Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src/lib/libbsp
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @875fbdbb   11/22/99 13:48:10 Joel Sherrill Added files missed by previous merger of SH-2 port. 4.104.114.84.95
(edit) @9608320   11/22/99 13:41:11 Joel Sherrill Patch rtems-rc-19991117-4.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @d2a05e7   11/19/99 16:40:40 Joel Sherrill Renaming all BSP specific startXXX directories to use the same name … 4.104.114.84.95
(edit) @9c0385a   11/19/99 16:22:09 Joel Sherrill Renaming all BSP specific startXXX directories to use the same name … 4.104.114.84.95
(edit) @149f3f9   11/19/99 16:06:32 Joel Sherrill Moved startsis to start. 4.104.114.84.95
(edit) @4a238002   11/18/99 21:22:58 Joel Sherrill Patch from "John M. Mills" <jmills@…> with subsequent cleanup … 4.104.114.84.95
(edit) @08311cc3   11/17/99 17:51:34 Joel Sherrill Updated copyright notice. 4.104.114.84.95
(edit) @39827cc   11/17/99 17:31:51 Joel Sherrill Now allows override of base address via -Ttext command to linker. 4.104.114.84.95
(edit) @23d9392f   11/17/99 15:42:18 Joel Sherrill New file documenting the on board monitor (PPCBUG) configuration used … 4.104.114.84.95
(edit) @38d65f80   11/16/99 22:56:53 Joel Sherrill Fixed alignment problem on _endtext. 4.104.114.84.95
(edit) @ac656f2d   11/16/99 14:15:56 Joel Sherrill Moved start code from lib/start to libbsp. 4.104.114.84.95
(edit) @1d04e16   11/16/99 13:45:51 Joel Sherrill Moved start code from lib/start to libbsp. 4.104.114.84.95
(edit) @a7d988a   11/16/99 13:37:25 Joel Sherrill Minor changes since new Makefile. 4.104.114.84.95
(edit) @14dbf50   11/16/99 13:34:41 Joel Sherrill Added start subdirectory. 4.104.114.84.95
(edit) @c73b8ac2   11/09/99 22:18:43 Joel Sherrill This patch adds the basic framework for the ITRON 3.0 API … 4.104.114.84.95
(edit) @c8cad188   11/09/99 22:16:16 Joel Sherrill Removed. 4.104.114.84.95
(edit) @d55af6d   11/09/99 15:38:47 Joel Sherrill Now using libchip instead of local precursor to libchip. Untested. 4.104.114.84.95
(edit) @0fab6dde   11/05/99 17:49:56 Joel Sherrill Patch from Eric Valette <valette@…> so this will build … 4.104.114.84.95
(edit) @f817b02   11/04/99 18:05:09 Joel Sherrill The files in libcpu should not be directly dependent on any BSP. In … 4.104.114.84.95
(edit) @d76608e0   11/03/99 12:46:29 Joel Sherrill Typo fixed by Ralf Corsepius <corsepiu@…>. 4.104.114.84.95
(edit) @c42bd452   11/02/99 16:05:41 Joel Sherrill Split console_reserve_resources into its own file to reduce … 4.104.114.84.95
(edit) @92f69999   11/01/99 13:08:35 Joel Sherrill Removed all references to shared memory driver as it is not supported … 4.104.114.84.95
(edit) @a2504f7   11/01/99 13:07:56 Joel Sherrill Removed shmsupp directory as it is not really implemented. 4.104.114.84.95
(edit) @4c9d61e8   11/01/99 13:07:22 Joel Sherrill MVME2307 does not really include MP support. 4.104.114.84.95
(edit) @7046cdd   10/28/99 16:01:41 Joel Sherrill Patch rtems-rc-19991011-3.diff from Ralf Corsepius. 4.104.114.84.95
