# # ChangeLog for c/src/lib/libbsp in rtems # # Generated by Trac 1.2.1.dev0 # 04/20/24 02:04:52 Mon, 13 Oct 2014 21:54:12 GMT Joel Sherrill [af03345] * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c (modified) * c/src/lib/libcpu/m68k/Makefile.am (modified) * c/src/lib/libcpu/m68k/mcf5225x/cache/cachepd.c (added) Move CPU cache support from mcf5225x BSP to libcpu Mon, 13 Oct 2014 20:53:11 GMT Joel Sherrill [bf49991f] * c/src/lib/libbsp/i386/shared/comm/uart.c (modified) i386/shared/comm/uart.c: Remove unused uart_set_driver_handler() method Mon, 13 Oct 2014 20:52:34 GMT Joel Sherrill [451d323] * c/src/lib/libbsp/powerpc/tqm8xx/clock/p_clock.c (modified) tqm8xx/clock/p_clock.c: Remove unused BSP_get_clock_irq_level() method Mon, 13 Oct 2014 20:52:01 GMT Joel Sherrill [a8ac803e] * c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c (modified) tqm8xx/startup/bspstart.c: Remove myCpu variables and clean up Mon, 13 Oct 2014 20:52:00 GMT Joel Sherrill [27474fb] * c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c (modified) ss555/startup/bspstart.c: Remove myCpu variables and clean up Mon, 13 Oct 2014 20:52:00 GMT Joel Sherrill [c506cc98] * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) shared/startup/bspstart.c: Remove myCpu variables and clean up Mon, 13 Oct 2014 20:52:00 GMT Joel Sherrill [0697180] * c/src/lib/libbsp/powerpc/qemuppc/startup/cmain.c (modified) qemuppc/startup/cmain.c: Remove myCpu variables and clean up Mon, 13 Oct 2014 20:52:00 GMT Joel Sherrill [0af227c] * c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c (modified) mpc8260ads/startup/bspstart.c: Remove myCpu variables and clean up Mon, 13 Oct 2014 20:52:00 GMT Joel Sherrill [0549cd7] * c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c (modified) mbx8xx/startup/bspstart.c: Remove myCpu variables and clean up Mon, 13 Oct 2014 20:52:00 GMT Joel Sherrill [5271fd0] * c/src/lib/libbsp/powerpc/ep1a/startup/bspstart.c (modified) ep1a/startup/bspstart.c: Remove myCpu variables and clean up Mon, 13 Oct 2014 20:50:45 GMT Joel Sherrill [01746c4] * c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c (modified) virtex5/startup/bspstart.c: Fix header Mon, 13 Oct 2014 20:50:37 GMT Joel Sherrill [1e77dde7] * c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c (modified) virtex4/startup/bspstart.c: Fix header Mon, 13 Oct 2014 20:49:46 GMT Joel Sherrill [becc686] * c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c (modified) mvme3100/startup/bspstart.c: Remove myCpu variables and clean up Mon, 13 Oct 2014 19:56:07 GMT Joel Sherrill [3916cec] * c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c (modified) powerpc/virtex: Fix unused variable warnings Mon, 13 Oct 2014 19:55:54 GMT Joel Sherrill [cfff78f] * c/src/lib/libbsp/powerpc/mbx8xx/startup/imbx8xx.c (modified) powerpc/mbx8xx: Fix unused variable warnings Mon, 13 Oct 2014 19:55:35 GMT Joel Sherrill [e81fe6d] * c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/spi/spi_init.c (modified) powerpc/gen83xx: Fix unused variable warnings Mon, 13 Oct 2014 19:50:12 GMT Joel Sherrill [cba474e] * c/src/lib/libbsp/m68k/ods68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/console/console.c (modified) * c/src/lib/libbsp/m68k/ods68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/ods68302/start/reset.S (modified) * c/src/lib/libbsp/m68k/ods68302/startup/gdb-hooks.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/m68k-stub.