@94c17af
06/03/13 08:03:10 |
Sebastian Huber |
bsp/qoriq: Add missing #ifdef RTEMS_SMP
4.115
@bd39add
05/31/13 08:08:43 |
Sebastian Huber |
bsp/qoriq: Add SMP support
4.115
@9344677
05/21/13 13:58:12 |
Sebastian Huber |
bsp/qoriq: Avoid NULL pointer access
4.115
@cab410f
05/21/13 12:19:24 |
Sebastian Huber |
bsps: Update due to linker changes
In case the VMA and LMA regions …
4.115
@92d8038
04/19/13 09:53:07 |
Sebastian Huber |
bsp/mpc5200: New BSP variant BRS6L
4.115
@7a44d06
04/19/13 12:17:09 |
Sebastian Huber |
bsp/mpc5200: Change SDRAM initialization
Change SDRAM initialization …
4.115
@d4a4811
04/19/13 12:01:47 |
Sebastian Huber |
bsp/mpc5200: Set SDELAY register
4.115
@dbe6aae7
04/19/13 11:51:54 |
Sebastian Huber |
bsp/mpc5200: Move CSBOOTROM_VAL definition
4.115
@e79e904
04/19/13 11:50:34 |
Sebastian Huber |
bsp/mpc5200: Move comment
4.115
@6c094da
04/19/13 11:48:48 |
Sebastian Huber |
bsp/mpc5200: Change ADREN register defines
4.115
@2793778
04/19/13 11:00:14 |
Sebastian Huber |
bsp/mpc5200: Remove Erratum 342/339 comment
4.115
@be04e62
04/19/13 10:51:57 |
Sebastian Huber |
bsp/mpc5200: Set XLB timeout values
4.115
@5e920ceb
04/19/13 10:50:10 |
Sebastian Huber |
bsp/mpc5200: Do not initialize debug registers
4.115
@740abbd
04/17/13 13:57:20 |
Sebastian Huber |
bsp/mpc5200: Add and use enable_bat_4_to_7()
4.115
@d5587f9f
04/17/13 14:03:03 |
Sebastian Huber |
bsp/mpc5200: Fix cache handling
4.115
@47fb2fe
04/11/13 15:22:02 |
Sebastian Huber |
bsp/mpc5200: Add MPC5200_BOARD prefix
4.115
@db21e1d
04/03/13 10:05:49 |
Sebastian Huber |
bsp/mpc55xx: eDMA API changes
4.115
@db0ed4c5
04/08/13 08:43:42 |
Sebastian Huber |
bsp/mpc55xx: Add PCR index enumeration
4.115
@7806a2b5
04/05/13 14:05:30 |
Sebastian Huber |
bsp/mpc55xx: New define MPC55XX_PERIPHERAL_CLOCK
4.115
@15c7657
04/05/13 14:05:03 |
Sebastian Huber |
bsp/mpc55xx: Rename BSP option
4.115
@30158371
04/03/13 10:10:25 |
Sebastian Huber |
bsp/mpc55xx: New fatal errors
4.115
@055f1f4c
04/08/13 13:21:37 |
Sebastian Huber |
bsp/mpc55xx: Include <bsp/linker-symbols.h>
4.115
@087a29b4
04/08/13 14:13:18 |
Sebastian Huber |
bsp/mpc55xx: Fix warnings
4.115
@5ab9b13
04/08/13 07:45:45 |
Sebastian Huber |
bsps/powerpc: Use proper type
4.115
@166d78f
04/08/13 07:45:09 |
Sebastian Huber |
bsp/gen5200: Fix syntax
4.115
@dea6fb6
04/02/13 14:01:05 |
Sebastian Huber |
bsp/gen5200: Typo
4.115
@0841c07
04/02/13 13:58:40 |
Sebastian Huber |
bsp/gen5200: Elaborate option help message
4.115
@fa77ad4b
04/02/13 13:50:23 |
Sebastian Huber |
bsp/gen5200: Remove superfluous option definition
4.115
@aa11df6
03/28/13 08:25:07 |
Sebastian Huber |
bsp/gen5200: Use busy wait
The usage of rtems_task_wake_after() is …
4.115
@d1e1df68
03/28/13 08:24:11 |
Sebastian Huber |
bsp/gen5200: Use fatal error instead of assert
4.115
@7b14e8b
03/21/13 09:46:03 |
Sebastian Huber |
bsp/mpc83xx: Add MPC83XX_NET*_INTERFACE_0_PHY_ADDR
4.115
@6457fb29
03/19/13 09:12:06 |
Sebastian Huber |
bsp/psim: Use shared linkcmds.base
Several GCC tests faild due to the …
4.115
@df6818f9
03/18/13 14:24:00 |
Sebastian Huber |
bsps: Support DWARF extension
4.115
@faad192
03/11/13 16:54:34 |
Sebastian Huber |
mpc83xx: Add and use mpc83xx_reset()
The inline version makes it …
4.115
@f88da30
03/11/13 16:50:27 |
Sebastian Huber |
mpc83xx: Use shared linkcmds.base
4.115
@b34401cc
03/11/13 16:44:51 |
Sebastian Huber |
mpc83xx: Copy nothing if necessary
4.115
@9e25621
03/11/13 16:44:19 |
Sebastian Huber |
mpc83xx: Fix local access window 1 configuration
4.115
@907b07d9
03/11/13 16:43:08 |
Sebastian Huber |
mpc83xx: Add MPC83XX_HAS_NAND_LP_FLASH_ON_CS0
4.115
@dbc983c
03/11/13 19:28:06 |
Joel Sherrill |
mvme3100/Makefile.am: Remove reference to ChangeLog?
