source: rtems/c/src/lib/libbsp/powerpc
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @55e0be36   09/16/16 10:58:06 Sebastian Huber termios: Use IMFS nodes for new Termios devices This makes the new … 5
(edit) @f383f4bf   07/27/16 09:39:56 Sebastian Huber bsp/qoriq: Remove legacy U-Boot support 5
(edit) @cecc109   07/28/16 08:48:02 Sebastian Huber bsp/qoriq: Fix start stack setup 5
(edit) @6446773   07/28/16 08:35:24 Sebastian Huber bsp/qoriq: Fix tlbwe synchronization 5
(edit) @b1ef3674   07/27/16 09:30:09 Sebastian Huber bsp/qoriq: Add QORIQ_HAS_WRITE_BACK_L1_CACHE Fixes start via U-Boot … 5
(edit) @c2a4b8bf   07/19/16 07:42:26 Sebastian Huber bsps/powerpc: Fix shared console driver The Termios modes are now an … 5
(edit) @612297e8   07/12/16 10:44:17 joel Misc: Spell length correctly 5
(edit) @814bd6e3   07/12/16 08:02:40 Sebastian Huber bsps/powerpc: Fix AltiVec? enable There must be an isync after the … 5
(edit) @0057e38f   07/04/16 09:06:53 Sebastian Huber libchip: Simplify RTC driver 5
(edit) @9bb3ce39   06/29/16 07:50:47 Sebastian Huber score: Fix SMP message handling According to the C11 standard only … 5
(edit) @4c02385   06/24/16 06:52:48 Christian.Mauderer libnetworking: Import current <arpa/inet.h> Import the <arpa/inet.h> … 5
(edit) @1c77a36   06/24/16 12:31:29 Sebastian Huber bsps: Include missing <rtems/bspIo.h> 5
(edit) @a0cd238d   06/13/16 11:42:02 Sebastian Huber bsp/qoriq: Increase reserved size for FDT Some boards require this size. 5
(edit) @89f627b5   06/08/16 14:03:12 Sebastian Huber bsps/powerpc: Update to RTEMS printer changes 5
(edit) @a9cff51b   04/12/16 05:30:38 Sebastian Huber bsp/qoriq: Fix nocache region placement Avoid memory waste due to … 5
(edit) @0546e65e   05/31/16 07:12:43 Sebastian Huber bsps: Add defines for some linker subsections The GNU ld sort by name … 5
(edit) @ccda9459   05/31/16 07:10:24 Sebastian Huber bsps: Sort some sections first by alignment This helps to avoid … 5
(edit) @f57f513d   05/09/16 11:04:39 Sebastian Huber bsp/qoriq: Add portal clear functions 5
(edit) @c70f9d1   04/28/16 08:19:54 Sebastian Huber bsp/qoriq: Set M and G bits in ENTRY_DEV_CACHED() Set M and G MMU … 5
(edit) @159b637   05/03/16 04:47:21 Sebastian Huber bsp/mvme5500: Use thread local variable Use thread local variable … 5
(edit) @0000791   04/28/16 08:27:51 Sebastian Huber bsp/qoriq: Add and use qoriq_reset_qman_and_bman() 5
(edit) @ddc12de   04/28/16 08:22:03 Sebastian Huber bsp/qoriq: Add DCFG to memory map 5
(edit) @d8f4689   04/22/16 12:03:43 Sebastian Huber bsp/qoriq: Add bsp_restart() 5
(edit) @2816c84a   04/22/16 11:34:09 Sebastian Huber bsp/qoriq: Use IPI_INDEX throughout 5
(edit) @9b1f338d   04/22/16 11:32:52 Sebastian Huber bsp/qoriq: Add qoriq_start_spin_table_addr[] Make the U-Boot start … 5
(edit) @2c68a47e   04/22/16 11:11:15 Sebastian Huber bsp/qoriq: Add qoriq_tlb1_invalidate_all_by_ts() Generalize … 5
(edit) @582e4272   04/22/16 11:09:39 Sebastian Huber bsp/qoriq: Move L1 cache invalidate function 5
(edit) @0ac0632   04/22/16 08:28:00 Sebastian Huber bsp/qoriq: Do not reset time base We may use this as an entropy source. 5
(edit) @d35e6dde   04/22/16 12:10:47 Sebastian Huber powerpc: Add FSL_EIS_TENSR, etc. defines 5
(edit) @c287dc0   04/21/16 10:37:25 Sebastian Huber bsp/qoriq: Flush and invalidate all L2 caches 5
(edit) @6a46d99   04/21/16 09:39:28 Sebastian Huber bsp/qoriq: Optionally initialize register HID0 Enable the L2MMU … 5
(edit) @a12724f9   04/14/16 05:57:38 Sebastian Huber bsp/qoriq: Fix MMU initialization for e6500 In case a hypervisor mode … 5
(edit) @09a21c5   03/30/16 19:04:23 joel powerpc/virtex5/include/bsp.h: Do not include <rtems/iosupp.h> 5
