# # ChangeLog for c/src/lib/libbsp in rtems # # Generated by Trac 1.2.1.dev0 # 05/20/24 13:06:05 Mon, 07 Jan 2013 13:56:53 GMT Sebastian Huber [f1413c4] * c/src/lib/libbsp/arm/lpc24xx/configure.ac (modified) bsp/lpc24xx: System reset after fatal conditions Mon, 07 Jan 2013 13:56:18 GMT Sebastian Huber [2460cc7] * c/src/lib/libbsp/arm/lpc24xx/startup/bspreset.c (modified) bsp/lpc24xx: Request system reset for LPC17XX Mon, 07 Jan 2013 13:55:54 GMT Sebastian Huber [4cc629cd] * c/src/lib/libbsp/arm/lpc24xx/include/lpc17xx.h (modified) bsp/lpc24xx: Add WWDT module defines Mon, 07 Jan 2013 09:19:23 GMT Sebastian Huber [04f399d] * c/src/lib/libbsp/arm/shared/start/start.S (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/arm/armv7m-exception-default.c (added) * cpukit/score/cpu/arm/rtems/score/armv7m.h (modified) arm: Add and use _ARMV7M_Exception_default() Fri, 04 Jan 2013 15:25:19 GMT Sebastian Huber [0f7abd99] * c/src/lib/libbsp/arm/lpc24xx/irq/irq-dispatch.c (modified) * c/src/lib/libbsp/arm/lpc32xx/irq/irq.c (modified) * cpukit/score/cpu/arm/rtems/score/armv4.h (modified) arm: Rename inline functions Rename arm_status_irq_enable() to ... Fri, 04 Jan 2013 15:22:18 GMT Sebastian Huber [8df0e91] * c/src/lib/libbsp/arm/lpc24xx/irq/irq-dispatch.c (modified) * cpukit/score/cpu/arm/rtems/score/armv4.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Move inline functions Fri, 04 Jan 2013 14:47:34 GMT Sebastian Huber [13cf952] * c/src/lib/libbsp/arm/shared/start/start.S (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/arm/armv4-exception-default.S (added) * cpukit/score/cpu/arm/rtems/score/armv4.h (modified) arm: Add and use default exception handler Add and use ... Fri, 04 Jan 2013 12:06:51 GMT Sebastian Huber [370c2c80] * c/src/lib/libbsp/arm/edb7312/irq/irq.c (modified) * c/src/lib/libbsp/arm/gba/start/start.S (modified) * c/src/lib/libbsp/arm/lpc24xx/irq/irq.c (modified) * c/src/lib/libbsp/arm/lpc32xx/irq/irq.c (modified) * c/src/lib/libcpu/arm/at91rm9200/irq/irq.c (modified) * c/src/lib/libcpu/arm/lpc22xx/irq/irq.c (modified) * c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c (modified) * c/src/lib/libcpu/arm/pxa255/irq/irq.c (modified) * c/src/lib/libcpu/arm/s3c24xx/irq/irq.c (modified) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/rtems/score/armv4.h (modified) arm: Rename arm_exc_interrupt() Rename arm_exc_interrupt() to ... Fri, 04 Jan 2013 12:05:28 GMT Sebastian Huber [9b2e7143] * c/src/lib/libbsp/arm/edb7312/irq/irq.c (modified) * c/src/lib/libbsp/arm/lpc24xx/irq/irq.c (modified) * c/src/lib/libbsp/arm/lpc32xx/irq/irq.c (modified) * c/src/lib/libcpu/arm/at91rm9200/irq/irq.c (modified) * c/src/lib/libcpu/arm/lpc22xx/irq/irq.c (modified) * c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c (modified) * c/src/lib/libcpu/arm/pxa255/irq/irq.c (modified) * c/src/lib/libcpu/arm/s3c24xx/irq/irq.c (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/arm/preinstall.am (modified) * cpukit/score/cpu/arm/rtems/score/armv4.h (added) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Move prototypes to new file Move bsp_interrupt_dispatch() and ... Thu, 03 Jan 2013 14:41:16 GMT Sebastian Huber [9224905b] * c/src/lib/libbsp/shared/src/irq-server.c (modified) bsps: Fix rtems_interrupt_server_handler_remove() Wed, 19 Dec 2012 12:41:27 GMT Sebastian Huber [566c05c] * c/src/lib/libbsp/powerpc/gen83xx/include/hwreg_vals.h (modified) bsp/gen83xx: Fix CSB clock calculation for MPC8309 Tue, 18 Dec 2012 08:24:56 GMT Sebastian Huber [4592658] * c/src/lib/libbsp/arm/shared/lpc/network/lpc-ethernet.c (modified) bsps/arm: Move promiscuous mode setting Mon, 17 Dec 2012 14:41:53 GMT Sebastian Huber [3f58ac7] * c/src/lib/libbsp/arm/shared/lpc/network/lpc-ethernet.c (modified) bsps/arm: Add PHY up/down All PHYs will be set to power up/down ... Mon, 17 Dec 2012 10:12:20 GMT Sebastian Huber [50233d37] * c/src/lib/libbsp/arm/shared/lpc/network/lpc-ethernet.c (modified) bsps/arm: Add PHY timeout detection Fri, 14 Dec 2012 12:08:10 GMT Sebastian Huber [2cd48da] * c/src/lib/libbsp/arm/lpc24xx/include/lpc-ethernet-config.h (modified) * c/src/lib/libbsp/arm/lpc32xx/include/lpc-ethernet-config.h (modified) * c/src/lib/libbsp/arm/shared/lpc/network/lpc-ethernet.c (modified) bsps/arm: Add interface down support Fri, 14 Dec 2012 11:17:15 GMT Sebastian Huber [e99893f9] * c/src/lib/libbsp/arm/shared/lpc/network/lpc-ethernet.c (modified) bsps/arm: Prepare for interface down support Fri, 14 Dec 2012 11:07:28 GMT Sebastian Huber [573822b] * c/src/lib/libbsp/arm/shared/lpc/network/lpc-ethernet.c (modified) bsps/arm: Use assert() instead of status macros Fri, 14 Dec 2012 09:28:18 GMT Sebastian Huber [5970dcc9] * c/src/lib/libbsp/arm/shared/lpc/network/lpc-ethernet.c (modified) bsps/arm: Remove superfluous attributes Fri, 14 Dec 2012 08:40:44 GMT Sebastian Huber [e5a7f846] * c/src/lib/libbsp/arm/shared/lpc/network/lpc-ethernet.c (modified) bsps/arm: Avoid mbuf migration in LPC ethernet The receive task ... Tue, 18 Dec 2012 10:18:40 GMT Sebastian Huber [c9562c5] * c/src/lib/libbsp/arm/lpc32xx/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/bspstarthooks.c (modified) bsp/lpc32xx: Add UART_CLKMODE settings Tue, 18 Dec 2012 09:45:13 GMT Sebastian Huber [380628ea] * c/src/lib/libbsp/arm/lpc32xx/console/console-config.c (modified) bsp/lpc32xx: Configure U4_TX pin for UART 4 Tue, 18 Dec 2012 09:44:48 GMT Sebastian Huber [d1cf326] * c/src/lib/libbsp/arm/lpc32xx/console/console-config.c (modified) bsp/lpc32xx: Fix function prototype Mon, 17 Dec 2012 15:40:23 GMT Sebastian Huber [f25d31f] * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/idle-thread.c (added) bsp/lpc32xx: Add idle thread body Wed, 12 Dec 2012 08:26:51 GMT Sebastian Huber [7371995] * c/src/lib/libbsp/arm/lpc32xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc32xx/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/bspstarthooks.c (modified) bsp/lpc32xx: Fix console baud configuration Fri, 07 Dec 2012 08:50:27 GMT Sebastian Huber [80232ee7] * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5566evb_spe.cfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc55xx_spe.inc (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_ecu508_app.cfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_ecu508_boot.cfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_rsm6_koma_app.cfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_rsm6_koma_boot.cfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_rsm6_moma_app.cfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_rsm6_moma_boot.cfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674fevb_spe.cfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/phycore_mpc5554.cfg (modified) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq.inc (modified) bsps/powerpc: Use explicit compiler options Thu, 06 Dec 2012 16:47:30 GMT Sebastian Huber [48bff53b] * c/src/lib/libbsp/lm32/milkymist/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mrm332/misc/interr.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/beatnik/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/virtex4/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/virtex5/startup/bspclean.c (modified) * c/src/lib/libbsp/shared/bootcard.c (modified) * c/src/lib/libbsp/shared/bspclean.c (modified) * c/src/lib/libbsp/shared/include/bootcard.h (modified) * cpukit/sapi/include/rtems/init.h (modified) * cpukit/sapi/src/exinit.c (modified) * doc/bsp_howto/init.t (modified) * doc/bsp_howto/support.t (modified) * doc/user/init.t (modified) * testsuites/sptests/spinternalerror01/init.c (modified) score: rtems_initialize_start_multitasking() Do not return from ... Thu, 06 Dec 2012 16:44:55 GMT Sebastian Huber [1bb8782] * c/src/lib/libbsp/arm/gdbarmsim/start/start.S (modified) bsp/gdbarmsim: Do not call bsp_cleanup() Thu, 06 Dec 2012 16:42:41 GMT Sebastian Huber [facf8362] * c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c (modified) * c/src/lib/libbsp/shared/include/bootcard.h (modified) bsps: Add BSP_GENERIC_FATAL_SPURIOUS_INTERRUPT Use rtems_fatal() ... Thu, 06 Dec 2012 16:40:42 GMT Sebastian Huber [dabdbd91] * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) bsp/mrm332: Use shared bspclean.c Thu, 06 Dec 2012 16:40:08 GMT Sebastian Huber [40fe4b86] * c/src/lib/libbsp/m68k/mcf52235/startup/init52235.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/startup/init5225x.c (modified) * c/src/lib/libbsp/m68k/mcf5329/startup/init5329.c (modified) * c/src/lib/libbsp/m68k/mrm332/startup/start_c.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/cpuboot.c (modified) * c/src/lib/libbsp/powerpc/qemuppc/startup/cmain.c (modified) bsps: Use Fri, 23 Nov 2012 16:25:54 GMT Sebastian Huber [2858aeb9] * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_rsm6_koma_app.cfg (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_rsm6_koma_boot.cfg (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_rsm6_moma_app.cfg (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_rsm6_moma_boot.cfg (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674f_rsm6 (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674f_rsm6_koma_app (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674f_rsm6_koma_boot (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674f_rsm6_moma_app (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674f_rsm6_moma_boot (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-clock.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-ebi-cs-cal.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-ebi.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-mmu-early.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-mmu.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-siu-pcr.c (modified) bsp/mpc55xx: New BSP variants for RSM6 Mon, 26 Nov 2012 16:02:44 GMT Sebastian Huber [e1e248f] * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/mpc55xx-config.h (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-ebi.c (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-early.c (modified) bsp/mpc55xx: Add optional EBI configuration Mon, 26 Nov 2012 15:58:58 GMT Sebastian Huber [f4309b0] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-ebi-cs-cal.