db8e8a8b
08/14/98 15:23:33 |
Joel Sherrill |
Added information on caching.
4.104.114.84.95
@0088e39c
08/14/98 15:23:22 |
Joel Sherrill |
Updated.
4.104.114.84.95
@2097470
08/13/98 22:46:59 |
Joel Sherrill |
Fixed version reference
4.104.114.84.95
@3978eec2
08/13/98 22:46:35 |
Joel Sherrill |
Updated.
4.104.114.84.95
@8626d6d
08/13/98 17:46:27 |
Joel Sherrill |
base line -- copied from erc32
4.104.114.84.95
@af3e81c9
08/13/98 16:53:37 |
Joel Sherrill |
Enable TX interrupts only when we need TDAs.
4.104.114.84.95
@1253f39
08/13/98 16:20:14 |
Joel Sherrill |
Cleaned up some debugging stuff.
Redid interrupt handler to read …
4.104.114.84.95
@ae320e0
08/12/98 23:53:23 |
Joel Sherrill |
Removed spurious prints and cleaned up XXX.
4.104.114.84.95
@9693fac4
08/12/98 23:10:38 |
Joel Sherrill |
Added more debug information. There are probably debug prints left …
4.104.114.84.95
@4f38b713
08/12/98 16:28:17 |
Joel Sherrill |
Fixed bug where the last link of the RDA was not initialized properly.
4.104.114.84.95
@7d07970
08/11/98 14:20:26 |
Joel Sherrill |
Added SONIC_DEBUG_DESCRIPTORS and changed debug level.
4.104.114.84.95
@339737b
08/10/98 23:20:25 |
Joel Sherrill |
Survives 16-20 packets. Appears to be ok on TX buffer management. …
4.104.114.84.95
@3fbd528
08/10/98 22:23:33 |
Joel Sherrill |
Added prints
4.104.114.84.95
@7344fba9
08/10/98 21:45:01 |
Joel Sherrill |
Can now reply to multiple successive pings successfully without being …
4.104.114.84.95
@c153a7b
08/10/98 21:27:33 |
Joel Sherrill |
replies to ping -- forced into prosmiscuous mode
4.104.114.84.95
@0c0419a1
08/08/98 17:57:23 |
Joel Sherrill |
Reordered some stuff.
4.104.114.84.95
@870284d
08/08/98 16:37:43 |
Joel Sherrill |
Corrected spacing.
4.104.114.84.95
@301a2a3c
08/08/98 16:37:25 |
Joel Sherrill |
Changed debug level.
Moved CAM Descriptor types to sonic.h.
CAM …
4.104.114.84.95
@13451a3
08/06/98 19:01:03 |
Joel Sherrill |
Removed SonicRegisters? structure since we now use register indices
and …
4.104.114.84.95
@e70a8f16
08/06/98 19:01:02 |
Joel Sherrill |
Enabled specific types of debug info.
Added pointer to RDA to sonic …
4.104.114.84.95
@e995f3a1
08/06/98 15:27:08 |
Joel Sherrill |
Changed debug enable macros to support individually enabling different …
4.104.114.84.95
@c23118b
08/06/98 15:05:59 |
Joel Sherrill |
Card Resource Register was a 16-bit register not a 32-bit one.
Used …
4.104.114.84.95
@308e18c
08/06/98 00:24:52 |
Joel Sherrill |
Added support for the Card Resource Register. The new probe routines …
4.104.114.84.95
@d4bf16c
08/05/98 23:56:48 |
Joel Sherrill |
Added constants which made the multiple bit settings more readable
for …
4.104.114.84.95
@dddc0557
08/05/98 23:56:13 |
Joel Sherrill |
DCR setting changed to match what the DY-4 Firmware initialized it to. …
4.104.114.84.95
@bd8c8b2a
08/05/98 16:51:39 |
Joel Sherrill |
Patch from Eric Valette <valette@…> which brings the i386ex …
4.104.114.84.95
@ab0df696
08/05/98 15:15:46 |
Joel Sherrill |
Automatic CPU type detection code from Eric Valette …
4.104.114.84.95
@5094711
08/05/98 15:12:03 |
Joel Sherrill |
Fixed name of Buffer so this would compile.
4.104.114.84.95
@7fc5d54e
08/03/98 21:01:21 |
Joel Sherrill |
Switched to read/write register routines and added some basic debug
help.
4.104.114.84.95
@2889189
07/30/98 22:57:21 |
Joel Sherrill |
Changed name of network driver.
