@b6cfe2f6
05/10/05 23:24:23 |
WENorum |
Poke RDAR/TDAR every time. Add more diagnostic printout.
4.104.114.84.95
@36078145
05/04/05 22:34:18 |
WENorum |
Clarify bootstrap procedure.
4.104.114.84.95
@d2fbe62
05/03/05 22:31:39 |
Joel Sherrill |
2005-05-03 Joel Sherrill <joel@…>
* startup/init5282.c: …
4.104.114.84.95
@6191ee4
04/26/05 23:11:35 |
Joel Sherrill |
2005-04-26 Joel Sherrill <joel@…>
* network/network.c: …
4.104.114.84.95
@1321155f
04/26/05 23:10:50 |
Joel Sherrill |
4.104.114.84.95
@8b9e7f1
04/26/05 23:07:58 |
Joel Sherrill |
* startup/alloc360.c: …
4.104.114.84.95
@9d5993b
04/26/05 18:29:03 |
WENorum |
Fix typos.
4.104.114.84.95
@ac9bbe7
04/21/05 00:25:53 |
WENorum |
Try insructioin-only cache.
4.104.114.84.95
@d5fe91e
04/19/05 20:50:45 |
WENorum |
Expose some read/write copies of configuration registers.
4.104.114.84.95
@27111a79
04/13/05 19:31:26 |
WENorum |
Add some more diagnostics. Poke TDAR/RDAR only when necessary.
4.104.114.84.95
@402f4df
04/10/05 21:10:32 |
WENorum |
Set up IRQ1* handling properly.
4.104.114.84.95
@a81e4f1
04/09/05 01:59:49 |
WENorum |
FPGA interrupt status register is now 16-bit.
4.104.114.84.95
@3adc6c13
03/12/05 16:02:34 |
WENorum |
Add statistics counter for number of transmit bytes realigned.
4.104.114.84.95
@b3e3a5fd
03/11/05 20:06:37 |
Joel Sherrill |
2005-03-11 Joel Sherrill <joel@…>
* startup/init68360.c: …
4.104.114.84.95
@cbb615b
03/10/05 19:52:35 |
WENorum |
Add NOP after writing the CACR is there to address the issue
noted in …
4.104.114.84.95
@a79cb5b8
03/03/05 01:27:33 |
WENorum |
Add missing line.
4.104.114.84.95
@cc8c3d4
03/03/05 01:21:47 |
WENorum |
Add some more EPICS notes.
4.104.114.84.95
@bb540989
02/14/05 22:38:03 |
WENorum |
Remove some now-unused declarations.
4.104.114.84.95
@059c95e
02/14/05 22:05:04 |
WENorum |
Don't cache flash.
4.104.114.84.95
@12cad01
02/13/05 18:03:10 |
WENorum |
EPICS has its own log facility so don't bother with LOGSERVER.
4.104.114.84.95
@008c4b5
02/12/05 22:26:37 |
WENorum |
Rearrange devLib address spaces.
4.104.114.84.95
@8af3643
02/12/05 22:20:28 |
WENorum |
Add some more system calls.
Improve in-line assembly.
4.104.114.84.95
@c97f5fd
02/12/05 01:35:44 |
Joel Sherrill |
2005-02-11 Joel Sherrill <joel@…>
* m68kpretaskinghook.c: …
4.104.114.84.95
@3e53230
02/12/05 01:35:38 |
Joel Sherrill |
* include/bsp.h: Correct …
4.104.114.84.95
@c95013a0
02/12/05 01:35:32 |
Joel Sherrill |
* include/bsp.h, …
4.104.114.84.95
@16ae480
02/10/05 22:22:59 |
WENorum |
Name changes.
4.104.114.84.95
@c2ab8b0
02/08/05 00:43:39 |
WENorum |
Intra-level priorities range from 0 to 7.
Levels range from 1 to 6.
4.104.114.84.95
@f3f4be7
02/08/05 00:21:08 |
WENorum |
Ensure consistency of 'installed' bitmap.
4.104.114.84.95
@8e712757
02/07/05 23:07:01 |
WENorum |
Set INTC0_ICRx registers properly.
4.104.114.84.95
@4fabd645
02/05/05 20:08:45 |
WENorum |
Fix typo.
4.104.114.84.95
@0eff7b8
02/05/05 19:58:45 |
WENorum |
Clean up the RAM/FLASH sizes/locations are specified.
4.104.114.84.95
@fa39b174
02/04/05 20:29:42 |
WENorum |
Fix flash base address.
Enable UART2.
4.104.114.84.95
@d88c378
02/04/05 16:15:06 |
Ralf Corsepius |
Reformat.
4.104.114.84.95
@a7e6bc96
02/04/05 15:37:04 |
WENorum |
Clean up INTC0 initialization. EPORT1-7 sources are fixed level/priority.