4.115
@b1f105e1
03/11/13 19:27:50 |
Joel Sherrill |
beatnik/Makefile.am: Remove reference to ChangeLog?
4.115
@fad2d38
03/08/13 20:55:06 |
Gedare Bloom |
RTEMS: Delete ChangeLog? files.
This commit deletes all RTEMS …
4.115
@57bcb88e
02/18/13 16:00:28 |
Sebastian Huber |
bsp/gen5200: New ATA driver
This is a replacement for the ATA task. …
4.115
@c7a5656
02/18/13 15:29:32 |
Sebastian Huber |
bsp/gen5200: Add and use mpc5200_fatal()
4.115
@ced11eb1
02/18/13 15:27:50 |
Sebastian Huber |
bsp/mpc55xx: Fix prototype
4.115
@7b859d59
02/12/13 10:24:40 |
Sebastian Huber |
bsps/powerpc: Remove unused files
4.115
@c8bd3cd
02/08/13 12:39:59 |
Sebastian Huber |
libchip/serial: Add const qualifier
4.115
@4b53f191
02/06/13 10:38:29 |
Sebastian Huber |
bsp/mpc55xx: Add MPC55XX_ENABLE_START_PROLOGUE
4.115
@dc5cd79
02/06/13 10:37:26 |
Sebastian Huber |
bsp/mpc55xx: Merge RSM6 variants into one
4.115
@c082b575
02/05/13 16:23:55 |
Sebastian Huber |
bsp/mpc55xx: Add and use BSP specific fatal codes
4.115
@c934a10d
01/11/13 13:41:53 |
Sebastian Huber |
bsp/mpc55xx: Add BSP_DATA_CACHE_USE_WRITE_THROUGH
4.115
@4dafa52
01/28/13 11:38:55 |
Sebastian Huber |
bsp/mpc55xx: Fix MMU configuration for RSM6
4.115
@967278f
01/23/13 00:16:37 |
Ric Claus |
Fixed virtex4,5 BSP compile time warnings
4.115
@7f7b09c
01/18/13 08:48:38 |
Sebastian Huber |
bsp/gen83xx: Disable caches in bsp_restart()
4.115
@f7351e4
01/14/13 07:16:04 |
Sebastian Huber |
bsp/virtex5: Fix define location
4.115
@da80202
01/09/13 13:31:58 |
Sebastian Huber |
bsp/gen83xx: Register I2C SEMTECH SC620 driver
4.115
@aeff597
01/09/13 12:17:18 |
Sebastian Huber |
bsps/powerpc: Add probe handler to I2C driver
4.115
@bfde536e
01/09/13 10:12:48 |
Sebastian Huber |
bsp/gen83xx: Invalidate caches only if disabled
4.115
@5828127
01/09/13 08:29:04 |
Sebastian Huber |
bsp/gen83xx: System reset after fatal conditions
4.115
@d4e2f337
01/09/13 08:28:19 |
Sebastian Huber |
bsp/gen83xx: Add bsp_restart()
4.115
@253cb8b5
01/08/13 09:37:41 |
Sebastian Huber |
bsp/gen83xx: Delete obsolete region
4.115
@566c05c
12/19/12 12:41:27 |
Sebastian Huber |
bsp/gen83xx: Fix CSB clock calculation for MPC8309
4.115
@80232ee7
12/07/12 08:50:27 |
Sebastian Huber |
bsps/powerpc: Use explicit compiler options
4.115
@48bff53b
12/06/12 16:47:30 |
Sebastian Huber |
score: rtems_initialize_start_multitasking()
Do not return from …
4.115
@40fe4b86
12/06/12 16:40:08 |
Sebastian Huber |
bsps: Use <bsp/bootcard.h>
4.115
@2858aeb9
11/23/12 16:25:54 |
Sebastian Huber |
bsp/mpc55xx: New BSP variants for RSM6
4.115
@e1e248f
11/26/12 16:02:44 |
Sebastian Huber |
bsp/mpc55xx: Add optional EBI configuration
4.115
@f4309b0
11/26/12 15:58:58 |
Sebastian Huber |
bsp/mpc55xx: Use RTEMS_ARRAY_SIZE()
4.115
@29919ec0
11/23/12 14:12:41 |
Sebastian Huber |
bsp/mpc55xx: Add .sysram section
4.115
@65ab304b
11/23/12 13:47:47 |
Sebastian Huber |
bsp/mpc55xx: Add .dsram section
4.115
@bb3090c5
11/23/12 13:43:04 |
Sebastian Huber |
bsp/mpc55xx: Delete <bsp/mpc55xxevb.h>
4.115
@113768f