(edit) @bea9a25   03/30/16 19:04:23 joel powerpc/virtex4/include/bsp.h: Do not include <rtems/iosupp.h> 5
(edit) @c9705f0   03/30/16 19:04:23 joel powerpc/virtex/include/bsp.h: Do not include <rtems/iosupp.h> 5
(edit) @d379a629   03/30/16 19:04:23 joel powerpc/qemuppc/include/bsp.h: Do not include <rtems/iosupp.h> 5
(edit) @c5ecb95   03/30/16 19:04:23 joel powerpc/psim/include/bsp.h: Do not include <rtems/iosupp.h> 5
(edit) @bf820a6f   03/30/16 19:04:23 joel powerpc/haleakala/include/bsp.h: Do not include <rtems/iosupp.h> 5
(edit) @c30d6686   03/30/16 14:10:53 joel powerpc/gen5200/include/bsp.h: Remove unnecessary include of <rtems/rtc.h> 5
(edit) @c228bd93   03/29/16 18:10:52 joel powerpc/virtex5: Remove include of <rtems/console.h> from <bsp.h> and … 5
(edit) @0b2ea32   03/29/16 18:10:52 joel powerpc/virtex4: Remove include of <rtems/console.h> from <bsp.h> and … 5
(edit) @ac0ecf27   03/29/16 18:10:52 joel powerpc/virtex: Remove include of <rtems/console.h> from <bsp.h> and … 5
(edit) @2a8afe1   03/29/16 18:10:52 joel powerpc/tqm8xx: Remove include of <rtems/console.h> from <bsp.h> and … 5
(edit) @8d1a5a3   03/29/16 18:10:52 joel powerpc/t32mppc: Remove include of <rtems/console.h> from <bsp.h> and … 5
(edit) @ed29ced   03/29/16 18:10:52 joel powerpc/ss555: Remove include of <rtems/console.h> from <bsp.h> and … 5
(edit) @97ea73fe   03/29/16 18:10:52 joel powerpc/qemuppc: Remove include of <rtems/console.h> from <bsp.h> and … 5
(edit) @f37e259a   03/29/16 18:10:52 joel powerpc/psim: Remove include of <rtems/console.h> from <bsp.h> and fix … 5
(edit) @78816f4   03/29/16 18:10:52 joel powerpc/mvme5500: Remove include of <rtems/console.h> from <bsp.h> and … 5
(edit) @899f6357   03/29/16 18:10:52 joel powerpc/mvme3100: Remove include of <rtems/console.h> from <bsp.h> and … 5
(edit) @629555cf   03/29/16 18:10:52 joel powerpc/mpc8260ads: Remove include of <rtems/console.h> from <bsp.h> … 5
(edit) @a2abd26   03/29/16 18:10:52 joel powerpc/mpc55xxevb: Remove include of <rtems/console.h> from <bsp.h> … 5
(edit) @c093f37   03/29/16 18:10:52 joel powerpc/motorola_powerpc: Remove include of <rtems/console.h> from … 5
(edit) @3f9ce5b9   03/29/16 18:10:52 joel powerpc/haleakala: Remove include of <rtems/console.h> from <bsp.h> … 5
(edit) @6c5d7181   03/29/16 18:10:52 joel powerpc/gen83xx: Remove include of <rtems/console.h> from <bsp.h> and … 5
(edit) @93ba1d55   03/29/16 18:10:52 joel powerpc/gen5200: Remove include of <rtems/console.h> from <bsp.h> and … 5
(edit) @13279f5e   03/29/16 18:10:52 joel powerpc/beatnik: Remove include of <rtems/console.h> from <bsp.h> and … 5
(edit) @b02c77c6   03/29/16 17:54:00 joel powerpc/shared/console/console.c: Add include of <rtems/console.h> to … 5
(edit) @ffa9cbf   03/29/16 06:11:29 Sebastian Huber bsps/powerpc: Avoid recursion in exception handler 5
(edit) @6f9c3e55   03/23/16 10:24:18 Sebastian Huber bsp/motorola_powerpc: README.qemu 5
(edit) @01096ad   03/25/16 15:47:17 joel powerpc/virtex5/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @7b107c24   03/25/16 15:47:17 joel powerpc/virtex4/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @667b0c15   03/25/16 15:47:17 joel powerpc/virtex/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @022432d   03/25/16 15:47:17 joel powerpc/tqm8xx/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @17de5f0   03/25/16 15:47:17 joel powerpc/t32mppc/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @83b1c4c2   03/25/16 15:47:16 joel powerpc/ss555/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @37770be1   03/25/16 15:47:16 joel