(edit) @c8b35b1b   10/28/99 13:36:26 Joel Sherrill Notes on what to do when merging a BSP. 4.104.114.84.95
(edit) @45544f0   10/27/99 20:50:57 Joel Sherrill Patch from Aleksey (Quality Quorum <qqi@…>) to increase … 4.104.114.84.95
(edit) @3abbfdb   10/27/99 19:27:05 Joel Sherrill Added $(EXEEXT) in attempt to help Cygwin install process. 4.104.114.84.95
(edit) @2bdc1e98   10/27/99 18:54:14 Joel Sherrill Last cleanup to attempt to link. 4.104.114.84.95
(edit) @ae7325bd   10/27/99 17:25:53 Joel Sherrill rxgen960 now compiles -- may not link. 4.104.114.84.95
(edit) @2ea8df3   10/27/99 16:27:34 Joel Sherrill Added CVS Ids and a basic header. More header cleanup needed. 4.104.114.84.95
(edit) @f08a5596   10/27/99 16:26:00 Joel Sherrill Removed systbl.S save_systbl.c. They were unnecessary. 4.104.114.84.95
(edit) @8ac4213   10/27/99 16:21:49 Joel Sherrill Removed sctns.S. This file was obviously the output of the compiler. 4.104.114.84.95
(edit) @919822f   10/27/99 16:19:24 Joel Sherrill Replaced Makefile.in's with modified copies of cvme961 to get … 4.104.114.84.95
(edit) @d73a8649   10/27/99 15:58:26 Joel Sherrill Moved timerisr.s to timerisr.S per GNU conventions. 4.104.114.84.95
(edit) @ce644256   10/27/99 15:57:20 Joel Sherrill Moved systbl.s to systbl.S per GNU conventions. 4.104.114.84.95
(edit) @5ee66da   10/27/99 15:57:19 Joel Sherrill Moved sctns.s to sctns.S per GNU conventions. 4.104.114.84.95
(edit) @bf71be9e   10/27/99 15:57:17 Joel Sherrill Moved rxgen_romld.s to rxgen_romld.S per GNU conventions. 4.104.114.84.95
(edit) @478c4b8   10/27/99 15:57:16 Joel Sherrill Moved ihandler.s to ihandler.S per GNU conventions. 4.104.114.84.95
(edit) @49b8c26   10/27/99 15:57:15 Joel Sherrill Moved asmstub.s to asmstub.S per GNU conventions. 4.104.114.84.95
(edit) @eb7f0f22   10/27/99 15:57:14 Joel Sherrill Moved asmfault.s to asmfault.S per GNU conventions. 4.104.114.84.95
(edit) @702c5f5   10/27/99 15:29:18 Joel Sherrill The rxgen960 BSP and i960 RPM support was submitted by Mark Bronson … 4.104.114.84.95
(edit) @7ee88c16   10/26/99 20:30:20 Joel Sherrill Split console_reserve_resources to separate file to reduce code size. 4.104.114.84.95
(edit) @66a8c6f   10/26/99 15:21:01 Joel Sherrill Patch from Emmanuel Raguet <raguet@…> to fix a small bug … 4.104.114.84.95
(edit) @99826740   10/26/99 01:35:36 Joel Sherrill Modifications from Erik Ivanenko <erik.ivanenko@…> to add … 4.104.114.84.95
(edit) @f70598c7   10/26/99 01:34:42 Joel Sherrill Patch from Erik Ivanenko <erik.ivanenko@…> to fix some … 4.104.114.84.95
(edit) @3eb75db3   10/25/99 14:52:19 Joel Sherrill tch from Eric Valette <valette@…> and Emmanuel Raguet … 4.104.114.84.95
(edit) @538db54   10/25/99 14:09:13 Joel Sherrill Modified to produce correct output with new version of sis. 4.104.114.84.95
(edit) @f58f0b45   10/11/99 15:28:04 Joel Sherrill Now compiles for coff and elf. 4.104.114.84.95
(edit) @1f350ef9   10/06/99 20:54:06 Joel Sherrill Removed aclocal.m4 generated from aclocal macros 4.104.114.84.95
