# # ChangeLog for c/src/lib/libbsp in rtems # # Generated by Trac 1.2.1.dev0 # 05/19/24 16:14:21 Wed, 30 Nov 2005 02:21:11 GMT Till Straumann [5b8eb3f0] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/shared/vectors/vectors.S (modified) 2005-11-29 Till Straumann ... Wed, 30 Nov 2005 01:22:48 GMT Till Straumann [2b370444] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq.c (modified) 2005-11-29 Till Straumann ... Tue, 29 Nov 2005 18:47:05 GMT Till Straumann [8c6579b] * c/src/lib/libbsp/powerpc/shared/startup/pretaskinghook.c (modified) - trivial correction in comment Tue, 22 Nov 2005 03:21:26 GMT Ralf Corsepius [5367a6e] * c/src/lib/libbsp/arm/csb336/ChangeLog (modified) * c/src/lib/libbsp/arm/csb336/bsp_specs (modified) * c/src/lib/libbsp/arm/csb337/ChangeLog (modified) * c/src/lib/libbsp/arm/csb337/bsp_specs (modified) * c/src/lib/libbsp/arm/gba/ChangeLog (modified) * c/src/lib/libbsp/arm/gba/bsp_specs (modified) * c/src/lib/libbsp/arm/gp32/ChangeLog (modified) * c/src/lib/libbsp/arm/gp32/bsp_specs (modified) 2005-11-22 Ralf Corsepius * ... Sun, 13 Nov 2005 05:38:34 GMT Ralf Corsepius [15ec224] * c/src/lib/libbsp/mips/csb350/ChangeLog (modified) * c/src/lib/libbsp/mips/csb350/bsp_specs (modified) 2005-11-13 Ralf Corsepius * ... Sun, 13 Nov 2005 05:17:24 GMT Ralf Corsepius [17e451a] * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/bsp_specs (modified) 2005-11-13 Ralf Corsepius * ... Sat, 12 Nov 2005 07:21:23 GMT Ralf Corsepius [bf221c5] * c/src/lib/libbsp/m68k/csb360/ChangeLog (modified) * c/src/lib/libbsp/m68k/csb360/bsp_specs (modified) * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/bsp_specs (modified) 2005-11-12 Ralf Corsepius * ... Sat, 12 Nov 2005 07:08:33 GMT Ralf Corsepius [bcd0867d] * c/src/lib/libbsp/m68k/av5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/av5282/bsp_specs (modified) * c/src/lib/libbsp/m68k/av5282/console/console.c (modified) 2005-11-12 Ralf Corsepius * ... Sat, 12 Nov 2005 07:04:49 GMT Ralf Corsepius [b1a0917] * c/src/lib/libbsp/arm/csb336/ChangeLog (modified) * c/src/lib/libbsp/arm/csb336/bsp_specs (modified) * c/src/lib/libbsp/arm/csb337/ChangeLog (modified) * c/src/lib/libbsp/arm/csb337/bsp_specs (modified) * c/src/lib/libbsp/arm/gba/ChangeLog (modified) * c/src/lib/libbsp/arm/gba/bsp_specs (modified) * c/src/lib/libbsp/arm/gp32/ChangeLog (modified) * c/src/lib/libbsp/arm/gp32/bsp_specs (modified) 2005-11-12 Ralf Corsepius * ... Sat, 12 Nov 2005 05:26:25 GMT Ralf Corsepius [cea62b21] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) 2005-11-12 Ralf Corsepius * ... Fri, 11 Nov 2005 15:48:24 GMT Eric Norum [46fa1f64] * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/README (modified) * c/src/lib/libbsp/m68k/uC5282/console/console.c (modified) Clean up UART2 pin setup. Protect pin setup code. Wed, 09 Nov 2005 17:23:35 GMT Eric Norum [0cf20a9] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) Need to install vme_am_defs.h. Wed, 09 Nov 2005 16:53:30 GMT Ralf Corsepius [ac3a37d7] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) 2005-11-09 Ralf Corsepius * ... Wed, 09 Nov 2005 16:51:26 GMT Ralf Corsepius [c29d03e9] * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeUniverse.c (modified) 2005-11-09 Ralf Corsepius * ... Wed, 09 Nov 2005 16:38:33 GMT Eric Norum [d5b3fe52] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds (modified) Fix disagreement between GCCSPECS and GCC_SPECS. Tue, 08 Nov 2005 20:11:02 GMT Eric Norum [8e6835a5] * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/console/console.c (modified) Add code to set up pin assignments. Tue, 08 Nov 2005 10:46:29 GMT Ralf Corsepius [347733c4] * c/src/lib/libbsp/arm/gba/ChangeLog (modified) 2005-11-08 Ralf Corsepius * ... Tue, 08 Nov 2005 10:46:19 GMT Ralf Corsepius [b07b75f] * c/src/lib/libbsp/arm/gba/irq/irq.c (modified) * c/src/lib/libbsp/arm/gba/startup/bspstart.c (modified) Remove obsolete types (*unsigned32). Mon, 07 Nov 2005 17:30:17 GMT Eric Norum [91c832b9] * c/src/lib/libbsp/m68k/uC5282/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/uC5282/start/start.S (modified) Remove assignation to U.S. Government. Mon, 07 Nov 2005 17:22:23 GMT Eric Norum [12b36efe] * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/clock/clock.c (modified) * c/src/lib/libbsp/m68k/uC5282/console/console.c (modified) * c/src/lib/libbsp/m68k/uC5282/include/bsp.h (modified) * c/src/lib/libbsp/m68k/uC5282/include/tm27.h (modified) * c/src/lib/libbsp/m68k/uC5282/network/network.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/init5282.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/uC5282/timer/timer.c (modified) Assign copyright to OAR since all files descend from OAR's source. Mon, 07 Nov 2005 16:19:21 GMT Joel Sherrill [086c1c3] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libcpu/arm/ChangeLog (modified) * c/src/lib/libcpu/mips/ChangeLog (modified) * cpukit/score/cpu/powerpc/ChangeLog (modified) * testsuites/ChangeLog (modified) Fixed formatting. Mon, 07 Nov 2005 15:36:31 GMT Joel Sherrill [fb08bd92] * c/src/lib/libbsp/powerpc/ChangeLog (modified) Repaired some changelog entries lost. Mon, 07 Nov 2005 06:26:45 GMT Ralf Corsepius [cb98129] * c/src/lib/libbsp/m68k/mcf5235/ChangeLog (modified) 2005-11-07 Ralf Corsepius * ... Mon, 07 Nov 2005 06:26:37 GMT Ralf Corsepius [71a7ed0] * c/src/lib/libbsp/m68k/av5282/include/bsp.h (modified) * c/src/lib/libbsp/m68k/av5282/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mcf5235/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5235/startup/bspstart.c (modified) Eliminate unsigned32. Mon, 07 Nov 2005 06:26:08 GMT Ralf Corsepius [8fd9e978] * c/src/lib/libbsp/m68k/mcf5235/console/console.c (modified) Eliminate unsigned32, unsigned8. Mon, 07 Nov 2005 06:23:24 GMT Ralf Corsepius [e3996e2b] * c/src/lib/libbsp/m68k/av5282/ChangeLog (modified) 2005-11-07 Ralf Corsepius * ... Mon, 07 Nov 2005 06:23:14 GMT Ralf Corsepius [9ab9f026] * c/src/lib/libbsp/m68k/av5282/network/network.c (modified) Several minor bug fixes. Sun, 06 Nov 2005 08:32:36 GMT Ralf Corsepius [f2535df] * c/src/lib/libbsp/i386/ChangeLog (modified) 2005-11-06 Ralf Corsepius * ... Sun, 06 Nov 2005 08:32:13 GMT Ralf Corsepius [4d90b98e] * c/src/lib/libbsp/i386/shared/irq/idt.c (modified) Reflect API changes. Sun, 06 Nov 2005 06:25:30 GMT Ralf Corsepius [1fdeb22] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) 2005-11-06 Ralf Corsepius * ... Sun, 06 Nov 2005 06:25:07 GMT Ralf Corsepius [3e21ecf] * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) Remove C++-style comments. Fri, 04 Nov 2005 08:17:56 GMT Till Straumann [784e792] * c/src/lib/libbsp/ChangeLog (modified) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/shared/vmeUniverse/README.universe (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148.c (added) * c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148.h (added) * c/src/lib/libbsp/shared/vmeUniverse/vmeUniverse.c (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeUniverse.h (modified) * c/src/lib/libbsp/shared/vmeUniverse/vme_am_defs.h (added) 2005-11-04 Till Straumann ... Fri, 04 Nov 2005 08:10:42 GMT Till Straumann [6d3ff66f] * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/vme/vmeconfig.c (modified) * c/src/lib/libbsp/powerpc/shared/vme/README (added) * c/src/lib/libbsp/powerpc/shared/vme/VME.h (modified) * c/src/lib/libbsp/powerpc/shared/vme/VMEConfig.h (modified) * c/src/lib/libbsp/powerpc/shared/vme/vme_universe.c (added) * c/src/lib/libbsp/powerpc/shared/vme/vmeconfig.c (modified) 2005-11-03 Till Straumann ... Fri, 04 Nov 2005 06:14:26 GMT Till Straumann [c4423933] * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/include/bsp.h (modified) 2005-11-03 Till Straumann ... Fri, 04 Nov 2005 04:03:31 GMT Till Straumann [94c31843] * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/irq/irq.h (modified) 2005-11-03 Till Straumann ... Fri, 04 Nov 2005 03:44:13 GMT Till Straumann [896cacf] * c/src/lib/libbsp/i386/ChangeLog (modified) Added reference to PR#832 Fri, 04 Nov 2005 03:43:10 GMT Till Straumann [758ee5c] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) corrected redundant PR number Fri, 04 Nov 2005 03:34:08 GMT Till Straumann [98afe31] * c/src/lib/libbsp/powerpc/shared/motorola/motorola.c (modified) * c/src/lib/libbsp/powerpc/shared/pci/detect_raven_bridge.c (modified) * c/src/lib/libbsp/powerpc/shared/pci/pci.c (modified) * c/src/lib/libbsp/powerpc/shared/pci/pci.h (modified) * c/src/lib/libbsp/powerpc/shared/pci/pcifinddevice.c (modified) 2005-11-03 Till Straumann ... Fri, 04 Nov 2005 03:31:10 GMT Till Straumann [cca22863] * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/include/bsp.h (modified) 2005-11-03 Till Straumann ... Fri, 04 Nov 2005 03:25:22 GMT Till Straumann [0de2f239] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) Added reference to PR#838 Fri, 04 Nov 2005 03:20:29 GMT Till Straumann [dc0f6585] * c/src/lib/libbsp/powerpc/shared/console/reboot.c (modified) * c/src/lib/libbsp/powerpc/shared/start/start.S (modified) 2005-11-03 * ... Fri, 04 Nov 2005 01:39:45 GMT Till Straumann [8c9fffd] * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/shared/irq/openpic_i8259_irq.c (added) 2005-11-03 * ... Fri, 04 Nov 2005 01:00:33 GMT Till Straumann [be45f8e] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/bsp.h (modified) 2005-11-03 * Makefile.am, ... Fri, 04 Nov 2005 00:57:25 GMT Till Straumann [ab20575] * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/pretaskinghook.c (added) * c/src/lib/libbsp/powerpc/shared/startup/zerobss.c (added) 2005-11-03 * ... Fri, 04 Nov 2005 00:23:28 GMT Till Straumann [f3173c0] * c/src/lib/libbsp/powerpc/mvme5500/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/psim/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/shared/console/uart.c (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq.h (modified) 2005-11-03 * ... Thu, 03 Nov 2005 22:14:59 GMT Till Straumann [0ac68b0] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) 2005-11-03 straumanatslacdotstanforddotedu * ... Thu, 03 Nov 2005 22:13:43 GMT Till Straumann [b6e3ee54] * c/src/lib/libbsp/powerpc/shared/vectors/vectors.S (modified) 2005-11-03 straumanatslacdotstanforddotedu * ... Thu, 03 Nov 2005 21:39:33 GMT Till Straumann [9a76deb5] * c/src/lib/libbsp/powerpc/ChangeLog (modified) 2005-11-03 straumanatslacdotstanforddotedu * ... Thu, 03 Nov 2005 21:38:36 GMT Till Straumann [7e2dcde] * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/start/preload.S (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/linkcmds (deleted) 2005-11-03 straumanatslacdotstanforddotedu * ... Thu, 03 Nov 2005 21:35:09 GMT Till Straumann [4ef2fd43] * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/linkcmds (deleted) 2005-11-03 straumanatslacdotstanforddotedu * ... Thu, 03 Nov 2005 21:35:08 GMT Till Straumann [d45540a] * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds (added) 2005-11-03 straumanatslacdotstanforddotedu * ... Thu, 03 Nov 2005 19:14:54 GMT Till Straumann [e156c633] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/misc.c (modified) * c/src/lib/libbsp/powerpc/shared/console/polled_io.c (modified) * c/src/lib/libbsp/powerpc/shared/residual/residual.c (modified) 2005-11-03 straumanatslacdotstanforddotedu * ... Thu, 03 Nov 2005 14:55:33 GMT Ralf Corsepius [ef9e015] * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c (modified) 2005-11-03 Ralf Corsepius ... Thu, 03 Nov 2005 02:59:18 GMT Till Straumann [05a2cc4b] * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/shared/pci/pcibios.c (modified) 2005-11-02 straumanatslacdotstanford.edu * ... Thu, 03 Nov 2005 02:58:09 GMT Till Straumann [ebedf31] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) 2005-11-02 straumanatslacdotstanford.edu * ... Thu, 03 Nov 2005 01:57:27 GMT Till Straumann [ec58ea04] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mvme5500/start/start.S (modified) * c/src/lib/libbsp/powerpc/shared/start/start.S (modified) 2005-11-02 straumanatslacdotstanford.edu * ... Wed, 26 Oct 2005 14:56:58 GMT Eric Norum [21dd4cf8] * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/README (modified) * c/src/lib/libbsp/m68k/uC5282/network/network.c (modified) Allow network to be locked at 100/Full. Thu, 20 Oct 2005 21:41:49 GMT Joel Sherrill [fab9046] * c/src/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/shared/ChangeLog (modified) Fix formatting. Thu, 20 Oct 2005 18:38:26 GMT Eric Norum [cc2fcc1] * c/src/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/shared/pci/detect_raven_bridge.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/shared/vme/VMEConfig.h (modified) * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeUniverse.c (modified) * c/src/libchip/network/dec21140.c (modified) Numerous changes and cleanups to support MVME2100. Mon, 17 Oct 2005 12:47:51 GMT Ralf Corsepius [5c786ff7] * c/src/lib/libbsp/i386/i386ex/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.am (modified) Add pci.rel to librtemsbsp.a Mon, 17 Oct 2005 12:38:54 GMT Ralf Corsepius [7e9874b] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) Cosmetics. Mon, 17 Oct 2005 12:38:24 GMT Ralf Corsepius [7a9c410] * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.am (modified) 2005-10-17 Ralf