Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src/lib/libbsp/powerpc
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @582e4272   04/22/16 11:09:39 Sebastian Huber bsp/qoriq: Move L1 cache invalidate function 5
(edit) @0ac0632   04/22/16 08:28:00 Sebastian Huber bsp/qoriq: Do not reset time base We may use this as an entropy source. 5
(edit) @d35e6dde   04/22/16 12:10:47 Sebastian Huber powerpc: Add FSL_EIS_TENSR, etc. defines 5
(edit) @c287dc0   04/21/16 10:37:25 Sebastian Huber bsp/qoriq: Flush and invalidate all L2 caches 5
(edit) @6a46d99   04/21/16 09:39:28 Sebastian Huber bsp/qoriq: Optionally initialize register HID0 Enable the L2MMU … 5
(edit) @a12724f9   04/14/16 05:57:38 Sebastian Huber bsp/qoriq: Fix MMU initialization for e6500 In case a hypervisor mode … 5
(edit) @09a21c5   03/30/16 19:04:23 joel powerpc/virtex5/include/bsp.h: Do not include <rtems/iosupp.h> 5
(edit) @bea9a25   03/30/16 19:04:23 joel powerpc/virtex4/include/bsp.h: Do not include <rtems/iosupp.h> 5
(edit) @c9705f0   03/30/16 19:04:23 joel powerpc/virtex/include/bsp.h: Do not include <rtems/iosupp.h> 5
(edit) @d379a629   03/30/16 19:04:23 joel powerpc/qemuppc/include/bsp.h: Do not include <rtems/iosupp.h> 5
(edit) @c5ecb95   03/30/16 19:04:23 joel powerpc/psim/include/bsp.h: Do not include <rtems/iosupp.h> 5
(edit) @bf820a6f   03/30/16 19:04:23 joel powerpc/haleakala/include/bsp.h: Do not include <rtems/iosupp.h> 5
(edit) @c30d6686   03/30/16 14:10:53 joel powerpc/gen5200/include/bsp.h: Remove unnecessary include of <rtems/rtc.h> 5
(edit) @c228bd93   03/29/16 18:10:52 joel powerpc/virtex5: Remove include of <rtems/console.h> from <bsp.h> and … 5
(edit) @0b2ea32   03/29/16 18:10:52 joel powerpc/virtex4: Remove include of <rtems/console.h> from <bsp.h> and … 5
(edit) @ac0ecf27   03/29/16 18:10:52 joel powerpc/virtex: Remove include of <rtems/console.h> from <bsp.h> and … 5
(edit) @2a8afe1   03/29/16 18:10:52 joel powerpc/tqm8xx: Remove include of <rtems/console.h> from <bsp.h> and … 5
(edit) @8d1a5a3   03/29/16 18:10:52 joel powerpc/t32mppc: Remove include of <rtems/console.h> from <bsp.h> and … 5
(edit) @ed29ced   03/29/16 18:10:52 joel powerpc/ss555: Remove include of <rtems/console.h> from <bsp.h> and … 5
(edit) @97ea73fe   03/29/16 18:10:52 joel powerpc/qemuppc: Remove include of <rtems/console.h> from <bsp.h> and … 5
(edit) @f37e259a   03/29/16 18:10:52 joel powerpc/psim: Remove include of <rtems/console.h> from <bsp.h> and fix … 5
(edit) @78816f4   03/29/16 18:10:52 joel powerpc/mvme5500: Remove include of <rtems/console.h> from <bsp.h> and … 5
(edit) @899f6357   03/29/16 18:10:52 joel powerpc/mvme3100: Remove include of <rtems/console.h> from <bsp.h> and … 5
(edit) @629555cf   03/29/16 18:10:52 joel powerpc/mpc8260ads: Remove include of <rtems/console.h> from <bsp.h> … 5
(edit) @a2abd26   03/29/16 18:10:52 joel powerpc/mpc55xxevb: Remove include of <rtems/console.h> from <bsp.h> … 5
(edit) @c093f37   03/29/16 18:10:52 joel powerpc/motorola_powerpc: Remove include of <rtems/console.h> from … 5
(edit) @3f9ce5b9   03/29/16 18:10:52 joel powerpc/haleakala: Remove include of <rtems/console.h> from <bsp.h> … 5
(edit) @6c5d7181   03/29/16 18:10:52 joel powerpc/gen83xx: Remove include of <rtems/console.h> from <bsp.h> and … 5
(edit) @93ba1d55   03/29/16 18:10:52 joel powerpc/gen5200: Remove include of <rtems/console.h> from <bsp.h> and … 5
(edit) @13279f5e   03/29/16 18:10:52 joel powerpc/beatnik: Remove include of <rtems/console.h> from <bsp.h> and … 5
(edit) @b02c77c6   03/29/16 17:54:00 joel powerpc/shared/console/console.c: Add include of <rtems/console.h> to … 5
