Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src/lib/libbsp
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @6436036c   10/17/06 17:12:18 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * LICENSE: … 4.104.114.84.95
(edit) @57357d9   10/17/06 08:58:44 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @11c60096   10/17/06 06:35:01 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @754610f   10/17/06 06:21:56 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @2c278a4   10/17/06 02:42:28 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @1af911b8   10/17/06 02:40:57 Ralf Corsepius Convert to utf-8. 4.104.114.84.95
(edit) @748bc60   10/17/06 02:35:27 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @ca97282   10/17/06 02:35:11 Ralf Corsepius Convert to utf-8 4.104.114.84.95
(edit) @0c8c5e3f   10/17/06 02:30:21 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @36e0d53   10/17/06 02:25:26 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @372b8414   10/15/06 05:59:35 Ralf Corsepius Convert to utf-8. 4.104.114.84.95
(edit) @e0987b9d   10/15/06 05:59:17 Ralf Corsepius 2006-10-15 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @47ebb84   10/15/06 05:53:42 Ralf Corsepius 2006-10-15 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @e6a07e14   10/15/06 05:53:22 Ralf Corsepius Convert to utf-8 4.104.114.84.95
(edit) @c69885a5   09/14/06 15:50:54 Joel Sherrill 2006-09-14 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @6094c1a   09/11/06 21:46:47 Joel Sherrill * empty log message * 4.104.114.84.95
(edit) @c5feb602   09/11/06 21:44:06 Joel Sherrill 2006-09-11 Joel Sherrill <joel@…> * include/mpc5200.h, … 4.104.114.84.95
(edit) @b18803f   09/11/06 21:43:59 Joel Sherrill 2006-09-11 Joel Sherrill <joel@…> * startup/bspstart.c: … 4.104.114.84.95
(edit) @da2fc6c0   09/11/06 21:43:56 Joel Sherrill 2006-09-11 Joel Sherrill <joel@…> * console/console.c, … 4.104.114.84.95
(edit) @1883c87   09/11/06 21:43:45 Joel Sherrill 2006-09-11 Joel Sherrill <joel@…> * console/console.c, … 4.104.114.84.95
(edit) @0b1cb769   09/11/06 21:43:36 Joel Sherrill 2006-09-11 Joel Sherrill <joel@…> * startup/init5282.c: … 4.104.114.84.95
(edit) @c6fda81   09/11/06 21:43:30 Joel Sherrill 2006-09-11 Joel Sherrill <joel@…> * console/fb_vga.c, … 4.104.114.84.95
(edit) @126694fa   09/11/06 21:43:24 Joel Sherrill 2006-09-11 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @cb66894   09/11/06 12:14:53 Chris Johns Remove extra CRLF. 4.104.114.84.95
(edit) @8f1e4948   09/11/06 11:52:08 Chris Johns Remove extra CRLF. 4.104.114.84.95
(edit) @662c157   09/04/06 23:29:29 strauman * startup/bspstart.c, start/start.S: Since the crude memory … 4.104.114.84.95
(edit) @f74578a2   09/04/06 23:24:08 strauman * startup/linkcmds: added *(.text.*) *(.data.*) *(.bss.*) 4.104.114.84.95
(edit) @e8beb870   08/23/06 11:25:54 Joel Sherrill 2006-08-23 Joel Sherrill <joel@…> * startup/bspstart.c: … 4.104.114.84.95
(edit) @25c53700   08/22/06 17:21:14 Joel Sherrill 2006-08-22 Joel Sherrill <joel@…> * startup/bspstart.c: … 4.104.114.84.95
(edit) @655c8bf2   08/22/06 02:52:29 strauman * shared/vme/vmeconfig.c: open outbound window to VME CSR space if … 4.104.114.84.95
(edit) @0f8eaed1   08/15/06 11:06:11 Joel Sherrill 2006-08-15 Joel Sherrill <joel@…> * Makefile.am, … 4.104.114.84.95
(edit) @4a4c7900   08/13/06 15:58:46 Thomas.Doerfler added vectors.h to bsp.h fixed bug in mscan 4.104.114.84.95
(edit) @ced8ea7d   08/11/06 00:29:52 strauman * shared/irq/openpic_i8259_irq.c: fixed type of 'frame' argument to … 4.104.114.84.95
(edit) @07e6eba3   08/10/06 11:11:49 Joel Sherrill 2006-08-10 Joel Sherrill <joel@…> * .cvsignore: New file. 4.104.114.84.95
