Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src/lib/libbsp/sparc
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @3f8abd2   12/03/13 21:21:51 Daniel Ramirez sparc: refactored shared/start.S to shared/start/start.S 4.115
(edit) @ebd0844   12/03/13 20:41:45 Gedare Bloom leon2: fix typo in doxygen 4.115
(edit) @133f3cce   12/03/13 20:26:51 radustoma leon2: improve doxygen Add doxygen to the cchip.c & leon_open_eth.c files. 4.115
(edit) @b9287a15   12/03/13 07:30:39 Daniel Ramirez libbsp: refactored sparc/shared/bspgetworkarea.c to … 4.115
(edit) @8d830fae   12/02/13 20:07:35 radustoma leon2_doxygen_1 4.115
(edit) @d230d8e   11/30/13 20:51:35 radustoma sparc/leon3: Add doxygen. 4.115
(edit) @2d3eb23   11/30/13 15:28:28 Daniel Hellstrom sparc/shared/irq_asm.S: Get pointer to self per-CPU control … 4.115
(edit) @52c3af1   11/14/13 23:26:12 Joel Sherrill sparc/../irq-shared.c: Fix compilation for SMP when not LEON3 4.115
(edit) @12cbc37   11/12/13 09:29:50 Sebastian Huber bsp/ngmp: New BSP variant 4.115
(edit) @f204e31   11/12/13 09:28:54 Sebastian Huber bsp/leon3: Enable linker script variants 4.115
(edit) @19814000   11/12/13 09:33:07 Sebastian Huber bsp/leon3: Delete unused LEON_REG symbol 4.115
(edit) @b3211b5a   10/31/13 14:23:23 Daniel Hellstrom SPARC BSPs: disable interrupts as early as possible There is no point … 4.115
(edit) @82e11be2   10/31/13 14:23:21 Daniel Hellstrom LEON3 SMP: remove compiler warning from delay() declaration 4.115
(edit) @bedfe13   10/31/13 14:23:20 Daniel Hellstrom LEON3 SMP: CPU ack irq on trap vector entry execution 4.115
(edit) @e1b53274   10/31/13 14:23:19 Daniel Hellstrom LEON3_MP ISR: shared-IRQ setup overwrite SMP/MP ISR trap handler … 4.115
(edit) @24a6943   10/24/13 23:37:17 Joel Sherrill sparc all BSPs: Use function and data sections This reduces the size … 4.115
(edit) @ba2e98e6   09/30/13 17:08:38 Joel Sherrill libbsp/sparc/.../gnatcommon.c: Formatting 4.115
(edit) @d349636b   09/30/13 17:08:13 Joel Sherrill leon2/.../ckinit.c: Change get nanoseconds handler to static 4.115
(edit) @38905d70   09/23/13 13:28:48 Joel Sherrill leon3/bsppredriver.c: Add include file to warning 4.115
(edit) @876af7a   09/23/13 13:16:55 Joel Sherrill leon3/.../ckinit.c: Change get nanoseconds handler to static 4.115
(edit) @d2c5bff   09/22/13 15:51:36 Joel Sherrill leon3/.../ckinit.c: Fix missing prototype warnings 4.115
(edit) @4650678b   09/22/13 15:38:31 Joel Sherrill leon3/.../bspstart.c: Fix missing prototype warnings 4.115
(edit) @f07b0e65   09/22/13 14:41:49 Joel Sherrill sparc/.../grcan.c: Switch to using RTEMS_COMPILER_UNUSED_ATTRIBUTE 4.115
(edit) @c8707a3   09/21/13 21:25:06 Joel Sherrill leon3/console.c: Fix misisng prototype issues 4.115
(edit) @34b57d61   09/21/13 21:10:17 Joel Sherrill sparc/.../grcan.c: Fix multiple warnings 4.115
(edit) @e9da278   09/21/13 21:09:48 Joel Sherrill sparc/.../ambapp.h: Add ambapp_get_number_apbslv_devices() prototype 4.115
(edit) @ac19578   09/21/13 20:56:28 Joel Sherrill sparc/.../occan.c: Fix missing prototype warning 4.115
(edit) @110cc8c   09/21/13 20:55:40 Joel Sherrill sparc/.../ambapp.h: Add ambapp_get_number_ahbslv_devices() prototype 4.115
(edit) @946c391   09/21/13 20:48:45 Joel Sherrill sparc/../occan.c: Fix set but unused variable warning 4.115
(edit) @df74da0   09/21/13 20:38:48 Joel Sherrill sparc irq-shared.c: Fix unused variable warning 4.115
(edit) @564860f   09/16/13 19:32:36 Joel Sherrill leon3/include/bsp.h: Fix spacing 4.115
(edit) @d473dc0   08/14/13 11:26:41 Sebastian Huber bsps: Fix clock driver defines 4.115
(edit) @f8ad6c6f   08/02/13 12:12:55 Sebastian Huber sparc: Make _CPU_ISR_Dispatch_disable per-CPU This variable must be … 4.115
(edit) @88f6c4fc   08/02/13 12:06:52 Sebastian Huber sparc: Move _CPU_Context_switch(), etc. Move the … 4.115