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/memcheck.c (deleted) * c/src/lib/libbsp/m68k/ods68302/startup/trace.c (modified) m68k/ods68302: Fix warnings Mon, 13 Oct 2014 19:10:11 GMT Joel Sherrill [d6236971] * c/src/lib/libbsp/arm/gp32/startup/bspstart.c (modified) gp32/startup/bspstart.c: Fix warnings Mon, 13 Oct 2014 19:09:51 GMT Joel Sherrill [c144c09] * c/src/lib/libbsp/arm/csb336/startup/bspstart.c (modified) csb336/startup/bspstart.c: Fix warnings Mon, 13 Oct 2014 19:09:16 GMT Joel Sherrill [6da91abb] * c/src/lib/libbsp/m68k/idp/console/console.c (modified) * c/src/lib/libbsp/m68k/idp/include/bsp.h (modified) * c/src/lib/libbsp/m68k/idp/timer/timer.c (modified) m68k/idp: Fix warnings Mon, 13 Oct 2014 18:20:35 GMT Joel Sherrill [3c743901] * c/src/lib/libbsp/arm/gp32/smc/smc.c (modified) arm/gp32/smc/smc.c: Remove unused sm_ECCEncode() and sm_status() Mon, 13 Oct 2014 18:18:55 GMT Joel Sherrill [57e8a0d] * c/src/lib/libbsp/arm/gp32/smc/smc.c (modified) arm/gp32/smc/smc.c: Fix warnings and clean up Thu, 16 Oct 2014 11:41:06 GMT Sebastian Huber [c52384a] * c/src/lib/libbsp/powerpc/qoriq/console/console-config.c (modified) bsp/qoriq: Fix warnings Wed, 15 Oct 2014 14:31:03 GMT Joel Sherrill [e6386f7] * c/src/lib/libbsp/h8300/h8sim/Makefile.am (modified) * c/src/lib/libbsp/h8300/h8sim/configure.ac (modified) * c/src/lib/libbsp/h8300/h8sim/start/start.S (modified) h8300/h8sim: Exit simulator cleanly Wed, 15 Oct 2014 14:26:07 GMT Joel Sherrill [85c533b] * c/src/lib/libbsp/h8300/h8sim/startup/__main.c (deleted) h8300/h8sim/startup/__main.c: Removed. Obsolete remnant of COFF. Mon, 13 Oct 2014 13:19:12 GMT Sebastian Huber [116ef2e9] * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/console/console-config.c (modified) * c/src/lib/libbsp/arm/shared/arm-pl011.c (modified) * c/src/lib/libbsp/arm/shared/arm-pl050.c (modified) * c/src/lib/libbsp/arm/shared/include/arm-pl011.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-pl050.h (modified) bsps/arm: Convert PL011 and PL050 console drivers Use Termios ... Fri, 10 Oct 2014 16:43:08 GMT Hesham ALMatary [393e8ea] * c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c (modified) * c/src/lib/libbsp/or1k/or1ksim/console/uart.c (modified) libbsp/or1ksim: Fix warnings. Mon, 13 Oct 2014 19:25:47 GMT Gedare Bloom [fcc1d157] * c/src/lib/libbsp/sparc64/niagara/startup/m5op.h (modified) sparc64: use null in empty argument list Mon, 13 Oct 2014 19:24:31 GMT Gedare Bloom [b7d32736] * c/src/lib/libbsp/sparc64/shared/console/conscfg.c (modified) sparc64: make local functions static in conscfg Mon, 13 Oct 2014 19:21:14 GMT Gedare Bloom [a0f27360] * c/src/lib/libbsp/sparc64/shared/console/conscfg.c (modified) * c/src/lib/libbsp/sparc64/shared/helenos/boot/include/ofw.h (modified) sparc64: fix warnings for ofw function calls Mon, 13 Oct 2014 19:07:10 GMT Gedare Bloom [2d7029d5] * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/shared/startup/bsppredriverhook.c (deleted) * c/src/lib/libbsp/sparc64/shared/startup/bspstart.c (deleted) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libcpu/sparc64/Makefile.am (modified) * c/src/lib/libcpu/sparc64/shared/interrupts/installisrentries.c (deleted) * c/src/lib/libcpu/sparc64/shared/score/cpu.c (modified) sparc64: remove sparc64_install_isr_entries and its callers. ... Mon, 13 Oct 2014 16:47:10 GMT Joel Sherrill [c7d8be5] * c/src/lib/libbsp/mips/rbtx4938/start/start.S (modified) mips/rbtx4938/start/start.S: Fix nested comment Mon, 13 Oct 2014 16:46:57 GMT Joel Sherrill [635119b] * c/src/lib/libbsp/mips/rbtx4925/start/start.S (modified) mips/rbtx4925/start/start.S: Fix nested comment Mon, 13 Oct 2014 16:12:37 GMT Joel Sherrill [54560d3] * c/src/lib/libbsp/h8300/h8sim/make/custom/h8sxsim-testsuite.tcfg (modified) h8sxsim-testsuite.tcfg: Disable capture test - uses too many task ... Mon, 13 Oct 2014 00:17:29 GMT Joel Sherrill [a5222b65] * c/src/lib/libbsp/mips/shared/gdbstub/mips-stub.c (modified) mips/gdbstub: Fix warnings Mon, 13 Oct 2014 00:17:11 GMT Joel Sherrill [2dac965] * c/src/lib/libbsp/mips/genmongoosev/console/conscfg.c (modified) * c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c (modified) * c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.h (modified) * c/src/lib/libbsp/mips/genmongoosev/include/bsp.h (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/gdb-support.c (modified) mips/genmongoosev: Fix warnings Mon, 13 Oct 2014 00:16:33 GMT Joel Sherrill [a36094f] * c/src/lib/libbsp/shared/umon/monlib.c (modified) * c/src/lib/libbsp/shared/umon/tfsDriver.c (modified) * c/src/lib/libbsp/shared/umon/umon.h (modified) libbsp/shared/umon: Fix warnings Sun, 12 Oct 2014 22:39:59 GMT Joel Sherrill [d9c12bb] * c/src/lib/libbsp/m68k/mcf5225x/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/startup/init5225x.c (modified) m68k/mcf5225x: Fix warnings Sun, 12 Oct 2014 21:05:01 GMT Joel Sherrill [99a7f55] * c/src/lib/libbsp/m32c/m32cbsp/timer/timer.c (modified) m32c/m32csim/timer/timer.c: Fix warnings Sun, 12 Oct 2014 20:48:12 GMT Joel Sherrill [5b6438a] * c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c (modified) * c/src/lib/libbsp/i386/shared/comm/i386-stub.c (modified) * c/src/lib/libbsp/i386/shared/comm/uart.c (modified) * c/src/lib/libbsp/i386/shared/comm/uart.h (modified) libbsp/i386/shared/comm: Fix warnings Sun, 12 Oct 2014 20:22:27 GMT Joel Sherrill [ff8922c] * c/src/lib/libbsp/arm/gba/console/conio.c (modified) * c/src/lib/libbsp/arm/gba/console/console.c (modified) arm/gba/console: Fix warnings and clean up Sun, 12 Oct 2014 19:10:00 GMT Joel Sherrill [5ad38eac] * c/src/lib/libbsp/powerpc/shared/clock/clock.c (modified) powerpc/shared/clock/clock.c: Remove clock major/minor and clean up Sun, 12 Oct 2014 19:09:37 GMT Joel Sherrill [5fdb72a0] * c/src/lib/libbsp/no_cpu/no_bsp/clock/ckinit.c (modified) no_cpu/no_bsp/clock/ckinit.c: Remove clock major/minor and clean up Sun, 12 Oct 2014 19:09:12 GMT Joel Sherrill [45666bc7] * c/src/lib/libbsp/m68k/mrm332/clock/ckinit.c (modified) m68k/mrm332/clock/ckinit.c: Remove clock major/minor and clean up Sun, 12 Oct 2014 19:01:44 GMT Joel Sherrill [12966a0b] * c/src/lib/libbsp/powerpc/virtex5/include/bsp.h (modified) powerpc/virtex5/include/bsp.h: Add prototypes to fix warnings Sun, 12 Oct 2014 19:01:26 GMT Joel Sherrill [a820a5e] * c/src/lib/libbsp/powerpc/score603e/include/bsp.h (modified) powerpc/score603e/include/bsp.h: Add prototypes to fix warnings Sun, 12 Oct 2014 19:01:12 GMT Joel Sherrill [42aca8b] * c/src/lib/libbsp/powerpc/psim/include/bsp.h (modified) powerpc/psim/include/bsp.h: Add prototypes to fix warnings Sun, 12 Oct 2014 19:00:53 GMT Joel Sherrill [11c1657a] * c/src/lib/libbsp/lm32/shared/clock/ckinit.c (modified) * c/src/lib/libbsp/lm32/shared/console/console.c (modified) libbsp/lm32/shared: Fix warnings Sun, 12 Oct 2014 18:58:23 GMT Joel Sherrill [48f8a98f] * c/src/lib/libbsp/sparc64/shared/clock/ckinit.c (modified) sparc64/shared/clock/ckinit.c: Fix warnings Sun, 12 Oct 2014 18:58:23 GMT Joel Sherrill [459ddfc0] * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) sparc/erc32/clock/ckinit.c: Fix warnings Sun, 12 Oct 2014 18:58:22 GMT Joel Sherrill [e8db6d0] * c/src/lib/libbsp/powerpc/shared/clock/p_clock.c (modified) powerpc/shared/clock/p_clock.c: Fix warnings Sun, 12 Oct 2014 18:58:22 GMT Joel Sherrill [250a867f] * c/src/lib/libbsp/nios2/nios2_iss/clock/clock.c (modified) nios2/nios2_iss/clock/clock.c: Fix warnings Sun, 12 Oct 2014 18:58:22 GMT Joel Sherrill [d6d213b] * c/src/lib/libbsp/lm32/shared/milkymist_clock/ckinit.c (modified) lm32/shared/milkymist_clock/ckinit.c: Fix warnings Sun, 12 Oct 2014 18:58:22 GMT Joel Sherrill [6077804] * c/src/lib/libbsp/lm32/lm32_evr/include/bsp.h (modified) lm32/lm32_evr/include/bsp.h: Fix warnings Sun, 12 Oct 2014 18:57:28 GMT Joel Sherrill [ee0ea5bf] * c/src/lib/libbsp/powerpc/tqm8xx/clock/p_clock.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/include/bsp.h (modified) powerpc/tqm8xx: Fix warnings Sun, 12 Oct 2014 15:07:07 GMT Joel Sherrill [9ca6799] * c/src/lib/libbsp/powerpc/shared/console/console.c (modified) * c/src/lib/libbsp/powerpc/shared/console/uart.c (modified) powerpc/shared/console: Fix warnings Sun, 12 Oct 2014 15:06:47 GMT Joel Sherrill [59888da] * c/src/lib/libbsp/powerpc/haleakala/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c (modified) powerpc/haleakala: Fix warnings Sun, 12 Oct 2014 15:06:05 GMT Joel Sherrill [cd1b0404] * c/src/lib/libbsp/m68k/sim68000/clock/clockdrv.c (modified) sim68000/clock/clockdrv.c: Fix warnings Sun, 12 Oct 2014 15:06:05 GMT Joel Sherrill [b3f86763] * c/src/lib/libbsp/m68k/ods68302/clock/ckinit.c (modified) ods68302/clock/ckinit.c: Fix warnings Sun, 12 Oct 2014 15:06:05 GMT Joel Sherrill [6d44a3e] * c/src/lib/libbsp/m68k/mvme167/clock/ckinit.c (modified) mvme167/clock/ckinit.c: Fix warnings Sun, 12 Oct 2014 15:06:05 GMT Joel Sherrill [88867e89] * c/src/lib/libbsp/m68k/mvme162/clock/ckinit.c (modified) mvme162/clock/ckinit.c: Fix warnings Sun, 12 Oct 2014 15:06:05 GMT Joel Sherrill [7bddaa3c] * c/src/lib/libbsp/m68k/mvme147/clock/ckinit.c (modified) mvme147/clock/ckinit.c: Fix warnings Sun, 12 Oct 2014 15:06:05 GMT Joel Sherrill [d1347a37] * c/src/lib/libbsp/m68k/idp/clock/ckinit.c (modified) idp/clock/ckinit.c: Fix warnings Sun, 12 Oct 2014 15:06:05 GMT Joel Sherrill [8a442b5] * c/src/lib/libbsp/m68k/gen68340/clock/ckinit.c (modified) gen68340/clock/ckinit.c: Fix warnings Sun, 12 Oct 2014 15:06:05 GMT Joel Sherrill [767164a] * c/src/lib/libbsp/m68k/gen68302/clock/ckinit.c (modified) gen68302/clock/ckinit.c: Fix warnings Sun, 12 Oct 2014 14:12:18 GMT Joel Sherrill [0f9dd74] * c/src/lib/libbsp/m68k/uC5282/clock/clock.c (modified) * c/src/lib/libbsp/m68k/uC5282/include/bsp.h (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/init5282.c (modified) m68k/uC5282: Fix warnings Sun, 12 Oct 2014 13:38:49 GMT Joel Sherrill [958ed38] * c/src/lib/libbsp/powerpc/mvme5500/GT64260/MVME5500I2C.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/vectors/exceptionhandler.