@4abbc567
10/09/14 21:40:20 |
Joel Sherrill |
powerpc bootloader: Remove warnings
This code is shared by multiple …
4.115
@a869b37a
10/13/14 15:31:22 |
Joel Sherrill |
powerpc/score603e/irq/irq_init.c: Clean up
4.115
@fb252a68
10/13/14 15:29:44 |
Joel Sherrill |
libbsp/powerpc/shared: Fix warnings
4.115
@7a4c4f4
10/13/14 15:28:44 |
Joel Sherrill |
powerpc/ep1a: Fix warnings
4.115
@e160e41
10/09/14 20:15:55 |
Joel Sherrill |
powerpc/ep1a: Remove if 0 sections
There may be useful nuggets for …
4.115
@cc7c922
10/09/14 18:38:59 |
Joel Sherrill |
powerpc/ep1a: Fix multiple warnings
4.115
@6279149
10/08/14 21:04:56 |
Joel Sherrill |
Add console-polled.h and update all BSPs that should use it.
The file …
4.115
@a9fd601
10/10/14 07:49:59 |
Sebastian Huber |
bsp/mpc55xxevb: Fix warnings
4.115
@d7a267b3
10/10/14 07:43:59 |
Sebastian Huber |
bsp/gen5200: Fix warnings
4.115
@78a38fa2
10/08/14 22:38:12 |
Joel Sherrill |
Eliminate use of /*PAGE and clean up formatting
4.115
@819aa3c9
10/08/14 19:10:38 |
Joel Sherrill |
libbsp/powerpc/shared/tod/todcfg.c: Fix method prototype to eliminate …
4.115
@9827d51e
10/08/14 14:24:02 |
Joel Sherrill |
gen5200/startup/cpuinit.c: Warning for function which should have been void
4.115
@5eb04f4d
10/07/14 22:39:26 |
Joel Sherrill |
powerpc/ss555/startup/bspstart.c: Add include of <bsp/bootcard.h> to …
4.115
@ad38073
10/07/14 22:39:08 |
Joel Sherrill |
powerpc/shared/startup/bspstart.c: Add include of <bsp/bootcard.h> to …
4.115
@80207b8
10/07/14 22:38:54 |
Joel Sherrill |
powerpc/score603e/startup/bspstart.c: Add include of <bsp/bootcard.h> …
4.115
@48aa5e2c
10/07/14 22:38:33 |
Joel Sherrill |
powerpc/mvme5500/startup/bspstart.c: Add include of <bsp/bootcard.h> …
4.115
@8303fc97
10/07/14 22:38:19 |
Joel Sherrill |
powerpc/mvme3100/startup/bspstart.c: Add include of <bsp/bootcard.h> …
4.115
@44d6d21
10/07/14 22:33:00 |
Joel Sherrill |
powerpc/mbc8260ads/startup/bspstart.c: Add include of <bsp/bootcard.h> …
4.115
@3947b5d
10/07/14 22:32:37 |
Joel Sherrill |
powerpc/mbx8xx/startup/bspstart.c: Add include of <bsp/bootcard.h> to …
4.115
@f57aa10
10/07/14 22:32:17 |
Joel Sherrill |
powerpc/haleakala/startup/bspstart.c: Add include of <bsp/bootcard.h> …
4.115
@7ac87aee
10/07/14 22:31:59 |
Joel Sherrill |
powerpc/ep1a/startup/bspstart.c: Add include of <bsp/bootcard.h> to …
4.115
@dbd8b307
10/07/14 22:31:41 |
Joel Sherrill |
powerpc/beatnik/startup/bspstart.c: Add include of <bsp/bootcard.h> to …
4.115
@780eab4
10/07/14 14:39:42 |
Joel Sherrill |
libcpu/powerpc/mpc8xx/clock: Fix warnings and clean up
4.115
@6ec438e
10/07/14 06:29:16 |
Sebastian Huber |
libchip/serial: Add alternative NS16550 driver
Use the Termios device API.
4.115
@bdd6082
09/18/14 09:07:41 |
Sebastian Huber |
bsps: Fix build error
Fix build error introduced in …
4.115
@8fbe2e6
09/04/14 13:59:49 |
Joel Sherrill |
Use correct prototype of benchmark_timer_read()
This change starts …
4.115
@5674767f
09/09/14 13:18:01 |
Sebastian Huber |
bsp/qoriq: Fix tm27 support
4.115
@ce134f74
09/02/14 17:30:01 |
Joel Sherrill |
score603e/start/start.S: Add start symbol to eliminate warning
4.115
@59990cc
08/29/14 02:48:01 |
Chris Johns |
Regenerate all preinstall.am files.
