# # ChangeLog for c/src/lib/libbsp/powerpc/gen5200/bestcomm/dma_image.reloc.c in rtems # # Generated by Trac 1.2.1.dev0 # 05/23/24 12:21:47 Thu, 04 Jan 2018 07:50:56 GMT Chris Johns [caeaae26] * c/src/lib/libbsp/powerpc/gen5200/bestcomm/bestcomm_api.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/bestcomm_glue.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/dma_image.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/dma_image.reloc.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/load_task.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_ata.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_bdtable.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_crc16_dp_0.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_crc16_dp_1.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_fec_rx_bd.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_fec_tx_bd.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_dp_0.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_dp_1.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_dp_2.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_dp_3.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_dp_bd_0.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_dp_bd_1.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_rx_bd.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_tx_bd.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_lpc.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_pci_rx.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_pci_tx.c (modified) * c/src/lib/libbsp/powerpc/gen5200/console/console.c (modified) * c/src/lib/libbsp/powerpc/gen5200/i2c/mpc5200mbus.c (modified) * c/src/lib/libbsp/powerpc/gen5200/i2c/mpc5200mbus.h (modified) * c/src/lib/libbsp/powerpc/gen5200/ide/idecfg.c (modified) * c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.c (modified) * c/src/lib/libbsp/powerpc/gen5200/mscan/mscan.c (modified) * c/src/lib/libbsp/powerpc/gen5200/mscan/mscan_int.h (modified) * c/src/lib/libbsp/powerpc/gen5200/nvram/nvram.c (modified) * c/src/lib/libbsp/powerpc/gen5200/slicetimer/slicetimer.c (modified) bsp/gen5200: Use public include path Update #3254. Sun, 29 Nov 2009 15:27:07 GMT Ralf Corsepius [efdfd48] * c/src/lib/libbsp/mips/csb350/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/csb350/console/console-io.c (modified) * c/src/lib/libbsp/mips/csb350/include/bsp.h (modified) * c/src/lib/libbsp/mips/csb350/network/network.c (modified) * c/src/lib/libbsp/mips/csb350/start/start.S (modified) * c/src/lib/libbsp/mips/csb350/startup/bspreset.c (modified) * c/src/lib/libbsp/mips/csb350/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/csb350/timer/timer.c (modified) * c/src/lib/libbsp/mips/hurricane/clock/ckinit.c (modified) * c/src/lib/libbsp/mips/hurricane/clock/clock.S (modified) * c/src/lib/libbsp/mips/hurricane/console/console.c (modified) * c/src/lib/libbsp/mips/hurricane/include/bsp.h (modified) * c/src/lib/libbsp/mips/hurricane/start/start.S (modified) * c/src/lib/libbsp/mips/hurricane/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/hurricane/startup/exception.S (modified) * c/src/lib/libbsp/mips/hurricane/startup/idttlb.S (modified) * c/src/lib/libbsp/mips/rbtx4925/console/console-io.c (modified) * c/src/lib/libbsp/mips/rbtx4925/start/start.S (modified) * c/src/lib/libbsp/mips/rbtx4925/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/rbtx4925/startup/exception.S (modified) * c/src/lib/libbsp/mips/rbtx4925/startup/idttlb.S (modified) * c/src/lib/libbsp/mips/rbtx4938/clock/yamon_api.h (modified) * c/src/lib/libbsp/mips/rbtx4938/console/console-io.c (modified) * c/src/lib/libbsp/mips/rbtx4938/console/yamon_api.h (modified) * c/src/lib/libbsp/mips/rbtx4938/start/start.S (modified) * c/src/lib/libbsp/mips/rbtx4938/startup/exception.S (modified) * c/src/lib/libbsp/mips/rbtx4938/startup/idttlb.S (modified) * c/src/lib/libbsp/mips/shared/gdbstub/mips-stub.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/bestcomm_api.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/bestcomm_api.h (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/bestcomm_priv.h (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/dma_image.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/dma_image.capi.h (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/dma_image.h (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/dma_image.reloc.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/include/mgt5200/mgt5200.h (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/include/mgt5200/sdma.h (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/include/ppctypes.h (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/load_task.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/task_api/bestcomm_api_mem.h (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/task_api/bestcomm_cntrl.h (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/task_api/tasksetup_bdtable.h (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/task_api/tasksetup_general.h (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_bdtable.c (modified) * c/src/lib/libbsp/powerpc/gen5200/clock/clock.c (modified) * c/src/lib/libbsp/powerpc/gen5200/i2c/i2c.c (modified) * c/src/lib/libbsp/powerpc/gen5200/i2c/i2cdrv.c (modified) * c/src/lib/libbsp/powerpc/gen5200/i2c/mpc5200mbus.c (modified) * c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.c (modified) * c/src/lib/libbsp/powerpc/gen5200/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen5200/mscan/mscan-base.c (modified) * c/src/lib/libbsp/powerpc/gen5200/network_5200/network.c (modified) * c/src/lib/libbsp/powerpc/gen5200/start/start.S (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/bspreset.c (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/cpuinit.c (modified) * c/src/lib/libbsp/powerpc/gen5200/tod/pcf8563.c (modified) Whitespace removal. Mon, 02 Jan 2006 04:48:19 GMT Ralf Corsepius [c8423f9] * c/src/lib/libbsp/powerpc/gen5200/bestcomm/bestcomm_api.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/bestcomm_api.h (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/bestcomm_glue.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/dma_image.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/dma_image.capi.h (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/dma_image.h (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/dma_image.reloc.