Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src/lib/libbsp/m68k
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @c50fb1c   02/08/06 12:25:04 Joel Sherrill 2006-02-08 Joel Sherrill <joel@…> * startup/linkcmds, … 4.104.114.84.95
(edit) @b468898   02/06/06 21:43:58 WENorum Avoid possible division by zero. 4.104.114.84.95
(edit) @b8b8d34   02/01/06 18:38:30 Joel Sherrill Formatting. 4.104.114.84.95
(edit) @be5b08a   01/29/06 22:48:33 WENorum Add code to maintain CPU load average. 4.104.114.84.95
(edit) @2eb7d07e   01/14/06 06:20:35 Ralf Corsepius Regenerate. 4.104.114.84.95
(edit) @008ff567   01/12/06 10:16:01 Ralf Corsepius Regenerate. 4.104.114.84.95
(edit) @fc1a3ba   01/12/06 10:12:31 Ralf Corsepius Remove all-local:. 4.104.114.84.95
(edit) @950f19a   01/12/06 05:57:00 Ralf Corsepius Regenerate. 4.104.114.84.95
(edit) @bb1571ec   01/12/06 05:40:08 Ralf Corsepius Cleanup. 4.104.114.84.95
(edit) @399c163b   01/11/06 05:33:23 Ralf Corsepius Remove leftovers of consolex. 4.104.114.84.95
(edit) @5a9284a   01/11/06 05:26:03 Ralf Corsepius 2006-01-11 Ralf Corsepius <ralf.corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @760486f7   01/11/06 05:25:53 Ralf Corsepius 2006-01-11 Ralf Corsepius <ralf.corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @d2bba01c   01/11/06 05:23:17 Ralf Corsepius New. 4.104.114.84.95
(edit) @80d4330   01/08/06 18:07:33 Joel Sherrill 2006-01-08 Joel Sherrill <joel@…> * network/network.c: … 4.104.114.84.95
(edit) @91cb065   12/19/05 21:23:52 WENorum Add another 'extended BSP' routine which returns reboot status … 4.104.114.84.95
(edit) @bf221c5   11/12/05 07:21:23 Ralf Corsepius 2005-11-12 Ralf Corsepius <ralf.corsepius@…> * bsp_specs: … 4.104.114.84.95
(edit) @bcd0867d   11/12/05 07:08:33 Ralf Corsepius 2005-11-12 Ralf Corsepius <ralf.corsepius@…> * bsp_specs: … 4.104.114.84.95
(edit) @46fa1f64   11/11/05 15:48:24 WENorum Clean up UART2 pin setup. Protect pin setup code. 4.104.114.84.95
(edit) @8e6835a5   11/08/05 20:11:02 WENorum Add code to set up pin assignments. 4.104.114.84.95
(edit) @91c832b9   11/07/05 17:30:17 WENorum Remove assignation to U.S. Government. 4.104.114.84.95
(edit) @12b36efe   11/07/05 17:22:23 WENorum Assign copyright to OAR since all files descend from OAR's source. 4.104.114.84.95
(edit) @086c1c3   11/07/05 16:19:21 Joel Sherrill Fixed formatting. 4.104.114.84.95
(edit) @cb98129   11/07/05 06:26:45 Ralf Corsepius 2005-11-07 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @71a7ed0   11/07/05 06:26:37 Ralf Corsepius Eliminate unsigned32. 4.104.114.84.95
(edit) @8fd9e978   11/07/05 06:26:08 Ralf Corsepius Eliminate unsigned32, unsigned8. 4.104.114.84.95
(edit) @e3996e2b   11/07/05 06:23:24 Ralf Corsepius 2005-11-07 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @9ab9f026   11/07/05 06:23:14 Ralf Corsepius Several minor bug fixes. 4.104.114.84.95
(edit) @21dd4cf8   10/26/05 14:56:58 WENorum Allow network to be locked at 100/Full. 4.104.114.84.95
(edit) @1ebfc5af   10/17/05 08:51:36 Ralf Corsepius Remove. 4.104.114.84.95
(edit) @6fdf978   10/17/05 08:51:06 Ralf Corsepius 2005-10-17 Ralf Corsepius <ralf.corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @030b91e   09/19/05 21:57:17 WENorum Silently return to bootstrap PROM. 4.104.114.84.95
(edit) @8627734   09/19/05 03:47:45 Ralf Corsepius Correct my email address. 4.104.114.84.95
(edit) @dbc7c79   09/19/05 03:47:16 Ralf Corsepius 2005-09-19 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @c140041b   09/19/05 03:46:17 Ralf Corsepius Include <errno.h> instead of <sys/errno.h>. 4.104.114.84.95
