Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src/lib/libbsp/m68k
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @b2a78a3   12/15/14 15:42:08 Joel Sherrill mcf5225x-testsuite.tcfg: Add fileio 4.115
(edit) @12072880   12/04/14 09:03:50 Sebastian Huber Update bug report URL 4.115
(edit) @e870941   12/04/14 08:38:27 Sebastian Huber libmisc: More useful default configuration The dummy.c was a de-facto … 4.115
(edit) @dd309b1   12/01/14 03:55:23 Chris Johns m68k/mcf5235: GCC 4.9.2 generates invalid code for Init5235. Move the … 4.115
(edit) @46dde0fc   10/23/14 08:05:17 Sebastian Huber bsps: Move extern "C" to not cover includes Some includes may use C++ … 4.115
(edit) @d6db94a   10/20/14 15:59:08 Joel Sherrill m68k/mrm332: Fix warnings 4.115
(edit) @a8777397   10/20/14 15:58:57 Joel Sherrill m68k/mcf5329: Fix warnings 4.115
(edit) @63fe77e1   10/20/14 15:58:38 Joel Sherrill m68k/mcf5235: Fix warnings 4.115
(edit) @13827524   10/20/14 15:58:21 Joel Sherrill m68k/mcf5225x: Fix warnings 4.115
(edit) @3bba2a9b   10/20/14 15:58:09 Joel Sherrill m68k/mcf52235: Fix warnings 4.115
(edit) @fd36451   10/20/14 15:57:54 Joel Sherrill m68k/idp: Fix warnings 4.115
(edit) @21ee1c8   10/20/14 15:57:44 Joel Sherrill m68k/gen68360: Fix warnings 4.115
(edit) @4f21badb   10/20/14 02:27:09 Joel Sherrill m68k/csb360: Fix warnings 4.115
(edit) @3d4898f   10/20/14 02:21:06 Joel Sherrill m68k/av5282: Fix warning 4.115
(edit) @51995b69   10/19/14 22:14:07 Joel Sherrill m68k/mrm332: Move include of <rtems/m68k/sim.h> This file defines at … 4.115
(edit) @fd0dfd47   10/17/14 13:50:11 Joel Sherrill m68k/mcf5329/startup/init5329.c: Fix warning 4.115
(edit) @597caed   10/17/14 13:49:46 Joel Sherrill m68k/mcf52235/startup/init52235.c: Fix warning 4.115
(edit) @8e330bc   10/16/14 22:01:54 Joel Sherrill gen68302/console: Fix warnings 4.115
(edit) @f4c6c27   10/16/14 18:23:01 Joel Sherrill m68k/mrm332/console/sci.c: Fix missing variable error introduced by … 4.115
(edit) @a94fb39   10/15/14 23:34:36 Joel Sherrill mcf5206 libcpu and mcf5206elite: Fix warnings 4.115
(edit) @46dad9d4   10/15/14 22:54:02 Joel Sherrill m68k/mvme147: Fix warnings 4.115
(edit) @ef559c7   10/15/14 22:44:14 Joel Sherrill m68k/mvme167: Fix warnings 4.115
(edit) @6e14a99   10/15/14 22:31:04 Joel Sherrill m68k/shared and sim68000: Fix warnings 4.115
(edit) @c186f2ed   10/15/14 22:17:08 Joel Sherrill m68k/mvme162: Fix warnings 4.115
(edit) @c7e77ee   10/14/14 17:39:57 Joel Sherrill mcf5282: Move cache to libcpu and update av5282 and uC5282 BSPs 4.115
(edit) @c28f503   10/14/14 14:34:52 Joel Sherrill m68k/gen68340: Fix warnings 4.115
(edit) @af03345   10/13/14 21:54:12 Joel Sherrill Move CPU cache support from mcf5225x BSP to libcpu 4.115
(edit) @cba474e   10/13/14 19:50:12 Joel Sherrill m68k/ods68302: Fix warnings 4.115
(edit) @6da91abb   10/13/14 19:09:16 Joel Sherrill m68k/idp: Fix warnings 4.115
(edit) @d9c12bb   10/12/14 22:39:59 Joel Sherrill m68k/mcf5225x: Fix warnings 4.115
(edit) @45666bc7   10/12/14 19:09:12 Joel Sherrill m68k/mrm332/clock/ckinit.c: Remove clock major/minor and clean up 4.115
(edit) @cd1b0404   10/12/14 15:06:05 Joel Sherrill sim68000/clock/clockdrv.c: Fix warnings 4.115
(edit) @b3f86763   10/12/14 15:06:05 Joel Sherrill ods68302/clock/ckinit.c: Fix warnings 4.115
(edit) @6d44a3e   10/12/14 15:06:05 Joel Sherrill mvme167/clock/ckinit.c: Fix warnings 4.115
(edit) @88867e89   10/12/14 15:06:05 Joel Sherrill mvme162/clock/ckinit.c: Fix warnings 4.115
(edit) @7bddaa3c   10/12/14 15:06:05 Joel Sherrill mvme147/clock/ckinit.c: Fix warnings 4.115