With this patch the preinstall.am …
4.115
@b597c0d
08/28/14 13:44:52 |
Joel Sherrill |
Apparently, at some point …
4.115
@bfa2b8c
08/27/14 17:50:36 |
Joel Sherrill |
virtex5/.../bsp.h: Add BSP_Convert_decrementer() macro required by …
4.115
@6c5c2f3
05/12/14 07:23:51 |
Sebastian Huber |
bsps: Use bsp_start_on_secondary_processor()
Use a standard function …
4.115
@64a04ac
05/12/14 06:53:11 |
Sebastian Huber |
bsps: Use standard file name for BSP support
4.115
@89f0794
05/08/14 11:00:08 |
Sebastian Huber |
bsp/gen83xx: Disable interrupt nesting for br_uid
This is necessary …
4.115
@053abcda
04/23/14 23:38:43 |
Joel Sherrill |
multiple BSPs: Remove BSP_SMALL_MEMORY
4.115
@c2ea0ea
05/06/14 12:44:17 |
Sebastian Huber |
bsp/gen83xx: Add BSP_USB_EHCI_MPC83XX_HAS_ULPI
4.115
@1461b648
05/04/14 22:12:52 |
Chris Johns |
testsuite: Add a per BSP test check for tests not to build.
Provide a …
4.115
@b74c9cf
04/23/14 04:31:55 |
Chris Johns |
bootstrap: Sort the contents of the prinstall.am files.
Sorting …
4.115
@b6a2e57b
04/22/14 18:07:01 |
Joel Sherrill |
score603e: Add rtems_crti
4.115
@77737ad
04/22/14 18:06:08 |
Joel Sherrill |
ss555: Add rtems_crti/n
4.115
@2f36f5a5
04/22/14 15:36:44 |
Joel Sherrill |
mpc8260ads: Add rtems_crti/n
4.115
@d60e760
04/22/14 07:45:39 |
Sebastian Huber |
bsps: Fix TLS support in linker command files
The TLS section symbols …
4.115
@e2782684
04/22/14 07:32:16 |
Sebastian Huber |
bsp/mbx8xx: Fix Makefile.am and bsp_specs
4.115
@e10574a
04/22/14 06:32:27 |
Sebastian Huber |
bsps/powerpc: Fix linker command files
4.115
@b80f920
04/15/14 11:36:35 |
Sebastian Huber |
bsp/qoriq: SMP support for IRQ support
4.115
@53e008b
04/10/14 13:48:05 |
Sebastian Huber |
score: SMP initialization changes
Add and use …
4.115
@6c0b7b8
04/03/14 20:13:25 |
Joel Sherrill |
psim/console/console-io.c: Comment clean up
4.115
@8e980e61
04/01/14 07:48:40 |
Sebastian Huber |
4.115
@5130248e
03/13/14 13:28:46 |
cederman |
smc91111: Move driver attach prototype to header file.
Also signal to …
4.115
@c499856
03/20/14 21:10:47 |
Chris Johns |
Change all references of rtems.com to rtems.org.
4.115
@0b9fd991
02/21/14 16:12:16 |
Sebastian Huber |
bsps: Add empty cache manager
This is necessary to add tests that use …
4.115
@0fe0718
02/21/14 12:32:13 |
Sebastian Huber |
bsps/powerpc: Use System V small-data area
The 32-bit ABIs for …
4.115
@1be15db1
02/19/14 14:15:18 |
Sebastian Huber |
bsp/score603e: Remove unused BSP_fatal_return()
4.115
@4d9bd56
02/17/14 14:12:43 |
Sebastian Huber |
score: Rename rtems_smp_process_interrupt()
Rename …
4.115
@911b1d2
02/17/14 14:02:54 |
Sebastian Huber |
score: Rename rtems_smp_secondary_cpu_initialize()
Rename …
4.115
@f8ff2a0
02/17/14 13:31:32 |
Sebastian Huber |
score: Delete bsp_smp_broadcast_interrupt()
Since the per-CPU SMP …
4.115
@4627fcd
02/17/14 13:25:29 |
Sebastian Huber |
score: Rename bsp_smp_initialize()
Rename bsp_smp_initialize() into …
4.115
@33cb8bf
02/17/14 10:40:18 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_BSP
Merge …
4.115
@801b5d8
02/17/14 08:23:59 |
Sebastian Huber |
powerpc: Change interrupt disable implemetation
Instead of SPRG0 (= …
4.115
@24bf11e
02/12/14 09:31:38 |
Sebastian Huber |
score: Add CPU counter support
Add a CPU counter interface to allow …
4.115
@bab16de2
02/07/14 08:53:47 |
Sebastian Huber |
score: Change debug helper functions
Rename …
4.115
@960fd85
01/28/14 10:52:17 |
Sebastian Huber |
bsps: Thread-local storage (TLS) for linkcmds
4.115
@bba0e09
01/30/14 09:37:02 |
Sebastian Huber |
bsps: Fix barrier section definitions
4.115
@f334847b
01/17/14 01:57:08 |
Nick Withers |
powerpc/flash: give string variables const attribute
4.115
@a7775cb
01/16/14 03:21:10 |
Nick Withers |
Add warnings to MOTLoad-equipped BSPs' READMEs that a "waitProbe", …
4.115
@279d83d3
01/14/14 23:33:48 |
cynt6007 |
libbsp powerpc: Add Doxygen file header to coverhd.h
4.115
@e327e69
01/09/14 22:05:54 |
cynt6007 |
libbsp tm27.h: Add Doxygen file header to all tm27.h
4.115
@a77c3719
01/03/14 12:35:39 |
zsoltisharkboy |
powerpc/mvme3100: Improve Doxygen
4.115
@e4927ece
12/04/13 14:39:20 |
Sebastian Huber |
bsps: Simplify FreeBSD linker sets
4.115
@43c6268
07/09/13 07:53:08 |
Sebastian Huber |
bsps/powerpc: Use ALIGN_WITH_INPUT
This requires at least Binutils 2.24.