4.104.114.84.95
@fa655207
07/30/98 22:57:12 |
Joel Sherrill |
Added temporary include of dmv170.h
4.104.114.84.95
@4fbf114
07/30/98 22:56:56 |
Joel Sherrill |
Added SONIC configuration information.
4.104.114.84.95
@56392179
07/30/98 22:56:17 |
Joel Sherrill |
Added a hint to continue writing this.
4.104.114.84.95
@509dc7c1
07/30/98 21:27:51 |
Joel Sherrill |
Added getRealTime() and setRealTime().
Reimplemented checkRealTime() …
4.104.114.84.95
@91af3e4
07/30/98 21:27:01 |
Joel Sherrill |
Changed clock rate from 32 Khz to 1 Mhz.
Registers are at 8 byte …
4.104.114.84.95
@a47bca7c
07/30/98 21:26:25 |
Joel Sherrill |
Changed comment to be more polite.
4.104.114.84.95
@8e992e1
07/30/98 21:26:11 |
Joel Sherrill |
Updating to make more readable.
4.104.114.84.95
@1aa4186
07/30/98 19:41:46 |
Joel Sherrill |
Spacing corrected.
4.104.114.84.95
@1a256e3
07/30/98 19:41:41 |
Joel Sherrill |
New file based on email from DY-4 technical support.
4.104.114.84.95
@1c5f4e1
07/30/98 19:26:47 |
Joel Sherrill |
Fixed spacing.
4.104.114.84.95
@8751f800
07/30/98 19:25:54 |
Joel Sherrill |
Updated to accurately reflect the dmv177.
4.104.114.84.95
@7fd8641
07/30/98 16:07:54 |
Joel Sherrill |
Made chain.h shared
4.104.114.84.95
@3fdde4ce
07/30/98 16:05:14 |
Joel Sherrill |
Made tod.h shared
4.104.114.84.95
@02733a96
07/29/98 00:38:51 |
Joel Sherrill |
New file. Based on merged of shared libchip style console.c and the …
4.104.114.84.95
@acac0e8
07/29/98 00:38:14 |
Joel Sherrill |
Cleaned up comment.
Modified open so it uses a local variable rather …
4.104.114.84.95
@6a0f5ac2
07/29/98 00:37:37 |
Joel Sherrill |
Added reference to shared TOD driver.
4.104.114.84.95
@ee306fd
07/29/98 00:17:01 |
Joel Sherrill |
Corrected to reflect the ICM7170 which is really on this board.
4.104.114.84.95
@55dcdfd
07/29/98 00:16:44 |
Joel Sherrill |
Added config.c and deleted tod.c.
4.104.114.84.95
@e74735b2
07/29/98 00:16:32 |
Joel Sherrill |
Simplified RTC base address.
4.104.114.84.95
@5217d5a
07/29/98 00:16:11 |
Joel Sherrill |
Changed cast on RTC address and added base address of RTC fields as …
4.104.114.84.95
@9968efb
07/28/98 23:16:34 |
Joel Sherrill |
First cut at configuration table for libchip RTC. At this point, we …
4.104.114.84.95
@5752f930
07/25/98 17:34:41 |
Joel Sherrill |
New file -- copied from dmv177 but same as ppcn_60x.
4.104.114.84.95
@3d2c161
07/25/98 16:16:10 |
Joel Sherrill |
Removed "if 0" used to switch between serial ports.
4.104.114.84.95
@a3c9f0d
07/25/98 14:50:07 |
Joel Sherrill |
Moved console.c to libbsp/shared.
4.104.114.84.95
@03c0961
07/24/98 16:18:39 |
Joel Sherrill |
Patch from David Fiddes <D.J.Fiddes@…>:
Here's a small …
4.104.114.84.95
@dbab462
07/24/98 16:09:51 |
Joel Sherrill |
Patch from Eric Valette <valette@…> and Emmanuel Raguet …
4.104.114.84.95
@dbaf51a
07/23/98 22:13:10 |
Joel Sherrill |
Here is a patch …
4.104.114.84.95
@67a2288
07/23/98 22:02:34 |
Joel Sherrill |
Patch from Eric VALETTE <valette@…>:
Here is a …
4.104.114.84.95
@c91e032
07/23/98 19:32:01 |
Joel Sherrill |
Removed consolex from build list. This file should be obsoleted by …
4.104.114.84.95
@bced36d
07/18/98 18:44:12 |
Joel Sherrill |
Changed so we could test interrupts on port 3.
4.104.114.84.95