Corsepius * ... Mon, 17 Oct 2005 10:34:22 GMT Ralf Corsepius [939ae4c] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) 2005-10-17 Ralf Corsepius * ... Mon, 17 Oct 2005 10:34:02 GMT Ralf Corsepius [cba119c9] * c/src/lib/libbsp/i386/pc386/console/fb_vga.h (modified) * c/src/lib/libbsp/i386/pc386/console/kd.h (modified) * c/src/lib/libbsp/i386/pc386/console/ps2_drv.h (modified) * c/src/lib/libbsp/i386/pc386/console/serial_mouse.c (modified) * c/src/lib/libbsp/i386/pc386/console/serial_mouse.h (modified) * c/src/lib/libbsp/i386/shared/comm/i386_io.h (modified) * c/src/lib/libbsp/i386/shared/comm/tty_drv.c (modified) * c/src/lib/libbsp/i386/shared/comm/tty_drv.h (modified) Remove CVS Log Mon, 17 Oct 2005 10:31:42 GMT Ralf Corsepius [2950439] * c/src/lib/libbsp/i386/ChangeLog (modified) 2005-10-17 Ralf Corsepius * ... Mon, 17 Oct 2005 09:02:24 GMT Ralf Corsepius [d94df689] * c/src/lib/libbsp/powerpc/shared/.cvsignore (deleted) * c/src/lib/libbsp/powerpc/shared/ChangeLog (deleted) * c/src/lib/libbsp/powerpc/shared/Makefile.am (deleted) Remove Mon, 17 Oct 2005 09:01:51 GMT Ralf Corsepius [3d570dfb] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) 2005-10-17 Ralf Corsepius * ... Mon, 17 Oct 2005 08:51:36 GMT Ralf Corsepius [1ebfc5af] * c/src/lib/libbsp/m68k/shared/.cvsignore (deleted) * c/src/lib/libbsp/m68k/shared/ChangeLog (deleted) * c/src/lib/libbsp/m68k/shared/Makefile.am (deleted) Remove. Mon, 17 Oct 2005 08:51:06 GMT Ralf Corsepius [6fdf978] * c/src/lib/libbsp/m68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) 2005-10-17 Ralf Corsepius * ... Mon, 17 Oct 2005 08:45:46 GMT Ralf Corsepius [dd2c72af] * c/src/lib/libbsp/arm/gba/Makefile.am (modified) Regenerate. Mon, 17 Oct 2005 08:34:46 GMT Ralf Corsepius [6b346ca] * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) 2005-10-17 Ralf Corsepius * ... Mon, 17 Oct 2005 08:04:01 GMT Ralf Corsepius [8d62d94a] * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.am (modified) 2005-10-17 Ralf Corsepius * ... Mon, 17 Oct 2005 08:00:27 GMT Ralf Corsepius [578209bc] * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/configure.ac (modified) 2005-10-16 Ralf Corsepius * ... Mon, 17 Oct 2005 07:59:54 GMT Ralf Corsepius [e4752eb7] * c/src/lib/libbsp/i386/shared/.cvsignore (deleted) * c/src/lib/libbsp/i386/shared/ChangeLog (deleted) * c/src/lib/libbsp/i386/shared/Makefile.am (deleted) Remove. Sun, 16 Oct 2005 08:34:06 GMT Ralf Corsepius [1b7e802b] * c/src/lib/libbsp/c4x/ChangeLog (modified) * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) 2005-10-16 Ralf Corsepius * ... Sun, 16 Oct 2005 08:33:22 GMT Ralf Corsepius [79d172ab] * c/src/lib/libbsp/sparc/shared/.cvsignore (deleted) * c/src/lib/libbsp/sparc/shared/ChangeLog (deleted) * c/src/lib/libbsp/sparc/shared/Makefile.am (deleted) Remove. Sun, 16 Oct 2005 08:29:14 GMT Ralf Corsepius [ddc94069] * c/src/lib/libbsp/c4x/configure.ac (modified) Remove shared/Makefile.am. Sun, 16 Oct 2005 08:28:54 GMT Ralf Corsepius [39c0e675] * c/src/lib/libbsp/c4x/Makefile.am (modified) Merge-in shared/Makefile.am. Sun, 16 Oct 2005 08:28:16 GMT Ralf Corsepius [3224b76] * c/src/lib/libbsp/c4x/shared/.cvsignore (deleted) * c/src/lib/libbsp/c4x/shared/ChangeLog (deleted) * c/src/lib/libbsp/c4x/shared/Makefile.am (deleted) Remove. Sun, 16 Oct 2005 08:23:26 GMT