# # ChangeLog for c/src/lib/libbsp/sparc in rtems # # Generated by Trac 1.2.1.dev0 # 05/02/24 00:25:37 Thu, 13 Apr 2017 12:57:01 GMT Daniel Hellstrom [998e34ad] * c/src/lib/libbsp/sparc/shared/net/greth.c (modified) leon, greth: SMP support by using spin-lock protection Tue, 11 Apr 2017 11:55:02 GMT Martin Aberg [8927c0f] * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) leon, gptimer: offset intnum with subtimer index If separate ... Mon, 10 Apr 2017 17:07:04 GMT Martin Aberg [256e083f] * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) leon, gptimer: fixed probing separate interrupts Probing of ... Wed, 08 Mar 2017 11:59:07 GMT Javier Jalle [6234abe] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/l4stat.h (added) * c/src/lib/libbsp/sparc/shared/stat/l4stat.c (added) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) leon, l4stat: Initial driver commit Tue, 07 Mar 2017 11:50:48 GMT Javier Jalle [21b3319f] * c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h (modified) leon, ambapp: Added L4STAT driver to ambapp ids Mon, 06 Mar 2017 12:08:04 GMT Martin Aberg [a8595605] * c/src/lib/libbsp/sparc/shared/can/occan.c (modified) leon, occan: Converted disable/enable to SMP locks This commit ... Thu, 19 Jan 2017 17:57:58 GMT Martin Aberg [c609ccea] * c/src/lib/libbsp/sparc/shared/amba/ahbstat.c (modified) leon, ahbstat: Use RTEMS 4.12 SMP interrupt lock Wed, 15 Mar 2017 13:38:21 GMT Javier Jalle [c241236] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h (modified) * c/src/lib/libbsp/sparc/shared/include/memscrub.h (added) * c/src/lib/libbsp/sparc/shared/scrub/memscrub.c (added) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) leon, memscrub: add GR740 memory scrubber driver Wed, 15 Mar 2017 14:04:33 GMT Javier Jalle [d79429f] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/griommu.h (added) * c/src/lib/libbsp/sparc/shared/iommu/griommu.c (added) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) leon, griommu: add GR740 IOMMU driver The driver is limited to the ... Wed, 15 Feb 2017 15:51:33 GMT Javier Jalle [3e948cc] * c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h (modified) leon, ambapp: Added GRIOMMU driver to ambapp ids Tue, 21 Feb 2017 08:14:46 GMT Javier Jalle [dfa86338] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/l2c.h (added) * c/src/lib/libbsp/sparc/shared/l2c/l2c.c (added) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) leon, l2cache: add GR740 L2-Cache driver Wed, 15 Mar 2017 13:58:04 GMT Javier Jalle [d24ed54] * c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h (modified) leon, ambapp: Added L2CACHE driver to ambapp ids Thu, 09 Feb 2017 13:09:17 GMT Javier Jalle [93c5e63] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/grpci2dma.h (added) * c/src/lib/libbsp/sparc/shared/pci/grpci2dma.c (added) leon, grpci2dma: add GR740 PCI DMA driver Wed, 15 Feb 2017 10:14:13 GMT Javier Jalle [31ba1f21] * c/src/lib/libbsp/sparc/shared/pci/grpci2.c (modified) leon, grpci2: prepare for GRPCI2DMA driver Wed, 15 Feb 2017 10:09:23 GMT Javier Jalle [8e45d55] * c/src/lib/libbsp/sparc/shared/pci/grpci2.c (modified) leon, grpci2: Make driver SMP safe Fri, 17 Mar 2017 13:44:25 GMT Daniel Hellstrom [9631e5a9] * c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c (modified) * c/src/lib/libbsp/sparc/shared/include/ambapp_ids.h (modified) leon, ambapp: updated AMBA PnP IDs and names database Tue, 14 Mar 2017 16:46:12 GMT Martin Aberg [e5e44bdb] * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) leon, apbuart: Wait for shift register on close Do not disable ... Tue, 14 Mar 2017 16:27:57 GMT Martin Aberg [6860ddb] * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) leon, apbuart: Optimized RX processing in ISR Limit the number of ... Mon, 13 Mar 2017 09:53:47 GMT Martin Aberg [3df6710] * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) leon, apbuart: support termios task driven mode The APBUART