@6b7cf9f
01/03/00 15:39:06 |
Joel Sherrill |
Patch rtems-rc-19991203-12.diff from Ralf Corsepius …
4.104.114.84.95
@b84176b
01/03/00 15:36:18 |
Joel Sherrill |
Do not explicitly list pieces from libcpu used.
4.104.114.84.95
@e07b6868
01/03/00 14:14:37 |
Joel Sherrill |
Added tm27 stuff.
4.104.114.84.95
@95273a6
01/03/00 14:06:42 |
Joel Sherrill |
Combination of coverhd.h cleanup and MVME23xx/MCP750 patch from Eric …
4.104.114.84.95
@d5c4681e
01/03/00 14:04:22 |
Joel Sherrill |
Use shared coverhd.h.
4.104.114.84.95
@2116e33
12/21/99 20:29:57 |
Joel Sherrill |
Reverted the delay logic.
4.104.114.84.95
@ed46b47
12/21/99 20:29:40 |
Joel Sherrill |
Moved PPC_Set_decrementer() and PPC_Get_timebase_register() to …
4.104.114.84.95
@56018097
12/21/99 20:28:13 |
Joel Sherrill |
Now use coverhd.h out of the libbsp/shared directory.
4.104.114.84.95
@0d6f0b4
12/21/99 20:10:04 |
Joel Sherrill |
Now use shared coverhd.h
4.104.114.84.95
@a3ba9f98
12/21/99 17:05:15 |
Joel Sherrill |
New file.
4.104.114.84.95
@8437abd4
12/21/99 16:56:31 |
Joel Sherrill |
Removed as part of moving this driver to libchip.
4.104.114.84.95
@400c552
12/21/99 16:20:38 |
Joel Sherrill |
Removing Makefile.in and adding Makefile.am. These were missed in …
4.104.114.84.95
@fb16fed
12/21/99 15:25:05 |
Joel Sherrill |
Patch rtems-rc-19991203-10.diff from Ralf Corsepius …
4.104.114.84.95
@9ba1f0a
12/21/99 15:04:48 |
Joel Sherrill |
Patch rtems-rc-19991203-9.diff from Ralf Corsepius …
4.104.114.84.95
@8b91282
12/21/99 14:27:52 |
Joel Sherrill |
Patch rtems-rc-19991203-5.diff from Ralf Corsepius …
4.104.114.84.95
@947c27aa
12/16/99 14:30:34 |
Joel Sherrill |
Spelling error corrected.
4.104.114.84.95
@e8918ec
12/13/99 22:12:03 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to change to gen68360 clock …
4.104.114.84.95
@c629812
12/13/99 22:10:45 |
Joel Sherrill |
Removed warnings.
4.104.114.84.95
@da8ae79b
12/13/99 21:21:31 |
Joel Sherrill |
Warning removal patch from Philip A. Prindeville <philipp@…>.
4.104.114.84.95
@5dae90a
12/13/99 17:37:25 |
Joel Sherrill |
Patch rtems-rc-19991203-3.diff from Ralf Corsepius …
4.104.114.84.95
@ad0c286
12/13/99 16:02:57 |
Joel Sherrill |
4.104.114.84.95
@fa178d49
12/13/99 15:57:41 |
Joel Sherrill |
4.104.114.84.95
@49be66d
12/13/99 14:48:58 |
Joel Sherrill |
Now builds and installs properly.
4.104.114.84.95
@76c356f
12/03/99 15:46:17 |
Joel Sherrill |
Patch from Aleksey (Quality Quorum <qqi@…>) to change the …
4.104.114.84.95
@ad9a21a
12/03/99 13:53:01 |
Joel Sherrill |
New file.
4.104.114.84.95
@a0a6f67f
12/03/99 13:48:53 |
Joel Sherrill |
Added more timing information.
4.104.114.84.95
@5707fe9
12/03/99 13:46:13 |
Joel Sherrill |
New file based on information from <valette@…>.
4.104.114.84.95
@5a820308
12/03/99 13:42:34 |
Joel Sherrill |
Modification from Emmanuel Raguet <raguet@…> to merge the …
4.104.114.84.95
@5ea0bd37
12/03/99 13:14:08 |
Joel Sherrill |
Patch from Rosimildo DaSilva? <rdasilva@…> for Cygwin
to …
4.104.114.84.95
@43283456
12/02/99 17:45:14 |
Joel Sherrill |
Patch rtems-rc-19991123-rc-2.diff from Ralf Corsepius …
4.104.114.84.95
@3a96054
12/02/99 14:58:38 |
Joel Sherrill |
Merged of mcp750 and mvme2307 BSP by Eric Valette …
4.104.114.84.95
@acc25ee
12/02/99 14:31:19 |
Joel Sherrill |
4.104.114.84.95
@e4ab88f
12/02/99 14:00:01 |
Joel Sherrill |
4.104.114.84.95
@48bfd992
11/30/99 19:58:02 |
Joel Sherrill |
Renamed shm.h to shm_driver.h to avoid conflicts with POSIX shm.h.