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-ebi-cs.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-mmu-early.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-mmu.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-siu-pcr.c (modified) bsp/mpc55xx: Use RTEMS_ARRAY_SIZE() Fri, 23 Nov 2012 14:12:41 GMT Sebastian Huber [29919ec0] * c/src/lib/libbsp/powerpc/mpc55xxevb/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674f_ecu508 (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674f_ecu508_app (modified) bsp/mpc55xx: Add .sysram section Fri, 23 Nov 2012 13:47:47 GMT Sebastian Huber [65ab304b] * c/src/lib/libbsp/powerpc/mpc55xxevb/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674f_ecu508 (modified) bsp/mpc55xx: Add .dsram section Fri, 23 Nov 2012 13:43:04 GMT Sebastian Huber [bb3090c5] * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/mpc55xxevb.h (deleted) * c/src/lib/libbsp/powerpc/mpc55xxevb/preinstall.am (modified) bsp/mpc55xx: Delete Fri, 23 Nov 2012 13:16:11 GMT Sebastian Huber [113768f] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.gwlcfm (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5566evb (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5643l_evb (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674f_ecu508 (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674fevb (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.phycore_mpc5554 (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/linkcmds.qoriq_core_0 (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/linkcmds.qoriq_core_1 (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/linkcmds.qoriq_p1020rdb (modified) * c/src/lib/libbsp/powerpc/shared/include/linker-symbols.h (modified) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/powerpc/t32mppc/startup/linkcmds.t32mppc (modified) bsps/powerpc: Add .nvram section Fri, 23 Nov 2012 09:11:55 GMT Sebastian Huber [95aebbe] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674f_ecu508 (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674f_ecu508_app (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674f_ecu508_boot (modified) bsp/mpc55xx: Add and use STARTROM Fri, 23 Nov 2012 09:11:22 GMT Sebastian Huber [840dd00] * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674f_ecu508 (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674f_ecu508_app (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674f_ecu508_boot (modified) bsp/mpc55xx: Add and use linkcmds.mpc5674f_ecu508 Wed, 21 Nov 2012 08:46:58 GMT Sebastian Huber [c6d35ad4] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start.S (modified) bsp/mpc55xx: Errata e4396 for e200z7 Mon, 19 Nov 2012 08:12:07 GMT Sebastian Huber [2e80662] * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) bsp/mpc55xx: Set PPC_EXC_CONFIG_BOOKE_ONLY Mon, 19 Nov 2012 08:02:12 GMT Sebastian Huber [3ce66aa] * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/exc-vector-base.S (modified) * c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c (modified) bsp/mpc55xx: Set PPC_EXC_CONFIG_USE_FIXED_HANDLER Fri, 16 Nov 2012 09:06:07 GMT Sebastian Huber [1c479be4] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start.S (modified) bsp/mpc55xx: Documentation Mon, 03 Dec 2012 12:08:42 GMT Sebastian Huber [fee41c9] * c/src/lib/libbsp/powerpc/mpc55xxevb/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-clock.c (modified) bsp/mpc55xx: Add and use mpc55xx_fatal_code Thu, 15 Nov 2012 16:33:15 GMT Christian Mauderer [6eb0ce2] * c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c (modified) bsp/mpc55xx: Fix SMSC9218I MAC address setting Thu, 15 Nov 2012 16:01:29 GMT Sebastian Huber [da2fa4eb] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) bsp/mpc55xx: Remove BSP_panic() Thu, 15 Nov 2012 15:57:02 GMT Sebastian Huber [67338ed] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/idle-thread.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/mpc55xx.h (modified) bsp/mpc55xx: Add mpc55xx_wait_for_interrupt() Use ... Tue, 13 Nov 2012 13:39:19 GMT Sebastian Huber [2d561b9] * c/src/lib/libbsp/powerpc/mpc55xxevb/include/mpc55xx-config.h (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-clock.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-ebi-cs-cal.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-ebi-cs.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-mmu-early.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-mmu.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-siu-pcr.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-early.c (modified) bsp/mpc55xx: Use BSP_START_DATA_SECTION Tue, 13 Nov 2012 10:50:38 GMT Sebastian Huber [6c454104] * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-ebi-cs-cal.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-mmu-early.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-mmu.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-siu-pcr.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-early.