# # ChangeLog for c/src/lib/libbsp/powerpc/mpc55xxevb/console in rtems # # Generated by Trac 1.2.1.dev0 # 04/16/24 13:51:29 Mon, 23 Jan 2012 10:19:22 GMT Sebastian Huber [a762dc2] * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/README (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/clock/clock-config.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-config.c (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-esci.c (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-generic.c (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-linflex.c (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/console-esci.h (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/console-generic.h (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/console-linflex.h (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/mpc55xx-config.h (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/xkt564levb.cfg (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/early-init.c (deleted) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/fmpll-syncr-vals.c (deleted) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/get-system-clock.c (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.xkt564levb (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/reset.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/sd-card-init.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-cache.S (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-clock.c (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-clock.c (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-ebi-cs-cal.c (moved) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-ebi-cs.c (moved) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-mmu-early.c (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-mmu.c (moved) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-config-siu-pcr.c (moved) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-early.c (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-flash.S (moved) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-watchdog.c (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start.S (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc55xx/dspi/dspi.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/edma/edma.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/emios/emios.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/emios.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/fsl-mpc551x.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/fsl-mpc555x.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/fsl-mpc556x.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/fsl-mpc564xL.h (added) * c/src/lib/libcpu/powerpc/mpc55xx/include/fsl-mpc567x.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/irq.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/mpc55xx.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/reg-defs.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/regs-mmu.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/regs.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/misc/fmpll.S (deleted) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_categories.c (modified) * c/src/lib/libcpu/powerpc/preinstall.am (modified) * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.c (modified) * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.h (modified) Support for MPC5643L. Rework of the start sequence to reduce the ...