4.115
@296c74e6
12/09/13 19:37:48 |
Daniel Ramirez |
doxygen: refactored doxygen in libbsp to illustrate new rule set
4.115
@ab1733b
12/06/13 22:42:25 |
Daniel Ramirez |
virtex4: Move start.S to virtex4/start/start.S
4.115
@a4d6739
12/06/13 22:31:27 |
Daniel Ramirez |
tqm8xx: Move start.S to tqm8xx/start/start.S
4.115
@09c33ed
12/06/13 22:44:40 |
Daniel Ramirez |
virtex5: Move start.S to virtex5/start/start.S
4.115
@c6af4585
12/06/13 16:17:52 |
cdesai |
powerpc/ss555: move startup/start.S to start/start.S
4.115
@1203d38
12/06/13 15:57:55 |
cdesai |
powerpc: mbx8xx: move starup/start.S to start/start.S
4.115
@f339afb
12/03/13 08:51:13 |
Sebastian Huber |
bsp/qoriq: Use System V small-data area
4.115
@4b43051
12/02/13 16:07:29 |
cdesai |
powerpc: motorola: Move bspreset.c to startup/
* Move …
4.115
@22fa874a
11/24/13 15:46:00 |
cdesai |
powerpc/mpc55xxevb: Move bspworkarea.c to bspgetworkarea.c
Fixes …
4.115
@287fefe2
11/23/13 21:55:32 |
Daniel Ramirez |
mpc55xxevb: Move start.S to mpc55xxevb/start/start.S
4.115
@9660ad6
11/23/13 19:23:14 |
Daniel Ramirez |
beatnik: Move bsp_reset() to beatnik/startup/bspreset.c
4.115
@571216ac
11/23/13 14:21:03 |
cdesai |
powerpc/mpc55xxevb: Move bspworkareainit.c to bspgetworkarea.c
* Move …
4.115
@4abc4d1
11/23/13 08:57:28 |
cdesai |
powerpc/mpc55xxevb: Move startup/reset.c to startup/bspreset.c
4.115
@efdda565
08/09/13 04:18:17 |
Nick Withers |
Use $(EXEEXT) [defaults to "exe"] to generate binaries
4.115
@00630411
08/06/13 14:03:40 |
Sebastian Huber |
PR766: Delete RTEMS_APPLICATION
This define is no longer used.
4.115
@fe52e7c0
07/26/13 12:10:25 |
Sebastian Huber |
smp: Add and use _Per_CPU_Get()
Add and use _Per_CPU_Get_by_index() …
4.115
@4e00fe62
07/26/13 07:18:05 |
Sebastian Huber |
bsps: Include missing <rtems/score/heapimpl.h>
4.115
@0c3edbf
07/25/13 08:46:15 |
Sebastian Huber |
Include missing <rtems/score/threaddispatch.h>
4.115
@39046f7
07/24/13 09:09:23 |
Sebastian Huber |
score: Merge sysstate API into one file
4.115
@2f589cc
07/18/13 08:08:05 |
ralf.kirchner |
bsp/gen83xx: Fix BSP options for MPC8348EAMDS
4.115
@ca63ae2
06/13/13 13:41:21 |
Sebastian Huber |
smp: Add and use _CPU_SMP_Send_interrupt()
Delete bsp_smp_interrupt_cpu().
4.115
@39e51758
06/14/13 12:00:38 |
Sebastian Huber |
smp: Add and use _CPU_SMP_Get_current_processor()
Add and use …
4.115
@c8d78ee
07/02/13 08:37:13 |
Sebastian Huber |
bsp/mpc55xx: Add MPC5668G support
4.115
@26c093e
07/10/13 12:36:50 |
Sebastian Huber |
bsp/virtex: Use #if instead of #ifdef
This allows …
4.115
@0a697dd9
07/09/13 09:24:27 |
Sebastian Huber |
bsp/virtex: Add VIRTEX_CONSOLE_USE_INTERRUPTS
Add interrupt support …
4.115
@d168079
07/09/13 14:38:03 |
Sebastian Huber |
bsp/virtex: Use ppc_count_leading_zeros()
Use …
4.115
@296b60d7
07/09/13 14:04:04 |
Sebastian Huber |
bsp/virtex: Fix interrupt handling
Some modules like the XPS UART …
4.115
@818edbd
07/02/13 13:16:33 |
Sebastian Huber |
bsp/mpc55xx: Update due to API changes
Termios notifies now the …
4.115
@d91d50f
07/02/13 13:14:51 |
Sebastian Huber |
bsp/mpc55xx: Avoid integer overflow
4.115
@c97d3dd
07/02/13 13:13:54 |
Sebastian Huber |
bsp/mpc55xx: Round PLL divider up
4.115