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/vme/VMEConfig.h (modified) powerpc/mvme5500: Fix warnings Sun, 12 Oct 2014 13:38:32 GMT Joel Sherrill [1ec8b829] * c/src/lib/libbsp/powerpc/mvme3100/startup/misc.c (modified) powerpc/mvme3100/startup/misc.c: Fix warnings Sun, 12 Oct 2014 13:31:32 GMT Joel Sherrill [888fadaf] * c/src/lib/libbsp/i386/pc386/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/pc386/console/inch.c (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/shared/comm/i386-stub.c (modified) * c/src/lib/libbsp/i386/shared/comm/uart.c (modified) * c/src/lib/libbsp/i386/shared/irq/irq_init.c (modified) i386/pc386: Clean up and fix warnings Sat, 11 Oct 2014 23:34:23 GMT Joel Sherrill [12579b2d] * c/src/lib/libbsp/sparc/leon2/cchip/cchip.c (modified) * c/src/lib/libbsp/sparc/leon2/console/console.c (modified) * c/src/lib/libbsp/sparc/leon2/console/debugputs.c (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon2/leon_open_eth/leon_open_eth.c (modified) * c/src/lib/libbsp/sparc/leon2/pci/pci.c (modified) * c/src/lib/libbsp/sparc/leon2/rasta/rasta.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/bsppredriver.c (modified) * c/src/lib/libbsp/sparc/shared/can/grcan_rasta.c (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_rasta.c (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_rasta.c (modified) sparc/leon2: Fix warnings Sun, 12 Oct 2014 00:10:17 GMT Joel Sherrill [ee2c3b6] * c/src/lib/libbsp/shared/dummy_printk_support.c (modified) libbsp/shared/dummy_printk_support.c: Fix warning Sun, 12 Oct 2014 00:09:52 GMT Joel Sherrill [66402ef2] * c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme136/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme136/timer/timer.c (modified) m68k/mvme136: Fix warnings Sun, 12 Oct 2014 13:54:17 GMT Joel Sherrill [d08e1320] * c/src/lib/libbsp/m68k/uC5282/console/console.c (modified) m68k/uC5282/console/console.c: Eliminate unused debug methods Sun, 12 Oct 2014 13:53:46 GMT Joel Sherrill [d5e533d] * c/src/lib/libbsp/m68k/mcf5329/console/console.c (modified) m68k/mcf5329/console/console.c: Eliminate unused debug methods Sun, 12 Oct 2014 13:53:15 GMT Joel Sherrill [b1c89d25] * c/src/lib/libbsp/m68k/mcf5235/console/console.c (modified) m68k/mcf5235/console/console.c: Eliminate unused debug methods Sun, 12 Oct 2014 13:52:58 GMT Joel Sherrill [ce1ba304] * c/src/lib/libbsp/m68k/genmcf548x/console/console.c (modified) m68k/genmcf548x/console/console.c: Eliminate unused debug methods Sun, 12 Oct 2014 13:52:31 GMT Joel Sherrill [575c12c1] * c/src/lib/libbsp/m68k/av5282/console/console.c (modified) m68k/av5282/console/console.c: Eliminate unused debug methods Sat, 11 Oct 2014 23:48:17 GMT Joel Sherrill [91e4946f] * c/src/lib/libbsp/powerpc/shared/startup/pretaskinghook.c (modified) powerpc/shared/startup/pretaskinghook.c: Include Sat, 11 Oct 2014 23:47:47 GMT Joel Sherrill [780cfea] * c/src/lib/libbsp/powerpc/beatnik/startup/bspreset.c (modified) powerpc/beatnik/startup/bspreset.c: Include Sat, 11 Oct 2014 23:47:33 GMT Joel Sherrill [6ae1142] * c/src/lib/libbsp/powerpc/mvme5500/startup/bspreset.c (modified) powerpc/mvme5500/startup/bspreset.c: Include Sat, 11 Oct 2014 23:47:14 GMT Joel Sherrill [d9931b7] * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/bspreset.c (modified) powerpc/motorola_powerpc/startup/bspreset.c: Include Sat, 11 Oct 2014 23:46:38 GMT Joel Sherrill [907a4706] * c/src/lib/libbsp/mips/malta/startup/bspreset.c (modified) mips/malta/startup/bspreset.c: Include Sat, 11 Oct 2014 23:46:32 GMT Joel Sherrill [f4f011f] * c/src/lib/libbsp/mips/csb350/startup/bspreset.c (modified) mips/csb350/startup/bspreset.c: Include Sat, 11 Oct 2014 23:46:13 GMT Joel Sherrill [d3c8245f] * c/src/lib/libbsp/arm/smdk2410/startup/bspreset.c (modified) arm/smdk2410/startup/bspreset.c: Include Sat, 11 Oct 2014 23:46:04 GMT Joel Sherrill [b184c41] * c/src/lib/libbsp/arm/rtl22xx/startup/bspreset.c (modified) arm/rtl22xx/startup/bspreset.c: Include Sat, 11 Oct 2014 23:45:57 GMT Joel Sherrill [22ed84bc] * c/src/lib/libbsp/arm/gumstix/startup/bspreset.c (modified) arm/gumstix/startup/bspreset.c: Include Sat, 11 Oct 2014 23:45:47 GMT Joel Sherrill [10eac0e] * c/src/lib/libbsp/arm/gp32/startup/bspreset.c (modified) arm/gp32/startup/bspreset.c: Include Sat, 11 Oct 2014 23:45:39 GMT Joel Sherrill [47240f2] * c/src/lib/libbsp/arm/gba/startup/bspreset.c (modified) arm/gba/startup/bspreset.c: Include Sat, 11 Oct 2014 23:45:32 GMT Joel Sherrill [c0662b6] * c/src/lib/libbsp/arm/edb7312/startup/bspreset.c (modified) arm/edb7312/startup/bspreset.c: Include Sat, 11 Oct 2014 23:44:50 GMT Joel Sherrill [7748d8d] * c/src/lib/libbsp/arm/csb337/startup/bspreset.c (modified) arm/csb337/startup/bspreset.c: Include Thu, 09 Oct 2014 21:40:20 GMT Joel Sherrill [4abbc567] * c/src/lib/libbsp/powerpc/shared/bootloader/bootldr.h (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/em86.c (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/lib.c (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/misc.c (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/mm.c (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/pci.c (modified) * c/src/lib/libbsp/powerpc/shared/console/polled_io.c (modified) powerpc bootloader: Remove warnings This code is shared by multiple ... Mon, 13 Oct 2014 15:31:22 GMT Joel Sherrill [a869b37a] * c/src/lib/libbsp/powerpc/score603e/irq/irq_init.c (modified) powerpc/score603e/irq/irq_init.c: Clean up Mon, 13 Oct 2014 15:30:09 GMT Joel Sherrill [d7760ac] * c/src/lib/libbsp/shared/vmeUniverse/VMEDMA.h (modified) * c/src/lib/libbsp/shared/vmeUniverse/bspVmeDmaList.c (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeUniverse.c (modified) libbsp/shared/vmeUniverse: Fix warnings Mon, 13 Oct 2014 15:29:44 GMT Joel Sherrill [fb252a68] * c/src/lib/libbsp/powerpc/shared/pci/pci.h (modified) * c/src/lib/libbsp/powerpc/shared/startup/pgtbl_activate.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/pgtbl_setup.c (modified) * c/src/lib/libbsp/powerpc/shared/vme/vmeconfig.c (modified) libbsp/powerpc/shared: Fix warnings Mon, 13 Oct 2014 15:28:44 GMT Joel Sherrill [7a4c4f4] * c/src/lib/libbsp/powerpc/ep1a/console/mc68360_scc.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/printk_support.c (modified) * c/src/lib/libbsp/powerpc/ep1a/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/ep1a/irq/openpic_xxx_irq.c (modified) * c/src/lib/libbsp/powerpc/ep1a/pci/no_host_bridge.c (modified) * c/src/lib/libbsp/powerpc/ep1a/vme/VMEConfig.h (modified) powerpc/ep1a: Fix warnings Mon, 13 Oct 2014 14:11:02 GMT Sebastian Huber [2faaf4b] * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) bsps/arm: Move abort stack Move abort stack above the other ... Thu, 09 Oct 2014 20:35:10 GMT Joel Sherrill [ef4c461] * c/src/lib/libbsp/arm/nds/Makefile.am (modified) * c/src/lib/libbsp/arm/nds/block/block.c (modified) * c/src/lib/libbsp/arm/nds/console/console.c (modified) * c/src/lib/libbsp/arm/nds/coproc/coproc.c (modified) * c/src/lib/libbsp/arm/nds/include/bsp.h (modified) * c/src/lib/libbsp/arm/nds/irq/irq.c (modified) * c/src/lib/libbsp/arm/nds/irq/irq.