powerpc/qemuppc/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @a3ce764   03/25/16 15:47:16 joel powerpc/psim/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @5f72835   03/25/16 15:47:16 joel powerpc/mvme5500/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @b951a2b   03/25/16 15:47:16 joel powerpc/mvme3100/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @d04bf84d   03/25/16 15:47:15 joel powerpc/mpc8260ads/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @a853c061   03/25/16 15:47:14 joel powerpc/mpc55xxevb/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @227399d   03/25/16 15:47:12 joel powerpc/motorola_powerpc/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @b63f12a   03/25/16 15:47:10 joel powerpc/haleakala/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @0ee0eae   03/25/16 15:47:09 joel powerpc/gen83xx/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @ec5b3f0   03/25/16 15:47:09 joel powerpc/gen5200/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @a632950   03/25/16 15:47:08 joel powerpc/beatnik/include/bsp.h: Do not include <rtems/clockdrv.h> 5
(edit) @561dec5   03/21/16 15:53:32 joel powerpc/shared/openpic/openpic.c: Ignore warnings for … 5
(edit) @e12f4e17   03/18/16 09:58:41 Sebastian Huber bsp/qoriq: Invalidate TLS anchor 5
(edit) @b0443736   03/16/16 09:29:48 Sebastian Huber bsp/mpc55xx: Fix BSS initialization 5
(edit) @057154e   03/15/16 07:15:53 Sebastian Huber bsp/beatnik: Delete unused linkcmds file 5
(edit) @734118d9   03/14/16 09:55:57 Sebastian Huber bsp/qoriq: Fix interrupt numbers 5
(edit) @45e5623   03/10/16 23:22:59 joel powerpc/motorola_powerpc: Add per-section compilation and linking … 5
(edit) @9430052   03/09/16 21:45:44 joel powerpc/mvme5500: Use shared pci_find_device() 5
(edit) @90d8567   02/18/16 07:36:16 Sebastian Huber score: Distribute clock tick to all online CPUs Update #2554. 5
(edit) @cc1add7b   03/03/16 08:49:15 Sebastian Huber bsps: Delete empty Clock_driver_support_at_tick() 5
(edit) @73de9393   03/02/16 12:32:44 Sebastian Huber bsp/qoriq: Do not touch MMU config for SMP start Assume that the boot … 5
(edit) @e468ba5   03/03/16 08:08:08 Sebastian Huber U-Boot: Flush data cache after bdinfo copy 5
(edit) @aaa21b1   02/06/16 16:19:46 joel powerpc/.../ss555.cfg: Correct ticket number in comment 5
(edit) @406b3b7   02/06/16 16:18:41 joel powerpc/.../qemuppc.cfg: Correct ticket number in comment 5
(edit) @6564bd2   02/06/16 16:17:59 joel powerpc/.../mpc8260ads.cfg: Correct ticket number in comment 5
(edit) @068b3125   02/06/16 15:35:21 joel powerpc/.../mpc8260ads.cfg: Disable per function sections updates #2565. 5
(edit) @8926fad   02/06/16 14:53:30 joel powerpc/.../qemuppc.cfg: Disable per function sections updates #2564. 5
(edit) @72d8e64c   02/06/16 14:50:26 joel powerpc/.../ss555.cfg: Disable per function sections. updates #2563. 5
(edit) @c5ce9c3c   02/05/16 13:51:48 joel powerpc/.../haleakala.cfg: Disable per function sections. updates #2561. 5
(edit) @3bc12a8f   01/26/16 10:16:56 Sebastian Huber Delete unused API extensions 5
(edit) @8ca372e   01/26/16 09:11:48 Sebastian Huber Use linker set for MPCI initialization Update #2408. 5
(edit) @ca4602e   01/25/16 21:03:00 Sebastian Huber Use linker set for libio initialization Update #2408. 5
(edit) @ab8e821   01/27/16 06:33:50 Sebastian Huber bsps/powerpc: Fix startup Do work area initialization after … 5
(edit) @0aeeca42   01/24/16 23:43:58 ralph powerpc/gen83xx: Add per-section compilation and linking support. For … 5
(edit) @8c7c891   01/24/16 16:55:49 ralph powerpc/mpc55xxevb: Add per-section compilation and linking support. … 5