(edit) @ffa9cbf   03/29/16 06:11:29 Sebastian Huber bsps/powerpc: Avoid recursion in exception handler 5
(edit) @6f9c3e55   03/23/16 10:24:18 Sebastian Huber bsp/motorola_powerpc: README.qemu 5
(edit) @01096ad   03/25/16 15:47:17 joel powerpc/virtex5/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @7b107c24   03/25/16 15:47:17 joel powerpc/virtex4/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @667b0c15   03/25/16 15:47:17 joel powerpc/virtex/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @022432d   03/25/16 15:47:17 joel powerpc/tqm8xx/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @17de5f0   03/25/16 15:47:17 joel powerpc/t32mppc/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @83b1c4c2   03/25/16 15:47:16 joel powerpc/ss555/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @37770be1   03/25/16 15:47:16 joel powerpc/qemuppc/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @a3ce764   03/25/16 15:47:16 joel powerpc/psim/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @5f72835   03/25/16 15:47:16 joel powerpc/mvme5500/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @b951a2b   03/25/16 15:47:16 joel powerpc/mvme3100/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @d04bf84d   03/25/16 15:47:15 joel powerpc/mpc8260ads/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @a853c061   03/25/16 15:47:14 joel powerpc/mpc55xxevb/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @227399d   03/25/16 15:47:12 joel powerpc/motorola_powerpc/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @b63f12a   03/25/16 15:47:10 joel powerpc/haleakala/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @0ee0eae   03/25/16 15:47:09 joel powerpc/gen83xx/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @ec5b3f0   03/25/16 15:47:09 joel powerpc/gen5200/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @a632950   03/25/16 15:47:08 joel powerpc/beatnik/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @561dec5   03/21/16 15:53:32 joel powerpc/shared/openpic/openpic.c: Ignore warnings for … 5
(edit) @e12f4e17   03/18/16 09:58:41 Sebastian Huber bsp/qoriq: Invalidate TLS anchor 5
(edit) @b0443736   03/16/16 09:29:48 Sebastian Huber bsp/mpc55xx: Fix BSS initialization 5
(edit) @057154e   03/15/16 07:15:53 Sebastian Huber bsp/beatnik: Delete unused linkcmds file 5
(edit) @734118d9   03/14/16 09:55:57 Sebastian Huber bsp/qoriq: Fix interrupt numbers 5
(edit) @45e5623   03/10/16 23:22:59 joel powerpc/motorola_powerpc: Add per-section compilation and linking … 5
(edit) @9430052   03/09/16 21:45:44 joel powerpc/mvme5500: Use shared pci_find_device() 5
(edit) @90d8567   02/18/16 07:36:16 Sebastian Huber score: Distribute clock tick to all online CPUs Update #2554. 5
(edit) @cc1add7b   03/03/16 08:49:15 Sebastian Huber bsps: Delete empty Clock_driver_support_at_tick() 5
(edit) @73de9393   03/02/16 12:32:44 Sebastian Huber bsp/qoriq: Do not touch MMU config for SMP start Assume that the boot … 5
(edit) @e468ba5   03/03/16 08:08:08 Sebastian Huber U-Boot: Flush data cache after bdinfo copy 5
(edit) @aaa21b1   02/06/16 16:19:46 joel powerpc/.../ss555.cfg: Correct ticket number in comment 5
(edit) @406b3b7   02/06/16 16:18:41 joel powerpc/.../qemuppc.cfg: Correct ticket number in comment 5
(edit) @6564bd2   02/06/16 16:17:59 joel powerpc/.../mpc8260ads.cfg: Correct ticket number in comment 5
(edit) @068b3125   02/06/16 15:35:21 joel powerpc/.../mpc8260ads.cfg: Disable per function sections updates #2565. 5
(edit) @8926fad   02/06/16 14:53:30 joel powerpc/.../qemuppc.cfg: Disable per function sections updates #2564. 5
(edit) @72d8e64c   02/06/16 14:50:26 joel powerpc/.../ss555.cfg: Disable per function sections. updates #2563. 5