Ralf Corsepius [6432910] * c/src/lib/libbsp/arm/ChangeLog (modified) 2005-10-16 Ralf Corsepius * ... Sun, 16 Oct 2005 07:42:32 GMT Ralf Corsepius [c0cbdab] * c/src/lib/libbsp/arm/ChangeLog (modified) Merge-in shared/ChangeLog. Sun, 16 Oct 2005 07:42:14 GMT Ralf Corsepius [e952e15] * c/src/lib/libbsp/arm/configure.ac (modified) Remove shared/Makefile.am Sun, 16 Oct 2005 07:41:51 GMT Ralf Corsepius [94011ca] * c/src/lib/libbsp/arm/Makefile.am (modified) Merge-in shared/Makefile.am. Sun, 16 Oct 2005 07:41:07 GMT Ralf Corsepius [b4156a3] * c/src/lib/libbsp/arm/shared/.cvsignore (deleted) * c/src/lib/libbsp/arm/shared/ChangeLog (deleted) * c/src/lib/libbsp/arm/shared/Makefile.am (deleted) Remove. Sun, 16 Oct 2005 07:30:45 GMT Ralf Corsepius [7836c1e5] * c/src/lib/libbsp/sh/ChangeLog (modified) 2005-10-16 Ralf Corsepius * ... Sun, 16 Oct 2005 07:30:31 GMT Ralf Corsepius [9f5382d] * c/src/lib/libbsp/sh/configure.ac (modified) Remove shared/Makefile.am. Sun, 16 Oct 2005 07:30:12 GMT Ralf Corsepius [a3e2358] * c/src/lib/libbsp/sh/Makefile.am (modified) Merge-in shared/Makefile.am. Sun, 16 Oct 2005 07:29:31 GMT Ralf Corsepius [4237e5e] * c/src/lib/libbsp/sh/shared/.cvsignore (deleted) * c/src/lib/libbsp/sh/shared/ChangeLog (deleted) * c/src/lib/libbsp/sh/shared/Makefile.am (deleted) Remove. Thu, 06 Oct 2005 19:36:41 GMT Joel Sherrill [384ba756] * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/shared/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq_asm.S (modified) 2005-10-06 Till Straumann ... Wed, 05 Oct 2005 00:31:35 GMT Joel Sherrill [da6ce58f] * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) Remove comments not really for 4.6 branch. Thu, 29 Sep 2005 11:34:57 GMT Joel Sherrill [2f22923] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) Added PR number. Thu, 29 Sep 2005 08:05:32 GMT Thomas Doerfler [d1572bcf] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/ide/idecfg.c (modified) 2005-09-29 Thomas Doerfler ... Mon, 19 Sep 2005 21:57:17 GMT Eric Norum [030b91e] * c/src/lib/libbsp/m68k/uC5282/startup/bspclean.c (modified) Silently return to bootstrap PROM. Mon, 19 Sep 2005 06:18:19 GMT Ralf Corsepius [240c917] * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) 2005-09-19 Ralf Corsepius * ... Mon, 19 Sep 2005 06:18:10 GMT Ralf Corsepius [f052a9b] * c/src/lib/libbsp/powerpc/mpc8260ads/network/if_hdlcsubr.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/network/network.c (modified) Include instead of . Mon, 19 Sep 2005 06:15:46 GMT Ralf Corsepius [c7179542] * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/network/network.c (modified) 2005-09-19 Ralf Corsepius * ... Mon, 19 Sep 2005 03:47:45 GMT Ralf Corsepius [8627734] * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) Correct my email address. Mon, 19 Sep 2005 03:47:16 GMT Ralf Corsepius [dbc7c79] * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) 2005-09-19 Ralf Corsepius * ... Mon, 19 Sep 2005 03:46:17 GMT Ralf Corsepius [c140041b] * c/src/lib/libbsp/i386/ts_386ex/network/ne2000.c (modified) * c/src/lib/libbsp/m68k/gen68302/network/network.c (modified) * c/src/libchip/network/if_fxp.c (modified) Include instead of . Mon, 19 Sep 2005 03:44:24 GMT Ralf Corsepius [009f4fa] * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) 2005-09-19 Ralf Corsepius * ...
