# # ChangeLog for c/src/lib/libbsp in rtems # # Generated by Trac 1.2.1.dev0 # 04/27/24 18:22:00 Fri, 19 Dec 2014 11:13:41 GMT Sebastian Huber [494df99f] * c/src/lib/libbsp/powerpc/shared/src/bsp-start-zero.S (modified) bsps/powerpc: Support for 64 byte cache lines Mon, 22 Dec 2014 06:26:19 GMT Sebastian Huber [06251bb] * c/src/lib/libbsp/shared/src/bsp-uboot-board-info.c (modified) bsps/u-boot: Add optional text and data sections Fri, 19 Dec 2014 08:00:18 GMT Sebastian Huber [b79f98f] * c/src/lib/libbsp/powerpc/shared/include/u-boot-generic-board-info.h (added) * c/src/lib/libbsp/powerpc/shared/uboot_dump_bdinfo.c (modified) * c/src/lib/libbsp/shared/include/u-boot.h (modified) bsps/u-boot: Update due to API changes Tue, 23 Dec 2014 07:28:24 GMT Sebastian Huber [2a4f9d7] * c/src/lib/libbsp/i386/shared/smp/smp-imps.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspclean.c (modified) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smp.c (modified) smp: Add and use _SMP_Should_start_processor() Sun, 14 Dec 2014 22:27:06 GMT Joel Sherrill [7cdabc49] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/console/conscfg.c (modified) * c/src/lib/libbsp/i386/pc386/console/console_edison.c (added) * c/src/lib/libbsp/i386/pc386/console/printk_support.c (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/make/custom/edison.cfg (added) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) * c/src/lib/libbsp/i386/pc386/startup/bspgetworkarea.c (modified) * c/src/lib/libbsp/i386/pc386/startup/bspreset.c (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) pc386: Add Edison base support The current support for the Edison ... Sun, 14 Dec 2014 22:02:42 GMT Joel Sherrill [1ae7baf] * c/src/lib/libbsp/shared/clock_driver_simidle.c (modified) clock_driver_simidle.c: Add BSP_CLOCK_DRIVER_DELAY This allows the ... Sun, 14 Dec 2014 22:45:08 GMT Joel Sherrill [0a36af04] * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/console/conscfg.c (modified) * c/src/lib/libbsp/i386/pc386/console/printk_support.c (modified) pc386: Add BSP_ENABLE_COM1_COM4 BSP option This allows the support ... Thu, 11 Dec 2014 21:16:34 GMT Joel Sherrill [93546b8] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) pc386: Add BSP_ENABLE_IDE BSP option This allows the IDE support to ... Thu, 11 Dec 2014 20:49:49 GMT Joel Sherrill [607c854] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/console/conscfg.c (modified) * c/src/lib/libbsp/i386/pc386/console/console_control.c (modified) * c/src/lib/libbsp/i386/pc386/console/printk_support.c (modified) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) * c/src/lib/libbsp/i386/pc386/start/start.S (modified) pc386: Add BSP_ENABLE_VGA BSP option This allows the VGA and ... Thu, 27 Nov 2014 06:39:36 GMT Nick Withers [2d5c486] * c/src/lib/libbsp/powerpc/beatnik/marvell/discovery.c (modified) * c/src/lib/libbsp/powerpc/beatnik/marvell/gt_timer.c (modified) * c/src/lib/libbsp/powerpc/beatnik/marvell/gti2c.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/if_gfe/if_gfe.c (modified) * c/src/lib/libbsp/powerpc/beatnik/network/porting/rtemscompat.h (modified) * c/src/lib/libbsp/powerpc/beatnik/pci/gt_pci_init.c (modified) * c/src/lib/libbsp/powerpc/beatnik/pci/motload_fixup.c (modified) * c/src/lib/libbsp/powerpc/beatnik/startup/bspreset.c (modified) * c/src/lib/libbsp/powerpc/ep1a/console/rsPMCQ1.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/irq/BSP_irq.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/network/if_1GHz/if_wm.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/pci/pci_interface.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/bspreset.c (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/pci.c (modified) * c/src/lib/libbsp/powerpc/shared/console/console.inl (modified) * c/src/lib/libbsp/powerpc/shared/console/uart.c (modified) * c/src/lib/libbsp/powerpc/shared/openpic/openpic.c (modified) * c/src/lib/libbsp/powerpc/shared/pci/pci.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148.c (modified) * c/src/lib/libcpu/powerpc/shared/include/io.h (modified) Use fixed-width C99 types for PowerPC in_be16() and co. Also use ... Wed, 24 Dec 2014 03:27:25 GMT Till Strauman [2573e69] * c/src/lib/libbsp/i386/shared/pci/pcibios.c (modified) pc386: scan all functions of multi-function PCI devices The ... Wed, 17 Dec 2014 07:13:46 GMT Sebastian Huber [481054e0] * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) bsp/moxiesim: Add cache manager implementation Close #2220. Mon, 15 Dec 2014 12:35:26 GMT Ben Gras [1e587f7d] * c/src/lib/libbsp/arm/beagle/clock.c (modified) * c/src/lib/libbsp/arm/beagle/irq.c (modified) * c/src/lib/libbsp/shared/console_control.c (modified) * c/src/lib/libbsp/shared/console_read.c (modified) * c/src/lib/libbsp/shared/console_write.c (modified) bsp/beagle: Fix some warnings The extra includes in console_*.c are ... Mon, 15 Dec 2014 15:42:08 GMT Joel Sherrill [b2a78a3] * c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x-testsuite.tcfg (modified) mcf5225x-testsuite.tcfg: Add fileio Mon, 15 Dec 2014 10:55:27 GMT Sebastian Huber [20aba89] * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c (modified) bsp/mpc55xxevb: Fix warnings