Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src/lib/libbsp/sparc
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @1045422   05/26/15 08:02:27 Sebastian Huber bsps/sparc: Delete unused local labels 4.115
(edit) @26ffb8c2   05/26/15 08:01:29 Sebastian Huber bsps/sparc: Change tabs to spaces 4.115
(edit) @75acd9e   04/01/15 13:33:25 alexander.krutwig bsps: Convert clock drivers to use a timecounter Update #2271. 4.115
(edit) @a0001d6   05/14/15 09:17:00 Sebastian Huber Remove obsolete rtems_clock_major/minor These global variables are … 4.115
(edit) @c77e3cb   04/14/15 07:31:05 Daniel Hellstrom LEON3: gptimer drvmgr init simplified wrt boot 4.115
(edit) @9fe249d   04/14/15 07:28:54 Daniel Hellstrom LEON3: move timer variable to where initialized 4.115
(edit) @efd43ad   04/14/15 07:24:33 Daniel Hellstrom LEON3: simplify amba initialization 4.115
(edit) @628e739   04/14/15 06:18:27 Daniel Hellstrom LEON3: clock irq always same as timer instance The leon.h already … 4.115
(edit) @291c5391   04/13/15 11:12:33 Daniel Hellstrom DRVMGR: remove struct driver registration func 4.115
(edit) @bef5e23e   04/13/15 09:31:53 Daniel Hellstrom DRVMGR: renamed RES_EMPTY to DRVMGR_RES_EMPTY 4.115
(edit) @4d3e70f4   04/13/15 09:26:52 Daniel Hellstrom DRVMGR: KEY_TYPE now a enum drvmgr_kt 4.115
(edit) @14d55deb   04/13/15 09:12:04 Daniel Hellstrom DRVMGR: renamed info_dev to get_info_dev 4.115
(edit) @246fe22   04/13/15 09:07:54 Daniel Hellstrom DRVMGR: change name of freq_get to get_freq 4.115
(edit) @4a7d1026   04/13/15 08:25:52 Daniel Hellstrom sparc bsps: updated license to rtems.org 4.115
(edit) @159ee990   04/07/15 14:05:04 Daniel Hellstrom leon3,ngmp: cpucounter initialization use proper names To be merged … 4.115
(edit) @5564b5a   04/07/15 14:04:13 Daniel Hellstrom leon3: timer config updated to use proper naming To be merged with … 4.115
(edit) @9b292ea   04/07/15 12:31:22 Daniel Hellstrom LEON: converted LEON4-N2X to BSD header 4.115
(edit) @8b29637c   04/07/15 12:31:07 Daniel Hellstrom LEON: converted PCI peripherals to BSD header 4.115
(edit) @d5ca821   04/07/15 12:28:29 Daniel Hellstrom LEON: converted AT697,GRPCi,GRPCI2,PCIF to BSD header 4.115
(edit) @5823bae8   02/27/15 13:03:15 Daniel Hellstrom LEON: move driver headers to bsp/ directory 4.115
(edit) @445e253   02/06/15 09:07:19 Daniel Hellstrom MCTRL: fix build warnings in MCTRL driver 4.115
(edit) @dbfa7c98   02/11/15 11:56:03 Daniel Hellstrom AMBAPP GRLIB: fix build warnings 4.115
(edit) @62fb1778   02/11/15 11:55:32 Daniel Hellstrom LEON2: fix build warnings 4.115
(edit) @43613a90   02/11/15 11:54:57 Daniel Hellstrom AMBAPP_BUS: fix build warnings 4.115
(edit) @56662f5c   02/11/15 11:52:14 Daniel Hellstrom LEON CONS: fix build warnings 4.115
(edit) @103bbde   02/11/15 11:50:35 Daniel Hellstrom GR-TMTC-1553: fix build warnings 4.115
(edit) @dd8abfc   02/11/15 11:40:17 Daniel Hellstrom GR-RASTA-TMTC: fix build warnings 4.115
(edit) @90fd587   02/11/15 11:39:40 Daniel Hellstrom GR-RASTA-SPW-ROUTER: fix build warnings 4.115
(edit) @960aebf   02/11/15 11:39:04 Daniel Hellstrom GR-RASTA-IO: fix build warnings 4.115
(edit) @03037b4   02/11/15 11:38:22 Daniel Hellstrom GR-RASTA-ADCDAC: fix build warnings 4.115
(edit) @ef7a009   02/11/15 11:37:28 Daniel Hellstrom GR-LEON4-N2X: fix build warnings 4.115
(edit) @05a45c79   02/11/15 11:36:50 Daniel Hellstrom GR_701: fix build warnings 4.115
(edit) @cb64b862   02/11/15 11:35:53 Daniel Hellstrom GRGPIO: fix buld warnings 4.115
