@4004d97
05/21/15 12:52:21 |
Joel Sherrill |
mcf5225x/clock/clock.c: Remove unused variable warning
4.115
@2a605f6
05/21/15 12:52:02 |
Joel Sherrill |
mcf52235/clock/clock.c: Remove unused variable warning
4.115
@5a9c3c1
05/21/15 12:51:36 |
Joel Sherrill |
pc386/clock/ckinit.c: Remove prototyped but not defined warning
4.115
@52258f1
05/21/15 12:51:01 |
Joel Sherrill |
arm/shared/lpc/clock/lpc-clock-config.c: Remove unused variable warning
4.115
@1c0663b4
05/20/15 19:12:52 |
Joel Sherrill |
mcf52235-testsuite.tcfg: Add syscall01
4.115
@0afac6a
05/20/15 17:11:41 |
Joel Sherrill |
Multiple bsp_specs: Change *(old_endfile) to %(old_endfile)
Fix typo. …
4.115
@22e576d
05/20/15 17:08:15 |
Joel Sherrill |
simsh2e-testsuite.tcfg: Add fileio
4.115
@bb997dd9
05/20/15 17:08:00 |
Joel Sherrill |
simsh1-testsuite.tcfg: Add fileio
4.115
@9588946
05/21/15 15:27:34 |
Sebastian Huber |
bsp/tms570: Typo
4.115
@75acd9e
04/01/15 13:33:25 |
alexander.krutwig |
bsps: Convert clock drivers to use a timecounter
Update #2271.
4.115
@a0001d6
05/14/15 09:17:00 |
Sebastian Huber |
Remove obsolete rtems_clock_major/minor
These global variables are …
4.115
@438e78e
05/04/15 21:32:48 |
Joel Sherrill |
mrm332-testsuite.tcfg: Add fileio
4.115
@3dead51
04/26/15 16:28:08 |
Hesham Almatary |
Fix or1k C++ build failure
Closes #2329
4.115
@5a8cd17
04/19/15 01:28:22 |
Joel Sherrill |
simsh*.tcfg: Add iostream
4.115
@d9ef7ebe
04/19/15 01:27:56 |
Joel Sherrill |
gensh2-testsuite.tcfg: Add iostream
4.115
@07d9954b
04/19/15 01:27:40 |
Joel Sherrill |
gensh1-testsuite.tcfg: Add iostream
4.115
@ba885bd
04/19/15 01:27:09 |
Joel Sherrill |
mbx8xx/include/bsp.h: Add include of <rtems/irq.h>
4.115
@9a9614e5
04/19/15 01:26:41 |
Joel Sherrill |
ods68302-testsuite.tcfg: Add iosteam
4.115
@f620ac7
04/19/15 01:26:20 |
Joel Sherrill |
mrm332-testsuite.tcfg: Add iostream and sptls02
4.115
@0c87234f
04/19/15 01:25:44 |
Joel Sherrill |
mcf5225x-testsuite.tcfg: Add iostream
4.115
@e38fdc2
04/19/15 01:25:22 |
Joel Sherrill |
lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add sptls02
4.115
@2e9baac
04/18/15 15:23:51 |
Joel Sherrill |
lm3s3749-testsuite.tcfg: Add cdtest
4.115
@3d597c0
04/18/15 16:25:51 |
Hesham Almatary |
Rename or1ksim BSP to generic_or1k
or1ksim BSP was initially named …
4.115
@c77e3cb
04/14/15 07:31:05 |
Daniel Hellstrom |
LEON3: gptimer drvmgr init simplified wrt boot
4.115
@9fe249d
04/14/15 07:28:54 |
Daniel Hellstrom |
LEON3: move timer variable to where initialized
4.115
@efd43ad
04/14/15 07:24:33 |
Daniel Hellstrom |
LEON3: simplify amba initialization
4.115
@628e739
04/14/15 06:18:27 |
Daniel Hellstrom |
LEON3: clock irq always same as timer instance
The leon.h already …
4.115
@291c5391
04/13/15 11:12:33 |
Daniel Hellstrom |
DRVMGR: remove struct driver registration func
4.115
@bef5e23e
04/13/15 09:31:53 |
Daniel Hellstrom |
DRVMGR: renamed RES_EMPTY to DRVMGR_RES_EMPTY
4.115
@4d3e70f4
04/13/15 09:26:52 |
Daniel Hellstrom |
DRVMGR: KEY_TYPE now a enum drvmgr_kt
4.115
@14d55deb
04/13/15 09:12:04 |
Daniel Hellstrom |
DRVMGR: renamed info_dev to get_info_dev
4.115
@246fe22
04/13/15 09:07:54 |
Daniel Hellstrom |
DRVMGR: change name of freq_get to get_freq