(edit) @d1347a37   10/12/14 15:06:05 Joel Sherrill idp/clock/ckinit.c: Fix warnings 4.115
(edit) @8a442b5   10/12/14 15:06:05 Joel Sherrill gen68340/clock/ckinit.c: Fix warnings 4.115
(edit) @767164a   10/12/14 15:06:05 Joel Sherrill gen68302/clock/ckinit.c: Fix warnings 4.115
(edit) @0f9dd74   10/12/14 14:12:18 Joel Sherrill m68k/uC5282: Fix warnings 4.115
(edit) @66402ef2   10/12/14 00:09:52 Joel Sherrill m68k/mvme136: Fix warnings 4.115
(edit) @d08e1320   10/12/14 13:54:17 Joel Sherrill m68k/uC5282/console/console.c: Eliminate unused debug methods 4.115
(edit) @d5e533d   10/12/14 13:53:46 Joel Sherrill m68k/mcf5329/console/console.c: Eliminate unused debug methods 4.115
(edit) @b1c89d25   10/12/14 13:53:15 Joel Sherrill m68k/mcf5235/console/console.c: Eliminate unused debug methods 4.115
(edit) @ce1ba304   10/12/14 13:52:58 Joel Sherrill m68k/genmcf548x/console/console.c: Eliminate unused debug methods 4.115
(edit) @575c12c1   10/12/14 13:52:31 Joel Sherrill m68k/av5282/console/console.c: Eliminate unused debug methods 4.115
(edit) @6279149   10/08/14 21:04:56 Joel Sherrill Add console-polled.h and update all BSPs that should use it. The file … 4.115
(edit) @78a38fa2   10/08/14 22:38:12 Joel Sherrill Eliminate use of /*PAGE and clean up formatting 4.115
(edit) @253f5ec3   10/07/14 22:31:19 Joel Sherrill m68k/uC5282/startup/bspstart.c: Add include of <bsp/bootcard.h> to fix … 4.115
(edit) @0aab0a8   10/07/14 22:30:50 Joel Sherrill m68k/mvme162/startup/bspstart.c: Add include of <bsp/bootcard.h> to … 4.115
(edit) @1b679add   10/07/14 22:30:30 Joel Sherrill m68k/mvme147s/startup/bspstart.c: Add include of <bsp/bootcard.h> to … 4.115
(edit) @3c688ade   10/07/14 22:30:18 Joel Sherrill m68k/mvme147/startup/bspstart.c: Add include of <bsp/bootcard.h> to … 4.115
(edit) @754f51b6   10/07/14 22:29:29 Joel Sherrill m68k/mvme136/startup/bspstart.c: Add include of <bsp/bootcard.h> to … 4.115
(edit) @b587a20   10/07/14 22:29:06 Joel Sherrill m68k/mcf5329/startup/bspstart.c: Add include of <bsp/bootcard.h> to … 4.115
(edit) @736abcf   10/07/14 22:28:52 Joel Sherrill m68k/mcf5235/startup/bspstart.c: Add include of <bsp/bootcard.h> to … 4.115
(edit) @31ca0507   10/07/14 22:23:48 Joel Sherrill m68k/mcf5225x/startup/bspstart.c: Add include of <bsp/bootcard.h> to … 4.115
(edit) @bb9448b   10/07/14 22:23:28 Joel Sherrill m68k/idp/startup/bspstart.c: Add include of <bsp/bootcard.h> to fix … 4.115
(edit) @527a08ba   10/07/14 22:23:11 Joel Sherrill m68k/av5282/startup/bspstart.c: Add include of <bsp/bootcard.h> to fix … 4.115
(edit) @1d3025b5   10/09/14 05:27:48 Sebastian Huber bsp/genmcf548x: Fix warning 4.115
(edit) @79bbb1cb   09/23/14 08:45:23 Sebastian Huber bsp/genmcf548x: Use inline cache implementation 4.115
(edit) @c3bf343   09/23/14 08:36:02 Sebastian Huber bsp/genmcf548x: Delete duplicate network config 4.115
(edit) @bdd6082   09/18/14 09:07:41 Sebastian Huber bsps: Fix build error Fix build error introduced in … 4.115
(edit) @f535fe53   09/04/14 20:41:21 Joel Sherrill tod.h -> libcsupport like other driver and helper prototype files … 4.115
(edit) @8fbe2e6   09/04/14 13:59:49 Joel Sherrill Use correct prototype of benchmark_timer_read() This change starts … 4.115
(edit) @ae03ad26   09/02/14 17:29:42 Joel Sherrill mcf5235/.../linkcmds: Use dram region consistently like other variants … 4.115
(edit) @59990cc   08/29/14 02:48:01 Chris Johns Regenerate all preinstall.am files. With this patch the preinstall.am … 4.115
(edit) @b597c0d   08/28/14 13:44:52 Joel Sherrill Regenerate all preinstall.am files. Apparently, at some point … 4.115