(edit) @c39de3c4   02/11/15 11:35:36 Daniel Hellstrom GPIOLIB: fix build warnings 4.115
(edit) @7bc74ed   02/11/15 11:34:48 Daniel Hellstrom GRADCDAC: fix build warnings 4.115
(edit) @0355ad4   02/11/15 11:34:02 Daniel Hellstrom GENIRQ: fix build warnings 4.115
(edit) @9d05c6df   02/11/15 11:32:22 Daniel Hellstrom GRPWM: fix build warnings 4.115
(edit) @126b25d   02/11/15 11:31:26 Daniel Hellstrom SPWCUC: fix build warnings 4.115
(edit) @8c6c53d   02/11/15 11:27:05 Daniel Hellstrom SPICTRL: fix build warnings 4.115
(edit) @9b90342   02/11/15 11:23:45 Daniel Hellstrom GRSPW router: fix build warnings 4.115
(edit) @b6292a0b   02/11/15 11:23:04 Daniel Hellstrom GRSPW_PKT: fix build warnings 4.115
(edit) @fd7eaa2   02/11/15 08:40:15 Daniel Hellstrom TLIB: fix build warnings 4.115
(edit) @6048035   02/11/15 08:39:48 Daniel Hellstrom TLIB Clock: fix build warnings 4.115
(edit) @a93b3aa4   02/11/15 08:37:50 Daniel Hellstrom GRASCS: fix build warnings 4.115
(edit) @3823f5c   02/11/15 08:20:40 Daniel Hellstrom GRCTM: fix build warnings 4.115
(edit) @60d392b7   02/11/15 08:19:53 Daniel Hellstrom GRTM: fix build warnings 4.115
(edit) @e21a5b0   02/11/15 08:18:53 Daniel Hellstrom GRTC: fix build warnings 4.115
(edit) @6657a3d   02/10/15 15:33:16 Daniel Hellstrom LEON: GRPCI2 driver warning fixes 4.115
(edit) @48191662   02/10/15 15:29:39 Daniel Hellstrom LEON: I2CMST driver warnings fixes 4.115
(edit) @c9f75435   02/10/15 15:28:55 Daniel Hellstrom LEON: OCCAN driver warnings fixes 4.115
(edit) @be815e78   02/10/15 15:28:19 Daniel Hellstrom LEON: B1553BRM driver warnings fixes 4.115
(edit) @44e514f   02/10/15 15:28:03 Daniel Hellstrom LEON: B1553RT driver warnings fixes 4.115
(edit) @3f38335b   02/10/15 15:05:38 Daniel Hellstrom LEON: added get_resarray_count() helper routine 4.115
(edit) @b787bead   02/10/15 08:23:48 Daniel Hellstrom GR1553B: fixed build warnings 4.115
(edit) @05ce8bd5   02/10/15 07:32:42 Daniel Hellstrom AT697PCI: fix build warnings 4.115
(edit) @e3c9937   02/18/15 14:34:39 Daniel Hellstrom GPTIMER: move ISR install from init1 To avoid install ISRs during … 4.115
(edit) @f37a3c2   02/06/15 10:10:17 Daniel Hellstrom GPTIMER: fix build warnings 4.115
(edit) @7a03ac29   02/06/15 08:59:13 Daniel Hellstrom APBUART_CONS: fix build warning 4.115
(edit) @d77b16d   02/06/15 08:27:08 Daniel Hellstrom GR-RASTA-SPW-ROUTER: fix build warnings 4.115
(edit) @28950f0b   02/05/15 13:35:33 Daniel Hellstrom PCIF: fixed build warnings 4.115
(edit) @f407c51   02/05/15 13:31:42 Daniel Hellstrom GRPCI: fixed build warnings 4.115
(edit) @0d9bc25   02/05/15 08:52:00 Daniel Hellstrom GRSPW: fix build warnings 4.115
(edit) @b55aa49   02/05/15 07:07:15 Daniel Hellstrom LEON3: watchdog use common timer defines 4.115
(edit) @5ba49066   02/05/15 07:06:26 Daniel Hellstrom LEON3: export debug uart to console uart driver 4.115
(edit) @aedc9849   02/05/15 07:05:56 Daniel Hellstrom GRETH: fix build warnings with GCC-4.9 4.115
(edit) @bf6fe958   02/04/15 15:22:59 Daniel Hellstrom GPTIMER: avoid build warnings 4.115
(edit) @0fcd4b33   02/04/15 15:22:41 Daniel Hellstrom AHBSTAT: fix build warnings 4.115
(edit) @bb689e6   11/04/14 07:57:55 Daniel Hellstrom GRTM: fixed descriptor TS bit declaration 4.115
(edit) @5f4028b   11/04/14 07:52:39 Daniel Hellstrom GRSPW_PKT: grspw_status renamed in header 4.115
(edit) @e8f6005f   08/08/14 08:01:41 Daniel Hellstrom GR-RASTA-TMTC,rev1: add GRGPIO[0] register init 4.115
(edit) @fed905c8   08/08/14 07:59:36 Daniel Hellstrom B1553BRM: change the init of the RT legalization registers 4.115