4.104.114.84.95
@0b2c943
02/04/05 08:46:43 |
Ralf Corsepius |
2005-02-04 Ralf Corsepius <ralf.corsepius@…>
4.104.114.84.95
@be129f69
02/04/05 08:43:39 |
Ralf Corsepius |
4.104.114.84.95
@3479b8b1
02/04/05 00:40:43 |
Joel Sherrill |
Fixed formatting.
4.104.114.84.95
@d75023e
02/03/05 22:52:26 |
WENorum |
Add 'extended' BSP support (pseudo-VME)
4.104.114.84.95
@5b6111b
02/03/05 16:01:04 |
WENorum |
Add support for interrupt controller allocation. This will provides a …
4.104.114.84.95
@98653c6
02/02/05 19:55:59 |
WENorum |
Lock FEC/PHYS at 100 Mbs, full-duplex.
4.104.114.84.95
@12993b3
02/02/05 14:17:26 |
WENorum |
Clean up bootloader syscall handling.
4.104.114.84.95
@dd2f891
02/02/05 14:17:11 |
WENorum |
Provide 'last-ditch' hardware address.
4.104.114.84.95
@043329e
02/02/05 01:21:05 |
WENorum |
Add interrupt assignment map.
4.104.114.84.95
@1d386ff
02/01/05 22:36:53 |
WENorum |
Want only two serial ports for now.
4.104.114.84.95
@c60eccb
02/01/05 20:05:00 |
WENorum |
Add EPICS information.
4.104.114.84.95
@7eab0f78
02/01/05 17:16:41 |
WENorum |
Add some bootrom system calls.
4.104.114.84.95
@7c7184a
02/01/05 15:12:55 |
WENorum |
Place FEC buffer descriptors in static RAM. No more cache concerns.
4.104.114.84.95
@fa5dfe8
01/31/05 19:04:33 |
WENorum |
Remove diagnostic printf.
4.104.114.84.95
@518edef
01/31/05 19:03:41 |
WENorum |
Processor doesn't snoop FEC DMA so we must invalidate the cache …
4.104.114.84.95
@7a2ebd3
01/31/05 14:37:51 |
Joel Sherrill |
Move entry to appropriate sub-ChangeLogs?.
4.104.114.84.95
@5579a28
01/31/05 14:37:33 |
Joel Sherrill |
2005-01-28 Eric Norum <norume@…>
4.104.114.84.95
@239b819
01/31/05 14:37:03 |
Joel Sherrill |
2005-01-31 Joel Sherrill <joel@…>
* .cvsignore: New file.
4.104.114.84.95
@098c4f9a
01/31/05 14:37:00 |
Joel Sherrill |
New file.
4.104.114.84.95
@d5f0a05
01/28/05 23:03:17 |
WENorum |
printk really does work!
4.104.114.84.95
@dfbfe5df
01/28/05 19:38:47 |
WENorum |
Cosmetic.
4.104.114.84.95
@572484f
01/28/05 19:35:23 |
WENorum |
New BSP for Arcturus uCDIMM ColdFire? 5282.
4.104.114.84.95
@9d83387b
01/28/05 03:02:15 |
Ralf Corsepius |
Cosmetics.
4.104.114.84.95
@445f8cc
01/22/05 04:13:41 |
Ralf Corsepius |
2005-01-22 Ralf Corsepius <ralf.corsepius@…>
* tod/todcfg.c: …
4.104.114.84.95
@9afd70e
01/18/05 06:01:23 |
Ralf Corsepius |
2005-01-18 Ralf Corsepius <ralf.corsepius@…>
* Makefile.am: …
4.104.114.84.95
@21023ab8
01/09/05 16:59:49 |
Joel Sherrill |
2005-01-09 Joel Sherrill <joel@…>
* startup/linkcmds: Add …
4.104.114.84.95
@844609f9
01/07/05 06:57:39 |
Ralf Corsepius |
2005-01-07 Ralf Corsepius <ralf.corsepius@…>
* Makefile.am: …
4.104.114.84.95
@55068fa5
01/05/05 18:12:35 |
Ralf Corsepius |
2005-01-05 Ralf Corsepius <ralf.corsepius@…>
4.104.114.84.95
@78962326
01/04/05 23:28:10 |
Joel Sherrill |
2005-01-04 Joel Sherrill <joel@…>
* console/sci.c: Remove …
4.104.114.84.95
@c11aaf49
01/04/05 23:28:06 |
Joel Sherrill |
* console/leds.c: Remove …
4.104.114.84.95
@d99aa9d
01/04/05 23:28:03 |
Joel Sherrill |
* console/console.c: …
4.104.114.84.95
@b5e685b0
01/04/05 23:27:57 |
Joel Sherrill |
* console/console-io.c, …
4.104.114.84.95
@4cbf22a
01/02/05 21:06:25 |
Ralf Corsepius |
2005-01-02 Ralf Corsepius <ralf.corsepius@…>
* Makefile.am: …
4.104.114.84.95
@1f9f30a1
01/02/05 02:59:19 |
Ralf Corsepius |
2005-01-02 Ralf Corsepius <ralf_corsepius@…>
4.104.114.84.95
@b815d9e
01/01/05 11:14:03 |
Ralf Corsepius |
2005-01-01 Ralf Corsepius <ralf_corsepius@…>
* configure.ac: …
4.104.114.84.95
@3dae380
11/26/04 01:58:19 |
Joel Sherrill |
2004-11-25 Joel Sherrill <joel@…>
4.104.114.84.95
@7f71164
11/26/04 01:56:20 |
Joel Sherrill |
4.104.114.84.95
@9f903322
11/26/04 01:54:51 |
Joel Sherrill |
* startup/linkcmds, …
4.104.114.84.95
@f331442d
11/26/04 01:54:41 |
Joel Sherrill |
4.104.114.84.95
@5f0fdeb
11/26/04 01:54:22 |
Joel Sherrill |
4.104.114.84.95
@46ce08d
11/19/04 04:44:55 |
Ralf Corsepius |
2004-11-19 Ralf Corsepius <ralf_corsepius@…>
4.104.114.84.95
@9fcf77a6
10/28/04 18:09:48 |
Joel Sherrill |
2004-10-28 Joel Sherrill <joel@…>
4.104.114.84.95
@646bf00
10/27/04 23:15:41 |
Ralf Corsepius |
2004-10-27 Ralf Corsepius <ralf_corsepius@…>
4.104.114.84.95
@f002813d
10/26/04 03:40:54 |
Ralf Corsepius |
Reformat.