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start.S (modified) bsp/mpc55xx: Fix no-cache section load Wed, 21 Nov 2012 08:54:32 GMT Sebastian Huber [fe1a4e4b] * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) bsp/qoriq: Set PPC_EXC_CONFIG_BOOKE_ONLY Wed, 21 Nov 2012 08:54:12 GMT Sebastian Huber [f6999e6] * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) bsp/qoriq: Set PPC_EXC_CONFIG_USE_FIXED_HANDLER Tue, 13 Nov 2012 14:01:24 GMT Sebastian Huber [c383372] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/exc-vector-base.S (modified) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds.base (modified) bsps/powerpc: Add and use bsp_text input section Tue, 13 Nov 2012 14:00:53 GMT Sebastian Huber [d33f743] * c/src/lib/libbsp/powerpc/shared/startup/linkcmds.base (modified) bsps/powerpc: Move .fast_text after .text section Mon, 19 Nov 2012 07:37:04 GMT Sebastian Huber [f665f13] * c/src/lib/libbsp/powerpc/shared/src/ppc-exc-handler-table.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_asm_macros.h (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_hdl.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_naked.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) bsps/powerpc: Add PPC_EXC_CONFIG_BOOKE_ONLY In combination with the ... Fri, 23 Nov 2012 08:32:52 GMT Sebastian Huber [4bd4c9e] * c/src/lib/libbsp/powerpc/shared/src/ppc-exc-handler-table.c (added) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_asm_macros.h (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_global_handler.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_hdl.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_prologue.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) bsps/powerpc: Add PPC_EXC_CONFIG_USE_FIXED_HANDLER In case a BSP ... Fri, 30 Nov 2012 12:21:37 GMT Sebastian Huber [3bf002a] * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) bsp/gen83xx: Workaround for USB stack Fri, 30 Nov 2012 12:14:34 GMT Sebastian Huber [7ac89a6f] * c/src/lib/libbsp/powerpc/gen83xx/startup/linkcmds.base (modified) bsp/gen83xx: Add sections for USB stack Mon, 03 Dec 2012 09:02:29 GMT Sebastian Huber [fd5c1eb] * c/src/lib/libbsp/arm/csb337/startup/linkcmds.csb637 (modified) bsp/csb637: Fix memory map Mon, 03 Dec 2012 08:57:59 GMT Sebastian Huber [e168410] * c/src/lib/libbsp/arm/csb337/startup/linkcmds.csb337 (modified) bsp/csb337: Fix memory map Fri, 30 Nov 2012 23:58:32 GMT Ric Claus [655bd39] * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/README (added) * c/src/lib/libbsp/powerpc/virtex5/console/dummy_console.c (deleted) * c/src/lib/libbsp/powerpc/virtex5/include/irq.h (modified) * c/src/lib/libbsp/powerpc/virtex5/include/mmu.h (added) * c/src/lib/libbsp/powerpc/virtex5/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/virtex5/mmu/mmu.c (added) * c/src/lib/libbsp/powerpc/virtex5/preinstall.am (modified) * c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/virtex5/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/virtex5/startup/start.S (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) Virtex5 BSP: Various updates and improvements. This BSP now uses ... Fri, 30 Nov 2012 23:56:04 GMT Ric Claus [5b822ab] * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/README (added) * c/src/lib/libbsp/powerpc/virtex4/clock/clock.c (deleted) * c/src/lib/libbsp/powerpc/virtex4/include/mmu.h (added) * c/src/lib/libbsp/powerpc/virtex4/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/virtex4/mmu/mmu.c (added) * c/src/lib/libbsp/powerpc/virtex4/preinstall.am (modified) * c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/virtex4/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/virtex4/startup/start.S (modified) Virtex4 BSP: Various updates and improvements. Switched to using ... Sun, 25 Nov 2012 16:48:11 GMT Sebastian Huber [815994f] * c/src/aclocal/bsp-bspcleanup-options.m4 (modified) * c/src/lib/libbsp/mips/shared/irq/vectorexceptions.c (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/shared/bspclean.c (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_global_handler.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) * cpukit/sapi/include/rtems/fatal.h (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/arm/arm-exception-frame-print.c (added) * cpukit/score/cpu/arm/armv7m-exception-frame-print.c (added) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/avr/Makefile.am (modified) * cpukit/score/cpu/avr/avr-exception-frame-print.c (added) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/Makefile.am (modified) * cpukit/score/cpu/bfin/bfin-exception-frame-print.c (added) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/h8300/Makefile.am (modified) * cpukit/score/cpu/h8300/h8300-exception-frame-print.c (added) * cpukit/score/cpu/h8300/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/Makefile.am (modified) * cpukit/score/cpu/lm32/lm32-exception-frame-print.c (added) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/Makefile.am (modified) * cpukit/score/cpu/m32c/m32c-exception-frame-print.c (added) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32r/Makefile.am (modified) * cpukit/score/cpu/m32r/m32r-exception-frame-print.c (added) * cpukit/score/cpu/m32r/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/m68k/m68k-exception-frame-print.c (added) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/Makefile.am (modified) * cpukit/score/cpu/nios2/nios2-exception-frame-print.c (added) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/sh-exception-frame-print.c (added) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/Makefile.am (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/sparc64-exception-frame-print.c (added) * cpukit/score/cpu/v850/Makefile.am (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/v850-exception-frame-print.c (added) * cpukit/score/include/rtems/score/interr.h (modified) * doc/user/fatal.t (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal26/Makefile.am (added) * testsuites/sptests/spfatal26/init.c (added) * testsuites/sptests/spfatal26/spfatal26.doc (added) * testsuites/sptests/spfatal26/spfatal26.scn (added) score: Add CPU_Exception_frame Add CPU port type ... Mon, 26 Nov 2012 16:52:01 GMT Sebastian Huber [f0e3cc0] * c/src/lib/libbsp/powerpc/mvme5500/vectors/exceptionhandler.c (modified) * c/src/lib/libcpu/powerpc/mpc5xx/vectors/vectors.h (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) bsps/powerpc: Delete unused EXC_DAR field The Data Access Register ... Fri, 23 Nov 2012 21:40:09 GMT Sebastian Huber [39aa75e7] * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/include/bsp.h (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) bsps: Use RTEMS_BSP_CLEANUP_OPTIONS Thu, 22 Nov 2012 13:41:59 GMT Sebastian Huber [f5d0285] * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/misc/interr.c (modified) m68k/mrm332: Delete _Internal_error_Occurred() Use custom ... Thu, 22 Nov 2012 13:34:41 GMT Sebastian Huber [86d80f0] * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/bspfatal.c (deleted) * c/src/lib/libbsp/m68k/mvme167/include/fatal.h (deleted) * c/src/lib/libbsp/m68k/mvme167/preinstall.am (modified) m68k/mvme167: Delete bsp_fatal_error_occurred() Tue, 20 Nov 2012 07:36:25 GMT Sebastian Huber [7ca64d69] * c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c (modified) bsp/mpc55xx: Update due to API changes Wed, 14 Nov 2012 08:57:55 GMT Sebastian Huber [b1e8a58] * c/src/lib/libbsp/powerpc/ep1a/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qemuppc/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c (modified) * c/src/lib/libbsp/shared/include/bootcard.h (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) bsps/powerpc: Exception initialization error is fatal Wed, 14 Nov 2012 12:59:27 GMT Sebastian Huber [dd8df59] * c/src/lib/libbsp/arm/csb336/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/csb337/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/edb7312/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/gba/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/gp32/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/gumstix/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/stm32f4/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/shared/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qemuppc/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c (modified) * c/src/lib/libbsp/shared/include/bootcard.h (modified) * c/src/lib/libbsp/shared/include/irq-generic.h (modified) * c/src/lib/libbsp/shared/src/irq-generic.c (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc/shared/irq/irq-shared.c (modified) bsps: Interrupt initialization error is fatal Wed, 14 Nov 2012 08:59:10 GMT Sebastian Huber [a052181] * c/src/lib/libbsp/arm/csb336/include/bsp.h (modified) * c/src/lib/libbsp/arm/csb337/include/bsp.h (modified) * c/src/lib/libbsp/arm/edb7312/include/bsp.h (modified) * c/src/lib/libbsp/arm/gba/include/bsp.h (modified) * c/src/lib/libbsp/arm/gdbarmsim/include/bsp.h (modified) * c/src/lib/libbsp/arm/gp32/include/bsp.h (modified) * c/src/lib/libbsp/arm/gumstix/include/bsp.h (modified) * c/src/lib/libbsp/arm/lm3s69xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc32xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/nds/include/bsp.h (modified) * c/src/lib/libbsp/arm/rtl22xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/smdk2410/include/bsp.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/bsp.h (modified) * c/src/lib/libbsp/avr/avrtest/include/bsp.h (modified) * c/src/lib/libbsp/bfin/TLL6527M/include/bsp.h (modified) * c/src/lib/libbsp/bfin/bf537Stamp/include/bsp.h (modified) * c/src/lib/libbsp/bfin/eZKit533/include/bsp.h (modified) * c/src/lib/libbsp/h8300/h8sim/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/lm32/lm32_evr/include/bsp.h (modified) * c/src/lib/libbsp/lm32/milkymist/include/bsp.h (modified) * c/src/lib/libbsp/lm32/milkymist/startup/bspclean.c (modified) * c/src/lib/libbsp/m32c/m32cbsp/include/bsp.h (modified) * c/src/lib/libbsp/m32r/m32rsim/include/bsp.h (modified) * c/src/lib/libbsp/m68k/av5282/include/bsp.h (modified) * c/src/lib/libbsp/m68k/csb360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68340/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/genmcf548x/include/bsp.h (modified) * c/src/lib/libbsp/m68k/idp/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5206elite/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf52235/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5225x/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5225x/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mcf5235/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5329/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mrm332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/ods68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/sim68000/include/bsp.h (modified) * c/src/lib/libbsp/m68k/uC5282/include/bsp.h (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspclean.c (modified) * c/src/lib/libbsp/mips/csb350/include/bsp.h (modified) * c/src/lib/libbsp/mips/genmongoosev/include/bsp.h (modified) * c/src/lib/libbsp/mips/hurricane/include/bsp.h (modified) * c/src/lib/libbsp/mips/jmr3904/include/bsp.h (modified) * c/src/lib/libbsp/mips/malta/include/bsp.h (modified) * c/src/lib/libbsp/mips/rbtx4925/include/bsp.h (modified) * c/src/lib/libbsp/mips/rbtx4938/include/bsp.h (modified) * c/src/lib/libbsp/nios2/nios2_iss/include/bsp.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/beatnik/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/beatnik/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/ep1a/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/haleakala/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mbx8xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mvme5500/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/psim/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/qemuppc/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/score603e/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/ss555/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/t32mppc/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/tqm8xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex4/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex4/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/virtex5/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex5/startup/bspclean.c (modified) * c/src/lib/libbsp/sh/gensh1/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh2/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh4/include/bsp.h (modified) * c/src/lib/libbsp/sh/shsim/include/bsp.h (modified) * c/src/lib/libbsp/shared/bspclean.c (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/niagara/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/usiii/include/bsp.h (modified) * c/src/lib/libbsp/v850/gdbv850sim/include/bsp.h (modified) * cpukit/score/include/rtems/score/interr.h (modified) * testsuites/psxtests/psxfatal_support/init.c (modified) * testsuites/samples/minimum/init.c (modified) * testsuites/sptests/spfatal_support/init.c (modified) score: Add RTEMS_FATAL_SOURCE_EXIT Include ... Tue, 13 Nov 2012 16:40:33 GMT Sebastian Huber [dc6e830] * c/src/lib/libbsp/powerpc/shared/startup/panic.c (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/rtems/fatal.h (modified) * cpukit/sapi/src/interrdesc.c (added) * doc/user/Makefile.am (modified) * doc/user/fatal.t (modified) * testsuites/psxtests/psxfatal_support/init.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal_support/init.c (modified) * testsuites/sptests/spinternalerror02/Makefile.am (added) * testsuites/sptests/spinternalerror02/init.c (added) * testsuites/sptests/spinternalerror02/spinternalerror02.doc (added) * testsuites/sptests/spinternalerror02/spinternalerror02.scn (added) sapi: Add and use rtems_internal_error_description Wed, 14 Nov 2012 11:37:24 GMT Sebastian Huber [e4b40531] * c/src/lib/libbsp/shared/include/default-initial-extension.h (modified) * cpukit/sapi/include/rtems/extension.h (modified) sapi: Add rtems_fatal_source and rtems_fatal_code Thu, 15 Nov 2012 12:04:42 GMT Sebastian Huber [767b4c1] * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/start/start.S (modified) bsp/jmr3904: Define bsp_reset() This is declared in ... Thu, 15 Nov 2012 10:57:59 GMT Sebastian Huber [db5cb262] * c/src/lib/libbsp/lm32/shared/startup/bspstart.c (modified) bsps/lm32: Include Wed, 14 Nov 2012 13:21:26 GMT Sebastian Huber [12007d0] * c/src/lib/libbsp/arm/smdk2410/include/bsp.h (modified) * c/src/lib/libbsp/m68k/av5282/include/bsp.h (modified) * c/src/lib/libbsp/m68k/uC5282/include/bsp.h (modified) bsps: Include in Wed, 14 Nov 2012 10:53:38 GMT Sebastian Huber [a3e8ab2] * c/src/lib/libbsp/sparc/shared/start.S (modified) bsps/sparc: Define bsp_reset() This is declared in ... Wed, 14 Nov 2012 10:14:21 GMT Sebastian Huber [3a1d9c6] * c/src/lib/libbsp/lm32/milkymist/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/beatnik/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/virtex4/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/virtex5/startup/bspclean.c (modified) * c/src/lib/libbsp/shared/bspclean.c (modified) bsps: Include Use to get ... Wed, 07 Nov 2012 13:59:20 GMT Sebastian Huber [7121cac0] * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc/shared/startup/bspfatalextension.c (added) bsps/sparc: Add BSP_INITIAL_EXTENSION to The ... Wed, 07 Nov 2012 15:18:39 GMT