control ... Fri, 10 Mar 2017 14:32:38 GMT Martin Aberg [f164a294] * c/src/lib/libbsp/sparc/shared/include/cons.h (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) * c/src/lib/libbsp/sparc/shared/uart/cons.c (modified) leon, apbuart: Inherit HW parameters on sysconsole The cons layer ... Fri, 10 Mar 2017 13:03:11 GMT Martin Aberg [6e2e1299] * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) leon, apbuart: Assign proper device name Always assign a ... Thu, 09 Mar 2017 17:51:47 GMT Martin Aberg [1fefc719] * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) leon, apbuart: RX delayed interrupt Utilize the APBUART RX delayed ... Wed, 01 Feb 2017 15:48:51 GMT Martin Aberg [fd9fb21] * c/src/lib/libbsp/sparc/shared/include/cons.h (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) * c/src/lib/libbsp/sparc/shared/uart/cons.c (modified) leon, cons: drvmgr cons interface uses new TERMIOS LEON driver ... Mon, 06 Mar 2017 10:14:23 GMT Martin Aberg [7cb93250] * c/src/lib/libbsp/sparc/shared/include/apbuart.h (modified) leon, apbuart: added register defines: FIFO, delay int The FIFOs ... Thu, 23 Feb 2017 15:33:21 GMT Martin Aberg [f600458d] * c/src/lib/libbsp/sparc/shared/include/tlib.h (modified) * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) * c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c (modified) leon, clock: new driver manager clock driver - Compatible with SMP ... Mon, 10 Apr 2017 12:52:16 GMT Daniel Hellstrom [78e56096] * c/src/lib/libbsp/sparc/shared/include/tlib.h (modified) * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) leon, tlib: added timer width mask information Fri, 07 Apr 2017 06:31:48 GMT Daniel Hellstrom [ae203e0d] * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c (modified) * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus_grlib.c (modified) * c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h (modified) leon, ambapp_bus: IRQ affinity for on-chip AMBAPP bus Tue, 31 Jan 2017 09:13:41 GMT Javier Jalle [61788e76] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/gr_cpci_gr740.h (added) * c/src/lib/libbsp/sparc/shared/pci/gr_cpci_gr740.c (added) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) * cpukit/libpci/pci/ids_extra.h (modified) * cpukit/libpci/pci_bus.h (modified) leon, GR-CPCI-GR740: Added peripheral PCI driver Mon, 24 Apr 2017 16:16:37 GMT Joel Sherrill [3ed2cf60] * c/src/lib/libbsp/sparc/leon2/console/debugputs.c (modified) leon2/console/debugputs.c: Fix misleading indentation warning Mon, 24 Apr 2017 01:17:54 GMT Joel Sherrill [38d0a94] * c/src/lib/libbsp/sparc/shared/drvmgr/leon2_amba_bus.c (modified) shared/drvmgr/leon2_amba_bus.c: Include Sun, 23 Apr 2017 17:03:22 GMT Joel Sherrill [29129822] * c/src/lib/libbsp/sparc/shared/amba/ahbstat.c (modified) amba/ahbstat.c: Correct printf() format Sun, 23 Apr 2017 16:49:54 GMT Joel Sherrill [35e523d9] * c/src/lib/libbsp/sparc/shared/uart/apbuart.c (modified) uart/apbuart.c: Correct printk() format Sun, 23 Apr 2017 16:49:05 GMT Joel Sherrill [76052e6] * c/src/lib/libbsp/sparc/shared/spw/grspw_router.c (modified) spw/grspw_router.c: Include Sun, 23 Apr 2017 16:48:32 GMT Joel Sherrill [d968826] * c/src/lib/libbsp/sparc/shared/irq/genirq.c (modified) irq/genirq.c: Include Sun, 23 Apr 2017 16:48:15 GMT Joel Sherrill [5c93fb3b] * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c (modified) drvmgr/ambapp_bus.c: Include Sun, 23 Apr 2017 16:47:53 GMT Joel Sherrill [9ed3266] * c/src/lib/libbsp/sparc/shared/amba/ahbstat.c (modified) amba/ahbstat.c: Include Mon, 03 Apr 2017 10:51:51 GMT Sebastian Huber [1301468] * c/src/lib/libbsp/arm/atsam/console/console.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-esci.