# # ChangeLog for c/src/lib/libbsp in rtems # # Generated by Trac 1.2.1.dev0 # 05/11/24 21:43:25 Fri, 25 Aug 2017 08:58:58 GMT Sebastian Huber [b2ed712] * c/src/lib/libbsp/arm/altera-cyclone-v/rtc/rtc.c (modified) * c/src/lib/libbsp/arm/atsam/spi/atsam_spi_bus.c (modified) * c/src/lib/libbsp/arm/lpc176x/can/can.c (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/nand-mlc-read-blocks.c (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/nand-mlc-write-blocks.c (modified) * c/src/lib/libbsp/arm/raspberrypi/console/console_select.c (modified) * c/src/lib/libbsp/arm/raspberrypi/misc/vc_defines.h (modified) * c/src/lib/libbsp/arm/raspberrypi/startup/cmdline.c (modified) * c/src/lib/libbsp/arm/shared/arm-pl111-fb.c (modified) * c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c (modified) * c/src/lib/libbsp/arm/tms570/console/printk-support.c (modified) * c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_framebuffer/framebuffer.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_versions/versions.c (modified) * c/src/lib/libbsp/lm32/shared/tsmac/tsmac.c (modified) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * c/src/lib/libbsp/sparc/shared/amba/ahbstat.c (modified) * c/src/lib/libbsp/sparc/shared/analog/gradcdac.c (modified) * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus_leon2.c (modified) * c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c (modified) * c/src/lib/libbsp/sparc/shared/iommu/griommu.c (modified) * c/src/lib/libbsp/sparc/shared/l2c/l2c.c (modified) * c/src/lib/libbsp/sparc/shared/pci/grpci2dma.c (modified) * c/src/lib/libbsp/sparc/shared/scrub/memscrub.c (modified) * c/src/lib/libbsp/sparc/shared/time/grctm.c (modified) * c/src/lib/libbsp/sparc/shared/time/spwcuc.c (modified) * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) * c/src/lib/libbsp/sparc64/shared/helenos/boot/sparc64/loader/main.c (modified) * c/src/lib/libcpu/bfin/bf52x/interrupt/interrupt.c (modified) * c/src/lib/libcpu/bfin/interrupt/interrupt.c (modified) * cpukit/dev/i2c/ti-lm25066a.c (modified) * cpukit/include/rtems/printer.h (modified) * cpukit/libcsupport/src/cfmakesane.c (modified) * cpukit/libcsupport/src/chroot.c (modified) * cpukit/libcsupport/src/fchmod.c (modified) * cpukit/libcsupport/src/fchown.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libdl/rtl-allocator.c (modified) * cpukit/libdl/rtl-error.c (modified) * cpukit/libdl/rtl-find-file.c (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-sym.c (modified) * cpukit/libdl/rtl-unresolved.c (modified) * cpukit/libfs/src/imfs/imfs_linfile.c (modified) * cpukit/libmisc/dummy/default-configuration.c (modified) * cpukit/libmisc/redirector/stdio-redirect.c (modified) * cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c (modified) * cpukit/libmisc/shell/main_md5.c (modified) * cpukit/libmisc/shell/main_rtrace.c (modified) * cpukit/libmisc/untar/untar_tgz.c (modified) * cpukit/libpci/pci_cfg_print_code.c (modified) * cpukit/librpc/src/rpc/get_myaddress.c (modified) * cpukit/posix/src/mmap.c (modified) * cpukit/posix/src/shmheap.c (modified) * cpukit/posix/src/shmwkspace.c (modified) * cpukit/score/src/threadq.c (modified) Include missing Update #2133. Thu, 10 Aug 2017 09:37:30 GMT Sebastian Huber [695c9c50] * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_e6500_64-testsuite.tcfg (added) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_e6500_64.cfg (added) bsp/qoriq: Add qoriq_e6500_64 variant Update #3082. Wed, 02 Aug 2017 13:48:03 GMT Sebastian Huber [95a4b1f] * c/src/lib/libbsp/powerpc/qoriq/startup/linkcmds.qoriq_e6500_32 (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-config.c (modified) bsp/qoriq: Enable > 2GiB memory Update #3082. Fri, 11 Aug 2017 08:44:04 GMT Sebastian Huber [c693a3a] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_fatal.S (modified) * cpukit/score/cpu/powerpc/rtems/asm.h (modified) powerpc: PPC64_NOP_FOR_LINKER_TOC_POINTER_RESTORE In 64-bit mode, ... Wed, 02 Aug 2017 12:36:32 GMT Sebastian Huber [c8aeb76] * c/src/lib/libbsp/powerpc/qoriq/include/mmu.h (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-tlb1.