4.115
@4a7d1026
04/13/15 08:25:52 |
Daniel Hellstrom |
sparc bsps: updated license to rtems.org
4.115
@159ee990
04/07/15 14:05:04 |
Daniel Hellstrom |
leon3,ngmp: cpucounter initialization use proper names
To be merged …
4.115
@5564b5a
04/07/15 14:04:13 |
Daniel Hellstrom |
leon3: timer config updated to use proper naming
To be merged with …
4.115
@9b292ea
04/07/15 12:31:22 |
Daniel Hellstrom |
LEON: converted LEON4-N2X to BSD header
4.115
@8b29637c
04/07/15 12:31:07 |
Daniel Hellstrom |
LEON: converted PCI peripherals to BSD header
4.115
@d5ca821
04/07/15 12:28:29 |
Daniel Hellstrom |
LEON: converted AT697,GRPCi,GRPCI2,PCIF to BSD header
4.115
@5823bae8
02/27/15 13:03:15 |
Daniel Hellstrom |
LEON: move driver headers to bsp/ directory
4.115
@445e253
02/06/15 09:07:19 |
Daniel Hellstrom |
MCTRL: fix build warnings in MCTRL driver
4.115
@dbfa7c98
02/11/15 11:56:03 |
Daniel Hellstrom |
AMBAPP GRLIB: fix build warnings
4.115
@62fb1778
02/11/15 11:55:32 |
Daniel Hellstrom |
LEON2: fix build warnings
4.115
@43613a90
02/11/15 11:54:57 |
Daniel Hellstrom |
AMBAPP_BUS: fix build warnings
4.115
@56662f5c
02/11/15 11:52:14 |
Daniel Hellstrom |
LEON CONS: fix build warnings
4.115
@103bbde
02/11/15 11:50:35 |
Daniel Hellstrom |
GR-TMTC-1553: fix build warnings
4.115
@dd8abfc
02/11/15 11:40:17 |
Daniel Hellstrom |
GR-RASTA-TMTC: fix build warnings
4.115
@90fd587
02/11/15 11:39:40 |
Daniel Hellstrom |
GR-RASTA-SPW-ROUTER: fix build warnings
4.115
@960aebf
02/11/15 11:39:04 |
Daniel Hellstrom |
GR-RASTA-IO: fix build warnings
4.115
@03037b4
02/11/15 11:38:22 |
Daniel Hellstrom |
GR-RASTA-ADCDAC: fix build warnings
4.115
@ef7a009
02/11/15 11:37:28 |
Daniel Hellstrom |
GR-LEON4-N2X: fix build warnings
4.115
@05a45c79
02/11/15 11:36:50 |
Daniel Hellstrom |
GR_701: fix build warnings
4.115
@cb64b862
02/11/15 11:35:53 |
Daniel Hellstrom |
GRGPIO: fix buld warnings
4.115
@c39de3c4
02/11/15 11:35:36 |
Daniel Hellstrom |
GPIOLIB: fix build warnings
4.115
@7bc74ed
02/11/15 11:34:48 |
Daniel Hellstrom |
GRADCDAC: fix build warnings
4.115
@0355ad4
02/11/15 11:34:02 |
Daniel Hellstrom |
GENIRQ: fix build warnings
4.115
@9d05c6df
02/11/15 11:32:22 |
Daniel Hellstrom |
GRPWM: fix build warnings
4.115
@126b25d
02/11/15 11:31:26 |
Daniel Hellstrom |
SPWCUC: fix build warnings
4.115
@8c6c53d
02/11/15 11:27:05 |
Daniel Hellstrom |
SPICTRL: fix build warnings
4.115
@9b90342
02/11/15 11:23:45 |
Daniel Hellstrom |
GRSPW router: fix build warnings
4.115
@b6292a0b
02/11/15 11:23:04 |
Daniel Hellstrom |
GRSPW_PKT: fix build warnings
4.115
@fd7eaa2
02/11/15 08:40:15 |
Daniel Hellstrom |
TLIB: fix build warnings
4.115
@6048035
02/11/15 08:39:48 |
Daniel Hellstrom |
TLIB Clock: fix build warnings
4.115
@a93b3aa4
02/11/15 08:37:50 |
Daniel Hellstrom |
GRASCS: fix build warnings
4.115
@3823f5c
02/11/15 08:20:40 |
Daniel Hellstrom |
GRCTM: fix build warnings
4.115
@60d392b7
02/11/15 08:19:53 |
Daniel Hellstrom |
GRTM: fix build warnings
4.115
@e21a5b0
02/11/15 08:18:53 |
Daniel Hellstrom |
GRTC: fix build warnings
4.115
@6657a3d
02/10/15 15:33:16 |
Daniel Hellstrom |
LEON: GRPCI2 driver warning fixes
4.115
@48191662
02/10/15 15:29:39 |
Daniel Hellstrom |