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-linflex.c (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_termios.c (modified) * c/src/libchip/serial/ns16550-context.c (modified) * c/src/libchip/serial/ns16550.c (modified) * cpukit/dev/serial/sc16is752.c (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) bsps: Fix baud settings Update #2897. Tue, 21 Mar 2017 19:39:48 GMT Kevin Kirspel [1c6926c1] * c/src/lib/libbsp/arm/csb336/console/uart.c (modified) * c/src/lib/libbsp/arm/lpc32xx/console/hsu.c (modified) * c/src/lib/libbsp/i386/shared/comm/tty_drv.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_console/console.c (modified) * c/src/lib/libbsp/m68k/av5282/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68340/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68360/console/console.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf52235/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5235/console/console.c (modified) * c/src/lib/libbsp/m68k/mcf5329/console/console.c (modified) * c/src/lib/libbsp/m68k/mrm332/console/sci.c (modified) * c/src/lib/libbsp/m68k/mvme167/console/console.c (modified) * c/src/lib/libbsp/m68k/uC5282/console/console.c (modified) * c/src/lib/libbsp/powerpc/acinclude.m4 (modified) * c/src/lib/libbsp/powerpc/gen5200/console/console.c (modified) * c/src/lib/libbsp/powerpc/shared/console/console.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/console/console.c (modified) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) * c/src/lib/libcpu/arm/at91rm9200/usart/usart.c (modified) * c/src/lib/libcpu/arm/s3c24xx/include/s3c2400.h (modified) * c/src/lib/libcpu/arm/s3c24xx/include/s3c2410.h (modified) * c/src/lib/libcpu/bfin/serial/uart.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/esci/esci.c (modified) * c/src/lib/libcpu/powerpc/mpc5xx/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console405.c (modified) * c/src/lib/libcpu/powerpc/ppc403/tty_drv/tty_drv.c (modified) * c/src/lib/libcpu/sh/sh7032/sci/sci.c (modified) * c/src/lib/libcpu/sh/sh7045/sci/sci.c (modified) * c/src/lib/libcpu/sh/sh7045/sci/sci_termios.c (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681_baud.c (modified) * c/src/libchip/serial/z85c30.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/include/sys/_termios.h (added) * cpukit/libcsupport/include/sys/ioccom.h (modified) * cpukit/libcsupport/include/sys/termios.h (modified) * cpukit/libcsupport/include/sys/ttycom.h (modified) * cpukit/libcsupport/include/sys/ttydefaults.h (added) * cpukit/libcsupport/src/cfgetispeed.c (modified) * cpukit/libcsupport/src/cfgetospeed.c (modified) * cpukit/libcsupport/src/cfmakeraw.c (modified) * cpukit/libcsupport/src/cfmakesane.c (added) * cpukit/libcsupport/src/cfsetispeed.c (modified) * cpukit/libcsupport/src/cfsetospeed.c (modified) * cpukit/libcsupport/src/cfsetspeed.c (modified) * cpukit/libcsupport/src/tcdrain.c (modified) * cpukit/libcsupport/src/tcflush.c (modified) * cpukit/libcsupport/src/tcgetattr.c (modified) * cpukit/libcsupport/src/tcsetattr.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termios_baud2index.c (modified) * cpukit/libcsupport/src/termios_baud2num.c (modified) * cpukit/libcsupport/src/termios_baudtable.c (modified) * cpukit/libcsupport/src/termios_setbestbaud.c (modified) * cpukit/libcsupport/src/termios_setinitialbaud.c (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) * cpukit/preinstall.am (modified) * testsuites/libtests/termios/init.c (modified) * testsuites/libtests/termios01/init.c (modified) * testsuites/libtests/termios01/termios01.scn (modified) * testsuites/libtests/termios01/termios_testdriver.c (modified) * testsuites/libtests/termios02/termios02.scn (modified) * testsuites/libtests/termios03/termios03.scn (modified) * testsuites/libtests/termios04/termios04.scn (modified) * testsuites/libtests/termios05/termios05.scn (modified) * testsuites/libtests/termios06/init.c (modified) * testsuites/libtests/termios06/termios06.scn (modified) * testsuites/libtests/termios07/termios07.scn (modified) * testsuites/libtests/termios08/termios08.scn (modified) * tools/cpu/sh/sci.c (modified) termios: Synchronize