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu.c (modified) bsp/qoriq: 64-bit MMU support Update #3082. Thu, 10 Aug 2017 12:14:26 GMT Sebastian Huber [77c81016] * c/src/lib/libbsp/powerpc/qoriq/irq/irq.c (modified) bsp/qoriq: 64-bit support for interrupt controller Update #3082. Wed, 02 Aug 2017 07:16:10 GMT Sebastian Huber [5f42a0e] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) bsp/qoriq: Enable 64-bit mode for exceptions Update #3082. Tue, 01 Aug 2017 06:42:45 GMT Sebastian Huber [f14da45] * c/src/lib/libbsp/powerpc/qoriq/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspsmp.c (modified) bsp/qoriq: 64-bit support for spin table Update #3082. Tue, 01 Aug 2017 06:41:07 GMT Sebastian Huber [0ae1916b] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) bsp/qoriq: Copy FDT later We need a ready to use TOC section before ... Thu, 10 Aug 2017 09:39:43 GMT Sebastian Huber [43cc2b4] * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/bsp_specs (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/preinstall.am (modified) * c/src/lib/libbsp/powerpc/qoriq/shmsupp/intercom.c (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/linkcmds.qoriq_e6500_32 (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/linkcmds.qoriq_e6500_64 (added) bsp/qoriq: Add basic 64-bit support Update #3082. Mon, 31 Jul 2017 13:10:33 GMT Sebastian Huber [c6994af] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) bsp/qoriq: Use LA to load an address Add 64-bit support for LA. ... Tue, 01 Aug 2017 13:35:16 GMT Sebastian Huber [0e26c19a] * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/bsp_specs (modified) * c/src/lib/libbsp/powerpc/qoriq/preinstall.am (modified) * c/src/lib/libbsp/powerpc/shared/start/rtems_crti.S (modified) * c/src/lib/libbsp/powerpc/shared/start/rtems_crtn.S (added) bsps/powerpc: Add 64-bit CRT init/fini support Update #3082. Mon, 31 Jul 2017 13:25:12 GMT Sebastian Huber [50382788] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/t32mppc/start/start.S (modified) * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) bsps/powerpc: Add 64-bit SET_SELF_CPU_CONTROL Update #3082. Thu, 10 Aug 2017 09:38:46 GMT Sebastian Huber [60d077f] * c/src/lib/libbsp/powerpc/shared/startup/linkcmds.base (modified) bsps/powerpc: Add 64-bit linker sections Update #3082. Wed, 02 Aug 2017 12:13:06 GMT Sebastian Huber [241d2f2] * c/src/lib/libbsp/shared/src/bsp-fdt.c (modified) bsps: Fix integer types in bsp_fdt_copy() Update #3082. Tue, 01 Aug 2017 06:37:12 GMT Sebastian Huber [d8012bbd] * c/src/lib/libbsp/arm/beagle/configure.ac (modified) * c/src/lib/libbsp/shared/src/bsp-fdt.c (modified) bsps: Add BSP_FDT_BLOB_COPY_TO_READ_ONLY_LOAD_AREA Thu, 10 Aug 2017 12:23:02 GMT Sebastian Huber [ec25c6ef] * c/src/lib/libbsp/shared/src/irq-generic.c (modified) bsps: Fix integer to/from pointer Update #3082. Tue, 01 Aug 2017 08:57:46 GMT Sebastian Huber [a6f84b27] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_fatal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) * cpukit/score/cpu/powerpc/cpu.c (modified) * cpukit/score/cpu/powerpc/ppc-context-validate.S (modified) * cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/powerpc/rtems/score/powerpc.h (modified) powerpc: Add 64-bit context/interrupt support Update #3082. Fri, 04 Aug 2017 12:46:17 GMT Sebastian Huber [ca9490c] * c/src/lib/libbsp/arm/imx/console/console-config.c (modified) bsp/imx: Fix UART interrupt Update #3090. Thu, 03 Aug 2017 06:53:13 GMT Sebastian Huber [694c31f9] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (added) * c/src/lib/libbsp/arm/imx/bsp_specs (added) * c/src/lib/libbsp/arm/imx/configure.ac (added) * c/src/lib/libbsp/arm/imx/console/console-config.c (added) * c/src/lib/libbsp/arm/imx/include/arm/freescale/imx/imx_ccmvar.h (added) * c/src/lib/libbsp/arm/imx/include/arm/freescale/imx/imx_uartreg.h (added) * c/src/lib/libbsp/arm/imx/include/bsp.h (added) * c/src/lib/libbsp/arm/imx/include/irq.h (added) * c/src/lib/libbsp/arm/imx/include/tm27.h (added) * c/src/lib/libbsp/arm/imx/make/custom/imx7.cfg (added) * c/src/lib/libbsp/arm/imx/preinstall.am (added) * c/src/lib/libbsp/arm/imx/startup/bspreset.c (added) * c/src/lib/libbsp/arm/imx/startup/bspsmp.c (added) * c/src/lib/libbsp/arm/imx/startup/bspstart.c (added) * c/src/lib/libbsp/arm/imx/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/imx/startup/ccm.c (added) * c/src/lib/libbsp/arm/imx/startup/linkcmds.imx7 (added) * c/src/lib/libbsp/shared/include/fatal.h (modified) bsp/imx: New BSP Update #3090. Fri, 04 Aug 2017 11:56:42 GMT Sebastian Huber [ffe7c0e] * c/src/lib/libbsp/arm/shared/arm-generic-timer-clock-config.c (added) * c/src/lib/libbsp/shared/include/fatal.h (modified) bsps/arm: Add ARMv7-AR Generic Timer clock driver Update #3090. Thu, 03 Aug 2017 12:48:04 GMT Sebastian Huber [30be024a] * c/src/lib/libbsp/lm32/shared/clock/ckinit.