(edit) @b7115915   09/16/05 02:40:14 WENorum Add bsp_reset bootrom call. Call bsp_reset from bsp_cleanup(). 4.104.114.84.95
(edit) @27178a81   08/17/05 22:07:46 Joel Sherrill New file. 4.104.114.84.95
(edit) @a3aac67   08/17/05 22:03:45 Joel Sherrill 2005-08-17 Mike Bertosh <mbertosh@…> * acinclude.m4: … 4.104.114.84.95
(edit) @1b269c56   08/17/05 22:03:22 Joel Sherrill 2005-08-17 Mike Bertosh <mbertosh@…> * .cvsignore, … 4.104.114.84.95
(edit) @d452949f   07/24/05 19:10:31 WENorum Add .gnu.linkonce.b 4.104.114.84.95
(edit) @2025958   07/24/05 18:33:55 WENorum Add .gnu.linkonce.b.* relocation. 4.104.114.84.95
(edit) @728e177   07/06/05 00:17:28 WENorum Enable CS1* and CS2* now that Arcturus bootstrap PROMs no longer take … 4.104.114.84.95
(edit) @d0f01d2   06/30/05 11:53:12 WENorum Add description of external interrupt request assignments. 4.104.114.84.95
(edit) @57519ea   06/29/05 22:00:17 WENorum Reflect changes to network driver. 4.104.114.84.95
(edit) @5eb336b   06/29/05 20:44:25 WENorum Drive LEDs with more useful information. 4.104.114.84.95
(edit) @81291a0   06/29/05 20:09:14 WENorum Add duplex negotation support. 4.104.114.84.95
(edit) @cdb717e   06/22/05 18:53:10 WENorum Minor tweak to make it easier to insert some code to test realignment. 4.104.114.84.95
(edit) @f077cc96   06/20/05 20:48:48 WENorum Clean up transmit buffer realignment. Many thanks to Mr. Kolja Waschk … 4.104.114.84.95
(edit) @18ec73e3   06/17/05 14:33:23 Joel Sherrill 2005-06-17 Joel Sherrill <joel@…> * include/.cvsignore: … 4.104.114.84.95
(edit) @181601f   06/17/05 14:30:24 Joel Sherrill 2005-06-17 Joel Sherrill <joel@…> * acinclude.m4: Added … 4.104.114.84.95
(edit) @1612af0   06/17/05 14:06:05 Joel Sherrill 2005-06-17 Mike Bertosh <mbertosh@…> * .cvsignore, … 4.104.114.84.95
(edit) @34c4852   05/26/05 05:36:48 Ralf Corsepius 2005-05-26 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @5d25da9   05/24/05 04:05:39 WENorum Fix typo. 4.104.114.84.95
(edit) @e2f88ab9   05/24/05 01:07:45 WENorum Try to maintain compatability with everyone else's VBR changes. 4.104.114.84.95
(edit) @207a979   05/20/05 19:04:17 Joel Sherrill 2005-05-20 Joel Sherrill <joel@…> * console/duart.c: … 4.104.114.84.95
(edit) @d00b37d0   05/11/05 13:40:29 WENorum Followup fix to Joel's earlier _VBR changes. 4.104.114.84.95
(edit) @b6cfe2f6   05/10/05 23:24:23 WENorum Poke RDAR/TDAR every time. Add more diagnostic printout. 4.104.114.84.95
(edit) @36078145   05/04/05 22:34:18 WENorum Clarify bootstrap procedure. 4.104.114.84.95
(edit) @d2fbe62   05/03/05 22:31:39 Joel Sherrill 2005-05-03 Joel Sherrill <joel@…> * startup/init5282.c: … 4.104.114.84.95
(edit) @6191ee4   04/26/05 23:11:35 Joel Sherrill 2005-04-26 Joel Sherrill <joel@…> * network/network.c: … 4.104.114.84.95
(edit) @1321155f   04/26/05 23:10:50 Joel Sherrill 2005-04-26 Joel Sherrill <joel@…> * network/network.c: … 4.104.114.84.95
(edit) @8b9e7f1   04/26/05 23:07:58 Joel Sherrill 2005-04-26 Joel Sherrill <joel@…> * startup/alloc360.c: … 4.104.114.84.95
(edit) @9d5993b   04/26/05 18:29:03 WENorum Fix typos. 4.104.114.84.95
(edit) @ac9bbe7   04/21/05 00:25:53 WENorum Try insructioin-only cache. 4.104.114.84.95
(edit) @d5fe91e   04/19/05 20:50:45 WENorum Expose some read/write copies of configuration registers. 4.104.114.84.95
(edit) @27111a79   04/13/05 19:31:26 WENorum Add some more diagnostics. Poke TDAR/RDAR only when necessary. 4.104.114.84.95
(edit) @402f4df   04/10/05 21:10:32 WENorum Set up IRQ1* handling properly. 4.104.114.84.95
