# # ChangeLog for c/src/lib/libbsp in rtems # # Generated by Trac 1.2.1.dev0 # 05/03/24 14:00:10 Thu, 30 Jul 1998 21:26:25 GMT Joel Sherrill [a47bca7c] * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) Changed comment to be more polite. Thu, 30 Jul 1998 21:26:11 GMT Joel Sherrill [8e992e1] * c/src/lib/libbsp/powerpc/dmv177/README.net (modified) Updating to make more readable. Thu, 30 Jul 1998 19:41:46 GMT Joel Sherrill [1aa4186] * c/src/lib/libbsp/powerpc/dmv177/timer/timer.c (modified) Spacing corrected. Thu, 30 Jul 1998 19:41:41 GMT Joel Sherrill [1a256e3] * c/src/lib/libbsp/powerpc/dmv177/README.net (added) New file based on email from DY-4 technical support. Thu, 30 Jul 1998 19:26:47 GMT Joel Sherrill [1c5f4e1] * c/src/lib/libbsp/powerpc/dmv177/QUIRKS (modified) Fixed spacing. Thu, 30 Jul 1998 19:25:54 GMT Joel Sherrill [8751f800] * c/src/lib/libbsp/powerpc/dmv177/README (modified) Updated to accurately reflect the dmv177. Thu, 30 Jul 1998 16:07:54 GMT Joel Sherrill [7fd8641] * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/include/chain.h (deleted) Made chain.h shared Thu, 30 Jul 1998 16:05:14 GMT Joel Sherrill [3fdde4ce] * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (modified) * c/src/lib/libbsp/shared/tod.h (moved) Made tod.h shared Wed, 29 Jul 1998 00:38:51 GMT Joel Sherrill [02733a96] * c/src/lib/libbsp/shared/tod.c (added) New file. Based on merged of shared libchip style console.c and the ... Wed, 29 Jul 1998 00:38:14 GMT Joel Sherrill [acac0e8] * c/src/lib/libbsp/shared/console.c (modified) Cleaned up comment. Modified open so it uses a local variable ... Wed, 29 Jul 1998 00:37:37 GMT Joel Sherrill [6a0f5ac2] * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (modified) Added reference to shared TOD driver. Wed, 29 Jul 1998 00:17:01 GMT Joel Sherrill [ee306fd] * c/src/lib/libbsp/powerpc/dmv177/tod/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/todcfg.c (modified) Corrected to reflect the ICM7170 which is really on this board. Wed, 29 Jul 1998 00:16:44 GMT Joel Sherrill [55dcdfd] * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (modified) Added config.c and deleted tod.c. Wed, 29 Jul 1998 00:16:32 GMT Joel Sherrill [e74735b2] * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) Simplified RTC base address. Wed, 29 Jul 1998 00:16:11 GMT Joel Sherrill [5217d5a] * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) Changed cast on RTC address and added base address of RTC fields as ... Tue, 28 Jul 1998 23:16:34 GMT Joel Sherrill [9968efb] * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/config.c (added) * c/src/lib/libbsp/powerpc/dmv177/tod/tod.c (deleted) * c/src/lib/libbsp/powerpc/dmv177/tod/todcfg.c (added) First cut at configuration table for libchip RTC. At this point, we ... Sat, 25 Jul 1998 17:34:41 GMT Joel Sherrill [5752f930] * c/src/lib/libbsp/shared/console.c (added) New file -- copied from dmv177 but same as ppcn_60x. Sat, 25 Jul 1998 16:16:10 GMT Joel Sherrill [3d2c161] * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) Removed "if 0" used to switch between serial ports. Sat, 25 Jul 1998 14:50:07 GMT Joel Sherrill [a3c9f0d] * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/console.c (deleted) Moved console.c to libbsp/shared. Fri, 24 Jul 1998 16:18:39 GMT Joel Sherrill [03c0961] * c/src/lib/libbsp/m68k/gen68340/console/console.c (modified) Patch from David Fiddes : Here's a small ... Fri, 24 Jul 1998 16:09:51 GMT Joel Sherrill [dbab462] * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/network/network.c (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/irq/irq_init.c (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * make/leaf.cfg (modified) Patch from Eric Valette and Emmanuel Raguet ... Thu, 23 Jul 1998 22:13:10 GMT Joel Sherrill [dbaf51a] * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/wd80x3.h (added) * c/src/lib/libbsp/i386/pc386/network/Makefile.in (added) * c/src/lib/libbsp/i386/pc386/network/network.c (added) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * make/custom/pc386.cfg (modified) Patch from Emmanuel Raguet : Here is a ... Thu, 23 Jul 1998 22:02:34 GMT Joel Sherrill [67a2288] * Makefile.in (modified) * c/Makefile.in (modified) * c/src/exec/score/cpu/i386/cpu.c (modified) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/exec/score/cpu/i386/cpu_asm.s (modified) * c/src/exec/score/cpu/i386/i386.h (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/console/inch.c (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/start/start.s (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.s (modified) * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) * c/src/lib/libbsp/i386/shared/Makefile.in (added) * c/src/lib/libbsp/i386/shared/irq/Makefile.in (added) * c/src/lib/libbsp/i386/shared/irq/idt.c (added) * c/src/lib/libbsp/i386/shared/irq/irq.c (added) * c/src/lib/libbsp/i386/shared/irq/irq.h (added) * c/src/lib/libbsp/i386/shared/irq/irq_asm.h (added) * c/src/lib/libbsp/i386/shared/irq/irq_asm.s (added) * c/src/lib/libbsp/i386/shared/irq/irq_init.c (added) * c/src/lib/libcpu/i386/Makefile.in (added) * c/src/lib/libcpu/i386/cpu.c (added) * c/src/lib/libcpu/i386/cpu.h (added) * c/src/lib/libcpu/i386/cpu_asm.S (added) * c/src/lib/libcpu/i386/idt.c (added) * c/src/lib/libcpu/i386/wrapup/Makefile.in (added) * c/src/lib/wrapup/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * cpukit/score/cpu/i386/cpu.c (modified) Patch from Eric VALETTE : Here is a ... Thu, 23 Jul 1998 19:32:01 GMT Joel Sherrill [c91e032] * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) Removed consolex from build list. This file should be obsoleted by ... Sat, 18 Jul 1998 18:44:12 GMT Joel Sherrill [bced36d] * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) Changed so we could test interrupts on port 3. Sat, 18 Jul 1998 18:35:07 GMT Joel Sherrill [3652929e] * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) Removed use of data port for z8530. Tested all four ports. MC68681 ... Sat, 18 Jul 1998 18:34:04 GMT Joel Sherrill [91f16d5] * c/src/lib/libbsp/powerpc/dmv177/QUIRKS (added) New file Sat, 18 Jul 1998 17:47:50 GMT Joel Sherrill [a4d34dd2] * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) Added z85c30 specific probe routine to decide what the clock rate ... Sat, 18 Jul 1998 17:46:33 GMT Joel Sherrill [f8a5d54e] * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) Addresses for SCC were wrong. A and B ports were swapped. Deleted ... Sat, 18 Jul 1998 16:56:16 GMT Joel Sherrill [c53e1df4] * c/src/lib/libbsp/powerpc/dmv177/cable.doc (modified) Swapped RX and TX since doing this makes the lights blink on the ... Sat, 18 Jul 1998 16:11:13 GMT Joel Sherrill [fe05ec5e] * c/src/lib/libbsp/powerpc/dmv177/cable.doc (modified) Added RS-422 converter information and cable building information. Sat, 18 Jul 1998 15:34:03 GMT Joel Sherrill [cc3d33ac] * c/src/lib/libbsp/powerpc/dmv177/cable.doc (modified) Added information on the MC68681. Sat, 18 Jul 1998 15:24:14 GMT Joel Sherrill [f7d6e57] * c/src/lib/libbsp/powerpc/dmv177/cable.doc (modified) Added background and setup to add section on RS-422. Sat, 18 Jul 1998 15:23:56 GMT Joel Sherrill [f77670be] * c/src/lib/libbsp/powerpc/dmv177/startup/genpvec.c (modified) Reworked to removed dependency on DY-4 CSS ROM monitor interface. Sat, 18 Jul 1998 15:23:24 GMT Joel Sherrill [e286479] * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) Removed css_iface. Sat, 18 Jul 1998 15:22:54 GMT Joel Sherrill [6d4062f] * c/src/lib/libbsp/powerpc/dmv177/css_iface/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/css_iface/css_iface.c (deleted) Removed. We are no longer dependent on DY-4 CSS interface code. Sat, 18 Jul 1998 15:19:28 GMT Joel Sherrill [cce1200e] * c/src/lib/libbsp/powerpc/dmv177/cable.doc (added) New file. Fri, 17 Jul 1998 15:43:42 GMT Joel Sherrill [8123c635] * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (modified) Added scitab directory. Fri, 17 Jul 1998 15:19:04 GMT Joel Sherrill [bdba552f] * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (added) Patch fromalf Corsepius : * ... Wed, 15 Jul 1998 23:58:08 GMT Joel Sherrill [4a11d8c] * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) Fixed typo in which last port did not get switched to default ... Wed, 15 Jul 1998 23:55:04 GMT Joel Sherrill [670d037] * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/mc68681cfg.c (deleted) * c/src/lib/libbsp/powerpc/dmv177/console/mc68681cfg.h (deleted) * c/src/lib/libbsp/powerpc/dmv177/console/z85c30cfg.c (deleted) * c/src/lib/libbsp/powerpc/dmv177/console/z85c30cfg.h (deleted) Switched to usign the default z8530 and mc68681 register access routines. Wed, 15 Jul 1998 21:43:28 GMT Joel Sherrill [8a2e9c41] * c/src/lib/libbsp/powerpc/dmv177/scv64/scv64.c (modified) Added SCV64_Get_Interrupt_Enable(). Added proper headers to routines. Wed, 15 Jul 1998 21:43:00 GMT Joel Sherrill [d0cff6dc] * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) Added SCV64_Get_Interrupt_Enable(). Wed, 15 Jul 1998 21:42:26 GMT Joel Sherrill [38e717f] * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) Added chip type identifier field. This was necessary because a ... Wed, 15 Jul 1998 19:28:29 GMT Joel Sherrill [0f61336] * c/src/lib/libbsp/powerpc/dmv177/console/console.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/z85c30cfg.c (modified) Added comments. Wed, 15 Jul 1998 19:20:20 GMT Joel Sherrill [a69f0ad9] * c/src/lib/libbsp/powerpc/dmv177/startup/setvec.c (modified) Added comments. Wed, 15 Jul 1998 19:19:14 GMT Joel Sherrill [100a4e5] * c/src/lib/libbsp/powerpc/dmv177/startup/genpvec.c (modified) Masked out interrupts not being used prior to processing the status ... Wed, 15 Jul 1998 19:12:11 GMT Joel Sherrill [6c45da17] * c/src/lib/libbsp/powerpc/dmv177/scv64/scv64.c (modified) Added routine to return interrupt mask. Added comments. Wed, 15 Jul 1998 14:06:37 GMT Joel Sherrill [01e54b8] * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) Added scv64 subdirectory. Wed, 15 Jul 1998 14:06:08 GMT Joel Sherrill [e49ef37c] * c/src/lib/libbsp/powerpc/dmv177/startup/genpvec.c (modified) Switched to SCV64. Wed, 15 Jul 1998 14:05:51 GMT Joel Sherrill [8f563b9b] * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) Added CSCV64 functions and addresses. Wed, 15 Jul 1998 14:04:31 GMT Joel Sherrill [30a3f76] * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) Switched from polling to interrupts and in the process added a ... Wed, 15 Jul 1998 14:00:23 GMT Joel Sherrill [437b5a7d] * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) Added scv64 subdirectory. Wed, 15 Jul 1998 14:00:09 GMT Joel Sherrill [090a3511] * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.in (added) * c/src/lib/libbsp/powerpc/dmv177/scv64/scv64.c (added) New files. Fri, 10 Jul 1998 15:43:18 GMT Joel Sherrill [dbfa3148] * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/console/inch.c (modified) * c/src/lib/libbsp/i386/pc386/startup/exit.c (modified) Patch from Quality Quorum . Comments: ... Thu, 09 Jul 1998 22:59:32 GMT Joel Sherrill [11c6a92d] * c/src/lib/libbsp/powerpc/dmv177/startup/bspclean.c (modified) Commented out the system call invocation since we don't know what ... Thu, 09 Jul 1998 22:59:13 GMT Joel Sherrill [a6e36dff] * c/src/lib/libbsp/powerpc/dmv177/start/start.s (modified) Removed call back to exit() since that has already been called. Thu, 09 Jul 1998 18:50:13 GMT Joel Sherrill [2ba0a0c2] * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) Corrected z85c30 address and clock constants. Thu, 09 Jul 1998 18:49:49 GMT Joel Sherrill [459c1d2] * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) Added board specific baud rate table and set driver function table ... Tue, 07 Jul 1998 16:38:18 GMT Joel Sherrill [030ff417] * c/src/lib/libbsp/sparc/erc32/console/console.c (modified) Conditionals for CONSOLE_USE_INTERRUPTS should have been "if" not ... Mon, 06 Jul 1998 18:44:32 GMT Joel Sherrill [a90b990] * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.in (added) Missed this file in the initial merge. Mon, 06 Jul 1998 14:52:30 GMT Joel Sherrill [b5bb3d6] * c/src/lib/libbsp/m68k/gen68340/README (modified) * c/src/lib/libbsp/m68k/gen68340/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68340/start/startfor340only.s (modified) * c/src/lib/libbsp/m68k/gen68340/start340/startfor340only.s (modified) * c/src/lib/libbsp/m68k/gen68340/timer/timer.c (modified) Update from Geoffroy Montel (g_montel@yahoo.com) to get in sync with ... Sun, 05 Jul 1998 11:01:21 GMT Joel Sherrill [bc2ebb4] * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) Added some address constants for the SCC and DUART to make it easier ... Sun, 05 Jul 1998 11:00:57 GMT Joel Sherrill [e7ff2b2] * c/src/lib/libbsp/powerpc/dmv177/console/config.c (added) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (added) New file added in the process of converting the console driver to ... Sun, 05 Jul 1998 11:00:00 GMT Joel Sherrill [92a6454] * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/console.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/debugio.c (added) * c/src/lib/libbsp/powerpc/dmv177/console/duart.c (deleted) * c/src/lib/libbsp/powerpc/dmv177/console/mc68681cfg.c (added) * c/src/lib/libbsp/powerpc/dmv177/console/mc68681cfg.h (added) * c/src/lib/libbsp/powerpc/dmv177/console/z85c30cfg.c (added) * c/src/lib/libbsp/powerpc/dmv177/console/z85c30cfg.h (added) Converted the console driver to use libchip/serial and added support ... Thu, 02 Jul 1998 18:07:09 GMT Joel Sherrill [0e8c2000] * c/src/lib/libbsp/m68k/gen68340/start/startfor340only.s (added) * c/src/lib/libbsp/m68k/gen68340/start340/startfor340only.s (added) Renamed old_start340.s to startfor340only.s Wed, 01 Jul 1998 22:03:20 GMT Joel Sherrill [132f194] * c/src/lib/libbsp/m68k/gen68340/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/README (added) * c/src/lib/libbsp/m68k/gen68340/bsp_specs (added) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/clock/ckinit.c (added) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/console/Modif_cpu_asm.s (added) * c/src/lib/libbsp/m68k/gen68340/console/console.c (added) * c/src/lib/libbsp/m68k/gen68340/console/m340uart.c (added) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/include/bsp.h (added) * c/src/lib/libbsp/m68k/gen68340/include/coverhd.h (added) * c/src/lib/libbsp/m68k/gen68340/include/m340timer.h (added) * c/src/lib/libbsp/m68k/gen68340/include/m340uart.h (added) * c/src/lib/libbsp/m68k/gen68340/include/m68340.h (added) * c/src/lib/libbsp/m68k/gen68340/include/m68340.inc (added) * c/src/lib/libbsp/m68k/gen68340/include/m68349.inc (added) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/start/start340.s (added) * c/src/lib/libbsp/m68k/gen68340/start340/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/start340/start340.s (added) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/startup/bspclean.c (added) * c/src/lib/libbsp/m68k/gen68340/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/gen68340/startup/dumpanic.c (added) * c/src/lib/libbsp/m68k/gen68340/startup/init68340.c (added) * c/src/lib/libbsp/m68k/gen68340/startup/linkcmds (added) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/timer/timer.c (added) * make/custom/gen68340.cfg (added) Initial submission of gen68340 BSP (should run on a 68349) from ... Mon, 29 Jun 1998 17:51:50 GMT Joel Sherrill [dc95ee8d] * c/src/lib/libbsp/powerpc/psim/console/console.c (modified) Changed prototype for console_write_support to eliminate a warning. Sat, 27 Jun 1998 20:01:28 GMT Joel Sherrill [cf65c408] * README.configure (modified) * c/PROBLEMS (modified) * c/src/lib/libbsp/bare/README (modified) * c/src/lib/libbsp/bare/build-tools (added) * c/src/lib/libbsp/bare/do-bare-bsp-build (added) Bare BSP patch from Chris Johns . He also ... Sat, 27 Jun 1998 18:51:49 GMT Joel Sherrill [5d18fb0] * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/bsp_specs (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/console/inch.c (modified) * c/src/lib/libbsp/i386/pc386/console/outch.c (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/start/start.s (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/exit.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.s (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/bin2boot.c (modified) * c/src/lib/libbsp/i386/pc386/tools/binpatch.c (added) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * make/custom/pc386.cfg (modified) * tools/build/binpatch.c (added) PC386 BSP enhancements from Aleksey Romanov (Quality Quorum ... Sat, 27 Jun 1998 17:09:47 GMT Joel Sherrill [98100d2] * Makefile.in (modified) * aclocal.m4 (modified) * aclocal/ar-s.m4 (added) * aclocal/canonicalize-tools.m4 (modified) * aclocal/cygwin.m4 (added) * aclocal/exeext.m4 (added) * aclocal/gcc-pipe.m4 (modified) * aclocal/gcc-specs.m4 (modified) * c/PROBLEMS (modified) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/src/Makefile.in (modified) * c/src/exec/score/tools/generic/size_rtems.in (modified) * c/src/lib/libbsp/i386/pc386/tools/bin2boot.c (modified) * c/src/lib/libbsp/m68k/idp/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme162/console/console.c (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/make/README (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/host.cfg.in (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * make/README (modified) * make/compilers/gcc-no_bsp.cfg (modified) * make/compilers/gcc-portsw.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/bare.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/go32.