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/load_task.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_ata.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_bdtable.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_crc16_dp_0.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_crc16_dp_1.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_fec_rx_bd.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_fec_tx_bd.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_dp_0.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_dp_1.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_dp_2.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_dp_3.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_dp_bd_0.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_dp_bd_1.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_rx_bd.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_tx_bd.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_lpc.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_pci_rx.c (modified) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_pci_tx.c (modified) Eliminate #include "../bestcomm/... Sat, 31 Dec 2005 05:09:26 GMT Ralf Corsepius [ca680bc5] * c/src/lib/libbsp/powerpc/gen5200/.cvsignore (added) * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (added) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (added) * c/src/lib/libbsp/powerpc/gen5200/README (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/bestcomm_api.c (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/bestcomm_api.h (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/bestcomm_glue.c (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/bestcomm_glue.h (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/bestcomm_priv.h (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/dma_image.c (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/dma_image.capi.h (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/dma_image.h (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/dma_image.reloc.c (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/include/mgt5200/mgt5200.h (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/include/mgt5200/sdma.h (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/load_task.c (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/task_api/bestcomm_api_mem.h (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/task_api/bestcomm_cntrl.h (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/task_api/tasksetup_bdtable.h (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/task_api/tasksetup_general.h (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_ata.c (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_bdtable.c (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_crc16_dp_0.c (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_crc16_dp_1.c (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_fec_rx_bd.c (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_fec_tx_bd.c (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_dp_0.c (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_dp_1.c (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_dp_2.c (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_dp_3.c (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_dp_bd_0.c (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_dp_bd_1.c (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_rx_bd.c (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_gen_tx_bd.c (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_lpc.c (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_pci_rx.c (added) * c/src/lib/libbsp/powerpc/gen5200/bestcomm/tasksetup_pci_tx.c (added) * c/src/lib/libbsp/powerpc/gen5200/bsp_specs (added) * c/src/lib/libbsp/powerpc/gen5200/clock/clock.c (added) * c/src/lib/libbsp/powerpc/gen5200/configure.ac (added) * c/src/lib/libbsp/powerpc/gen5200/console/console.c (added) * c/src/lib/libbsp/powerpc/gen5200/i2c/i2c.c (added) * c/src/lib/libbsp/powerpc/gen5200/i2c/i2cdrv.c (added) * c/src/lib/libbsp/powerpc/gen5200/i2c/mpc5200mbus.c (added) * c/src/lib/libbsp/powerpc/gen5200/i2c/mpc5200mbus.h (added) * c/src/lib/libbsp/powerpc/gen5200/ide/idecfg.c (added) * c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.c (added) * c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.h (added) * c/src/lib/libbsp/powerpc/gen5200/include/.cvsignore (added) * c/src/lib/libbsp/powerpc/gen5200/include/bsp.h (added) * c/src/lib/libbsp/powerpc/gen5200/include/coverhd.h (added) * c/src/lib/libbsp/powerpc/gen5200/include/i2c.h (added) * c/src/lib/libbsp/powerpc/gen5200/include/i2cdrv.h (added) * c/src/lib/libbsp/powerpc/gen5200/include/mpc5200.h (added) * c/src/lib/libbsp/powerpc/gen5200/include/raw_exception.h (added) * c/src/lib/libbsp/powerpc/gen5200/include/tm27.h (added) * c/src/lib/libbsp/powerpc/gen5200/include/u-boot.h (added) * c/src/lib/libbsp/powerpc/gen5200/irq/irq.c (added) * c/src/lib/libbsp/powerpc/gen5200/irq/irq.h (added) * c/src/lib/libbsp/powerpc/gen5200/irq/irq_asm.S (added) * c/src/lib/libbsp/powerpc/gen5200/irq/irq_init.c (added) * c/src/lib/libbsp/powerpc/gen5200/mscan/mscan.c (added) * c/src/lib/libbsp/powerpc/gen5200/mscan/mscan.h (added) * c/src/lib/libbsp/powerpc/gen5200/network_5200/network.c (added) * c/src/lib/libbsp/powerpc/gen5200/nvram/m93cxx.h (added) * c/src/lib/libbsp/powerpc/gen5200/nvram/nvram.c (added) * c/src/lib/libbsp/powerpc/gen5200/nvram/nvram.h (added) * c/src/lib/libbsp/powerpc/gen5200/slicetimer/slicetimer.c (added) * c/src/lib/libbsp/powerpc/gen5200/slicetimer/slicetimer.h (added) * c/src/lib/libbsp/powerpc/gen5200/start/start.S (added) * c/src/lib/libbsp/powerpc/gen5200/startup/bspstart.c (added) * c/src/lib/libbsp/powerpc/gen5200/startup/cpuinit.c (added) * c/src/lib/libbsp/powerpc/gen5200/startup/linkcmds (added) * c/src/lib/libbsp/powerpc/gen5200/startup/linkcmds.pm520 (added) * c/src/lib/libbsp/powerpc/gen5200/tod/pcf8563.c (added) * c/src/lib/libbsp/powerpc/gen5200/tod/pcf8563.h (added) * c/src/lib/libbsp/powerpc/gen5200/tod/todcfg.c (added) * c/src/lib/libbsp/powerpc/gen5200/vectors/asm_utils.S (added) * c/src/lib/libbsp/powerpc/gen5200/vectors/raw_exception.c (added) * c/src/lib/libbsp/powerpc/gen5200/vectors/vectors.S (added) * c/src/lib/libbsp/powerpc/gen5200/vectors/vectors.h (added) * c/src/lib/libbsp/powerpc/gen5200/vectors/vectors_init.c (added) New (CVS import Thomas Doerfler