Sebastian Huber [38c0b112] * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/preinstall.am (added) * c/src/lib/libbsp/shared/include/default-initial-extension.h (added) bsps: New file Tue, 06 Nov 2012 11:32:44 GMT Sebastian Huber [9186fa8] * c/src/lib/libbsp/sparc/shared/start.S (modified) bsps/sparc: Delete unused symbol declaration Tue, 06 Nov 2012 11:18:10 GMT Sebastian Huber [ef5f359] * c/src/lib/libbsp/arm/gumstix/include/bsp.h (modified) * c/src/lib/libbsp/m68k/idp/clock/ckinit.c (modified) * c/src/lib/libbsp/powerpc/beatnik/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/config.h (modified) sapi: Delete duplicate declarations Tue, 06 Nov 2012 11:01:19 GMT Sebastian Huber [c479497] * c/src/lib/libbsp/powerpc/beatnik/startup/bspstart.c (modified) sapi: Use rtems_configuration_get_work_space_size Tue, 06 Nov 2012 10:59:43 GMT Sebastian Huber [f536e12] * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/leon3/shmsupp/getcfg.c (modified) * cpukit/sapi/src/exinit.c (modified) sapi: Use rtems_*_get_user_multiprocessing_table Tue, 06 Nov 2012 10:26:58 GMT Sebastian Huber [75524a5e] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspworkareainit.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c (modified) * c/src/lib/libbsp/shared/bspgetworkarea.c (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/percpu.c (modified) sapi: Use rtems_config*_get_interrupt_stack_size Tue, 06 Nov 2012 09:34:42 GMT Sebastian Huber [5e86086] * c/src/lib/libbsp/m68k/idp/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mcf52235/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5329/clock/clock.c (modified) * c/src/lib/libcpu/arm/pxa255/clock/clock.c (modified) * cpukit/libmisc/capture/capture.c (modified) sapi: Use rtems_config*_get_microseconds_per_tick Tue, 06 Nov 2012 11:05:26 GMT Sebastian Huber [524473fd] * c/src/lib/libbsp/arm/nds/startup/bspstart.c (modified) bsp/nds: Do not change configuration Tue, 06 Nov 2012 10:52:44 GMT Sebastian Huber [c082e633] * c/src/lib/libbsp/m68k/mvme167/startup/bspstart.c (modified) bsp/mvme167: Do not provide user extensions table The application ... Tue, 06 Nov 2012 10:50:59 GMT Sebastian Huber [e85476b] * c/src/lib/libbsp/m68k/mvme167/include/page_table.h (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/page_table.c (modified) bsp/mvme167: Remove unused parameter Tue, 06 Nov 2012 09:15:17 GMT Sebastian Huber [a9e5e74] * c/src/lib/libbsp/shared/src/irq-generic.c (modified) bsps: Use allocator mutex for generic IRQ support Since the ... Wed, 31 Oct 2012 10:54:39 GMT Sebastian Huber [9f0a68c] * c/src/lib/libbsp/arm/gp32/smc/smc.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_memcard/memcard.c (modified) * c/src/libchip/i2c/spi-sd-card.c (modified) * c/src/libchip/ide/ata.c (modified) * c/src/libchip/ide/ata_internal.h (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) * cpukit/libblock/src/ramdisk-driver.c (modified) * testsuites/libtests/block05/init.c (modified) * testsuites/libtests/block06/init.c (modified) * testsuites/libtests/block08/test_disk.c (modified) * testsuites/libtests/block09/init.c (modified) * testsuites/libtests/block10/init.c (modified) * testsuites/libtests/block12/init.c (modified) * testsuites/libtests/block13/init.c (modified) * testsuites/libtests/block14/init.c (modified) * testsuites/libtests/block15/init.c (modified) libblock: Block device transfer request API change Add and use ... Wed, 31 Oct 2012 16:03:06 GMT Sebastian Huber [20e1e769] * c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c (modified) bsp/mpc55xx: SMSC9218i avoid mbuf migration The receive task will ... Tue, 30 Oct 2012 16:42:17 GMT Sebastian Huber [26e90fb1] * c/src/lib/libbsp/arm/csb336/network/network.c (modified) * c/src/lib/libbsp/arm/csb337/network/network.c (modified) * c/src/lib/libbsp/arm/gumstix/rtl8019/rtl8019.c (modified) * c/src/lib/libbsp/arm/nds/wifi/wifi.c (modified) * c/src/lib/libbsp/arm/shared/lpc/network/lpc-ethernet.c (modified) * c/src/lib/libbsp/i386/pc386/3c509/3c509.c (modified) * c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c (modified) * c/src/lib/libbsp/i386/pc386/wd8003/wd8003.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_networking/network.c (modified) * c/src/lib/libbsp/lm32/shared/tsmac/tsmac.c (modified) * c/src/lib/libbsp/m68k/av5282/network/network.c (modified) * c/src/lib/libbsp/m68k/csb360/network/network.c (modified) * c/src/lib/libbsp/m68k/gen68302/network/network.c (modified) * c/src/lib/libbsp/m68k/gen68360/network/network.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/network/network.c (modified) * c/src/lib/libbsp/m68k/mcf5235/network/network.c (modified) * c/src/lib/libbsp/m68k/mcf5329/network/network.c (modified) * c/src/lib/libbsp/m68k/mvme167/network/network.c (modified) * c/src/lib/libbsp/m68k/uC5282/network/network.c (modified) * c/src/lib/libbsp/mips/csb350/network/network.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_mve/mv643xx_eth.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/porting/if_xxx_rtems.c (modified) * c/src/lib/libbsp/powerpc/gen5200/network_5200/network.