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mcf52235/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5329/clock/clock.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libcpu/arm/at91rm9200/clock/clock.c (modified) * c/src/lib/libcpu/arm/pxa255/clock/clock.c (modified) Optional Clock_driver_support_shutdown_hardware() Make ... Tue, 01 Aug 2017 09:43:57 GMT Sebastian Huber [a8694035] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/exc-vector-base.S (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/t32mppc/start/start.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) bsps/powerpc: Add PPC_EXC_INTERRUPT_FRAME_SIZE Use a specific ... Tue, 01 Aug 2017 09:38:32 GMT Sebastian Huber [23cb9af] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/exc-vector-base.S (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/t32mppc/start/start.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) bsps/powerpc: Rename ppc_exc_wrap_async_normal Rename ... Mon, 31 Jul 2017 12:14:46 GMT Sebastian Huber [b7be9439] * c/src/lib/libbsp/powerpc/shared/startup/linkcmds.base (modified) bsps/powerpc: Do not set ouput format and arch There is no need to ... Mon, 31 Jul 2017 11:39:34 GMT Sebastian Huber [65ee42c] * c/src/lib/libbsp/powerpc/qoriq/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspsmp.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-config.c (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_fatal.S (added) * c/src/lib/libcpu/powerpc/preinstall.am (modified) bsp/qoriq: Simplify fatal exceptions Avoid use of small-data area, ... Fri, 28 Jul 2017 19:15:36 GMT Joel Sherrill [dd6992fd] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/console/conscfg.c (modified) * c/src/lib/libbsp/i386/pc386/console/console_edison.c (deleted) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/make/custom/edison.cfg (deleted) * c/src/lib/libbsp/i386/pc386/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/i386/pc386/startup/bspreset.c (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) Remove Edison BSP. Intel has obsoleted this hardware and the BSP ... Fri, 28 Jul 2017 16:27:54 GMT Joel Sherrill [9cb874d] * c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c (modified) beagle/i2c/bbb-i2c.c: Eliminiate set but not used warning Fri, 28 Jul 2017 13:39:39 GMT Sebastian Huber [8966e8a] * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/include/bsp.h (modified) bsp/qoriq: Fix pre-processor expansion Update #3082. Update #3085. Fri, 28 Jul 2017 13:03:47 GMT Sebastian Huber [5d0fa047] * c/src/lib/libbsp/powerpc/t32mppc/start/start.S (modified) bsp/t32mppc: Set PPC_PER_CPU_CONTROL_REGISTER Fri, 28 Jul 2017 12:42:53 GMT Sebastian Huber [585706a4] * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c (modified) * cpukit/score/cpu/powerpc/rtems/score/cpuimpl.h (modified) bsp/t32mppc: Add SMP support Fri, 28 Jul 2017 11:50:12 GMT Sebastian Huber [cd7991b8] * c/src/lib/libbsp/powerpc/shared/src/memcpy.c (modified) bsps/powerpc: Fix warning Fri, 28 Jul 2017 11:40:45 GMT Sebastian Huber [9379c70] * c/src/lib/libbsp/sparc64/shared/helenos/boot/sparc64/loader/main.c (modified) bsps/sparc64: Fix warning Fri, 28 Jul 2017 11:10:19 GMT Sebastian Huber [0684f35] * c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c (modified) bsp/i386: Fix warning Fri, 28 Jul 2017 11:06:55 GMT Sebastian Huber [fd3437c] * c/src/lib/libbsp/powerpc/gen5200/irq/irq.c (modified) bsp/gen5200: Fix warnings Fri, 28 Jul 2017 11:06:41 GMT Sebastian Huber [a9f5812] * c/src/lib/libbsp/powerpc/qoriq/irq/irq.c (modified) bsp/qoriq: Fix warning Thu, 27 Jul 2017 13:36:11 GMT Sebastian Huber [0db7c55] * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_e500-testsuite.tcfg (moved) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_e500.cfg (added) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_e6500_32-testsuite.tcfg (moved) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_e6500_32.cfg (moved) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_p1020rdb.cfg (deleted) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_t4240rdb-testsuite.tcfg (deleted) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_t4240rdb.cfg (deleted) * c/src/lib/libbsp/powerpc/qoriq/preinstall.am (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/linkcmds.qoriq_e500 (moved) * c/src/lib/libbsp/powerpc/qoriq/startup/linkcmds.qoriq_e6500_32 (moved) * c/src/lib/libbsp/powerpc/qoriq/startup/linkcmds.qoriq_t4240rdb (deleted) bsp/qoriq: New BSP names Due to the FDT support we can now reduce ... Thu, 27 Jul 2017 13:16:36 GMT Sebastian Huber [b615e9b] * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) bsp/qoriq: Simplify initialization Do not flush/invalidate the ... Mon, 17 Jul 2017 05:30:46 GMT Sebastian Huber [146adb1] * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libcpu/sparc/syscall/syscall.S (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/cpu_asm.S (deleted) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) * testsuites/sptests/spfatal30/init.c (modified) * testsuites/sptests/spfatal31/init.c (modified) * testsuites/sptests/spsize/size.c (modified) sparc: Add lazy floating point switch The SPARC ABI is a bit ... Wed, 19 Jul 2017 07:07:17 GMT Sebastian Huber [600d88d] * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal30/Makefile.am (added) * testsuites/sptests/spfatal30/init.c (added) * testsuites/sptests/spfatal30/spfatal30.doc (added) * testsuites/sptests/spfatal30/spfatal30.scn (added) * testsuites/sptests/spfatal31/Makefile.am (added) * testsuites/sptests/spfatal31/init.c (added) * testsuites/sptests/spfatal31/spfatal31.doc (added) * testsuites/sptests/spfatal31/spfatal31.scn (added) * testsuites/sptests/spinternalerror02/init.c (modified) INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT Add new fatal ... Tue, 18 Jul 2017 13:11:41 GMT Sebastian Huber [a400d06f] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) sparc: Rename SPARC_USE_SAFE_FP_SUPPORT Rename ... Wed, 19 Jul 2017 12:06:06 GMT Sebastian Huber [671efc50] * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/make/custom/at697f.cfg (added) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon2/startup/linkcmds.at697f (added) * c/src/lib/libbsp/sparc/leon2/startup/linkcmds.leon2 (added) bsp/leon2: Add at697f variant Wed, 19 Jul 2017 12:05:24 GMT Sebastian Huber [9f84bdb] * c/src/lib/libbsp/sparc/leon2/make/custom/leon2.cfg (modified) bsp/leon2: Use hard-float by default Wed, 19 Jul 2017 12:26:19 GMT Sebastian Huber [dcc3ccc] * c/src/lib/libbsp/shared/src/irq-server.c (modified) bsps: Fix warning Update #3071. Fri, 14 Jul 2017 12:12:07 GMT Daniel Cederman [4debaca6] * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/make/custom/gr712rc.cfg (added) * c/src/lib/libbsp/sparc/leon3/make/custom/gr740.cfg (moved) * c/src/lib/libbsp/sparc/leon3/make/custom/leon3.cfg (modified) * c/src/lib/libbsp/sparc/leon3/make/custom/ut699.cfg (added) * c/src/lib/libbsp/sparc/leon3/make/custom/ut700.cfg (added) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/startup/linkcmds.gr712rc (added) * c/src/lib/libbsp/sparc/leon3/startup/linkcmds.gr740 (moved) * c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ut699 (added) * c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ut700 (added) bsps/sparc: Add leon3 BSP variants Rename NGMP to GR740 and add ... Thu, 13 Jul 2017 07:26:50 GMT Daniel Cederman [2f8704b6] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libcpu/sparc/access/access.S (modified) * c/src/lib/libcpu/sparc/reg_win/window.S (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) sparc: Add assembly workaround for LEON3FT B2BST errata This patch ... Wed, 12 Jul 2017 08:55:59 GMT Sebastian Huber [e19da87a] * c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h (modified) * c/src/lib/libbsp/powerpc/qoriq/include/irq.h (modified) * c/src/lib/libbsp/shared/src/irq-generic.c (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp/irq.h (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp/irq.h (modified) bsps: Include missing header file Update #3071. Tue, 11 Jul 2017 10:51:19 GMT Sichen Zhao <1473996754@…> [f6115d7c] * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/configure.ac (modified) * c/src/lib/libbsp/arm/beagle/include/bsp.h (modified) * c/src/lib/libbsp/arm/beagle/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/shared/start/start.S (modified) bsp/beagle: Add FDT support for Beaglebone Black Tue, 11 Jul 2017 09:54:30 GMT Sebastian Huber [af207fa9] * c/src/lib/libbsp/arm/shared/arm-gic-irq.c (modified) * c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h (modified) * c/src/lib/libbsp/powerpc/qoriq/clock/clock-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/include/irq.h (modified) * c/src/lib/libbsp/powerpc/qoriq/irq/irq.c (modified) * c/src/lib/libbsp/shared/src/irq-generic.c (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp/irq.h (modified) * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp/irq.h (modified) * c/src/lib/libbsp/sparc/leon3/startup/eirq.c (modified) * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus_grlib.c (modified) * cpukit/include/rtems/irq-extension.h (modified) * cpukit/score/include/rtems/score/processormask.h (modified) Add interrupt vector set/get affinity Close #3071. Tue, 11 Jul 2017 09:20:06 GMT Sebastian Huber [ccc87c8b] * c/src/lib/libbsp/shared/src/irq-server.c (modified) * cpukit/include/rtems/irq-extension.h (modified) Add interrupt server move Update #3071. Tue, 11 Jul 2017 07:08:15 GMT Sebastian Huber [d184140] * c/src/lib/libbsp/shared/src/irq-server.c (modified) * cpukit/include/rtems/irq-extension.h (modified) Add interrupt server set affinity Update #3071. Tue, 11 Jul 2017 06:48:15 GMT Sebastian Huber [a961e198] * c/src/lib/libbsp/shared/src/irq-server.c (modified) * cpukit/include/rtems/irq-extension.h (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) Add interrupt server suspend/resume This mechanism can be used to ... Tue, 11 Jul 2017 06:25:09 GMT Sebastian Huber [e7ee719f] * c/src/lib/libbsp/shared/src/irq-server.c (modified) * cpukit/include/rtems/irq-extension.h (modified) Create one interrupt server per processor This allows load ... Tue, 11 Jul 2017 12:15:47 GMT Sebastian Huber [c29eb085] * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c (modified) bsps/sparc: Fix ambapp_int_set_affinity() Update #3059. Fri, 07 Jul 2017 05:45:57 GMT Sebastian Huber [76d1198] * c/src/lib/libbsp/powerpc/qoriq/startup/bsprestart.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) * cpukit/score/src/threadinitialize.c (modified) * testsuites/smptests/smpipi01/init.c (modified) score: Introduce _SMP_Get_online_processors() Update #3059. Mon, 03 Jul 2017 09:46:12 GMT Sebastian Huber [3dfe55ee] * c/src/lib/libbsp/powerpc/qoriq/clock/clock-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bsprestart.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c (modified) * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus_grlib.c (modified) * c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h (modified) * cpukit/libdrvmgr/drvmgr.h (modified) * cpukit/libdrvmgr/drvmgr_drvinf.c (modified) * cpukit/score/include/rtems/score/processormask.h (modified) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/smpmulticastaction.c (modified) * testsuites/smptests/smpipi01/init.c (modified) score: Use for Processor_mask Implement the ... Fri, 23 Jun 2017 09:51:14 GMT Sebastian Huber [5bfeab95] * c/src/lib/libbsp/shared/src/irq-server.c (modified) * cpukit/include/rtems/irq-extension.h (modified) Add rtems_interrupt_server_handler_iterate() Thu, 15 Jun 2017 17:40:25 GMT Joel Sherrill [ec230fc7] * c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c (modified) i386/shared/comm/i386-stub-glue.c: Fix duplicate const warning Thu, 15 Jun 2017 17:40:04 GMT Joel Sherrill [9177426] * c/src/lib/libbsp/arm/lpc176x/misc/restart.c (modified) lpc176x/misc/restart.c: Fix