with latest FreeBSD headers Adding modified ... Fri, 03 Feb 2017 07:55:27 GMT Daniel Hellstrom [49caf22] * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: fix overwrite protection when more than 32 devs ... Fri, 03 Feb 2017 07:53:35 GMT Daniel Hellstrom [cc8a50ab] * c/src/lib/libbsp/sparc/shared/tmtc/grtm.c (modified) leon,grtm: ioctl() shouldn't access pointer before validated This ... Mon, 23 Jan 2017 15:45:48 GMT Daniel Hellstrom [fec8288] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: SMP support The driver already was developed with ... Fri, 24 Feb 2017 11:54:01 GMT Daniel Hellstrom [36fc8b18] * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: unregister ISR on close Sun, 22 Jan 2017 10:34:25 GMT Daniel Hellstrom [090016a] * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: ISR activate shutdown work only if errintr enabled ... Fri, 24 Feb 2017 11:49:07 GMT Daniel Hellstrom [029ce4d1] * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: fix descriptor table mem leak on grspw_close() Sun, 22 Jan 2017 10:30:04 GMT Daniel Hellstrom [1b559e3] * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: add missing GRSPW1 IP-core support Sun, 22 Jan 2017 14:58:18 GMT Daniel Hellstrom [94fb377b] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: ISR RX/TX DMA interrupt source disable configurable ... Sun, 22 Jan 2017 14:43:17 GMT Daniel Hellstrom [8acfa94] * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grpsw_pkt: set unique work-task name Sun, 22 Jan 2017 14:35:27 GMT Daniel Hellstrom [72ec13ef] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: functions to support custom work-task Added ... Sun, 22 Jan 2017 14:03:51 GMT Daniel Hellstrom [29c2304] * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: fix interrupt code ctrl bit declarations Sun, 22 Jan 2017 14:01:55 GMT Daniel Hellstrom [ab9b447] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: added work-task configuration options Following ... Mon, 13 Feb 2017 09:16:14 GMT Javier Jalle [f46f5f84] * c/src/lib/libbsp/sparc/shared/include/grpci2.h (modified) * c/src/lib/libbsp/sparc/shared/pci/grpci2.c (modified) leon, grpci2: latency timer user configurable (default 64) Wed, 15 Feb 2017 10:05:27 GMT Javier Jalle [0c23dd5] * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c (modified) leon, gr740: fix device registration for GRPCI2 core Tue, 31 Jan 2017 09:14:29 GMT Javier Jalle [73b06e64] * c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c (modified) leon, gr-cpci-leon4-n2x: small comment fix Thu, 26 Jan 2017 15:03:19 GMT Javier Jalle [bb8e099] * c/src/lib/libbsp/sparc/shared/pci/grpci2.c (modified) leon, grpci2: updated DMA descriptor layout Thu, 26 Jan 2017 14:37:34 GMT Javier Jalle [d9d8dbd] * c/src/lib/libbsp/sparc/shared/pci/grpci2.c (modified) leon, grpci2: fixed wrong bit layout Thu, 26 Jan 2017 14:31:17 GMT Javier Jalle [a545ce26] * c/src/lib/libbsp/sparc/shared/pci/grpci2.c (modified) leon, grpci2: added TIMEOUT interrupt Thu, 26 Jan 2017 10:36:52 GMT Javier Jalle [89173ee9] * c/src/lib/libbsp/sparc/shared/include/grlib.h (modified) bsps/sparc: Updated L2C registers Tue, 12 Apr 2016 11:53:42 GMT Daniel Hellstrom [ef94150f] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: Added checks for special list cases - Fixed ... Fri, 08 Apr 2016 12:03:47 GMT Daniel Hellstrom [a7cc0da9] * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: fix stscfg cfg TimeCode Int clr Without this patch ... Thu, 07 Apr 2016 08:02:55 GMT Daniel Hellstrom [0d31dcc] * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: split DMA sem into RX and TX sem By introducing a ... Thu, 07 Apr 2016 07:36:37 GMT Daniel Hellstrom [7701c37] * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: coding style fix Wed, 30 Mar 2016 12:29:52 GMT Daniel Hellstrom [77856f6] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: allow user controlled DMA intr The user has ... Tue, 29 Mar 2016 