(edit) @54eccb1a   10/06/99 20:52:34 Joel Sherrill Removed configure generated from configure.in 4.104.114.84.95
(edit) @1b821242   10/06/99 20:37:26 Joel Sherrill Modified to avoid conflicts on definitions of malloc. newlib 1.8.2 … 4.104.114.84.95
(edit) @3adc848d   10/06/99 20:34:55 Joel Sherrill Modified to explicitly list all files as part of C_PIECES. 4.104.114.84.95
(edit) @add0545d   10/06/99 18:05:39 Joel Sherrill Added sections as required by C++ and ELF. 4.104.114.84.95
(edit) @01c36de   10/06/99 18:04:34 Joel Sherrill Added more sections and made minor modifications to let the linkcmds … 4.104.114.84.95
(edit) @8eb0f64   10/05/99 19:21:14 Joel Sherrill Added comment with CVS Id. 4.104.114.84.95
(edit) @25ce07e0   10/05/99 19:20:27 Joel Sherrill Changed bra.s to bra.l to remove error with new version of binutils. 4.104.114.84.95
(edit) @649bcbc   10/05/99 19:19:13 Joel Sherrill Changed bra.s to bra.l to correct compilation error triggered by new … 4.104.114.84.95
(edit) @74f3d8f   10/05/99 19:18:14 Joel Sherrill Corrected so sections did not overlap with new version of binutils. 4.104.114.84.95
(edit) @fce982a8   10/05/99 19:17:45 Joel Sherrill Corrected comment. 4.104.114.84.95
(edit) @b22feedc   10/05/99 18:38:04 Joel Sherrill Modified to remove reference to Force CPU386. Actually this was a … 4.104.114.84.95
(edit) @7c9cca11   10/05/99 18:34:15 Joel Sherrill Modified to remove error for overlapping sections now that … 4.104.114.84.95
(edit) @6d81ea3   10/05/99 14:20:12 Joel Sherrill Removed targets and configurations that are no longer functional and … 4.104.114.84.95
(edit) @17978a1   10/05/99 14:05:30 Joel Sherrill Minor corrections to get mvme2307 to compile. 4.104.114.84.95
(edit) @133dcd92   10/05/99 14:02:57 Joel Sherrill Patch from Eric Valette <valette@…> with two small fixes … 4.104.114.84.95
(edit) @4075af6f   10/05/99 13:49:54 Joel Sherrill Regenerated. 4.104.114.84.95
(edit) @19ca797   10/04/99 20:41:28 Joel Sherrill Motorola MVME2307 BSP submitted by Jay Kulpinski … 4.104.114.84.95
(edit) @811804fe   10/04/99 19:15:14 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> to make fix bug … 4.104.114.84.95
(edit) @b62a92c   10/04/99 18:20:14 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: The patch below … 4.104.114.84.95
(edit) @4f021c0   10/04/99 17:33:23 Joel Sherrill Removed Makefile.in generated from Makefile.am 4.104.114.84.95
(edit) @b7c712e3   10/04/99 16:19:21 Joel Sherrill Removed empty file. 4.104.114.84.95
(edit) @cb620844   10/04/99 13:47:31 Joel Sherrill Patch from Eric Norum <eric@…> to ensure the console … 4.104.114.84.95
(edit) @67d0f4e   10/04/99 13:43:46 Joel Sherrill Modified to setup environment pointer on all BSPs. This results in … 4.104.114.84.95
(edit) @936f288   10/04/99 13:42:45 Joel Sherrill Setup environment pointer for getenv/putenv. Patch from Eric Norum … 4.104.114.84.95
(edit) @473b4e5   10/04/99 13:30:15 Joel Sherrill Regenerated. 4.104.114.84.95