duplicate const warning Mon, 19 Jun 2017 12:09:28 GMT Sebastian Huber [c6810c8] * c/src/lib/libbsp/arm/beagle/irq.c (modified) * c/src/lib/libbsp/arm/edb7312/irq/irq.c (modified) * c/src/lib/libbsp/arm/gdbarmsim/irq/irq.c (modified) * c/src/lib/libbsp/arm/lpc24xx/irq/irq.c (modified) * c/src/lib/libbsp/arm/lpc32xx/irq/irq.c (modified) * c/src/lib/libbsp/arm/raspberrypi/irq/irq.c (modified) * c/src/lib/libbsp/arm/shared/arm-gic-irq.c (modified) * c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c (modified) * c/src/lib/libbsp/arm/tms570/irq/irq.c (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c (modified) * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) * c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c (modified) * c/src/lib/libbsp/i386/shared/irq/irq.c (modified) * c/src/lib/libbsp/lm32/shared/irq/irq.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c (modified) * c/src/lib/libbsp/mips/shared/irq/irq.c (modified) * c/src/lib/libbsp/or1k/generic_or1k/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/gen5200/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/psim/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/qoriq/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/t32mppc/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c (modified) * c/src/lib/libbsp/shared/include/irq-generic.h (modified) * c/src/lib/libbsp/shared/src/irq-generic.c (modified) * c/src/lib/libbsp/shared/src/irq-server.c (modified) * c/src/lib/libbsp/sparc/shared/irq/irq-shared.c (modified) * c/src/lib/libcpu/arm/at91rm9200/irq/irq.c (modified) * c/src/lib/libcpu/arm/lpc22xx/irq/irq.c (modified) * c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c (modified) * c/src/lib/libcpu/arm/pxa255/irq/irq.c (modified) * c/src/lib/libcpu/arm/s3c24xx/irq/irq.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c (modified) bsps: Improve interrupt vector enable/disable API Change ... Fri, 16 Jun 2017 04:22:21 GMT Sebastian Huber [b361cb6c] * c/src/lib/libbsp/powerpc/shared/src/memcpy.c (modified) bsps/powerpc: Fix warning Close #3051. Thu, 15 Jun 2017 11:35:20 GMT Sichen Zhao <1473996754@…> [369372c3] * c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c (modified) Fix beagle i2c file bbb-i2c.c comment issues Wed, 14 Jun 2017 14:53:44 GMT Sichen Zhao <1473996754@…> [8f550d2] * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c (added) * c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h (modified) * c/src/lib/libbsp/arm/beagle/include/i2c.h (modified) * c/src/lib/libcpu/arm/shared/include/am335x.h (modified) Add the i2c driver for Beaglebone Black Update ticket #2891 and my ... Mon, 05 Jun 2017 12:49:49 GMT Sichen Zhao <1473996754@…> [7741545b] * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/include/i2c.h (modified) * c/src/lib/libbsp/arm/beagle/misc/i2c.c (deleted) Remove beagle old i2c code modify ... Thu, 11 May 2017 13:33:10 GMT Alexei Pososin [fd10817] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) Remove excessive locking from cache operations. According to ... Tue, 13 Jun 2017 09:38:39 GMT Sebastian Huber [3f884b4] * c/src/lib/libbsp/powerpc/virtex/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex/network/xiltemac.c (modified) * c/src/libchip/network/smc91111.c (modified) bsp: Fixes due to header file changes Update #2833. Mon, 12 Jun 2017 13:40:37 GMT Sebastian Huber [0af8bb6] * c/src/lib/libbsp/arm/edb7312/network/network.c (modified) * c/src/lib/libbsp/arm/rtl22xx/network/network.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_mve/mv643xx_eth.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_mve/mve_smallbuf_tst.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_mve/testing.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/network/tsec.c (modified) bsp: Include missing Update #2833. Mon, 12 Jun 2017 13:30:13 GMT Sebastian Huber [74a13c8] * c/src/lib/libbsp/powerpc/beatnik/network/if_em/if_em.