@8d05346
09/03/97 22:05:51 |
Joel Sherrill |
Fix from Eric Norum. Here is the comment:
Enable SDMA …
4.104.114.84.95
@e9932367
08/28/97 21:54:59 |
Joel Sherrill |
Switched to new style which does not require hackspecs.awk.
4.104.114.84.95
@f80faeb
08/27/97 20:33:11 |
Joel Sherrill |
Modified to support the BSP family concept.
4.104.114.84.95
@49c2f589
08/27/97 20:31:34 |
Joel Sherrill |
Modified to have correct address for vector table on multiple models.
4.104.114.84.95
@12a17af3
08/26/97 18:10:59 |
Joel Sherrill |
Corrected to compile with egcs.
4.104.114.84.95
@8affd6f1
08/22/97 19:16:22 |
Joel Sherrill |
Removed redundant stanza.
4.104.114.84.95
@2d997375
08/22/97 13:08:56 |
Joel Sherrill |
start no longer a global symbol per Eric Norum's request.
Also, I …
4.104.114.84.95
@d074e12
08/04/97 22:22:59 |
Joel Sherrill |
Switched to new version of mc68681.h
4.104.114.84.95
@19fd334
08/04/97 22:22:31 |
Joel Sherrill |
moved mc68230.h from main include directory to motorola
4.104.114.84.95
@3dd8372
08/04/97 22:03:03 |
Joel Sherrill |
Corrected typo
4.104.114.84.95
@8bc9051
08/04/97 21:58:30 |
Joel Sherrill |
Fixed typo and removed duplicated code
4.104.114.84.95
@4ef9e99
08/04/97 21:58:00 |
Joel Sherrill |
First attempt at values for PPC
4.104.114.84.95
@50b5f9d
08/04/97 21:57:06 |
Joel Sherrill |
Trying to support all models
4.104.114.84.95
@c74169bd
08/04/97 21:56:48 |
Joel Sherrill |
Trying to support all models.
4.104.114.84.95
@c9647b3
08/04/97 21:56:00 |
Joel Sherrill |
consolex built for all models.
4.104.114.84.95
@81d96577
08/04/97 21:55:30 |
Joel Sherrill |
moved header files into the motorola and zilog subdirectories
4.104.114.84.95
@669123e1
08/04/97 21:53:42 |
Joel Sherrill |
Correcting difference between mvme162lx and mvme162. All versions …
4.104.114.84.95
@02d0880
08/04/97 21:50:35 |
Joel Sherrill |
4.104.114.84.95
@033ec54
08/04/97 21:49:47 |
Joel Sherrill |
Modified to reflect changes in mc68681.h header file.
4.104.114.84.95
@b739617
08/04/97 21:45:27 |
Joel Sherrill |
Header files moved into zilog subdirectory.
4.104.114.84.95
@bcbd75d4
08/01/97 20:56:36 |
Joel Sherrill |
Added consolex to wrapup
4.104.114.84.95
@a7fcfd0
08/01/97 20:56:24 |
Joel Sherrill |
Corrected typo.
4.104.114.84.95
@adf7b5c4
08/01/97 20:15:02 |
Joel Sherrill |
Made to work.
4.104.114.84.95
@29a9e5d
08/01/97 20:14:57 |
Joel Sherrill |
Removed warnings.
4.104.114.84.95
@9deb5b8b
08/01/97 18:12:11 |
Joel Sherrill |
Katsutoshi Shibuya (shibuya@…)of BU-Denken Co., Ltd. …
4.104.114.84.95
@0074691a
07/31/97 22:13:29 |
Joel Sherrill |
Merged very large and much appreciated patch from Chris Johns …
4.104.114.84.95
@bf3a7a5a
07/10/97 19:16:40 |
Joel Sherrill |
Added information on different MVME162 models.
4.104.114.84.95
@900a3ab1
07/09/97 23:57:56 |
Joel Sherrill |
Repository damaged -- file re-added
4.104.114.84.95
@1f0f3e35
05/27/97 23:39:29 |
Joel Sherrill |
added ka9q stack
4.104.114.84.95
@f5bd03c
05/23/97 21:44:19 |
Joel Sherrill |
KA9Q stack removed prior to testing for 4.0.0 public release.
4.104.114.84.95
@edd12702
05/21/97 12:59:40 |
Joel Sherrill |
patch from Eric Norum
4.104.114.84.95
@18647b7
04/25/97 16:58:10 |
Joel Sherrill |
updated to reflect new license per John Gwynne's permission.
4.104.114.84.95
@e71ce071
04/22/97 17:47:16 |
Joel Sherrill |
updated with new license information per Tony Bennett.
4.104.114.84.95
@03f2154e
04/22/97 17:20:27 |
Joel Sherrill |
headers updated to reflect new style copyright notice as part
of …
4.104.114.84.95
@59097e7
04/18/97 18:38:19 |
Joel Sherrill |
Changed format of comment blocks to C comments.