(edit) @742402b5   07/16/14 20:45:49 Joel Sherrill m68k/gen68360/include/tm27.h: Correct comment 4.115
(edit) @6e868d87   07/16/14 20:43:05 Joel Sherrill Add More Testsuite Configuration Files and Update Existing Ones The … 4.115
(edit) @3660154   06/01/14 23:18:28 Joel Sherrill mrm332: Tests now build and fewer warnings 4.115
(edit) @053abcda   04/23/14 23:38:43 Joel Sherrill multiple BSPs: Remove BSP_SMALL_MEMORY 4.115
(edit) @1461b648   05/04/14 22:12:52 Chris Johns testsuite: Add a per BSP test check for tests not to build. Provide a … 4.115
(edit) @f412e12   04/24/14 13:21:00 Joel Sherrill mcf52235/configure.ac: Delete junk line 4.115
(edit) @812c9d6   04/22/14 15:44:20 Joel Sherrill sim68000/bsp_specs: Add crtbegin/end, crt[in] 4.115
(edit) @d60e760   04/22/14 07:45:39 Sebastian Huber bsps: Fix TLS support in linker command files The TLS section symbols … 4.115
(edit) @d4db719   04/03/14 20:13:08 Joel Sherrill sim68000/console/conscfg.c: Comment clean up 4.115
(edit) @89aa1ec8   03/24/14 09:32:10 james.fitzsimons m68k/mrm332: changes required to get the mrm332 bsp working again. … 4.115
(edit) @43e5a3c   03/17/14 18:25:48 Joel Sherrill sim68000/include/bsp.h: Remove rtems_bsp_delay() 4.115
(edit) @2e9efbf   03/17/14 18:25:48 Joel Sherrill ods68302/include/bsp.h: Remove rtems_bsp_delay() 4.115
(edit) @a4ee9f5   03/17/14 18:25:48 Joel Sherrill mvme136/include/bsp.h: Remove rtems_bsp_delay() 4.115
(edit) @3420b6b   03/17/14 18:25:48 Joel Sherrill mrm332/include/bsp.h: Remove rtems_bsp_delay() 4.115
(edit) @65e0fece   03/17/14 18:25:47 Joel Sherrill gen68360/include/bsp.h: Remove rtems_bsp_delay() 4.115
(edit) @99a1a2c5   03/17/14 18:25:47 Joel Sherrill gen68340/include/bsp.h: Remove rtems_bsp_delay() 4.115
(edit) @3139c1d0   03/17/14 18:25:47 Joel Sherrill gen68302/include/bsp.h: Remove rtems_bsp_delay() 4.115
(edit) @c499856   03/20/14 21:10:47 Chris Johns Change all references of rtems.com to rtems.org. 4.115
(edit) @0b9fd991   02/21/14 16:12:16 Sebastian Huber bsps: Add empty cache manager This is necessary to add tests that use … 4.115
(edit) @33cb8bf   02/17/14 10:40:18 Sebastian Huber score: Add RTEMS_FATAL_SOURCE_BSP Merge … 4.115
(edit) @960fd85   01/28/14 10:52:17 Sebastian Huber bsps: Thread-local storage (TLS) for linkcmds 4.115
(edit) @f6866007   01/14/14 23:33:04 cynt6007 libbsp m68k: Add Doxygen file header to coverhd.h 4.115
(edit) @e327e69   01/09/14 22:05:54 cynt6007 libbsp tm27.h: Add Doxygen file header to all tm27.h 4.115
(edit) @d48ac181   01/01/14 21:30:24 zsoltisharkboy m68k/gen68360: Improve Doxygen 4.115
(edit) @d4960953   01/02/14 17:43:18 radustoma genmcf548x: Improve Doxygen Add doxygen to the header files in the … 4.115
(edit) @7388557   01/03/14 20:18:58 radustoma av5282: Improve Doxygen Add doxygen to the header files in the … 4.115
(edit) @6b1ee025   01/03/14 14:14:49 zsoltisharkboy idp: Add doxygen headers. 4.115
(edit) @56ac38e   01/02/14 15:40:06 radustoma gen68340: Add doxygen header files. 4.115
(edit) @3bba3f58   12/30/13 20:24:12 radustoma gen68302: Add doxygen headers. 4.115
(edit) @7c70c1d7   12/30/13 17:08:13 radustoma m68k_csb360: doxygen improvement Add doxygen to the header files in … 4.115
(edit) @9bb28849   12/26/13 18:51:20 zsoltisharkboy libbsp/m68k: Add doxygen to m68k shared files. 4.115
(edit) @14e1c677   12/11/13 10:42:41 Sebastian Huber bsp/genmcf548x: Increase network TX FIFO watermark This prevents … 4.115
(edit) @a19b915   12/11/13 10:35:10 Sebastian Huber bsp/genmcf548x: Fix network FIFO error handling Use a buffer handling … 4.115