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_mve/mv643xx_eth.c (modified) bsp/beatnik: Fixes due to header file changes Update #2833. Fri, 09 Jun 2017 13:42:36 GMT Sebastian Huber [7b0c74ff] * c/src/lib/libbsp/i386/pc386/include/tblsizes.h (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) * c/src/lib/libbsp/i386/shared/irq/idt.c (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/cpu_asm.S (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/tls.h (modified) i386: Support thread-local storage (TLS) Update #2468. Fri, 09 Jun 2017 05:55:16 GMT Sebastian Huber [f256685] * c/src/lib/libbsp/powerpc/psim/network/if_sim.c (modified) bsp/psim: Include missing Fri, 09 Jun 2017 05:25:02 GMT Sebastian Huber [32b4a0c] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) Simplify TLS support in context switch There is no need to save the ... Tue, 06 Jun 2017 13:41:48 GMT Christian Mauderer [ce3ac00] * c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c (modified) bsps/arm: Fix ARMv7-M interrupt suppport Enable/disable vector ... Tue, 06 Jun 2017 09:08:16 GMT Sebastian Huber [787f51f] * c/src/lib/libbsp/arm/atsam/network/if_atsam.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_gfe/if_gfe.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/network/if_hdlcsubr.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/network/if_100MHz/GT64260eth.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/network/if_1GHz/if_wm.c (modified) * c/src/libchip/network/i82586.c (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/pipe/fifo.c (modified) * cpukit/libmisc/shell/main_ifconfig.c (modified) * cpukit/libnetworking/net/if.c (modified) * cpukit/libnetworking/net/if_ethersubr.c (modified) * cpukit/libnetworking/net/if_loop.c (modified) * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) * cpukit/libnetworking/net/route.c (modified) * cpukit/libnetworking/netinet/in.c (modified) * cpukit/libnetworking/netinet/in_pcb.c (modified) * cpukit/libnetworking/netinet/ip_mroute.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_dhcp.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_showifstat.c (modified) * testsuites/sptests/spfifo04/init.c (modified) * testsuites/sptests/spfifo05/init.c (modified) Do not include in kernel-space Update #2833. Thu, 01 Jun 2017 17:04:05 GMT Sebastian Huber [7203b70] * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mcp750.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mtx603e.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2100.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2307.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep-altivec.cfg (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep.cfg (modified) bsp/motorola_powerpc: Fix for Binutils 2.28+ There are mismatched ... Thu, 01 Jun 2017 17:00:38 GMT Sebastian Huber [697a6ca] * c/src/lib/libbsp/powerpc/shared/bootloader/ppcboot.lds (modified) bsps/powerpc: Set output format in linker script Set the proper ... Thu, 25 May 2017 05:10:11 GMT Chris Johns [ff781cc] * c/src/lib/libbsp/m32c/m32cbsp/make/custom/m32csim-testsuite.tcfg (modified) m32c/m32csim: Exclude linpack from the tests. Closes #3025. Sun, 14 May 2017 01:52:52 GMT Chris Johns [a748603] * c/Makefile.am (modified) * c/src/Makefile.am (modified) * c/src/automake/subdirs.am (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/arm/Makefile.am (modified) * c/src/lib/libbsp/bfin/Makefile.am (modified) * c/src/lib/libbsp/epiphany/Makefile.am (modified) * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/Makefile.am (modified) * c/src/lib/libbsp/m32c/Makefile.am (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/mips/Makefile.am (modified) * c/src/lib/libbsp/moxie/Makefile.am (modified) * c/src/lib/libbsp/nios2/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/Makefile.am (modified) * c/src/lib/libbsp/or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/sh/Makefile.am (modified) * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc64/Makefile.am (modified) * c/src/lib/libbsp/v850/Makefile.am (modified) * c/src/lib/libcpu/Makefile.am (modified) * cpukit/Makefile.am (modified) * cpukit/automake/subdirs.am (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/Makefile.am (modified) build-system: Parallel build all subdirs. Tue, 23 May 2017 23:26:29 GMT Chris Johns [9935c23] * c/src/lib/libbsp/arm/tms570/preinstall.am (modified) arm/tms570: Update preinstall.am after