4.104.114.84.95
@7e7143e
04/18/97 18:37:48 |
Joel Sherrill |
Duplicated timerisr symbol as _timerisr to avoid tool naming problems.
4.104.114.84.95
@9fbba98
04/16/97 17:47:48 |
Joel Sherrill |
Fixed path which points to shared directory for all BSPs.
4.104.114.84.95
@f9f375e
04/16/97 17:45:52 |
Joel Sherrill |
added fpsp support.
4.104.114.84.95
@f8f370b6
04/16/97 17:45:35 |
Joel Sherrill |
Update from Eric Norum.
4.104.114.84.95
@b584751
04/15/97 17:37:12 |
Joel Sherrill |
Switched all bsps which had an implementation of sbrk.c which only …
4.104.114.84.95
@ecc4594
04/15/97 17:28:26 |
Joel Sherrill |
Removed many BSPs' copy of setvec.c and let them share the same …
4.104.114.84.95
@bc7d465
04/11/97 18:41:38 |
Joel Sherrill |
replaced linking of source from mvme147 drivers with use of vpath to …
4.104.114.84.95
@0956b52
04/09/97 20:05:37 |
Joel Sherrill |
correct incorrect register addresses for port a.
4.104.114.84.95
@8c0dc2c
04/09/97 20:05:12 |
Joel Sherrill |
removed unused is_character_ready routine.
4.104.114.84.95
@e2d79559
04/09/97 14:05:50 |
Joel Sherrill |
Added ka9q tcpip stack and network driver for the gen68360. This …
4.104.114.84.95
@bed475e
04/08/97 11:53:54 |
Joel Sherrill |
added cast to eliminate warning.
4.104.114.84.95
@dd1d1c7
04/07/97 21:29:49 |
Joel Sherrill |
added prototype and return statement to eliminate warnings.
4.104.114.84.95
@f1fc782e
04/07/97 21:29:09 |
Joel Sherrill |
commented out sccs_id's to eliminate warnings.
main.c: added return …
4.104.114.84.95
@318976f
04/07/97 21:28:21 |
Joel Sherrill |
removed reference to no_bsp.
added prototypes.
4.104.114.84.95
@de1d716
04/07/97 21:27:59 |
Joel Sherrill |
commented out sccs_id to eliminate warnings
4.104.114.84.95
@2938c1a3
04/07/97 21:27:22 |
Joel Sherrill |
added or fixed includes of page_table.h to eliminate warnings.
4.104.114.84.95
@588c9ed
04/07/97 21:26:49 |
Joel Sherrill |
4.104.114.84.95
@930b3d5
04/07/97 21:26:34 |
Joel Sherrill |
added prototype for delay.
4.104.114.84.95
@3bc409c
04/07/97 21:26:22 |
Joel Sherrill |
added global statement for start entry point
4.104.114.84.95
@437366f
04/07/97 21:25:42 |
Joel Sherrill |
removed noreturn from prototype to avoid warnings.
4.104.114.84.95
@2bad8aa
04/07/97 21:25:21 |
Joel Sherrill |
4.104.114.84.95
@759a9d9
04/07/97 21:24:28 |
Joel Sherrill |
added return statement to avoid warning.
4.104.114.84.95
@d6ba279
04/07/97 21:24:02 |
Joel Sherrill |
added initialization of variable to eliminate warning.
4.104.114.84.95
@0b50855
04/07/97 21:23:43 |
Joel Sherrill |
added include of unistd.h to eliminate warning for no prototype for …
4.104.114.84.95
@254b4450
04/01/97 23:07:52 |
Joel Sherrill |
This set of changes is the build of what was required to convert to …
4.104.114.84.95
@84e5b57f
03/21/97 19:19:33 |
Joel Sherrill |
Removed Fake input ifdef code.
4.104.114.84.95
@691259b
03/21/97 19:18:11 |
Joel Sherrill |
Fixed timerisr symbol.
4.104.114.84.95
@e667a0b
03/21/97 19:17:46 |
Joel Sherrill |
Rewrote to avoid references to C symbols from assembly. This entirely …
4.104.114.84.95
@51c9fb4
03/21/97 19:17:05 |
Joel Sherrill |
Fixes incorrect reference to start symbol.
4.104.114.84.95
@d0e126a6
03/11/97 15:53:05 |
Joel Sherrill |
updates from John Gwynne
4.104.114.84.95
@6335022e
03/11/97 15:42:59 |
Joel Sherrill |
4.104.114.84.95
@133fb0e5
03/08/97 03:53:37 |
Joel Sherrill |
Larger Workspace when it is a POSIX API. Actually this is just to …
4.104.114.84.95
@cd912a09
01/29/97 15:35:13 |
Joel Sherrill |
new file explaining issues related to this bsp.