4.104.114.84.95
@79f2e19
11/30/99 13:58:59 |
Joel Sherrill |
Split from console.c to eliminate dependencies.
4.104.114.84.95
@1d9a2fc
11/29/99 15:45:11 |
Joel Sherrill |
Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius …
4.104.114.84.95
@49da88c
11/23/99 15:53:09 |
Joel Sherrill |
Patch rtems-rc-19991117-16.diff from Ralf Corsepius …
4.104.114.84.95
@7e642ba
11/22/99 19:27:13 |
Joel Sherrill |
Patch rtems-rc-19991117-9.diff from Ralf Corsepius …
4.104.114.84.95
@6b910bd
11/22/99 14:27:04 |
Joel Sherrill |
Use PGM consistently.
4.104.114.84.95
@c99d395
11/22/99 14:26:36 |
Joel Sherrill |
Made it agree on PGM versus PGM/PGMS.
4.104.114.84.95
@561e4ff6
11/22/99 14:03:16 |
Joel Sherrill |
Adding files missed by earlier merger of SH-2.
4.104.114.84.95
@875fbdbb
11/22/99 13:48:10 |
Joel Sherrill |
Added files missed by previous merger of SH-2 port.
4.104.114.84.95
@9608320
11/22/99 13:41:11 |
Joel Sherrill |
Patch rtems-rc-19991117-4.diff from Ralf Corsepius …
4.104.114.84.95
@d2a05e7
11/19/99 16:40:40 |
Joel Sherrill |
Renaming all BSP specific startXXX directories to use the same name …
4.104.114.84.95
@9c0385a
11/19/99 16:22:09 |
Joel Sherrill |
4.104.114.84.95
@149f3f9
11/19/99 16:06:32 |
Joel Sherrill |
Moved startsis to start.
4.104.114.84.95
@4a238002
11/18/99 21:22:58 |
Joel Sherrill |
Patch from "John M. Mills" <jmills@…> with subsequent cleanup …
4.104.114.84.95
@08311cc3
11/17/99 17:51:34 |
Joel Sherrill |
Updated copyright notice.
4.104.114.84.95
@39827cc
11/17/99 17:31:51 |
Joel Sherrill |
Now allows override of base address via -Ttext command to linker.
4.104.114.84.95
@23d9392f
11/17/99 15:42:18 |
Joel Sherrill |
New file documenting the on board monitor (PPCBUG) configuration used …
4.104.114.84.95
@38d65f80
11/16/99 22:56:53 |
Joel Sherrill |
Fixed alignment problem on _endtext.
4.104.114.84.95
@ac656f2d
11/16/99 14:15:56 |
Joel Sherrill |
Moved start code from lib/start to libbsp.
4.104.114.84.95
@1d04e16
11/16/99 13:45:51 |
Joel Sherrill |
4.104.114.84.95
@a7d988a
11/16/99 13:37:25 |
Joel Sherrill |
Minor changes since new Makefile.
4.104.114.84.95
@14dbf50
11/16/99 13:34:41 |
Joel Sherrill |
Added start subdirectory.
4.104.114.84.95
@c73b8ac2
11/09/99 22:18:43 |
Joel Sherrill |
This patch adds the basic framework for the ITRON 3.0 API …
4.104.114.84.95
@c8cad188
11/09/99 22:16:16 |
Joel Sherrill |
Removed.
4.104.114.84.95
@d55af6d
11/09/99 15:38:47 |
Joel Sherrill |
Now using libchip instead of local precursor to libchip. Untested.
4.104.114.84.95
@0fab6dde
11/05/99 17:49:56 |
Joel Sherrill |
Patch from Eric Valette <valette@…> so this will build …
4.104.114.84.95
@f817b02
11/04/99 18:05:09 |
Joel Sherrill |
The files in libcpu should not be directly dependent on any BSP. In …
4.104.114.84.95
@d76608e0
11/03/99 12:46:29 |
Joel Sherrill |
Typo fixed by Ralf Corsepius <corsepiu@…>.
4.104.114.84.95
@c42bd452
11/02/99 16:05:41 |
Joel Sherrill |
Split console_reserve_resources into its own file to reduce …
4.104.114.84.95
@92f69999
11/01/99 13:08:35 |
Joel Sherrill |
Removed all references to shared memory driver as it is not supported …
4.104.114.84.95
@a2504f7
11/01/99 13:07:56 |
Joel Sherrill |
Removed shmsupp directory as it is not really implemented.
4.104.114.84.95
@4c9d61e8
11/01/99 13:07:22 |
Joel Sherrill |
MVME2307 does not really include MP support.
4.104.114.84.95
@7046cdd
10/28/99 16:01:41 |
Joel Sherrill |
Patch rtems-rc-19991011-3.diff from Ralf Corsepius.
4.104.114.84.95
@c8b35b1b
10/28/99 13:36:26 |
Joel Sherrill |
Notes on what to do when merging a BSP.
4.104.114.84.95
@45544f0
10/27/99 20:50:57 |
Joel Sherrill |
increase …
4.104.114.84.95
@3abbfdb
10/27/99 19:27:05 |
Joel Sherrill |
Added $(EXEEXT) in attempt to help Cygwin install process.