(edit) @417fca76   08/09/06 23:02:38 Joel Sherrill 2006-08-09 Joel Sherrill <joel@…> * startup/linkcmds: … 4.104.114.84.95
(edit) @82756af   08/09/06 22:02:16 Joel Sherrill 2006-08-09 Kolja Waschk <waschk@…> * clock/clock.c: New file. 4.104.114.84.95
(edit) @783669fc   08/09/06 20:57:11 Joel Sherrill 2006-08-09 Kolja Waschk <waschk@…> * ChangeLog?, Makefile.am, … 4.104.114.84.95
(edit) @73a312d7   08/07/06 07:01:25 Thomas.Doerfler added startup/linkcmds.brs5l 4.104.114.84.95
(edit) @167818a   08/01/06 18:30:35 WENorum Add bsp_setbenv system call. 4.104.114.84.95
(edit) @517782a   07/16/06 14:37:02 Joel Sherrill 2006-07-16 Joel Sherrill <joel@…> * preinstall.am: Install … 4.104.114.84.95
(edit) @0b83afe9   07/14/06 20:11:29 Joel Sherrill 2006-07-13 Jerry Needell <jerry.needell@…> * clock/ckinit.c, … 4.104.114.84.95
(edit) @8eb78a20   07/14/06 09:52:00 Thomas.Doerfler added ChangeLog? entries for PR1117/1118/1119/1120 4.104.114.84.95
(edit) @b365d4d   07/13/06 00:41:03 strauman * shared/pci/pcibios.c: let pci_find_device() return -1 on failure, … 4.104.114.84.95
(edit) @c8f74b47   07/12/06 23:43:56 strauman * vmeUniverse/vmeTsi148.c: Silenced compiler warnings (gcc-4.1.1 … 4.104.114.84.95
(edit) @689429f8   07/12/06 23:39:48 strauman * shared/startup/probeMemEnd.c: added paranoia to inline assembly … 4.104.114.84.95
(edit) @c632f647   07/12/06 23:37:13 strauman * shared/startup/panic.c: Fixed compiler warnings. 4.104.114.84.95
(edit) @ad6a58d   07/12/06 20:57:29 Joel Sherrill 2006-07-12 Jerry Needell <jerry.needell@…> * amba/amba.c, … 4.104.114.84.95
(edit) @9956f81d   07/12/06 19:08:32 Joel Sherrill 2006-07-12 Joel Sherrill <joel@…> * Makefile.am, … 4.104.114.84.95
(edit) @97871c97   07/12/06 18:24:44 Joel Sherrill 2006-07-12 Joel Sherrill <joel@…> * Makefile.am: Merge SHM … 4.104.114.84.95
(edit) @1a3ddc10   07/11/06 22:27:28 Joel Sherrill 2006-07-11 Joel Sherrill <joel@…> * clock/ckinit.c: … 4.104.114.84.95
(edit) @4795141   07/11/06 15:56:58 Joel Sherrill 2006-07-11 Joel Sherrill <joel@…> * leon_greth/.cvsignore, … 4.104.114.84.95
(edit) @72baf565   07/11/06 14:53:07 Joel Sherrill 2006-07-11 Joel Sherrill <joel@…> * clock/ckinit.c, … 4.104.114.84.95
(edit) @6dd1665c   07/11/06 14:14:15 Joel Sherrill 2006-07-11 Jerry Needell <jerry.needell@…> * ChangeLog?, … 4.104.114.84.95
(edit) @a871a6c7   07/11/06 03:32:01 Ralf Corsepius Regenerate. 4.104.114.84.95
(edit) @c9b005a9   07/09/06 10:05:27 Thomas.Doerfler applied patches for PR1117/1118/1119/1120 4.104.114.84.95
(edit) @2758e1fc   06/25/06 00:36:40 Joel Sherrill 2006-06-24 Joel Sherrill <joel@…> * startup/linkcmds, … 4.104.114.84.95
(edit) @272ac23a   06/25/06 00:36:35 Joel Sherrill 2006-06-24 Joel Sherrill <joel@…> * startup/linkcmds: Add … 4.104.114.84.95
(edit) @f3323e1   06/25/06 00:36:29 Joel Sherrill 2006-06-24 Joel Sherrill <joel@…> * startup/linkcmds, … 4.104.114.84.95
(edit) @b8de9518   06/25/06 00:36:23 Joel Sherrill 2006-06-24 Joel Sherrill <joel@…> * startup/linkcmds, … 4.104.114.84.95
(edit) @f70c44da   06/25/06 00:14:10 Joel Sherrill 2006-06-24 Joel Sherrill <joel@…> * startup/linkcmds: Add … 4.104.114.84.95
(edit) @6f96a1d   06/24/06 14:49:51 Joel Sherrill 2006-06-24 Joel Sherrill <joel@…> * configure.ac: 4.104.114.84.95
(edit) @504c5ca   06/23/06 16:04:33 Joel Sherrill 2006-06-23 Worth Burruss <worth@…> * Makefile.am, … 4.104.114.84.95
(edit) @026e4793   06/22/06 18:54:46 Joel Sherrill 2006-06-22 Joel Sherrill <joel@…> PR 1100/bsps * … 4.104.114.84.95
(edit) @e5f55a1   06/21/06 13:52:18 Joel Sherrill Fix formatting. 4.104.114.84.95
(edit) @06cfd95   06/19/06 20:51:19 strauman Indicate that it's ok to use decoupled cycles to access on-board … 4.104.114.84.95