LEON: I2CMST driver warnings fixes
4.115
@c9f75435
02/10/15 15:28:55 |
Daniel Hellstrom |
LEON: OCCAN driver warnings fixes
4.115
@be815e78
02/10/15 15:28:19 |
Daniel Hellstrom |
LEON: B1553BRM driver warnings fixes
4.115
@44e514f
02/10/15 15:28:03 |
Daniel Hellstrom |
LEON: B1553RT driver warnings fixes
4.115
@3f38335b
02/10/15 15:05:38 |
Daniel Hellstrom |
LEON: added get_resarray_count() helper routine
4.115
@b787bead
02/10/15 08:23:48 |
Daniel Hellstrom |
GR1553B: fixed build warnings
4.115
@05ce8bd5
02/10/15 07:32:42 |
Daniel Hellstrom |
AT697PCI: fix build warnings
4.115
@e3c9937
02/18/15 14:34:39 |
Daniel Hellstrom |
GPTIMER: move ISR install from init1
To avoid install ISRs during …
4.115
@f37a3c2
02/06/15 10:10:17 |
Daniel Hellstrom |
GPTIMER: fix build warnings
4.115
@7a03ac29
02/06/15 08:59:13 |
Daniel Hellstrom |
APBUART_CONS: fix build warning
4.115
@d77b16d
02/06/15 08:27:08 |
Daniel Hellstrom |
4.115
@28950f0b
02/05/15 13:35:33 |
Daniel Hellstrom |
PCIF: fixed build warnings
4.115
@f407c51
02/05/15 13:31:42 |
Daniel Hellstrom |
GRPCI: fixed build warnings
4.115
@0d9bc25
02/05/15 08:52:00 |
Daniel Hellstrom |
GRSPW: fix build warnings
4.115
@b55aa49
02/05/15 07:07:15 |
Daniel Hellstrom |
LEON3: watchdog use common timer defines
4.115
@5ba49066
02/05/15 07:06:26 |
Daniel Hellstrom |
LEON3: export debug uart to console uart driver
4.115
@aedc9849
02/05/15 07:05:56 |
Daniel Hellstrom |
GRETH: fix build warnings with GCC-4.9
4.115
@bf6fe958
02/04/15 15:22:59 |
Daniel Hellstrom |
GPTIMER: avoid build warnings
4.115
@0fcd4b33
02/04/15 15:22:41 |
Daniel Hellstrom |
AHBSTAT: fix build warnings
4.115
@bb689e6
11/04/14 07:57:55 |
Daniel Hellstrom |
GRTM: fixed descriptor TS bit declaration
4.115
@5f4028b
11/04/14 07:52:39 |
Daniel Hellstrom |
GRSPW_PKT: grspw_status renamed in header
4.115
@e8f6005f
08/08/14 08:01:41 |
Daniel Hellstrom |
GR-RASTA-TMTC,rev1: add GRGPIO[0] register init
4.115
@fed905c8
08/08/14 07:59:36 |
Daniel Hellstrom |
B1553BRM: change the init of the RT legalization registers
4.115
@d2a94ab
05/02/14 12:28:44 |
Daniel Hellstrom |
GRSPW: added clock cycles after GRSPW reset
added clock cycles after …
4.115
@56fc7809
07/03/13 08:16:30 |
andreas |
GRSPW_PKT: Add support for Interrupt-codes
Update: Daniel Hellstrom …
4.115
@c119c0e
07/03/13 08:06:37 |
andreas |
GRSPW: Fix incorrect register defines - presently functionally …
4.115
@f1b1668
12/20/13 09:17:22 |
Daniel Hellstrom |
AMBAPP: updated PnP IDs database with SPWTDP
4.115
@fa12bb43
11/29/13 13:58:58 |
Daniel Hellstrom |
GRTIMER: added to GPTIMER driver
GRTIMER is compatible with GPTIMER, …
4.115
@9b8e04e2
10/22/13 10:03:41 |
Daniel Hellstrom |
GRETH: avoid hw generated UDP/TCP cksum generation
Hardware generated …
4.115
@80b9c8ac
12/20/13 13:03:10 |
Daniel Hellstrom |
GR-RASTA-IO: updated for new version
From this driver's point of view …
4.115
@fc76056e
12/20/13 13:01:12 |
Daniel Hellstrom |
GR-RASTA-TMTC: updated for new version
From this driver's point of …
4.115
@9d88008
12/18/13 15:42:16 |
Daniel Hellstrom |
AT697PCI: fix PCI cfg writes
4.115
@ddc4002
11/22/13 09:22:56 |
Daniel Hellstrom |
AT697 PCI: abort whhen a peripheral PCI system detected
4.115