4.104.114.84.95
@2bdc1e98
10/27/99 18:54:14 |
Joel Sherrill |
Last cleanup to attempt to link.
4.104.114.84.95
@ae7325bd
10/27/99 17:25:53 |
Joel Sherrill |
rxgen960 now compiles -- may not link.
4.104.114.84.95
@2ea8df3
10/27/99 16:27:34 |
Joel Sherrill |
Added CVS Ids and a basic header. More header cleanup needed.
4.104.114.84.95
@f08a5596
10/27/99 16:26:00 |
Joel Sherrill |
Removed systbl.S save_systbl.c. They were unnecessary.
4.104.114.84.95
@8ac4213
10/27/99 16:21:49 |
Joel Sherrill |
Removed sctns.S. This file was obviously the output of the compiler.
4.104.114.84.95
@919822f
10/27/99 16:19:24 |
Joel Sherrill |
Replaced Makefile.in's with modified copies of cvme961 to get …
4.104.114.84.95
@d73a8649
10/27/99 15:58:26 |
Joel Sherrill |
Moved timerisr.s to timerisr.S per GNU conventions.
4.104.114.84.95
@ce644256
10/27/99 15:57:20 |
Joel Sherrill |
Moved systbl.s to systbl.S per GNU conventions.
4.104.114.84.95
@5ee66da
10/27/99 15:57:19 |
Joel Sherrill |
Moved sctns.s to sctns.S per GNU conventions.
4.104.114.84.95
@bf71be9e
10/27/99 15:57:17 |
Joel Sherrill |
Moved rxgen_romld.s to rxgen_romld.S per GNU conventions.
4.104.114.84.95
@478c4b8
10/27/99 15:57:16 |
Joel Sherrill |
Moved ihandler.s to ihandler.S per GNU conventions.
4.104.114.84.95
@49b8c26
10/27/99 15:57:15 |
Joel Sherrill |
Moved asmstub.s to asmstub.S per GNU conventions.
4.104.114.84.95
@eb7f0f22
10/27/99 15:57:14 |
Joel Sherrill |
Moved asmfault.s to asmfault.S per GNU conventions.
4.104.114.84.95
@702c5f5
10/27/99 15:29:18 |
Joel Sherrill |
The rxgen960 BSP and i960 RPM support was submitted by Mark Bronson …
4.104.114.84.95
@7ee88c16
10/26/99 20:30:20 |
Joel Sherrill |
Split console_reserve_resources to separate file to reduce
code size.
4.104.114.84.95
@66a8c6f
10/26/99 15:21:01 |
Joel Sherrill |
Patch from Emmanuel Raguet <raguet@…> to fix a small bug …
4.104.114.84.95
@99826740
10/26/99 01:35:36 |
Joel Sherrill |
Modifications from Erik Ivanenko <erik.ivanenko@…> to add …
4.104.114.84.95
@f70598c7
10/26/99 01:34:42 |
Joel Sherrill |
Patch from Erik Ivanenko <erik.ivanenko@…> to fix some …
4.104.114.84.95
@3eb75db3
10/25/99 14:52:19 |
Joel Sherrill |
tch from Eric Valette <valette@…> and Emmanuel Raguet …
4.104.114.84.95
@538db54
10/25/99 14:09:13 |
Joel Sherrill |
Modified to produce correct output with new version of sis.
4.104.114.84.95
@f58f0b45
10/11/99 15:28:04 |
Joel Sherrill |
Now compiles for coff and elf.
4.104.114.84.95
@1f350ef9
10/06/99 20:54:06 |
Joel Sherrill |
Removed aclocal.m4 generated from aclocal macros
4.104.114.84.95
@54eccb1a
10/06/99 20:52:34 |
Joel Sherrill |
Removed configure generated from configure.in
4.104.114.84.95
@1b821242
10/06/99 20:37:26 |
Joel Sherrill |
Modified to avoid conflicts on definitions of malloc. newlib 1.8.2 …
4.104.114.84.95
@3adc848d
10/06/99 20:34:55 |
Joel Sherrill |
Modified to explicitly list all files as part of C_PIECES.
4.104.114.84.95
@add0545d
10/06/99 18:05:39 |
Joel Sherrill |
Added sections as required by C++ and ELF.
4.104.114.84.95
@01c36de
10/06/99 18:04:34 |
Joel Sherrill |
Added more sections and made minor modifications to let the linkcmds …
4.104.114.84.95
@8eb0f64
10/05/99 19:21:14 |
Joel Sherrill |
Added comment with CVS Id.
4.104.114.84.95
@25ce07e0
10/05/99 19:20:27 |
Joel Sherrill |
Changed bra.s to bra.l to remove error with new version of binutils.
4.104.114.84.95
@649bcbc
10/05/99 19:19:13 |
Joel Sherrill |
Changed bra.s to bra.l to correct compilation error triggered by new …
4.104.114.84.95
@74f3d8f
10/05/99 19:18:14 |
Joel Sherrill |
Corrected so sections did not overlap with new version of binutils.
4.104.114.84.95
