Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src/lib/libbsp/m68k
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @d0f01d2   06/30/05 11:53:12 WENorum Add description of external interrupt request assignments. 4.104.114.84.95
(edit) @57519ea   06/29/05 22:00:17 WENorum Reflect changes to network driver. 4.104.114.84.95
(edit) @5eb336b   06/29/05 20:44:25 WENorum Drive LEDs with more useful information. 4.104.114.84.95
(edit) @81291a0   06/29/05 20:09:14 WENorum Add duplex negotation support. 4.104.114.84.95
(edit) @cdb717e   06/22/05 18:53:10 WENorum Minor tweak to make it easier to insert some code to test realignment. 4.104.114.84.95
(edit) @f077cc96   06/20/05 20:48:48 WENorum Clean up transmit buffer realignment. Many thanks to Mr. Kolja Waschk … 4.104.114.84.95
(edit) @18ec73e3   06/17/05 14:33:23 Joel Sherrill 2005-06-17 Joel Sherrill <joel@…> * include/.cvsignore: … 4.104.114.84.95
(edit) @181601f   06/17/05 14:30:24 Joel Sherrill 2005-06-17 Joel Sherrill <joel@…> * acinclude.m4: Added … 4.104.114.84.95
(edit) @1612af0   06/17/05 14:06:05 Joel Sherrill 2005-06-17 Mike Bertosh <mbertosh@…> * .cvsignore, … 4.104.114.84.95
(edit) @34c4852   05/26/05 05:36:48 Ralf Corsepius 2005-05-26 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @5d25da9   05/24/05 04:05:39 WENorum Fix typo. 4.104.114.84.95
(edit) @e2f88ab9   05/24/05 01:07:45 WENorum Try to maintain compatability with everyone else's VBR changes. 4.104.114.84.95
(edit) @207a979   05/20/05 19:04:17 Joel Sherrill 2005-05-20 Joel Sherrill <joel@…> * console/duart.c: … 4.104.114.84.95
(edit) @d00b37d0   05/11/05 13:40:29 WENorum Followup fix to Joel's earlier _VBR changes. 4.104.114.84.95
(edit) @b6cfe2f6   05/10/05 23:24:23 WENorum Poke RDAR/TDAR every time. Add more diagnostic printout. 4.104.114.84.95
(edit) @36078145   05/04/05 22:34:18 WENorum Clarify bootstrap procedure. 4.104.114.84.95
(edit) @d2fbe62   05/03/05 22:31:39 Joel Sherrill 2005-05-03 Joel Sherrill <joel@…> * startup/init5282.c: … 4.104.114.84.95
(edit) @6191ee4   04/26/05 23:11:35 Joel Sherrill 2005-04-26 Joel Sherrill <joel@…> * network/network.c: … 4.104.114.84.95
(edit) @1321155f   04/26/05 23:10:50 Joel Sherrill 2005-04-26 Joel Sherrill <joel@…> * network/network.c: … 4.104.114.84.95
(edit) @8b9e7f1   04/26/05 23:07:58 Joel Sherrill 2005-04-26 Joel Sherrill <joel@…> * startup/alloc360.c: … 4.104.114.84.95
(edit) @9d5993b   04/26/05 18:29:03 WENorum Fix typos. 4.104.114.84.95
(edit) @ac9bbe7   04/21/05 00:25:53 WENorum Try insructioin-only cache. 4.104.114.84.95
(edit) @d5fe91e   04/19/05 20:50:45 WENorum Expose some read/write copies of configuration registers. 4.104.114.84.95
(edit) @27111a79   04/13/05 19:31:26 WENorum Add some more diagnostics. Poke TDAR/RDAR only when necessary. 4.104.114.84.95
(edit) @402f4df   04/10/05 21:10:32 WENorum Set up IRQ1* handling properly. 4.104.114.84.95
(edit) @a81e4f1   04/09/05 01:59:49 WENorum FPGA interrupt status register is now 16-bit. 4.104.114.84.95
(edit) @3adc6c13   03/12/05 16:02:34 WENorum Add statistics counter for number of transmit bytes realigned. 4.104.114.84.95
(edit) @b3e3a5fd   03/11/05 20:06:37 Joel Sherrill 2005-03-11 Joel Sherrill <joel@…> * startup/init68360.c: … 4.104.114.84.95
(edit) @cbb615b   03/10/05 19:52:35 WENorum Add NOP after writing the CACR is there to address the issue noted in … 4.104.114.84.95
(edit) @a79cb5b8   03/03/05 01:27:33 WENorum Add missing line. 4.104.114.84.95
(edit) @cc8c3d4   03/03/05 01:21:47 WENorum Add some more EPICS notes. 4.104.114.84.95
(edit) @bb540989   02/14/05 22:38:03 WENorum Remove some now-unused declarations. 4.104.114.84.95
(edit) @059c95e   02/14/05 22:05:04 WENorum Don't cache flash. 4.104.114.84.95