(edit) @d2a94ab   05/02/14 12:28:44 Daniel Hellstrom GRSPW: added clock cycles after GRSPW reset added clock cycles after … 4.115
(edit) @56fc7809   07/03/13 08:16:30 andreas GRSPW_PKT: Add support for Interrupt-codes Update: Daniel Hellstrom … 4.115
(edit) @c119c0e   07/03/13 08:06:37 andreas GRSPW: Fix incorrect register defines - presently functionally … 4.115
(edit) @f1b1668   12/20/13 09:17:22 Daniel Hellstrom AMBAPP: updated PnP IDs database with SPWTDP 4.115
(edit) @fa12bb43   11/29/13 13:58:58 Daniel Hellstrom GRTIMER: added to GPTIMER driver GRTIMER is compatible with GPTIMER, … 4.115
(edit) @9b8e04e2   10/22/13 10:03:41 Daniel Hellstrom GRETH: avoid hw generated UDP/TCP cksum generation Hardware generated … 4.115
(edit) @80b9c8ac   12/20/13 13:03:10 Daniel Hellstrom GR-RASTA-IO: updated for new version From this driver's point of view … 4.115
(edit) @fc76056e   12/20/13 13:01:12 Daniel Hellstrom GR-RASTA-TMTC: updated for new version From this driver's point of … 4.115
(edit) @9d88008   12/18/13 15:42:16 Daniel Hellstrom AT697PCI: fix PCI cfg writes 4.115
(edit) @ddc4002   11/22/13 09:22:56 Daniel Hellstrom AT697 PCI: abort whhen a peripheral PCI system detected 4.115
(edit) @3c236cc   02/05/14 16:17:53 Daniel Hellstrom LEON PCI: fix for PCI host bridge driver CFG space access 4.115
(edit) @acf7047e   09/10/13 11:46:29 Daniel Hellstrom GPTIMER: timer probing must not be on timer0 Timers are identical … 4.115
(edit) @51347053   07/01/13 13:00:21 Daniel Hellstrom LEON PCI: host bridge driver support for probing dev0=AD16 Before the … 4.115
(edit) @d936c1a   06/03/13 12:12:08 Daniel Hellstrom APBUART: debug bit was cleared incorrectly 4.115
(edit) @ab907e8e   05/21/13 08:10:21 Daniel Hellstrom NGMP PCI: added support for NGMP prototype boards 4.115
(edit) @bc89145   02/11/15 13:39:34 Daniel Hellstrom LEON GRSPW: updated to new DRVMGR translation interface 4.115
(edit) @ffd8002d   05/08/13 12:41:13 Daniel Hellstrom GR-CPCI-LEON4-N2X: added PCI peripheral driver for PCI device … 4.115
(edit) @8aa446a   05/08/13 12:38:10 Daniel Hellstrom GRPCI2: updated register layout to newer specification 4.115
(edit) @ecbd577   04/30/13 07:49:32 Daniel Hellstrom AMBAPP: update AMBA PnP ID database 4.115
(edit) @175b9a64   04/24/13 15:36:44 Daniel Hellstrom GRPCI2: work-around for rev0 bug by limiting prefetching 4.115
(edit) @819de55b   03/18/13 07:29:39 Daniel Hellstrom PCI-RASTA: set GRPCI1 target cache-line-size to avoid poor performance 4.115
(edit) @37ac3b86   03/14/13 09:20:15 Daniel Hellstrom GRETH: cleaned up parts of PHY init code 4.115
(edit) @107c5aea   03/13/13 15:40:05 Daniel Hellstrom GRETH: changed the PHY initialization sequence 1. read_mii() now … 4.115
(edit) @a79c36ad   03/12/13 14:30:09 Daniel Hellstrom GRETH: forcing autonegotiation during PHY initialization Looking at … 4.115
(edit) @bee7c46f   03/12/13 13:49:33 Daniel Hellstrom GRETH: updated worker Deamon thread name The name was probably copied … 4.115
(edit) @552d4a9   03/06/13 14:08:31 Daniel Hellstrom GRPCI: initialize cache-line-size and latency timer In some GRPCI … 4.115
(edit) @5dd83de   01/18/13 12:16:05 Daniel Hellstrom GRSPW: fixed SET_RMAPEN and SET_RMAPBUFDIS Both ioctl commands … 4.115
(edit) @4d249b9f   11/19/12 16:41:15 Daniel Hellstrom GPTIMER: support separate & shared irq by clearing pending bit after ISR 4.115
(edit) @7ebc28cd   11/19/12 14:24:21 Daniel Hellstrom GPTIMER: Only probe pending bit on timer0 4.115