11/23/12 13:16:11 |
Sebastian Huber |
bsps/powerpc: Add .nvram section
4.115
@95aebbe
11/23/12 09:11:55 |
Sebastian Huber |
bsp/mpc55xx: Add and use STARTROM
4.115
@840dd00
11/23/12 09:11:22 |
Sebastian Huber |
bsp/mpc55xx: Add and use linkcmds.mpc5674f_ecu508
4.115
@c6d35ad4
11/21/12 08:46:58 |
Sebastian Huber |
bsp/mpc55xx: Errata e4396 for e200z7
4.115
@2e80662
11/19/12 08:12:07 |
Sebastian Huber |
bsp/mpc55xx: Set PPC_EXC_CONFIG_BOOKE_ONLY
4.115
@3ce66aa
11/19/12 08:02:12 |
Sebastian Huber |
bsp/mpc55xx: Set PPC_EXC_CONFIG_USE_FIXED_HANDLER
4.115
@1c479be4
11/16/12 09:06:07 |
Sebastian Huber |
bsp/mpc55xx: Documentation
4.115
@fee41c9
12/03/12 12:08:42 |
Sebastian Huber |
bsp/mpc55xx: Add and use mpc55xx_fatal_code
4.115
@6eb0ce2
11/15/12 16:33:15 |
christian.mauderer |
bsp/mpc55xx: Fix SMSC9218I MAC address setting
4.115
@da2fa4eb
11/15/12 16:01:29 |
Sebastian Huber |
bsp/mpc55xx: Remove BSP_panic()
4.115
@67338ed
11/15/12 15:57:02 |
Sebastian Huber |
bsp/mpc55xx: Add mpc55xx_wait_for_interrupt()
Use …
4.115
@2d561b9
11/13/12 13:39:19 |
Sebastian Huber |
bsp/mpc55xx: Use BSP_START_DATA_SECTION
4.115
@6c454104
11/13/12 10:50:38 |
Sebastian Huber |
bsp/mpc55xx: Fix no-cache section load
4.115
@fe1a4e4b
11/21/12 08:54:32 |
Sebastian Huber |
bsp/qoriq: Set PPC_EXC_CONFIG_BOOKE_ONLY
4.115
@f6999e6
11/21/12 08:54:12 |
Sebastian Huber |
bsp/qoriq: Set PPC_EXC_CONFIG_USE_FIXED_HANDLER
4.115
@c383372
11/13/12 14:01:24 |
Sebastian Huber |
bsps/powerpc: Add and use bsp_text input section
4.115
@d33f743
11/13/12 14:00:53 |
Sebastian Huber |
bsps/powerpc: Move .fast_text after .text section
4.115
@f665f13
11/19/12 07:37:04 |
Sebastian Huber |
bsps/powerpc: Add PPC_EXC_CONFIG_BOOKE_ONLY
In combination with the …
4.115
@4bd4c9e
11/23/12 08:32:52 |
Sebastian Huber |
bsps/powerpc: Add PPC_EXC_CONFIG_USE_FIXED_HANDLER
In case a BSP …
4.115
@3bf002a
11/30/12 12:21:37 |
Sebastian Huber |
bsp/gen83xx: Workaround for USB stack
4.115
@7ac89a6f
11/30/12 12:14:34 |
Sebastian Huber |
bsp/gen83xx: Add sections for USB stack
4.115
@655bd39
11/30/12 23:58:32 |
Ric Claus |
Virtex5 BSP: Various updates and improvements.
This BSP now uses the …
4.115
@5b822ab
11/30/12 23:56:04 |
Ric Claus |
Virtex4 BSP: Various updates and improvements.
Switched to using the …
4.115
@815994f
11/25/12 16:48:11 |
Sebastian Huber |
score: Add CPU_Exception_frame
Add CPU port type CPU_Exception_frame …
4.115
@f0e3cc0
11/26/12 16:52:01 |
Sebastian Huber |
bsps/powerpc: Delete unused EXC_DAR field
The Data Access Register …
4.115
@39aa75e7
11/23/12 21:40:09 |
Sebastian Huber |
bsps: Use RTEMS_BSP_CLEANUP_OPTIONS
4.115
@7ca64d69
11/20/12 07:36:25 |
Sebastian Huber |
bsp/mpc55xx: Update due to API changes
4.115
@b1e8a58
11/14/12 08:57:55 |
Sebastian Huber |
bsps/powerpc: Exception initialization error is fatal
4.115
@dd8df59
11/14/12 12:59:27 |
Sebastian Huber |
bsps: Interrupt initialization error is fatal
4.115
@a052181
11/14/12 08:59:10 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_EXIT
Include …
4.115