Mon, 15 Dec 2014 10:49:10 GMT Sebastian Huber [b7cd6d51] * c/src/lib/libbsp/powerpc/t32mppc/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c (modified) bsp/t32mppc: Fix warnings Mon, 15 Dec 2014 10:26:06 GMT Sebastian Huber [5063e1a] * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc55xx.inc (modified) * c/src/lib/libbsp/powerpc/t32mppc/make/custom/t32mppc.cfg (modified) bsps/powerpc: Disable SPE for soft-float variants Mon, 15 Dec 2014 06:40:04 GMT Sebastian Huber [3acc619] * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_mzx_stage_1 (modified) bsp/lpc32xx: Fix memory map Fixes bug introduced with ... Fri, 12 Dec 2014 15:32:58 GMT Sebastian Huber [3cd3a260] * c/src/lib/libbsp/powerpc/mbx8xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/tqm8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/tqm8xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/tqm8xx/include/irq.h (modified) * c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c (modified) * c/src/lib/libcpu/powerpc/mpc8xx/clock/clock.c (modified) bsp/mpc8xx: Fix warnings close #2211 Fri, 12 Dec 2014 14:29:59 GMT Sebastian Huber [3507f3f9] * c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/network/network.c (modified) * c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc8xx/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c (modified) bsp/mpc8xx: Fix warnings close #2211 Mon, 08 Dec 2014 18:16:37 GMT Gedare Bloom [71d97c9] * c/src/lib/libbsp/sparc64/niagara/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/shared/asm/asm.S (modified) * c/src/lib/libbsp/sparc64/shared/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc64/shared/startup/setvec.c (modified) * c/src/lib/libbsp/sparc64/usiii/include/bsp.h (modified) * c/src/lib/libcpu/sparc64/shared/score/cpu.c (modified) * c/src/lib/libcpu/sparc64/shared/score/interrupt.S (modified) * c/src/lib/libcpu/sparc64/shared/syscall/sparc64-syscall.S (modified) * cpukit/score/cpu/sparc64/context.S (modified) * cpukit/score/cpu/sparc64/cpu.c (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/sparc64.h (modified) * cpukit/score/cpu/sparc64/rtems/score/types.h (modified) sparc64: put each copyright on one line Fri, 05 Dec 2014 10:07:02 GMT Sebastian Huber [4a3db517] * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) bsps/sparc: Fix trap table initialization Fixes bug introduced with ... Thu, 04 Dec 2014 09:03:50 GMT Sebastian Huber [12072880] * c/configure.ac (modified) * c/src/ada-tests/configure.ac (modified) * c/src/configure.ac (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/configure.ac (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/arm/csb336/configure.ac (modified) * c/src/lib/libbsp/arm/csb337/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/gba/configure.ac (modified) * c/src/lib/libbsp/arm/gdbarmsim/configure.ac (modified) * c/src/lib/libbsp/arm/gp32/configure.ac (modified) * c/src/lib/libbsp/arm/gumstix/configure.ac (modified) * c/src/lib/libbsp/arm/lm3s69xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc176x/configure.ac (modified) * c/src/lib/libbsp/arm/lpc24xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc32xx/configure.ac (modified) * c/src/lib/libbsp/arm/nds/configure.ac (modified) * c/src/lib/libbsp/arm/nds/tools/configure.ac (modified) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (modified) * c/src/lib/libbsp/arm/rtl22xx/configure.ac (modified) * c/src/lib/libbsp/arm/smdk2410/configure.ac (modified) * c/src/lib/libbsp/arm/stm32f4/configure.ac (modified) * c/src/lib/libbsp/arm/tms570/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/avr/avrtest/configure.ac (modified) * c/src/lib/libbsp/avr/configure.ac (modified) * c/src/lib/libbsp/bfin/TLL6527M/configure.ac (modified) * c/src/lib/libbsp/bfin/bf537Stamp/configure.ac (modified) * c/src/lib/libbsp/bfin/configure.ac (modified) * c/src/lib/libbsp/bfin/eZKit533/configure.ac (modified) * c/src/lib/libbsp/h8300/configure.ac (modified) * c/src/lib/libbsp/h8300/h8sim/configure.ac (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/lm32/configure.ac (modified) * c/src/lib/libbsp/lm32/lm32_evr/configure.ac (modified) * c/src/lib/libbsp/lm32/milkymist/configure.ac (modified) * c/src/lib/libbsp/m32c/configure.ac (modified) * c/src/lib/libbsp/m32c/m32cbsp/configure.ac (modified) * c/src/lib/libbsp/m32r/configure.ac (modified) * c/src/lib/libbsp/m32r/m32rsim/configure.ac (modified) * c/src/lib/libbsp/m68k/av5282/configure.ac (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/csb360/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68302/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/genmcf548x/configure.ac (modified) * c/src/lib/libbsp/m68k/idp/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf52235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5225x/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5329/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme136/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/ods68302/configure.ac (modified) * c/src/lib/libbsp/m68k/sim68000/configure.ac (modified) * c/src/lib/libbsp/m68k/uC5282/configure.ac (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/csb350/configure.ac (modified) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (modified) * c/src/lib/libbsp/mips/hurricane/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (modified) * c/src/lib/libbsp/mips/malta/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4925/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4938/configure.ac (modified) * c/src/lib/libbsp/moxie/configure.ac (modified) * c/src/lib/libbsp/moxie/moxiesim/configure.ac (modified) * c/src/lib/libbsp/nios2/configure.ac (modified) * c/src/lib/libbsp/nios2/nios2_iss/configure.ac (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/or1k/configure.ac (modified) * c/src/lib/libbsp/or1k/or1ksim/configure.ac (modified) * c/src/lib/libbsp/powerpc/beatnik/configure.ac (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/ep1a/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen5200/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/haleakala/configure.ac (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme3100/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme5500/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/qemuppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/score603e/configure.ac (modified) * c/src/lib/libbsp/powerpc/ss555/configure.ac (modified) * c/src/lib/libbsp/powerpc/t32mppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/tqm8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex4/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex5/configure.ac (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc64/configure.ac (modified) * c/src/lib/libbsp/sparc64/niagara/configure.ac (modified) * c/src/lib/libbsp/sparc64/usiii/configure.ac (modified) * c/src/lib/libbsp/v850/configure.ac (modified) * c/src/lib/libbsp/v850/gdbv850sim/configure.ac (modified) * c/src/lib/libcpu/arm/configure.ac (modified) * c/src/lib/libcpu/bfin/configure.ac (modified) * c/src/lib/libcpu/i386/configure.ac (modified) * c/src/lib/libcpu/lm32/configure.ac (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/mips/configure.ac (modified) * c/src/lib/libcpu/nios2/configure.ac (modified) * c/src/lib/libcpu/or1k/configure.ac (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/sh/configure.ac (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) * c/src/lib/libcpu/sparc64/configure.ac (modified) * c/src/librtems++/configure.ac (modified) * c/src/make/configure.ac (modified) * configure.ac (modified) * cpukit/configure.ac (modified) * doc/configure.ac (modified) * doc/tools/configure.ac (modified) * testsuites/configure.ac (modified) * testsuites/fstests/configure.ac (modified) * testsuites/libtests/configure.ac (modified) * testsuites/mptests/configure.ac (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtmtests/configure.ac (modified) * testsuites/rhealstone/configure.ac (modified) * testsuites/samples/configure.ac (modified) * testsuites/smptests/configure.ac (modified) * testsuites/sptests/configure.ac (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tools/configure.ac (modified) * testsuites/tools/generic/configure.ac (modified) * tools/build/configure.ac (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/nios2/configure.ac (modified) * tools/cpu/sh/configure.ac (modified) Update bug report URL Thu, 04 Dec 2014 08:38:27 GMT Sebastian Huber [e870941] * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/shared/bspinit.c (deleted) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/dummy/README (deleted) * cpukit/libmisc/dummy/default-configuration.c (added) * cpukit/libmisc/dummy/dummy.c (deleted) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/defaultconfig01/Makefile.am (added) * testsuites/libtests/defaultconfig01/defaultconfig01.doc (added) * testsuites/libtests/defaultconfig01/defaultconfig01.scn (added) * testsuites/libtests/defaultconfig01/init.c (added) libmisc: More useful default configuration The dummy.c was a ... Thu, 04 Dec 2014 17:21:11 GMT Ben Gras [13d9029] * c/src/lib/libbsp/arm/beagle/clock.c (modified) * c/src/lib/libcpu/arm/shared/include/am335x.h (modified) beagle bsp: disable watchdog on am335x On recent u-boots, the ... Wed, 03 Dec 2014 23:56:39 GMT Jan Dolezal [038e1dba] * c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c (modified) * c/src/lib/libbsp/i386/pc386/include/edid.h (modified) * c/src/lib/libbsp/i386/pc386/include/fb_vesa.h (modified) * c/src/lib/libbsp/i386/pc386/include/tblsizes.h (modified) * c/src/lib/libbsp/i386/pc386/include/vbe3.h (modified) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c (modified) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h (modified) * c/src/lib/libcpu/i386/cpu.h (modified) * cpukit/score/cpu/i386/cpu_asm.S (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) i386: doxygen and comments related to VESA real mode framebuffer Wed, 03 Dec 2014 23:56:38 GMT Jan Dolezal [d78eac6] * c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c (modified) * c/src/lib/libbsp/i386/pc386/include/edid.h (modified) * c/src/lib/libbsp/i386/pc386/include/fb_vesa.h (modified) * c/src/lib/libbsp/i386/pc386/include/tblsizes.h (modified) * c/src/lib/libbsp/i386/pc386/include/vbe3.h (modified) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c (modified) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h (modified) i386/pc386: cammelCase (struct and function names) to underscores, ... Thu, 04 Dec 2014 14:15:52 GMT Sebastian Huber [adc1dbeb] * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) bsp/leon3: Fix trap table initialization Fixes bug introduced with ... Wed, 03 Dec 2014 10:35:52 GMT Daniel Hellstrom [dff1803] * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libcpu/sparc/syscall/syscall.S (modified) * c/src/lib/libcpu/sparc/syscall/syscall.h (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * doc/cpu_supplement/sparc.t (modified) SPARC: optimize IRQ enable & disable * Coding style cleanups. * ... Tue, 02 Dec 2014 22:36:59 GMT Ben Gras [4081032] * c/src/lib/libbsp/i386/pc386/start/start.S (modified) pc386 bsp fix for default mode If USE_VBE_RM is 0, ... Thu, 30 Jan 2014 01:58:41 GMT Nick Withers [fa4fe456] * c/src/lib/libbsp/powerpc/shared/flash/flash.c (modified) Move the flash size probe into bankValidate() Previously, ... Sun, 23 Nov 2014 21:53:00 GMT Jiri Gaisler [2501814e] * c/src/lib/libbsp/sparc/leon2/include/leon.h (modified) sparc/leon2: LEON_Is_interrupt_masked for Leon2 in leon.h wrongly ... Sun, 23 Nov 2014 21:53:00 GMT Jiri Gaisler [291f30f] * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) sparc/leon3: LEON_Is_interrupt_masked for Leon3 in leon.h wrongly ... Tue, 11 Nov 2014 14:18:01 GMT Daniel Hellstrom [0d3b5d47] * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libcpu/sparc/reg_win/window.S (modified) SPARC: optimize window underflow trap Save five instructions on ... Tue, 27 May 2014 09:15:46 GMT Daniel Hellstrom [348d1812] * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libcpu/sparc/reg_win/window.S (modified) SPARC: window overflow optimization I see no need for waiting the 3 ... Mon, 01 Dec 2014 03:55:23 GMT Chris Johns [dd309b1] * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/startup/copyvectors.c (added) * c/src/lib/libbsp/m68k/mcf5235/startup/init5235.c (modified) m68k/mcf5235: GCC 4.9.2 generates invalid code for Init5235. Move ... Thu, 27 Nov 2014 13:03:34 GMT Sebastian Huber [3a8566b7] * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/include/hwreg_vals.h (deleted) * c/src/lib/libbsp/powerpc/qoriq/preinstall.am (modified) bsp/qoriq: Delete empty header file close #2062 Tue, 25 Nov 2014 07:40:20 GMT Sebastian Huber [cbc433c7] * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/include/nocache-heap.h (deleted) * c/src/lib/libbsp/arm/altera-cyclone-v/network/network.c (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/linkcmds.altcycv (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/linkcmds.altcycv_devkit (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/mmu-config.c (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/nocache-heap.c (deleted) * c/src/lib/libbsp/arm/beagle/startup/linkcmds.beagle (modified) * c/src/lib/libbsp/arm/csb336/startup/linkcmds (modified) * c/src/lib/libbsp/arm/csb337/startup/linkcmds.csb337 (modified) * c/src/lib/libbsp/arm/csb337/startup/linkcmds.csb637 (modified) * c/src/lib/libbsp/arm/edb7312/startup/linkcmds (modified) * c/src/lib/libbsp/arm/gdbarmsim/startup/linkcmds (modified) * c/src/lib/libbsp/arm/gp32/startup/linkcmds (modified) * c/src/lib/libbsp/arm/gumstix/startup/linkcmds (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/linkcmds.lm3s3749 (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/linkcmds.lm3s6965 (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/linkcmds.lm3s6965_qemu (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/linkcmds.lm4f120 (modified) * c/src/lib/libbsp/arm/lpc176x/startup/linkcmds.lpc1768_mbed (modified) * c/src/lib/libbsp/arm/lpc176x/startup/linkcmds.lpc1768_mbed_ahb_ram (modified) * c/src/lib/libbsp/arm/lpc176x/startup/linkcmds.lpc1768_mbed_ahb_ram_eth (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc17xx_ea_ram (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc17xx_ea_rom_int (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc17xx_plx800_ram (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc17xx_plx800_rom_int (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc2362 (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc23xx_tli800 (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_ea (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_ncs_ram (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_ncs_rom_ext (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_ncs_rom_int (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_plx800_ram (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_plx800_rom_int (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_mzx (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_mzx_stage_1 (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_mzx_stage_2 (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_phycore (modified) * c/src/lib/libbsp/arm/nds/startup/linkcmds (modified) * c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds.realview_pbx_a9_qemu (modified) * c/src/lib/libbsp/arm/rtl22xx/startup/linkcmds (modified) * c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h (modified) * c/src/lib/libbsp/arm/shared/include/linker-symbols.h (modified) * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/arm/smdk2410/startup/linkcmds (modified) * c/src/lib/libbsp/arm/stm32f4/startup/linkcmds.stm32f105rc (modified) * c/src/lib/libbsp/arm/stm32f4/startup/linkcmds.stm32f4 (modified) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk (modified) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_intram (modified) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_sdram (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.in (modified) bsps/arm: Add .nocache section This section can be use to provide a ... Wed, 19 Nov 2014 20:26:11 GMT Josh Oguin [61f8d668] * c/src/lib/libbsp/shared/bspinit.c (modified) libbsp/shared/bspinit.c: Document assumption of NULL returned Tue, 25 Nov 2014 07:36:58 GMT Sebastian Huber [42fe0d3] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 avoid infinite loops Mon, 24 Nov 2014 08:44:50 GMT Sebastian Huber [55db0e5] * c/src/lib/libbsp/sparc/leon3/make/custom/ngmp.cfg (modified) bsp/ngmp: Use -muser-mode GCC option This option is necessary to ... Sun, 23 Nov 2014 15:48:17 GMT Joel Sherrill [b46a31e] * c/src/lib/libbsp/sparc/leon2/console/console.c (modified) leon2: include not close #2113 Fri, 21 Nov 2014 19:11:57 GMT Joel Sherrill [ff1c613] * c/src/lib/libbsp/powerpc/haleakala/mmu/mmu_405.c (modified) * c/src/lib/libbsp/powerpc/haleakala/network/network.c (modified) powerpc/haleakala: Fix warnings Fri, 21 Nov 2014 17:15:22 GMT Nigel Spon [502609c8] * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/configure.ac (modified) * c/src/lib/libbsp/powerpc/haleakala/include/mmu_405.h (added) * c/src/lib/libbsp/powerpc/haleakala/mmu/mmu_405.c (added) * c/src/lib/libbsp/powerpc/haleakala/mmu/mmu_405asm.S (added) * c/src/lib/libbsp/powerpc/haleakala/network/network.c (added) * c/src/lib/libbsp/powerpc/haleakala/preinstall.am (modified) * c/src/lib/libcpu/powerpc/ppc403/include/ppc405ex.h (modified) * c/src/lib/libcpu/powerpc/ppc403/include/ppc405gp.h (modified) powerpc/haleakala: Add network driver close 1405 Fri, 21 Nov 2014 07:49:57 GMT Sebastian Huber [11925eef] * c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/network/if_100MHz/GT64260eth.c (modified) * c/src/libchip/ide/ata_internal.h (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/pipe/fifo.c (modified) * cpukit/libmisc/untar/untar.c (modified) * cpukit/librpc/src/rpc/svc_udp.c (modified) * cpukit/pppd/pppd.h (modified) * testsuites/psxtests/psxaio02/init.c (modified) * testsuites/psxtests/psxaio03/init.c (modified) * testsuites/samples/fileio/init.c (modified) * testsuites/sptests/sp48/init.c (modified) * testsuites/sptests/sp63/init.c (modified) Delete or rename MIN/MAX macros and defines Include ... Thu, 20 Nov 2014 16:05:02 GMT Gedare Bloom [280f4ecc] * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) autotools: regenerate preinstall.am for pc386 Thu, 20 Nov 2014 14:00:33 GMT Jan Dolezal [067da5c] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c (added) * c/src/lib/libbsp/i386/pc386/include/fb_vesa.h (added) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) * c/src/lib/libbsp/i386/pc386/start/start.S (modified) i386/pc386: VESA based frame buffer utilizing real mode interrupt 10h Thu, 20 Nov 2014 14:00:32 GMT Jan Dolezal [c5a74946] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/include/edid.h (added) * c/src/lib/libbsp/i386/pc386/include/vbe3.h (added) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) i386/pc386/include: header files for VESA BIOS EXTENSIONS and VESA ... Thu, 20 Nov 2014 14:00:31 GMT Jan Dolezal [586c86c7] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c (added) * c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h (added) i386/shared/realmode_int: real mode interrupt interface Thu, 20 Nov 2014 14:00:30 GMT Jan Dolezal [74d2d940] * c/src/lib/libbsp/i386/shared/irq/idt.c (modified) * c/src/lib/libcpu/i386/cpu.h (modified) i386: global descriptor table manipulation functions Thu, 20 Nov 2014 14:00:26 GMT Jan Dolezal [ec494ff] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/include/tblsizes.h (added) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) i386/pc386: configurable size of descriptor tables Wed, 19 Nov 2014 14:30:24 GMT Sebastian Huber [50440c0] * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/configure.ac (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspsmp.c (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspsmp.c (added) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspsmp.c (added) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstarthooks.c (modified) bsps/arm: Enable L2C for Cortex-A9 MPCore BSPs Wed, 19 Nov 2014 14:07:58 GMT Sebastian Huber [d1eb7b1] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 drop exclusive cache support Optimize locking. Wed, 19 Nov 2014 13:55:53 GMT Sebastian Huber [5f4f828] * c/src/lib/libbsp/arm/shared/include/arm-cache-l1.h (modified) bsps/arm: L1 cache support changes Wed, 19 Nov 2014 13:37:11 GMT Sebastian Huber [e492e7f8] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 compile-time errata 588369 Wed, 19 Nov 2014 13:29:27 GMT Sebastian Huber [52d24b00] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 compile-time errata 753970 Wed, 19 Nov 2014 13:19:13 GMT Sebastian Huber [55741886] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) * c/src/lib/libbsp/shared/include/fatal.h (modified) bsps/arm: L2C 310 exclusive config is fatal Wed, 19 Nov 2014 13:08:44 GMT Sebastian Huber [d53de34] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 use l2c_310_* prefix throughout Wed, 19 Nov 2014 13:05:36 GMT Sebastian Huber [861d315] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 use L2C_310_* prefix throughout Wed, 19 Nov 2014 11:24:07 GMT Sebastian Huber [f2fed0c1] * c/src/lib/libbsp/arm/altera-cyclone-v/include/bsp.h (modified) * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h (modified) * c/src/lib/libbsp/shared/include/fatal.h (modified) bsps/arm: L2C 310 add compile time checks Simplify initialization. ... Wed, 19 Nov 2014 11:07:04 GMT Sebastian Huber [13f1462f] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 delete invalid link Wed, 19 Nov 2014 11:23:02 GMT Sebastian Huber [a9d6c20] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 simplify and remove white space Wed, 19 Nov 2014 10:51:33 GMT Sebastian Huber [957c075] * c/src/lib/libbsp/arm/altera-cyclone-v/include/bsp.h (modified) * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h (modified) bsps/arm: L2C 310 rename BSP_ARM_L2CC_BASE Rename BSP_ARM_L2CC_BASE ... Mon, 10 Nov 2014 12:46:32 GMT Sebastian Huber [45a63ee] * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/i2c/cadence-i2c.c (added) * c/src/lib/libbsp/arm/xilinx-zynq/include/cadence-i2c-regs.h (added) * c/src/lib/libbsp/arm/xilinx-zynq/include/cadence-i2c.h (added) * c/src/lib/libbsp/arm/xilinx-zynq/include/i2c.h (added) * c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am (modified) bsp/xilinx-zynq: Add Cadence I2C bus driver Thu, 13 Nov 2014 09:12:32 GMT Sebastian Huber [bdf8fa76] * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstart.c (modified) bsp/xilinx-zynq: Add zync_clock_cpu_1x() Thu, 13 Nov 2014 09:15:41 GMT Sebastian Huber [234d5c40] * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/console/zynq-uart.c (modified) bsp/xilinx-zynq: Rename BSP_ARM_A9MPCORE_UARTCLK Rename ... Wed, 12 Nov 2014 13:02:53 GMT Sebastian Huber [8100e71] * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) bsp/xilinx-zynq: Adjust BSP_ARM_A9MPCORE_PERIPHCLK Wed, 12 Nov 2014 12:57:24 GMT Sebastian Huber [f0c564c] * c/src/lib/libbsp/arm/shared/startup/linkcmds.armv4 (modified) * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) bsps/arm: Adjust stacks for ARMv4 Reduce non-IRQ stacks to size ... Wed, 12 Nov 2014 13:00:05 GMT Alan Cudmore [96a9f4c] * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/shared/abort/abort.c (modified) * c/src/lib/libbsp/arm/shared/abort/abort.h (added) * c/src/lib/libbsp/arm/shared/abort/simple_abort.c (modified) ARM removed shared/abort from several ARM BSPs Wed, 05 Nov 2014 23:52:23 GMT Joel Sherrill [a373dc37] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg (modified) lpc23xx_tli800-testsuite.tcfg: Add dl02 Wed, 05 Nov 2014 23:52:05 GMT Joel Sherrill [091c610] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc2362-testsuite.tcfg (modified) lpc2362-testsuite.tcfg: Add dl02 Wed, 05 Nov 2014 23:51:43 GMT Joel Sherrill [0b91cfbf] * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg (modified) lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add a handful more tests Wed, 05 Nov 2014 21:31:36 GMT Joel Sherrill [f9e4139] * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s3749-testsuite.tcfg (modified) lm3s3749-testsuite.tcfg: Add dl02 Tue, 04 Nov 2014 21:05:08 GMT Joel Sherrill [8d74b80e] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg (modified) lpc23xx_tli800-testsuite.tcfg: Add dl01 Tue, 04 Nov 2014 21:04:46 GMT Joel Sherrill [6d84a9f] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc2362-testsuite.tcfg (modified) lpc2362-testsuite.tcfg: Add dl01 Tue, 04 Nov 2014 21:04:28 GMT Joel Sherrill [a7812cdc] * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg (modified) lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add rbheap01 Tue, 04 Nov 2014 21:02:03 GMT Joel Sherrill [643e7cb8] * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s3749-testsuite.tcfg (modified) lm3s3749-testsuite.tcfg: Add dl01 Tue, 04 Nov 2014 02:02:03 GMT Chris Johns [de5596b] * c/src/lib/libbsp/arm/beagle/preinstall.am (modified) Regenerated preinstall.am file. Mon, 03 Nov 2014 18:53:40 GMT Ben Gras [53dd6d61] * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/README (modified) * c/src/lib/libbsp/arm/beagle/README.JTAG (added) * c/src/lib/libbsp/arm/beagle/TESTING (added) * c/src/lib/libbsp/arm/beagle/clock.c (added) * c/src/lib/libbsp/arm/beagle/clock/beagle-clock-config.c (deleted) * c/src/lib/libbsp/arm/beagle/configure.ac (modified) * c/src/lib/libbsp/arm/beagle/console/console-config.c (modified) * c/src/lib/libbsp/arm/beagle/include/beagle-clock-config.h (deleted) * c/src/lib/libbsp/arm/beagle/include/beagle-timer.h (deleted) * c/src/lib/libbsp/arm/beagle/include/beagle.h (deleted) * c/src/lib/libbsp/arm/beagle/include/boot.h (deleted) * c/src/lib/libbsp/arm/beagle/include/bsp.h (modified) * c/src/lib/libbsp/arm/beagle/include/i2c.h (modified) * c/src/lib/libbsp/arm/beagle/include/irq.h (modified) * c/src/lib/libbsp/arm/beagle/irq.c (added) * c/src/lib/libbsp/arm/beagle/irq/irq.c (deleted) * c/src/lib/libbsp/arm/beagle/make/custom/beagleboardorig.cfg (added) * c/src/lib/libbsp/arm/beagle/make/custom/beagleboardxm.cfg (moved) * c/src/lib/libbsp/arm/beagle/make/custom/beagleboneblack.cfg (added) * c/src/lib/libbsp/arm/beagle/make/custom/beaglebonewhite.cfg (added) * c/src/lib/libbsp/arm/beagle/misc/boot.c (deleted) * c/src/lib/libbsp/arm/beagle/misc/i2c.c (modified) * c/src/lib/libbsp/arm/beagle/misc/restart.c (deleted) * c/src/lib/libbsp/arm/beagle/misc/system-clocks.c (deleted) * c/src/lib/libbsp/arm/beagle/misc/timer.c (deleted) * c/src/lib/libbsp/arm/beagle/preinstall.am (modified) * c/src/lib/libbsp/arm/beagle/rtc/rtc-config.c (deleted) * c/src/lib/libbsp/arm/beagle/simscripts/bbxm.cfg (added) * c/src/lib/libbsp/arm/beagle/simscripts/gdbinit.bbxm (added) * c/src/lib/libbsp/arm/beagle/simscripts/sdcard.sh (added) * c/src/lib/libbsp/arm/beagle/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/beagle/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/beagle/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c (added) * c/src/lib/libbsp/arm/beagle/startup/linkcmds.beagle (modified) BSP for several Beagle products Specifically the beagleboard, ... Wed, 22 Aug 2012 12:39:02 GMT Claas Ziemke [7a66986] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (added) * c/src/lib/libbsp/arm/beagle/README (added) * c/src/lib/libbsp/arm/beagle/bsp_specs (added) * c/src/lib/libbsp/arm/beagle/clock/beagle-clock-config.c (added) * c/src/lib/libbsp/arm/beagle/configure.ac (added) * c/src/lib/libbsp/arm/beagle/console/console-config.c (added) * c/src/lib/libbsp/arm/beagle/include/beagle-clock-config.h (added) * c/src/lib/libbsp/arm/beagle/include/beagle-timer.h (added) * c/src/lib/libbsp/arm/beagle/include/beagle.h (added) * c/src/lib/libbsp/arm/beagle/include/boot.h (added) * c/src/lib/libbsp/arm/beagle/include/bsp.h (added) * c/src/lib/libbsp/arm/beagle/include/i2c.h (added) * c/src/lib/libbsp/arm/beagle/include/irq.h (added) * c/src/lib/libbsp/arm/beagle/irq/irq.c (added) * c/src/lib/libbsp/arm/beagle/make/custom/beagle.cfg (added) * c/src/lib/libbsp/arm/beagle/make/custom/beagle.inc (added) * c/src/lib/libbsp/arm/beagle/misc/boot.c (added) * c/src/lib/libbsp/arm/beagle/misc/i2c.c (added) * c/src/lib/libbsp/arm/beagle/misc/restart.c (added) * c/src/lib/libbsp/arm/beagle/misc/system-clocks.c (added) * c/src/lib/libbsp/arm/beagle/misc/timer.c (added) * c/src/lib/libbsp/arm/beagle/preinstall.am (added) * c/src/lib/libbsp/arm/beagle/rtc/rtc-config.c (added) * c/src/lib/libbsp/arm/beagle/simscripts/qemu-beagleboard.in (added) * c/src/lib/libbsp/arm/beagle/startup/bspreset.c (added) * c/src/lib/libbsp/arm/beagle/startup/bspstart.c (added) * c/src/lib/libbsp/arm/beagle/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/beagle/startup/linkcmds.beagle (added) Added BeagleBoard BSP Coding done in course of GSoC2012. Commit ... Thu, 30 Oct 2014 13:29:09 GMT Sebastian Huber [e08b0b9] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-flash.S (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/reg-defs.h (modified) bsp/mpc55xxevb: Fix flash settings for MPC5510 Wed, 29 Oct 2014 16:07:20 GMT Chris Nott [513668f6] * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_adc.h (added) Added missing stm32f4xxxx_adc.h Thu, 23 Oct 2014 12:31:15 GMT Sebastian Huber [866a6fc] * c/src/lib/libbsp/sparc/leon3/startup/bsp_fatal_halt.c (modified) * c/src/lib/libbsp/sparc/shared/startup/bsp_fatal_halt.c (modified) bsps/sparc: Include right header file Thu, 23 Oct 2014 08:11:59 GMT Sebastian Huber [b442032] * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspstart.c (modified) bsp/leon3: Fix LEON3_mp_irq definition Provide it also if ... Thu, 23 Oct 2014 08:05:17 GMT Sebastian Huber [46dde0fc] * c/src/lib/libbsp/arm/csb336/include/bsp.h (modified) * c/src/lib/libbsp/arm/csb337/include/bsp.h (modified) * c/src/lib/libbsp/arm/edb7312/include/bsp.h (modified) * c/src/lib/libbsp/arm/gba/include/bsp.h (modified) * c/src/lib/libbsp/arm/gdbarmsim/include/bsp.h (modified) * c/src/lib/libbsp/arm/gp32/include/bsp.h (modified) * c/src/lib/libbsp/arm/gumstix/include/bsp.h (modified) * c/src/lib/libbsp/arm/nds/include/bsp.h (modified) * c/src/lib/libbsp/arm/rtl22xx/include/bsp.h (modified) * c/src/lib/libbsp/avr/avrtest/include/bsp.h (modified) * c/src/lib/libbsp/bfin/TLL6527M/include/bsp.h (modified) * c/src/lib/libbsp/bfin/bf537Stamp/include/bsp.h (modified) * c/src/lib/libbsp/bfin/eZKit533/include/bsp.h (modified) * c/src/lib/libbsp/h8300/h8sim/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/m32c/m32cbsp/include/bsp.h (modified) * c/src/lib/libbsp/m32r/m32rsim/include/bsp.h (modified) * c/src/lib/libbsp/m68k/av5282/include/bsp.h (modified) * c/src/lib/libbsp/m68k/csb360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68340/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/genmcf548x/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5206elite/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf52235/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5225x/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5235/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5329/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mrm332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) * c/src/lib/libbsp/m68k/ods68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/sim68000/include/bsp.h (modified) * c/src/lib/libbsp/m68k/uC5282/include/bsp.h (modified) * c/src/lib/libbsp/mips/csb350/include/bsp.h (modified) * c/src/lib/libbsp/mips/genmongoosev/include/bsp.h (modified) * c/src/lib/libbsp/mips/hurricane/include/bsp.h (modified) * c/src/lib/libbsp/mips/jmr3904/include/bsp.h (modified) * c/src/lib/libbsp/mips/malta/include/bsp.h (modified) * c/src/lib/libbsp/mips/rbtx4925/include/bsp.h (modified) * c/src/lib/libbsp/mips/rbtx4938/include/bsp.h (modified) * c/src/lib/libbsp/moxie/moxiesim/include/bsp.h (modified) * c/src/lib/libbsp/nios2/nios2_iss/include/bsp.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/haleakala/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mbx8xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/psim/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/qemuppc/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/score603e/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/ss555/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex4/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex5/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh1/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh2/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh4/include/bsp.h (modified) * c/src/lib/libbsp/sh/shsim/include/bsp.h (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/niagara/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/usiii/include/bsp.h (modified) * c/src/lib/libbsp/v850/gdbv850sim/include/bsp.h (modified) bsps: Move extern "C" to not cover includes Some includes may use ... Wed, 10 Sep 2014 11:39:53 GMT Daniel Cederman [77a2226] * c/src/lib/libbsp/shared/include/fatal.h (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c (modified) bsp/sparc: Ensure that data cache snooping is enabled Check that ... Sat, 18 Oct 2014 08:55:37 GMT Chris Nott [040ed0b4] * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_exti.h (added) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_flash.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_otgfs.h (added) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_pwr.h (added) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_rcc.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_syscfg.h (added) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_tim.h (added) * c/src/lib/libbsp/arm/stm32f4/preinstall.am (modified) * c/src/lib/libbsp/arm/stm32f4/startup/bspstart.c (modified) bsp/stm32f4: Add header files Added register definition headers for ... Mon, 20 Oct 2014 20:25:37 GMT Joel Sherrill [ea05c438] * c/src/lib/libbsp/or1k/or1ksim/console/uart.c (modified) or1k/or1ksim: Fix warnings Mon, 20 Oct 2014 20:25:22 GMT Joel Sherrill [ddc8165] * c/src/lib/libbsp/arm/raspberrypi/console/usart.c (modified) * c/src/lib/libbsp/arm/raspberrypi/include/bsp.h (modified) arm/raspberrypi: Fix warnings Mon, 20 Oct 2014 19:36:49 GMT Joel Sherrill [3532ff91] * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) shared/clockdrv_shell.h: Always include to avoid ... Mon, 20 Oct 2014 19:36:19 GMT Joel Sherrill [71bc995] * c/src/lib/libbsp/powerpc/qoriq/include/bsp.h (modified) powerpc/qoriq/include/bsp.h: Add prototypes to fix warnings Mon, 20 Oct 2014 19:21:37 GMT Joel Sherrill [ed18345] * c/src/lib/libbsp/powerpc/qemuppc/startup/cmain.c (modified) powerpc/qemuppc/startup/cmain.c: Fix warnings Mon, 20 Oct 2014 19:13:47 GMT Joel Sherrill [7294054b] * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) powerpc/shared/startup/bspstart.c: Fix warning for mvme2100 Mon, 20 Oct 2014 18:58:12 GMT Joel Sherrill [ce5c3b3] * c/src/lib/libbsp/nios2/nios2_iss/console/console.c (modified) * c/src/lib/libbsp/nios2/nios2_iss/startup/bspstart.c (modified) * c/src/lib/libbsp/nios2/nios2_iss/timer/timer.c (modified) nios2/nios2_iss: Fix warnings Mon, 20 Oct 2014 18:57:54 GMT Joel Sherrill [a4fea82] * c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c (modified) ss555/startup/bspstart.c: BSP does not use SPRG0 Mon, 20 Oct 2014 18:57:41 GMT Joel Sherrill [ad456877] * c/src/lib/libbsp/powerpc/ep1a/startup/bspstart.c (modified) ep1a/startup/bspstart.c: BSP does not use SPRG0 Mon, 20 Oct 2014 16:31:25 GMT Joel Sherrill [6fc2d389] * c/src/lib/libbsp/sh/shared/console.c (modified) libbsp/sh/shared/console.c: Eliminate use of obsolete method Mon, 20 Oct 2014 15:59:08 GMT Joel Sherrill [d6db94a] * c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c (modified) m68k/mrm332: Fix warnings Mon, 20 Oct 2014 15:58:57 GMT Joel Sherrill [a8777397] * c/src/lib/libbsp/m68k/mcf5329/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5329/startup/init5329.c (modified) m68k/mcf5329: Fix warnings Mon, 20 Oct 2014 15:58:38 GMT Joel Sherrill [63fe77e1] * c/src/lib/libbsp/m68k/mcf5235/include/bsp.h (modified) m68k/mcf5235: Fix warnings