4.104.114.84.95
@f3f23878
01/29/97 15:22:49 |
Joel Sherrill |
Fixed this where it works. It includes the libpc.a and libc.a from …
4.104.114.84.95
@cb585c3
01/29/97 00:32:23 |
Joel Sherrill |
erc32 bsp supercedes sis
4.104.114.84.95
@634e746
01/29/97 00:28:47 |
Joel Sherrill |
All RTEMS system call implementation renamed to be rtems_*.
4.104.114.84.95
@2f93371
01/29/97 00:28:30 |
Joel Sherrill |
The CONSOLE_USE_INTERRUPTS and CONSOLE_USE_POLLED macros are now …
4.104.114.84.95
@b1b5a7cb
01/28/97 23:16:16 |
Joel Sherrill |
new file used by gcc 2.8.x -specs option
4.104.114.84.95
@7f96eef
12/02/96 22:36:28 |
Joel Sherrill |
Replacement for the sis bsp which supports the simulator and real …
4.104.114.84.95
@c766cac
12/02/96 22:35:22 |
Joel Sherrill |
New bsp for the erc32/sis from Jiri Gaisler <jgais@…> …
4.104.114.84.95
@fe6ef776
10/15/96 21:39:27 |
Joel Sherrill |
updated to format of 3.6.0
4.104.114.84.95
@6c58b6f
10/15/96 21:39:15 |
Joel Sherrill |
updated to format of 3.6.0 console drivers
4.104.114.84.95
@39cafa5
10/15/96 21:39:06 |
Joel Sherrill |
updated to format of 3.6.0 clock drivers
4.104.114.84.95
@60e2964
10/15/96 21:01:55 |
Joel Sherrill |
new file
4.104.114.84.95
@d1dbcab9
10/15/96 21:00:41 |
Joel Sherrill |
reference to Force CPU-386 removed.
added standard comments about …
4.104.114.84.95
@752cd8f
10/15/96 20:57:04 |
Joel Sherrill |
initial version from Erik
4.104.114.84.95
@caf87fd7
09/27/96 15:49:44 |
Joel Sherrill |
data and control addresses were swapped for channel a of the scc
4.104.114.84.95
@0836603
09/18/96 21:13:10 |
Joel Sherrill |
new files submitted by Craig Lebakken (lebakken@…) and Derrick …
4.104.114.84.95
@d6b2bba
09/18/96 20:56:35 |
Joel Sherrill |
4.104.114.84.95
@afe99c2
09/18/96 14:17:54 |
Joel Sherrill |
new file submitted by Dominique le Campion.
4.104.114.84.95
@0971cd5
09/11/96 19:15:09 |
Joel Sherrill |
added $ string to file header
4.104.114.84.95
@5bb00a8
09/11/96 19:13:44 |
Joel Sherrill |
added $Id$ string to file header
4.104.114.84.95
@9c0d032
09/11/96 19:12:43 |
Joel Sherrill |
new files
4.104.114.84.95
@3d07c8b
09/08/96 16:24:13 |
Joel Sherrill |
added mips64orion entries for SHM_LOCK_VALUE and SHM_UNLOCK_VALUE
4.104.114.84.95
@bdef2d8
09/08/96 16:23:35 |
Joel Sherrill |
idtmem.S: changed reference to include files to correct location
4.104.114.84.95
@eaa34e7
09/08/96 16:22:29 |
Joel Sherrill |
4.104.114.84.95
@f198c63
09/06/96 18:11:41 |
Joel Sherrill |
new file for MIPS port by Craig Lebakken (lebakken@…) and …
4.104.114.84.95
@729c8f2e
07/02/96 18:14:52 |
Joel Sherrill |
updated for 3.5.17
4.104.114.84.95
@c486e917
06/18/96 19:06:19 |
Joel Sherrill |
changed reboot to a macro to avoid the "noreturn returns" warning.
4.104.114.84.95
@7d74395f
06/18/96 16:43:12 |
Joel Sherrill |
corrected typo
4.104.114.84.95
@4b06db75
05/28/96 13:25:15 |
Joel Sherrill |
fixed typo
4.104.114.84.95
@e6d4b1d
05/28/96 13:13:34 |
Joel Sherrill |
added initial posix configuration support
4.104.114.84.95
@28fa54d9
05/24/96 20:34:49 |
Joel Sherrill |
added Motorola MVME147 BSP submitted by Dominique le Campion …
4.104.114.84.95
@64b976a
05/23/96 15:36:46 |
Joel Sherrill |
added code to insure that delay is always non-zero
4.104.114.84.95
@a6aded4f
05/23/96 15:36:08 |
Joel Sherrill |
updates from tony bennett
4.104.114.84.95