(edit) @12cad01   02/13/05 18:03:10 WENorum EPICS has its own log facility so don't bother with LOGSERVER. 4.104.114.84.95
(edit) @008c4b5   02/12/05 22:26:37 WENorum Rearrange devLib address spaces. 4.104.114.84.95
(edit) @8af3643   02/12/05 22:20:28 WENorum Add some more system calls. Improve in-line assembly. 4.104.114.84.95
(edit) @c97f5fd   02/12/05 01:35:44 Joel Sherrill 2005-02-11 Joel Sherrill <joel@…> * m68kpretaskinghook.c: … 4.104.114.84.95
(edit) @3e53230   02/12/05 01:35:38 Joel Sherrill 2005-02-11 Joel Sherrill <joel@…> * include/bsp.h: Correct … 4.104.114.84.95
(edit) @c95013a0   02/12/05 01:35:32 Joel Sherrill 2005-02-11 Joel Sherrill <joel@…> * include/bsp.h, … 4.104.114.84.95
(edit) @16ae480   02/10/05 22:22:59 WENorum Name changes. Add some more system calls. 4.104.114.84.95
(edit) @c2ab8b0   02/08/05 00:43:39 WENorum Intra-level priorities range from 0 to 7. Levels range from 1 to 6. 4.104.114.84.95
(edit) @f3f4be7   02/08/05 00:21:08 WENorum Ensure consistency of 'installed' bitmap. 4.104.114.84.95
(edit) @8e712757   02/07/05 23:07:01 WENorum Set INTC0_ICRx registers properly. 4.104.114.84.95
(edit) @4fabd645   02/05/05 20:08:45 WENorum Fix typo. 4.104.114.84.95
(edit) @0eff7b8   02/05/05 19:58:45 WENorum Clean up the RAM/FLASH sizes/locations are specified. 4.104.114.84.95
(edit) @fa39b174   02/04/05 20:29:42 WENorum Fix flash base address. Enable UART2. 4.104.114.84.95
(edit) @d88c378   02/04/05 16:15:06 Ralf Corsepius Reformat. 4.104.114.84.95
(edit) @a7e6bc96   02/04/05 15:37:04 WENorum Clean up INTC0 initialization. EPORT1-7 sources are fixed level/priority. 4.104.114.84.95
(edit) @0b2c943   02/04/05 08:46:43 Ralf Corsepius 2005-02-04 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @be129f69   02/04/05 08:43:39 Ralf Corsepius 2005-02-04 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @3479b8b1   02/04/05 00:40:43 Joel Sherrill Fixed formatting. 4.104.114.84.95
(edit) @d75023e   02/03/05 22:52:26 WENorum Add 'extended' BSP support (pseudo-VME) 4.104.114.84.95
(edit) @5b6111b   02/03/05 16:01:04 WENorum Add support for interrupt controller allocation. This will provides a … 4.104.114.84.95
(edit) @98653c6   02/02/05 19:55:59 WENorum Lock FEC/PHYS at 100 Mbs, full-duplex. 4.104.114.84.95
(edit) @12993b3   02/02/05 14:17:26 WENorum Clean up bootloader syscall handling. 4.104.114.84.95
(edit) @dd2f891   02/02/05 14:17:11 WENorum Provide 'last-ditch' hardware address. 4.104.114.84.95
(edit) @043329e   02/02/05 01:21:05 WENorum Add interrupt assignment map. 4.104.114.84.95
(edit) @1d386ff   02/01/05 22:36:53 WENorum Want only two serial ports for now. 4.104.114.84.95
(edit) @c60eccb   02/01/05 20:05:00 WENorum Add EPICS information. 4.104.114.84.95
(edit) @7eab0f78   02/01/05 17:16:41 WENorum Add some bootrom system calls. 4.104.114.84.95
(edit) @7c7184a   02/01/05 15:12:55 WENorum Place FEC buffer descriptors in static RAM. No more cache concerns. 4.104.114.84.95
(edit) @fa5dfe8   01/31/05 19:04:33 WENorum Remove diagnostic printf. 4.104.114.84.95
(edit) @518edef   01/31/05 19:03:41 WENorum Processor doesn't snoop FEC DMA so we must invalidate the cache … 4.104.114.84.95
(edit) @7a2ebd3   01/31/05 14:37:51 Joel Sherrill Move entry to appropriate sub-ChangeLogs?. 4.104.114.84.95
(edit) @5579a28   01/31/05 14:37:33 Joel Sherrill 2005-01-28 Eric Norum <norume@…> * m68kpretaskinghook.c: … 4.104.114.84.95
(edit) @239b819   01/31/05 14:37:03 Joel Sherrill 2005-01-31 Joel Sherrill <joel@…> * .cvsignore: New file. 4.104.114.84.95
(edit) @098c4f9a   01/31/05 14:37:00 Joel Sherrill New file. 4.104.114.84.95
(edit) @d5f0a05   01/28/05 23:03:17 WENorum printk really does work! 4.104.114.84.95
(edit) @dfbfe5df   01/28/05 19:38:47 WENorum Cosmetic. 4.104.114.84.95