(edit) @9a30162   06/19/06 20:34:07 strauman Added address-modifier codes for BLT/MBLT. 4.104.114.84.95
(edit) @df9cadc2   06/19/06 20:19:06 strauman Only set/access the _BSP_vme_bridge_irq variable on BSPs that define … 4.104.114.84.95
(edit) @599e719a   06/19/06 20:14:05 strauman filter exception vector for altivec and remap 0xf20 to assigned … 4.104.114.84.95
(edit) @d1999c8b   06/19/06 20:08:41 strauman fixed compiler warnings (bspIo.h inclusion, cast of number constants … 4.104.114.84.95
(edit) @efc0cd8   06/19/06 19:49:11 strauman Never allow the FPU to be switched on for integer-only tasks (new gcc … 4.104.114.84.95
(edit) @eeef62e   06/18/06 13:37:35 Joel Sherrill 2006-06-18 Joel Sherrill <joel@…> * README: 4.104.114.84.95
(edit) @965c3924   06/03/06 03:24:00 Jay Monkman 2006-06-02 Jay Monkman <jtm@…> * shared/irq/irq_init.c: … 4.104.114.84.95
(edit) @1453d92   06/03/06 03:22:19 Jay Monkman 2006-06-02 Jay Monkman <jtm@…> * startup/linkcmds: … 4.104.114.84.95
(edit) @20e266ca   06/03/06 03:21:30 Jay Monkman 2006-06-02 Jay Monkman <jtm@…> * times: Reran timing … 4.104.114.84.95
(edit) @47dbc76   06/03/06 03:20:15 Jay Monkman 2006-06-02 Jay Monkman <jtm@…> * startup/bspstart.c: … 4.104.114.84.95
(edit) @9cdfb0e   06/03/06 03:18:46 Jay Monkman 2006-06-02 Jay Monkman <jtm@…> * Makefile.am, … 4.104.114.84.95
(edit) @128bbf9   06/03/06 03:08:01 Jay Monkman 2006-06-02 Jay Monkman <jtm@…> * irq/bsp_irq_init.c: … 4.104.114.84.95
(edit) @1ca844f9   06/03/06 03:06:54 Jay Monkman 2006-06-02 Jay Monkman * irq/bsp_irq_init.c: Changed interrupt … 4.104.114.84.95
(edit) @9c05850c   06/03/06 03:04:41 Jay Monkman 2006-06-02 Jay Monkman * network/network.c: Changed interrupt … 4.104.114.84.95
(edit) @0eede05   06/02/06 21:53:04 Jay Monkman 2006-06-02 Jay Monkman <jtm@…> * start/start.S, … 4.104.114.84.95
(edit) @1db81f98   06/01/06 15:23:31 Joel Sherrill Formatting. 4.104.114.84.95
(edit) @2ba4b72   05/31/06 13:43:16 Joel Sherrill 2006-05-31 Joel Sherrill <joel@…> * clock/clock.c: Switch … 4.104.114.84.95
(edit) @8a742dd   05/15/06 15:59:01 WENorum Allow single spurious FPGA interrupt. 4.104.114.84.95
(edit) @a7edc92   05/15/06 14:47:32 WENorum Improve handling of unexpected FPGA interrupt conditions. 4.104.114.84.95
(edit) @cd0142d5   04/12/06 20:32:35 Joel Sherrill 2006-04-12 Konrad Eisele <konrad@…> * include/leon.h: Add … 4.104.114.84.95
(edit) @e846fc9   04/11/06 19:17:09 WENorum Add default exception handler. 4.104.114.84.95
(edit) @73ad880   04/05/06 20:12:51 Joel Sherrill Fix formatting. 4.104.114.84.95
(edit) @84572474   03/24/06 20:07:57 WENorum Add missing reset cause bit. 4.104.114.84.95
(edit) @a71c31b   03/22/06 13:53:32 Joel Sherrill 2006-03-22 Joel Sherrill <joel@…> * include/.cvsignore: … 4.104.114.84.95
(edit) @c1a96804   03/17/06 10:34:12 Ralf Corsepius Misc. cosmetics. 4.104.114.84.95
(edit) @674be421   03/17/06 10:11:37 Ralf Corsepius Remove eof include file 4.104.114.84.95
(edit) @b22b31fd   03/16/06 17:57:42 Ralf Corsepius Regenerate. 4.104.114.84.95
(edit) @da7d7c2   03/16/06 17:57:27 Ralf Corsepius AC_CONFIG_SRCDIR(csb350). 4.104.114.84.95
(edit) @43b09557   03/16/06 17:57:12 Ralf Corsepius 2006-03-16 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @b7b487cb   03/16/06 17:43:00 Ralf Corsepius New. 4.104.114.84.95
(edit) @79b1dea5   03/16/06 17:42:47 Ralf Corsepius Add preinstall.am 4.104.114.84.95
(edit) @4ba5ac6   03/16/06 17:41:28 Ralf Corsepius New (Submission by Bruce Robinson <brucer@…>). 4.104.114.84.95
(edit) @c6254224   03/16/06 17:36:21 Ralf Corsepius Add preinstall.am 4.104.114.84.95
(edit) @991f9022   03/16/06 17:35:34 Ralf Corsepius New. 4.104.114.84.95
(edit) @15ebdf1f   03/16/06 17:34:05 Ralf Corsepius New (Submission by Bruce Robinson <brucer@…>) 4.104.114.84.95