(edit) @a24c280   09/09/99 21:22:36 Joel Sherrill Applied patch rtems-rc-19990820-6.diff.gz from Ralf Corsepius … 4.104.114.84.95
(edit) @e1d8abb   09/07/99 13:45:03 Joel Sherrill Applied patch rtems-rc-19990820-6.diff.gz from Ralf Corsepius … 4.104.114.84.95
(edit) @6688a0d   09/02/99 18:23:32 Joel Sherrill Missing file from Charles-Antoine Gauthier … 4.104.114.84.95
(edit) @9396d1e4   09/02/99 18:12:57 Joel Sherrill Cleaned up to move conditional to C files -- not Makefile. 4.104.114.84.95
(edit) @6cc786f   08/30/99 18:07:45 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: Somehow a … 4.104.114.84.95
(edit) @6fc973e   08/18/99 16:49:52 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: Here is … 4.104.114.84.95
(edit) @1d4048b2   08/11/99 23:45:57 Joel Sherrill Patch from Tony R. Ambardar <tonya@…>: I'm attaching a … 4.104.114.84.95
(edit) @981b99f   08/10/99 16:41:44 Joel Sherrill Patch from Eric Valette <valette@…> and Emmanuel Raguet … 4.104.114.84.95
(edit) @908436c1   08/10/99 15:38:09 Joel Sherrill New configuration files added by patch from Ralf Corsepius … 4.104.114.84.95
(edit) @3a8915e   08/06/99 17:55:25 Joel Sherrill Patch rtems-rc-19990709-6-diff from Ralf Corsepius … 4.104.114.84.95
(edit) @22544db9   08/06/99 16:56:16 Joel Sherrill Typo -- removed blank line at top of file. 4.104.114.84.95
(edit) @f42fb02   08/06/99 16:00:32 Joel Sherrill Patch from Jiri Gaisler <jgais@…> to fix remote gdb use: … 4.104.114.84.95
(edit) @a92280e0   08/05/99 22:37:17 Joel Sherrill Now supports C++ global constructors and exceptions. 4.104.114.84.95
(edit) @a1c70a2   08/05/99 18:02:15 Joel Sherrill Fixed typo on report from Tony R. Ambardar <tonya@…>. 4.104.114.84.95
(edit) @783e8322   08/03/99 13:52:59 Joel Sherrill Patch from Eric Valette <valette@…> to fix interrupt … 4.104.114.84.95
(edit) @26eff5c   08/02/99 20:26:57 Joel Sherrill Fix By Joel based on suggestion from Ian Lance Taylor <ian@…> … 4.104.114.84.95
(edit) @ae2ddb8   08/02/99 15:40:27 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: The patch … 4.104.114.84.95
(edit) @ac384b9   08/02/99 15:25:24 Joel Sherrill Added more sections to pick up all of the new C++ sections. 4.104.114.84.95
(edit) @bd527866   08/02/99 15:24:57 Joel Sherrill Now correctly does deep copy. 4.104.114.84.95
(edit) @1896a650   07/30/99 17:52:50 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: The main topic … 4.104.114.84.95
(edit) @aa9eb940   07/30/99 17:28:11 Joel Sherrill Fixed typos. 4.104.114.84.95
(edit) @a2cc7b7f   07/30/99 17:18:39 Joel Sherrill Corrected typo and added correct conditional compilation on … 4.104.114.84.95
(edit) @f82c98b   07/28/99 16:14:57 Joel Sherrill Missed adding file from Eric Valette <valette@…>. This file … 4.104.114.84.95
(edit) @54f440d   07/26/99 22:11:02 Joel Sherrill Patch from Charles-Antoine Gauthier <charles.gauthier@…>. to … 4.104.114.84.95
(edit) @220ad7d   07/26/99 21:38:08 Joel Sherrill Patch fixing typo from Eric Valette <valette@…> on bug … 4.104.114.84.95