4.104.114.84.95
@1dff10fd
10/21/04 13:15:54 |
Ralf Corsepius |
2004-10-21 Ralf Corsepius <ralf_corsepius@…>
4.104.114.84.95
@3e46c1cf
09/24/04 06:32:10 |
Ralf Corsepius |
Fix typo in previous change.
4.104.114.84.95
@97891e5e
09/24/04 05:54:59 |
Ralf Corsepius |
2004-09-24 Ralf Corsepius <ralf_corsepius@…>
* configure.ac: …
4.104.114.84.95
@7df6efc5
09/15/04 14:13:11 |
Joel Sherrill |
2004-09-15 Joel Sherrill <joel@…>
* README, times, …
4.104.114.84.95
@02e708d
08/03/04 05:01:51 |
Jay Monkman |
2004-08-03 Jay Monkman <jtm@…>
* .cvsignore, ChangeLog?, …
4.104.114.84.95
@888bc77
07/25/04 14:24:01 |
Joel Sherrill |
2004-07-25 Joel Sherrill <joel@…>
* network/network.c: Add …
4.104.114.84.95
@26e064ec
05/21/04 14:23:59 |
Joel Sherrill |
2004-05-21 Joel Sherrill <joel@…>
4.104.114.84.95
@3defec6
04/23/04 04:47:38 |
Ralf Corsepius |
2004-04-23 Ralf Corsepius <ralf_corsepius@…>
PR 610/bsps
4.104.114.84.95
@0df29b07
04/22/04 15:41:35 |
Ralf Corsepius |
2004-04-22 Ralf Corsepius <ralf_corsepius@…>
4.104.114.84.95
@e35761b
04/22/04 15:25:55 |
Ralf Corsepius |
4.104.114.84.95
@3344730a
04/21/04 16:21:25 |
Ralf Corsepius |
2004-04-21 Ralf Corsepius <ralf_corsepius@…>
PR 613/bsps
4.104.114.84.95
@7dd6e8d
04/21/04 16:16:38 |
Ralf Corsepius |
PR 614/bsps
4.104.114.84.95
@f05b2ac
04/21/04 16:01:48 |
Ralf Corsepius |
Remove duplicate white lines.
4.104.114.84.95
@6128a4a
04/21/04 10:43:04 |
Ralf Corsepius |
Remove stray white spaces.
4.104.114.84.95
@d3fdf89f
04/19/04 22:08:13 |
Joel Sherrill |
2004-04-19 Joel Sherrill <joel@…>
* start/start.S: DWARF …
4.104.114.84.95
@1f788a3
04/15/04 13:53:12 |
Ralf Corsepius |
4.104.114.84.95
@3239698
04/15/04 13:26:21 |
Ralf Corsepius |
4.104.114.84.95
@6f2aebe1
04/13/04 20:55:26 |
Joel Sherrill |
Fixed wrapping.
4.104.114.84.95
@1257707b
04/13/04 15:59:03 |
Ralf Corsepius |
2004-04-13 Ralf Corsepius <ralf_corsepius@…>
4.104.114.84.95
@7eb78e14
04/09/04 04:48:57 |
Ralf Corsepius |
2004-04-09 Ralf Corsepius <ralf_corsepius@…>
4.104.114.84.95
@11f147b7
04/08/04 11:35:19 |
Ralf Corsepius |
2004-04-08 Ralf Corsepius <ralf_corsepius@…>
4.104.114.84.95
@5e6d901
04/08/04 11:35:16 |
Ralf Corsepius |
4.104.114.84.95