bootstrap. Mon, 31 Oct 2016 10:01:39 GMT Jacob Hansen [bc470d3c] * c/src/lib/libbsp/sparc/shared/start/start.S (modified) sparc: only define start if it is different from SYM(start) The SYM ... Fri, 28 Oct 2016 14:05:56 GMT Jacob Hansen [8639685] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libcpu/sparc/access/access.S (modified) * c/src/lib/libcpu/sparc/reg_win/window.S (modified) * c/src/lib/libcpu/sparc/syscall/syscall.S (modified) sparc: Adjust assembly to improve compability with LLVM - All ... Thu, 11 May 2017 11:43:53 GMT Daniel Hellstrom [1ea73e2b] * c/src/lib/libbsp/sparc/shared/tmtc/grtc.c (modified) leon, grtc: SMP support by using spin-locks Thu, 11 May 2017 10:54:46 GMT Daniel Hellstrom [818f10bc] * c/src/lib/libbsp/sparc/shared/tmtc/grtc.c (modified) leon, grtc: updated overrun condition handling The following ... Wed, 10 May 2017 10:39:23 GMT Daniel Hellstrom [6fdded2c] * c/src/lib/libbsp/sparc/shared/1553/gr1553bm.c (modified) leon, gr1553bm: SMP support by using spin-locks Wed, 10 May 2017 08:46:01 GMT Daniel Hellstrom [3feae3b] * c/src/lib/libbsp/sparc/shared/1553/gr1553bc.c (modified) leon, gr1553bc: SMP support by using spin-locks Since DMA buffers ... Tue, 09 May 2017 14:00:56 GMT Daniel Hellstrom [84e4d10c] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/shared/include/apbuart.h (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart.c (deleted) leon, apbuart: remove old RAW UART driver This driver was initially ... Tue, 09 May 2017 11:13:44 GMT Daniel Hellstrom [c92f402c] * c/src/lib/libbsp/sparc/shared/tmtc/grtm.c (modified) leon, grtm: SMP support by using spin-locks Mon, 08 May 2017 14:10:14 GMT Daniel Hellstrom [f767fe74] * c/src/lib/libbsp/sparc/shared/amba/ahbstat.c (modified) leon, ahbstat: remove printf warnings Mon, 08 May 2017 12:58:41 GMT Daniel Hellstrom [ce76b9d2] * c/src/lib/libbsp/sparc/shared/pci/gr_701.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_cpci_gr740.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_tmtc_1553.c (modified) leon, pci-peripherals: SMP support by spin-locks and updated genirq Fri, 05 May 2017 13:42:45 GMT Daniel Hellstrom [8670c464] * c/src/lib/libbsp/sparc/shared/include/genirq.h (modified) * c/src/lib/libbsp/sparc/shared/irq/genirq.c (modified) leon, genirq: SMP support for PCI peripherals The common interrupt ... Mon, 24 Apr 2017 14:39:49 GMT Martin Aberg [aa19873] * c/src/lib/libbsp/sparc/leon3/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) leon: allow SMP boot from any CPU Thu, 13 Apr 2017 12:12:31 GMT Martin Aberg [039edd2a] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: removed unused txerror, rxerror Thu, 13 Apr 2017 12:06:04 GMT Martin Aberg [ee078c21] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: fixed historical comment Tue, 11 Apr 2017 10:30:02 GMT Daniel Hellstrom [91541551] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: semaphore reset count required after flushing It is ... Tue, 11 Apr 2017 08:47:39 GMT Daniel Hellstrom [9855690] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: split hw_stop() into hw and sw stop this is to avoid ... Thu, 13 Apr 2017 12:08:50 GMT Martin Aberg [3a650d3b] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: RTEMS_NO_TIMEOUT on tx_sem Mon, 03 Apr 2017 11:27:49 GMT Martin Aberg [2d3d8f96] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) * c/src/lib/libbsp/sparc/shared/include/grcan.h (modified) leon, grcan: redesigned bus-off and AHB error handling When bus-off ... Thu, 09 Mar 2017 14:44:08 GMT Daniel Hellstrom [ca4c4164] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) * c/src/lib/libbsp/sparc/shared/include/grcan.h (modified) leon, grcan: updated device name and use it for ISR Thu, 26 Jan 2017 10:01:10 GMT Martin Aberg [05749690] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: fixed race on interrupt mask register There was a ... Thu, 26 Jan 2017 09:54:57 GMT Martin Aberg [5d367c56] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: unregister interrupt handler at close Mon, 13 Mar 2017 11:44:58 GMT Martin Aberg [c297060] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: protect statistics on copy to user Locking the stats ...