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/network/network.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/network/network.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/network/tsec.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/network/if_100MHz/GT64260eth.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/network/if_1GHz/if_wm.c (modified) * c/src/lib/libbsp/powerpc/psim/network/if_sim.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/network/network_fec.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/network/network_scc.c (modified) * c/src/lib/libbsp/powerpc/virtex/network/xiltemac.c (modified) * c/src/lib/libcpu/bfin/network/ethernet.c (modified) * c/src/lib/libcpu/powerpc/mpc83xx/network/tsec.c (modified) * c/src/libchip/network/cs8900.c (modified) * c/src/libchip/network/dec21140.c (modified) * c/src/libchip/network/elnk.c (modified) * c/src/libchip/network/greth.c (modified) * c/src/libchip/network/i82586.c (modified) * c/src/libchip/network/if_dc.c (modified) * c/src/libchip/network/if_fxp.c (modified) * c/src/libchip/network/open_eth.c (modified) * c/src/libchip/network/smc91111.c (modified) * c/src/libchip/network/sonic.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_select.c (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) libnetworking: Use system events Add reserved system events ... Mon, 29 Oct 2012 20:14:23 GMT Sebastian Huber [f33873b] * c/src/lib/libbsp/i386/pc386/startup/bspgetworkarea.c (modified) bsp/pc386: Typo Thu, 25 Oct 2012 15:40:57 GMT Sebastian Huber [2ece571e] * c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c (modified) bsp/mpc55xx: Stop tasks for SMSC9218i during off Fri, 28 Sep 2012 13:36:26 GMT Sebastian Huber [da890759] * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspworkareainit.c (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5566evb (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc55xx (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5643l_evb (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674f_ecu508_app (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674f_ecu508_boot (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.mpc5674fevb (modified) bsp/mpc55xx: Add custom work area init Fri, 24 Aug 2012 13:25:45 GMT Sebastian Huber [c118a6e5] * c/src/lib/libbsp/shared/include/bootcard.h (modified) bsps: Add bsp_work_area_initialize_with_table() Thu, 09 Aug 2012 14:48:00 GMT Sebastian Huber [47a3cd8] * c/src/lib/libbsp/arm/gba/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/i386/pc386/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/sbrk.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/shared/bootcard.c (modified) * c/src/lib/libbsp/shared/bspgetworkarea.c (modified) * c/src/lib/libbsp/shared/bsplibc.c (modified) * c/src/lib/libbsp/shared/include/bootcard.h (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc/shared/bspgetworkarea.c (modified) * c/src/lib/libbsp/sparc/shared/startup/early_malloc.c (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/shared/startup/bspgetworkarea.c (deleted) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/libcsupport.h (modified) * cpukit/libcsupport/include/rtems/malloc.h (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/libcsupport/src/malloc_p.h (modified) * cpukit/libcsupport/src/malloc_sbrk_helpers.c (deleted) * cpukit/libcsupport/src/mallocinfo.c (modified) * cpukit/libcsupport/src/rtems_heap_extend_via_sbrk.c (added) * cpukit/libcsupport/src/rtems_heap_null_extend.c (added) * cpukit/libmisc/monitor/mon-config.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/score/include/rtems/score/heap.h (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/wkspace.h (modified) * cpukit/score/inline/rtems/score/heap.inl (modified) * cpukit/score/src/wkspace.c (modified) * doc/bsp_howto/init.t (modified) * testsuites/libtests/malloc04/init.c (modified) * testsuites/psxtests/psxfatal_support/init.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal06/testcase.h (modified) * testsuites/sptests/spfatal07/testcase.h (modified) * testsuites/sptests/spfatal08/testcase.h (modified) * testsuites/sptests/spfatal09/testcase.h (modified) * testsuites/sptests/spfatal12/testcase.h (modified) * testsuites/sptests/spfatal21/Makefile.am (deleted) * testsuites/sptests/spfatal21/spfatal21.doc (deleted) * testsuites/sptests/spfatal21/spfatal21.scn (deleted) * testsuites/sptests/spfatal21/testcase.h (deleted) * testsuites/sptests/spfatal_support/init.c (modified) score: Work area initialization API change The work areas (RTEMS ... Mon, 15 Oct 2012 08:27:59 GMT Ralf Corsépius [86d7cbd] * c/src/lib/libbsp/shared/console-polled.c (modified) Remove unused var 'sc'. Mon, 15 Oct 2012 04:00:20 GMT Ralf Corsépius [61af4b0b] * c/src/lib/libbsp/i386/pc386/console/fb_vga.c (modified) Include . Thu, 09 Aug 2012 14:45:12 GMT Sebastian Huber [f7513a0] * c/src/lib/libbsp/arm/csb337/startup/bspstart.c (modified) * c/src/lib/libbsp/bfin/TLL6527M/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/bspstart.c (modified) bsps: Remove unused bsp_libc_init() prototype