12:59:59 GMT Daniel Hellstrom [1ef9caa2] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: support for reading tx/rx DMA queue * Add support ... Wed, 23 Mar 2016 09:45:26 GMT Daniel Hellstrom [eb5a42f6] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: fixed device/dma closing The user is now ... Wed, 23 Mar 2016 08:57:10 GMT Daniel Hellstrom [36c3fbbd] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) leon, grspw_pkt: coding style fixups Tue, 22 Mar 2016 15:41:51 GMT Daniel Hellstrom [9cb7e5d] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: fixed and improved RX/TX wait Tue, 22 Mar 2016 15:07:51 GMT Daniel Hellstrom [57e1f4c3] * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: fixed error return path in dma_open Tue, 22 Mar 2016 14:51:13 GMT Daniel Hellstrom [ac7da5bc] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: Manual handling of link status events Added ... Tue, 22 Mar 2016 14:37:36 GMT Daniel Hellstrom [49cf776e] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: added link_ctrl options Improved the link error ... Tue, 22 Mar 2016 12:59:56 GMT Daniel Hellstrom [fad4324d] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: added grspw_link_status_clr() to API Tue, 22 Mar 2016 10:42:10 GMT Daniel Hellstrom [c442647f] * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: code style clean-ups Mon, 21 Mar 2016 14:02:58 GMT Daniel Hellstrom [61cc024a] * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) leon, gptimer: start/reset must take RS and IP into account Mon, 21 Mar 2016 12:50:27 GMT Daniel Hellstrom [b109add] * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c (modified) leon: Fix ambapp_bus OCCAN device registeration order NOTE that ... Tue, 27 Oct 2015 11:41:50 GMT Martin Aberg [6ecad1d] * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: Preserve DMA address enable at start. The EN bit ... Tue, 20 Oct 2015 09:25:06 GMT Martin Aberg [a48bfc0f] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) leon, grspw_pkt: Fixed txpkt flag for link error There was a mixup ... Tue, 30 Jun 2015 13:00:51 GMT Martin Aberg [3395ca99] * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: Fixed parameter check in grspw_dma_open() Mon, 13 Apr 2015 07:01:54 GMT Daniel Hellstrom [4431f7d] * c/src/lib/libbsp/sparc/shared/include/gr1553b.h (modified) leon, gr1553b: RT status words register declarations fix The fix ... Fri, 02 Jan 2015 12:18:33 GMT Daniel Hellstrom [d745297] * c/src/lib/libbsp/sparc/shared/include/gr1553b.h (modified) leon, gr1553b: comment cleanup Fri, 02 Jan 2015 12:16:10 GMT Daniel Hellstrom [be66bbc1] * c/src/lib/libbsp/sparc/shared/spw/grspw.c (modified) leon, grspw: rxPktSize must set DMA RX max length Wed, 15 Feb 2017 11:57:56 GMT Sebastian Huber [bc744618] * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) bsps/sparc: Fix warnings Thu, 12 Jan 2017 22:12:51 GMT Joel Sherrill [1fcdd639] * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/m68k/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/or1k/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/sparc/shared/startup/linkcmds.base (modified) powerpc/shared/linkcmds.base: Add .rela.rtemsroset and .rela.rtemsrwset Thu, 12 Jan 2017 15:36:26 GMT Christian Spindeldreier [a1e4e3bf] * c/src/lib/libbsp/sparc/shared/net/greth.c (modified) GRETH: Interrupt Handler Uses Wrong Events closes #2796. Wed, 07 Dec 2016 06:20:38 GMT Chris Johns [c6eead1] * c/src/lib/libbsp/sparc/erc32/make/custom/erc32-testsuite.tcfg (deleted) * cpukit/libdl/Makefile.am (modified) * cpukit/libdl/dlfcn.c (modified) * cpukit/libdl/rtl-allocator.c (modified) * cpukit/libdl/rtl-allocator.h (modified) * cpukit/libdl/rtl-debugger.c (modified) * cpukit/libdl/rtl-elf.c (modified) * cpukit/libdl/rtl-elf.h (modified) * cpukit/libdl/rtl-error.c (modified) * cpukit/libdl/rtl-mdreloc-arm.c (modified) * cpukit/libdl/rtl-mdreloc-bfin.c (modified) * cpukit/libdl/rtl-mdreloc-h8300.c (modified) * cpukit/libdl/rtl-mdreloc-i386.c (modified) * cpukit/libdl/rtl-mdreloc-lm32.c (modified) * cpukit/libdl/rtl-mdreloc-m68k.c (modified) * cpukit/libdl/rtl-mdreloc-mips.c (modified) * cpukit/libdl/rtl-mdreloc-moxie.c (modified) * cpukit/libdl/rtl-mdreloc-powerpc.c (modified) * cpukit/libdl/rtl-mdreloc-sparc.c (modified) * cpukit/libdl/rtl-mdreloc-v850.c (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-obj.h (modified) * cpukit/libdl/rtl-rap.c (modified) * cpukit/libdl/rtl-rap.h (modified) * cpukit/libdl/rtl-unwind-dw2.c (added) * cpukit/libdl/rtl-unwind-dw2.h (added) * cpukit/libdl/rtl-unwind.h (added) * cpukit/libdl/rtl.c (modified) * cpukit/libdl/rtl.h (modified) * testsuites/libtests/dl01/init.c (modified) * testsuites/libtests/dl02/init.c (modified) * testsuites/libtests/dl03/init.c (modified) * testsuites/libtests/dl04/init.c (modified) * testsuites/libtests/dl05/dl-cpp.cpp (modified) * testsuites/libtests/dl05/dl-load.c (modified) * testsuites/libtests/dl05/dl-load.h (modified) * testsuites/libtests/dl05/dl-o5.cpp (modified) * testsuites/libtests/dl05/dl05.scn (modified) * testsuites/libtests/dl05/init.c (modified) libdl: Add C++ exception support to loaded modules. This has been ... Fri, 09 Dec 2016 09:49:49 GMT Sebastian Huber [6a9282d] * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspclean.c (modified) * c/src/lib/libbsp/lm32/milkymist/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mrm332/misc/interr.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/beatnik/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/virtex4/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/virtex5/startup/bspclean.c (modified) * c/src/lib/libbsp/shared/bspclean.c (modified) * c/src/lib/libbsp/shared/include/default-initial-extension.h (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspclean.c (modified) * c/src/lib/libbsp/sparc64/niagara/startup/bspclean.c (modified) * c/src/libchip/shmdr/fatal.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libmisc/testsupport/test.h (modified) * cpukit/libmisc/testsupport/testextension.c (modified) * cpukit/score/include/rtems/score/userext.h (modified) * testsuites/libtests/exit01/init.c (modified) * testsuites/libtests/exit02/init.c (modified) * testsuites/libtests/stackchk/init.c (modified) * testsuites/libtests/stackchk/system.h (modified) * testsuites/psxtests/psxfatal_support/init.c (modified) * testsuites/psxtests/psxfatal_support/system.h (modified) * testsuites/smptests/smpfatal01/init.c (modified) * testsuites/smptests/smpfatal02/init.c (modified) * testsuites/smptests/smpfatal03/init.c (modified) * testsuites/smptests/smpfatal04/init.c (modified) * testsuites/smptests/smpfatal05/init.c (modified) * testsuites/smptests/smpfatal06/init.c (modified) * testsuites/smptests/smpfatal08/init.c (modified) * testsuites/sptests/sperror01/init.c (modified) * testsuites/sptests/sperror02/init.c (modified) * testsuites/sptests/sperror03/init.c (modified) * testsuites/sptests/spextensions01/init.c (modified) * testsuites/sptests/spfatal26/init.c (modified) * testsuites/sptests/spfatal_support/init.c (modified) * testsuites/sptests/spfatal_support/system.h (modified) * testsuites/sptests/spinternalerror01/init.c (modified) * testsuites/sptests/spmutex01/init.c (modified) * testsuites/sptests/spsyslock01/init.c (modified) Rename is_internal to always_set_to_false Update #2825. Mon, 05 Dec 2016 03:53:54 GMT Chris Johns [28fda62] * c/src/lib/libbsp/arm/atsam/make/custom/atsamv-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s3749-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s6965-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm4f120-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc17xx_ea_rom_int-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc17xx_plx800_rom_int-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc2362-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc24xx_ncs_rom_int-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc24xx_plx800_rom_int-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc40xx_ea_rom_int-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx_mzx_stage_1-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/rtl22xx/make/custom/rtl22xx-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/rtl22xx/make/custom/rtl22xx_t-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/stm32f4/make/custom/stm32f105rc-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/stm32f4/make/custom/stm32f4-testsuite.tcfg (modified) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram-testsuite.tcfg (modified) * c/src/lib/libbsp/m32c/m32cbsp/make/custom/m32csim-testsuite.tcfg (modified) * c/src/lib/libbsp/m68k/mcf5206elite/make/custom/mcf5206elite-testsuite.tcfg (modified) * c/src/lib/libbsp/m68k/mcf52235/make/custom/mcf52235-testsuite.tcfg (modified) * c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x-testsuite.tcfg (modified) * c/src/lib/libbsp/m68k/mrm332/make/custom/mrm332-testsuite.tcfg (modified) * c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162-testsuite.tcfg (modified) * c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162lx-testsuite.tcfg (modified) * c/src/lib/libbsp/mips/hurricane/make/custom/hurricane-testsuite.tcfg (modified) * c/src/lib/libbsp/mips/jmr3904/make/custom/jmr3904-testsuite.tcfg (modified) * c/src/lib/libbsp/mips/rbtx4925/make/custom/rbtx4925-testsuite.tcfg (modified) * c/src/lib/libbsp/mips/rbtx4938/make/custom/rbtx4938-testsuite.tcfg (modified) * c/src/lib/libbsp/or1k/generic_or1k/make/custom/generic_or1k-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/gwlcfm-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5566evb-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5566evb_spe-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5643l_dpu-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5643l_evb-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5668g-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_ecu508_app-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_ecu508_boot-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674f_rsm6-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674fevb-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5674fevb_spe-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/phycore_mpc5554-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_core_0-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_core_1-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_p1020rdb-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_t2080rdb-testsuite.tcfg (modified) * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq_t4240rdb-testsuite.tcfg (modified) * c/src/lib/libbsp/sh/gensh1/make/custom/gensh1-testsuite.tcfg (modified) * c/src/lib/libbsp/sh/gensh2/make/custom/gensh2-testsuite.tcfg (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh1-testsuite.tcfg (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh2-testsuite.tcfg (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh2e-testsuite.tcfg (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh4-testsuite.tcfg (modified) * c/src/lib/libbsp/sparc/erc32/make/custom/erc32-testsuite.tcfg (added) * testsuites/automake/compile.am (modified) * testsuites/automake/test-subdirs.am (modified) * testsuites/support/include/buffer_test_io.h (modified) * testsuites/testdata/disable-intrcritical-tests.tcfg (modified) * testsuites/testdata/disable-jffs2-tests.tcfg (modified) * testsuites/testdata/disable-mrfs-tests.tcfg (modified) * testsuites/testdata/dltests-broken-on-this-bsp.tcfg (modified) * testsuites/testdata/require-tick-isr.tcfg (modified) * tools/build/rtems-test-check (modified) testsuite: Add test states to the testsuit configuration files. ... Tue, 15 Nov 2016 18:19:39 GMT Joel Sherrill [de7b174e] * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/make/custom/sis.cfg (deleted) * c/src/lib/libbsp/sparc/erc32/timer/timer.c (modified) * c/src/lib/libbsp/sparc/leon2/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) Remove sparc/sis BSP. closes #2810. Tue, 22 Nov 2016 09:13:27 GMT Sebastian Huber [6a1b9e4] * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libcpu/sparc/syscall/syscall.S (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) sparc: Optimize _ISR_Handler() Use _Thread_Do_dispatch() instead of ... Mon, 14 Nov 2016 13:42:56 GMT Sebastian Huber [c11ac2d5] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/rtems/score/cpuimpl.h (modified) sparc: Use Per_CPU_Control::isr_dispatch_disable Update #2751. Fri, 11 Nov 2016 13:37:51 GMT Sebastian Huber [d5e073c] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/include/rtems/score/userextimpl.h (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadloadenv.c (modified) score: Allow interrupts during thread dispatch Use a ... Mon, 14 Nov 2016 10:34:54 GMT Sebastian Huber [c539a865] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) * cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S (modified) sparc: Move CPU_Interrupt_frame related defines Move ... Fri, 11 Nov 2016 10:17:02 GMT Sebastian Huber [427dcee] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) * cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S (modified) sparc: Rename CPU_Minimum_stack_frame Rename SPARC-specific ... Mon, 07 Nov 2016 15:54:40 GMT Sebastian Huber [1f5bee3] * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c (modified) * c/src/lib/libcpu/bfin/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/threadcreateidle.c (modified) * testsuites/sptests/spintrcritical_support/intrcritical.c (modified) score: Add and use Thread_Control::is_idle Update #2797. Wed, 02 Nov 2016 09:01:36 GMT Sebastian Huber [fac8a3a] * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libbsp/sparc/shared/startup/linkcmds.base (modified) bsps/sparc: Fix copy of initialized data The text and data sections ... Tue, 18 Oct 2016 22:22:57 GMT Sebastian Huber [f94155b] * c/src/lib/libbsp/sparc/shared/include/grlib.h (modified) bsps/sparc: Add interrupt controller registers Tue, 18 Oct 2016 22:21:21 GMT Sebastian Huber [9361412] * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) bsp/leon3: Avoid implicit integer conversions Tue, 11 Oct 2016 06:25:39 GMT Sebastian Huber [00bac95] * c/src/lib/libbsp/sparc/shared/include/grlib.h (modified) bsps/sparc: Support GR740 GPIO Fri, 16 Sep 2016 10:58:06 GMT Sebastian Huber [55e0be36] * c/src/lib/libbsp/arm/atsam/console/console.c (modified) * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) * c/src/lib/libbsp/powerpc/t32mppc/console/console.c (modified) * c/src/lib/libbsp/shared/console-termios-init.c (modified) * c/src/lib/libbsp/shared/console-termios.c (modified) * c/src/lib/libbsp/shared/include/console-termios.h (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios.c (modified) * testsuites/libtests/termios01/init.c (modified) * testsuites/psxtests/psxfile01/test.c (modified) termios: Use IMFS nodes for new Termios devices This makes the new ... Wed, 22 Jun 2016 11:45:02 GMT Sebastian Huber [655ce0fb] * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon2/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/cpucounter.c (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/preinstall.am (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/sparcimpl.h (added) * cpukit/score/cpu/sparc/sparc-counter.c (modified) sparc: Optimize CPU counter support Tue, 21 Jun 2016 08:24:13 GMT Sebastian Huber [a4ff2a2] * c/src/lib/libbsp/shared/include/fatal.h (modified) * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) bsp/leon3: Add up counter timecounter Tue, 21 Jun 2016 08:58:04 GMT Sebastian Huber [291945f1] * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) bsp/leon3: Fix interrupt timestamping Close #2684.