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_efa2.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_fcsr.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3cf.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3sd.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_mpcf.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_njsd.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_nmmc.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_sccf.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_scsd.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm7/touch.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/boxtest.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/console.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/gurumeditation.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/initSystem.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/ndsmotion.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/video.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/videoGL.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/common/card.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/common/gbfs.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/common/interrupts.c (modified) * c/src/lib/libbsp/arm/nds/preinstall.am (modified) * c/src/lib/libbsp/arm/nds/rtc/rtc.c (modified) * c/src/lib/libbsp/arm/nds/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/nds/touchscreen/parser.c (modified) * c/src/lib/libbsp/arm/nds/touchscreen/reco.c (modified) * c/src/libchip/serial/ns16550.c (modified) arm/nds: Warning clean up This patch eliminates most of the ... Thu, 09 Oct 2014 20:15:55 GMT Joel Sherrill [e160e41] * c/src/lib/libbsp/powerpc/ep1a/console/m68360.h (modified) * c/src/lib/libbsp/powerpc/ep1a/console/mc68360_scc.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/polled_io.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/rsPMCQ1.c (modified) * c/src/lib/libbsp/powerpc/ep1a/irq/openpic_xxx_irq.c (modified) * c/src/lib/libbsp/powerpc/ep1a/startup/bspstart.c (modified) powerpc/ep1a: Remove if 0 sections There may be useful nuggets for ... Thu, 09 Oct 2014 18:38:59 GMT Joel Sherrill [cc7c922] * c/src/lib/libbsp/powerpc/ep1a/console/alloc360.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/m68360.h (modified) * c/src/lib/libbsp/powerpc/ep1a/console/mc68360_scc.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/ns16550cfg.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/ns16550cfg.h (modified) * c/src/lib/libbsp/powerpc/ep1a/console/rsPMCQ1.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/rsPMCQ1.h (modified) * c/src/lib/libbsp/powerpc/ep1a/startup/bspstart.c (modified) powerpc/ep1a: Fix multiple warnings Thu, 09 Oct 2014 17:56:18 GMT Joel Sherrill [4977f07e] * c/src/lib/libbsp/i386/pc386/console/conscfg.c (modified) * c/src/lib/libbsp/i386/pc386/console/keyboard.c (modified) * c/src/lib/libbsp/i386/pc386/console/outch.c (modified) * c/src/lib/libbsp/i386/pc386/console/rtd316.c (modified) * c/src/lib/libbsp/i386/pc386/console/rtd316.h (modified) * c/src/lib/libbsp/i386/pc386/ide/ide.c (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) * c/src/lib/libbsp/i386/shared/comm/i386-stub.c (modified) i386/pc386: Eliminate multiple warnings