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/simhppa.cfg (modified) * make/host.cfg.in (modified) * make/target.cfg.in (modified) * tools/build/scripts/Makefile.in (modified) * tools/build/src/Makefile.in (modified) * tools/cpu/generic/size_rtems.in (modified) Monstrous patch from Ralf Corsepius . I ... Thu, 25 Jun 1998 18:42:30 GMT Joel Sherrill [d13b247] * c/src/lib/libbsp/i386/pc386/start/start16.s (modified) Clean up from Aleksey Romanov (Quality Quorum ). ... Mon, 22 Jun 1998 10:15:14 GMT Joel Sherrill [547de5d] * c/src/lib/libbsp/powerpc/dmv177/console/duart.c (modified) Removed blank lines and bad debug stuff Thu, 18 Jun 1998 15:13:29 GMT Joel Sherrill [bdb1057] * c/src/lib/libbsp/sparc/erc32/console/console.c (modified) Spacing changes. Tue, 16 Jun 1998 19:06:35 GMT Joel Sherrill [fe52766e] * c/src/lib/libbsp/powerpc/dmv177/css_iface/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/css_iface/css_iface.c (modified) Corrected compilation problems. Tue, 16 Jun 1998 19:05:50 GMT Joel Sherrill [8bf6095] * c/src/lib/libbsp/powerpc/dmv177/startup/genpvec.c (modified) Added initialization of css routines. Tue, 16 Jun 1998 18:22:54 GMT Joel Sherrill [1efeb61] * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/css_iface/Makefile.in (added) * c/src/lib/libbsp/powerpc/dmv177/css_iface/css_iface.c (added) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) Added css_iface -- assumes ../include/dy_supplied. Sat, 13 Jun 1998 13:34:09 GMT Joel Sherrill [23f5cdb5] * c/src/lib/libbsp/powerpc/dmv177/startup/genpvec.c (modified) Adding interrupt handling routine. Sat, 13 Jun 1998 13:34:08 GMT Joel Sherrill [510524c6] * c/src/lib/libbsp/powerpc/dmv177/startup/bspstart.c (modified) Removed bad comments. Sat, 13 Jun 1998 13:33:38 GMT Joel Sherrill [8d830755] * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) Added IRQ information. Sat, 13 Jun 1998 13:33:11 GMT Joel Sherrill [a12d7fd7] * c/src/lib/libbsp/powerpc/dmv177/bsp_specs (modified) Updated to add -qrtems_debug and -qnolinkcmds. Thu, 04 Jun 1998 13:08:02 GMT Joel Sherrill [70b0d66] * c/src/lib/libbsp/i386/go32/bsp_specs (modified) Added support for -qrtems_debug flag. Wed, 03 Jun 1998 19:01:21 GMT Joel Sherrill [ea57368] * c/src/lib/libbsp/powerpc/psim/timer/timer.c (modified) Removed PPC_Get_timebase_register() as this is now provided by the ... Wed, 03 Jun 1998 19:00:57 GMT Joel Sherrill [3c7916f] * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/start16.s (modified) Update from Pedro Romano with an ... Wed, 03 Jun 1998 18:47:44 GMT Joel Sherrill [5184958] * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/bin2boot.c (added) Update from Pedro Romano which replaces ... Sat, 30 May 1998 16:01:12 GMT Joel Sherrill [2785eab2] * c/src/lib/libbsp/powerpc/dmv177/clock/clock.c (modified) Changed calculaction for Clock_Decrementer_value to use the ... Sat, 30 May 1998 15:58:37 GMT Joel Sherrill [95a683b] * c/src/lib/libbsp/powerpc/dmv177/console/console.c (modified) Set console to port 2. Changed #if defined to a #if check for ... Sat, 30 May 1998 15:55:46 GMT Joel Sherrill [a874427] * c/src/lib/libbsp/powerpc/dmv177/include/bsp.h (modified) Made Debug defination a null routine. Sat, 30 May 1998 15:53:19 GMT Joel Sherrill [b317117a] * c/src/lib/libbsp/powerpc/dmv177/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/linkcmds (modified) clicks_per_usec had to be cut in half (unknown reason). fixed ... Sat, 30 May 1998 11:46:21 GMT Joel Sherrill [dc104a4] * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/clock.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/console.