(edit) @c5ce9c3c   02/05/16 13:51:48 joel powerpc/.../haleakala.cfg: Disable per function sections. updates #2561. 5
(edit) @3bc12a8f   01/26/16 10:16:56 Sebastian Huber Delete unused API extensions 5
(edit) @8ca372e   01/26/16 09:11:48 Sebastian Huber Use linker set for MPCI initialization Update #2408. 5
(edit) @ca4602e   01/25/16 21:03:00 Sebastian Huber Use linker set for libio initialization Update #2408. 5
(edit) @ab8e821   01/27/16 06:33:50 Sebastian Huber bsps/powerpc: Fix startup Do work area initialization after … 5
(edit) @0aeeca42   01/24/16 23:43:58 ralph powerpc/gen83xx: Add per-section compilation and linking support. For … 5
(edit) @8c7c891   01/24/16 16:55:49 ralph powerpc/mpc55xxevb: Add per-section compilation and linking support. … 5
(edit) @2dca2e6   01/23/16 22:49:29 joel Obsolete and remove powerpc/mbx8xx closes #2545. 5
(edit) @6d21c13e   01/23/16 21:15:40 ralph powerpc/gen5200: Add per-section compilation and linking support. For … 5
(edit) @0a9ee085   01/23/16 20:40:27 ralph powerpc/tqm8xx: Add per-section compilation and linking support. For … 5
(edit) @413cd7f   01/23/16 19:46:19 ralph powerpc/mbx8xx: Add per-section compilation and linking support. For … 5
(edit) @4e98ffa0   01/23/16 18:42:55 ralph powerpc/haleakala: Add per-section compilation and linking support. … 5
(edit) @82bf2773   01/23/16 18:40:43 ralph powerpc/virtex5: Add per-section compilation and linking support. The … 5
(edit) @4ba2eb41   01/23/16 18:38:17 ralph powerpc/virtex4: Add per-section compilation and linking support. The … 5
(edit) @005c3547   01/23/16 18:35:51 ralph powerpc/virtex: Add per-section compilation and linking support. The … 5
(edit) @99a03876   01/23/16 18:33:18 ralph powerpc/t32mppc: Add per-section compilation and linking support. The … 5
(edit) @c663474   01/23/16 18:31:10 ralph powerpc/ss555: Add per-section compilation and linking support. The … 5
(edit) @cfd0336   01/23/16 18:28:42 ralph powerpc/qemuppc: Add per-section compilation and linking support. The … 5
(edit) @cc30900   01/23/16 18:26:15 ralph powerpc/mvme5500: Add per-section compilation and linking support. … 5
(edit) @e5e0acd   01/23/16 18:23:43 ralph powerpc/mvme3100: Add per-section compilation and linking support. … 5
(edit) @5adc3b6   01/23/16 18:21:11 ralph powerpc/mpc8260ads: Add per-section compilation and linking support. … 5
(edit) @3a84377   01/23/16 18:18:41 ralph powerpc/beatnik: Add per-section compilation and linking support. The … 5
(edit) @ac84d42e   10/26/15 08:10:22 Sebastian Huber bsp/qoriq: Function and data sections 5
(edit) @76ac1ee3   12/23/15 06:29:47 Sebastian Huber score: Fix simple timecounter support Update #2502. 5
(edit) @b308f23   11/24/15 07:31:16 Sebastian Huber bsp/qoriq: Use array for FMan modules 5
(edit) @c37710b   01/05/16 23:33:47 joel powerpc/psim: Add per-section compilation and linking support The … 5
(edit) @ebcf458   12/26/15 16:59:48 Joel Sherrill powerpc/qemuppc/configure.ac: Correct typo 5
(edit) @2268ee6   12/24/15 22:45:59 Joel Sherrill libbsp/bfin and libbsp/powerpc acinclude.m4 regenerate 5
(edit) @d5154d0f   12/23/15 20:44:02 admin api: Remove deprecated Notepads Notepads where a feature of RTEMS' … 5
(edit) @af418e8f   12/15/15 03:31:21 Joel Sherrill configure.ac: Do not reference ep1a 5
(edit) @2858939a   12/09/15 11:03:49 Sebastian Huber bsps: Delete superfluous bsp_pretasking_hook() Use the … 5
(edit) @e7545f1b   12/09/15 10:43:49 Sebastian Huber bsps/powerpc: Use default bsp_pretasking_hook() Update #2408. 5
(edit) @ac78f35   12/09/15 10:23:25 Sebastian Huber bsp/beatnik: Delete superfluous declaration Update #2408. 5