(edit) @572484f   01/28/05 19:35:23 WENorum New BSP for Arcturus uCDIMM ColdFire? 5282. 4.104.114.84.95
(edit) @9d83387b   01/28/05 03:02:15 Ralf Corsepius Cosmetics. 4.104.114.84.95
(edit) @445f8cc   01/22/05 04:13:41 Ralf Corsepius 2005-01-22 Ralf Corsepius <ralf.corsepius@…> * tod/todcfg.c: … 4.104.114.84.95
(edit) @9afd70e   01/18/05 06:01:23 Ralf Corsepius 2005-01-18 Ralf Corsepius <ralf.corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @21023ab8   01/09/05 16:59:49 Joel Sherrill 2005-01-09 Joel Sherrill <joel@…> * startup/linkcmds: Add … 4.104.114.84.95
(edit) @844609f9   01/07/05 06:57:39 Ralf Corsepius 2005-01-07 Ralf Corsepius <ralf.corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @55068fa5   01/05/05 18:12:35 Ralf Corsepius 2005-01-05 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @78962326   01/04/05 23:28:10 Joel Sherrill 2005-01-04 Joel Sherrill <joel@…> * console/sci.c: Remove … 4.104.114.84.95
(edit) @c11aaf49   01/04/05 23:28:06 Joel Sherrill 2005-01-04 Joel Sherrill <joel@…> * console/leds.c: Remove … 4.104.114.84.95
(edit) @d99aa9d   01/04/05 23:28:03 Joel Sherrill 2005-01-04 Joel Sherrill <joel@…> * console/console.c: … 4.104.114.84.95
(edit) @b5e685b0   01/04/05 23:27:57 Joel Sherrill 2005-01-04 Joel Sherrill <joel@…> * console/console-io.c, … 4.104.114.84.95
(edit) @4cbf22a   01/02/05 21:06:25 Ralf Corsepius 2005-01-02 Ralf Corsepius <ralf.corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @1f9f30a1   01/02/05 02:59:19 Ralf Corsepius 2005-01-02 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @b815d9e   01/01/05 11:14:03 Ralf Corsepius 2005-01-01 Ralf Corsepius <ralf_corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @3dae380   11/26/04 01:58:19 Joel Sherrill 2004-11-25 Joel Sherrill <joel@…> * startup/linkcmds: Add … 4.104.114.84.95
(edit) @7f71164   11/26/04 01:56:20 Joel Sherrill 2004-11-25 Joel Sherrill <joel@…> * startup/linkcmds: Add … 4.104.114.84.95
(edit) @9f903322   11/26/04 01:54:51 Joel Sherrill 2004-11-25 Joel Sherrill <joel@…> * startup/linkcmds, … 4.104.114.84.95
(edit) @f331442d   11/26/04 01:54:41 Joel Sherrill 2004-11-25 Joel Sherrill <joel@…> * startup/linkcmds, … 4.104.114.84.95
(edit) @5f0fdeb   11/26/04 01:54:22 Joel Sherrill 2004-11-25 Joel Sherrill <joel@…> * startup/linkcmds, … 4.104.114.84.95
(edit) @46ce08d   11/19/04 04:44:55 Ralf Corsepius 2004-11-19 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @9fcf77a6   10/28/04 18:09:48 Joel Sherrill 2004-10-28 Joel Sherrill <joel@…> * startup/linkcmds: Add … 4.104.114.84.95
(edit) @646bf00   10/27/04 23:15:41 Ralf Corsepius 2004-10-27 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @f002813d   10/26/04 03:40:54 Ralf Corsepius Reformat. 4.104.114.84.95
(edit) @1dff10fd   10/21/04 13:15:54 Ralf Corsepius 2004-10-21 Ralf Corsepius <ralf_corsepius@…> * … 4.104.114.84.95
(edit) @3e46c1cf   09/24/04 06:32:10 Ralf Corsepius Fix typo in previous change. 4.104.114.84.95
(edit) @97891e5e   09/24/04 05:54:59 Ralf Corsepius 2004-09-24 Ralf Corsepius <ralf_corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @7df6efc5   09/15/04 14:13:11 Joel Sherrill 2004-09-15 Joel Sherrill <joel@…> * README, times, … 4.104.114.84.95
(edit) @02e708d   08/03/04 05:01:51 Jay Monkman 2004-08-03 Jay Monkman <jtm@…> * .cvsignore, ChangeLog?, … 4.104.114.84.95
(edit) @888bc77   07/25/04 14:24:01 Joel Sherrill 2004-07-25 Joel Sherrill <joel@…> * network/network.c: Add … 4.104.114.84.95
(edit) @26e064ec   05/21/04 14:23:59 Joel Sherrill 2004-05-21 Joel Sherrill <joel@…> * network/network.c: … 4.104.114.84.95
(edit) @3defec6   04/23/04 04:47:38 Ralf Corsepius 2004-04-23 Ralf Corsepius <ralf_corsepius@…> PR 610/bsps * … 4.104.114.84.95
