@6d4062f
07/18/98 15:22:54 |
Joel Sherrill |
Removed. We are no longer dependent on DY-4 CSS interface code.
4.104.114.84.95
@cce1200e
07/18/98 15:19:28 |
Joel Sherrill |
New file.
4.104.114.84.95
@4a11d8c
07/15/98 23:58:08 |
Joel Sherrill |
Fixed typo in which last port did not get switched to default
register …
4.104.114.84.95
@670d037
07/15/98 23:55:04 |
Joel Sherrill |
Switched to usign the default z8530 and mc68681 register access routines.
4.104.114.84.95
@8a2e9c41
07/15/98 21:43:28 |
Joel Sherrill |
Added SCV64_Get_Interrupt_Enable().
Added proper headers to routines.
4.104.114.84.95
@d0cff6dc
07/15/98 21:43:00 |
Joel Sherrill |
4.104.114.84.95
@38e717f
07/15/98 21:42:26 |
Joel Sherrill |
Added chip type identifier field. This was necessary because a single …
4.104.114.84.95
@0f61336
07/15/98 19:28:29 |
Joel Sherrill |
Added comments.
4.104.114.84.95
@a69f0ad9
07/15/98 19:20:20 |
Joel Sherrill |
Added comments.
4.104.114.84.95
@100a4e5
07/15/98 19:19:14 |
Joel Sherrill |
Masked out interrupts not being used prior to processing the status …
4.104.114.84.95
@6c45da17
07/15/98 19:12:11 |
Joel Sherrill |
Added routine to return interrupt mask. Added comments.
4.104.114.84.95
@01e54b8
07/15/98 14:06:37 |
Joel Sherrill |
Added scv64 subdirectory.
4.104.114.84.95
@e49ef37c
07/15/98 14:06:08 |
Joel Sherrill |
Switched to SCV64.
4.104.114.84.95
@8f563b9b
07/15/98 14:05:51 |
Joel Sherrill |
Added CSCV64 functions and addresses.
4.104.114.84.95
@30a3f76
07/15/98 14:04:31 |
Joel Sherrill |
Switched from polling to interrupts and in the process added a …
4.104.114.84.95
@437b5a7d
07/15/98 14:00:23 |
Joel Sherrill |
4.104.114.84.95
@090a3511
07/15/98 14:00:09 |
Joel Sherrill |
New files.
4.104.114.84.95
@11c6a92d
07/09/98 22:59:32 |
Joel Sherrill |
Commented out the system call invocation since we don't know what …
4.104.114.84.95
@a6e36dff
07/09/98 22:59:13 |
Joel Sherrill |
Removed call back to exit() since that has already been called.
4.104.114.84.95
@2ba0a0c2
07/09/98 18:50:13 |
Joel Sherrill |
Corrected z85c30 address and clock constants.
4.104.114.84.95
@459c1d2
07/09/98 18:49:49 |
Joel Sherrill |
Added board specific baud rate table and set driver function table
to …
4.104.114.84.95
@bc2ebb4
07/05/98 11:01:21 |
Joel Sherrill |
Added some address constants for the SCC and DUART to make it easier …
4.104.114.84.95
@e7ff2b2
07/05/98 11:00:57 |
Joel Sherrill |
New file added in the process of converting the console driver to …
4.104.114.84.95
@92a6454
07/05/98 11:00:00 |
Joel Sherrill |
Converted the console driver to use libchip/serial and added support …
4.104.114.84.95
@547de5d
06/22/98 10:15:14 |
Joel Sherrill |
Removed blank lines and bad debug stuff
4.104.114.84.95
@fe52766e
06/16/98 19:06:35 |
Joel Sherrill |
Corrected compilation problems.
4.104.114.84.95
@8bf6095
06/16/98 19:05:50 |
Joel Sherrill |
Added initialization of css routines.
4.104.114.84.95
@1efeb61
06/16/98 18:22:54 |
Joel Sherrill |
Added css_iface -- assumes ../include/dy_supplied.
4.104.114.84.95
@23f5cdb5
06/13/98 13:34:09 |
Joel Sherrill |
Adding interrupt handling routine.
4.104.114.84.95
@510524c6
06/13/98 13:34:08 |
Joel Sherrill |
Removed bad comments.
4.104.114.84.95
@8d830755
06/13/98 13:33:38 |
Joel Sherrill |
Added IRQ information.
4.104.114.84.95
@a12d7fd7
06/13/98 13:33:11 |
Joel Sherrill |
Updated to add -qrtems_debug and -qnolinkcmds.
4.104.114.84.95
@2785eab2
05/30/98 16:01:12 |
Joel Sherrill |
Changed calculaction for Clock_Decrementer_value to use the …
4.104.114.84.95
@95a683b
05/30/98 15:58:37 |
Joel Sherrill |
Set console to port 2.
Changed #if defined to a #if check for …
4.104.114.84.95
@a874427
05/30/98 15:55:46 |
Joel Sherrill |
Made Debug defination a null routine.
4.104.114.84.95
@b317117a
05/30/98 15:53:19 |
Joel Sherrill |
clicks_per_usec had to be cut in half (unknown reason).
fixed …
4.104.114.84.95
@dc104a4
05/30/98 11:46:21 |
Joel Sherrill |
Updated to current source and removed warnings.
4.104.114.84.95
@a38b9f8
05/30/98 10:42:01 |
Joel Sherrill |
Used shared sbrk.c.
4.104.114.84.95
@825a2bb
05/30/98 10:41:21 |
Joel Sherrill |
Use shared initialization.
4.104.114.84.95
@55b517c
05/30/98 10:32:19 |
Joel Sherrill |
Rewrote in C to avoid Makefile problems.
4.104.114.84.95
@c932d85
05/30/98 10:09:14 |
Joel Sherrill |
New files -- from rtems-LM-980406 which was based on an RTEMS from …
4.104.114.84.95