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/duart.c (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/start.s (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/genpvec.c (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/setvec.c (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/timer.c (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/tod.c (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) * make/custom/dmv177.cfg (modified) Updated to current source and removed warnings. Sat, 30 May 1998 10:42:01 GMT Joel Sherrill [a38b9f8] * c/src/lib/libbsp/powerpc/dmv177/startup/sbrk.c (deleted) Used shared sbrk.c. Sat, 30 May 1998 10:41:21 GMT Joel Sherrill [825a2bb] * c/src/lib/libbsp/powerpc/dmv177/startup/rtems-ctor.cc (deleted) Use shared initialization. Sat, 30 May 1998 10:32:19 GMT Joel Sherrill [55b517c] * c/src/lib/libbsp/powerpc/dmv177/startup/bspclean.c (added) * c/src/lib/libbsp/powerpc/dmv177/startup/bspclean.s (deleted) Rewrote in C to avoid Makefile problems. Sat, 30 May 1998 10:09:14 GMT Joel Sherrill [c932d85] * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (added) * c/src/lib/libbsp/powerpc/dmv177/README (added) * c/src/lib/libbsp/powerpc/dmv177/STATUS (added) * c/src/lib/libbsp/powerpc/dmv177/bsp_specs (added) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (added) * c/src/lib/libbsp/powerpc/dmv177/clock/clock.c (added) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (added) * c/src/lib/libbsp/powerpc/dmv177/console/console.c (added) * c/src/lib/libbsp/powerpc/dmv177/console/duart.c (added) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (added) * c/src/lib/libbsp/powerpc/dmv177/include/bsp.h (added) * c/src/lib/libbsp/powerpc/dmv177/include/chain.h (added) * c/src/lib/libbsp/powerpc/dmv177/include/coverhd.h (added) * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (added) * c/src/lib/libbsp/powerpc/dmv177/include/tod.h (added) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (added) * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.c (added) * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.h (added) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.in (added) * c/src/lib/libbsp/powerpc/dmv177/start/start.s (added) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (added) * c/src/lib/libbsp/powerpc/dmv177/startup/bspclean.s (added) * c/src/lib/libbsp/powerpc/dmv177/startup/bspstart.c (added) * c/src/lib/libbsp/powerpc/dmv177/startup/genpvec.c (added) * c/src/lib/libbsp/powerpc/dmv177/startup/linkcmds (added) * c/src/lib/libbsp/powerpc/dmv177/startup/rtems-ctor.cc (added) * c/src/lib/libbsp/powerpc/dmv177/startup/sbrk.c (added) * c/src/lib/libbsp/powerpc/dmv177/startup/setvec.c (added) * c/src/lib/libbsp/powerpc/dmv177/startup/vmeintr.c (added) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (added) * c/src/lib/libbsp/powerpc/dmv177/timer/timer.c (added) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (added) * c/src/lib/libbsp/powerpc/dmv177/tod/tod.c (added) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (added) New files -- from rtems-LM-980406 which was based on an RTEMS from ... Wed, 27 May 1998 22:09:47 GMT Joel Sherrill [1278ea1] * c/src/lib/libbsp/i386/pc386/startup/ldsegs.s (modified) Deleted blank lines. Wed, 27 May 1998 22:09:39 GMT Joel Sherrill [bb6d368] * c/src/lib/libbsp/i386/pc386/start/start.s (modified) Added "speaker on" debug code. Wed, 27 May 1998 19:34:37 GMT Joel Sherrill [4050a7f] * c/src/lib/libbsp/i386/pc386/start/start.s (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.s (modified) Numerous changes including the following: + DEBUG_EARLY_START ... Wed, 27 May 1998 19:24:57 GMT Joel Sherrill [339cc25] * c/src/lib/libbsp/i386/pc386/startup/exit.c (modified) Moved rtemsReboot() to console/inch.c. Wed, 27 May 1998 19:20:55 GMT Joel Sherrill [a92adc6] * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) Deleted HEAP_SIZE constant. Wed, 27 May 1998 19:20:38 GMT Joel Sherrill [37eacd7] * c/src/lib/libbsp/i386/pc386/console/videoAsm.s (modified) Removed illegally formatted comments.