(edit) @8b077ca0   08/09/13 09:12:56 Sebastian Huber bsps/sparc: SMP and per-CPU thread dispatch disable Interrupt support … 4.115
(edit) @849bb7a3   08/01/13 09:35:16 Sebastian Huber bsps/sparc: Revert most SMP related changes As a side-effect the … 4.115
(edit) @c236082   07/30/13 13:54:53 Sebastian Huber smp: Provide cache optimized Per_CPU_Control Delete … 4.115
(edit) @fe52e7c0   07/26/13 12:10:25 Sebastian Huber smp: Add and use _Per_CPU_Get() Add and use _Per_CPU_Get_by_index() … 4.115
(edit) @ca63ae2   06/13/13 13:41:21 Sebastian Huber smp: Add and use _CPU_SMP_Send_interrupt() Delete bsp_smp_interrupt_cpu(). 4.115
(edit) @39e51758   06/14/13 12:00:38 Sebastian Huber smp: Add and use _CPU_SMP_Get_current_processor() Add and use … 4.115
(edit) @e18db9f   06/24/13 15:29:11 Sebastian Huber termios: Update due to API changes Termios notifies now the driver … 4.115
(edit) @edde99b   06/14/13 12:26:34 Sebastian Huber score: Rename rtems_smp_get_number_of_processors() Rename in … 4.115
(edit) @2f6108f9   05/28/13 08:58:19 Sebastian Huber smp: Simplify SMP initialization sequence Delete bsp_smp_wait_for(). … 4.115
(edit) @8cacceb   05/14/13 11:23:10 Sebastian Huber smp: Delete bsp_smp_secondary_cpu_initialize() Do not call … 4.115
(edit) @baf8f4d   05/14/13 08:12:52 Sebastian Huber smp: Simplify main CPU initialization Call _SMP_Handler_initialize() … 4.115
(edit) @6c2eedc   05/13/13 11:37:06 Sebastian Huber smp: Add maximum_processors field to config Delete … 4.115
(edit) @fad2d38   03/08/13 20:55:06 Gedare Bloom RTEMS: Delete ChangeLog? files. This commit deletes all RTEMS … 4.115
(edit) @e517714b   02/26/13 18:31:23 Jennifer Averett sparc: Remove dead code that was leftover from SMP development. 4.115
(edit) @c8bd3cd   02/08/13 12:39:59 Sebastian Huber libchip/serial: Add const qualifier 4.115
(edit) @5de9e8d   02/08/13 10:58:20 Sebastian Huber bsp/erc32: Fix warnings 4.115
(edit) @f597cc1   01/08/13 18:49:56 Joel Sherrill leon3: disable unused ISR handler 4.115
(edit) @4967f6b   01/08/13 18:37:05 Joel Sherrill leon3/shmsupp: Fix warnings & comment clean up 4.115
(edit) @4fd1ccaa   01/08/13 17:58:41 Joel Sherrill leon3: Open Ethernet Fixed Warning 4.115
(edit) @815994f   11/25/12 16:48:11 Sebastian Huber score: Add CPU_Exception_frame Add CPU port type CPU_Exception_frame … 4.115
(edit) @39aa75e7   11/23/12 21:40:09 Sebastian Huber bsps: Use RTEMS_BSP_CLEANUP_OPTIONS 4.115
(edit) @dd8df59   11/14/12 12:59:27 Sebastian Huber bsps: Interrupt initialization error is fatal 4.115
(edit) @a052181   11/14/12 08:59:10 Sebastian Huber score: Add RTEMS_FATAL_SOURCE_EXIT Include … 4.115
(edit) @a3e8ab2   11/14/12 10:53:38 Sebastian Huber bsps/sparc: Define bsp_reset() This is declared in <bsp/bootcard.h> … 4.115
(edit) @7121cac0   11/07/12 13:59:20 Sebastian Huber bsps/sparc: Add BSP_INITIAL_EXTENSION to <bsp.h> The … 4.115
(edit) @9186fa8   11/06/12 11:32:44 Sebastian Huber bsps/sparc: Delete unused symbol declaration 4.115
(edit) @f536e12   11/06/12 10:59:43 Sebastian Huber sapi: Use rtems_*_get_user_multiprocessing_table 4.115
(edit) @47a3cd8   08/09/12 14:48:00 Sebastian Huber score: Work area initialization API change The work areas (RTEMS work … 4.115
(edit) @c717fda5   08/06/12 17:03:46 Gedare Bloom Revert "Add bspopts.h.in." This reverts commit … 4.115
(edit) @1c554014   07/19/12 14:14:53 Ralf Corsepius Remove CVS-Ids. 4.115
(edit) @bb2b825   07/19/12 13:47:55 Ralf Corsepius Require automake-1.12.2. 4.115
(edit) @0f77281   07/19/12 13:44:32 Ralf Corsepius Require autoconf-2.69. 4.115
(edit) @aae7daa9   07/16/12 08:56:30 Sebastian Huber Fix broken _endtext symbol 4.115
(edit) @c2395717   07/14/12 19:26:20 Joel Sherrill sparc linkcmds.base: Add new FreeBSD TCP/IP stack sections 4.115