(edit) @a81e4f1   04/09/05 01:59:49 WENorum FPGA interrupt status register is now 16-bit. 4.104.114.84.95
(edit) @3adc6c13   03/12/05 16:02:34 WENorum Add statistics counter for number of transmit bytes realigned. 4.104.114.84.95
(edit) @b3e3a5fd   03/11/05 20:06:37 Joel Sherrill 2005-03-11 Joel Sherrill <joel@…> * startup/init68360.c: … 4.104.114.84.95
(edit) @cbb615b   03/10/05 19:52:35 WENorum Add NOP after writing the CACR is there to address the issue noted in … 4.104.114.84.95
(edit) @a79cb5b8   03/03/05 01:27:33 WENorum Add missing line. 4.104.114.84.95
(edit) @cc8c3d4   03/03/05 01:21:47 WENorum Add some more EPICS notes. 4.104.114.84.95
(edit) @bb540989   02/14/05 22:38:03 WENorum Remove some now-unused declarations. 4.104.114.84.95
(edit) @059c95e   02/14/05 22:05:04 WENorum Don't cache flash. 4.104.114.84.95
(edit) @12cad01   02/13/05 18:03:10 WENorum EPICS has its own log facility so don't bother with LOGSERVER. 4.104.114.84.95
(edit) @008c4b5   02/12/05 22:26:37 WENorum Rearrange devLib address spaces. 4.104.114.84.95
(edit) @8af3643   02/12/05 22:20:28 WENorum Add some more system calls. Improve in-line assembly. 4.104.114.84.95
(edit) @c97f5fd   02/12/05 01:35:44 Joel Sherrill 2005-02-11 Joel Sherrill <joel@…> * m68kpretaskinghook.c: … 4.104.114.84.95
(edit) @3e53230   02/12/05 01:35:38 Joel Sherrill 2005-02-11 Joel Sherrill <joel@…> * include/bsp.h: Correct … 4.104.114.84.95
(edit) @c95013a0   02/12/05 01:35:32 Joel Sherrill 2005-02-11 Joel Sherrill <joel@…> * include/bsp.h, … 4.104.114.84.95
(edit) @16ae480   02/10/05 22:22:59 WENorum Name changes. Add some more system calls. 4.104.114.84.95
(edit) @c2ab8b0   02/08/05 00:43:39 WENorum Intra-level priorities range from 0 to 7. Levels range from 1 to 6. 4.104.114.84.95
(edit) @f3f4be7   02/08/05 00:21:08 WENorum Ensure consistency of 'installed' bitmap. 4.104.114.84.95
(edit) @8e712757   02/07/05 23:07:01 WENorum Set INTC0_ICRx registers properly. 4.104.114.84.95
(edit) @4fabd645   02/05/05 20:08:45 WENorum Fix typo. 4.104.114.84.95
(edit) @0eff7b8   02/05/05 19:58:45 WENorum Clean up the RAM/FLASH sizes/locations are specified. 4.104.114.84.95
(edit) @fa39b174   02/04/05 20:29:42 WENorum Fix flash base address. Enable UART2. 4.104.114.84.95
(edit) @d88c378   02/04/05 16:15:06 Ralf Corsepius Reformat. 4.104.114.84.95
(edit) @a7e6bc96   02/04/05 15:37:04 WENorum Clean up INTC0 initialization. EPORT1-7 sources are fixed level/priority. 4.104.114.84.95
(edit) @0b2c943   02/04/05 08:46:43 Ralf Corsepius 2005-02-04 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @be129f69   02/04/05 08:43:39 Ralf Corsepius 2005-02-04 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @3479b8b1   02/04/05 00:40:43 Joel Sherrill Fixed formatting. 4.104.114.84.95
(edit) @d75023e   02/03/05 22:52:26 WENorum Add 'extended' BSP support (pseudo-VME) 4.104.114.84.95
(edit) @5b6111b   02/03/05 16:01:04 WENorum Add support for interrupt controller allocation. This will provides a … 4.104.114.84.95
(edit) @98653c6   02/02/05 19:55:59 WENorum Lock FEC/PHYS at 100 Mbs, full-duplex. 4.104.114.84.95
(edit) @12993b3   02/02/05 14:17:26 WENorum Clean up bootloader syscall handling. 4.104.114.84.95
(edit) @dd2f891   02/02/05 14:17:11 WENorum Provide 'last-ditch' hardware address. 4.104.114.84.95
(edit) @043329e   02/02/05 01:21:05 WENorum Add interrupt assignment map. 4.104.114.84.95
(edit) @1d386ff   02/01/05 22:36:53 WENorum Want only two serial ports for now. 4.104.114.84.95
(edit) @c60eccb   02/01/05 20:05:00 WENorum Add EPICS information. 4.104.114.84.95