(edit) @daffa60   05/24/12 04:36:40 Ralf Corsepius Add bspopts.h.in. 4.115
(edit) @8bbf69e   05/16/12 21:04:10 Joel Sherrill pci.h cleanup - Consolidate common defines to cpukit pci.h + … 4.115
(edit) @226d48d8   05/16/12 15:20:35 Daniel Hellstrom LEON: moved register definitions into grlib header file Some register … 4.115
(edit) @9b4422a2   05/03/12 15:09:24 Joel Sherrill Remove All CVS Id Strings Possible Using a Script Script does what is … 4.115
(edit) @33a105fb   05/07/12 16:08:48 Joel Sherrill Revert: Remove CVS Ids See … 4.115
(edit) @bf8e316   05/04/12 06:51:44 Ralf Corsepius Remove CVS-Ids. 4.115
(edit) @2579e53   05/02/12 19:13:56 Joel Sherrill LEON3 - Remove bad $Id$ and clean up file header 4.115
(edit) @1e7ee71   05/02/12 19:13:44 Joel Sherrill LEON2 - Remove bad $Id$ and clean up file header 4.115
(edit) @e621bde   04/19/12 17:34:28 Daniel Hellstrom LEON3: rename console/debugputs.c to printk_support.c 4.115
(edit) @5d48037   04/19/12 13:21:25 Daniel Hellstrom LEON3: added TX-wait-complete and CR on NL support for UART … 4.115
(edit) @605b4b64   04/19/12 13:21:24 Daniel Hellstrom LEON3: debugputs removed pointless isinit code, invoked only once … 4.115
(edit) @5903484   04/19/12 13:21:23 Daniel Hellstrom LEON3: debugputs added printk mem buffer when no UART present … 4.115
(edit) @62694fd   04/19/12 13:46:10 Daniel Hellstrom LEON3: add console interrupt mode support The comment in configure.ac … 4.115
(edit) @07557c8   04/19/12 13:21:21 Daniel Hellstrom LEON3: add console attributes such as parity and baudrate … 4.115
(edit) @6845f80   04/19/12 13:21:20 Daniel Hellstrom LEON3: console, lower bus utilization waiting for UART TX ready … 4.115
(edit) @7a01a888   04/17/12 14:25:42 Daniel Hellstrom LEON: updated drivers to use new AMBAPP Layer The drivers are updated … 4.115
(edit) @fc6f872   04/17/12 14:25:41 Daniel Hellstrom LEON3: Network initialization code updated to new AMBAPP layer … 4.115
(edit) @ddf0d60   04/17/12 14:25:40 Daniel Hellstrom LEON3: updated console driver for new AMBAPP layer Signed-off-by: … 4.115
(edit) @1f7cfbe3   04/17/12 14:25:39 Daniel Hellstrom LEON2: clock driver use new AMBAPP layer Signed-off-by: Daniel … 4.115
(edit) @9ea65119   04/17/12 14:25:38 Daniel Hellstrom LEON: updated AMBA PnP API The old layer had some … 4.115
(edit) @7afcb26   04/10/12 19:12:23 Daniel Hellstrom PR2052: LEON3: fix open_eth interrupt initialization bug Fixed a bug … 4.115
(edit) @7499b84   04/05/12 15:23:17 Daniel Hellstrom GRETH: use shared-irq service instead of BSP specific set_vec() The … 4.115
(edit) @0f04edd   04/05/12 15:23:16 Daniel Hellstrom SMC91111: updated to use shared IRQ service Signed-off-by: Daniel … 4.115
(edit) @c500cbc   04/06/12 14:09:35 Joel Sherrill LEON3 - Fix spacing 4.115
(edit) @3722ff5a   04/05/12 15:23:21 Daniel Hellstrom LEON3: added IRQAMP support 4.115
(edit) @684b54a   04/05/12 15:23:20 Daniel Hellstrom LEON3: halt boot if IRQ controller not found Signed-off-by: Daniel … 4.115
(edit) @95518e59   04/06/12 10:05:07 Daniel Hellstrom SPARC BSPs: implemented shared-irq using libbsp/shared layer The … 4.115
(edit) @e60e862   04/05/12 15:23:19 Daniel Hellstrom LEON3: console use register pointers instead of UART indexes … 4.115
(edit) @4b557617   04/05/12 15:23:18 Daniel Hellstrom LEON3: cleanup console UART indexing handling The UART indexing was … 4.115
(edit) @2cee553   03/29/12 11:52:16 Daniel Hellstrom LEON3: various cleanups in leon.h Removed old LEON2 definitions never … 4.115
(edit) @226771c   03/29/12 11:52:14 Daniel Hellstrom LEON3: IRQ index mask was bad, but always shifted out anyway … 4.115
(edit) @4fa6be9   03/29/12 11:52:13 Daniel Hellstrom LEON3: clock timer indexing should be consequent Signed-off-by: … 4.115
